[U-Boot] [PATCH v1 0/3] arm, am335x: siemens board updates
This series contains some updates for the am335x based boards from siemens. - Patch: arm, am335x, siemens: fix factoryset interpretation fixes an error in the siemens factoryset implementation - Patch: arm, am335x, siemens: read COMP/ver from factoryset reads also the "COMP/ver" value from the siemens factoryset - Patch: arm, am335x: siemens boards add FIT support - adds FIT support as we now boot kernels with DT - create a u-boot envvariable "boardid" which is used for selecting the DT from the FIT image.
Heiko Schocher (3): arm, am335x, siemens: fix factoryset interpretation arm, am335x, siemens: read COMP/ver from factoryset arm, am335x: siemens boards add FIT support
board/siemens/common/board.c | 9 ------- board/siemens/common/factoryset.c | 52 ++++++++++++++++++++++++++------------- board/siemens/common/factoryset.h | 2 ++ board/siemens/draco/board.c | 9 +++++++ board/siemens/pxm2/board.c | 34 +++++++++++++++++++++++++ board/siemens/rut/board.c | 23 +++++++++++++++++ include/configs/pxm2.h | 4 +++ include/configs/rut.h | 4 +++ 8 files changed, 111 insertions(+), 26 deletions(-)
a record could contain other records, so after an ">" (begin mark) there not always come an end mark "<", instead a ">" is possible. Take care of this.
Signed-off-by: Heiko Schocher hs@denx.de
board/siemens/common/factoryset.c | 26 ++++++++++++++++++-------- 1 file changed, 18 insertions(+), 8 deletions(-)
diff --git a/board/siemens/common/factoryset.c b/board/siemens/common/factoryset.c index 266dbbb..d98e59d 100644 --- a/board/siemens/common/factoryset.c +++ b/board/siemens/common/factoryset.c @@ -86,6 +86,7 @@ int get_factory_record_val(unsigned char *eeprom_buf, int size, uchar *record, int i, nxt = 0; int c; unsigned char end = 0xff; + unsigned char tmp;
for (i = 0; fact_get_char(i) != end; i = nxt) { nxt = i + 1; @@ -93,6 +94,7 @@ int get_factory_record_val(unsigned char *eeprom_buf, int size, uchar *record, int pos; int endpos; int z; + int level = 0;
c = strncmp((char *)&eeprom_buf[i + 1], (char *)record, strlen((char *)record)); @@ -103,22 +105,30 @@ int get_factory_record_val(unsigned char *eeprom_buf, int size, uchar *record, /* search for "<" */ c = -1; for (z = pos; fact_get_char(z) != end; z++) { - if ((fact_get_char(z) == '<') || - (fact_get_char(z) == '>')) { - endpos = z; - nxt = endpos; - c = 0; - break; + if (fact_get_char(z) == '<') { + if (level == 0) { + endpos = z; + nxt = endpos; + c = 0; + break; + } else { + level--; + } } + if (fact_get_char(z) == '>') + level++; } + } else { + continue; } if (c == 0) { /* end found -> call get_factory_val */ + tmp = eeprom_buf[endpos]; eeprom_buf[endpos] = end; ret = get_factory_val(&eeprom_buf[pos], - size - pos, name, buf, len); + endpos - pos, name, buf, len); /* fix buffer */ - eeprom_buf[endpos] = '<'; + eeprom_buf[endpos] = tmp; debug("%s: %s.%s = %s\n", __func__, record, name, buf); return ret;
Applied to u-boot-ti/master, thanks!
