[U-Boot] [PATCH 15/22] ppc4xx: remove WUH405 board
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- arch/powerpc/cpu/ppc4xx/Kconfig | 4 - board/esd/wuh405/Kconfig | 12 - board/esd/wuh405/MAINTAINERS | 6 - board/esd/wuh405/Makefile | 10 - board/esd/wuh405/flash.c | 85 - board/esd/wuh405/fpgadata.c | 3636 --------------------------------------- board/esd/wuh405/wuh405.c | 171 -- configs/WUH405_defconfig | 3 - doc/README.scrapyard | 1 + include/configs/WUH405.h | 346 ---- 10 files changed, 1 insertion(+), 4273 deletions(-) delete mode 100644 board/esd/wuh405/Kconfig delete mode 100644 board/esd/wuh405/MAINTAINERS delete mode 100644 board/esd/wuh405/Makefile delete mode 100644 board/esd/wuh405/flash.c delete mode 100644 board/esd/wuh405/fpgadata.c delete mode 100644 board/esd/wuh405/wuh405.c delete mode 100644 configs/WUH405_defconfig delete mode 100644 include/configs/WUH405.h
diff --git a/arch/powerpc/cpu/ppc4xx/Kconfig b/arch/powerpc/cpu/ppc4xx/Kconfig index 9884894..6c4759a 100644 --- a/arch/powerpc/cpu/ppc4xx/Kconfig +++ b/arch/powerpc/cpu/ppc4xx/Kconfig @@ -137,9 +137,6 @@ config TARGET_PMC440 config TARGET_VOM405 bool "Support VOM405"
-config TARGET_WUH405 - bool "Support WUH405" - config TARGET_DLVISION_10G bool "Support dlvision-10g"
@@ -221,7 +218,6 @@ source "board/esd/plu405/Kconfig" source "board/esd/pmc405de/Kconfig" source "board/esd/pmc440/Kconfig" source "board/esd/vom405/Kconfig" -source "board/esd/wuh405/Kconfig" source "board/g2000/Kconfig" source "board/gdsys/405ep/Kconfig" source "board/gdsys/405ex/Kconfig" diff --git a/board/esd/wuh405/Kconfig b/board/esd/wuh405/Kconfig deleted file mode 100644 index 8a7df4d..0000000 --- a/board/esd/wuh405/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_WUH405 - -config SYS_BOARD - default "wuh405" - -config SYS_VENDOR - default "esd" - -config SYS_CONFIG_NAME - default "WUH405" - -endif diff --git a/board/esd/wuh405/MAINTAINERS b/board/esd/wuh405/MAINTAINERS deleted file mode 100644 index 782c72a..0000000 --- a/board/esd/wuh405/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -WUH405 BOARD -M: Matthias Fuchs matthias.fuchs@esd-electronics.com -S: Maintained -F: board/esd/wuh405/ -F: include/configs/WUH405.h -F: configs/WUH405_defconfig diff --git a/board/esd/wuh405/Makefile b/board/esd/wuh405/Makefile deleted file mode 100644 index b9beeff..0000000 --- a/board/esd/wuh405/Makefile +++ /dev/null @@ -1,10 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = wuh405.o flash.o \ - ../common/misc.o \ - ../common/esd405ep_nand.o \ diff --git a/board/esd/wuh405/flash.c b/board/esd/wuh405/flash.c deleted file mode 100644 index 23e8164..0000000 --- a/board/esd/wuh405/flash.c +++ /dev/null @@ -1,85 +0,0 @@ -/* - * (C) Copyright 2001 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/ppc4xx.h> -#include <asm/processor.h> - -/* - * include common flash code (for esd boards) - */ -#include "../common/flash.c" - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long * addr, flash_info_t * info); -static void flash_get_offsets (ulong base, flash_info_t * info); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - unsigned long size_b0; - int i; - uint pbcr; - unsigned long base_b0; - int size_val = 0; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size_b0 = flash_get_size((vu_long *)FLASH_BASE0_PRELIM, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0<<20); - } - - /* Setup offsets */ - flash_get_offsets (-size_b0, &flash_info[0]); - - /* Re-do sizing to get full correct info */ - mtdcr(EBC0_CFGADDR, PB0CR); - pbcr = mfdcr(EBC0_CFGDATA); - mtdcr(EBC0_CFGADDR, PB0CR); - base_b0 = -size_b0; - switch (size_b0) { - case 1 << 20: - size_val = 0; - break; - case 2 << 20: - size_val = 1; - break; - case 4 << 20: - size_val = 2; - break; - case 8 << 20: - size_val = 3; - break; - case 16 << 20: - size_val = 4; - break; - } - pbcr = (pbcr & 0x0001ffff) | base_b0 | (size_val << 17); - mtdcr(EBC0_CFGDATA, pbcr); - - /* Monitor protection ON by default */ - (void)flash_protect(FLAG_PROTECT_SET, - -CONFIG_SYS_MONITOR_LEN, - 0xffffffff, - &flash_info[0]); - - flash_info[0].size = size_b0; - - return (size_b0); -} diff --git a/board/esd/wuh405/fpgadata.c b/board/esd/wuh405/fpgadata.c deleted file mode 100644 index a964f9f..0000000 --- a/board/esd/wuh405/fpgadata.c +++ /dev/null @@ -1,3636 +0,0 @@ -0x1f, 0x8b, 0x08, 0x08, 0xe2, 0x44, 0xc5, 0x42, -0x00, 0x03, 0x77, 0x75, 0x68, 0x34, 0x30, 0x35, -0x5f, 0x31, 0x2e, 0x62, 0x69, 0x74, 0x00, 0xec, -0xbd, 0x0d, 0x74, 0x14, 0xd7, 0x95, 0x2e, 0xba, -0xeb, 0x54, 0x49, 0x94, 0xba, 0x5b, 0xea, 0x42, -0x48, 0x1e, 0xd9, 0x60, 0x5c, 0x6a, 0x09, 0xd2, -0x28, 0x8d, 0x68, 0x24, 0x47, 0x60, 0x21, 0x4b, -0x45, 0x8b, 0x78, 0x14, 0x20, 0x41, 0xe3, 0x78, -0x12, 0xee, 0x7d, 0x5e, 0x99, 0xb6, 0x43, 0x66, -0x78, 0x33, 0xc4, 0x97, 0xc4, 0xb9, 0x77, 0x88, -0x27, 0xd7, 0x3e, 0x6a, 0x09, 0x23, 0x2c, 0x6c, -0xda, 0x36, 0x89, 0x71, 0xe2, 0xc9, 0x34, 0x98, -0x24, 0xd8, 0x61, 0x32, 0x0d, 0xc2, 0x46, 0x80, -0x63, 0x97, 0xb0, 0xe2, 0x34, 0x58, 0xc6, 0x8a, -0xe3, 0xc9, 0x60, 0xcc, 0xe0, 0x26, 0x51, 0x6c, -0xd9, 0x96, 0xb1, 0x8c, 0x19, 0x5b, 0x20, 0x40, -0xef, 0xec, 0x53, 0x5d, 0xd5, 0x55, 0xfd, 0x23, -0x27, 0x77, 0xd6, 0xbc, 0x35, 0x6f, 0xbd, 0x61, -0xd6, 0xba, 0x77, 0xa7, 0xba, 0x52, 0xa9, 0x73, -0x74, 0x6a, 0xef, 0xef, 0x7c, 0xfb, 0xdb, 0xfb, -0x40, 0x91, 0x77, 0xcc, 0xf8, 0x3f, 0x00, 0xe1, -0x36, 0x28, 0xfe, 0xdb, 0xff, 0xb9, 0xf6, 0xfa, -0xe0, 0x67, 0xfe, 0x62, 0x61, 0xed, 0x1d, 0x5f, -0x5d, 0x03, 0xb7, 0x83, 0xbb, 0xee, 0xce, 0xcf, -0x04, 0xbf, 0xf6, 0xad, 0x6f, 0x2c, 0xbc, 0xfe, -0x7a, 0xf8, 0x2a, 0xfb, 0x4f, 0xc1, 0xe0, 0x67, -0x16, 0x04, 0x17, 0x2d, 0x08, 0x2e, 0x84, 0x35, -0x50, 0xb4, 0xf0, 0x33, 0x8d, 0x75, 0x8b, 0x1b, -0x83, 0xf5, 0xf0, 0x35, 0x10, 0xea, 0x77, 0x4d, -0xb2, 0x7f, 0x4f, 0x3e, 0xfa, 0xe7, 0x7f, 0x19, -0x04, 0x2a, 0x00, 0xc0, 0xb4, 0xa0, 0x10, 0xc6, -0xff, 0xdf, 0x1d, 0x14, 0x54, 0x01, 0x68, 0xcb, -0xfc, 0x20, 0xe8, 0xf8, 0x9f, 0x21, 0xf5, 0x7b, -0x51, 0x10, 0x54, 0xfb, 0x7f, 0x16, 0x82, 0xa0, -0x41, 0x3b, 0x68, 0x5b, 0x84, 0x52, 0xf8, 0x43, -0xfe, 0x75, 0xd1, 0x94, 0x21, 0xfd, 0x61, 0xf7, -0x4b, 0xe6, 0xfd, 0x93, 0xc7, 0x68, 0xde, 0x9b, -0xd2, 0xff, 0x5a, 0xce, 0xc5, 0x52, 0x56, 0x01, -0x09, 0x7e, 0xf2, 0xed, 0x82, 0x46, 0xcd, 0xa7, -0x5e, 0x3c, 0xf9, 0x07, 0x3d, 0xff, 0x7f, 0x99, -0xcf, 0xbf, 0xf2, 0x47, 0xde, 0x0f, 0xca, 0x1f, -0x70, 0x3b, 0x1b, 0xaf, 0x69, 0x5c, 0x54, 0x40, -0x06, 0x02, 0x40, 0xc1, 0x0f, 0x2e, 0x20, 0x14, -0x62, 0xb9, 0x8c, 0x96, 0x65, 0xe6, 0xfd, 0xfa, -0xc6, 0x2b, 0x30, 0xd1, 0xd9, 0x92, 0x74, 0x8f, -0x88, 0xdf, 0xaa, 0x98, 0xa4, 0x0d, 0x27, 0x8a, -0xc7, 0xc4, 0x3a, 0x66, 0xb4, 0x0c, 0x7b, 0xc7, -0xc5, 0x31, 0x78, 0x83, 0xd6, 0x27, 0xd1, 0x10, -0xc2, 0xe6, 0xfd, 0x15, 0x3f, 0x86, 0xc3, 0xb4, -0x36, 0xe9, 0xde, 0x4d, 0xe6, 0x42, 0x4f, 0x75, -0x65, 0x7f, 0xcf, 0x37, 0x9e, 0xf7, 0xe1, 0x95, -0x84, 0xb7, 0x8f, 0xbc, 0x09, 0x3d, 0xd4, 0x97, -0x74, 0xf7, 0x91, 0xa4, 0x64, 0xce, 0x62, 0x42, -0xea, 0x92, 0x7b, 0x21, 0xa0, 0xbb, 0x63, 0x85, -0xc3, 0xd0, 0x2b, 0x07, 0x06, 0xdd, 0x41, 0x02, -0x78, 0x25, 0xc1, 0x8c, 0x63, 0xd2, 0xc3, 0x92, -0xaa, 0x33, 0xe3, 0x88, 0xa0, 0x9a, 0xcf, 0x2f, -0x18, 0x86, 0xc3, 0x50, 0xdb, 0xcf, 0x9e, 0x1f, -0x9b, 0xde, 0x09, 0x35, 0xfd, 0x2b, 0xe2, 0x35, -0x7e, 0x38, 0x4c, 0x6a, 0x75, 0x77, 0x1c, 0x9f, -0x0f, 0x3e, 0x34, 0xc6, 0xa4, 0xf5, 0xa9, 0xfb, -0x97, 0x96, 0x8f, 0xc2, 0x04, 0x34, 0xeb, 0xde, -0x1a, 0xf1, 0x26, 0x8a, 0x46, 0x71, 0x7c, 0x86, -0x9f, 0x5d, 0x99, 0xad, 0x5f, 0x17, 0x17, 0xcf, -0xc2, 0xeb, 0x50, 0xa7, 0x7b, 0xe3, 0xe2, 0xd0, -0x32, 0xf3, 0xfe, 0xb8, 0xb0, 0x1f, 0x26, 0xa1, -0x45, 0xf7, 0x26, 0x3b, 0xbe, 0xc6, 0x8c, 0x45, -0xfa, 0xaa, 0x31, 0x71, 0xbf, 0x3a, 0x49, 0x5a, -0xf4, 0x92, 0xb1, 0x69, 0x83, 0xec, 0xca, 0x73, -0xba, 0x77, 0x4c, 0x1c, 0x01, 0x73, 0xbc, 0x43, -0xca, 0x2e, 0xe3, 0xf9, 0x31, 0x71, 0x97, 0x3e, -0x01, 0x8d, 0x7a, 0x71, 0x50, 0x9c, 0x27, 0x4d, -0x48, 0xcd, 0xfd, 0x5e, 0x7c, 0xfe, 0xbb, 0xa4, -0x19, 0x9f, 0x3f, 0x26, 0x99, 0xef, 0x9f, 0x28, -0xa8, 0xc6, 0xf7, 0xd7, 0xdd, 0xbb, 0xe9, 0xa7, -0xd8, 0xdb, 0x56, 0xe9, 0xf2, 0x18, 0x99, 0x4f, -0x71, 0x44, 0x33, 0xe3, 0x64, 0x14, 0x3a, 0x81, -0x0f, 0xe4, 0x1c, 0x5b, 0xfd, 0xa9, 0xf1, 0x4a, -0x2b, 0x81, 0xcf, 0x8f, 0x9f, 0xfc, 0x52, 0x7a, -0x5c, 0xf0, 0xb3, 0xd9, 0x28, 0xfc, 0x53, 0xe3, -0x4a, 0x90, 0xe8, 0xf0, 0xb8, 0x61, 0x8c, 0xb3, -0x6f, 0xc5, 0xf8, 0x37, 0xa6, 0x7c, 0x49, 0x3b, -0x10, 0x9b, 0x9f, 0x74, 0x7f, 0xdb, 0x75, 0x15, -0x6c, 0xa2, 0x95, 0x23, 0xae, 0x6f, 0xcf, 0x7e, -0x05, 0x0e, 0xc4, 0xbe, 0x3e, 0xe2, 0xde, 0x40, -0xde, 0x60, 0x57, 0xd8, 0x4f, 0x1b, 0xc8, 0x09, -0xeb, 0xf9, 0x6d, 0xf2, 0x32, 0xf8, 0x30, 0xde, -0xa4, 0x7b, 0x55, 0xb1, 0x8b, 0x0d, 0x64, 0x71, -0xd2, 0x1b, 0x14, 0xff, 0xf4, 0xc4, 0x87, 0xd1, -0xa6, 0x11, 0x77, 0x50, 0x1c, 0x84, 0xdf, 0x01, -0xfb, 0x29, 0x28, 0xbe, 0x42, 0xcc, 0xf5, 0xa0, -0x15, 0xec, 0x57, 0x26, 0xcb, 0xd8, 0xfc, 0x28, -0xe2, 0x7e, 0x78, 0x1f, 0x1a, 0x87, 0x8a, 0xe3, -0xa2, 0xdf, 0x98, 0xb1, 0xb1, 0xaa, 0xd4, 0x54, -0x8f, 0x89, 0x43, 0xc4, 0x9c, 0x1f, 0x59, 0xda, -0x03, 0x2f, 0xe2, 0x45, 0x75, 0xda, 0xb7, 0x60, -0x82, 0x36, 0xbe, 0xea, 0x79, 0xfa, 0xc5, 0xf9, -0x2a, 0xbb, 0x2d, 0xe9, 0x89, 0xb3, 0x69, 0xe4, -0xf7, 0xc7, 0xc5, 0x63, 0x60, 0xcd, 0x4f, 0xc5, -0x36, 0xf8, 0x17, 0x98, 0xaf, 0xbb, 0xc3, 0x64, -0x16, 0x3c, 0x07, 0x6a, 0xa2, 0xf8, 0x9b, 0xe2, -0x2d, 0xf4, 0x80, 0x34, 0x5f, 0x97, 0xd7, 0x93, -0x53, 0x70, 0x00, 0x7f, 0x5a, 0x4f, 0xce, 0x59, -0xf3, 0xa9, 0xc2, 0xd3, 0x7c, 0x50, 0x3d, 0x23, -0x91, 0xef, 0x49, 0x07, 0x22, 0xf3, 0x46, 0xe4, -0x1b, 0xc8, 0x57, 0xb4, 0x03, 0xec, 0x4a, 0xd1, -0x06, 0x72, 0x1a, 0x0e, 0x18, 0xe3, 0xd5, 0xad, -0xe7, 0x8f, 0x48, 0x5d, 0xf0, 0x30, 0x9f, 0xcf, -0x23, 0xf7, 0xb2, 0x69, 0x54, 0xf5, 0xa2, 0x60, -0xe8, 0x0b, 0x6a, 0xaf, 0x18, 0xd0, 0xe5, 0x20, -0x39, 0x4e, 0x53, 0x13, 0xfb, 0x8a, 0xf5, 0xfc, -0x64, 0xf9, 0x08, 0x1c, 0x83, 0x66, 0xea, 0x1d, -0x15, 0x0f, 0xeb, 0x17, 0xa1, 0x91, 0x7a, 0x62, -0x55, 0x7f, 0x43, 0x2f, 0xb2, 0x2b, 0x81, 0x98, -0x38, 0xce, 0x0d, 0xf6, 0xa7, 0x1f, 0x97, 0xcc, -0xf1, 0xb6, 0x09, 0x31, 0x18, 0x87, 0x66, 0xf0, -0x52, 0xb7, 0xca, 0x8d, 0x05, 0xb4, 0x2a, 0x09, -0xe3, 0x04, 0xaf, 0x88, 0x67, 0x52, 0x3f, 0x89, -0xaf, 0x80, 0xb9, 0xfe, 0x65, 0xb6, 0x7e, 0x8e, -0x42, 0xb3, 0xe6, 0xfd, 0xbe, 0xb8, 0x0b, 0x5e, -0x83, 0x26, 0xcd, 0x13, 0x15, 0xab, 0xe1, 0xa0, -0xc0, 0xae, 0x44, 0xc5, 0xbf, 0xa4, 0x17, 0x80, -0x1b, 0x47, 0xac, 0xef, 0x85, 0x4a, 0xcb, 0xc8, -0x66, 0xa8, 0xd5, 0xdc, 0x65, 0x44, 0x62, 0xf7, -0xd7, 0x6a, 0xc5, 0x51, 0x12, 0xf0, 0x1c, 0xc4, -0x2b, 0xd1, 0xd2, 0xdf, 0x53, 0xc3, 0x20, 0x49, -0xcb, 0x2d, 0x2c, 0x16, 0xaa, 0xa5, 0xcd, 0x42, -0xad, 0xb6, 0x22, 0x5a, 0xba, 0x4b, 0x79, 0x94, -0xfd, 0xea, 0x57, 0x08, 0x7b, 0xbe, 0x71, 0xdb, -0xb0, 0x69, 0xbc, 0x60, 0xad, 0x07, 0x7f, 0x59, -0x35, 0x74, 0xc0, 0x3a, 0x76, 0xf1, 0xa6, 0xea, -0xd8, 0x83, 0x10, 0x58, 0x5e, 0x54, 0x7a, 0x4c, -0x82, 0xbd, 0x10, 0xd0, 0xdc, 0x0a, 0x19, 0x88, -0xa5, 0x8c, 0x23, 0x82, 0xb9, 0x1e, 0x36, 0x14, -0x87, 0xa1, 0x1b, 0x07, 0x15, 0x13, 0x63, 0xf4, -0x04, 0x34, 0xcb, 0x9e, 0xc8, 0x0c, 0x1c, 0x78, -0x13, 0x0e, 0x33, 0x4c, 0x53, 0xe3, 0x3d, 0x2d, -0x9a, 0xeb, 0x73, 0x7b, 0xc1, 0xab, 0xc0, 0x07, -0x35, 0x24, 0x9e, 0x87, 0x0b, 0xfe, 0xe6, 0xe5, -0x25, 0x0f, 0x75, 0x0e, 0xe3, 0x95, 0xe5, 0x6c, -0x98, 0xe7, 0x21, 0x35, 0xde, 0x37, 0x89, 0xf9, -0x3d, 0x56, 0x94, 0x0f, 0x1b, 0x17, 0xdb, 0xc5, -0x6a, 0x7a, 0x14, 0xee, 0x0a, 0x05, 0xb6, 0x89, -0xec, 0x8a, 0xd4, 0x8c, 0x13, 0x75, 0x5e, 0xbd, -0x6c, 0xdc, 0xff, 0x02, 0x98, 0xf7, 0x2f, 0x56, -0x92, 0xd0, 0x07, 0xb5, 0xcc, 0xd1, 0xb8, 0x6f, -0x63, 0x2f, 0xe6, 0x03, 0x79, 0x13, 0xe1, 0x57, -0x64, 0x17, 0x35, 0x0c, 0x70, 0x53, 0x72, 0xdc, -0x9a, 0xff, 0x36, 0xe8, 0x82, 0xbd, 0x42, 0x40, -0x9b, 0xa9, 0x7c, 0x69, 0x0e, 0xec, 0x90, 0xfd, -0x21, 0xb9, 0x94, 0x0c, 0xe0, 0x78, 0x43, 0xb2, -0x82, 0x86, 0x10, 0x58, 0xca, 0xc6, 0xfb, 0x8a, -0x60, 0x3e, 0x7f, 0x7b, 0xd9, 0x2e, 0x36, 0x69, -0x25, 0x6c, 0x7e, 0x0a, 0xbf, 0x46, 0x3a, 0x40, -0xd5, 0xe4, 0x68, 0x68, 0x98, 0x4d, 0x7b, 0x40, -0x73, 0x45, 0x99, 0xff, 0x31, 0xe6, 0x33, 0xf4, -0xa6, 0xb5, 0x1e, 0x62, 0x05, 0x7f, 0x69, 0xbc, -0xbf, 0x22, 0x4e, 0xd3, 0xde, 0x96, 0x6a, 0xf0, -0xb5, 0xd9, 0xfb, 0x0b, 0xcd, 0x4b, 0x67, 0xb1, -0x61, 0xaa, 0x38, 0x10, 0xf6, 0xfe, 0x23, 0x96, -0xbf, 0x4a, 0x4c, 0xdf, 0x65, 0xfc, 0xd1, 0x1f, -0xab, 0x3a, 0x2b, 0xa7, 0x66, 0x63, 0x18, 0x32, -0x8d, 0x8b, 0x96, 0xff, 0x91, 0x15, 0x73, 0xbd, -0x89, 0x61, 0x7d, 0x04, 0x6a, 0x05, 0x0f, 0x15, -0x55, 0x3e, 0xed, 0x1e, 0x63, 0xbd, 0x35, 0xe2, -0x4f, 0xc7, 0xac, 0xf5, 0xec, 0x2f, 0xf0, 0xc3, -0x21, 0x61, 0x2e, 0x75, 0x0f, 0xbb, 0xe6, 0x49, -0x87, 0xa0, 0x96, 0xca, 0xb1, 0xba, 0x79, 0xd4, -0x30, 0x98, 0x1b, 0x39, 0x04, 0x3e, 0xea, 0x8e, -0x91, 0x63, 0xe9, 0xf5, 0x60, 0xfa, 0x9f, 0xea, -0xc8, 0x4a, 0x19, 0xbd, 0x4d, 0x5b, 0x90, 0x94, -0xf0, 0x2b, 0xf8, 0xbd, 0x30, 0x03, 0x3d, 0x12, -0xbb, 0xdf, 0x5c, 0x6f, 0x54, 0xb9, 0x95, 0x7d, -0xa4, 0x73, 0xd8, 0xf7, 0xeb, 0xba, 0x05, 0x0e, -0xa8, 0x81, 0x81, 0x8a, 0x6f, 0xbb, 0xca, 0xf0, -0xb3, 0x4d, 0xb0, 0xef, 0xf7, 0x5f, 0xe1, 0x39, -0x5a, 0x89, 0xdf, 0xef, 0x88, 0x75, 0x7f, 0x77, -0xf7, 0x57, 0x94, 0x8f, 0xe9, 0x8d, 0x49, 0xef, -0x06, 0xf1, 0x2b, 0xf0, 0x57, 0x4f, 0xdc, 0xf8, -0xbb, 0x59, 0x17, 0xc5, 0xd9, 0xf0, 0x71, 0x47, -0xcb, 0xc5, 0xc0, 0x06, 0xf1, 0x34, 0x4c, 0xd2, -0x1b, 0xf0, 0xa7, 0x77, 0xe6, 0x9a, 0xf7, 0xcb, -0x05, 0x7b, 0xb8, 0xf7, 0x66, 0x83, 0xda, 0x15, -0x9b, 0x50, 0x9b, 0x13, 0xde, 0xfd, 0xc2, 0x30, -0xba, 0x91, 0xa3, 0xcc, 0x8d, 0x24, 0x4d, 0x7f, -0x72, 0xe4, 0x5e, 0x73, 0x7e, 0x40, 0x7a, 0x96, -0xb9, 0x1d, 0x16, 0xbf, 0xd6, 0x8a, 0x77, 0x2c, -0x7b, 0xa3, 0x7b, 0xd1, 0xb0, 0xe7, 0xb2, 0xd8, -0x22, 0xbc, 0x1b, 0xad, 0x39, 0xe3, 0x19, 0x17, -0x9f, 0xd6, 0x58, 0x20, 0xc3, 0xf8, 0xa5, 0xc7, -0xcc, 0xf9, 0xdf, 0x5d, 0xf1, 0x18, 0x7a, 0x0f, -0xdd, 0xbd, 0x8e, 0x94, 0xc2, 0x5b, 0xb0, 0xe0, -0x8c, 0xff, 0x2e, 0x42, 0x76, 0xfd, 0x3a, 0x56, -0x9b, 0x2c, 0x5e, 0x4f, 0x4e, 0x2b, 0xdc, 0x9f, -0xac, 0x27, 0xef, 0x58, 0x7f, 0x5f, 0xa0, 0x8f, -0xb1, 0xd1, 0x7d, 0x5d, 0x77, 0xaf, 0x89, 0xdc, -0x1a, 0xdb, 0x04, 0xf3, 0x07, 0x8a, 0xea, 0x6e, -0x6e, 0xea, 0x3e, 0xe0, 0xe3, 0xfe, 0xea, 0x9f, -0x29, 0xfe, 0x34, 0x73, 0xbd, 0xcd, 0xff, 0xa8, -0xd2, 0x03, 0xc6, 0x7c, 0x02, 0x21, 0xf2, 0xe3, -0x85, 0x01, 0xbd, 0x28, 0x7e, 0x4d, 0x2b, 0xf7, -0x48, 0x45, 0x41, 0x9f, 0x6e, 0x3a, 0xf6, 0x84, -0xf5, 0xbd, 0xef, 0x2e, 0x3f, 0xab, 0xf2, 0x41, -0x05, 0xc4, 0xe5, 0xf0, 0x32, 0x8b, 0x47, 0x47, -0xc7, 0x5a, 0xfd, 0x45, 0x13, 0xe4, 0xef, 0x74, -0xe6, 0x3f, 0x7f, 0x4a, 0x53, 0xe3, 0x7d, 0xc7, -0x5a, 0x3f, 0x54, 0xd8, 0x93, 0x8a, 0x47, 0xad, -0x23, 0xd5, 0x68, 0xd4, 0xc6, 0xc5, 0xdd, 0x1d, -0xef, 0xe2, 0x8c, 0xc5, 0xc5, 0x51, 0x01, 0xaf, -0xfc, 0x29, 0x4e, 0x94, 0xf9, 0xfe, 0x95, 0xca, -0x33, 0xa9, 0x78, 0x27, 0x6e, 0x90, 0x5e, 0x26, -0x4b, 0x58, 0x98, 0x9b, 0xd1, 0xd8, 0x75, 0x0f, -0x59, 0xa4, 0x17, 0x8f, 0xb1, 0xf5, 0x80, 0x81, -0x8f, 0xf9, 0x73, 0x7d, 0x99, 0xf9, 0xfe, 0x3b, -0xa4, 0x75, 0xa9, 0xf8, 0x45, 0xe6, 0xd1, 0x1e, -0x1e, 0x76, 0x5b, 0xd7, 0x4a, 0x87, 0x85, 0x5a, -0x7d, 0x45, 0x9c, 0xbc, 0x4b, 0x0f, 0x1b, 0xf1, -0x2b, 0xa9, 0x59, 0xeb, 0xa1, 0x20, 0x20, 0xe3, -0x45, 0xd7, 0x6e, 0xb2, 0x66, 0xd9, 0x0f, 0xa0, -0x04, 0x7f, 0x9d, 0x23, 0xa4, 0x6e, 0x7b, 0x07, -0xcc, 0xfb, 0xad, 0xf5, 0x26, 0x97, 0x79, 0xa0, -0x57, 0x65, 0x93, 0xa0, 0x46, 0x54, 0xb5, 0x53, -0x08, 0x0c, 0xad, 0x08, 0x7e, 0x69, 0xa9, 0x6a, -0xe0, 0x01, 0x18, 0x84, 0x5e, 0x29, 0x60, 0xe0, -0x01, 0x73, 0xfa, 0xa1, 0x78, 0x1d, 0x4c, 0x28, -0xb5, 0x7a, 0x49, 0x4c, 0x5c, 0x03, 0xec, 0xfd, -0x4f, 0xcc, 0x3e, 0x37, 0xa3, 0x5a, 0x99, 0xf0, -0x2d, 0x1a, 0xbc, 0x3f, 0x3e, 0x6d, 0x64, 0x0b, -0xae, 0x90, 0xad, 0x71, 0x51, 0xb7, 0xfc, 0x4f, -0xec, 0x17, 0x97, 0x60, 0x52, 0xbb, 0x0e, 0xe3, -0xf5, 0x10, 0x1b, 0x78, 0xf3, 0x09, 0xef, 0xfe, -0x56, 0x1d, 0x26, 0xd7, 0xb6, 0x0c, 0x62, 0x58, -0xd7, 0x26, 0x94, 0xe6, 0x01, 0x34, 0x0a, 0xcd, -0xf9, 0xd4, 0xcb, 0xaf, 0x00, 0x5f, 0x24, 0x71, -0xb1, 0x59, 0x7a, 0xb9, 0xa3, 0x59, 0xf4, 0xee, -0x23, 0x01, 0x78, 0xff, 0x86, 0x4f, 0x9d, 0x2c, -0x4e, 0x88, 0xef, 0xb4, 0xbd, 0xae, 0xd5, 0x25, -0x03, 0x08, 0x84, 0xac, 0xf9, 0x57, 0xce, 0xca, -0x1c, 0xff, 0x44, 0x4b, 0xd7, 0x31, 0x27, 0x54, -0x1b, 0x77, 0x7f, 0x44, 0xaa, 0x63, 0x5b, 0x97, -0x7d, 0x7a, 0x48, 0xde, 0xcd, 0x96, 0xfd, 0x56, -0xcd, 0x17, 0x92, 0x71, 0xbc, 0x96, 0xff, 0x2f, -0x18, 0x94, 0x53, 0x1f, 0xd1, 0x4a, 0x5c, 0x06, -0xe0, 0x5e, 0xb8, 0x73, 0xa5, 0xf4, 0x38, 0x51, -0x13, 0x45, 0x40, 0xf4, 0xee, 0x47, 0xc3, 0xbe, -0x84, 0x8c, 0xe3, 0xb5, 0xde, 0xa7, 0x60, 0x8f, -0x31, 0x7b, 0x51, 0xb2, 0x0e, 0x7e, 0x00, 0xb5, -0xc9, 0xd6, 0xb8, 0xab, 0x9a, 0xc1, 0x86, 0x1a, -0x5d, 0xde, 0x49, 0x75, 0xc4, 0x3f, 0x9a, 0x8c, -0xf8, 0xc7, 0x5a, 0x9f, 0x5d, 0xe6, 0x7a, 0x70, -0x07, 0xc8, 0xeb, 0xd0, 0xbc, 0x77, 0x55, 0xbc, -0x2a, 0xcc, 0x60, 0x49, 0x9d, 0xfe, 0xf9, 0xa8, -0xf8, 0x36, 0xfc, 0x1a, 0xe2, 0xb8, 0x90, 0x74, -0xcb, 0x3f, 0x9c, 0x81, 0xd4, 0x7a, 0x88, 0x89, -0x4d, 0x2c, 0xbe, 0xb7, 0xd0, 0x7f, 0x08, 0x8a, -0xe3, 0xf0, 0x77, 0xd0, 0xd8, 0xef, 0x4d, 0x3e, -0x3f, 0x8e, 0x3f, 0xb5, 0x7b, 0xc7, 0x3a, 0xc7, -0xcd, 0x3f, 0x17, 0xe8, 0xb0, 0x07, 0xde, 0x35, -0xf0, 0xcf, 0x3a, 0x0c, 0xf4, 0x23, 0x0c, 0x06, -0xc4, 0xe0, 0xfd, 0x82, 0x6b, 0xf4, 0xe2, 0x6d, -0x33, 0xde, 0x91, 0x8e, 0x76, 0x1f, 0xc2, 0xe7, -0xdb, 0xf0, 0x8f, 0x14, 0x30, 0xfe, 0xe8, 0x31, -0x36, 0xd6, 0x1e, 0xa8, 0x1d, 0x73, 0x8f, 0x11, -0x3f, 0x6c, 0x85, 0x4f, 0xf7, 0xbb, 0x62, 0x64, -0x84, 0xa4, 0xde, 0xff, 0x9c, 0xf5, 0xe7, 0x4d, -0x96, 0xaf, 0x34, 0x40, 0x4e, 0xbc, 0x70, 0x1d, -0x1b, 0x66, 0x20, 0xca, 0x26, 0x6a, 0x37, 0x41, -0xe0, 0x57, 0x24, 0x91, 0x04, 0xbb, 0xb2, 0x1b, -0x1d, 0x51, 0x1a, 0xff, 0x84, 0x85, 0xd9, 0x46, -0xd0, 0x5f, 0x5d, 0xf7, 0x15, 0x0e, 0x0c, 0x66, -0xfe, 0x1d, 0x21, 0xdd, 0x9b, 0xa2, 0x0c, 0x08, -0xad, 0x8e, 0x5c, 0x3c, 0xb2, 0x29, 0x56, 0x19, -0x96, 0x9d, 0xf8, 0xc7, 0xa3, 0xfd, 0x0e, 0xf1, -0x4f, 0x93, 0x78, 0x07, 0x79, 0x1e, 0x9a, 0x76, -0x6f, 0xbd, 0x41, 0xec, 0xa1, 0xbf, 0x8b, 0x2d, -0x3e, 0x53, 0x0c, 0xe2, 0x11, 0x7a, 0x34, 0xd6, -0x98, 0x0c, 0x30, 0xfc, 0x63, 0xbd, 0x8f, 0x76, -0x6d, 0x6a, 0x7e, 0x7e, 0x25, 0x72, 0x63, 0x60, -0xda, 0x98, 0x98, 0xd4, 0x26, 0xb4, 0xe6, 0x23, -0x2c, 0xa2, 0x0d, 0x69, 0x93, 0xed, 0xd7, 0x69, -0xde, 0x0f, 0xc4, 0xa1, 0x42, 0x73, 0xfe, 0x77, -0x17, 0x8c, 0x9a, 0x4e, 0x69, 0x1d, 0x37, 0x3c, -0x1f, 0xe2, 0x42, 0x55, 0x0b, 0x13, 0x9e, 0x5e, -0xc4, 0x9f, 0x5a, 0x1d, 0xce, 0xcf, 0x3b, 0x90, -0xf6, 0xff, 0x8f, 0xa5, 0x40, 0x4e, 0xe9, 0x29, -0xe6, 0x7f, 0x98, 0x1b, 0xb9, 0x13, 0x66, 0x41, -0x67, 0xb8, 0x72, 0x70, 0xf9, 0x9d, 0x0c, 0xff, -0xfc, 0x13, 0x7c, 0x1a, 0x1d, 0xcb, 0x39, 0xeb, -0xef, 0xab, 0xc3, 0x0f, 0x4d, 0x90, 0x83, 0x68, -0x27, 0x30, 0xc6, 0x60, 0xcf, 0x4d, 0xbe, 0x4d, -0x3b, 0x7f, 0x3f, 0xd2, 0xb6, 0x21, 0x34, 0x09, -0xdf, 0xa5, 0x95, 0x49, 0x36, 0xde, 0x31, 0xcb, -0xff, 0xb4, 0x95, 0x0d, 0x1a, 0x4e, 0xa6, 0x8f, -0x0c, 0xc2, 0xe3, 0x02, 0xbb, 0x3f, 0x4e, 0x8a, -0x69, 0x8f, 0xb4, 0x46, 0x77, 0x2d, 0x26, 0x2f, -0xb1, 0xa9, 0xae, 0x4d, 0xfa, 0x11, 0xff, 0x98, -0xeb, 0x73, 0xa4, 0x7c, 0x37, 0x70, 0x90, 0x73, -0x56, 0x5c, 0x2b, 0x5d, 0x14, 0xee, 0xe9, 0xba, -0x36, 0x26, 0x7e, 0x9b, 0x21, 0xa2, 0x06, 0xea, -0xd9, 0x25, 0x5e, 0x5c, 0x7a, 0x12, 0xf6, 0xed, -0xf6, 0xc4, 0xc4, 0x8b, 0x69, 0xfc, 0x03, 0xc9, -0x54, 0x3c, 0xea, 0x4c, 0xc2, 0x08, 0xdc, 0x0d, -0x25, 0x74, 0x06, 0x5e, 0x59, 0x0c, 0xde, 0x0e, -0x76, 0x65, 0x4c, 0x6b, 0x84, 0xeb, 0xec, 0xf8, -0xa7, 0x5b, 0x31, 0x83, 0xda, 0xb4, 0x6a, 0x66, -0x34, 0xad, 0x9d, 0x16, 0x6d, 0x45, 0x20, 0xd4, -0xa8, 0x79, 0xbe, 0xcf, 0x80, 0xd0, 0xdb, 0xcc, -0x58, 0xb9, 0xcd, 0x81, 0x7f, 0xd6, 0x98, 0xa0, -0xa5, 0x5a, 0x61, 0x46, 0xfb, 0x7d, 0x68, 0x6c, -0x86, 0x06, 0x4d, 0x5e, 0x7c, 0x4d, 0xb5, 0x70, -0x10, 0xd7, 0xcf, 0x76, 0x1b, 0xfe, 0xa9, 0x90, -0xaa, 0xe1, 0x09, 0x7e, 0xbf, 0xc4, 0x61, 0xcf, -0x90, 0x1c, 0x25, 0x5d, 0xd2, 0xa3, 0xc2, 0xed, -0x2c, 0x70, 0x97, 0x06, 0xd8, 0x95, 0x1a, 0x66, -0x30, 0xfc, 0x63, 0xfe, 0x93, 0x21, 0x85, 0x76, -0x4a, 0x23, 0xdc, 0x58, 0xee, 0x2a, 0x8d, 0x74, -0xc5, 0x3a, 0xe6, 0x55, 0x2f, 0xf7, 0x47, 0x49, -0x21, 0xec, 0x0d, 0xb0, 0x88, 0x6f, 0xc7, 0x3f, -0x7d, 0x72, 0x98, 0x0d, 0x93, 0x8d, 0x37, 0xe2, -0xe2, 0x78, 0x4f, 0x2e, 0x26, 0x33, 0x18, 0x10, -0x9a, 0x1b, 0x94, 0x65, 0x3a, 0x43, 0x95, 0xde, -0x51, 0x0f, 0x41, 0x80, 0x8a, 0xc7, 0x89, 0x85, -0x7f, 0xae, 0x4d, 0x8d, 0xf7, 0x95, 0x5f, 0x0f, -0xc7, 0x2e, 0x90, 0x16, 0x6d, 0xeb, 0x43, 0x1d, -0xdf, 0x8a, 0x5d, 0xf0, 0xd7, 0x2e, 0x9f, 0x16, -0x15, 0x5f, 0x8d, 0x5d, 0xf6, 0xb7, 0x2c, 0xf7, -0x3e, 0xd4, 0xf9, 0xe6, 0x34, 0x0b, 0x6f, 0x70, -0xfc, 0xd3, 0xa2, 0x79, 0x1f, 0x16, 0x7f, 0xcf, -0xa6, 0xa5, 0xa5, 0xad, 0xf8, 0x41, 0x71, 0x58, -0x3b, 0xaa, 0x34, 0x2f, 0x2f, 0x66, 0xf8, 0x87, -0xdc, 0x0f, 0x75, 0xcb, 0x3c, 0x43, 0xe2, 0x4d, -0x69, 0xfc, 0x53, 0x91, 0x94, 0x0d, 0x90, 0x13, -0x4a, 0x52, 0x66, 0x6c, 0x2b, 0xde, 0xc8, 0xbc, -0x71, 0xf7, 0x2d, 0x75, 0x50, 0xc4, 0xf0, 0x8f, -0x9a, 0x90, 0x19, 0x22, 0x8a, 0x1c, 0x29, 0x91, -0xd2, 0xfe, 0x87, 0x81, 0x1c, 0xc2, 0xc6, 0x3b, -0x83, 0x0c, 0xd0, 0xbd, 0x6c, 0x36, 0x8a, 0x4a, -0x43, 0x03, 0xd0, 0x51, 0xe5, 0x0f, 0x7d, 0x4e, -0x29, 0x1d, 0xee, 0xe8, 0x50, 0xd8, 0x78, 0x4b, -0x49, 0xc8, 0xf2, 0x3f, 0x15, 0x05, 0xbb, 0x84, -0x34, 0x7a, 0x94, 0x6a, 0xb5, 0xa2, 0x28, 0xb0, -0xfb, 0x19, 0x10, 0x62, 0x0b, 0x69, 0x18, 0x36, -0x57, 0xef, 0xc4, 0xf9, 0x29, 0x4c, 0xe3, 0x1f, -0x69, 0x97, 0x85, 0x5e, 0x14, 0x86, 0x76, 0x96, -0xfe, 0x7d, 0x74, 0xfa, 0x30, 0x39, 0x0a, 0x8d, -0x4b, 0xd9, 0xfb, 0x0f, 0x08, 0x1d, 0xb0, 0x4f, -0x0b, 0x44, 0xc5, 0xb5, 0x5d, 0xe6, 0xf3, 0x9f, -0x54, 0x76, 0x39, 0xd1, 0xce, 0xec, 0x68, 0x2b, -0x1a, 0x8d, 0x5a, 0x49, 0xb4, 0xf3, 0xcd, 0x65, -0x17, 0x28, 0x5f, 0x2a, 0xef, 0x44, 0xcd, 0xe7, -0xfb, 0x19, 0xfe, 0x19, 0x49, 0xe1, 0x1f, 0x92, -0x98, 0xd6, 0xac, 0x14, 0x30, 0xfc, 0x23, 0x27, -0xa0, 0x41, 0x08, 0x51, 0x31, 0x29, 0x21, 0xa2, -0x61, 0x40, 0xe8, 0x58, 0x97, 0xb9, 0xfe, 0x55, -0xc9, 0x0f, 0xef, 0x48, 0xb5, 0x08, 0x72, 0xfc, -0xca, 0x7d, 0x30, 0x3f, 0xca, 0xdc, 0x8e, 0x1f, -0xee, 0x63, 0xb0, 0x07, 0xf1, 0x8f, 0xf0, 0x80, -0xd6, 0x40, 0xe5, 0x51, 0xe6, 0x58, 0x4c, 0xff, -0xe0, 0xdf, 0x98, 0xf2, 0x3f, 0xc1, 0xc2, 0x95, -0xe8, 0x7f, 0x7e, 0x23, 0x07, 0x4b, 0x3d, 0xcc, -0xa8, 0xd6, 0x5d, 0xc1, 0x52, 0xf6, 0x05, 0xc9, -0xcc, 0xf1, 0x2e, 0x61, 0xf8, 0xc7, 0xfc, 0xfb, -0x56, 0x0a, 0xb3, 0xe0, 0x27, 0xf8, 0xfd, 0xde, -0x45, 0x66, 0x03, 0xc3, 0x03, 0x7a, 0xc5, 0x37, -0xd8, 0x46, 0x66, 0x93, 0x7a, 0x5b, 0x42, 0x6e, -0x67, 0xdf, 0xef, 0x4f, 0x60, 0x4e, 0x42, 0x66, -0x2f, 0xaa, 0x59, 0xcf, 0x97, 0x67, 0xc3, 0x5b, -0x88, 0x7f, 0x16, 0x8b, 0xf7, 0xc0, 0x2f, 0x99, -0x51, 0x5c, 0xf7, 0x50, 0x73, 0xe8, 0x65, 0xfd, -0xfa, 0xe1, 0xc2, 0x0d, 0x9d, 0x2c, 0xf4, 0x74, -0x2c, 0x19, 0x0b, 0xac, 0x16, 0x8e, 0x59, 0xfb, -0x2f, 0xf9, 0xea, 0x3d, 0xa6, 0x3f, 0x41, 0xc7, -0x72, 0xbd, 0xbe, 0x60, 0xbf, 0x38, 0x4a, 0x27, -0xd6, 0xde, 0xc3, 0x02, 0x19, 0xbb, 0xc2, 0x3c, -0x70, 0x92, 0x4d, 0xc5, 0x11, 0x6b, 0xff, 0xa5, -0x15, 0xb0, 0xfd, 0x7b, 0xf4, 0xc6, 0xa4, 0x67, -0xbc, 0x33, 0x15, 0xc8, 0xc6, 0xc5, 0x66, 0x75, -0x32, 0xde, 0xf2, 0x5b, 0xcf, 0x78, 0xeb, 0x15, -0xf8, 0x0b, 0xba, 0x28, 0xe9, 0x49, 0xb0, 0x50, -0x68, 0xe1, 0x1f, 0xe6, 0x7f, 0x7a, 0x63, 0x1c, -0xbd, 0x0c, 0x0a, 0x6f, 0xc1, 0x8d, 0xc7, 0x7a, -0xc6, 0x84, 0x1f, 0xb2, 0x2b, 0x8d, 0xa3, 0xc5, -0x4b, 0x23, 0xa7, 0x60, 0x93, 0xc0, 0xfc, 0x4f, -0x3b, 0x0b, 0xdc, 0xe6, 0xf3, 0xb7, 0x33, 0xef, -0x84, 0xfe, 0xaa, 0x68, 0x7d, 0x84, 0xef, 0xce, -0xfa, 0x19, 0x3a, 0x9a, 0x55, 0x79, 0x40, 0x98, -0xaf, 0x0b, 0x6c, 0xbf, 0xa6, 0x3d, 0x52, 0xf1, -0xa3, 0x23, 0x6c, 0xbc, 0x49, 0xcb, 0xff, 0x87, -0x15, 0xc3, 0xff, 0x14, 0x61, 0x34, 0xaf, 0x82, -0x80, 0xca, 0xfc, 0xf9, 0xf1, 0xb2, 0xde, 0x02, -0xbf, 0x5e, 0x14, 0x60, 0xfb, 0xdf, 0x1e, 0xa8, -0x49, 0x32, 0xff, 0x7f, 0xc2, 0x5a, 0x9f, 0x35, -0xe5, 0xc6, 0x78, 0xe7, 0x8f, 0xcd, 0xb8, 0xc4, -0x8c, 0xbb, 0xc3, 0x2c, 0x3a, 0x37, 0x31, 0x58, -0xb2, 0x40, 0xff, 0xfc, 0x13, 0x33, 0x46, 0xe1, -0x24, 0x39, 0x90, 0xdc, 0xc3, 0xf6, 0x8f, 0xd6, -0x7a, 0x8b, 0xc2, 0x28, 0x8b, 0x56, 0xcd, 0x7a, -0x49, 0x5c, 0x18, 0x85, 0x77, 0x85, 0xbb, 0xfe, -0x1b, 0xdb, 0xbd, 0xee, 0xa9, 0x98, 0x40, 0x8f, -0x8d, 0x1b, 0x87, 0x11, 0x23, 0x54, 0xa5, 0xfd, -0x43, 0x47, 0xf4, 0x52, 0x6a, 0xf7, 0x2a, 0x72, -0x63, 0xe9, 0xd6, 0xb1, 0x69, 0x4d, 0xd2, 0x24, -0xdc, 0xa3, 0x7b, 0x8f, 0x88, 0xe3, 0x91, 0x63, -0x50, 0xaf, 0xb3, 0xef, 0x8b, 0x2e, 0x33, 0xdf, -0xa7, 0x1f, 0x10, 0xff, 0x34, 0xeb, 0x3d, 0x71, -0x71, 0x0f, 0x06, 0xb2, 0xf5, 0x0c, 0xbd, 0x18, -0x11, 0xad, 0x68, 0x5b, 0xe9, 0xef, 0xe8, 0x89, -0x64, 0x83, 0x2e, 0x53, 0x12, 0x4c, 0xe3, 0x1f, -0x33, 0xde, 0xc5, 0x09, 0xbf, 0xff, 0xf6, 0x1f, -0xc4, 0x43, 0x01, 0x58, 0xc2, 0xe2, 0x35, 0x8b, -0x80, 0xa3, 0x70, 0x1f, 0xf5, 0xe1, 0xfd, 0xb1, -0x34, 0xfe, 0x91, 0x18, 0xfe, 0x09, 0x73, 0x90, -0xb3, 0x85, 0x4d, 0x94, 0x47, 0x73, 0x2f, 0xf4, -0x6d, 0x51, 0x7b, 0x83, 0xeb, 0xf4, 0xab, 0x81, -0xfc, 0x82, 0x0d, 0xaf, 0x5a, 0x67, 0xdf, 0x17, -0xb1, 0xfc, 0x0f, 0x2d, 0x62, 0x61, 0x25, 0xcc, -0x06, 0xf5, 0x94, 0xf8, 0x8f, 0x08, 0x8c, 0x35, -0xf7, 0xd8, 0x35, 0x4d, 0x43, 0x93, 0x72, 0xcb, -0x2b, 0x6c, 0x19, 0x1c, 0x25, 0xc7, 0x96, 0xd6, -0x0d, 0xb1, 0x8d, 0x2a, 0x15, 0x2c, 0xfc, 0x53, -0x8c, 0xf8, 0x67, 0x89, 0xee, 0x3d, 0x27, 0x3e, -0x13, 0xbb, 0x07, 0x98, 0xb7, 0x39, 0x57, 0xb5, -0x8e, 0x4e, 0xcc, 0x6d, 0x3e, 0x56, 0xac, 0x8b, -0x63, 0x94, 0xf9, 0x9f, 0x63, 0x88, 0x7f, 0xca, -0xd2, 0x78, 0x83, 0xad, 0x1f, 0xb2, 0x24, 0x59, -0xbc, 0x9a, 0xe1, 0xcf, 0xf7, 0xcb, 0x16, 0x0d, -0x14, 0x9f, 0xeb, 0x3c, 0x07, 0x13, 0xa5, 0xb5, -0x7a, 0xf1, 0xb8, 0x78, 0x05, 0xde, 0x37, 0x56, -0x54, 0x1a, 0xff, 0xe8, 0xca, 0x59, 0xf8, 0x9b, -0x21, 0x5f, 0xd2, 0xbd, 0x9d, 0x3c, 0x09, 0x5b, -0x6f, 0xaf, 0x1a, 0x72, 0x5d, 0x0a, 0xbd, 0x09, -0xcf, 0x85, 0x17, 0xbc, 0x22, 0xf7, 0x91, 0xb3, -0x06, 0x35, 0xe4, 0xe0, 0x7f, 0x0a, 0x06, 0x8d, -0x4d, 0x84, 0xc2, 0x96, 0xec, 0xe3, 0x5a, 0xf5, -0x6b, 0xee, 0x60, 0x29, 0x83, 0xc1, 0x4b, 0x03, -0xaf, 0x15, 0x05, 0x59, 0x84, 0x7a, 0x58, 0x08, -0xf4, 0xb3, 0x2b, 0x47, 0xac, 0xf8, 0xa5, 0x97, -0xef, 0x51, 0x0e, 0x23, 0xc9, 0xb3, 0x9d, 0xec, -0x80, 0x4f, 0x33, 0x63, 0x79, 0x9c, 0x9c, 0x81, -0xc3, 0x42, 0x89, 0xde, 0x86, 0xfc, 0xc9, 0x61, -0xa9, 0xd6, 0xc9, 0xff, 0x68, 0xe5, 0xeb, 0xa4, -0x09, 0xe9, 0x9a, 0xfe, 0xe2, 0x6e, 0x71, 0x05, -0x03, 0x2a, 0x0d, 0x7a, 0xb1, 0x41, 0x3b, 0xcc, -0x46, 0x63, 0xb4, 0x82, 0x43, 0x97, 0xb8, 0x90, -0xe6, 0x7f, 0x62, 0xc2, 0x33, 0xca, 0x5b, 0x6c, -0x3d, 0xb8, 0x87, 0xc4, 0x09, 0x78, 0x9d, 0x19, -0x05, 0x63, 0xe2, 0x65, 0xb6, 0x1e, 0x38, 0xad, -0x71, 0x49, 0x30, 0x96, 0xca, 0x34, 0x3b, 0xff, -0x13, 0x30, 0xbe, 0xc7, 0x4e, 0x71, 0x2d, 0xbc, -0x25, 0xdd, 0x80, 0xd1, 0xfc, 0x0c, 0x9b, 0xb1, -0x1b, 0xd9, 0x0a, 0x6c, 0xb5, 0x42, 0xbf, 0x9d, -0xff, 0x09, 0xc8, 0xcf, 0xe1, 0x7a, 0x08, 0x72, -0xd8, 0x53, 0xa5, 0xef, 0x1e, 0x63, 0xb3, 0xf1, -0x1c, 0x2c, 0xd0, 0x65, 0xfe, 0xfe, 0xc0, 0x81, -0x74, 0x9a, 0xff, 0x19, 0x29, 0x30, 0xf6, 0x5f, -0x45, 0x65, 0xa4, 0x4d, 0x41, 0xfe, 0xa7, 0x88, -0xcd, 0x06, 0xed, 0x95, 0xfc, 0xfd, 0x2e, 0x9c, -0x9f, 0xde, 0x2c, 0xfe, 0xc7, 0xc4, 0x3f, 0x27, -0x49, 0x63, 0xe4, 0x53, 0xb4, 0x68, 0xd8, 0xbf, -0x81, 0xfc, 0x26, 0xb8, 0x28, 0x3e, 0x3f, 0x09, -0x0c, 0x21, 0x74, 0xb0, 0x9f, 0x46, 0x32, 0xf8, -0x1f, 0x8f, 0xc1, 0xff, 0x54, 0x88, 0x5f, 0xa0, -0xbf, 0x83, 0xc6, 0x11, 0xcf, 0x0d, 0xe2, 0x71, -0xe5, 0xce, 0x78, 0x53, 0xb2, 0x24, 0x28, 0x1e, -0x87, 0x3b, 0x69, 0x53, 0xd2, 0xc9, 0xff, 0x30, -0xfc, 0xf3, 0x77, 0x70, 0x9d, 0xbe, 0x75, 0x68, -0xfa, 0x25, 0xed, 0x0d, 0x68, 0x78, 0xd5, 0xfb, -0x41, 0xeb, 0xa5, 0x30, 0x67, 0x84, 0x3e, 0x10, -0xad, 0x4f, 0xc9, 0x89, 0x7f, 0xf8, 0xec, 0x81, -0x28, 0xc3, 0xa4, 0x6f, 0xc9, 0xab, 0xb3, 0xf6, -0x77, 0xbe, 0x1b, 0x7b, 0x37, 0xd8, 0x32, 0x1a, -0xe0, 0x1e, 0x8c, 0x64, 0xf2, 0x3f, 0xcc, 0xff, -0xbc, 0x85, 0xfb, 0xaf, 0xf5, 0xe2, 0x6a, 0xd8, -0xa4, 0x54, 0x26, 0xe4, 0x6f, 0x92, 0x53, 0xb4, -0x53, 0xa9, 0x1a, 0xcc, 0xcd, 0xff, 0x50, 0x86, -0x7f, 0x7e, 0x82, 0xe3, 0x6d, 0x0b, 0x5d, 0xa3, -0xf6, 0x46, 0xfd, 0x23, 0xf2, 0xb7, 0x4b, 0xaf, -0x74, 0x1d, 0xd8, 0x31, 0x6f, 0x24, 0x37, 0xff, -0x83, 0xf8, 0x87, 0xfb, 0xf3, 0xfa, 0xd0, 0x72, -0xe6, 0x6d, 0x54, 0xdc, 0xcf, 0x0e, 0x6a, 0x0f, -0x33, 0x43, 0xe6, 0xf3, 0x29, 0x65, 0xf0, 0x3f, -0x23, 0xe5, 0x2c, 0x5e, 0x20, 0xfe, 0x49, 0x8a, -0xd7, 0x30, 0x20, 0xd4, 0xd8, 0xe1, 0x89, 0xb5, -0xbe, 0xc3, 0x8c, 0x43, 0x94, 0xc1, 0x9e, 0x11, -0x16, 0x5d, 0x32, 0xf9, 0x1f, 0x48, 0x9a, 0xf1, -0xe8, 0xb7, 0xe6, 0xc6, 0x1c, 0xaf, 0x70, 0xd8, -0x93, 0xcc, 0xc5, 0xff, 0x60, 0x74, 0xab, 0xd5, -0xbc, 0x8f, 0x32, 0xb4, 0xf3, 0x1a, 0x83, 0x31, -0x2c, 0x2c, 0xae, 0x81, 0x6f, 0x40, 0x1d, 0x0b, -0x73, 0xc2, 0xb0, 0x94, 0x83, 0xff, 0x59, 0x23, -0xf1, 0xf8, 0x5b, 0xca, 0x60, 0xff, 0x66, 0x44, -0x3b, 0x51, 0xb6, 0x6c, 0x10, 0xf6, 0xd8, 0xf9, -0x1c, 0x1b, 0xfe, 0x29, 0xb0, 0xd8, 0x9e, 0xb9, -0xd2, 0xa3, 0x20, 0xb1, 0x78, 0x4d, 0xd6, 0xb0, -0x08, 0x7e, 0x3b, 0x32, 0x42, 0xc3, 0xc6, 0xa3, -0xa2, 0xbe, 0x17, 0x6c, 0xfe, 0x87, 0xc1, 0x1e, -0x3f, 0x27, 0x79, 0xaa, 0xa1, 0xc3, 0x1f, 0x5b, -0x2e, 0x97, 0xbe, 0x30, 0x20, 0xef, 0xf5, 0xab, -0xcb, 0x91, 0xff, 0x91, 0x0c, 0xfe, 0x07, 0xd2, -0xf8, 0x67, 0x71, 0x71, 0x18, 0xc6, 0x55, 0x3e, -0x28, 0x15, 0x4e, 0xf8, 0x1a, 0xe4, 0xe2, 0x88, -0x88, 0x57, 0xf6, 0xc9, 0x38, 0xf0, 0xe9, 0xd9, -0xfc, 0x8f, 0x81, 0x7f, 0x96, 0x1a, 0xfc, 0x4f, -0x80, 0xd3, 0x3e, 0x03, 0x70, 0x61, 0xde, 0xb3, -0xcb, 0xb7, 0x46, 0xab, 0x2c, 0x7e, 0xe3, 0x4d, -0x6b, 0xff, 0xc5, 0xf9, 0x1f, 0x0c, 0xfa, 0xed, -0xee, 0xeb, 0xe1, 0xb5, 0x70, 0x73, 0x5b, 0xc9, -0x43, 0xe2, 0x70, 0xc5, 0x05, 0x7f, 0xe3, 0x72, -0x8f, 0x8d, 0x0f, 0xc9, 0xe6, 0x7f, 0xdc, 0xb4, -0x54, 0x85, 0x6e, 0xa8, 0x9d, 0x25, 0x33, 0xfc, -0x03, 0xf1, 0x70, 0x43, 0x85, 0x83, 0xff, 0xb1, -0xe6, 0xb3, 0x0d, 0xf1, 0x8f, 0xe6, 0x67, 0x83, -0xba, 0xa9, 0x1a, 0x1e, 0xd4, 0x90, 0xf6, 0x29, -0x65, 0x57, 0x64, 0x7f, 0xa8, 0x5b, 0x31, 0x88, -0x20, 0xcd, 0xc1, 0xff, 0x54, 0x08, 0xbb, 0x8c, -0xf9, 0x7c, 0xb0, 0x10, 0xe7, 0x3f, 0xa0, 0x31, -0x58, 0x38, 0x2c, 0x1f, 0x04, 0x69, 0xa9, 0x0b, -0xe7, 0xff, 0x86, 0x6c, 0xfe, 0xc7, 0x40, 0x2f, -0xc8, 0xff, 0x04, 0x5f, 0x03, 0x4e, 0x5b, 0xbd, -0xd5, 0x7d, 0x01, 0x4c, 0x22, 0xc8, 0x80, 0xbe, -0x69, 0xfe, 0x67, 0x84, 0x3d, 0xff, 0x42, 0x01, -0xbb, 0xb8, 0x7d, 0xc6, 0x9b, 0x9a, 0x39, 0x1b, -0x94, 0x3f, 0x21, 0x27, 0xff, 0xe3, 0x87, 0x58, -0x8a, 0xe4, 0xe9, 0xbc, 0x8d, 0x2f, 0xbc, 0x12, -0x2a, 0x56, 0xc1, 0x38, 0x69, 0x40, 0xd8, 0x63, -0xad, 0xb7, 0x0c, 0xfe, 0x07, 0x18, 0xfe, 0x19, -0x26, 0x7e, 0xf5, 0x24, 0x33, 0x3c, 0x0c, 0xff, -0xd0, 0x43, 0x50, 0x43, 0x8b, 0xd9, 0xfe, 0x4b, -0xe6, 0x3f, 0x39, 0xf8, 0x9f, 0xf2, 0x95, 0xdc, -0x3f, 0xaf, 0x08, 0x16, 0x7e, 0x81, 0x18, 0x40, -0x68, 0x6e, 0x09, 0x73, 0x53, 0x81, 0xd4, 0xf7, -0x62, 0xf8, 0x9f, 0x34, 0xff, 0x13, 0x13, 0x0c, -0x3c, 0xe0, 0x1e, 0xbb, 0xe9, 0x3b, 0xc2, 0x23, -0xc1, 0xc0, 0x20, 0xdb, 0x7d, 0x94, 0xc1, 0x01, -0x75, 0x5e, 0xa2, 0xc8, 0xf6, 0xfd, 0xa6, 0xf9, -0x9f, 0xdd, 0x32, 0xfa, 0xab, 0x1b, 0xce, 0x78, -0xd7, 0x8a, 0x5f, 0x81, 0x9f, 0xc4, 0x6e, 0xfc, -0x2d, 0x03, 0x42, 0xb3, 0xe1, 0xe3, 0xa1, 0xa6, -0x8b, 0x1e, 0xe4, 0x7f, 0x52, 0xd4, 0xd0, 0x3b, -0x3e, 0x8b, 0xff, 0x29, 0x36, 0xf1, 0xcf, 0x17, -0xb7, 0xc0, 0xc4, 0x9a, 0xe6, 0x84, 0x37, 0xde, -0xf6, 0x7b, 0x98, 0x50, 0x1b, 0x12, 0x29, 0x44, -0x64, 0xf0, 0x3f, 0x16, 0xfe, 0x01, 0x16, 0xbf, -0x26, 0xa3, 0x3c, 0x48, 0x9d, 0x86, 0xf7, 0x07, -0x96, 0xa0, 0xf1, 0xae, 0x3c, 0x11, 0xad, 0x43, -0xfe, 0xc7, 0x42, 0x44, 0x36, 0xfe, 0x07, 0xf7, -0x5f, 0xbb, 0xe6, 0x0f, 0xb8, 0x17, 0x92, 0x59, -0x74, 0x13, 0xf8, 0x47, 0x7e, 0x10, 0x24, 0x2f, -0xd0, 0x03, 0xb1, 0xca, 0xa4, 0x6b, 0x7d, 0x6a, -0xbc, 0x6c, 0x20, 0x69, 0xfc, 0x03, 0x90, 0xda, -0xaf, 0x8d, 0x91, 0x6d, 0x0c, 0xdd, 0xcd, 0x4b, -0xb0, 0xd1, 0x9d, 0xa0, 0x07, 0xa0, 0xb2, 0xdf, -0xee, 0xaf, 0x6c, 0xfc, 0x0f, 0xdf, 0x7f, 0xad, -0xd3, 0xdd, 0x0b, 0xa9, 0xc4, 0x60, 0xa4, 0x5f, -0x17, 0x83, 0x2c, 0xac, 0xff, 0x00, 0x76, 0xea, -0x96, 0x3f, 0x2f, 0x72, 0xf2, 0x3f, 0x7b, 0x4c, -0x27, 0xb9, 0x85, 0xed, 0xc7, 0x59, 0xe0, 0x8e, -0xb7, 0xbe, 0xc7, 0x3c, 0x6a, 0x3d, 0x06, 0x1a, -0x6b, 0xbc, 0x36, 0xfe, 0x07, 0xac, 0x8b, 0x38, -0x51, 0x4d, 0x68, 0x8c, 0xd8, 0x11, 0x23, 0x66, -0x40, 0x6c, 0xfc, 0x8f, 0xa0, 0x18, 0x4e, 0x7b, -0xeb, 0x98, 0xd8, 0x0c, 0x2f, 0x33, 0xc3, 0xb3, -0x5e, 0x68, 0x52, 0xef, 0x01, 0xb6, 0x2d, 0x1d, -0x4b, 0xfb, 0xf3, 0x34, 0xff, 0x43, 0xa5, 0x75, -0x9c, 0xcf, 0x71, 0x57, 0x90, 0x9f, 0xe1, 0xfe, -0x9d, 0x3d, 0x8d, 0xec, 0x06, 0x8c, 0xc8, 0xc5, -0x3c, 0x7e, 0x91, 0x6c, 0xfe, 0x87, 0xa1, 0x1d, -0x76, 0xf1, 0x69, 0xb6, 0x0f, 0xea, 0x91, 0xe6, -0xea, 0xae, 0x38, 0x89, 0x69, 0x78, 0xbf, 0x15, -0xef, 0x9c, 0xfc, 0x0f, 0xe2, 0x1f, 0xbe, 0xa8, -0x7c, 0x5b, 0x34, 0xb6, 0xde, 0x5e, 0x5a, 0xb1, -0xb0, 0x30, 0xc2, 0xf0, 0x80, 0x7a, 0xe2, 0x73, -0xe8, 0xa8, 0x7b, 0xb5, 0x1c, 0xfc, 0xcf, 0x61, -0x95, 0x8d, 0x6e, 0xaf, 0x18, 0x60, 0x78, 0x7b, -0xd1, 0x2b, 0x25, 0xfb, 0xeb, 0x77, 0x68, 0x1f, -0x6b, 0xf5, 0x43, 0xc6, 0xfc, 0x68, 0xcd, 0xaf, -0xb2, 0x81, 0xeb, 0xd3, 0x2c, 0xfc, 0x73, 0x2d, -0x83, 0x91, 0x15, 0x2d, 0xec, 0x82, 0x78, 0x29, -0xf2, 0x06, 0xc2, 0x80, 0xb1, 0x2f, 0x8e, 0x0d, -0x4c, 0x36, 0xb4, 0xbc, 0x86, 0xf1, 0x9d, 0xb2, -0xf1, 0x26, 0x9c, 0xfc, 0x0f, 0xae, 0x9f, 0x8d, -0x2d, 0xc9, 0xcf, 0x8f, 0x7f, 0xf5, 0x32, 0xbc, -0xa1, 0x2e, 0x19, 0x2e, 0x3e, 0x27, 0x7e, 0x9d, -0x8e, 0xab, 0x0d, 0xfa, 0xfd, 0x63, 0xe2, 0x37, -0xb5, 0x97, 0x68, 0x7d, 0xac, 0xf8, 0x03, 0x31, -0x68, 0xe7, 0x7f, 0x4c, 0x90, 0x33, 0x4a, 0xb7, -0x46, 0x7d, 0x09, 0xf7, 0x9d, 0x91, 0xa6, 0xd5, -0xae, 0x0d, 0x55, 0x27, 0xe5, 0x8f, 0x23, 0xa0, -0xec, 