Signed-off-by: Heiko Schocher hs@denx.de ---
board/siemens/common/factoryset.c | 10 ++++++++++ board/siemens/common/factoryset.h | 1 + 2 files changed, 11 insertions(+)
diff --git a/board/siemens/common/factoryset.c b/board/siemens/common/factoryset.c index d98e59d..be0091d 100644 --- a/board/siemens/common/factoryset.c +++ b/board/siemens/common/factoryset.c @@ -249,6 +249,16 @@ int factoryset_read_eeprom(int i2c_addr) debug("version number: %d\n", factory_dat.version); }
+ /* Get COMP/ver from factory set if available */ + if (0 <= get_factory_record_val(cp, size, (uchar *)"COMP", + (uchar *)"ver", + factory_dat.comp_version, + MAX_STRING_LENGTH)) { + debug("factoryset COMP/ver: %s\n", factory_dat.comp_version); + } else { + strcpy((char *)factory_dat.comp_version, "1.0"); + } + return 0;
err: diff --git a/board/siemens/common/factoryset.h b/board/siemens/common/factoryset.h index 4d6de10..7667b96 100644 --- a/board/siemens/common/factoryset.h +++ b/board/siemens/common/factoryset.h @@ -20,6 +20,7 @@ struct factorysetcontainer { #endif unsigned char serial[MAX_STRING_LENGTH]; int version; + uchar comp_version[MAX_STRING_LENGTH]; };
int factoryset_read_eeprom(int i2c_addr);
add FIT support and set "boardid" from factoryset records "DEV/id" and "COMP/ver". "boardid" is used for selecting which fit configuration gets booted on the board.
board/siemens/common/board.c | 9 --------- board/siemens/common/factoryset.c | 18 ++++++++---------- board/siemens/common/factoryset.h | 1 + board/siemens/draco/board.c | 9 +++++++++ board/siemens/pxm2/board.c | 34 ++++++++++++++++++++++++++++++++++ board/siemens/rut/board.c | 23 +++++++++++++++++++++++ include/configs/pxm2.h | 4 ++++ include/configs/rut.h | 4 ++++ 8 files changed, 83 insertions(+), 19 deletions(-)
diff --git a/board/siemens/common/board.c b/board/siemens/common/board.c index 2782bcc..cc0ac6b 100644 --- a/board/siemens/common/board.c +++ b/board/siemens/common/board.c @@ -96,15 +96,6 @@ const struct dpll_params *get_dpll_ddr_params(void) return &dpll_ddr; }
-#ifdef CONFIG_BOARD_LATE_INIT -int board_late_init(void) -{ - omap_nand_switch_ecc(1, 8); - - return 0; -} -#endif - #ifndef CONFIG_SPL_BUILD #if defined(BOARD_DFU_BUTTON_GPIO) /* diff --git a/board/siemens/common/factoryset.c b/board/siemens/common/factoryset.c index be0091d..7baac3d 100644 --- a/board/siemens/common/factoryset.c +++ b/board/siemens/common/factoryset.c @@ -220,15 +220,6 @@ int factoryset_read_eeprom(int i2c_addr) printf("DFU USB: VID = 0x%4x, PID = 0x%4x\n", factory_dat.usb_vendor_id, factory_dat.usb_product_id); #endif - if (0 <= get_factory_record_val(cp, size, (uchar *)"DEV", - (uchar *)"id", buf, - MAX_STRING_LENGTH)) { - if (strncmp((const char *)buf, "PXM50", 5) == 0) - factory_dat.pxm50 = 1; - else - factory_dat.pxm50 = 0; - } - debug("PXM50: %d\n", factory_dat.pxm50); #if defined(CONFIG_VIDEO) if (0 <= get_factory_record_val(cp, size, (uchar *)"DISP1", (uchar *)"name", factory_dat.disp_name, @@ -248,7 +239,14 @@ int factoryset_read_eeprom(int i2c_addr) NULL, 16); debug("version number: %d\n", factory_dat.version); } - + /* Get ASN from factory set if available */ + if (0 <= get_factory_record_val(cp, size, (uchar *)"DEV", + (uchar *)"id", factory_dat.asn, + MAX_STRING_LENGTH)) { + debug("factoryset