0x90, 0xfc, 0xd4, 0xf5, 0x10, 0x89, 0xd9, -0xf6, 0x5f, 0xd6, 0x1f, 0x7d, 0x0b, 0x3c, 0xcc, -0x3f, 0xb4, 0xd2, 0x95, 0x74, 0xbb, 0x20, 0x0d, -0xf4, 0x04, 0xc9, 0x4a, 0x29, 0x32, 0x4f, 0xbd, -0x4f, 0x56, 0x19, 0xde, 0x4b, 0xf3, 0x51, 0x7b, -0xcc, 0x49, 0x1b, 0x84, 0x9f, 0x42, 0x4d, 0xff, -0xe7, 0xe2, 0xc4, 0x03, 0xf7, 0x69, 0x2a, 0x4e, -0x6c, 0x40, 0x78, 0x92, 0x7d, 0xc8, 0xcc, 0xd1, -0xc5, 0x2d, 0xff, 0xa3, 0x95, 0x5b, 0x7f, 0xf4, -0x3d, 0xf0, 0xba, 0xd0, 0xa8, 0x7f, 0x3e, 0xfe, -0xd5, 0x75, 0xf2, 0x85, 0x68, 0x03, 0x5b, 0x0f, -0x55, 0x61, 0x38, 0x2a, 0xd4, 0x51, 0xcf, 0x6e, -0x51, 0xb1, 0xd6, 0x4f, 0x52, 0x78, 0x26, 0x8d, -0x87, 0x5f, 0x87, 0x45, 0xfd, 0xee, 0xb1, 0xaa, -0x4b, 0x70, 0x59, 0x6a, 0xc1, 0x27, 0x8c, 0xc1, -0x65, 0x68, 0xa1, 0xde, 0x01, 0x71, 0xdc, 0x5a, -0x3f, 0xba, 0xb2, 0x47, 0x30, 0x57, 0x97, 0xf2, -0x31, 0xc3, 0x57, 0xd7, 0x05, 0xc5, 0x40, 0x51, -0x42, 0xab, 0x4b, 0x14, 0xaf, 0xef, 0x1c, 0xad, -0x38, 0x06, 0xec, 0xf9, 0x7d, 0x4e, 0xfc, 0x63, -0xbe, 0xff, 0x25, 0x68, 0x61, 0xcb, 0x60, 0xeb, -0x98, 0xab, 0x99, 0x76, 0xc1, 0xa7, 0xf5, 0xe5, -0x63, 0x64, 0xc1, 0xf6, 0x93, 0xc9, 0x86, 0x6d, -0xc5, 0xdb, 0x6c, 0xf8, 0x27, 0x99, 0xc2, 0x3f, -0x9c, 0x1f, 0xe3, 0x13, 0xb5, 0x98, 0x4d, 0x14, -0x05, 0xff, 0xd0, 0xf6, 0x20, 0x79, 0x9c, 0x3e, -0x9a, 0xac, 0xa1, 0x72, 0x34, 0x92, 0xc1, 0xff, -0x60, 0xfe, 0x6b, 0x83, 0x8f, 0x47, 0xff, 0x61, -0x17, 0xdb, 0x88, 0xd1, 0xc2, 0xd8, 0xa7, 0x87, -0xc9, 0x06, 0xf2, 0x90, 0x5c, 0x4e, 0xe7, 0xc4, -0x84, 0x4c, 0xfc, 0xd3, 0x4b, 0xbf, 0x83, 0x49, -0xae, 0x95, 0xf0, 0x21, 0xc1, 0xb4, 0x57, 0xe4, -0x67, 0x0f, 0x15, 0xc5, 0x18, 0x10, 0x0a, 0x8a, -0x83, 0xf4, 0x66, 0x25, 0x48, 0x3d, 0x90, 0x81, -0x7f, 0xf8, 0x6e, 0x62, 0x8c, 0xed, 0x2f, 0x26, -0x49, 0xbd, 0xbe, 0xf5, 0x5c, 0xe7, 0xff, 0x66, -0x13, 0xd5, 0x3c, 0x54, 0xf2, 0x6f, 0x9d, 0xdf, -0x81, 0x2b, 0x5d, 0x2d, 0x08, 0x15, 0x6c, 0xf8, -0xa7, 0x7c, 0x34, 0xfd, 0xf5, 0x4d, 0x6a, 0xec, -0x0f, 0x51, 0xc7, 0x80, 0xfa, 0xf3, 0x75, 0x3e, -0x3d, 0x70, 0x9e, 0x45, 0xcc, 0x83, 0x84, 0xe1, -0x07, 0x9a, 0xc5, 0xff, 0xdc, 0xc0, 0x9c, 0x06, -0x9c, 0xa2, 0x07, 0xd6, 0x22, 0xff, 0x13, 0xf2, -0x44, 0x7f, 0x22, 0xcf, 0x3b, 0xc1, 0x80, 0x90, -0x02, 0x4f, 0xc1, 0x7c, 0xea, 0x0e, 0xe7, 0xe1, -0x7f, 0x78, 0xda, 0x6b, 0x33, 0x1b, 0xb8, 0xf6, -0x0f, 0xb1, 0xea, 0x64, 0xdb, 0x5d, 0xbe, 0xd9, -0xf0, 0x74, 0x64, 0x7e, 0xcc, 0xbd, 0x9a, 0x8c, -0x59, 0x9f, 0x4b, 0x9b, 0x34, 0x28, 0xa5, 0xf8, -0xc6, 0x51, 0x21, 0x45, 0xe3, 0x6f, 0x81, 0x9f, -0xd2, 0x80, 0xde, 0x1d, 0x24, 0x1e, 0x65, 0x1f, -0xfb, 0x4a, 0xd9, 0x0c, 0xd8, 0xf8, 0x9f, 0x82, -0x14, 0xff, 0x83, 0x68, 0x07, 0x8d, 0x6b, 0xd1, -0x38, 0x89, 0xfc, 0x4f, 0xcc, 0xed, 0x67, 0x57, -0x16, 0x50, 0xef, 0x70, 0x16, 0xff, 0xd3, 0x68, -0xc0, 0x1e, 0x8c, 0x3e, 0xd7, 0xd1, 0x6b, 0x6e, -0x83, 0xf1, 0xab, 0xd9, 0x15, 0x69, 0x46, 0x12, -0x2e, 0x65, 0xe1, 0x1f, 0xb0, 0x65, 0x37, 0xfa, -0x11, 0xf6, 0x54, 0xb4, 0x76, 0xc1, 0x8b, 0xb1, -0x46, 0x0d, 0x1e, 0x14, 0xd7, 0xc8, 0x3c, 0x62, -0x6e, 0xcf, 0xc9, 0xff, 0xf8, 0x86, 0x09, 0xc7, -0x3f, 0x0f, 0x92, 0x39, 0x91, 0xcd, 0xba, 0x4f, -0x6b, 0xfb, 0x1e, 0x99, 0x03, 0x07, 0xb5, 0x5a, -0xcd, 0xef, 0xe0, 0x7f, 0xca, 0x39, 0xff, 0xb3, -0x94, 0xa3, 0xa3, 0xcd, 0xa0, 0x6a, 0xae, 0xa8, -0x6f, 0x17, 0xd9, 0xcc, 0x22, 0x3e, 0x03, 0x4e, -0x5f, 0x83, 0x9f, 0x87, 0xd6, 0x69, 0xab, 0x1f, -0x24, 0x19, 0xf8, 0xc7, 0x08, 0xfa, 0xc3, 0xb1, -0x0e, 0xbf, 0xaa, 0xc9, 0x75, 0x11, 0x89, 0x19, -0xc9, 0xe5, 0x35, 0xa5, 0x91, 0x32, 0x36, 0xff, -0x1e, 0x4d, 0x2e, 0x8d, 0x38, 0xf1, 0x4f, 0x0a, -0xef, 0x25, 0xbb, 0x12, 0x6a, 0x1c, 0xbc, 0x11, -0x31, 0xc6, 0x8c, 0x46, 0x59, 0x26, 0x62, 0x18, -0x4e, 0xc1, 0x6c, 0xf0, 0x44, 0xc4, 0xe3, 0xa2, -0xf9, 0x3e, 0xdb, 0x8b, 0xd3, 0xe3, 0x8d, 0x5d, -0x80, 0xd9, 0xcb, 0xbd, 0x0f, 0x3d, 0xcc, 0x0c, -0x7f, 0xf3, 0xf2, 0x62, 0xc3, 0xb8, 0x67, 0xb9, -0xfb, 0x95, 0xe7, 0xdf, 0x9c, 0x66, 0xce, 0x67, -0x45, 0x41, 0xfa, 0xfe, 0xe8, 0x05, 0xb5, 0x59, -0x2b, 0xfe, 0x15, 0x59, 0xa3, 0xbe, 0x56, 0xd6, -0x10, 0x2a, 0x79, 0x58, 0xac, 0xd6, 0x8e, 0x2a, -0x75, 0x0c, 0x48, 0x74, 0xde, 0x94, 0x03, 0xff, -0x90, 0x24, 0xed, 0x6b, 0xaf, 0x2d, 0x72, 0x6f, -0x22, 0x82, 0x42, 0xdb, 0x77, 0x56, 0xb4, 0x6d, -0x2a, 0x8d, 0x95, 0xde, 0xa7, 0xee, 0x94, 0xe5, -0x01, 0x92, 0xc1, 0xff, 0x60, 0xbe, 0x4f, 0x21, -0xbf, 0x50, 0xd9, 0xc0, 0x5b, 0x8b, 0x14, 0x72, -0x4b, 0xec, 0xbb, 0xea, 0x9c, 0x90, 0xab, 0x9d, -0x94, 0xd1, 0x8d, 0x50, 0x15, 0x92, 0xdb, 0xa9, -0x8d, 0xff, 0x29, 0xdf, 0x65, 0xcf, 0x1e, 0xce, -0x5d, 0xea, 0x56, 0x4a, 0xaf, 0x87, 0x8d, 0xe4, -0xab, 0x9a, 0xdc, 0x4e, 0x1e, 0x81, 0x8d, 0x4a, -0xd5, 0xd2, 0xb6, 0xa1, 0x88, 0x8d, 0xff, 0x29, -0xcf, 0xc8, 0x5e, 0x71, 0x7c, 0xfb, 0x9a, 0xda, -0xa0, 0x7d, 0x21, 0x5a, 0x35, 0xa7, 0xe2, 0xe8, -0xb2, 0xa0, 0x16, 0xd8, 0x26, 0xae, 0xb5, 0xfc, -0xcf, 0x6e, 0x21, 0x83, 0xff, 0xd9, 0xca, 0xf1, -0x21, 0x34, 0x85, 0xcc, 0x2b, 0xa1, 0x05, 0xd1, -0xce, 0x74, 0xfc, 0xf5, 0xa7, 0xf3, 0x5f, 0x49, -0x48, 0x30, 0x63, 0x56, 0xb7, 0xa8, 0x76, 0x8c, -0x40, 0x03, 0x02, 0xa1, 0x1d, 0x90, 0x08, 0x35, -0x83, 0x67, 0x99, 0xe8, 0xca, 0xc6, 0x3f, 0x0c, -0xed, 0xc0, 0x7d, 0xa4, 0x96, 0xba, 0x76, 0x21, -0xff, 0x23, 0x71, 0xfe, 0xc7, 0x0f, 0x27, 0x85, -0x5a, 0x06, 0x84, 0x5c, 0xae, 0x34, 0xfe, 0x31, -0xf7, 0x5f, 0x18, 0x9d, 0x3b, 0xf1, 0x7b, 0x59, -0x5c, 0x58, 0x0c, 0x8f, 0x53, 0xff, 0x18, 0xfb, -0x82, 0x1e, 0xc0, 0x2b, 0x63, 0xfe, 0x26, 0xe2, -0xb2, 0xfc, 0x8f, 0x85, 0x7f, 0xd6, 0x93, 0xe3, -0xf4, 0x11, 0x98, 0x3f, 0xea, 0x0a, 0xb2, 0x65, -0xb3, 0x49, 0x9e, 0x37, 0x24, 0x87, 0xc9, 0xb5, -0xf0, 0x88, 0xf4, 0xf5, 0x48, 0xd1, 0xfa, 0x88, -0xdf, 0x7a, 0x3e, 0xe2, 0x1f, 0x04, 0x39, 0xc5, -0x0c, 0xed, 0x44, 0x7e, 0xc9, 0xd0, 0x88, 0xbc, -0x56, 0x9c, 0x4d, 0x7e, 0x4c, 0x97, 0x24, 0x6b, -0xc7, 0xc5, 0x43, 0x0c, 0x7a, 0xb4, 0x24, 0x3d, -0x27, 0xc4, 0x9a, 0x34, 0xff, 0x73, 0xad, 0x81, -0x7f, 0xdc, 0x71, 0xf1, 0xbd, 0x18, 0xdb, 0xbd, -0x9e, 0xf4, 0xc6, 0xdc, 0xc3, 0x70, 0x17, 0xec, -0xb3, 0xe2, 0x3b, 0xc5, 0xfd, 0x42, 0xa9, 0x39, -0x3f, 0x88, 0x7f, 0x9e, 0x43, 0x90, 0xd3, 0x27, -0x5e, 0x51, 0x5f, 0x46, 0xe3, 0xa0, 0xf8, 0xd7, -0xd2, 0x4b, 0x91, 0x7a, 0x75, 0xeb, 0xf8, 0xb4, -0x17, 0xe0, 0x45, 0x1a, 0x4c, 0xae, 0x1c, 0x11, -0x75, 0x27, 0xff, 0xc3, 0xf6, 0x5f, 0x25, 0x77, -0x95, 0x5e, 0xa1, 0xff, 0x82, 0x8e, 0x77, 0x43, -0x61, 0xe9, 0xab, 0x1b, 0x63, 0x95, 0xeb, 0xae, -0xb9, 0x8d, 0xed, 0xa7, 0x36, 0xed, 0xae, 0x1c, -0x95, 0x6f, 0x0f, 0xd9, 0xf2, 0x5f, 0x26, 0xfe, -0xc1, 0x6d, 0x1a, 0xf2, 0x5d, 0xee, 0x3a, 0xe6, -0xa8, 0x23, 0x7e, 0x55, 0x66, 0x78, 0x69, 0x0c, -0x1e, 0x08, 0x56, 0xe9, 0xf2, 0x5a, 0x9a, 0x89, -0x7f, 0x02, 0xc6, 0xee, 0xf5, 0x61, 0xa1, 0x56, -0xe7, 0x1b, 0x8d, 0x08, 0xdd, 0xb9, 0x94, 0xc5, -0xaf, 0x41, 0x09, 0xf5, 0x1b, 0xb2, 0x3f, 0x13, -0xff, 0x00, 0x57, 0x53, 0x5c, 0x82, 0x17, 0xd1, -0xf1, 0x06, 0xc5, 0x75, 0xd2, 0x8b, 0x50, 0xd7, -0xef, 0x8d, 0xce, 0x18, 0x85, 0xa3, 0x5a, 0x9d, -0x16, 0xe8, 0x13, 0xd3, 0xef, 0x63, 0xc3, 0x3f, -0xa3, 0xf0, 0xa1, 0xd0, 0xdc, 0xbf, 0x8a, 0x19, -0x84, 0xc1, 0x00, 0xcc, 0x18, 0x8e, 0x4a, 0x13, -0xb8, 0x54, 0x10, 0xff, 0x98, 0xcf, 0x37, 0xf1, -0x4f, 0x8a, 0xff, 0xa9, 0xd7, 0x4b, 0xce, 0x88, -0xcf, 0x46, 0xde, 0x82, 0xfa, 0x64, 0xc9, 0x07, -0xe2, 0x62, 0x18, 0xac, 0xa8, 0x6f, 0xf7, 0xb4, -0xdb, 0xf8, 0x9f, 0x0e, 0x33, 0xff, 0x65, 0xa0, -0x97, 0xab, 0xf4, 0xb6, 0xdd, 0x24, 0x00, 0x3d, -0xaa, 0x6f, 0x58, 0xc6, 0x40, 0xcc, 0xde, 0x1f, -0xd8, 0x46, 0x40, 0x75, 0xe0, 0x1f, 0xdb, 0xfd, -0x84, 0x85, 0x69, 0xd7, 0x6e, 0xe6, 0x91, 0x7c, -0x14, 0x89, 0x6b, 0x66, 0xd4, 0xe8, 0xae, 0x58, -0x26, 0xff, 0x73, 0x3d, 0xc6, 0xbb, 0xc8, 0x20, -0xdb, 0xe6, 0x57, 0x33, 0xb7, 0x7c, 0x9f, 0x0c, -0x1d, 0x3e, 0xf5, 0x57, 0x32, 0xb8, 0x02, 0x6a, -0x27, 0xec, 0x4e, 0xb8, 0x54, 0x1b, 0xff, 0xc3, -0xf3, 0x5f, 0xc6, 0x78, 0x2f, 0xc5, 0x26, 0xa0, -0x7e, 0xa0, 0x64, 0x9f, 0xfb, 0x1f, 0xf5, 0x77, -0xcb, 0xea, 0xb6, 0x97, 0xc4, 0x45, 0x95, 0x32, -0x47, 0xa4, 0xb3, 0x8d, 0x2a, 0x4d, 0xe7, 0xbf, -0xae, 0x66, 0xf8, 0x27, 0xcc, 0xc7, 0x8b, 0x1b, -0x73, 0x44, 0x3b, 0xc2, 0x65, 0x98, 0x08, 0x3e, -0x7b, 0x82, 0xcf, 0xc0, 0xc7, 0xda, 0xa2, 0x21, -0x16, 0xbf, 0x9c, 0xf9, 0xaf, 0xb7, 0x0c, 0x91, -0xcf, 0xb3, 0x30, 0x19, 0xac, 0x4f, 0x78, 0x12, -0xe2, 0x28, 0x4d, 0xd0, 0xd9, 0xbf, 0xf7, 0xda, -0xf0, 0xb3, 0x2d, 0xff, 0x55, 0xc1, 0xf0, 0x8f, -0x8a, 0x22, 0x9f, 0xdb, 0x6b, 0xe1, 0xb9, 0x3b, -0x3f, 0x7d, 0x4a, 0xee, 0x0e, 0xfd, 0xab, 0xde, -0x43, 0x6b, 0x13, 0xee, 0x9c, 0xfc, 0x0f, 0xe2, -0x9f, 0xc7, 0xe5, 0xea, 0x14, 0xdf, 0xa5, 0xaa, -0x47, 0x64, 0x28, 0x1d, 0xac, 0x8e, 0x11, 0x1e, -0xf1, 0xad, 0xfd, 0x85, 0x23, 0xff, 0xc5, 0x40, -0xe6, 0x5c, 0x9d, 0xd3, 0x6e, 0xbd, 0x92, 0x5f, -0xf7, 0x77, 0x91, 0xd1, 0xb2, 0x9f, 0xa6, 0x67, -0x38, 0xc5, 0xff, 0x58, 0xeb, 0x53, 0xda, 0x03, -0xbf, 0x63, 0xb0, 0xc4, 0x1b, 0x24, 0xb8, 0x90, -0x7c, 0x3a, 0xdb, 0x76, 0x8d, 0x62, 0x62, 0x42, -0xb7, 0xef, 0x17, 0x6c, 0xf9, 0x2f, 0x9e, 0x0f, -0x3d, 0xcc, 0xd7, 0x83, 0xcc, 0x03, 0xfd, 0x30, -0x9b, 0x96, 0x37, 0x8e, 0x19, 0x2b, 0x44, 0x4a, -0x2d, 0x95, 0x71, 0xcd, 0xbc, 0x9f, 0xe1, 0x1f, -0x40, 0xd9, 0xcf, 0xd6, 0x7d, 0xfc, 0x69, 0x75, -0xfa, 0xca, 0x6d, 0x30, 0xea, 0x49, 0x68, 0xb3, -0xfb, 0xed, 0xcf, 0xcf, 0xc8, 0x7f, 0xc9, 0x35, -0xba, 0x7b, 0x3f, 0x7b, 0xff, 0xe7, 0xa4, 0x2a, -0xdd, 0x1f, 0x0b, 0x5d, 0xe2, 0x40, 0xda, 0xfe, -0xfe, 0xb6, 0xfc, 0x97, 0x89, 0x7f, 0xae, 0x27, -0x83, 0x4a, 0x3d, 0xa8, 0xfa, 0x72, 0x95, 0xdd, -0x46, 0xc1, 0x39, 0x3f, 0x19, 0xf8, 0x27, 0xca, -0xf1, 0x00, 0x6e, 0xac, 0x76, 0x8c, 0xba, 0x37, -0x84, 0x4e, 0x6b, 0x5d, 0xdd, 0x5c, 0xff, 0x63, -0xf1, 0x21, 0x19, 0xfc, 0x4f, 0x8c, 0xe3, 0x9f, -0xc1, 0xe8, 0x87, 0x50, 0x97, 0x2c, 0xa9, 0xfc, -0xea, 0x71, 0xfd, 0xf9, 0x78, 0xd3, 0x08, 0x5e, -0x81, 0x0f, 0xb3, 0xf4, 0x3f, 0x88, 0x7f, 0x84, -0x25, 0xba, 0xfb, 0x1b, 0xb8, 0x7e, 0xe4, 0x96, -0x13, 0x2b, 0x3f, 0x10, 0x2f, 0x1b, 0xdf, 0xd7, -0x58, 0x3e, 0xfe, 0x67, 0x82, 0xd6, 0xf1, 0xcf, -0x96, 0x2d, 0xbc, 0xba, 0xa1, 0x4d, 0xdb, 0xd4, -0xf7, 0x18, 0xca, 0x61, 0x33, 0x66, 0xdf, 0xbf, -0x38, 0xf0, 0xcf, 0x73, 0x80, 0x22, 0x81, 0xd2, -0x59, 0xd0, 0xeb, 0xaf, 0x4c, 0xc8, 0xff, 0xd3, -0x37, 0x48, 0xbb, 0x54, 0xee, 0x51, 0x6d, 0xfc, -0x8f, 0xf9, 0x7c, 0x9d, 0x05, 0xd8, 0x9f, 0xd0, -0xca, 0xe4, 0x8a, 0x0d, 0xa5, 0x3f, 0x14, 0x0e, -0xd0, 0xca, 0x61, 0xd7, 0xea, 0x9d, 0xa7, 0xdb, -0x37, 0x75, 0x59, 0x19, 0x31, 0x34, 0x42, 0x8e, -0xfc, 0x17, 0xc3, 0x3f, 0x31, 0xe4, 0xf3, 0x91, -0x5f, 0x55, 0xfb, 0xdb, 0x1a, 0xd0, 0xb1, 0x0b, -0x1e, 0xc7, 0x7c, 0xda, 0xf3, 0x5f, 0x23, 0xf0, -0x0e, 0x03, 0xb1, 0x5e, 0xd5, 0x8b, 0x40, 0xa8, -0xae, 0x63, 0xf6, 0x2e, 0x11, 0x15, 0x41, 0xd7, -0x98, 0x88, 0xe8, 0x6e, 0x34, 0xec, 0xf8, 0x87, -0xc5, 0x23, 0x0d, 0xe3, 0x51, 0x01, 0xe6, 0x83, -0x2e, 0x41, 0x49, 0x97, 0xa8, 0xbb, 0xc6, 0x6f, -0x6a, 0x4e, 0x23, 0xa2, 0x2c, 0xfe, 0xe7, 0x6d, -0x16, 0xe6, 0xa6, 0x7d, 0x9f, 0x85, 0xc5, 0x0f, -0x18, 0xfe, 0x59, 0xf9, 0xd8, 0x8c, 0x35, 0xd2, -0x51, 0x32, 0xdb, 0xce, 0x0f, 0x38, 0xf1, 0x8f, -0xcc, 0xe3, 0xef, 0xf6, 0xdb, 0xab, 0x39, 0xed, -0xe3, 0xaa, 0x63, 0x6e, 0xe4, 0xa7, 0x61, 0x2e, -0x04, 0xca, 0xc5, 0xff, 0x48, 0x16, 0xff, 0xb3, -0x86, 0xdf, 0xef, 0x8f, 0xfa, 0xd6, 0x40, 0x0f, -0x0d, 0x20, 0xfe, 0xb1, 0xe9, 0x7f, 0xcc, 0x7f, -0x36, 0xfc, 0x23, 0x61, 0xb6, 0x6b, 0xb9, 0x1c, -0x2d, 0x94, 0x62, 0x3b, 0xd8, 0x95, 0x22, 0x1b, -0x1f, 0x72, 0xc4, 0xba, 0x7f, 0xb1, 0x1c, 0x86, -0x8b, 0x5c, 0xdd, 0x54, 0x15, 0x96, 0xfa, 0xd4, -0xb8, 0xbc, 0x92, 0x8a, 0x61, 0x9a, 0x30, 0xf4, -0x27, 0x6c, 0xbc, 0x85, 0x7c, 0xbc, 0xc7, 0x89, -0x85, 0x7f, 0xae, 0xdd, 0x85, 0xb2, 0x1f, 0x6d, -0x55, 0x74, 0xc6, 0x30, 0xd7, 0xff, 0x18, 0x40, -0x48, 0x32, 0x8c, 0x1c, 0xfc, 0xcf, 0xf4, 0x61, -0xe1, 0xb2, 0xa1, 0x17, 0xaa, 0x86, 0x0b, 0x0b, -0x67, 0x33, 0xfc, 0x26, 0xfc, 0x5e, 0xba, 0x20, -0x34, 0x6a, 0x79, 0xf8, 0x9f, 0x0a, 0xc4, 0x3f, -0x8d, 0x0c, 0xff, 0xb8, 0xc3, 0xb0, 0x38, 0x58, -0x5b, 0x2a, 0x53, 0x72, 0x46, 0xef, 0x43, 0xb7, -0x9c, 0x93, 0xff, 0xe1, 0xf8, 0x07, 0xf9, 0xae, -0x20, 0x59, 0x06, 0x7b, 0xd5, 0x75, 0x2b, 0x67, -0x2a, 0xa5, 0x03, 0xd1, 0x83, 0x10, 0x58, 0x2e, -0xdb, 0xc7, 0x6b, 0xcf, 0x7f, 0xb1, 0x8f, 0xb4, -0x86, 0xcf, 0x27, 0xe6, 0x1f, 0xb5, 0x22, 0x06, -0x44, 0xe1, 0xa0, 0xef, 0x0b, 0x9a, 0x2b, 0x3d, -0x9f, 0xa5, 0x2f, 0x38, 0xf2, 0x5f, 0x07, 0x0d, -0xfd, 0x0f, 0x7b, 0x7f, 0xd2, 0xbc, 0xf4, 0x1f, -0xf0, 0xb5, 0x3f, 0xf8, 0x5a, 0xf3, 0x52, 0xfe, -0xfe, 0x37, 0x40, 0x86, 0xfe, 0xe7, 0x49, 0x65, -0x97, 0x4d, 0xf6, 0x43, 0xac, 0xfc, 0x57, 0x9d, -0x83, 0xff, 0x79, 0x87, 0x9a, 0xcf, 0x37, 0xf0, -0x4f, 0x9d, 0xc1, 0xbf, 0xa1, 0xd1, 0xd6, 0xd1, -0x99, 0x54, 0x4e, 0x68, 0xcd, 0x4e, 0xfe, 0xc7, -0x91, 0xff, 0x3a, 0x8b, 0x22, 0x9f, 0xdf, 0x87, -0xfc, 0xd2, 0x21, 0xa1, 0x81, 0xca, 0x7b, 0xc8, -0x88, 0x7c, 0x1f, 0xd4, 0x76, 0x20, 0xff, 0xe3, -0x49, 0x41, 0xa3, 0x84, 0x62, 0xfa, 0x07, 0xcc, -0x7f, 0xed, 0x88, 0xa9, 0xfa, 0x4c, 0x70, 0xe1, -0xc6, 0x7c, 0x2e, 0x03, 0x42, 0x85, 0x2c, 0x70, -0x33, 0x37, 0xe5, 0xe0, 0x7f, 0x54, 0x7b, 0xfe, -0xeb, 0x29, 0x9d, 0x7d, 0xbf, 0xed, 0x84, 0x01, -0x21, 0x5a, 0x8d, 0xb4, 0xcf, 0x69, 0x0e, 0x0c, -0x8a, 0xd6, 0x17, 0x5a, 0xdf, 0xaf, 0x33, 0xff, -0x75, 0x89, 0xee, 0x4d, 0x7a, 0xdb, 0xc4, 0xd9, -0x0c, 0x78, 0x7c, 0xe6, 0xdc, 0xe7, 0x37, 0x54, -0x4d, 0x4a, 0xff, 0x8c, 0xb0, 0xc7, 0xc6, 0xff, -0x38, 0xf3, 0x5f, 0x3c, 0x89, 0xa3, 0xa0, 0xf7, -0x58, 0xd3, 0x3c, 0xe4, 0xda, 0xdf, 0x39, 0xaa, -0x5e, 0x5c, 0xdb, 0xfc, 0xcf, 0x0e, 0xfe, 0xc7, -0xf2, 0x3f, 0x5a, 0xc1, 0x15, 0xed, 0x23, 0x8c, -0x5f, 0x4f, 0x88, 0x77, 0x6b, 0x93, 0x83, 0x75, -0xc3, 0x9e, 0x27, 0xd8, 0xf8, 0x5f, 0xa6, 0xf5, -0x63, 0xd3, 0xc6, 0xc5, 0xb3, 0x30, 0x11, 0x6d, -0x4e, 0x7a, 0x2f, 0x64, 0xe4, 0xbf, 0xf6, 0xa1, -0x48, 0xe9, 0xff, 0x16, 0x4f, 0xd3, 0xe7, 0x40, -0x4d, 0xba, 0xfe, 0x9a, 0x9c, 0xd6, 0xb7, 0xd2, -0x79, 0x23, 0xec, 0xb5, 0x4f, 0x1b, 0x5b, 0x4b, -0x3b, 0xff, 0x43, 0xe1, 0x31, 0xa9, 0x01, 0xfd, -0x55, 0x88, 0xa0, 0xf0, 0x49, 0xd5, 0xe5, 0x10, -0x39, 0xa5, 0xfc, 0xa3, 0xa7, 0x12, 0x89, 0xa0, -0x53, 0x0a, 0x8e, 0x77, 0xc5, 0xfa, 0x50, 0xd2, -0xf2, 0x3f, 0x61, 0x86, 0x7f, 0xf6, 0xb1, 0xdb, -0xdc, 0xc0, 0x60, 0xd2, 0x61, 0x08, 0xeb, 0xae, -0x22, 0x36, 0x9f, 0x3b, 0xfb, 0xd7, 0x72, 0xff, -0xa3, 0xa4, 0xe6, 0x33, 0x9d, 0xff, 0xf2, 0x33, -0xfc, 0x13, 0x67, 0x61, 0xcb, 0x0b, 0xcc, 0x7f, -0x72, 0xda, 0x67, 0x1b, 0x73, 0xb3, 0x4f, 0x3e, -0x5c, 0xe5, 0x88, 0x5f, 0xc7, 0x1c, 0xf8, 0xe7, -0x22, 0x5e, 0xec, 0x9a, 0x81, 0xbf, 0x5e, 0xd1, -0x57, 0x6d, 0x7b, 0x78, 0x94, 0xbc, 0x66, 0xe7, -0x7f, 0xae, 0xcb, 0xc4, 0x3f, 0x97, 0xb4, 0x7a, -0xdd, 0x3b, 0x88, 0x7a, 0x06, 0xb2, 0xb0, 0xdf, -0x93, 0x14, 0x07, 0xe5, 0x53, 0xb0, 0x28, 0xed, -0xcf, 0x57, 0x21, 0xff, 0x63, 0xe5, 0xbf, 0x18, -0xfe, 0x39, 0x84, 0xf9, 0x97, 0x2d, 0xbe, 0x00, -0xa7, 0x7d, 0xe4, 0x1f, 0x95, 0x8e, 0x42, 0x77, -0xdb, 0x1d, 0xce, 0xf8, 0xeb, 0xc8, 0x7f, 0x7d, -0x1f, 0xef, 0xa7, 0x91, 0x3d, 0xc6, 0xfd, 0xdb, -0xd8, 0x6d, 0xdf, 0x2f, 0xab, 0x71, 0xdc, 0x6f, -0xe3, 0x7f, 0xc0, 0x03, 0xfb, 0xc2, 0x6c, 0x7e, -0x08, 0xf1, 0x50, 0xe6, 0x9f, 0x07, 0xe5, 0x52, -0x32, 0xa8, 0x76, 0xc8, 0x5c, 0x0f, 0xcc, 0x10, -0x91, 0x6a, 0xe0, 0x81, 0x02, 0x73, 0x3d, 0x80, -0xbc, 0xae, 0xe8, 0xe4, 0xda, 0x3a, 0x44, 0x77, -0x7b, 0xba, 0x26, 0xa1, 0xf7, 0xd8, 0x96, 0x48, -0xe7, 0xa5, 0xb6, 0x13, 0xed, 0xf5, 0x27, 0x71, -0xbc, 0x74, 0xc2, 0x6f, 0xc4, 0x77, 0x07, 0xff, -0x73, 0x51, 0x65, 0x41, 0x6a, 0xa9, 0x38, 0xaa, -0x4d, 0x92, 0x96, 0xc4, 0x02, 0x9d, 0x0d, 0x73, -0x5c, 0x68, 0xc6, 0xb4, 0xd7, 0x25, 0x0d, 0x15, -0x1d, 0xc8, 0xff, 0x48, 0x69, 0xbc, 0x71, 0x05, -0x26, 0xba, 0x38, 0xc8, 0x39, 0x2b, 0xbd, 0x51, -0x59, 0x3f, 0xc8, 0x56, 0xcb, 0x1b, 0x65, 0xbf, -0xeb, 0xa8, 0xfb, 0x45, 0xe0, 0x23, 0xb1, 0x09, -0x5e, 0x4e, 0xe1, 0x9f, 0x34, 0x3e, 0xb1, 0xf1, -0x3f, 0xf0, 0x3f, 0xa2, 0x9f, 0x7e, 0xc9, 0xbd, -0x8f, 0x8c, 0xd2, 0x9e, 0x6a, 0x5f, 0x87, 0xeb, -0x63, 0xd2, 0x14, 0xe3, 0x40, 0x25, 0x3b, 0xff, -0x95, 0x8a, 0xe6, 0x0f, 0x83, 0x3f, 0xd1, 0x1a, -0xf4, 0xb1, 0xfd, 0xb8, 0xac, 0x76, 0xcb, 0x75, -0xc4, 0xd3, 0xf5, 0xb8, 0x89, 0x7f, 0xcc, 0xbf, -0xaf, 0x8d, 0xff, 0x19, 0x55, 0x7e, 0x8a, 0x69, -0xc4, 0x78, 0x68, 0x54, 0xe9, 0x81, 0x18, 0xca, -0x84, 0x02, 0xf0, 0x53, 0xc8, 0xc8, 0x7f, 0xe9, -0xe5, 0xa3, 0x8a, 0x85, 0x87, 0x5f, 0x97, 0x1a, -0x91, 0xf6, 0x19, 0x85, 0x33, 0xd1, 0x73, 0x9a, -0x27, 0x2e, 0x06, 0x0c, 0xe9, 0x0e, 0xea, 0x9f, -0xd3, 0xfb, 0x97, 0x67, 0xe4, 0xe7, 0xd2, 0x78, -0x78, 0x01, 0xfe, 0xf5, 0x2f, 0xc1, 0x65, 0xda, -0xa2, 0xda, 0xe3, 0xbb, 0x3d, 0xff, 0xb5, 0x47, -0xb6, 0xf8, 0xc6, 0x5f, 0x33, 0x58, 0xb5, 0x05, -0x8d, 0xa3, 0x72, 0x03, 0x61, 0xcf, 0xf7, 0x68, -0x2f, 0x42, 0xf3, 0x60, 0x49, 0x3c, 0x07, 0xff, -0x53, 0x14, 0x67, 0x0b, 0x75, 0x2b, 0x4f, 0x7b, -0xb1, 0xff, 0x67, 0xb3, 0xea, 0x6b, 0xab, 0x18, -0xeb, 0xfc, 0xdf, 0xf2, 0x8b, 0xe8, 0x58, 0xe2, -0xb9, 0xf9, 0x9f, 0x2d, 0x5c, 0x26, 0x27, 0x23, -0x90, 0xeb, 0x80, 0xea, 0x76, 0xb9, 0x29, 0xf2, -0x80, 0x8f, 0x5d, 0x19, 0x72, 0xd9, 0xf1, 0xcf, -0x78, 0x2a, 0xff, 0x85, 0xd9, 0x1f, 0xfa, 0x08, -0x9d, 0x3f, 0x22, 0x6f, 0x28, 0x7c, 0x96, 0x6e, -0x8d, 0xdc, 0xe6, 0x97, 0x11, 0x0f, 0x6c, 0x8a, -0xcd, 0x1f, 0x81, 0x0c, 0xfc, 0x23, 0x7d, 0x48, -0xbf, 0xd3, 0xef, 0x5d, 0x22, 0xfe, 0x8c, 0xbd, -0xff, 0x1d, 0x49, 0xf9, 0xb0, 0xf8, 0x00, 0x7d, -0x9e, 0x36, 0x04, 0xda, 0xe3, 0x78, 0x85, 0xf9, -0x87, 0x12, 0x07, 0xfe, 0xf9, 0x7b, 0x83, 0xff, -0xb9, 0x1f, 0x67, 0xe3, 0x7d, 0xf9, 0xee, 0x17, -0xd8, 0x6c, 0x7c, 0x27, 0x34, 0xa9, 0xb4, 0x2c, -0x65, 0xc6, 0xdd, 0x39, 0xf0, 0x8f, 0x60, 0xdb, -0x8f, 0x30, 0x98, 0xc4, 0x69, 0x6a, 0xf1, 0x45, -0xa9, 0x4e, 0x5f, 0xb5, 0xbf, 0x73, 0xbe, 0xce, -0xa5, 0xd1, 0x7d, 0x6e, 0x57, 0x3a, 0xff, 0xf5, -0xa0, 0xa9, 0xff, 0x41, 0xb4, 0xe3, 0x9f, 0x3f, -0xc0, 0x69, 0xf3, 0x8d, 0xd0, 0x41, 0x19, 0x02, -0x9c, 0xed, 0xdb, 0x64, 0xfc, 0xb4, 0xcf, 0x91, -0xff, 0x32, 0x40, 0x0e, 0xe7, 0xbb, 0x02, 0x23, -0xae, 0x0d, 0xe4, 0x0a, 0x7c, 0x37, 0x52, 0x19, -0x9b, 0x79, 0x17, 0xf9, 0x21, 0x45, 0x05, 0xd4, -0x8a, 0x0d, 0x21, 0xc8, 0xd6, 0xff, 0xb0, 0xf5, -0x26, 0xf7, 0x9a, 0x34, 0xfe, 0xa3, 0x82, 0x3a, -0xe0, 0x0e, 0xba, 0xb6, 0x30, 0x20, 0xca, 0x7f, -0x7a, 0xc8, 0xaa, 0x17, 0x48, 0x96, 0x67, 0xf0, -0x3f, 0x5e, 0x83, 0xff, 0xe9, 0xdd, 0xc1, 0x8c, -0xdd, 0x86, 0x34, 0x3a, 0x26, 0x2e, 0x96, 0xac, -0xf9, 0x84, 0xa4, 0x60, 0xea, 0x51, 0x53, 0xd1, -0x67, 0xc6, 0x19, 0x69, 0xc4, 0x7e, 0x65, 0x6b, -0x76, 0xfe, 0x8b, 0x27, 0x41, 0x0c, 0x83, 0x85, -0x45, 0x54, 0x44, 0xf7, 0x69, 0x7b, 0x50, 0x08, -0x7d, 0x54, 0xd9, 0xa7, 0x95, 0x64, 0xe0, 0x1f, -0x9e, 0x2f, 0x4b, 0xf1, 0x0f, 0x77, 0x20, 0xec, -0xa9, 0x76, 0x15, 0xa1, 0xfe, 0x27, 0x3a, 0x63, -0x0d, 0x6c, 0xa6, 0x3c, 0x23, 0xe6, 0xcc, 0x7f, -0x3d, 0x9a, 0xc6, 0x3f, 0x01, 0x54, 0xa7, 0x74, -0xa9, 0x9b, 0x29, 0x97, 0xa9, 0x48, 0xb0, 0x59, -0x08, 0x63, 0xe0, 0x76, 0xf2, 0x3f, 0x3b, 0x52, -0x6a, 0x67, 0x04, 0x06, 0xcb, 0x8b, 0xf0, 0xb6, -0x0e, 0x5a, 0xbd, 0x42, 0x2e, 0x3d, 0xb2, 0x2c, -0xd6, 0x09, 0x19, 0xfa, 0x1f, 0xe4, 0x7f, 0xb6, -0xf3, 0xd1, 0xb1, 0xff, 0xd1, 0x71, 0xb5, 0x56, -0x66, 0x61, 0x37, 0x06, 0xba, 0xd8, 0x28, 0xcb, -0x11, 0x11, 0x22, 0x6d, 0x2c, 0x22, 0x97, 0x60, -0xfe, 0xcb, 0x7c, 0x9f, 0x13, 0xd7, 0xda, 0xf9, -0x1f, 0x84, 0x3d, 0x0f, 0x75, 0xbe, 0x1a, 0xbb, -0x5c, 0xb3, 0x88, 0x19, 0x8f, 0x23, 0xff, 0x33, -0x7b, 0xf9, 0x34, 0xa5, 0x35, 0x37, 0xff, 0x03, -0x47, 0x3d, 0x35, 0xa1, 0x92, 0x07, 0x99, 0xf1, -0x22, 0xdb, 0xf6, 0x7a, 0xbe, 0x27, 0xee, 0xa2, -0x2f, 0x91, 0x16, 0x84, 0x46, 0x2f, 0x94, 0x9a, -0xdf, 0xfb, 0x06, 0x8b, 0xff, 0x61, 0xaf, 0xd1, -0x0d, 0xbe, 0x0a, 0x86, 0x7f, 0xf4, 0x0e, 0x0a, -0x3e, 0xb9, 0x7b, 0x93, 0x6b, 0x21, 0xed, 0x66, -0x6f, 0xe8, 0xd0, 0x3f, 0x1b, 0xfc, 0x8f, 0x31, -0xde, 0x9d, 0x1d, 0xe0, 0x0f, 0xb9, 0x4a, 0xc9, -0xab, 0xfe, 0x8d, 0x52, 0xe5, 0xcd, 0x72, 0x3b, -0x29, 0x47, 0xc7, 0x1b, 0x72, 0xe6, 0xbf, 0xd2, -0xfc, 0x4f, 0x17, 0xe7, 0xd3, 0xe4, 0x68, 0x68, -0x80, 0xdc, 0xaf, 0x54, 0x69, 0xf2, 0x10, 0xb9, -0x9e, 0x5d, 0xe1, 0x54, 0xdb, 0x9b, 0xb9, 0xf9, -0x9f, 0xa3, 0x04, 0x65, 0x3c, 0x22, 0x12, 0x71, -0xfb, 0xda, 0x02, 0xd1, 0x19, 0xbb, 0x08, 0x4a, -0xdf, 0xa7, 0xd9, 0xf1, 0xcf, 0x88, 0x50, 0x9d, -0xbe, 0xff, 0x1b, 0x02, 0x02, 0x45, 0x71, 0x98, -0xf0, 0x8c, 0xa1, 0x22, 0x0e, 0x4c, 0x37, 0x7e, -0xaa, 0xba, 0x98, 0x83, 0xff, 0xf9, 0x22, 0xa2, -0x9d, 0x06, 0xb8, 0x9f, 0xb6, 0x8e, 0xc1, 0x29, -0xa8, 0x57, 0x3c, 0xba, 0x38, 0x56, 0xc1, 0x80, -0x68, 0x61, 0xee, 0xfc, 0x17, 0xf2, 0x3f, 0x87, -0xb8, 0xec, 0xa7, 0x74, 0x84, 0xeb, 0x7f, 0x3e, -0xbf, 0x33, 0x34, 0xa2, 0x3d, 0x00, 0x0b, 0xe2, -0xee, 0xa4, 0x3d, 0xff, 0x95, 0xf6, 0x3f, 0xf8, -0xe1, 0x54, 0xf7, 0x73, 0x22, 0xe8, 0xb0, 0x54, -0xf3, 0x4a, 0x22, 0xe8, 0xdb, 0xcc, 0x19, 0xa1, -0x99, 0x6a, 0xae, 0xfc, 0x17, 0xfb, 0x6c, 0xe9, -0x22, 0x98, 0x93, 0x68, 0xfb, 0x46, 0xe9, 0x10, -0xec, 0x12, 0xe6, 0x41, 0x91, 0x56, 0xf8, 0x2a, -0x2a, 0x82, 0xc0, 0x1d, 0xb6, 0xe7, 0xbf, 0xba, -0x67, 0x9b, 0x20, 0xe7, 0x0d, 0xb5, 0x97, 0x2e, -0x4a, 0x16, 0x7f, 0xbb, 0xea, 0x24, 0x9c, 0xa7, -0x4b, 0x10, 0xff, 0x5c, 0x24, 0xcb, 0xf0, 0xa7, -0xb5, 0xe2, 0x3b, 0xaa, 0x95, 0xff, 0xba, 0xd6, -0xd2, 0xff, 0xbc, 0x47, 0xd9, 0xc6, 0xf3, 0xc4, -0xaa, 0x7d, 0xe2, 0xb0, 0xfc, 0x3a, 0x3c, 0x8d, -0xdf, 0xd7, 0xef, 0x83, 0xe3, 0x86, 0x14, 0xff, -0x48, 0x97, 0x39, 0x3f, 0xb0, 0xf1, 0x8a, 0x92, -0xda, 0xa4, 0xb3, 0xdd, 0x7a, 0x67, 0xfd, 0x47, -0x2c, 0x7e, 0x9d, 0x85, 0x17, 0x69, 0xdd, 0x8f, -0x3c, 0x27, 0x30, 0xe3, 0x83, 0x8e, 0x7d, 0xad, -0x08, 0xd4, 0x91, 0xff, 0x8a, 0xb1, 0xf7, 0x0f, -0xc2, 0x29, 0xed, 0x2d, 0x68, 0x1a, 0x91, 0x83, -0xa5, 0xbf, 0x7d, 0xa5, 0x6b, 0xd7, 0xbc, 0xb5, -0x25, 0x49, 0x17, 0xf0, 0xf1, 0xb2, 0xf7, 0xaf, -0x59, 0x66, 0x3d, 0x1f, 0xf9, 0x9f, 0xf4, 0xee, -0x4c, 0xd5, 0x5d, 0xeb, 0xaf, 0x3a, 0xf1, 0x50, -0x97, 0xfa, 0x75, 0xca, 0x11, 0x60, 0x97, 0x31, -0x5e, 0xc8, 0xe4, 0x7f, 0x52, 0xf3, 0x29, 0x05, -0xfa, 0x2b, 0x82, 0xec, 0x43, 0xee, 0x24, 0x81, -0x76, 0x97, 0x5a, 0xaa, 0x1a, 0x1b, 0x5b, 0x95, -0xc8, 0x36, 0xfe, 0x27, 0x60, 0xf1, 0x1b, 0xcc, -0xb8, 0x53, 0x3f, 0x3e, 0x26, 0x0e, 0x17, 0xbe, -0x48, 0x9b, 0xb5, 0xad, 0x31, 0x51, 0x25, 0x09, -0x43, 0xcf, 0x53, 0x93, 0x2b, 0xff, 0x35, 0xca, -0xa2, 0xdb, 0x5d, 0x7a, 0x09, 0xe6, 0xbf, 0x46, -0x94, 0xd5, 0x11, 0xef, 0x36, 0x71, 0x54, 0xe1, -0x5b, 0xb3, 0x58, 0x8e, 0xfc, 0x57, 0x6a, 0xbf, -0x7f, 0x03, 0x73, 0xec, 0x33, 0x30, 0xd1, 0x57, -0xa5, 0xed, 0x49, 0xce, 0x58, 0x0f, 0xef, 0xd3, -0x5e, 0x94, 0x46, 0x3b, 0xf2, 0x5f, 0xa9, 0xf8, -0x65, 0xa0, 0x97, 0x7e, 0x16, 0xad, 0x9a, 0x94, -0x4d, 0xf0, 0x78, 0x57, 0xc5, 0x90, 0xab, 0x29, -0xd4, 0xa3, 0xf9, 0x80, 0x2d, 0xad, 0x64, 0x2e, -0xfe, 0xc7, 0x08, 0xdc, 0x6c, 0xfd, 0xac, 0xd1, -0x7a, 0xa4, 0xe5, 0xcc, 0xd3, 0x90, 0x6a, 0x39, -0x16, 0xf6, 0xc1, 0xcc, 0x58, 0x66, 0xfe, 0x2b, -0x68, 0xf0, 0x8d, 0x5a, 0x3d, 0x04, 0x8e, 0xb0, -0xf9, 0x91, 0x0b, 0xba, 0x55, 0x75, 0x80, 0x39, -0x6a, 0x59, 0xa3, 0x08, 0x1d, 0x55, 0xdb, 0xfe, -0x0b, 0x3c, 0x29, 0xfd, 0xcf, 0x5e, 0xf1, 0xe7, -0x6c, 0xe0, 0x4b, 0x4e, 0x15, 0x9f, 0x17, 0x6f, -0xeb, 0xd6, 0x2b, 0x16, 0x5f, 0x23, 0x53, 0x71, -0x19, 0xbc, 0xab, 0xd4, 0x95, 0xb1, 0x89, 0xd2, -0x2d, 0xff, 0x13, 0x2b, 0x66, 0xf1, 0x4b, 0x69, -0xd1, 0x8b, 0xcf, 0xf1, 0x68, 0xce, 0xfe, 0x8b, -0xe7, 0x22, 0x97, 0x7e, 0x6b, 0xcc, 0xc0, 0x8c, -0x71, 0x83, 0x11, 0x4a, 0x8a, 0x23, 0xd3, 0xec, -0xf8, 0xe7, 0x32, 0x5b, 0x96, 0xde, 0x0a, 0xf1, -0x9b, 0xca, 0x79, 0xda, 0xb0, 0xcb, 0x73, 0x4e, -0x5c, 0x47, 0x51, 0xf6, 0x53, 0xc2, 0xf1, 0x33, -0x6d, 0xce, 0xe0, 0x7f, 0x18, 0xfe, 0x79, 0x9b, -0x72, 0xfd, 0x8f, 0x0f, 0x46, 0x3a, 0x7c, 0xdd, -0xf2, 0x07, 0xad, 0x77, 0xa3, 0x10, 0x5a, 0xcf, -0xcf, 0xff, 0x1c, 0x24, 0x9c, 0xff, 0xd1, 0x98, -0xe3, 0x0a, 0x74, 0xbb, 0x82, 0x37, 0x7b, 0xda, -0x19, 0xec, 0x79, 0x7e, 0x66, 0x6e, 0xfe, 0x87, -0xe1, 0x9f, 0x83, 0x0a, 0xd7, 0xff, 0xdc, 0x06, -0x7d, 0xb4, 0x66, 0xa7, 0x2b, 0x4e, 0xd6, 0x65, -0xf1, 0x27, 0x63, 0x8e, 0xfc, 0xd7, 0x87, 0xc8, -0xff, 0x6c, 0x17, 0xc3, 0x10, 0x8f, 0x35, 0xc7, -0x6b, 0x4d, 0xd8, 0x53, 0x62, 0xc3, 0xcf, 0x43, -0x8e, 0xfc, 0x17, 0x1b, 0x9d, 0xce, 0x9c, 0xea, -0x5e, 0xb6, 0x94, 0x50, 0x06, 0x2f, 0x9e, 0x72, -0x28, 0xc4, 0x38, 0xff, 0x63, 0xcf, 0x7f, 0xc1, -0x44, 0x8c, 0x3f, 0xe4, 0x71, 0x38, 0x01, 0x88, -0xaf, 0x66, 0x04, 0x94, 0x17, 0xed, 0x78, 0x3b, -0x53, 0xff, 0x23, 0xf1, 0x97, 0x54, 0x68, 0x2d, -0xf3, 0xcf, 0x44, 0xef, 0x1c, 0x23, 0x4d, 0x24, -0x9b, 0xff, 0x31, 0xd7, 0x03, 0xe2, 0x9f, 0x07, -0x31, 0xe9, 0x39, 0x2b, 0x42, 0x69, 0x14, 0x5c, -0xe0, 0x46, 0x9a, 0x91, 0xbb, 0x9d, 0xbc, 0xfc, -0xcf, 0x53, 0x5c, 0xff, 0x1c, 0x2a, 0x85, 0x2d, -0xb4, 0x32, 0xd9, 0xb3, 0xb8, 0xb0, 0x64, 0xe9, -0x26, 0x43, 0xf6, 0x73, 0x9a, 0xe6, 0xd4, 0xff, -0xfc, 0xca, 0xd0, 0xff, 0x44, 0x60, 0x08, 0x16, -0xaf, 0xf5, 0x06, 0x5b, 0x4b, 0xb4, 0xe7, 0x29, -0xe7, 0x7f, 0x8e, 0xd3, 0x0f, 0x0d, 0xc3, 0xc9, -0xff, 0x5c, 0x36, 0xf4, 0xcf, 0x43, 0xda, 0x28, -0x2c, 0x19, 0x58, 0x35, 0xe6, 0xfe, 0x39, 0x4c, -0x2a, 0xcd, 0x53, 0xe8, 0x7f, 0x78, 0xfe, 0x51, -0x11, 0x7d, 0x32, 0x43, 0x0b, 0xaa, 0xa7, 0xb7, -0xf5, 0xbd, 0xf6, 0xd7, 0xd9, 0x95, 0xad, 0x71, -0xf1, 0x38, 0x3c, 0x4f, 0x83, 0xc9, 0xdc, 0xfa, -0xe7, 0xf6, 0x4f, 0x2b, 0xca, 0xbd, 0xb0, 0x40, -0x93, 0xef, 0x64, 0xc3, 0x44, 0xd8, 0x23, 0xae, -0x87, 0x53, 0x64, 0x13, 0xdb, 0x6a, 0xf9, 0x33, -0xf5, 0xcf, 0x4f, 0xd1, 0xaf, 0x27, 0x8b, 0x4e, -0x90, 0x5e, 0xd4, 0x7b, 0x87, 0x8b, 0x18, 0x10, -0x42, 0xe0, 0xc7, 0xf9, 0x9f, 0xe9, 0x9b, 0x72, -0xeb, 0x9f, 0xd7, 0xe1, 0xfe, 0x2b, 0xa2, 0x46, -0x92, 0x81, 0xf0, 0xe7, 0x38, 0xb1, 0x6f, 0xf2, -0x8d, 0x9d, 0x86, 0x10, 0xe8, 0x15, 0xc9, 0xfc, -0x5e, 0x4c, 0xfd, 0x73, 0xf1, 0xef, 0xc5, 0x83, -0xf2, 0xf1, 0x58, 0xcb, 0x43, 0xc5, 0x0c, 0xff, -0x28, 0x27, 0x4d, 0x20, 0x74, 0x8c, 0x6d, 0x16, -0xb9, 0xfe, 0xd9, 0x9a, 0x4f, 0xcc, 0x7f, 0x2d, -0x6d, 0x66, 0xf1, 0x57, 0x50, 0xd9, 0x9f, 0xa5, -0x99, 0x94, 0x18, 0xdb, 0xf0, 0xbb, 0x53, 0x08, -0x21, 0xa7, 0xfe, 0x47, 0xc5, 0xfa, 0xaf, 0x19, -0xc3, 0x6c, 0xe3, 0x3f, 0x1b, 0x89, 0x02, 0x09, -0xde, 0x16, 0x1a, 0x58, 0x98, 0x9b, 0x91, 0x9b, -0xff, 0x81, 0x83, 0x2a, 0x8b, 0xbf, 0x4a, 0x64, -0x8e, 0xc9, 0x36, 0xec, 0x82, 0xcd, 0x19, 0xf5, -0x5c, 0x39, 0xf4, 0x3f, 0x71, 0x62, 0x05, 0x6e, -0x53, 0x11, 0x9d, 0xab, 0xfe, 0xcb, 0xe2, 0x7f, -0xa2, 0x6c, 0x99, 0xa5, 0x84, 0xd0, 0x5d, 0xb1, -0x0e, 0x0b, 0x11, 0x65, 0xd6, 0x7f, 0x71, 0xfd, -0x8f, 0x31, 0xa8, 0x54, 0x20, 0x8e, 0x88, 0x2a, -0xc5, 0xfc, 0x8b, 0x9d, 0xef, 0x3a, 0xee, 0xd0, -0xff, 0x70, 0x3e, 0x67, 0x4c, 0x7c, 0x15, 0x17, -0x12, 0xcf, 0x7f, 0x49, 0x17, 0x84, 0xe6, 0xe5, -0xab, 0x0c, 0x7e, 0x63, 0x36, 0xe2, 0x01, 0x1b, -0xff, 0x23, 0x0c, 0xb3, 0x6d, 0x69, 0x09, 0x03, -0x39, 0xd3, 0xf6, 0xc3, 0x99, 0x02, 0xa4, 0x4d, -0x3a, 0x39, 0x42, 0x68, 0xe7, 0xf5, 0x62, 0x97, -0x51, 0x1a, 0x1d, 0xb5, 0xe1, 0x1f, 0xcc, 0x7f, -0x2d, 0x36, 0xf0, 0x8f, 0xca, 0x81, 0x90, 0xe7, -0xde, 0x08, 0x37, 0x10, 0xf6, 0xe4, 0xa8, 0xff, -0x62, 0xf8, 0x47, 0x5a, 0x68, 0x54, 0x6f, 0x75, -0xc1, 0x0e, 0x21, 0xb0, 0x7c, 0xa6, 0x42, 0x0a, -0x14, 0x36, 0xcc, 0x36, 0x77, 0x6e, 0xfe, 0x07, -0xf1, 0x4f, 0x29, 0xd7, 0xff, 0xec, 0xd2, 0x0e, -0x6a, 0x48, 0xa3, 0xb9, 0x72, 0xd4, 0xd3, 0x65, -0xe1, 0x9f, 0x92, 0x32, 0xf2, 0xe3, 0xae, 0xb7, -0xa1, 0x19, 0xd3, 0x58, 0xd5, 0xce, 0x0c, 0x97, -0x83, 0xff, 0xb1, 0xf2, 0x5f, 0xdb, 0xc5, 0xb9, -0xdc, 0xf8, 0x27, 0x25, 0x35, 0x2d, 0xb6, 0xfb, -0xab, 0x1c, 0xf9, 0x2f, 0x13, 0x6f, 0x9f, 0x81, -0x11, 0xad, 0x8e, 0x45, 0xf4, 0xf4, 0xb4, 0xe7, -0xd1, 0xff, 0x3c, 0x8b, 0xf8, 0xe7, 0x1d, 0xf6, -0xac, 0xfb, 0xe0, 0x2a, 0x5a, 0xc2, 0x81, 0x90, -0x64, 0x21, 0xa2, 0x4c, 0xfd, 0x0f, 0xe2, 0x1f, -0x63, 0xd3, 0x3d, 0x48, 0x1f, 0x07, 0xb5, 0xbf, -0x35, 0x18, 0xb2, 0x47, 0x70, 0x53, 0xff, 0x63, -0xcf, 0x7f, 0x3d, 0xc5, 0xf1, 0x4f, 0xe1, 0x2b, -0x0c, 0xe9, 0xcf, 0x19, 0x70, 0x7d, 0x93, 0x03, -0x83, 0xe2, 0x01, 0xb7, 0x43, 0xff, 0x63, 0x3e, -0xdf, 0xd0, 0xff, 0xdc, 0x98, 0x5c, 0xb5, 0xa1, -0xf5, 0xa4, 0xf2, 0x16, 0x5d, 0x38, 0xe2, 0xbd, -0x1b, 0x69, 0x9f, 0x8e, 0x6b, 0x47, 0xbc, 0x76, -0xfd, 0x8f, 0xb9, 0xdc, 0x38, 0xfe, 0xb9, 0x90, -0x22, 0xed, 0xd1, 0xb1, 0x0c, 0x79, 0x9f, 0xee, -0x64, 0x1e, 0x46, 0x6a, 0x3e, 0xe9, 0xe0, 0x7f, -0xd2, 0xfc, 0x3f, 0xd7, 0x3f, 0x73, 0xd9, 0x4f, -0x23, 0x4c, 0xd2, 0xba, 0xf3, 0x25, 0xe3, 0xad, -0xcd, 0x58, 0xf6, 0xe5, 0xd4, 0xff, 0x38, 0xf8, -0x9f, 0x33, 0x49, 0xf6, 0x92, 0xff, 0xb3, 0x90, -0xaa, 0x07, 0xe0, 0x33, 0x23, 0xf2, 0x7a, 0xf1, -0x2b, 0xd0, 0x1b, 0x5f, 0x87, 0xfa, 0x1f, 0xeb, -0xfd, 0x9d, 0xf9, 0xaf, 0xa7, 0xe5, 0x79, 0xba, -0x6b, 0x8c, 0xac, 0xd6, 0x9e, 0x83, 0xaa, 0x01, -0x76, 0xdb, 0xad, 0x14, 0x6f, 0xab, 0x30, 0xee, -0x67, 0x3f, 0x65, 0xea, 0x7f, 0xf6, 0xa2, 0xb7, -0x69, 0xf2, 0xf5, 0x43, 0xaf, 0x16, 0x48, 0xb6, -0x05, 0xc9, 0x4a, 0xa1, 0x17, 0x2b, 0xa4, 0x6c, -0xf3, 0xe9, 0xcc, 0x7f, 0x7d, 0xc8, 0xc2, 0x4a, -0x49, 0xac, 0xf3, 0x76, 0x38, 0xac, 0x54, 0x8d, -0x95, 0x8c, 0x89, 0xeb, 0x14, 0xdc, 0x81, 0xca, -0x6c, 0xbc, 0x05, 0x13, 0x42, 0x23, 0x06, 0x32, -0x67, 0xfe, 0xeb, 0x6d, 0x64, 0xe3, 0xf7, 0xcd, -0x88, 0x31, 0x7c, 0xd8, 0x30, 0xc8, 0xbc, 0xb7, -0x7d, 0x07, 0x6a, 0x14, 0x82, 0x39, 0xf9, 0x9f, -0xcb, 0x50, 0xdf, 0xcf, 0xbe, 0xc7, 0x20, 0xf3, -0xde, 0x4b, 0xf4, 0x82, 0xb1, 0xaa, 0x26, 0xb8, -0x87, 0x05, 0x3e, 0x4b, 0xff, 0x53, 0x6c, 0xe7, -0x7f, 0x30, 0xff, 0xf5, 0x28, 0x65, 0xf1, 0xb7, -0x89, 0x3c, 0xae, 0xbe, 0xcb, 0xf5, 0x3f, 0x21, -0xac, 0xf0, 0x9a, 0x9b, 0xd2, 0xff, 0x64, 0xd5, -0x7f, 0x09, 0x0c, 0xff, 0x74, 0xf9, 0xb0, 0x5e, -0xcc, 0xc7, 0x65, 0x63, 0xae, 0xb8, 0x0b, 0x11, -0xd1, 0x1d, 0x53, 0xe8, 0x7f, 0x1e, 0x54, 0x63, -0x7a, 0x4f, 0x3c, 0x44, 0x71, 0x36, 0x8e, 0xb0, -0xd9, 0x28, 0xde, 0xd8, 0x5b, 0x57, 0xfd, 0x4a, -0x91, 0x03, 0x0f, 0x58, 0xd3, 0x5f, 0xbc, 0x8e, -0xe1, 0x01, 0x5e, 0xc4, 0xad, 0xb6, 0x1d, 0x86, -0x96, 0x81, 0x92, 0xf5, 0x62, 0x20, 0x36, 0xe1, -0xf9, 0xcc, 0xd1, 0x59, 0x0c, 0x21, 0xe3, 0x8e, -0x1b, 0x2b, 0x94, 0x6d, 0xf5, 0x5f, 0xd7, 0x5e, -0x82, 0x7f, 0xc5, 0xfc, 0x57, 0x7b, 0xe7, 0x58, -0xf7, 0x5b, 0xe4, 0x7f, 0x27, 0x8a, 0x51, 0xc8, -0xc1, 0x0b, 0x09, 0xd9, 0x78, 0xf7, 0x4c, 0xa6, -0xf4, 0xcf, 0x0e, 0xfd, 0xcf, 0x84, 0xb1, 0x48, -0xd8, 0xee, 0x9e, 0x36, 0x25, 0xff, 0x71, 0x4c, -0x6c, 0x8a, 0x4d, 0xd2, 0xeb, 0x38, 0xa2, 0xd6, -0x26, 0x81, 0x21, 0xf6, 0x4c, 0xfc, 0x73, 0x38, -0x52, 0x9b, 0xec, 0xe9, 0x13, 0x7f, 0xc6, 0x06, -0xde, 0x98, 0x94, 0x2f, 0x91, 0x16, 0xdc, 0x96, -0x26, 0x57, 0xf4, 0x91, 0x61, 0x7a, 0x50, 0xf6, -0x1d, 0x71, 0x65, 0xe2, 0x1f, 0x1c, 0x94, 0xc8, -0x47, 0x27, 0x32, 0x3c, 0xb9, 0x10, 0xf5, 0x18, -0xc0, 0x11, 0xd1, 0xe0, 0x74, 0xf6, 0xe9, 0x25, -0x8a, 0x32, 0xf1, 0x8f, 0x0d, 0x4f, 0xd6, 0xe8, -0x10, 0x0f, 0xed, 0x61, 0xfe, 0xbf, 0xa6, 0xbb, -0x07, 0xfd, 0xcf, 0x42, 0x94, 0x76, 0x64, 0xe2, -0x9f, 0x54, 0xfe, 0x74, 0x1d, 0xd7, 0x83, 0x79, -0x90, 0x9f, 0xf9, 0x9d, 0x81, 0x58, 0x86, 0xe5, -0xf1, 0x30, 0x4a, 0x83, 0xa6, 0x0d, 0xe5, 0xd0, -0xff, 0x90, 0x4b, 0xbc, 0xfa, 0xef, 0x67, 0x63, -0xe2, 0x77, 0xe0, 0x3d, 0xbd, 0x3e, 0xc9, 0xa6, -0xe5, 0x3c, 0x5c, 0x61, 0x0b, 0xa3, 0x04, 0x81, -0xa2, 0xf9, 0x7c, 0x23, 0xff, 0x95, 0x46, 0x3b, -0x03, 0xec, 0xf9, 0x83, 0xbc, 0xac, 0x7e, 0x15, -0x7b, 0x3e, 0xfa, 0x1f, 0x3d, 0x9b, 0xff, 0x11, -0x6c, 0x68, 0x87, 0x45, 0xe7, 0x4b, 0x70, 0x90, -0xd6, 0x50, 0xf7, 0x77, 0xd9, 0xfb, 0x1f, 0xca, -0xcd, 0xff, 0x54, 0x5b, 0xde, 0x26, 0xe9, 0xba, -0x01, 0x8d, 0xb6, 0x6a, 0x84, 0xc1, 0x48, 0xa5, -0x06, 0x74, 0x57, 0x56, 0xfe, 0x2b, 0x66, 0x65, -0x7f, 0x16, 0x20, 0x1f, 0x72, 0x1a, 0x0e, 0x3d, -0x34, 0x6f, 0x64, 0xc5, 0x06, 0xf2, 0x2a, 0xec, -0xef, 0xe0, 0x42, 0xe8, 0xcc, 0xfc, 0x17, 0x4f, -0x72, 0x0d, 0xc2, 0x87, 0xca, 0x77, 0x46, 0x4a, -0xea, 0xaa, 0x18, 0xec, 0xd9, 0x1d, 0x1c, 0xf5, -0x56, 0x8b, 0x83, 0xda, 0x39, 0xf6, 0xfe, 0x85, -0x99, 0xf8, 0x67, 0x92, 0xe1, 0x67, 0x6f, 0x7c, -0x1a, 0xc7, 0xcf, 0x03, 0x5f, 0x67, 0x13, 0x1b, -0x66, 0xd3, 0xd2, 0xc5, 0x10, 0x23, 0x1b, 0xaf, -0xd2, 0x9c, 0x1b, 0xff, 0xa4, 0xe6, 0xa7, 0x49, -0x2f, 0xd9, 0xff, 0xfc, 0x71, 0xfa, 0x3c, 0xb0, -0xf8, 0x1e, 0x53, 0xdf, 0xc4, 0xd4, 0x0f, 0x4e, -0x54, 0xae, 0xfa, 0xaf, 0x94, 0xb7, 0x41, 0x19, -0xa1, 0x7a, 0x2f, 0xf9, 0x9a, 0xb6, 0x62, 0x3d, -0xe1, 0xfb, 0xc7, 0xcc, 0xfc, 0x17, 0xf2, 0x3f, -0x73, 0x70, 0xbc, 0x5f, 0xe1, 0x44, 0x90, 0xeb, -0xdb, 0x85, 0xa7, 0xe9, 0x26, 0x3a, 0x2f, 0xec, -0x5e, 0x4b, 0x3e, 0x82, 0x8d, 0x0c, 0x1a, 0xb9, -0x73, 0xd6, 0x7f, 0xb1, 0xf9, 0x94, 0xd0, 0xe8, -0xc6, 0x89, 0x8d, 0x14, 0x04, 0x54, 0x8c, 0x77, -0x45, 0x9d, 0x6a, 0x6d, 0x66, 0xfe, 0x6b, 0x37, -0xfb, 0xa3, 0x34, 0x20, 0xda, 0x59, 0xcb, 0x81, -0x50, 0x09, 0xc2, 0x9e, 0x23, 0xd0, 0x18, 0x43, -0xfc, 0x43, 0xcf, 0xd2, 0xe6, 0xcc, 0xfc, 0x97, -0x3d, 0xfa, 0x48, 0xcd, 0x42, 0x4a, 0xf6, 0xbc, -0x53, 0xc2, 0x2b, 0x02, 0x9b, 0x9f, 0xdc, 0xf9, -0x2f, 0x33, 0xba, 0x85, 0x8b, 0x1e, 0xab, 0x1f, -0x56, 0x2e, 0x40, 0x5d, 0xd8, 0x8a, 0x77, 0x25, -0x51, 0x92, 0xb3, 0xfe, 0x0b, 0xa3, 0x6d, 0x20, -0x2c, 0x6f, 0xf7, 0x0d, 0xcb, 0x07, 0xb5, 0x9a, -0xb0, 0x15, 0x7f, 0xb3, 0xf8, 0x1f, 0x7b, 0x74, -0x6e, 0xe3, 0x78, 0xe9, 0xa0, 0xfc, 0x37, 0xcb, -0x7e, 0x30, 0x94, 0xba, 0x3f, 0x8b, 0xff, 0x31, -0x82, 0x7e, 0x21, 0x8f, 0xfe, 0x4b, 0xfd, 0xa5, -0x74, 0x20, 0xf6, 0x14, 0xcc, 0xd3, 0xd8, 0x7e, -0x76, 0x00, 0x16, 0xfa, 0x03, 0xd9, 0xfc, 0xcf, -0x88, 0x3d, 0xda, 0xfe, 0x8f, 0xc8, 0xd2, 0x18, -0xc5, 0xb2, 0xa3, 0xad, 0x3a, 0x5e, 0x51, 0xb9, -0x22, 0xf7, 0x78, 0xa6, 0xfe, 0xd9, 0x1c, 0x6f, -0x0b, 0xea, 0x5b, 0x18, 0x22, 0x12, 0x3e, 0xc2, -0x2b, 0xaf, 0xee, 0xba, 0x6c, 0x64, 0xc4, 0x6c, -0xf8, 0xc7, 0xc6, 0xff, 0x78, 0xf0, 0x7e, 0xd7, -0x2b, 0x9d, 0xe7, 0x95, 0x7f, 0x83, 0x7d, 0xec, -0x4a, 0xeb, 0x30, 0x1c, 0xf5, 0xd7, 0x2d, 0x2b, -0xce, 0xd4, 0x3f, 0x8f, 0xa4, 0xf4, 0x3f, 0x1c, -0xed, 0xc8, 0x5d, 0x21, 0xac, 0x08, 0x63, 0xdb, -0x52, 0x9d, 0xe8, 0xb1, 0x11, 0xd5, 0x27, 0xcb, -0x59, 0xf9, 0x2f, 0x03, 0xe4, 0x2c, 0x93, 0x50, -0x08, 0x74, 0x8d, 0x42, 0x7e, 0x01, 0x3f, 0x87, -0x39, 0x61, 0xb6, 0xcc, 0x86, 0x37, 0xef, 0xf5, -0x07, 0xda, 0x8a, 0x94, 0xc2, 0x23, 0x56, 0xfd, -0x08, 0xe2, 0x1f, 0x07, 0x7a, 