asn: %s\n", factory_dat.asn); + } else { + factory_dat.asn[0] = 0; + } /* Get COMP/ver from factory set if available */ if (0 <= get_factory_record_val(cp, size, (uchar *)"COMP", (uchar *)"ver", diff --git a/board/siemens/common/factoryset.h b/board/siemens/common/factoryset.h index 7667b96..3f23d5e 100644 --- a/board/siemens/common/factoryset.h +++ b/board/siemens/common/factoryset.h @@ -20,6 +20,7 @@ struct factorysetcontainer { #endif unsigned char serial[MAX_STRING_LENGTH]; int version; + uchar asn[MAX_STRING_LENGTH]; uchar comp_version[MAX_STRING_LENGTH]; };
diff --git a/board/siemens/draco/board.c b/board/siemens/draco/board.c index 9be2e34..ede73ba 100644 --- a/board/siemens/draco/board.c +++ b/board/siemens/draco/board.c @@ -280,4 +280,13 @@ U_BOOT_CMD( #endif /* #if defined(CONFIG_DRIVER_TI_CPSW) */ #endif /* #if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) */
+#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + omap_nand_switch_ecc(1, 8); + + return 0; +} +#endif + #include "../common/board.c" diff --git a/board/siemens/pxm2/board.c b/board/siemens/pxm2/board.c index 559af0e..264ba02 100644 --- a/board/siemens/pxm2/board.c +++ b/board/siemens/pxm2/board.c @@ -428,4 +428,38 @@ static int board_video_init(void) return 0; } #endif + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + int ret; + + omap_nand_switch_ecc(1, 8); + +#ifdef CONFIG_FACTORYSET + if (factory_dat.asn[0] != 0) { + char tmp[2 * MAX_STRING_LENGTH + 2]; + + if (strncmp((const char *)factory_dat.asn, "PXM50", 5) == 0) + factory_dat.pxm50 = 1; + else + factory_dat.pxm50 = 0; + sprintf(tmp, "%s_%s", factory_dat.asn, + factory_dat.comp_version); + ret = setenv("boardid", tmp); + if (ret) + printf("error setting board id\n"); + } else { + factory_dat.pxm50 = 1; + ret = setenv("boardid", "PXM50_1.0"); + if (ret) + printf("error setting board id\n"); + } + debug("PXM50: %d\n", factory_dat.pxm50); +#endif + + return 0; +} +#endif + #include "../common/board.c" diff --git a/board/siemens/rut/board.c b/board/siemens/rut/board.c index 1752df2..fb840f7 100644 --- a/board/siemens/rut/board.c +++ b/board/siemens/rut/board.c @@ -467,4 +467,27 @@ static int board_video_init(void) return 0; } #endif /* ifdef CONFIG_VIDEO */ + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + int ret; + char tmp[2 * MAX_STRING_LENGTH + 2]; + + omap_nand_switch_ecc(1, 8); + + if (factory_dat.asn[0] != 0) + sprintf(tmp, "%s_%s", factory_dat.asn, + factory_dat.comp_version); + else + sprintf(tmp, "QMX7.E38_4.0"); + + ret = setenv("boardid", tmp); + if (ret) + printf("error setting board id\n"); + + return 0; +} +#endif + #include "../common/board.c" diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index d75d562..946b2c8 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -150,4 +150,8 @@ #define CONFIG_SYS_CONSOLE_FG_COL 0x00 #endif
+#ifndef CONFIG_SPL_BUILD +#define CONFIG_FIT +#endif + #endif /* ! __CONFIG_PXM2_H */ diff --git a/include/configs/rut.h b/include/configs/rut.h index 6bddede..0067ea4 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -154,4 +154,8 @@ #define CONFIG_SYS_CONSOLE_FG_COL 0x00 #endif
+#ifndef CONFIG_SPL_BUILD +#define CONFIG_FIT +#endif + #endif /* ! __CONFIG_RUT_H */
Heiko Schocher