0xac, 0x88, 0x86, -0xd0, 0xf8, 0x53, 0xcd, 0x7d, 0x82, 0x5d, 0xd9, -0xc1, 0x66, 0x4c, 0xce, 0x85, 0x7f, 0xbc, 0x28, -0xfb, 0x41, 0xa3, 0xd0, 0x18, 0x78, 0xc3, 0x52, -0x43, 0xf8, 0x0d, 0xcf, 0x6a, 0x7f, 0x9f, 0x13, -0xff, 0x98, 0xf9, 0xaf, 0xad, 0xc6, 0xfd, 0x8d, -0xa9, 0x0a, 0x32, 0x23, 0x11, 0x96, 0x47, 0xff, -0x83, 0x78, 0x9b, 0x27, 0xc2, 0x86, 0xa0, 0x51, -0x4d, 0x29, 0x82, 0xea, 0xf2, 0xe8, 0x9f, 0x91, -0xf6, 0x39, 0x04, 0xf3, 0xa3, 0xf2, 0x4e, 0xf0, -0xcb, 0xf7, 0x19, 0x65, 0xef, 0x23, 0x50, 0xc3, -0x8c, 0x15, 0x59, 0xf8, 0xc7, 0x8e, 0x76, 0x8a, -0x82, 0x3e, 0x0f, 0x44, 0x61, 0x2d, 0xb8, 0xa1, -0x70, 0x50, 0xc0, 0xc2, 0x81, 0x2c, 0xfc, 0x63, -0xff, 0x7e, 0xb5, 0x4f, 0x6f, 0x20, 0x25, 0xf2, -0x56, 0x98, 0x0f, 0x2b, 0xda, 0x7d, 0xa7, 0xa0, -0xb7, 0xb2, 0x32, 0x1b, 0xff, 0xa4, 0x40, 0x8e, -0x81, 0x76, 0x8a, 0x51, 0xff, 0xfc, 0xcf, 0xf4, -0x86, 0x98, 0xb7, 0x4d, 0x3c, 0x4d, 0xff, 0x25, -0xb6, 0xf7, 0x1d, 0xc4, 0x3f, 0x76, 0xfd, 0xcf, -0x74, 0xbb, 0x3f, 0x59, 0x8a, 0x32, 0x57, 0x69, -0x02, 0x33, 0xd4, 0x51, 0x71, 0x54, 0x7b, 0xb7, -0xbd, 0xf9, 0x84, 0xdb, 0x9e, 0xff, 0x02, 0x29, -0x15, 0xbf, 0x2e, 0x88, 0x67, 0x19, 0xec, 0xb9, -0x31, 0xe6, 0xb9, 0x20, 0xce, 0xd6, 0xf4, 0xe8, -0x5d, 0x61, 0xef, 0x88, 0x38, 0x29, 0x4f, 0xea, -0xf5, 0x6f, 0x3a, 0xf1, 0x8f, 0xf2, 0x18, 0x7b, -0x8d, 0x6f, 0x63, 0xfd, 0xda, 0x69, 0x84, 0x31, -0xaa, 0xbc, 0xa1, 0xb4, 0xa4, 0xfb, 0xd7, 0x3b, -0x82, 0x61, 0xf7, 0xb7, 0xf0, 0x4a, 0x5f, 0xe5, -0x48, 0x16, 0xfe, 0xf9, 0x09, 0x31, 0xf4, 0x3f, -0x38, 0x5e, 0xda, 0xb6, 0xde, 0x37, 0x8b, 0x6e, -0xf4, 0x7f, 0x7d, 0xc8, 0x1d, 0x26, 0xa7, 0xf6, -0xf6, 0xf2, 0x54, 0x7e, 0x96, 0xfe, 0xd9, 0x6f, -0xcd, 0xa7, 0xe0, 0x0f, 0xb2, 0x8d, 0xc6, 0xc3, -0xba, 0x8a, 0x0a, 0x87, 0xb3, 0x3c, 0x43, 0x94, -0x85, 0x7f, 0xde, 0x95, 0xd2, 0xf1, 0x85, 0x56, -0xb0, 0xfd, 0xbb, 0x44, 0x3b, 0x1a, 0xf5, 0x55, -0xfb, 0xbf, 0x78, 0xa5, 0x6c, 0x52, 0xea, 0xc5, -0x8d, 0xa4, 0x13, 0xff, 0xbc, 0xcb, 0xb7, 0xe1, -0x22, 0x87, 0x85, 0x8a, 0x37, 0xee, 0x1e, 0x65, -0x1b, 0x2b, 0x76, 0xff, 0x33, 0x9d, 0xa6, 0x2b, -0x16, 0x9c, 0xf8, 0xe7, 0x7d, 0x6b, 0x77, 0x2f, -0xb5, 0xc8, 0xf3, 0x0f, 0x7e, 0xf1, 0x92, 0x7c, -0xb9, 0x3b, 0x95, 0xff, 0xda, 0xca, 0x10, 0x91, -0x27, 0x03, 0xff, 0xc8, 0x69, 0x3d, 0x0f, 0x09, -0xa8, 0x72, 0x1f, 0x19, 0x15, 0x0e, 0x22, 0xe3, -0x81, 0x57, 0x7e, 0x6a, 0x08, 0xa1, 0x73, 0xf2, -0x3f, 0x3c, 0xde, 0x45, 0x3f, 0x17, 0x2f, 0x1d, -0x85, 0x3e, 0xf5, 0xa6, 0x81, 0x9e, 0x3e, 0x7e, -0x7f, 0x8d, 0x2e, 0xe7, 0xd4, 0x3f, 0xd7, 0x91, -0x41, 0x2c, 0x7b, 0x07, 0xac, 0x4f, 0xe9, 0xda, -0x1b, 0x8c, 0x8d, 0xe0, 0x8c, 0x75, 0x3c, 0xae, -0xaa, 0x47, 0x36, 0x67, 0xd5, 0xbf, 0x23, 0xff, -0x63, 0xe8, 0x4f, 0x9a, 0x67, 0x15, 0xef, 0x6b, -0x7d, 0xaf, 0xeb, 0x60, 0x51, 0xc3, 0x51, 0xce, -0x98, 0xbd, 0x0f, 0x87, 0x13, 0x9e, 0x4c, 0xfc, -0x33, 0xb9, 0x98, 0x8d, 0x77, 0x6f, 0x2b, 0x8f, -0x5f, 0x15, 0x25, 0x0f, 0x8a, 0xa3, 0xc9, 0xcb, -0xea, 0x73, 0x98, 0xc8, 0x18, 0xc5, 0xfa, 0x77, -0x94, 0x82, 0x3b, 0xf1, 0xcf, 0x08, 0x03, 0x39, -0x25, 0xe3, 0x5f, 0xbd, 0x02, 0x2f, 0xd1, 0x7a, -0x8d, 0xcd, 0xc6, 0x6f, 0xd8, 0x26, 0x63, 0x61, -0x98, 0xe1, 0xe7, 0xd9, 0xcc, 0xb8, 0x31, 0xe9, -0x19, 0x71, 0xe8, 0x9f, 0x47, 0xe1, 0x01, 0xae, -0xee, 0x2e, 0x1d, 0xe5, 0xdd, 0x78, 0x18, 0x30, -0x1e, 0x35, 0xcb, 0xd2, 0x79, 0xc5, 0x37, 0x0a, -0xed, 0x54, 0x9b, 0xff, 0x19, 0x05, 0x3f, 0x43, -0x8f, 0x2e, 0x73, 0xf7, 0xcd, 0xd6, 0xc3, 0x00, -0x1a, 0x1a, 0x5f, 0x18, 0x9d, 0x10, 0xa0, 0x19, -0xfa, 0x67, 0x0f, 0x96, 0xbd, 0xa0, 0xda, 0x79, -0x50, 0xeb, 0xec, 0x37, 0x0c, 0xda, 0xc3, 0x02, -0xbf, 0xfd, 0xf9, 0x41, 0x1b, 0xfe, 0x39, 0xab, -0x8d, 0x68, 0xd7, 0x23, 0x08, 0x39, 0x4b, 0x5e, -0xa4, 0x0f, 0x45, 0xf1, 0x7b, 0x21, 0x2f, 0xc2, -0xbe, 0x64, 0x20, 0xee, 0xae, 0x65, 0x46, 0x73, -0xcc, 0x13, 0x73, 0x3b, 0xf5, 0xcf, 0x17, 0x85, -0x96, 0x21, 0x06, 0x7a, 0xaf, 0xe0, 0xfc, 0x3c, -0xb4, 0xca, 0x30, 0xf8, 0x0a, 0x41, 0xbc, 0xd7, -0xb2, 0x6b, 0x41, 0x32, 0x83, 0xff, 0x49, 0x18, -0x4d, 0x84, 0xf0, 0xb1, 0x4d, 0xd1, 0xaf, 0xec, -0x13, 0x03, 0xf8, 0xd8, 0x04, 0xd7, 0x9f, 0xbf, -0xa8, 0x34, 0x23, 0x3f, 0x10, 0xb4, 0xe1, 0x9f, -0xf9, 0x5a, 0x27, 0x3c, 0x89, 0xeb, 0xe1, 0xbd, -0x76, 0xfe, 0xb6, 0x97, 0x48, 0x40, 0xe8, 0xe9, -0xae, 0x1d, 0x2a, 0xde, 0x4f, 0xde, 0x54, 0x5f, -0x6f, 0xaf, 0xdd, 0x56, 0xbc, 0x27, 0x52, 0xe7, -0xc0, 0x3f, 0x51, 0xc3, 0xc9, 0x18, 0xfa, 0x43, -0x57, 0x53, 0xc8, 0x43, 0x7b, 0xa4, 0x80, 0x2e, -0x3f, 0x4d, 0x46, 0x69, 0x27, 0xd4, 0x26, 0xe5, -0x9d, 0x64, 0xb1, 0x03, 0xff, 0x7c, 0x2f, 0x3e, -0xcf, 0xc0, 0x3f, 0x9b, 0xba, 0x8a, 0x93, 0xf2, -0x86, 0xc2, 0x66, 0x75, 0x13, 0xfd, 0x1f, 0xc3, -0x45, 0x98, 0x18, 0xfa, 0x13, 0xba, 0x20, 0x59, -0xb4, 0x96, 0x54, 0xd8, 0xf0, 0x4f, 0x80, 0xfc, -0x4a, 0x8f, 0x23, 0xfe, 0xc1, 0xa7, 0xcd, 0xd2, -0x43, 0xf1, 0x9e, 0x62, 0xd2, 0x09, 0x4d, 0x97, -0x50, 0xff, 0x0c, 0xcf, 0x43, 0xd3, 0x49, 0x36, -0x3f, 0xa5, 0x0e, 0xfc, 0xf3, 0x1e, 0xce, 0x46, -0xdc, 0xd8, 0x1d, 0x60, 0xb6, 0x74, 0x54, 0xe2, -0x88, 0x28, 0x95, 0x3f, 0xd5, 0x9d, 0xfa, 0xe7, -0x82, 0x51, 0x92, 0x50, 0xf7, 0xe9, 0x01, 0xa4, -0xdd, 0x50, 0x28, 0xe5, 0xe9, 0x15, 0x3d, 0xe4, -0x75, 0x08, 0xb2, 0xbf, 0x48, 0x15, 0xd6, 0xab, -0xd6, 0xa1, 0x3e, 0xcd, 0x89, 0x7f, 0x22, 0x32, -0xb6, 0x45, 0xba, 0x6a, 0x96, 0x74, 0x00, 0x2a, -0x8f, 0xc8, 0x77, 0xb6, 0xde, 0x0a, 0x48, 0xfb, -0xc8, 0x58, 0x11, 0xcf, 0x8d, 0x4c, 0xfd, 0xf3, -0x46, 0xba, 0x03, 0x49, 0x9e, 0xaf, 0xc0, 0x73, -0xfa, 0xbc, 0xa4, 0xbc, 0x38, 0xd4, 0x0c, 0x9b, -0x22, 0x55, 0x49, 0x17, 0x5e, 0xd9, 0x44, 0x2b, -0xc3, 0xf2, 0x5a, 0x07, 0xfe, 0xb9, 0x49, 0xeb, -0xdc, 0xa6, 0x86, 0xe5, 0xe0, 0xf2, 0x65, 0xda, -0x3e, 0xa8, 0x19, 0x60, 0xcb, 0x66, 0x6d, 0x5b, -0x0f, 0xec, 0x8c, 0xb1, 0x15, 0x38, 0xaa, 0x75, -0x12, 0x75, 0x8c, 0xad, 0x37, 0x27, 0xfe, 0x39, -0x0e, 0x3e, 0x2c, 0x72, 0xff, 0x6b, 0xb8, 0xa2, -0x35, 0x46, 0xbf, 0x13, 0x13, 0x6f, 0x80, 0x63, -0x50, 0xdf, 0x57, 0xcb, 0x5e, 0x9b, 0x39, 0xfe, -0xfa, 0xdd, 0x81, 0x64, 0x6e, 0xfc, 0xc3, 0x02, -0x93, 0xdc, 0xc0, 0xc3, 0x90, 0x8f, 0x21, 0x04, -0x32, 0xdf, 0xe8, 0xc7, 0xf2, 0x2c, 0xc9, 0xc2, -0x3f, 0xaf, 0xb1, 0xa0, 0x26, 0x3f, 0x28, 0x56, -0xcb, 0x47, 0x19, 0x2c, 0xe4, 0x65, 0xef, 0x45, -0xd3, 0x51, 0xd6, 0x2b, 0xbe, 0x49, 0x8f, 0xb2, -0x0f, 0x07, 0xa2, 0x22, 0xb1, 0xe3, 0x1f, 0xb2, -0x59, 0xf3, 0xb5, 0xcb, 0xb3, 0x48, 0x35, 0xe9, -0x00, 0xdf, 0x7a, 0xf9, 0x31, 0xf2, 0x29, 0xd8, -0xac, 0xed, 0xd4, 0xe4, 0x6d, 0xe4, 0xcd, 0xc8, -0x66, 0xd8, 0xa9, 0xf9, 0x15, 0x97, 0x6a, 0xc3, -0x3f, 0x12, 0x74, 0x68, 0xbb, 0x56, 0x2f, 0xdf, -0x46, 0x0a, 0x84, 0xcd, 0xda, 0x8f, 0xc7, 0xd8, -0x6d, 0x73, 0x85, 0x27, 0x64, 0x1f, 0xde, 0x3f, -0xec, 0xe9, 0x08, 0xfb, 0x57, 0xbb, 0xb0, 0xb0, -0xdd, 0x5c, 0x0f, 0x88, 0x7f, 0x50, 0xf6, 0xec, -0x8a, 0xba, 0x24, 0x61, 0x33, 0xa8, 0xcb, 0xe5, -0xd2, 0x48, 0x21, 0xd9, 0x81, 0xdf, 0x23, 0xf2, -0x21, 0x1d, 0xe0, 0x47, 0xbc, 0x44, 0x6c, 0xf8, -0x47, 0x83, 0x84, 0xda, 0xc0, 0x16, 0x72, 0x95, -0xca, 0x3e, 0x84, 0xcf, 0xc8, 0x81, 0x88, 0x5b, -0x65, 0x5f, 0x51, 0x1d, 0x78, 0xe8, 0x74, 0x9d, -0xfd, 0x79, 0x16, 0x23, 0xfe, 0x29, 0x49, 0xe3, -0x9f, 0xe2, 0xf3, 0xb1, 0xc9, 0x40, 0xcb, 0xf2, -0xe2, 0x57, 0x1e, 0x3f, 0x1f, 0xfb, 0xd8, 0xff, -0xdc, 0x72, 0xef, 0x43, 0xcf, 0x7f, 0x2b, 0xf6, -0xaf, 0x58, 0xf6, 0xce, 0x80, 0x4d, 0xec, 0x82, -0x7f, 0x11, 0xfb, 0xa9, 0xd3, 0x59, 0xff, 0xf5, -0xb6, 0xff, 0x9b, 0x9a, 0x67, 0xdb, 0xb4, 0x6a, -0x38, 0x0a, 0x75, 0x21, 0xde, 0x1f, 0xe9, 0xa8, -0xe4, 0xd3, 0x4a, 0xb6, 0xa1, 0xfe, 0xd9, 0xc8, -0x18, 0x3a, 0xf0, 0x0f, 0xed, 0x0e, 0xef, 0x93, -0xfd, 0xe0, 0x52, 0x69, 0x37, 0xf8, 0x14, 0xff, -0x46, 0x36, 0x1b, 0xdd, 0xaa, 0x0f, 0x5c, 0xc4, -0xa5, 0x2a, 0x98, 0xff, 0x92, 0x75, 0x07, 0xfe, -0x39, 0xaf, 0xfe, 0x48, 0xae, 0x0c, 0xc9, 0xed, -0xe4, 0x7a, 0x75, 0xa3, 0xbf, 0x72, 0xb9, 0x7c, -0xf3, 0x6f, 0xcb, 0x62, 0x1b, 0xe5, 0xaf, 0x2e, -0x77, 0xdd, 0x5c, 0x5a, 0x46, 0x37, 0xca, 0x0b, -0xd8, 0x4f, 0x11, 0xbb, 0xfe, 0x67, 0xbf, 0xb0, -0x11, 0x04, 0x4d, 0x6e, 0x2f, 0xfd, 0x16, 0xd9, -0xa4, 0x54, 0x2e, 0x2b, 0x5a, 0xef, 0x2b, 0x87, -0x8d, 0xe4, 0xf1, 0xf6, 0x9a, 0x76, 0x52, 0x06, -0xf7, 0x4b, 0xde, 0x56, 0xff, 0x90, 0x1d, 0xff, -0x14, 0x2c, 0x83, 0xb7, 0x69, 0x29, 0xbe, 0xa4, -0xc4, 0xd5, 0xaa, 0xf8, 0xfe, 0xe4, 0xa8, 0x50, -0xa7, 0xd5, 0x72, 0x43, 0x9a, 0xbd, 0xde, 0xe3, -0xc4, 0x3f, 0x3f, 0xd6, 0x2e, 0xc4, 0x9a, 0xd7, -0xb0, 0x68, 0xce, 0x0c, 0x78, 0x36, 0x84, 0xf9, -0x32, 0xd5, 0x94, 0x45, 0x69, 0x17, 0x5c, 0xcd, -0x6d, 0x4e, 0xfc, 0x03, 0x31, 0x48, 0x68, 0x75, -0xf2, 0xca, 0x8e, 0x56, 0xb5, 0x22, 0xc1, 0xa6, -0x7d, 0x10, 0xf1, 0x4f, 0x4a, 0x7f, 0x85, 0x8d, -0x80, 0x18, 0xfe, 0xd1, 0x33, 0xf0, 0x0f, 0x43, -0x3b, 0x51, 0xae, 0x76, 0xbe, 0x8f, 0xfa, 0x68, -0xf7, 0x8f, 0x22, 0xfe, 0xae, 0xfb, 0xd4, 0x80, -0xa1, 0x7f, 0x3e, 0x04, 0x6a, 0x2c, 0xa3, 0xfe, -0xeb, 0x0b, 0xf0, 0x30, 0xdd, 0x9d, 0x94, 0x83, -0x91, 0x07, 0xa0, 0x33, 0x1a, 0xfb, 0x40, 0xc6, -0xfe, 0x3f, 0x9d, 0x34, 0x80, 0x57, 0xbc, 0xd0, -0xab, 0xef, 0x1e, 0xc9, 0xc0, 0x3f, 0x57, 0xc3, -0x23, 0xda, 0xbc, 0x21, 0xb6, 0x6d, 0x79, 0x14, -0xbf, 0xd6, 0x21, 0x58, 0x4f, 0x14, 0xd8, 0x88, -0x40, 0x8b, 0x19, 0xea, 0xd3, 0xdd, 0xf3, 0x22, -0x19, 0xf8, 0xa7, 0x99, 0xc1, 0x8a, 0x25, 0xb1, -0x40, 0x9b, 0xf8, 0x2c, 0x79, 0x99, 0xd6, 0xc7, -0x02, 0xb2, 0xd8, 0x0c, 0x28, 0x7b, 0x0e, 0xac, -0x65, 0xf1, 0xc5, 0xec, 0xff, 0x63, 0xc3, 0x3f, -0xbb, 0xe1, 0x1d, 0x89, 0xed, 0x47, 0xa8, 0x7b, -0x9d, 0xa1, 0x76, 0xa6, 0x90, 0x24, 0xe3, 0x12, -0xca, 0xf0, 0xdc, 0x49, 0xb6, 0x43, 0x61, 0x3f, -0x39, 0xf0, 0x4f, 0xc1, 0x47, 0x30, 0x11, 0xfd, -0xdb, 0xb0, 0x77, 0xdc, 0x3d, 0x17, 0x69, 0x9f, -0x70, 0xc9, 0xc1, 0xd6, 0x66, 0xed, 0x5d, 0x1a, -0x5f, 0x53, 0x62, 0xec, 0xe8, 0x5b, 0x30, 0x90, -0xd9, 0xf9, 0x9f, 0x28, 0xdb, 0x3f, 0x2e, 0x6c, -0x73, 0xdf, 0x25, 0x96, 0x22, 0x9e, 0x59, 0xcd, -0x1c, 0x4b, 0x29, 0xdd, 0x18, 0x53, 0xfd, 0xf8, -0xfe, 0xf0, 0x34, 0x2c, 0x00, 0x79, 0xbd, 0x43, -0xff, 0xbc, 0x0d, 0x9e, 0x56, 0x2a, 0xf5, 0x9e, -0x73, 0xe4, 0x55, 0x7a, 0xa0, 0x62, 0x41, 0xc7, -0xf7, 0x35, 0xd2, 0x04, 0x3f, 0x53, 0x3f, 0xa5, -0xb9, 0x93, 0xe4, 0x56, 0x78, 0x04, 0xe6, 0x87, -0xe4, 0x0d, 0x0e, 0xfc, 0xa3, 0xcb, 0x87, 0xba, -0x54, 0xf4, 0xff, 0x5d, 0xda, 0x61, 0x1a, 0xe8, -0x90, 0x81, 0x2c, 0x65, 0xa8, 0xa5, 0x5a, 0x91, -0x63, 0x3e, 0x4d, 0x3b, 0x04, 0x01, 0x45, 0x76, -0xe2, 0x9f, 0x9f, 0xd1, 0x0b, 0xe1, 0xba, 0x11, -0x77, 0xdc, 0x7d, 0x16, 0xfa, 0x68, 0xf3, 0x91, -0xda, 0xb8, 0xb8, 0xe0, 0xc8, 0xbb, 0xb0, 0x7f, -0xa8, 0x24, 0xea, 0xbe, 0x03, 0xa1, 0xf2, 0x40, -0x13, 0x38, 0xf0, 0xcf, 0x3a, 0xb8, 0xa0, 0xa2, -0xba, 0x72, 0x86, 0x1f, 0x36, 0x68, 0xcd, 0x43, -0xde, 0xfd, 0xee, 0x18, 0xe2, 0x67, 0xea, 0xdd, -0x26, 0xee, 0x40, 0x69, 0x62, 0xd4, 0xdb, 0xe5, -0xe0, 0x7f, 0xae, 0x2c, 0xbd, 0xa0, 0x55, 0xd1, -0x55, 0x3a, 0x9b, 0xf6, 0xcb, 0x9f, 0xab, 0xa7, -0xc5, 0x89, 0x19, 0x57, 0xe0, 0x74, 0xac, 0xe5, -0x88, 0xa7, 0x9f, 0x34, 0xd3, 0xcb, 0x9a, 0xa8, -0x7b, 0x13, 0x2e, 0xb0, 0xe3, 0x1f, 0xe1, 0xa0, -0xc4, 0xd0, 0x32, 0x2d, 0xad, 0x85, 0xb7, 0x35, -0x35, 0x5a, 0x4c, 0xc9, 0xf3, 0x7a, 0x37, 0x06, -0xb2, 0x08, 0x51, 0xa1, 0x4f, 0xf0, 0x3d, 0xcd, -0xb6, 0x1e, 0xaa, 0x9d, 0xff, 0xa9, 0x3e, 0x2c, -0xd7, 0x68, 0xee, 0xb8, 0x2f, 0xa0, 0x3d, 0x29, -0xd4, 0x68, 0xf2, 0x5e, 0x32, 0x4a, 0x7e, 0x80, -0x8d, 0xc8, 0xa2, 0xe4, 0x1f, 0xd9, 0x46, 0xac, -0x46, 0xeb, 0x89, 0x44, 0x32, 0xf4, 0xcf, 0x7e, -0xbf, 0xb6, 0x22, 0x58, 0x28, 0xab, 0x3b, 0x99, -0xf7, 0x9b, 0x57, 0x47, 0x92, 0xb4, 0x03, 0x6a, -0xaf, 0x91, 0x95, 0x5a, 0x0a, 0x71, 0xb6, 0xe0, -0x45, 0x4a, 0x22, 0x19, 0xf5, 0x5f, 0x87, 0x18, -0xfe, 0xe9, 0x09, 0x74, 0xbf, 0x0b, 0xfb, 0x68, -0x80, 0xb0, 0x40, 0x76, 0xd2, 0xcf, 0xdc, 0x02, -0x15, 0x91, 0x2a, 0x3c, 0xa4, 0x4d, 0xa3, 0x76, -0xfd, 0x33, 0xe2, 0x1f, 0xff, 0x22, 0x2c, 0x53, -0xba, 0x34, 0xfd, 0x7d, 0xb8, 0xb1, 0xdf, 0xfb, -0x81, 0xf8, 0x12, 0x7c, 0x04, 0x2d, 0xb2, 0xb7, -0x5d, 0xfc, 0x0e, 0xef, 0xf8, 0xc7, 0xbe, 0x97, -0xb5, 0xce, 0xfa, 0xaf, 0x94, 0x7e, 0x1e, 0x26, -0xd5, 0xe6, 0xb1, 0xf9, 0xfb, 0x66, 0x3c, 0x13, -0x3a, 0xae, 0xb4, 0x0c, 0x16, 0x8f, 0x8b, 0x01, -0x14, 0x8a, 0x24, 0x3d, 0x59, 0xfc, 0x8f, 0x91, -0xe4, 0x3a, 0x0b, 0xcf, 0x0d, 0xd5, 0x26, 0xe4, -0x31, 0x22, 0xd1, 0xfb, 0xd4, 0x05, 0xa7, 0x96, -0xf7, 0x91, 0x05, 0x5a, 0x8f, 0xec, 0x7b, 0xd1, -0xd5, 0x07, 0xd9, 0xfc, 0x4f, 0xaa, 0xde, 0xdf, -0x9f, 0x90, 0x17, 0x92, 0x6e, 0x5a, 0x05, 0x81, -0x04, 0x03, 0x36, 0x0f, 0xc8, 0x9d, 0x2a, 0x57, -0x68, 0xd8, 0xf9, 0x1f, 0x13, 0x4f, 0x96, 0x8e, -0xf2, 0x46, 0x40, 0xae, 0x78, 0x21, 0x85, 0x9f, -0xd2, 0x5a, 0xfd, 0x9a, 0xb8, 0x6b, 0x0f, 0xed, -0x94, 0xfc, 0x88, 0x88, 0xb2, 0xf8, 0x1f, 0x0b, -0x0f, 0x63, 0x19, 0xd7, 0x93, 0xf0, 0x1e, 0x9d, -0x8d, 0x8d, 0x0a, 0x77, 0xf3, 0xd6, 0x7c, 0x9e, -0x78, 0x55, 0x2e, 0xfe, 0x87, 0xe7, 0x5b, 0x39, -0xfb, 0xf7, 0x4d, 0xed, 0x5f, 0x09, 0xa7, 0x35, -0x6e, 0x67, 0x3f, 0x1d, 0xc8, 0x91, 0xff, 0x4a, -0x3d, 0x5f, 0xe6, 0x40, 0xbd, 0x8e, 0xfd, 0x0f, -0xbd, 0x0d, 0x4d, 0xfd, 0xec, 0x7f, 0x28, 0xc1, -0xe3, 0x7b, 0x4e, 0xfd, 0x0f, 0xc7, 0xc3, 0xcf, -0x81, 0xaf, 0x5f, 0x1c, 0x2b, 0x1d, 0x66, 0xb0, -0x6d, 0x81, 0x2e, 0xef, 0x63, 0x30, 0xb8, 0xc7, -0x28, 0x0c, 0xcc, 0xd6, 0xff, 0xa4, 0xd8, 0xbf, -0xb9, 0x6c, 0x9b, 0xa0, 0x0e, 0x48, 0xfb, 0xc0, -0xc3, 0xfb, 0x6f, 0x28, 0x9d, 0x20, 0xe7, 0xd0, -0x3f, 0x5b, 0xfd, 0x70, 0x3a, 0xd8, 0x6e, 0x65, -0x43, 0xe4, 0x74, 0xd1, 0xf7, 0xd8, 0x95, 0x1a, -0xac, 0x90, 0xda, 0x1a, 0xe3, 0x85, 0xe1, 0x19, -0xfc, 0x0f, 0x8a, 0x9c, 0x97, 0xf0, 0x6e, 0x87, -0xb3, 0x46, 0xbd, 0x4b, 0x66, 0xe8, 0x51, 0x76, -0xa5, 0xbf, 0x16, 0xf3, 0x5f, 0xcf, 0xd3, 0x6b, -0xb2, 0xeb, 0xdf, 0xed, 0xd9, 0xc0, 0x5f, 0x78, -0xc7, 0x3a, 0x46, 0x30, 0x9f, 0xf8, 0xaa, 0x87, -0xe7, 0xbf, 0x14, 0xe4, 0xc7, 0xf2, 0xf0, 0x3f, -0xc2, 0x84, 0xca, 0xd0, 0xf5, 0xfe, 0xce, 0x30, -0x66, 0x40, 0x12, 0x4d, 0x71, 0x16, 0x4f, 0xb1, -0x90, 0x21, 0x4f, 0xff, 0x1f, 0xdc, 0x4f, 0xb5, -0xe3, 0xc6, 0xaa, 0xf4, 0x04, 0x3c, 0x55, 0xc8, -0xfb, 0xa7, 0x9d, 0x52, 0xde, 0x80, 0x2a, 0xe4, -0x93, 0xf3, 0xf5, 0xff, 0x89, 0xa0, 0x31, 0xf7, -0x37, 0xc2, 0x81, 0xae, 0xf9, 0xc3, 0xae, 0x0d, -0xbe, 0xdf, 0xc0, 0x4f, 0x0c, 0x68, 0x64, 0xc7, -0x3f, 0x19, 0xfb, 0x59, 0x9e, 0x46, 0x3c, 0xac, -0x19, 0xfc, 0xb3, 0x76, 0x18, 0x33, 0xf8, 0x39, -0xfb, 0xff, 0xa4, 0xf5, 0x3f, 0x55, 0xdf, 0x86, -0x2b, 0x4a, 0x73, 0x47, 0x49, 0x8c, 0x2d, 0x03, -0x94, 0x46, 0x7b, 0xd4, 0xbc, 0xfc, 0x0f, 0x33, -0xdc, 0x5d, 0x24, 0xa9, 0x8e, 0x5f, 0x35, 0x1b, -0x3a, 0x18, 0xfe, 0x51, 0x4f, 0xe4, 0xae, 0x7f, -0xb7, 0x67, 0x43, 0xb6, 0xa3, 0x50, 0x04, 0xea, -0x96, 0xba, 0x98, 0xc1, 0xf0, 0x0f, 0xd7, 0xff, -0x90, 0x7c, 0xfc, 0x0f, 0x33, 0xb6, 0xf9, 0x50, -0x4f, 0x52, 0x83, 0x6d, 0x7f, 0x06, 0xe8, 0x13, -0x46, 0x45, 0xbc, 0x9a, 0x97, 0xff, 0x59, 0xea, -0x7e, 0x30, 0x32, 0x00, 0x4f, 0x30, 0xfc, 0xe0, -0x7a, 0x28, 0xb4, 0x26, 0x55, 0x11, 0x96, 0x81, -0x7f, 0xf6, 0xda, 0xf4, 0x3f, 0x5a, 0x4f, 0x69, -0x64, 0x20, 0xde, 0x11, 0xf0, 0x2f, 0x5f, 0x8e, -0xfd, 0x0f, 0x77, 0x70, 0xfd, 0x8f, 0x8b, 0xe4, -0xca, 0x7f, 0x21, 0xdb, 0x33, 0x1b, 0xf3, 0x5f, -0x49, 0x3a, 0xa2, 0x06, 0x65, 0x06, 0x7b, 0x50, -0x08, 0x5d, 0x97, 0x81, 0x7f, 0x9c, 0xfc, 0x4f, -0xf3, 0xf2, 0x55, 0x0f, 0x75, 0x9e, 0xdf, 0x39, -0xe9, 0x6f, 0x5e, 0xfe, 0xf9, 0x21, 0xf1, 0xbc, -0x92, 0xcd, 0xff, 0xd8, 0xf5, 0x33, 0xaf, 0xf9, -0x1b, 0xb5, 0x92, 0xa1, 0xce, 0x39, 0xea, 0x6b, -0xe1, 0xba, 0xe5, 0xde, 0x21, 0xf1, 0x7a, 0x9c, -0x28, 0xcd, 0x33, 0x24, 0xbe, 0x20, 0xd9, 0xf0, -0x8f, 0x55, 0xff, 0xa5, 0xf4, 0x69, 0x3e, 0x90, -0xef, 0x25, 0x95, 0x0c, 0xff, 0x5c, 0x5f, 0xc1, -0xae, 0xec, 0xd0, 0xba, 0x61, 0x67, 0x5e, 0xfe, -0x07, 0x0d, 0xff, 0xf2, 0xfb, 0x82, 0xd8, 0xf8, -0xe8, 0x76, 0x35, 0x54, 0xa4, 0xa0, 0xc2, 0xc7, -0xaf, 0x86, 0x64, 0xe4, 0x7f, 0xec, 0xfa, 0x67, -0xb3, 0xfe, 0x0e, 0x0e, 0x16, 0xa0, 0xfe, 0xa7, -0xac, 0xda, 0xb7, 0x43, 0xfd, 0x4b, 0x9c, 0xe1, -0x5d, 0xd2, 0x66, 0xf6, 0x85, 0xf0, 0x7e, 0x4a, -0xe6, 0x7a, 0x88, 0xd9, 0xf5, 0x4b, 0xaf, 0x09, -0x8d, 0xda, 0x17, 0xa2, 0xe2, 0x1c, 0xe5, 0xdb, -0x7a, 0x29, 0x0a, 0x7b, 0x76, 0xf1, 0x8a, 0x3f, -0xc4, 0x3f, 0xe9, 0xf8, 0x6b, 0xe7, 0x7f, 0xfe, -0x1b, 0x17, 0x4e, 0xcf, 0x44, 0x84, 0xcc, 0xaf, -0x0c, 0x90, 0x0b, 0x42, 0xb3, 0xb6, 0x20, 0x13, -0xff, 0x98, 0xf3, 0x2f, 0x8d, 0xc1, 0x3e, 0xb6, -0x47, 0xed, 0x54, 0xe1, 0x84, 0x31, 0xed, 0x49, -0x6a, 0xf6, 0x3f, 0xb4, 0xd6, 0x7f, 0xb6, 0xfe, -0x67, 0x98, 0xec, 0x36, 0xfa, 0xff, 0xf8, 0x7d, -0x13, 0xdd, 0x87, 0x48, 0x43, 0x06, 0xff, 0x53, -0xee, 0xf8, 0x5e, 0x54, 0xd4, 0xff, 0xac, 0xe3, -0x1d, 0x24, 0x5c, 0x8b, 0xe1, 0xb8, 0x62, 0xf6, -0x3f, 0x94, 0x72, 0xf1, 0x3f, 0xec, 0xd7, 0xca, -0x81, 0xb6, 0xf5, 0x3c, 0x71, 0xf6, 0xf5, 0xdf, -0xcb, 0xbc, 0x43, 0x8e, 0x92, 0x23, 0xff, 0x65, -0xf2, 0x3f, 0xca, 0xc7, 0xb4, 0x7e, 0xb4, 0x78, -0x9c, 0x7c, 0x25, 0xf2, 0x56, 0xfc, 0xc6, 0xd1, -0x42, 0xde, 0xff, 0x30, 0x7e, 0x43, 0x16, 0xff, -0xc3, 0xfc, 0x49, 0xad, 0x43, 0x5d, 0xb0, 0x27, -0xb9, 0x02, 0xf6, 0x0d, 0xa5, 0x14, 0x86, 0x0d, -0x27, 0x32, 0xf0, 0x8f, 0x95, 0xbf, 0xc0, 0x6e, -0x42, 0x75, 0xbf, 0xf7, 0x4c, 0x88, 0xcf, 0x2a, -0x2f, 0x77, 0xf7, 0xbe, 0xed, 0x19, 0xaf, 0xba, -0x82, 0xfd, 0x7b, 0x7f, 0xeb, 0xd9, 0x20, 0x82, -0x23, 0xff, 0xc5, 0xf5, 0x3f, 0xd8, 0xbd, 0xe7, -0x80, 0x34, 0x2f, 0xe9, 0xba, 0x93, 0xfc, 0x90, -0x6d, 0xa3, 0x3e, 0x3d, 0x2a, 0xaf, 0xaf, 0x3b, -0xa5, 0x1e, 0x80, 0x4f, 0x0f, 0x30, 0x47, 0xf4, -0xa4, 0xb3, 0xfe, 0xcb, 0xd4, 0xff, 0xb0, 0xf1, -0x26, 0x5c, 0x77, 0x5e, 0x35, 0x08, 0x3f, 0x01, -0x21, 0xf1, 0xfd, 0xf5, 0x64, 0x48, 0x7b, 0x04, -0xe6, 0xe8, 0x35, 0xeb, 0x09, 0xcd, 0xa1, 0xff, -0xf1, 0x19, 0x44, 0x10, 0xf3, 0x36, 0xb5, 0x6c, -0x3e, 0xfd, 0x7a, 0x0d, 0xf6, 0xb3, 0xed, 0x35, -0xf8, 0xfc, 0xee, 0xcc, 0xfa, 0x2f, 0x73, 0xbc, -0xf5, 0xfa, 0x17, 0xe2, 0xad, 0x97, 0xd4, 0xf7, -0xb1, 0x50, 0x2b, 0x2e, 0xbe, 0x09, 0x6f, 0x90, -0x45, 0x68, 0x3c, 0xe9, 0xe0, 0x7f, 0xd2, 0xf7, -0x0b, 0xcd, 0xfd, 0xee, 0xeb, 0x61, 0x94, 0xbc, -0x1e, 0x69, 0xd2, 0xe7, 0x61, 0x3e, 0xe2, 0x30, -0x69, 0x64, 0x11, 0x50, 0xc8, 0x5b, 0xff, 0xc5, -0x37, 0xb6, 0x4d, 0x65, 0x2f, 0x4a, 0x3c, 0xf0, -0x9d, 0x87, 0x49, 0xb1, 0xb7, 0x7f, 0xeb, 0x98, -0x60, 0xe3, 0x7f, 0x80, 0xb7, 0xdd, 0xc3, 0xfa, -0x3b, 0xc3, 0x28, 0xea, 0x8b, 0x70, 0xda, 0x01, -0xc3, 0xd6, 0xb0, 0xc1, 0x5f, 0x65, 0xf0, 0x3f, -0x82, 0x8d, 0xff, 0x61, 0xf1, 0xab, 0x2f, 0x14, -0x50, 0x7a, 0x48, 0x6d, 0xbf, 0x6b, 0x5f, 0xe9, -0x68, 0x7b, 0x6f, 0xea, 0xfe, 0x6c, 0xfe, 0x67, -0x21, 0xea, 0x81, 0xa5, 0xc0, 0x51, 0xb6, 0xde, -0x3c, 0x72, 0xa7, 0xcc, 0xf0, 0x40, 0x90, 0xbc, -0xa4, 0xf4, 0x6a, 0xe1, 0xa1, 0x9e, 0x2c, 0xfe, -0xc7, 0x67, 0xcd, 0xcf, 0x8d, 0xaf, 0xae, 0x7a, -0xaa, 0xb5, 0x09, 0x5e, 0x56, 0x5b, 0x12, 0x25, -0xf1, 0x19, 0x67, 0xa4, 0x8f, 0x97, 0xcd, 0xf8, -0xd5, 0xd6, 0x4c, 0xfe, 0xe7, 0x0d, 0xb6, 0x5b, -0x9f, 0x76, 0x4e, 0x6c, 0x82, 0x37, 0xa0, 0xe5, -0xc4, 0xfd, 0x47, 0x66, 0x8e, 0x86, 0x30, 0x71, -0x33, 0x7f, 0x88, 0xc1, 0x18, 0x53, 0xdf, 0xeb, -0xc0, 0x3f, 0x17, 0x61, 0x51, 0x8c, 0x2d, 0x92, -0xb3, 0x0c, 0x08, 0x2d, 0x31, 0xda, 0xfe, 0xa4, -0x64, 0x3f, 0xb9, 0xea, 0xbf, 0xe0, 0xac, 0xcc, -0x3f, 0xab, 0xbe, 0xba, 0x5a, 0x06, 0x84, 0xaa, -0xc6, 0xec, 0x6d, 0x7f, 0xd2, 0xfa, 0x1f, 0xdb, -0xf7, 0x38, 0x28, 0xf7, 0x41, 0x35, 0x95, 0x83, -0xb7, 0x73, 0xfc, 0x33, 0x64, 0x4f, 0xf3, 0xd9, -0xf2, 0x7d, 0xe6, 0xfd, 0xfa, 0x9f, 0xef, 0x61, -0xfe, 0xcd, 0xd7, 0x01, 0x46, 0xdb, 0x25, 0x67, -0x1b, 0x01, 0x9b, 0xfe, 0xc7, 0x7c, 0x1f, 0xac, -0xff, 0xba, 0x28, 0x35, 0x74, 0x55, 0x07, 0x45, -0xa3, 0x50, 0xab, 0xc0, 0xf6, 0xe1, 0xa4, 0xeb, -0xbf, 0xd2, 0xfd, 0x2d, 0x95, 0x26, 0xb8, 0xa8, -0xb7, 0x24, 0xb7, 0x8e, 0xf1, 0xfe, 0x7e, 0xce, -0xb2, 0xa6, 0xb4, 0xfe, 0xd9, 0x56, 0xff, 0x15, -0x60, 0xa0, 0xba, 0xa1, 0xdb, 0xb3, 0xb7, 0x73, -0x1d, 0xbc, 0xab, 0x36, 0x19, 0x6d, 0x19, 0x5e, -0x37, 0x2a, 0x34, 0xf3, 0xd4, 0x7f, 0xc5, 0xa9, -0x6f, 0xc8, 0xff, 0x0c, 0x7b, 0xff, 0x4e, 0x6d, -0x81, 0xee, 0xcf, 0xf5, 0xfe, 0xe9, 0xfa, 0x2f, -0x5d, 0xf2, 0x48, 0xfb, 0xe8, 0x93, 0xf1, 0x9a, -0xeb, 0xc9, 0xca, 0xf0, 0xe3, 0x5a, 0x40, 0xbf, -0xc6, 0x10, 0x8a, 0xe7, 0xad, 0xff, 0xd2, 0x66, -0xc3, 0xd3, 0xe3, 0xf3, 0x6a, 0x5c, 0xdf, 0x26, -0xb3, 0xbb, 0xa7, 0xd1, 0xe2, 0x24, 0xcf, 0x7f, -0xd9, 0x32, 0x62, 0x99, 0xf5, 0x5f, 0x15, 0x1e, -0xed, 0x5c, 0xb2, 0x91, 0x3e, 0x50, 0x27, 0x7e, -0x81, 0x7e, 0x15, 0x9a, 0x06, 0x78, 0xdb, 0x9f, -0x5f, 0xc7, 0x9a, 0x86, 0xbd, 0xc1, 0xaa, 0x74, -0xfd, 0x57, 0xa1, 0xf9, 0x3e, 0x9a, 0xe7, 0x19, -0xb8, 0x52, 0x56, 0x2f, 0x9b, 0xb2, 0xa8, 0x23, -0xc5, 0xa9, 0x69, 0xe9, 0xcf, 0x5d, 0xff, 0x25, -0x17, 0x8c, 0x4a, 0x17, 0x21, 0x48, 0xd9, 0xb4, -0xdc, 0x81, 0x68, 0xd3, 0xd1, 0xa6, 0x23, 0x5d, -0xbf, 0x90, 0xee, 0xcf, 0xbc, 0x94, 0xf9, 0x13, -0xa1, 0x52, 0x63, 0x4e, 0x66, 0x16, 0x6c, 0x22, -0xf3, 0x8f, 0xd8, 0x65, 0x03, 0xe9, 0xfa, 0x2f, -0xeb, 0x7e, 0x60, 0xf8, 0xa7, 0x97, 0x56, 0xc5, -0x8a, 0xb0, 0xde, 0xcd, 0x94, 0x39, 0xd9, 0x3b, -0x22, 0xe6, 0xe8, 0xff, 0xd3, 0xfb, 0xb9, 0x9d, -0x5a, 0x51, 0x30, 0x64, 0xc8, 0xa8, 0xdc, 0xb9, -0xd6, 0x9b, 0xad, 0xff, 0x8f, 0xb4, 0x1b, 0xae, -0x68, 0xf5, 0xd1, 0xf9, 0xaa, 0xe8, 0x27, 0xf7, -0xd9, 0x81, 0xd0, 0x56, 0x9b, 0x22, 0xda, 0xd6, -0xff, 0xc7, 0xc8, 0x47, 0x94, 0x96, 0x50, 0xf7, -0x99, 0x54, 0x21, 0x58, 0x0e, 0x3d, 0x86, 0xb3, -0xff, 0xf3, 0x07, 0x4a, 0x5d, 0x98, 0x05, 0xc1, -0x1f, 0x67, 0xc9, 0x42, 0x72, 0xea, 0x7f, 0xaa, -0xe5, 0x83, 0x47, 0x7c, 0xcb, 0xe4, 0x68, 0xe4, -0x53, 0xea, 0xc1, 0x36, 0xa7, 0xec, 0x24, 0x5f, -0xfd, 0x97, 0xb6, 0x53, 0xab, 0x60, 0xd1, 0x99, -0x66, 0xde, 0x96, 0xaf, 0xfe, 0xcb, 0xaf, 0x6a, -0x15, 0x0a, 0x91, 0x64, 0xec, 0x7f, 0x68, 0x00, -0x03, 0x29, 0x43, 0xff, 0x63, 0xe9, 0xc3, 0x17, -0x5f, 0x8d, 0xdd, 0x7e, 0xea, 0x68, 0x80, 0xfd, -0x0d, 0x64, 0xec, 0x7f, 0x98, 0x73, 0xbc, 0xa7, -0x0b, 0xcd, 0xf7, 0xe9, 0x43, 0xfd, 0xcf, 0xbc, -0x96, 0xe5, 0x6c, 0xb7, 0x35, 0x90, 0x1a, 0xdd, -0x0c, 0xde, 0x0f, 0xd9, 0x31, 0xde, 0x37, 0xd3, -0x78, 0x86, 0xe1, 0x8d, 0xcb, 0x70, 0xe3, 0x32, -0x4f, 0x3b, 0x43, 0x3b, 0x97, 0x8d, 0xb4, 0x11, -0xde, 0x76, 0xb7, 0xe3, 0xfe, 0x34, 0xff, 0x53, -0x01, 0x49, 0xb9, 0x4f, 0xae, 0x85, 0x62, 0xea, -0x42, 0xd9, 0x4f, 0x8d, 0xe2, 0x36, 0x64, 0x57, -0xb6, 0x8c, 0x98, 0xb3, 0xff, 0xcf, 0xb2, 0x2e, -0x79, 0x6f, 0xe8, 0x0e, 0x06, 0x5a, 0xae, 0x5a, -0x86, 0xa3, 0x5b, 0x66, 0x1f, 0x66, 0xae, 0xfe, -0x3f, 0x65, 0xbb, 0x52, 0x65, 0x5f, 0x5c, 0x4f, -0x5e, 0x93, 0x9a, 0x46, 0xc1, 0x39, 0x9f, 0x69, -0xfd, 0xf3, 0x4e, 0xec, 0x7f, 0xf8, 0xf7, 0xcd, -0x4b, 0x3d, 0x4a, 0x2a, 0xff, 0xd5, 0x63, 0xbc, -0x76, 0xad, 0xf1, 0xfe, 0x07, 0x53, 0xfa, 0x1f, -0xab, 0xff, 0xe1, 0x08, 0xf6, 0x3f, 0xe4, 0x4d, -0x0e, 0x3b, 0x6d, 0x40, 0xe8, 0xed, 0x8c, 0xf5, -0x70, 0xd1, 0x51, 0xff, 0x35, 0xa2, 0xd6, 0xb1, -0xf1, 0x8a, 0x61, 0x3e, 0xcc, 0x9c, 0xf3, 0x9f, -0xae, 0xff, 0x02, 0xc9, 0x0f, 0xcf, 0xca, 0x95, -0x54, 0x3e, 0x4b, 0x96, 0xd0, 0xa7, 0xb5, 0x12, -0x87, 0xec, 0xc7, 0x32, 0xd2, 0xfd, 0x0f, 0x65, -0xb6, 0xff, 0x7a, 0x5c, 0xaf, 0x86, 0xa2, 0x26, -0xd2, 0xa6, 0xee, 0x8b, 0x3b, 0x65, 0x87, 0x36, -0xfd, 0x8f, 0xf9, 0x0f, 0xeb, 0xbf, 0x9e, 0xa6, -0x9f, 0x3a, 0x22, 0xaf, 0x2f, 0x5c, 0x0d, 0x4f, -0x63, 0x23, 0xe8, 0x5c, 0xdf, 0x6f, 0xc2, 0x7c, -0x3c, 0xf8, 0x2b, 0x66, 0xc3, 0x59, 0xfa, 0x54, -0xac, 0x78, 0x83, 0xf8, 0xdf, 0xe1, 0x23, 0x7b, -0x22, 0xcc, 0x6e, 0x1c, 0xf3, 0x59, 0xeb, 0xb3, -0x78, 0x0f, 0x5c, 0x82, 0x43, 0x94, 0x79, 0xd7, -0xdd, 0x46, 0xa1, 0x93, 0xad, 0x8d, 0x58, 0x5a, -0xff, 0x73, 0xaf, 0x39, 0xde, 0x70, 0xd9, 0xb3, -0xda, 0x95, 0x68, 0xbd, 0xea, 0x19, 0x71, 0x5f, -0x05, 0x03, 0x74, 0x89, 0x19, 0xb6, 0x9a, 0x87, -0xed, 0xf1, 0x6b, 0x28, 0xad, 0x7f, 0xae, 0x78, -0x0c, 0x9e, 0x8e, 0x55, 0x6a, 0xc5, 0x9f, 0x21, -0xab, 0xa1, 0x4b, 0x5b, 0x88, 0xb2, 0xa5, 0x41, -0x7c, 0xed, 0xa4, 0xfb, 0x1b, 0x36, 0xfd, 0x8f, -0xa5, 0xaf, 0xa6, 0xf0, 0x98, 0xb0, 0x5f, 0x79, -0x7c, 0x1b, 0xf3, 0x57, 0xab, 0x51, 0xed, 0xac, -0x9b, 0xb7, 0x25, 0x7a, 0x6c, 0xe3, 0x4d, 0xc7, -0x3b, 0x8d, 0xc5, 0xf7, 0xb8, 0xa6, 0x52, 0x16, -0xe6, 0xda, 0x08, 0x35, 0x89, 0xfd, 0x54, 0xdb, -0x31, 0x6b, 0x3e, 0x6d, 0xf5, 0x5f, 0x05, 0x7b, -0xe0, 0x43, 0x8d, 0xfb, 0x4f, 0x3f, 0xca, 0xfc, -0xf4, 0xeb, 0x30, 0x4c, 0x4c, 0x48, 0x77, 0x38, -0xe2, 0x4b, 0x9a, 0xdf, 0x8b, 0x29, 0xa3, 0x70, -0x51, 0x65, 0xd1, 0x19, 0xe7, 0x67, 0xdc, 0xda, -0x78, 0x66, 0xf8, 0xdb, 0xf4, 0xfb, 0x20, 0xfe, -0xb9, 0x08, 0xf5, 0xb4, 0x03, 0x37, 0xf5, 0x97, -0x48, 0xaa, 0xcc, 0xf9, 0x0d, 0xc3, 0x8d, 0x7f, -0x27, 0xbb, 0xff, 0x4f, 0xbf, 0xb4, 0x4e, 0xee, -0xeb, 0xa8, 0x89, 0xb9, 0x9e, 0x21, 0xef, 0x40, -0x9f, 0xee, 0x0c, 0x5b, 0xb6, 0xfa, 0x2f, 0xf3, -0xef, 0x85, 0xf5, 0x5f, 0xbb, 0xa9, 0x2f, 0xe6, -0xde, 0x4e, 0xf6, 0x68, 0x7d, 0x34, 0x75, 0xdb, -0x0f, 0x32, 0xee, 0x77, 0xf6, 0x7f, 0xee, 0x53, -0x6b, 0x74, 0xd7, 0xf5, 0xe4, 0x28, 0xc4, 0x53, -0xcb, 0xac, 0xad, 0x57, 0x31, 0xea, 0xbf, 0x72, -0xe8, 0x7f, 0xe4, 0x75, 0x30, 0xb2, 0xbe, 0x8e, -0x2e, 0xd8, 0x26, 0x3e, 0x61, 0x8d, 0x17, 0xe3, -0xef, 0x0b, 0x56, 0xc7, 0x5d, 0xaf, 0x03, 0xff, -0x94, 0x5d, 0x82, 0xf1, 0xe0, 0x8d, 0x74, 0xd5, -0x7a, 0xe6, 0xb4, 0x2f, 0x19, 0xb2, 0xe7, 0x4b, -0x74, 0x92, 0xe1, 0xa5, 0xeb, 0xec, 0xf1, 0x3d, -0x9b, 0xff, 0xc1, 0xd5, 0xf2, 0x06, 0x2c, 0x49, -0x94, 0x9c, 0xeb, 0x0c, 0xb0, 0xf9, 0xaf, 0x3d, -0xe6, 0x5d, 0x2d, 0x36, 0x51, 0xf6, 0x53, 0x3f, -0xf2, 0x3f, 0x36, 0xfd, 0x39, 0x03, 0x39, 0x1d, -0xb5, 0x49, 0x91, 0xa3, 0x1d, 0xdd, 0x37, 0x26, -0x6f, 0x21, 0x0b, 0x94, 0x43, 0x7a, 0x6d, 0x9c, -0xcd, 0xc0, 0x02, 0xed, 0x70, 0x64, 0xc1, 0x70, -0x4e, 0xfd, 0x0f, 0x1f, 0xdd, 0x0e, 0xcd, 0x2f, -0x31, 0x98, 0x27, 0xc0, 0x5e, 0x8d, 0x77, 0x08, -0x07, 0xe8, 0x2d, 0xe0, 0x78, 0xd8, 0xd1, 0xff, -0xd0, 0x36, 0xdb, 0x84, 0x01, 0xad, 0x68, 0xe1, -0x6e, 0x85, 0xcf, 0x67, 0x37, 0xf3, 0x78, 0x06, -0x23, 0x14, 0x4a, 0xe3, 0x31, 0xb0, 0xeb, 0x4f, -0x5e, 0x97, 0x1a, 0x13, 0x25, 0x41, 0xf7, 0x7c, -0x89, 0x5f, 0x99, 0x2d, 0xd6, 0x6a, 0x13, 0x70, -0x77, 0x3f, 0xc3, 0xcf, 0xba, 0x85, 0x67, 0x62, -0xd3, 0x1d, 0xfc, 0x0f, 0xdb, 0x68, 0x24, 0xb1, -0xad, 0x0d, 0xb4, 0xec, 0x66, 0xfb, 0x4d, 0x06, -0x1d, 0xc9, 0xdd, 0x99, 0xf8, 0x67, 0x8f, 0x59, -0x54, 0x38, 0x0a, 0x1f, 0xb4, 0x2d, 0x2e, 0x62, -0x4f, 0xdb, 0x11, 0x3a, 0x0a, 0xcd, 0x47, 0xbc, -0xdb, 0x3a, 0x55, 0x3d, 0xa5, 0x38, 0x4a, 0xf3, -0x0f, 0x06, 0xff, 0x63, 0x56, 0x0b, 0x52, 0x5f, -0x54, 0x7e, 0xa6, 0x75, 0x77, 0xd9, 0xeb, 0x43, -0x0c, 0x16, 0x6e, 0xef, 0xbc, 0x0d, 0x0e, 0x4b, -0x0b, 0x18, 0x42, 0x73, 0xe2, 0x9f, 0xf4, 0xd7, -0xb1, 0xef, 0x66, 0x7f, 0xd2, 0xd5, 0x04, 0x0f, -0xd0, 0xce, 0x23, 0x81, 0xb0, 0xdb, 0xd6, 0x88, -0x7e, 0xdc, 0xda, 0x7f, 0x85, 0x21, 0xad, 0xff, -0x11, 0x9e, 0x8e, 0x56, 0x0e, 0xcb, 0x9f, 0x23, -0x3f, 0xa4, 0xf7, 0xd2, 0xf9, 0xb1, 0x9e, 0x71, -0x54, 0xc8, 0x74, 0xcc, 0x1f, 0x2e, 0xca, 0xc0, -0x3f, 0xf0, 0x61, 0x0c, 0x9f, 0x2f, 0x0e, 0xc2, -0x07, 0xe0, 0xff, 0xeb, 0x92, 0x60, 0xe7, 0xa6, -0x68, 0x47, 0x77, 0xd3, 0xed, 0xd3, 0x82, 0xa2, -0x87, 0x7e, 0x08, 0xb3, 0x74, 0x8f, 0x83, 0xff, -0x99, 0x95, 0xd2, 0xff, 0x18, 0xab, 0xe5, 0x1e, -0xdd, 0x3b, 0xd4, 0x7a, 0xaa, 0xed, 0x0d, 0x58, -0x30, 0x60, 0xea, 0x9f, 0xfb, 0x9d, 0xf8, 0x27, -0xcd, 0xbf, 0xad, 0x83, 0x8b, 0xb4, 0x2e, 0xe9, -0xe9, 0x13, 0x6b, 0xb1, 0xfe, 0x02, 0x23, 0x3e, -0x43, 0x44, 0x05, 0xcd, 0xaf, 0x78, 0x1c, 0xfd, -0x0f, 0x05, 0x1b, 0xff, 0xf3, 0x34, 0xcf, 0x76, -0xf9, 0x66, 0x49, 0xf7, 0x02, 0xf3, 0xd8, 0xed, -0x64, 0x0b, 0x6c, 0x82, 0xc0, 0x09, 0xbf, 0xf3, -0xfc, 0x0b, 0x1b, 0xff, 0xb3, 0x97, 0x56, 0x87, -0xe5, 0xc5, 0xe4, 0x5e, 0xe8, 0xe8, 0xf0, 0x87, -0xe1, 0x44, 0x88, 0x77, 0xc0, 0x46, 0x05, 0x54, -0x1a, 0xff, 0xac, 0x75, 0xd4, 0x5f, 0x40, 0x4c, -0xf7, 0x2f, 0xac, 0xd9, 0x42, 0xb0, 0x8d, 0xb6, -0x7f, 0x56, 0x64, 0x0b, 0x74, 0x4a, 0x01, 0x83, -0xff, 0x31, 0xef, 0x1f, 0x29, 0xb3, 0xf8, 0x9f, -0xb5, 0xa8, 0xfe, 0xa2, 0x9e, 0x11, 0xb1, 0x0f, -0x8e, 0xc3, 0x12, 0xea, 0xf9, 0x4b, 0x71, 0x03, -0x39, 0x66, 0x28, 0x82, 0xec, 0xfd, 0x0f, 0x6d, -0xfb, 0x71, 0xc3, 0x10, 0xc2, 0xbc, 0x30, 0x07, -0xeb, 0xbf, 0x24, 0x3c, 0x18, 0xa2, 0x20, 0x13, -0xff, 0xe4, 0x85, 0x3d, 0x86, 0x50, 0x36, 0x90, -0x81, 0x7f, 0x6c, 0xe8, 0x45, 0xab, 0x6d, 0x77, -0x6f, 0x23, 0xbf, 0x37, 0x8c, 0x68, 0xea, 0x60, -0x8b, 0xfc, 0xfa, 0x9f, 0xc3, 0x72, 0x6d, 0xc8, -0x1d, 0x8d, 0x0c, 0xab, 0x07, 0x99, 0xb1, 0x22, -0x7a, 0x4d, 0xc0, 0xbc, 0xff, 0x05, 0x6b, 0x7e, -0x32, 0xf9, 0x9f, 0xe5, 0xee, 0xd2, 0xc8, 0xc0, -0xee, 0xbd, 0x35, 0x81, 0xe5, 0x2b, 0x18, 0x22, -0xc2, 0xf3, 0x2f, 0x96, 0x3b, 0xf5, 0x3f, 0xd7, -0x3a, 0xf8, 0x1f, 0x86, 0x7f, 0x90, 0xff, 0x19, -0x57, 0x67, 0x23, 0x10, 0xe2, 0x07, 0x31, 0x60, -0x45, 0xd8, 0x69, 0x6b, 0xfd, 0xf4, 0xd9, 0xfa, -0xff, 0x18, 0xea, 0xe5, 0x21, 0xf1, 0xbc, 0xf4, -0x73, 0xd2, 0xa2, 0xad, 0x6a, 0xb7, 0x9d, 0x7f, -0x51, 0x98, 0xc6, 0x3f, 0xf6, 0x69, 0x91, 0xeb, -0x34, 0xcf, 0x43, 0x9d, 0xc3, 0xd5, 0x17, 0xe4, -0xe6, 0x10, 0x17, 0xc6, 0xb0, 0x0f, 0x2d, 0x14, -0x70, 0xe2, 0x9f, 0x98, 0xc5, 0xff, 0xb0, 0x8d, -0x55, 0x43, 0x99, 0xdc, 0xe5, 0x3b, 0x03, 0x7d, -0x5a, 0xad, 0xc2, 0xc2, 0xfa, 0x85, 0xf6, 0x6e, -0xa8, 0x55, 0xda, 0x1c, 0xf8, 0x47, 0xea, 0x4a, -0x8f, 0xf7, 0xe7, 0xb4, 0x52, 0xdb, 0xbc, 0x9a, -0xbc, 0x0a, 0x4f, 0x75, 0xcc, 0x0f, 0x8b, 0xed, -0xe4, 0x94, 0xd2, 0x61, 0x54, 0xcc, 0x39, 0xf0, -0x4f, 0x7a, 0x3e, 0x9f, 0x82, 0x4f, 0x85, 0x8a, -0x86, 0x6e, 0xfe, 0xb7, 0xe8, 0xcf, 0xd5, 0x05, -0x5a, 0xcf, 0x10, 0x39, 0x7f, 0xcb, 0x66, 0x63, -0x3e, 0x6d, 0xf5, 0x5f, 0x92, 0xfd, 0xef, 0x1b, -0xaa, 0xd3, 0xe6, 0x6f, 0x13, 0xdf, 0x82, 0x0b, -0x7a, 0x73, 0x3b, 0xf6, 0xe3, 0x25, 0x47, 0x8d, -0x83, 0x3c, 0x6c, 0xf5, 0x5f, 0x8e, 0xf5, 0xa0, -0x34, 0x2f, 0x2b, 0x89, 0x56, 0xbd, 0x99, 0x42, -0x44, 0x88, 0x18, 0x85, 0xeb, 0xb3, 0xf1, 0x8f, -0x35, 0xff, 0x97, 0xa0, 0x1e, 0x3c, 0xba, 0xb8, -0x10, 0x2e, 0x15, 0xd4, 0x43, 0xc9, 0x00, 0x73, -0x3b, 0xe3, 0x42, 0x06, 0xfe, 0x91, 0x25, 0x07, -0xff, 0xe3, 0xe7, 0x69, 0x2f, 0x63, 0xc7, 0xba, -0xb3, 0x34, 0x8d, 0x7f, 0x54, 0xd3, 0x3f, 0xc8, -0x0e, 0xfd, 0x0f, 0x55, 0xcf, 0xb0, 0xef, 0x0b, -0x3b, 0x86, 0xa9, 0x49, 0x66, 0x0c, 0x4a, 0x58, -0xc1, 0xc4, 0xf1, 0x8f, 0xf5, 0x3d, 0xda, 0xf5, -0x3f, 0xfb, 0xb5, 0x79, 0x4a, 0xdb, 0x4a, 0xa2, -0xc0, 0x7e, 0xbd, 0x32, 0x28, 0x6b, 0x64, 0x08, -0xb0, 0x31, 0x72, 0x16, 0xfe, 0xb1, 0xd0, 0xce, -0x39, 0x1a, 0x8f, 0x05, 0xfc, 0xee, 0x6b, 0x0c, -0x23, 0x8d, 0x7f, 0xaa, 0x6c, 0xf8, 0xe7, 0x5a, -0x1b, 0x1f, 0x72, 0x01, 0x65, 0x84, 0xd6, 0xf7, -0x42, 0xed, 0xe7, 0x5f, 0x98, 0xef, 0xc3, 0xf0, -0x8f, 0x11, 0xbf, 0x0e, 0x8a, 0x58, 0xc8, 0x53, -0xb7, 0x66, 0xeb, 0x76, 0x6e, 0xb4, 0x84, 0x59, -0xfc, 0x2a, 0x64, 0x8e, 0xa8, 0x19, 0xf3, 0x17, -0x43, 0xe9, 0xfe, 0x87, 0xf2, 0x63, 0x6c, 0xbc, -0xec, 0x25, 0x37, 0x70, 0xff, 0xa3, 0xc6, 0x4a, -0xd6, 0x5e, 0x35, 0xc4, 0x0c, 0x6c, 0x3b, 0xe6, -0xfb, 0x3e, 0xdd, 0xb4, 0x6b, 0xfe, 0xa8, 0xec, -0xd4, 0xff, 0xcc, 0xb2, 0xfa, 0xff, 0xc0, 0x33, -0x30, 0x47, 0x6e, 0xd5, 0x98, 0x77, 0xdd, 0x8f, -0x65, 0x5f, 0x43, 0xe4, 0x2a, 0xfa, 0x13, 0x95, -0x13, 0xd7, 0x76, 0xfc, 0xb3, 0xc5, 0xee, 0x7f, -0x76, 0xe9, 0xae, 0x1b, 0x23, 0x03, 0xa8, 0x30, -0x3f, 0xe2, 0x56, 0x49, 0x37, 0xee, 0xc8, 0xfa, -0xe5, 0xcc, 0xfa, 0xf7, 0x34, 0x7a, 0xa1, 0x0d, -0x98, 0x88, 0x79, 0x13, 0x26, 0x74, 0x86, 0x70, -0xd8, 0x8e, 0x8c, 0x17, 0xf2, 0xec, 0x71, 0xe0, -0x1f, 0x18, 0x95, 0xac, 0xfb, 0xc7, 0x69, 0xa3, -0x5a, 0x82, 0xec, 0xdf, 0x38, 0xbd, 0x5b, 0xf5, -0x46, 0xdd, 0xc3, 0x52, 0x4e, 0xfc, 0x93, 0x8a, -0x77, 0xcf, 0x60, 0x98, 0xc3, 0xee, 0x6d, 0x63, -0xda, 0x71, 0xc3, 0x58, 0xcc, 0x22, 0x7e, 0xb3, -0x13, 0xff, 0x38, 0xfa, 0xff, 0x5c, 0x20, 0xfc, -0x43, 0x18, 0x65, 0x9f, 0x61, 0x89, 0xd6, 0xfa, -0xbd, 0xd2, 0xea, 0x1c, 0xf8, 0x47, 0xb0, 0xdd, -0x6f, 0x7d, 0x38, 0x9b, 0x61, 0xae, 0x86, 0x69, -0x32, 0x25, 0x67, 0xfd, 0xbb, 0x35, 0x3f, 0xfb, -0xc0, 0xb3, 0x9d, 0x4d, 0x4b, 0x82, 0x44, 0x20, -0x40, 0x57, 0xc4, 0x49, 0x09, 0x4d, 0x29, 0xa2, -0x6d, 0xf8, 0xa7, 0xc2, 0x00, 0x39, 0xee, 0x7d, -0x9d, 0x7b, 0x60, 0x0c, 0x9a, 0x67, 0x7a, 0x23, -0x9d, 0xbc, 0x11, 0x96, 0x84, 0x27, 0x10, 0xc5, -0x5e, 0x57, 0xf9, 0x8e, 0xdb, 0x86, 0x7f, 0xb0, -0xff, 0xb3, 0x3f, 0x15, 0xbf, 0x4c, 0xe1, 0x93, -0xfa, 0x4f, 0x2e, 0x34, 0xdc, 0xec, 0xa7, 0x50, -0x06, 0xfe, 0x01, 0xc0, 0xba, 0x08, 0xcc, 0xfa, -0x2b, 0x53, 0x18, 0x60, 0xff, 0x27, 0x01, 0x7b, -0x3b, 0x8d, 0x79, 0xe0, 0x29, 0x0c, 0xfb, 0xbf, -0x2e, 0xa8, 0x04, 0xf6, 0x71, 0x28, 0x53, 0x19, -0xff, 0x9e, 0xe7, 0x23, 0xf9, 0x98, 0x3a, 0xf3, -0x2c, 0xaf, 0x61, 0xfb, 0x37, 0xf5, 0x8d, 0x86, -0xf1, 0xef, 0x79, 0xfe, 0x1f, 0xfb, 0xef, 0x3f, -0xd9, 0xfc, 0x2b, 0x78, 0x96, 0xdf, 0x20, 0xdc, -0xc9, 0x80, 0xd1, 0x14, 0x86, 0xf4, 0x7f, 0xfc, -0xfc, 0xff, 0xe0, 0xf9, 0x97, 0x14, 0xfa, 0x07, -0xcc, 0xb9, 0x60, 0xf9, 0x93, 0x3f, 0xf6, 0x5f, -0x53, 0xd3, 0x1f, 0x72, 0x97, 0xd7, 0xfb, 0x7f, -0xf8, 0xf8, 0xff, 0x17, 0xfe, 0xb5, 0x4c, 0x4e, -0x4e, 0xea, 0x9f, 0x60, 0xfc, 0xff, 0xf9, 0xfe, -0xff, 0x64, 0xdf, 0xe3, 0x7f, 0xf9, 0xc3, 0xff, -0xf2, 0x87, 0xff, 0x8e, 0xf9, 0xff, 0x2f, 0x7f, -0xf8, 0x49, 0xff, 0xfe, 0xb3, 0xf9, 0x9f, 0xff, -0x5c, 0xf7, 0xeb, 0x05, 0xe7, 0xe1, 0x38, 0x6d, -0xd1, 0x3c, 0x23, 0xe2, 0xb3, 0xf0, 0x2f, 0x94, -0x57, 0xc3, 0x71, 0x7e, 0x35, 0x5f, 0x7e, 0x50, -0xf9, 0x4b, 0xb8, 0x8f, 0x2e, 0x08, 0xcb, 0xbb, -0x4b, 0x6b, 0xf9, 0x69, 0xb0, 0xb9, 0xf3, 0x83, -0x69, 0x7e, 0x8c, 0xad, 0xd9, 0x08, 0xb6, 0xd9, -0x8f, 0x95, 0x6e, 0x51, 0xbe, 0x0f, 0xd5, 0x7a, -0xee, 0xfc, 0xa0, 0x8d, 0x1f, 0x7b, 0x4b, 0xb9, -0xaf, 0xbb, 0x96, 0x3d, 0x1f, 0xd5, 0xe0, 0x42, -0x9e, 0xfc, 0xe0, 0xb8, 0xb5, 0xdf, 0x14, 0xca, -0xfe, 0x49, 0x3a, 0xd6, 0xdf, 0xec, 0x0f, 0xa8, -0x33, 0xf6, 0x48, 0xbf, 0x56, 0x1b, 0x8c, 0x32, -0xc6, 0x89, 0x8c, 0xfc, 0x9d, 0x2d, 0x3f, 0x08, -0x5b, 0xc8, 0x15, 0xb8, 0x91, 0xed, 0x0e, 0xd8, -0x6e, 0x73, 0x52, 0x6d, 0x31, 0xfa, 0x23, 0x4d, -0x95, 0x1f, 0x7c, 0x02, 0x9b, 0xe4, 0x2c, 0x0b, -0x44, 0xc4, 0x3d, 0x74, 0x42, 0x6e, 0xd4, 0x03, -0xb9, 0xf2, 0x5f, 0xce, 0xfc, 0xe0, 0x7d, 0xb4, -0x56, 0xef, 0xde, 0x4f, 0x8a, 0xd9, 0xee, 0x40, -0x1d, 0xc9, 0xf9, 0xfe, 0x76, 0x7d, 0xd4, 0x32, -0x78, 0x78, 0x7d, 0x20, 0x24, 0x57, 0x87, 0xb6, -0x42, 0xaf, 0xe2, 0x77, 0xb4, 0x65, 0xcb, 0xd9, -0x1f, 0xe0, 0x2a, 0xed, 0x11, 0x54, 0x6f, 0xae, -0x0d, 0xcd, 0x56, 0x5b, 0x68, 0x65, 0x72, 0x79, -0xae, 0x7c, 0x99, 0x5d, 0x1f, 0x25, 0xc1, 0x2b, -0x5d, 0x4d, 0x5a, 0x40, 0x15, 0xb7, 0xc0, 0x87, -0xea, 0x62, 0xdd, 0x93, 0x6a, 0x0b, 0x99, 0xcc, -0xd7, 0x1f, 0x72, 0x3f, 0x79, 0x07, 0x5a, 0x86, -0xbc, 0x61, 0xde, 0x5f, 0xf4, 0x46, 0xfd, 0xf3, -0x46, 0x23, 0x71, 0x7e, 0xac, 0x5e, 0x8e, 0xfc, -0xa0, 0x5f, 0xfa, 0x31, 0xbc, 0xc8, 0xb6, 0xb1, -0x25, 0x31, 0x71, 0x9d, 0x34, 0x41, 0x50, 0x48, -0x4f, 0xb2, 0xe7, 0x27, 0xfd, 0xf7, 0x4d, 0x28, -0x8f, 0xc1, 0x26, 0xa1, 0xb2, 0x5f, 0xc6, 0xf3, -0x61, 0x0f, 0xc0, 0x8e, 0xdc, 0xf9, 0x85, 0x73, -0x36, 0x7f, 0xf5, 0x00, 0x3c, 0x70, 0xdf, 0x9c, -0xb0, 0x6b, 0x64, 0xee, 0x57, 0x90, 0xdf, 0xe0, -0x8d, 0x92, 0x64, 0x6b, 0xbc, 0x3f, 0x31, 0x8c, -0x84, 0x3d, 0x3f, 0xb8, 0xbc, 0x9b, 0xa8, 0xbf, -0x95, 0xeb, 0x78, 0xbf, 0x71, 0xd5, 0x31, 0x8d, -0x39, 0xf2, 0x83, 0xc9, 0xf2, 0x43, 0xf0, 0x00, -0x5d, 0xb4, 0xbd, 0xe4, 0x8e, 0x3b, 0xd7, 0x96, -0x5d, 0x39, 0x55, 0x67, 0x10, 0x0b, 0x99, 0x1d, -0x93, 0xc6, 0x33, 0xf4, 0x51, 0x4d, 0xe0, 0xed, -0x42, 0x35, 0x26, 0x34, 0x2b, 0x9f, 0x98, 0x1f, -0x1c, 0x16, 0x2e, 0x44, 0xeb, 0xda, 0x78, 0xdb, -0x9c, 0x0b, 0x94, 0x57, 0x3f, 0x59, 0x0c, 0xc9, -0x9a, 0x3c, 0xfd, 0x01, 0xc8, 0xce, 0x0d, 0xf2, -0xb6, 0xc8, 0x1c, 0xd8, 0x9b, 0xf0, 0xad, 0x2d, -0x49, 0xa7, 0xa5, 0x42, 0x79, 0xfb, 0x43, 0xfa, -0x34, 0x88, 0x62, 0x7f, 0x00, 0xb5, 0xa6, 0xcd, -0x4a, 0x63, 0xcd, 0xcc, 0x9d, 0x1f, 0x04, 0x29, -0x76, 0x10, 0x65, 0xe1, 0x46, 0x7f, 0x00, 0xbf, -0x36, 0x33, 0x57, 0xbe, 0x2c, 0xdd, 0x9f, 0x64, -0x83, 0x1c, 0xa6, 0x87, 0xa0, 0x4e, 0xae, 0x35, -0xfa, 0x03, 0x1c, 0x72, 0x0c, 0xd3, 0xa2, 0xce, -0x4e, 0xdb, 0xfa, 0x43, 0x9e, 0x2f, 0xfa, 0x37, -0xb8, 0x11, 0xcf, 0x7b, 0x1d, 0x96, 0xff, 0x0d, -0x17, 0x46, 0x2e, 0x62, 0xd0, 0x5e, 0x1f, 0x77, -0x1e, 0x5e, 0x82, 0xfa, 0x90, 0x67, 0x68, 0xda, -0x79, 0xf9, 0x32, 0x2c, 0xd1, 0x66, 0x19, 0xc7, -0xc8, 0xb6, 0x20, 0x6d, 0x98, 0xf3, 0x7c, 0x90, -0x33, 0x6d, 0xdd, 0x05, 0x3e, 0x45, 0x66, 0xae, -0x07, 0x85, 0x04, 0x30, 0xdb, 0x2a, 0x94, 0xcb, -0x77, 0x3e, 0xc8, 0x35, 0x9b, 0xa9, 0x1a, 0xf6, -0x07, 0x0b, 0x07, 0xd8, 0x6c, 0xf8, 0x35, 0xab, -0x2d, 0xa4, 0xbd, 0x3f, 0xa4, 0xed, 0x7c, 0xd8, -0xf2, 0x5d, 0x32, 0x6f, 0x4b, 0xfe, 0x5d, 0xd4, -0x47, 0x15, 0xf9, 0xd2, 0x6d, 0x21, 0xe5, 0x9c, -0xf9, 0xc1, 0xd8, 0xf4, 0x37, 0x83, 0xfd, 0x74, -0x5f, 0xbb, 0xe7, 0xb1, 0xc2, 0xe1, 0x32, 0x2c, -0x73, 0x4b, 0xb5, 0xb5, 0x6c, 0x72, 0xf4, 0xb7, -0xb4, 0xf7, 0x47, 0xfa, 0xf1, 0xb2, 0x1b, 0x14, -0x73, 0x36, 0xa2, 0xf9, 0xce, 0x87, 0xb5, 0xf3, -0x63, 0x42, 0xa2, 0x28, 0x88, 0x6a, 0xf0, 0x58, -0x45, 0xe2, 0xb6, 0x46, 0x58, 0x35, 0x75, 0x7e, -0x50, 0x2d, 0x90, 0x85, 0x07, 0xe4, 0xaa, 0x7b, -0xbb, 0x87, 0xc5, 0x3e, 0xf6, 0x69, 0x56, 0xc6, -0x3c, 0x6c, 0x3d, 0x2b, 0x87, 0x60, 0x81, 0x33, -0x3f, 0x68, 0xf1, 0x63, 0xfe, 0x2e, 0x8f, 0x10, -0xd1, 0xd4, 0xb8, 0x3c, 0x77, 0x6e, 0x1b, 0xa5, -0xba, 0xbf, 0xd4, 0xcc, 0x0f, 0xd2, 0xd4, 0xf7, -0xe2, 0xcf, 0xc8, 0x0f, 0x82, 0x07, 0x36, 0x81, -0x4a, 0x65, 0xec, 0x0f, 0xb0, 0x47, 0xab, 0x54, -0x52, 0x65, 0xf2, 0x5f, 0xa7, 0x79, 0xf2, 0x83, -0xdd, 0xb3, 0x95, 0x4d, 0x91, 0x85, 0x6a, 0x60, -0xad, 0xf8, 0xdf, 0xa5, 0x01, 0x7a, 0x43, 0xf8, -0xba, 0x14, 0x2d, 0x16, 0x4b, 0xe5, 0x07, 0x6f, -0xc8, 0xc8, 0x0f, 0x7a, 0xf6, 0x90, 0x0f, 0x8d, -0x8f, 0x8e, 0xc2, 0x98, 0xd0, 0xa4, 0xa5, 0xdb, -0x62, 0x1b, 0x46, 0x83, 0x93, 0x1f, 0xd3, 0xca, -0x4f, 0x6b, 0xff, 0xa0, 0x2c, 0x8c, 0x79, 0xba, -0xc9, 0x69, 0xed, 0xf7, 0x74, 0xa1, 0xca, 0xe2, -0xd7, 0x03, 0xe4, 0xe5, 0xe8, 0x8d, 0xb1, 0x5a, -0x7b, 0x7e, 0x30, 0xcd, 0x8f, 0x5d, 0xfd, 0x98, -0xde, 0x19, 0xaf, 0xa4, 0xf2, 0x0a, 0xf1, 0x15, -0x3a, 0x00, 0x3b, 0xba, 0xe5, 0x31, 0x32, 0x9b, -0x6e, 0x8a, 0xcd, 0xdf, 0x9d, 0x3a, 0xef, 0xe3, -0x06, 0xdd, 0xd9, 0x1f, 0x92, 0x3e, 0x53, 0xb4, -0xb5, 0x6e, 0x0e, 0x95, 0xb5, 0x9b, 0x4e, 0xc8, -0xfb, 0xe5, 0x4a, 0xa1, 0x68, 0x8c, 0x3c, 0x86, -0xfd, 0x30, 0xbb, 0xe5, 0x9c, 0xf9, 0xc1, 0xb0, -0xf4, 0x92, 0xd0, 0x39, 0xbd, 0x3a, 0xe6, 0x87, -0x7b, 0x75, 0xa0, 0x47, 0x18, 0x5c, 0xb3, 0xca, -0xa0, 0x72, 0xe7, 0x07, 0xa5, 0x3d, 0xea, 0xd1, -0x8e, 0xeb, 0x9f, 0x67, 0x7f, 0x5f, 0x5d, 0x8a, -0xd3, 0x3a, 0xb8, 0x1f, 0xeb, 0xbb, 0x7b, 0x0a, -0x9a, 0x69, 0x4d, 0xce, 0xfc, 0x20, 0xd6, 0x67, -0xbd, 0x0b, 0x8d, 0x51, 0xef, 0x46, 0xf4, 0x3f, -0x2a, 0xef, 0x86, 0xed, 0x98, 0x9f, 0xc6, 0x4c, -0x7e, 0xec, 0x19, 0x75, 0x12, 0x16, 0xc1, 0x16, -0x5d, 0x8c, 0xc3, 0xa0, 0xb6, 0x44, 0x33, 0xdd, -0x38, 0x4d, 0x19, 0x8b, 0xb2, 0xf2, 0x83, 0xd0, -0x3b, 0xe0, 0xa3, 0xb2, 0x4c, 0xaa, 0xe8, 0xb8, -0xee, 0x0b, 0xbb, 0xb1, 0x3f, 0xcf, 0x61, 0xec, -0x2f, 0x91, 0x3b, 0x3f, 0x88, 0xfd, 0x01, 0xf4, -0xb9, 0x11, 0x79, 0x0b, 0xd9, 0x09, 0xf7, 0x69, -0x35, 0xaa, 0x79, 0x1b, 0x4d, 0x2b, 0xa6, 0xb2, -0xf4, 0x51, 0xf2, 0x5c, 0x2a, 0xd3, 0x10, 0xd0, -0x3e, 0xf6, 0x9a, 0x78, 0x30, 0x04, 0xed, 0x95, -0x03, 0x91, 0xd6, 0xbc, 0xfd, 0x01, 0x26, 0xd4, -0x06, 0xea, 0x89, 0x74, 0xc6, 0x68, 0x02, 0x1a, -0xc1, 0x68, 0x3b, 0xac, 0x36, 0x3f, 0x66, 0x5f, -0x0f, 0xce, 0xfe, 0x90, 0x1f, 0xce, 0x5b, 0x42, -0xbd, 0xba, 0x98, 0xfc, 0x1c, 0x9e, 0x50, 0xc1, -0xcb, 0x9a, 0xf8, 0xfc, 0xe4, 0xce, 0x0f, 0x6e, -0x34, 0x17, 0x49, 0x55, 0xca, 0x18, 0x9b, 0xf6, -0x91, 0xf6, 0x46, 0x74, 0x91, 0xd1, 0x31, 0xe0, -0x8d, 0xa6, 0x7a, 0x95, 0x19, 0x71, 0xeb, 0x3c, -0x6b, 0xbd, 0xc2, 0xc8, 0x0f, 0xa6, 0xd1, 0xce, -0x33, 0xa1, 0xd1, 0xd2, 0x1e, 0x3c, 0xdf, 0xb6, -0x8e, 0x78, 0xe8, 0x26, 0xd5, 0xb7, 0x83, 0xfd, -0x34, 0x66, 0xf9, 0xff, 0x04, 0x6c, 0x51, 0x9c, -0xd1, 0xe7, 0x7a, 0x36, 0x2d, 0x8f, 0x73, 0x1a, -0x30, 0xb2, 0x52, 0x7d, 0x18, 0x54, 0x8d, 0xfd, -0x74, 0x2e, 0xad, 0x0f, 0x97, 0xf6, 0x64, 0xa1, -0x85, 0x51, 0x9a, 0x6a, 0x0b, 0x19, 0x80, 0x99, -0xc2, 0xed, 0xda, 0x4c, 0xbb, 0x3e, 0xfc, 0xb3, -0xe5, 0xa3, 0xfc, 0x3c, 0x3b, 0x5b, 0xb4, 0x25, -0xc7, 0x95, 0x17, 0x85, 0x06, 0x7d, 0x55, 0x7c, -0xfa, 0x3a, 0xe9, 0x75, 0xa9, 0x6e, 0x0e, 0xfb, -0x29, 0x66, 0xf9, 0x9f, 0x58, 0x4a, 0x1f, 0xbe, -0xd5, 0x36, 0x1b, 0x57, 0xe0, 0x1f, 0x52, 0xf8, -0x47, 0x79, 0x1f, 0xbc, 0xfd, 0x8e, 0xfe, 0x90, -0x98, 0x1f, 0x7c, 0xd7, 0xf9, 0xfc, 0x3f, 0x31, -0x96, 0x19, 0xf6, 0x9f, 0x54, 0x5f, 0x64, 0xa1, -0x81, 0xfd, 0xf4, 0x81, 0xb5, 0x3e, 0x4f, 0x64, -0xd4, 0x4b, 0xe2, 0xc1, 0x3a, 0xcc, 0xe8, 0xae, -0xfd, 0x6d, 0x71, 0x5f, 0xe7, 0x1d, 0xea, 0x1b, -0xa4, 0xae, 0x9d, 0xcd, 0xe6, 0x47, 0xd6, 0x7a, -0xd0, 0xa5, 0x95, 0x59, 0xd1, 0x79, 0x25, 0xcc, -0x68, 0x0b, 0x24, 0xe4, 0x7d, 0x64, 0x0f, 0xfc, -0x00, 0xaa, 0x95, 0x1e, 0xc7, 0xf9, 0x68, 0x8a, -0x51, 0x26, 0xef, 0xbe, 0xab, 0x90, 0xa3, 0x9d, -0xb7, 0x2d, 0xd8, 0x83, 0x1d, 0x23, 0xa3, 0x07, -0xa2, 0x95, 0x31, 0x76, 0x65, 0xdc, 0x86, 0x7f, -0x56, 0x1a, 0x20, 0xa7, 0x91, 0xa1, 0x9d, 0x5e, -0x25, 0x90, 0x74, 0x2f, 0xb9, 0x69, 0x50, 0xf9, -0x10, 0x38, 0x10, 0x7a, 0x80, 0x3e, 0x1f, 0xbf, -0x7e, 0xd4, 0xeb, 0x38, 0x1f, 0xb6, 0x1c, 0xfb, -0x43, 0xde, 0x63, 0x76, 0x43, 0x42, 0xf6, 0x98, -0x37, 0x0a, 0x58, 0x34, 0xc0, 0xf3, 0xe9, 0x6f, -0x40, 0xcb, 0x11, 0xc4, 0x3f, 0xd6, 0xfc, 0xcb, -0xd2, 0x9e, 0x74, 0x7e, 0x10, 0x0b, 0x57, 0x4b, -0xe2, 0x55, 0x28, 0x94, 0xe2, 0x07, 0xd5, 0x8d, -0x0a, 0x2f, 0xf6, 0xd7, 0xc9, 0x5b, 0x1d, 0xfa, -0xf0, 0x0a, 0x67, 0x7f, 0x80, 0x7e, 0xf7, 0x37, -0x7d, 0x58, 0x16, 0x57, 0xc5, 0x1b, 0x05, 0xe0, -0x89, 0x69, 0x83, 0x45, 0x0c, 0xff, 0xa8, 0xe6, -0xf3, 0x1d, 0xf9, 0x41, 0x6e, 0x7c, 0x9b, 0xe0, -0x89, 0x69, 0x73, 0xf8, 0x78, 0xe1, 0xe1, 0xef, -0xfd, 0x08, 0xc7, 0x9b, 0xb4, 0xf0, 0xea, 0x88, -0x9d, 0x9f, 0xaf, 0x37, 0x8c, 0xe3, 0xa1, 0x1e, -0x53, 0x68, 0x27, 0x1a, 0x08, 0x3c, 0xad, 0x0f, -0x4f, 0x96, 0x8f, 0x28, 0x06, 0xc8, 0x31, 0x60, -0x4f, 0xc7, 0x3f, 0xc4, 0x44, 0x3c, 0x31, 0xad, -0x81, 0x9f, 0x27, 0x25, 0x1e, 0x33, 0x5a, 0x07, -0xd8, 0xf0, 0x8f, 0xe0, 0xac, 0xd7, 0x36, 0x8f, -0x45, 0xbb, 0xcb, 0xcc, 0x18, 0x36, 0xc2, 0xb4, -0x3c, 0xf9, 0xc1, 0x94, 0xa1, 0x54, 0x55, 0xf3, -0x7e, 0xc8, 0xdd, 0xbc, 0x10, 0x4c, 0xe0, 0x89, -0xb0, 0xbc, 0xfd, 0x01, 0xb8, 0x50, 0x19, 0x1b, -0x25, 0xed, 0xd4, 0xfc, 0x51, 0x57, 0xb5, 0x6b, -0x33, 0x94, 0x24, 0x1d, 0xf8, 0x67, 0x71, 0x41, -0x46, 0x37, 0x24, 0x16, 0xaf, 0xab, 0x55, 0x3c, -0x1f, 0xad, 0x07, 0x11, 0xd1, 0x66, 0xde, 0x31, -0xc0, 0xd6, 0x1f, 0xc0, 0x5f, 0x86, 0xf9, 0xc1, -0x6a, 0x5e, 0x2f, 0x0f, 0x0f, 0xf2, 0xfe, 0x48, -0xf7, 0xe1, 0x95, 0x30, 0xd2, 0x0f, 0x58, 0x3a, -0x97, 0xd1, 0x1f, 0x69, 0x43, 0x66, 0x7f, 0x00, -0x6f, 0x44, 0x64, 0xab, 0x10, 0x4a, 0xa1, 0x84, -0x56, 0x51, 0x48, 0x18, 0x47, 0xa7, 0x9d, 0xb5, -0xea, 0xeb, 0xb7, 0x67, 0x9e, 0x97, 0xc1, 0x46, -0x77, 0x3e, 0x75, 0x3e, 0x48, 0x64, 0xf8, 0x47, -0xd8, 0x3a, 0xdb, 0x1b, 0x9d, 0xf1, 0x51, 0xce, -0xfe, 0x00, 0x86, 0xf1, 0x50, 0xe7, 0xef, 0xe1, -0x35, 0xa5, 0x41, 0xf3, 0x60, 0x7d, 0xdc, 0x6b, -0x59, 0x7a, 0xaa, 0x8a, 0xb4, 0x3e, 0x9c, 0x1b, -0x62, 0x17, 0x33, 0xba, 0x19, 0x10, 0xc2, 0x63, -0x2b, 0x61, 0x44, 0xe5, 0x3f, 0x9d, 0x4e, 0xe3, -0x1f, 0xb0, 0xe5, 0x07, 0x1f, 0x34, 0x8d, 0xef, -0xaa, 0xf3, 0x97, 0xcb, 0xed, 0xe4, 0x16, 0xfa, -0xe0, 0xe7, 0x02, 0xe1, 0x99, 0xf6, 0xfe, 0x48, -0xdb, 0xa5, 0x5d, 0x59, 0xea, 0xb2, 0x01, 0x7a, -0x3f, 0x99, 0xaf, 0xe1, 0xfd, 0xe6, 0x54, 0xdb, -0xf4, 0xe1, 0x99, 0xe3, 0xc5, 0xb7, 0xe5, 0x7a, -0x6f, 0x7f, 0xd4, 0xbd, 0x46, 0x7a, 0x4d, 0x68, -0x0e, 0x7b, 0xa3, 0x64, 0xc4, 0xd2, 0xe7, 0x24, -0x1c, 0xfd, 0x01, 0xd2, 0x46, 0x0a, 0x18, 0x17, -0xc1, 0xec, 0x35, 0x0e, 0xfc, 0x23, 0x67, 0xf4, -0x07, 0x60, 0xc6, 0x34, 0x23, 0x51, 0xc8, 0x3c, -0xfc, 0x18, 0x76, 0xcc, 0xc6, 0x7a, 0xcc, 0x63, -0xd4, 0x5c, 0xff, 0x19, 0xfa, 0x70, 0x34, 0x0a, -0x47, 0x78, 0x07, 0x0c, 0xbc, 0x22, 0x19, 0x86, -0xd8, 0x9d, 0x5e, 0x0f, 0x52, 0xd6, 0xee, 0xe0, -0xe6, 0x41, 0xdc, 0xb8, 0xa1, 0x50, 0x3c, 0x81, -0x19, 0xf6, 0x01, 0x87, 0x3e, 0x9c, 0x2a, 0xb7, -0x9a, 0xdf, 0xef, 0xad, 0xb6, 0x44, 0x21, 0xcc, -0x01, 0x51, 0x23, 0xaf, 0xc2, 0x81, 0x6d, 0x73, -0x10, 0x08, 0x8d, 0x68, 0xe6, 0xf3, 0xbb, 0xbb, -0xbf, 0x92, 0x4a, 0x02, 0x12, 0x33, 0x1b, 0x48, -0x4e, 0xb2, 0x40, 0x53, 0x99, 0xdc, 0xba, 0x41, -0x3c, 0x09, 0x1f, 0xc6, 0x17, 0x1a, 0xe7, 0xa3, -0x99, 0xeb, 0x4d, 0x76, 0xea, 0xa5, 0xb1, 0xde, -0x67, 0xc6, 0x08, 0x8c, 0x4b, 0x77, 0xa0, 0x42, -0x6c, 0x18, 0x26, 0xb4, 0xc6, 0xed, 0xec, 0xa7, -0xc8, 0xbd, 0xe6, 0xfc, 0x40, 0xd9, 0xb3, 0x2c, -0x5a, 0x2d, 0x31, 0xce, 0x77, 0x78, 0xc3, 0x6c, -0x14, 0x90, 0xd2, 0xf7, 0xde, 0xc5, 0xfe, 0x87, -0xee, 0x39, 0xcf, 0xae, 0x8c, 0x59, 0xf3, 0xff, -0xa4, 0x62, 0xf6, 0x87, 0xe4, 0xfe, 0x27, 0xf0, -0x36, 0x1b, 0xe6, 0x69, 0x6d, 0xff, 0xce, 0x1b, -0x02, 0x6e, 0x8d, 0x48, 0x5a, 0xaf, 0x52, 0xcd, -0xf1, 0x8f, 0x35, 0xff, 0x00, 0x8f, 0x09, 0x76, -0x7f, 0x95, 0x70, 0xaf, 0x57, 0x4e, 0x44, 0x53, -0x8a, 0xf1, 0xff, 0x8e, 0x57, 0xda, 0x57, 0xac, -0xb7, 0xed, 0xdf, 0x55, 0x65, 0x4b, 0x96, 0x3f, -0x4f, 0xc8, 0x71, 0xc9, 0x0f, 0x6e, 0x60, 0xdf, -0x57, 0x2f, 0x54, 0x87, 0x33, 0xfa, 0x03, 0x18, -0xd1, 0xc4, 0xda, 0xad, 0x5f, 0x17, 0x27, 0x67, -0xbb, 0x27, 0x8c, 0xfe, 0x72, 0x6b, 0xd1, 0x03, -0xb7, 0xb1, 0xf1, 0x9e, 0x4e, 0xeb, 0xc3, 0x85, -0x3d, 0x52, 0xc6, 0xfc, 0x60, 0xa2, 0x50, 0xe0, -0x65, 0x02, 0xc3, 0xf2, 0x04, 0xcc, 0x56, 0x1c, -0xfd, 0x91, 0x2a, 0x95, 0xac, 0x78, 0xd7, 0x3a, -0x6e, 0x1c, 0x14, 0x82, 0x8a, 0x29, 0x76, 0x25, -0xec, 0x19, 0x63, 0xfb, 0x77, 0xf3, 0xfe, 0x1d, -0x92, 0x71, 0x3e, 0xac, 0x01, 0x7b, 0x52, 0x6c, -0x03, 0x3c, 0xc3, 0x22, 0xb6, 0x5b, 0x27, 0xe7, -0xd9, 0xff, 0x62, 0x00, 0xe4, 0xb8, 0x2f, 0xed, -0x7f, 0xb0, 0x3f, 0x40, 0xe6, 0xe9, 0x15, 0xa3, -0x90, 0x92, 0x85, 0x8f, 0x60, 0xab, 0x9c, 0x6d, -0x8e, 0xfe, 0x00, 0xae, 0x32, 0x4f, 0x3a, 0xcc, -0x3d, 0x0c, 0x81, 0xa3, 0xd8, 0x38, 0x48, 0x8d, -0x57, 0x86, 0x89, 0x08, 0x75, 0x03, 0x4a, 0xaf, -0x52, 0xdb, 0xe5, 0x77, 0xe0, 0x9f, 0xfb, 0x59, -0x58, 0x41, 0x7d, 0xf8, 0x53, 0x33, 0x46, 0xb1, -0x51, 0xf3, 0xa9, 0x9e, 0xfd, 0x5f, 0x1d, 0xa1, -0x13, 0x6a, 0x5d, 0xa2, 0x24, 0x28, 0xbe, 0x8d, -0xf3, 0x03, 0x2c, 0x10, 0x27, 0xd3, 0xe7, 0xc3, -0x96, 0x5f, 0x82, 0x09, 0x85, 0x9f, 0x0f, 0x8b, -0xea, 0xaf, 0xe6, 0x97, 0x5e, 0x3e, 0xd7, 0x39, -0x0e, 0x97, 0x94, 0x16, 0xfc, 0x5e, 0xce, 0xc7, -0xde, 0x57, 0x5b, 0x8a, 0x1c, 0xf8, 0xa7, 0xbf, -0x20, 0x0e, 0xef, 0x09, 0xd3, 0xcf, 0x04, 0xc6, -0xc5, 0x66, 0x98, 0xec, 0xba, 0x51, 0xf5, 0x8c, -0x73, 0xa1, 0x78, 0x4b, 0x1e, 0xfe, 0x47, 0x97, -0x93, 0x42, 0x31, 0xf5, 0xe9, 0xfe, 0x3e, 0x82, -0xfa, 0xf0, 0x5a, 0xd5, 0x35, 0x35, 0xff, 0x73, -0x4c, 0x8a, 0xc1, 0x0e, 0xca, 0x9b, 0xf2, 0xe1, -0xc0, 0x6b, 0x21, 0x27, 0xbf, 0x61, 0xe3, 0x7f, -0xa4, 0xc7, 0xe5, 0xcd, 0x2a, 0x46, 0x2b, 0x29, -0xe0, 0x61, 0xf3, 0xa9, 0xba, 0xa6, 0xd6, 0x87, -0x2f, 0x2d, 0x7f, 0x1b, 0x76, 0x40, 0x10, 0xa3, -0x79, 0x40, 0x9a, 0x90, 0x9a, 0x82, 0xf6, 0x63, -0xf5, 0xd2, 0xfd, 0x21, 0xad, 0xf3, 0x61, 0xe3, -0xc2, 0x6e, 0xf9, 0x02, 0xe5, 0x41, 0x9c, 0xaf, -0x07, 0xc8, 0xad, 0x0f, 0xb7, 0xf5, 0xc7, 0x7e, -0x12, 0x8e, 0xc2, 0x3e, 0xab, 0xdb, 0x24, 0x94, -0xe4, 0x7a, 0xbe, 0xbd, 0x3e, 0x4e, 0x86, 0x13, -0xe0, 0x3b, 0xc3, 0xd0, 0x0b, 0x7f, 0xdb, 0xd2, -0x4f, 0xe2, 0x7f, 0xa4, 0x65, 0xd0, 0x19, 0x56, -0x93, 0xae, 0x3a, 0xec, 0x8e, 0x0e, 0x01, 0xd9, -0x95, 0x6b, 0x7e, 0xc6, 0xd2, 0xf8, 0x07, 0xbe, -0x1c, 0xfa, 0x2e, 0xad, 0x1c, 0x96, 0x53, 0xfd, -0x91, 0x62, 0x90, 0x02, 0x06, 0x79, 0xce, 0x07, -0x59, 0x5b, 0xa1, 0xc1, 0xf3, 0x34, 0x7e, 0x04, -0x65, 0xe1, 0x03, 0x1f, 0x4a, 0x4d, 0xed, 0x25, -0x4b, 0xc4, 0xe3, 0x90, 0x6a, 0x0b, 0x69, 0xf1, -0x3f, 0x27, 0xd3, 0xfc, 0xcf, 0xd5, 0x71, 0xe1, -0x3d, 0xb0, 0xce, 0x97, 0x69, 0xd6, 0xec, 0x8d, -0x02, 0x72, 0xea, 0xc3, 0xf7, 0x28, 0x2f, 0xb6, -0xd5, 0x25, 0x4b, 0x16, 0xf3, 0xfe, 0x00, 0x4d, -0x6a, 0xf1, 0xd4, 0xfa, 0xf0, 0xc4, 0xd5, 0x8f, -0xc1, 0x2f, 0x79, 0x37, 0x00, 0xce, 0xff, 0xcc, -0x07, 0x39, 0x17, 0xff, 0x73, 0xd1, 0xa6, 0x8f, -0x8a, 0xa8, 0x0f, 0x73, 0xda, 0xa7, 0x90, 0x17, -0x06, 0xae, 0xe7, 0xb0, 0xe7, 0x11, 0x3a, 0x3f, -0x8f, 0x3e, 0x3c, 0x21, 0xdd, 0x27, 0x77, 0x42, -0x8c, 0x81, 0x9c, 0xab, 0xf8, 0x87, 0xa6, 0x15, -0x05, 0xe7, 0x4e, 0xcd, 0xff, 0x8c, 0xc3, 0x0f, -0x63, 0x75, 0x88, 0x7f, 0xf0, 0x34, 0xb4, 0x96, -0x58, 0xb1, 0xa3, 0x51, 0x76, 0x36, 0xff, 0x23, -0xc4, 0xa6, 0x8d, 0x85, 0xd9, 0x32, 0xe8, 0x42, -0x7d, 0xb8, 0x71, 0x5e, 0xe7, 0x27, 0xe9, 0xc3, -0xf1, 0x90, 0x2f, 0xef, 0x43, 0xfc, 0x18, 0xd0, -0x86, 0xb5, 0xb6, 0xc0, 0x27, 0xe4, 0xd2, 0x87, -0xc3, 0x1a, 0xd8, 0x9c, 0xf4, 0xb5, 0xbb, 0x51, -0x4f, 0x9e, 0x57, 0xef, 0x6d, 0xc7, 0x3f, 0x52, -0xe1, 0x66, 0x69, 0x67, 0x78, 0x66, 0x94, 0xfc, -0x08, 0xcf, 0xf3, 0xca, 0xa7, 0x0f, 0x37, 0xd7, -0x83, 0x5f, 0x92, 0xf8, 0xb1, 0x68, 0x16, 0xdb, -0x93, 0x9b, 0xff, 0x49, 0xe3, 0x1f, 0x4f, 0x98, -0x26, 0x54, 0x9c, 0x1f, 0xce, 0xff, 0x38, 0xdb, -0x42, 0xa6, 0xf5, 0xe1, 0xb6, 0xfa, 0xb8, 0xfd, -0xb1, 0xcb, 0xd0, 0xb4, 0xdc, 0x1b, 0x9d, 0xb6, -0x8b, 0xd3, 0x38, 0xa8, 0x0f, 0x97, 0xa6, 0xe2, -0x7f, 0xfe, 0x8d, 0xfe, 0xab, 0xa7, 0x5e, 0xf3, -0x0c, 0x89, 0xdf, 0x62, 0xbf, 0xde, 0xe8, 0xa0, -0x4d, 0x72, 0x9f, 0x0f, 0xd2, 0xd5, 0xad, 0xed, -0x04, 0x3f, 0x0d, 0x31, 0xfc, 0x43, 0x4c, 0xda, -0x47, 0xc8, 0xab, 0x0f, 0xd7, 0x36, 0x76, 0x3d, -0x88, 0x7c, 0x97, 0x39, 0x3a, 0xd7, 0xd4, 0xfa, -0x70, 0x86, 0x7f, 0x2a, 0x1e, 0x65, 0xe8, 0x91, -0x57, 0x03, 0xb1, 0xd9, 0xbb, 0x05, 0x8c, 0x69, -0x2c, 0xc9, 0xa3, 0x0f, 0x8f, 0x95, 0xbf, 0x15, -0x7e, 0xcd, 0x13, 0xd4, 0x56, 0x46, 0x5b, 0x39, -0x9b, 0xb7, 0x3e, 0xe0, 0xd0, 0x87, 0x67, 0xf1, -0x3f, 0x09, 0xe1, 0xc7, 0xd2, 0x19, 0x78, 0xd6, -0xf1, 0xd7, 0xcf, 0xc1, 0xff, 0x58, 0xfe, 0x47, -0x56, 0x76, 0x40, 0xe2, 0xb6, 0x3a, 0xc9, 0x13, -0x31, 0x66, 0x5b, 0x31, 0x8e, 0x05, 0x21, 0x25, -0x79, 0xfb, 0x43, 0x2e, 0x0e, 0x3f, 0xa0, 0x55, -0xc5, 0xe5, 0x24, 0xb9, 0x60, 0xf4, 0x47, 0xca, -0xa5, 0x0f, 0xb7, 0xd5, 0xc7, 0x49, 0xff, 0x03, -0x22, 0x5a, 0xac, 0x93, 0xcd, 0x4f, 0x02, 0xfb, -0xd5, 0x6c, 0xe0, 0x65, 0xb9, 0xd9, 0xfa, 0x70, -0x2b, 0xde, 0x31, 0xfc, 0xd3, 0xc9, 0xd0, 0x8e, -0xbc, 0x8c, 0x9c, 0x62, 0xc0, 0x60, 0x41, 0xf4, -0xaf, 0x73, 0x7d, 0xbf, 0xe9, 0xfe, 0xd8, 0xdd, -0xdd, 0x77, 0xc3, 0x2f, 0x69, 0x7d, 0x38, 0xd0, -0x26, 0xbe, 0xa2, 0x30, 0xfc, 0x73, 0x5b, 0xc9, -0x06, 0x16, 0xcd, 0x3f, 0xee, 0x72, 0xea, 0xc3, -0x6d, 0xe7, 0xc3, 0x16, 0xec, 0x99, 0x31, 0x81, -0x45, 0x7f, 0x31, 0x43, 0x0d, 0x05, 0x39, 0xfd, -0x89, 0xad, 0x3e, 0xae, 0xeb, 0x59, 0xe5, 0x97, -0xf7, 0xd6, 0xc7, 0x3c, 0x89, 0xd6, 0x93, 0x0c, -0xff, 0xdc, 0xa8, 0xda, 0xc3, 0x56, 0xae, 0xf3, -0x61, 0x2b, 0x1e, 0xd3, 0xc4, 0xe9, 0x8b, 0x40, -0x5e, 0x4a, 0x12, 0xda, 0x26, 0x98, 0x5f, 0xe8, -0x42, 0x20, 0xc4, 0x36, 0x86, 0x8e, 0xf7, 0x77, -0xf6, 0x47, 0xda, 0x8a, 0x7a, 0x7b, 0x54, 0x7f, -0x3d, 0x82, 0xb2, 0xa8, 0x5c, 0xe3, 0xb5, 0xf5, -0x07, 0x60, 0xfb, 0xaf, 0x4e, 0x7d, 0x2e, 0x66, -0xe9, 0x74, 0xb6, 0xdb, 0x0a, 0x40, 0x4e, 0xfe, -0xd9, 0x81, 0x7f, 0x68, 0xbf, 0x5e, 0x47, 0x3d, -0x54, 0xd0, 0x91, 0x66, 0x0f, 0x7b, 0xe3, 0x42, -0xf6, 0x78, 0x6d, 0xe7, 0xc3, 0x0a, 0xbb, 0xc9, -0x05, 0xb6, 0xe9, 0x58, 0xd5, 0x85, 0xc7, 0x94, -0xb3, 0xf9, 0xa9, 0xcd, 0x35, 0x3f, 0xe9, 0xfe, -0xd8, 0x95, 0xca, 0x63, 0xdd, 0x2f, 0x03, 0xfb, -0xbe, 0x06, 0x59, 0x10, 0x7f, 0x9f, 0x7d, 0x8f, -0xa9, 0x7a, 0x1f, 0xaf, 0x23, 0xde, 0xd9, 0xf2, -0x23, 0xd2, 0xdf, 0xd0, 0x9e, 0x63, 0x35, 0x20, -0x77, 0x93, 0xdf, 0xe1, 0x69, 0x02, 0x6a, 0x71, -0xae, 0xf8, 0xe5, 0xec, 0x8f, 0xf4, 0x44, 0x87, -0x8f, 0xb2, 0xcf, 0xd0, 0xa7, 0x32, 0x20, 0xa4, -0x5e, 0x9d, 0xf3, 0x7e, 0x9b, 0x3e, 0x5c, 0xc2, -0x26, 0x24, 0xec, 0xff, 0x48, 0x3f, 0x5b, 0x48, -0xb5, 0x70, 0xf5, 0x42, 0x63, 0x5a, 0x86, 0xf2, -0xe8, 0xc3, 0xef, 0x5f, 0x09, 0x3f, 0x55, 0xb0, -0x3e, 0x45, 0x54, 0x91, 0x88, 0x60, 0xeb, 0x61, -0xc6, 0x7b, 0x5a, 0x56, 0xfd, 0x57, 0x5a, 0x1f, -0x55, 0x7e, 0x1e, 0x26, 0xab, 0x39, 0xda, 0x19, -0xa3, 0x3c, 0xbe, 0x9f, 0xc3, 0x63, 0x61, 0xfd, -0xfc, 0x58, 0xd8, 0x3c, 0xfa, 0x70, 0xac, 0xaf, -0x34, 0xd3, 0x5e, 0x7a, 0x71, 0xa2, 0xaa, 0x8e, -0x19, 0x9c, 0xff, 0x39, 0x07, 0x83, 0xb4, 0x65, -0x30, 0xab, 0x3f, 0xb6, 0xc1, 0xff, 0xa0, 0x50, -0x9c, 0x2e, 0x48, 0xc2, 0x76, 0x32, 0xb7, 0xe2, -0x30, 0xd4, 0x20, 0xec, 0xf9, 0x2d, 0x3c, 0x19, -0x59, 0x30, 0x98, 0xd5, 0x1f, 0xbb, 0x97, 0xa4, -0xce, 0x87, 0xc5, 0xb2, 0xd3, 0x22, 0x5a, 0x0a, -0xf0, 0xb0, 0x51, 0xa6, 0xbd, 0x1b, 0xcb, 0x11, -0x13, 0x59, 0xfd, 0xb1, 0x1d, 0xb3, 0x27, 0x47, -0x7d, 0x81, 0x78, 0x2f, 0x3f, 0x28, 0x84, 0x6d, -0x44, 0xad, 0xf3, 0x41, 0xcc, 0xbf, 0xaf, 0x5a, -0x6e, 0x83, 0xc1, 0x48, 0xd4, 0xdc, 0x5f, 0x20, -0x56, 0xc2, 0x84, 0xd1, 0xd1, 0x68, 0x80, 0x26, -0x84, 0xd4, 0xf9, 0x68, 0xe6, 0xf3, 0x1d, 0xfd, -0x01, 0x26, 0x59, 0xf4, 0x77, 0x8f, 0xfc, 0xe8, -0xa3, 0xd4, 0x15, 0xe1, 0x63, 0xf5, 0xb2, 0xd1, -0x28, 0x20, 0x7f, 0x7f, 0x48, 0xdd, 0x43, 0xf9, -0xc2, 0xe3, 0x34, 0xe3, 0xdb, 0xbc, 0x82, 0xc3, -0x93, 0xb3, 0x3f, 0xb6, 0xf1, 0xfe, 0x0b, 0xf4, -0xb6, 0x5d, 0x22, 0xb6, 0x05, 0x6b, 0x48, 0xe1, -0x61, 0x76, 0x05, 0xec, 0xf8, 0x47, 0xcf, 0x3c, -0x1f, 0x56, 0xae, 0x26, 0xcb, 0xb5, 0x19, 0x46, -0xe2, 0x46, 0xd3, 0xe2, 0x61, 0x43, 0x1f, 0x9e, -0xa7, 0x3f, 0x00, 0x83, 0x3d, 0xfe, 0xd5, 0xe4, -0xa4, 0x76, 0x20, 0x86, 0x1d, 0x14, 0x43, 0xaf, -0xc0, 0xd3, 0x5d, 0xf3, 0xb1, 0x5e, 0xde, 0x86, -0x7f, 0xb0, 0x3f, 0x40, 0x34, 0x80, 0xe7, 0xc7, -0x71, 0xb4, 0x33, 0xe2, 0xa9, 0x14, 0x5f, 0x18, -0x98, 0xa0, 0x1b, 0x30, 0xff, 0x35, 0x00, 0x1f, -0x48, 0x4d, 0x89, 0x40, 0xce, 0xfe, 0x00, 0x06, -0xec, 0x69, 0xfe, 0x4d, 0xed, 0x83, 0x33, 0x9e, -0x99, 0x9e, 0x9a, 0xb1, 0x61, 0x6d, 0x62, 0x75, -0x66, 0x7f, 0xc8, 0xf2, 0x51, 0x93, 0x1f, 0xe3, -0x13, 0x75, 0xc2, 0xbb, 0xbf, 0xf3, 0x9d, 0xfe, -0x89, 0x54, 0x7f, 0xf2, 0xee, 0x13, 0x7a, 0xdd, -0xb9, 0x29, 0xfa, 0x03, 0xe0, 0x7e, 0xea, 0x9b, -0xa1, 0x13, 0x9a, 0x71, 0xbe, 0x12, 0xf9, 0xd7, -0xd8, 0x53, 0xea, 0xf5, 0x27, 0xe4, 0xcc, 0xfe, -0x00, 0x3f, 0x71, 0xa0, 0x9d, 0xbf, 0x23, 0x1f, -0x75, 0xe1, 0x15, 0xd7, 0x06, 0xf2, 0x06, 0x3c, -0x4b, 0x2b, 0x51, 0x1f, 0x3e, 0x66, 0xf1, 0x3f, -0x6d, 0x52, 0xca, 0x7b, 0xc7, 0xcd, 0xaf, 0xa9, -0x29, 0x82, 0x07, 0x0d, 0xf3, 0xc6, 0x77, 0x83, -0x65, 0xbd, 0x72, 0x75, 0x46, 0x7f, 0x80, 0x82, -0xdd, 0xf0, 0x8e, 0x03, 0xed, 0xfc, 0x18, 0x0d, -0x81, 0xcb, 0xc2, 0xdf, 0xd6, 0x4e, 0xf6, 0xd7, -0xd1, 0xda, 0xfc, 0xfd, 0x21, 0x31, 0x11, 0x86, -0xc6, 0x76, 0xa1, 0x19, 0xa6, 0xb1, 0xf8, 0xcb, -0xfb, 0x43, 0x16, 0xe4, 0x39, 0x1f, 0xd6, 0x50, -0x83, 0x17, 0x6f, 0x47, 0x22, 0xc8, 0xaa, 0x17, -0xe3, 0xa9, 0x10, 0xe2, 0xc4, 0x3f, 0x46, 0x90, -0x15, 0x0d, 0xa3, 0xbb, 0x8f, 0xbc, 0x4f, 0x31, -0xc3, 0xc5, 0xc2, 0x2e, 0xdb, 0x91, 0xe9, 0x99, -0xf9, 0xaf, 0x72, 0x4b, 0x1f, 0x6e, 0x18, 0xf3, -0xf6, 0x62, 0x9b, 0x56, 0x06, 0x84, 0xb0, 0x9f, -0x2a, 0x0a, 0xc5, 0xf3, 0xf6, 0xc7, 0xe6, 0xf5, -0x62, 0x0c, 0x18, 0x84, 0x10, 0x06, 0xa8, 0x08, -0x84, 0x96, 0x09, 0xa9, 0x8a, 0xb9, 0x9c, 0xfd, -0xb1, 0xf1, 0x7c, 0xae, 0x66, 0xb9, 0x98, 0xb6, -0xc6, 0xa4, 0x71, 0x78, 0xd6, 0x8a, 0xbf, 0x28, -0x14, 0x3f, 0x6b, 0xef, 0x0f, 0xe0, 0x44, 0x3b, -0x2f, 0x47, 0x2b, 0x07, 0xc0, 0xa0, 0x7d, 0xd8, -0x95, 0x0f, 0x60, 0x8a, 0xfe, 0x90, 0xfc, 0x74, -0x54, 0x34, 0xe4, 0x0b, 0xc8, 0xff, 0xa4, 0xae, -0xb4, 0x79, 0x1c, 0xfc, 0x8f, 0xe2, 0xe4, 0x7f, -0x14, 0x99, 0x03, 0x21, 0xf0, 0xc1, 0xe7, 0x28, -0x19, 0x91, 0xb1, 0x51, 0x76, 0x76, 0x7f, 0x00, -0x5e, 0xfd, 0x17, 0x4a, 0xe3, 0x1f, 0x61, 0xaf, -0x9a, 0x46, 0x80, 0x37, 0xcb, 0x59, 0xfd, 0xb1, -0xed, 0xe8, 0x91, 0xa7, 0xbd, 0xf6, 0xb2, 0xf9, -0x2f, 0xe2, 0x57, 0xa8, 0xd1, 0x1f, 0x32, 0xcd, -0xff, 0x94, 0x65, 0xf0, 0x39, 0x0f, 0x30, 0xa3, -0xeb, 0x02, 0x3c, 0x8d, 0xef, 0xff, 0xe6, 0xe7, -0x2e, 0x84, 0x67, 0x63, 0x22, 0x2f, 0xcd, 0xff, -0xec, 0x06, 0xc7, 0xfd, 0x4d, 0x5a, 0x49, 0xb4, -0x6a, 0x98, 0x66, 0xe2, 0xe1, 0xcc, 0xf3, 0xd1, -0x6c, 0x68, 0x73, 0x6b, 0x87, 0x78, 0x86, 0x5a, -0x1d, 0xb3, 0xc7, 0x8d, 0x83, 0xd2, 0x6c, 0xfd, -0x01, 0xa4, 0x0c, 0xfe, 0x47, 0xde, 0x43, 0xde, -0xa5, 0x68, 0x30, 0x84, 0xff, 0x0e, 0x1c, 0x52, -0x79, 0x7f, 0xb9, 0x74, 0x7d, 0x9c, 0xdf, 0xd9, -0x9f, 0x84, 0x7d, 0x2f, 0x8d, 0xd2, 0xcb, 0xf0, -0xb0, 0x10, 0xd0, 0x85, 0x20, 0xf9, 0x82, 0xd2, -0x4b, 0x3d, 0xe8, 0x7f, 0xd2, 0xfc, 0x8f, 0x43, -0x1f, 0x6e, 0xf6, 0x77, 0x85, 0x03, 0x41, 0x7e, -0xe5, 0x9f, 0x19, 0x3e, 0xe6, 0x57, 0xd2, 0xfc, -0x8f, 0xdf, 0xde, 0x1f, 0xf2, 0x00, 0x6d, 0x4a, -0x7a, 0x57, 0x8b, 0xa7, 0x85, 0x8f, 0x77, 0xf3, -0x2b, 0x27, 0xe1, 0x6f, 0x69, 0xcb, 0x48, 0x20, -0xbb, 0x3f, 0x80, 0xcd, 0xdf, 0x2e, 0xf8, 0x1e, -0x5b, 0xc6, 0xd8, 0x78, 0x84, 0xf9, 0x93, 0x61, -0x3a, 0xa1, 0x35, 0x1f, 0xf1, 0x66, 0x9c, 0x8f, -0x66, 0x80, 0x9c, 0x0b, 0x29, 0xb4, 0xe3, 0x19, -0x65, 0x61, 0x2b, 0x05, 0x7b, 0x26, 0x61, 0x52, -0x6f, 0x79, 0xd3, 0x11, 0xbf, 0x76, 0x9b, 0xfe, -0xe7, 0x2e, 0xe3, 0xfd, 0x93, 0xdd, 0x77, 0x1b, -0x65, 0xfb, 0x03, 0xee, 0x6f, 0x90, 0xdf, 0xd0, -0xa7, 0xd1, 0xc3, 0x64, 0xe2, 0x1f, 0xc7, 0x78, -0xdb, 0x42, 0x85, 0x27, 0xd4, 0xd4, 0x95, 0x13, -0xf4, 0x29, 0x82, 0x8c, 0x90, 0x0d, 0xff, 0x84, -0xcb, 0x32, 0xd0, 0x8e, 0x5c, 0xc1, 0x76, 0xf7, -0xa9, 0x0a, 0x20, 0xb6, 0xde, 0x64, 0x03, 0x4f, -0xe6, 0xd1, 0x87, 0x63, 0x34, 0xe9, 0xeb, 0x3c, -0x2b, 0x4d, 0x9a, 0xf5, 0x80, 0x17, 0x84, 0x16, -0xec, 0xaf, 0x7b, 0xda, 0xde, 0x1f, 0xc0, 0xc9, -0xff, 0x2c, 0xd8, 0x35, 0xe3, 0x3d, 0xf3, 0x09, -0x6f, 0xc3, 0x38, 0x4d, 0xe1, 0x1f, 0xf3, 0xf9, -0x19, 0xfd, 0x01, 0x9a, 0x74, 0xcf, 0x07, 0x9d, -0xe3, 0xaa, 0x75, 0x0c, 0xc4, 0x95, 0x23, 0x2d, -0x48, 0x04, 0xa5, 0xf9, 0x9f, 0x8c, 0xf3, 0x61, -0x59, 0xfc, 0x8d, 0x91, 0x33, 0xb0, 0xc4, 0xb8, -0xf2, 0x36, 0x1c, 0x0a, 0xd7, 0xea, 0x33, 0x9d, -0xf8, 0x27, 0xf3, 0x7e, 0xca, 0xfe, 0x5e, 0xa9, -0xfa, 0xb8, 0xe1, 0x18, 0xfb, 0x82, 0xf4, 0xd6, -0x78, 0x69, 0x86, 0x3e, 0x5c, 0x33, 0xfa, 0x43, -0xe2, 0xfc, 0x9c, 0x90, 0x09, 0x9b, 0x16, 0x63, -0xc6, 0x4a, 0x75, 0x1a, 0x37, 0x0e, 0x4a, 0x73, -0xd6, 0xc7, 0xf1, 0xd3, 0x39, 0x53, 0xe3, 0x3d, -0xc9, 0x56, 0xfb, 0xdb, 0x78, 0x10, 0xf9, 0xab, -0x7c, 0x98, 0xe3, 0xbc, 0x51, 0x80, 0x98, 0x74, -0xf6, 0x47, 0xc2, 0xd1, 0xed, 0xaf, 0xe2, 0xf1, -0x2b, 0xb1, 0xa0, 0x43, 0x1c, 0x8b, 0xa5, 0x14, -0xe3, 0x49, 0x6d, 0xdc, 0x10, 0x72, 0xd8, 0xf1, -0xcf, 0x2b, 0xf0, 0x91, 0xba, 0x88, 0x06, 0x6c, -0x68, 0x79, 0x2a, 0xfe, 0x87, 0x2a, 0x6f, 0xc2, -0x73, 0x7a, 0xd5, 0x58, 0x1b, 0x67, 0x7b, 0xc0, -0x79, 0x2c, 0x48, 0xce, 0xf3, 0x41, 0x58, 0xbc, -0x57, 0xe6, 0x76, 0xe5, 0xa4, 0x7d, 0x72, 0x9e, -0x0f, 0x32, 0x57, 0x62, 0xde, 0x3b, 0xb7, 0xec, -0x27, 0xd7, 0xf9, 0xb0, 0xe5, 0xbf, 0xa5, 0x13, -0xbb, 0x1a, 0xda, 0x73, 0xd2, 0x3e, 0x39, 0xce, -0x87, 0x4d, 0x0a, 0xfb, 0x61, 0x32, 0xda, 0xd8, -0x96, 0x93, 0xf6, 0x49, 0x9f, 0x0f, 0x62, 0xd3, -0xff, 0xc4, 0xc2, 0x47, 0xa1, 0xb4, 0x3d, 0xa7, -0xec, 0x27, 0x27, 0xff, 0xf3, 0x29, 0xe8, 0xe8, -0xbe, 0x3e, 0x3c, 0xf5, 0xfb, 0xdb, 0xce, 0x87, -0x15, 0xbe, 0x40, 0xe8, 0x6d, 0x6a, 0x41, 0x4e, -0xda, 0x27, 0xf7, 0xf9, 0x20, 0xca, 0x46, 0x3a, -0x27, 0xe8, 0x4a, 0x9d, 0x06, 0x92, 0xc4, 0x46, -0xaf, 0x53, 0xea, 0x7f, 0x64, 0x38, 0x02, 0x41, -0x85, 0xb7, 0x05, 0xf8, 0x10, 0x66, 0x8d, 0x78, -0x1b, 0xd1, 0x10, 0x9a, 0xfa, 0xf3, 0xe8, 0x7f, -0x8a, 0xfb, 0xd8, 0xfc, 0xb4, 0xa8, 0xd7, 0x8e, -0x99, 0xb4, 0xcf, 0x07, 0x9c, 0x08, 0x72, 0xce, -0x8f, 0xbd, 0x3f, 0x12, 0x5b, 0x84, 0xae, 0xba, -0x23, 0xa9, 0xf9, 0x6f, 0x4c, 0xae, 0x8c, 0xb7, -0x9e, 0x85, 0xcc, 0xf3, 0x53, 0x9c, 0xf8, 0xe7, -0x29, 0xa8, 0xd4, 0x8b, 0xd1, 0x9f, 0x3c, 0x67, -0xa4, 0xbd, 0x2e, 0xc1, 0xbf, 0x64, 0xe9, 0x7f, -0xcc, 0xe7, 0xf7, 0xc3, 0x43, 0xb0, 0x8f, 0xde, -0x96, 0xe4, 0x7c, 0xd7, 0x73, 0x74, 0x1e, 0x1a, -0x57, 0xb0, 0x2c, 0xce, 0x31, 0x5e, 0x5b, 0x7f, -0xa4, 0x6d, 0xc7, 0xa1, 0x37, 0x1c, 0x1e, 0x9b, -0x97, 0xea, 0xf7, 0xa2, 0x43, 0xae, 0x7e, 0x0b, -0xf6, 0xfe, 0x48, 0x7d, 0x70, 0x45, 0xeb, 0xc5, -0xfe, 0x90, 0x88, 0x7f, 0x1a, 0x29, 0x37, 0x96, -0x67, 0xf0, 0x3f, 0x69, 0xfc, 0xb3, 0x1c, 0x92, -0xfa, 0x18, 0x34, 0x95, 0x5a, 0xf1, 0x28, 0xa7, -0x1e, 0xc3, 0xce, 0xff, 0xbc, 0xa9, 0x1d, 0x55, -0xf7, 0x99, 0x6a, 0x96, 0xba, 0xdc, 0xfb, 0x7d, -0x7b, 0xfe, 0xeb, 0x26, 0xd8, 0xac, 0xee, 0xbc, -0xd9, 0x50, 0x9b, 0x10, 0x9f, 0x11, 0x88, 0x1f, -0x9d, 0xf2, 0x7c, 0x90, 0xcd, 0x82, 0x2f, 0x1d, -0xa6, 0x3f, 0xb1, 0x3f, 0x40, 0x21, 0xf6, 0x87, -0x34, 0xf9, 0x90, 0x58, 0x46, 0x62, 0x28, 0x4b, -0xff, 0xd3, 0xc7, 0xf0, 0x4f, 0x42, 0xdd, 0x27, -0x07, 0x8c, 0xd1, 0xd5, 0xe1, 0xe9, 0x6f, 0xd9, -0xe3, 0xb5, 0x9f, 0x0f, 0x7b, 0x9e, 0x5c, 0x46, -0xfd, 0x0f, 0x1f, 0x1d, 0xef, 0x86, 0x34, 0x23, -0x7b, 0xbc, 0x69, 0xfc, 0xb3, 0x5d, 0x38, 0x0f, -0xef, 0x75, 0xd7, 0xaf, 0x4d, 0xa1, 0x9d, 0xda, -0xf6, 0x9c, 0xf3, 0xe3, 0xec, 0x8f, 0x8d, 0x6d, -0x91, 0xba, 0x39, 0xfe, 0x51, 0x03, 0x82, 0x9d, -0xf6, 0xc9, 0x79, 0x3e, 0xc8, 0x0b, 0xb0, 0x03, -0xaa, 0x97, 0xad, 0x56, 0x4a, 0x79, 0xf4, 0xe1, -0xc3, 0x14, 0xb2, 0xf9, 0x2e, 0x1b, 0xfe, 0x91, -0x0e, 0xaa, 0x73, 0x1d, 0x6a, 0x9f, 0x1c, 0xf3, -0x99, 0xe6, 0x7f, 0xbe, 0xfb, 0x7b, 0x78, 0x1b, -0x7e, 0xcc, 0xfe, 0xbe, 0xa1, 0x29, 0xf8, 0x1c, -0x5b, 0x7f, 0xc8, 0xa5, 0xd5, 0xea, 0x07, 0x74, -0x71, 0x28, 0xe7, 0x6d, 0x39, 0xf0, 0x4f, 0x4d, -0xea, 0x7c, 0x58, 0x8f, 0x39, 0xff, 0x9e, 0x5c, -0xf3, 0x6f, 0xd7, 0xff, 0x2c, 0x66, 0xd8, 0xb4, -0x8a, 0xa6, 0x68, 0x9f, 0x3a, 0xea, 0x8a, 0xd5, -0x4d, 0xd5, 0x1f, 0xc0, 0x5f, 0xb0, 0x4c, 0xeb, -0xa5, 0xfe, 0x32, 0x0b, 0xff, 0xe4, 0x74, 0xd4, -0xe9, 0xf3, 0x61, 0x63, 0x42, 0x05, 0x8b, 0x5f, -0xf3, 0x84, 0x22, 0xfc, 0x5a, 0x17, 0xd1, 0x4a, -0xc7, 0xb1, 0x1a, 0x69, 0xfd, 0xcf, 0x32, 0xf3, -0xf9, 0xbb, 0xe5, 0x6b, 0x18, 0xfe, 0xe9, 0x53, -0xe7, 0x6f, 0xa8, 0x3a, 0x0d, 0x93, 0x7b, 0x3e, -0x73, 0xde, 0x93, 0xb3, 0x3f, 0x80, 0xd5, 0x9f, -0x44, 0x2e, 0xde, 0x8d, 0xa2, 0x0e, 0x8b, 0x66, -0x3f, 0x61, 0xf0, 0x3f, 0x66, 0x07, 0xe9, 0xd7, -0x21, 0xe3, 0x7c, 0x10, 0xbd, 0xe0, 0x9c, 0x36, -0x11, 0xfd, 0x46, 0x75, 0xc9, 0x78, 0xd5, 0x59, -0x6d, 0x72, 0x7b, 0xcb, 0x70, 0x49, 0x5f, 0x8e, -0xfe, 0x36, 0xf6, 0xf3, 0x61, 0xa3, 0xeb, 0x37, -0x45, 0x2b, 0x1f, 0x63, 0xfe, 0xe7, 0x38, 0x1c, -0x88, 0xd6, 0x26, 0xe5, 0x46, 0x74, 0xa4, 0x71, -0x0e, 0x7b, 0x72, 0xf1, 0x3f, 0xda, 0x5e, 0x6d, -0x87, 0x5a, 0xc9, 0x69, 0x6a, 0x7a, 0x80, 0xed, -0x5e, 0xf1, 0x3c, 0x14, 0x7a, 0xa0, 0xc0, 0x39, -0xde, 0xb4, 0xde, 0x46, 0x2d, 0xd3, 0xb0, 0xfb, -0x71, 0xf4, 0xea, 0xa0, 0x71, 0x3e, 0x23, 0x56, -0xc3, 0xb1, 0x1d, 0x59, 0xde, 0xfe, 0x00, 0x6b, -0xcb, 0xff, 0x09, 0x7e, 0x87, 0x85, 0x62, 0x18, -0x1d, 0xd0, 0xbb, 0x96, 0xf0, 0x7a, 0x7f, 0xc9, -0xe9, 0x3f, 0xed, 0xe7, 0xc3, 0x8e, 0x20, 0xcd, -0x1e, 0xc2, 0x5f, 0xa5, 0x09, 0x21, 0x4f, 0x3c, -0x4a, 0xe3, 0x1f, 0x5d, 0x61, 0x20, 0x47, 0xee, -0xcd, 0x4d, 0xfb, 0xd8, 0xf8, 0x9f, 0x34, 0xfe, -0xf9, 0x6b, 0x38, 0x1c, 0xf6, 0xa5, 0xe2, 0x97, -0x90, 0x2f, 0xfe, 0xda, 0xf0, 0x0f, 0x1e, 0x0b, -0xe2, 0x0b, 0xa7, 0xd2, 0x34, 0x7f, 0x9d, 0xfb, -0x7e, 0xbb, 0xfe, 0x07, 0x94, 0xc3, 0xb2, 0xaa, -0xd5, 0x04, 0xc9, 0x4b, 0xb4, 0x57, 0xf5, 0x0c, -0xe0, 0xc1, 0xe8, 0xb2, 0x79, 0x42, 0x4d, 0x36, -0xff, 0x43, 0x8b, 0x79, 0x7f, 0x12, 0xad, 0x04, -0xcf, 0xcb, 0x9b, 0x54, 0x97, 0xf0, 0xfe, 0x33, -0x5d, 0x13, 0x55, 0xce, 0x46, 0x34, 0xf6, 0xfe, -0x48, 0x43, 0x38, 0x28, 0x3e, 0x5e, 0xec, 0x86, -0x3d, 0xe0, 0x3d, 0x2f, 0x8e, 0x26, 0x27, 0xcb, -0x9c, 0xf9, 0x8b, 0x5c, 0xfa, 0x9f, 0x94, 0xec, -0xf9, 0xe5, 0xed, 0x55, 0xcd, 0xcc, 0xa8, 0x4f, -0x7a, 0x93, 0x6c, 0x1a, 0x4f, 0xa8, 0x75, 0xb2, -0xf7, 0x15, 0x5b, 0x7f, 0x6c, 0xae, 0xff, 0xa1, -0x77, 0xd8, 0xd0, 0xce, 0x76, 0xf8, 0x19, 0x33, -0x6a, 0x92, 0xee, 0x3d, 0xe4, 0x7d, 0xed, 0xa7, -0xd1, 0x9a, 0x31, 0x66, 0xc4, 0xd3, 0xe7, 0xc3, -0x66, 0xe9, 0x7f, 0xf0, 0xfc, 0x2f, 0x6c, 0xd3, -0xe7, 0xae, 0x24, 0xba, 0x42, 0x41, 0x95, 0xdc, -0xd3, 0x49, 0x5d, 0x0e, 0xfd, 0x4f, 0x68, 0x1d, -0x36, 0x9e, 0xea, 0x5f, 0xb1, 0x37, 0x75, 0x50, -0x88, 0x3b, 0xf6, 0x90, 0xd1, 0x6f, 0x9c, 0x7d, -0xbf, 0x71, 0x6b, 0x3d, 0x2c, 0xe5, 0xfc, 0x8f, -0xd9, 0x4f, 0x0c, 0x97, 0x4d, 0x05, 0x4f, 0xc4, -0xd4, 0xe1, 0xc1, 0xf7, 0x63, 0x80, 0x1a, 0x10, -0xef, 0x90, 0xb8, 0xd0, 0xf2, 0x3f, 0x71, 0x27, -0xff, 0xc3, 0x8c, 0x13, 0xa6, 0x91, 0x14, 0x53, -0x47, 0xcd, 0xc6, 0x9c, 0xe7, 0xc3, 0x9a, 0x22, -0xab, 0x14, 0xd1, 0x14, 0x4d, 0xc9, 0xae, 0x3c, -0xbb, 0x44, 0x5d, 0xd1, 0xd1, 0x23, 0x29, 0x8e, -0xfe, 0xd8, 0x99, 0xfa, 0x9f, 0x68, 0xca, 0x28, -0x8e, 0x11, 0xfc, 0x7e, 0x1b, 0xfa, 0x8b, 0x63, -0xe2, 0xff, 0x9a, 0x42, 0xff, 0xa3, 0x30, 0xe3, -0xb0, 0xe1, 0x88, 0x74, 0xa3, 0xe0, 0x41, 0xb1, -0xf5, 0xc7, 0xb6, 0xf4, 0x3f, 0x56, 0xda, 0x6b, -0xb5, 0x91, 0x08, 0xe3, 0x7a, 0x18, 0xe5, 0x91, -0xd8, 0x1c, 0xec, 0x8f, 0xbd, 0x21, 0x5b, 0xff, -0x83, 0x68, 0xa7, 0x17, 0x9a, 0x46, 0xdc, 0x4b, -0x0a, 0x07, 0x35, 0x3c, 0xaf, 0xc7, 0x13, 0x14, -0x8f, 0x80, 0x1e, 0x0b, 0xaa, 0xec, 0xfd, 0x6d, -0xfd, 0xb1, 0xcb, 0x9f, 0x01, 0xdb, 0xf9, 0xb9, -0x46, 0x7f, 0x6c, 0x63, 0x06, 0x3e, 0x30, 0xcf, -0x17, 0x1e, 0xb1, 0xe7, 0xbf, 0x9c, 0xfa, 0x1f, -0xbe, 0x4d, 0xdb, 0x63, 0x74, 0xb0, 0xef, 0x13, -0x55, 0x38, 0x41, 0x1b, 0xc0, 0x1b, 0x75, 0xd7, -0xe4, 0xd5, 0xff, 0xd8, 0x0c, 0x43, 0x28, 0x58, -0x89, 0xe7, 0x33, 0xd6, 0x55, 0x9b, 0xcf, 0x57, -0xb5, 0x1f, 0xca, 0x99, 0xe8, 0xce, 0x32, 0x4a, -0x61, 0x1b, 0x9d, 0xa3, 0xba, 0x2b, 0x88, 0x9a, -0xee, 0xbf, 0xe4, 0xac, 0xcf, 0x0d, 0xe8, 0x3d, -0x41, 0x9e, 0x8f, 0x0e, 0x98, 0xcf, 0xe7, 0xe7, -0x0f, 0x96, 0x5a, 0xe7, 0xa3, 0x25, 0xcb, 0x47, -0xf0, 0xfc, 0xf7, 0xf4, 0xf9, 0x20, 0xde, 0xdd, -0x16, 0xec, 0x71, 0xfb, 0xe1, 0xa4, 0xa1, 0xff, -0x59, 0x9c, 0x43, 0xff, 0x33, 0x23, 0x15, 0x7d, -0x3a, 0xd2, 0x61, 0x68, 0x0c, 0x2e, 0x49, 0x2d, -0xe0, 0xd5, 0xa6, 0xea, 0x0f, 0x50, 0x90, 0x2a, -0x7b, 0x37, 0xea, 0xc1, 0xdf, 0x36, 0x84, 0xb2, -0x91, 0x2c, 0xfd, 0xcf, 0xcc, 0x28, 0xd8, 0xc2, -0xee, 0x6b, 0x66, 0xfe, 0x25, 0x55, 0x9f, 0xae, -0xda, 0xf5, 0x3f, 0xd2, 0x0d, 0xf6, 0xee, 0x3d, -0x45, 0x56, 0x7d, 0x6e, 0x94, 0x9c, 0x87, 0x7f, -0xc4, 0x13, 0xe8, 0x86, 0xc8, 0xbd, 0x19, 0xfa, -0x1f, 0x67, 0xf4, 0x1f, 0x4e, 0x09, 0x81, 0x22, -0xaf, 0xc6, 0x36, 0xd6, 0xce, 0x5f, 0xee, 0xbf, -0xf9, 0x08, 0x71, 0xe8, 0x7f, 0x78, 0x1b, 0x4c, -0x33, 0xda, 0x16, 0xa3, 0x91, 0x30, 0x84, 0x40, -0xd8, 0x28, 0xb2, 0x59, 0xf6, 0x1c, 0x11, 0x1f, -0x48, 0xf3, 0x3f, 0x59, 0x7a, 0x98, 0xa1, 0xcc, -0xf8, 0x3e, 0x2d, 0x2a, 0x4e, 0xa5, 0xff, 0x49, -0x0b, 0x81, 0xc4, 0x35, 0xf4, 0xa8, 0x5a, 0x17, -0x2a, 0x8e, 0x76, 0xde, 0x64, 0xe9, 0x0f, 0xb3, -0xf4, 0x3f, 0x56, 0x7f, 0xa4, 0x99, 0x5d, 0xbe, -0x4a, 0x14, 0x02, 0x29, 0x72, 0x17, 0x99, 0x6d, -0xcd, 0xbf, 0x43, 0xff, 0x63, 0x1a, 0x12, 0x67, -0x84, 0xa6, 0x93, 0x65, 0x5a, 0x87, 0x56, 0xad, -0x15, 0x29, 0x24, 0x34, 0x85, 0xfe, 0x67, 0x3b, -0x33, 0x9e, 0x30, 0x19, 0x36, 0x9c, 0x58, 0x36, -0xc3, 0x85, 0xb9, 0xcf, 0x87, 0xb5, 0x0c, 0x6c, -0x8b, 0x84, 0x0c, 0x9e, 0x82, 0x1d, 0xd1, 0x99, -0xc7, 0x58, 0x6b, 0xcb, 0x7f, 0x4d, 0xd1, 0x2f, -0x62, 0x80, 0x7c, 0x00, 0x87, 0xb4, 0x12, 0xc5, -0x91, 0xff, 0xca, 0xd2, 0xff, 0x98, 0x06, 0xf0, -0x3f, 0xc4, 0x62, 0x58, 0x49, 0x67, 0xb8, 0x6c, -0xf9, 0xaf, 0xdd, 0x59, 0x68, 0xc7, 0x66, 0xf0, -0x46, 0x91, 0x31, 0xe2, 0x52, 0xac, 0xf5, 0x90, -0x43, 0x7f, 0x98, 0x36, 0x48, 0x27, 0xf8, 0x75, -0x7f, 0xd0, 0xe5, 0xb2, 0xfc, 0x8f, 0x4d, 0xff, -0x93, 0x0d, 0x7b, 0x4e, 0xf1, 0xef, 0x97, 0x41, -0x05, 0xbf, 0xb5, 0xde, 0xba, 0xbb, 0xbf, 0xa2, -0xd8, 0xd0, 0xce, 0xb5, 0x0e, 0xd8, 0x73, 0x1c, -0x7e, 0x49, 0x17, 0x27, 0x3d, 0x8b, 0xc5, 0x1a, -0xf3, 0xf5, 0xb3, 0xf5, 0x3f, 0x39, 0x0d, 0xdb, -0xf9, 0xb0, 0x66, 0x7f, 0x00, 0xb3, 0x2d, 0xd2, -0xaa, 0xf1, 0x19, 0x57, 0xe4, 0x54, 0xfe, 0x22, -0x9d, 0xff, 0x4a, 0xf3, 0x6f, 0xca, 0x63, 0x9a, -0xfd, 0xb5, 0xf1, 0x34, 0x10, 0xc4, 0x3f, 0x46, -0xa3, 0xa7, 0xf0, 0x81, 0x0a, 0x03, 0xff, 0xa4, -0xcf, 0x87, 0xa5, 0x39, 0xfc, 0x15, 0x03, 0x42, -0xce, 0xc6, 0x50, 0xf6, 0xfe, 0xd8, 0xd9, 0xfa, -0x1f, 0x34, 0xf8, 0x09, 0x50, 0x2f, 0x21, 0xf5, -0x71, 0x9e, 0x45, 0xfc, 0x4c, 0xfd, 0x8f, 0x35, -0x3a, 0x0c, 0x64, 0xa5, 0xc8, 0xf0, 0xf0, 0x88, -0xf3, 0x3e, 0x4c, 0x74, 0xdd, 0x3d, 0xe4, 0x7d, -0xd6, 0xde, 0x1f, 0x3b, 0x53, 0xff, 0xb3, 0x35, -0x3e, 0x03, 0x8d, 0xd9, 0xfc, 0x0a, 0xfd, 0x50, -0x66, 0xc0, 0x60, 0x5f, 0x0e, 0xfd, 0x8f, 0x3d, -0xfa, 0xdb, 0xae, 0xb4, 0xc0, 0x42, 0xdd, 0x63, -0xc7, 0x3f, 0x3b, 0x32, 0xf9, 0x1f, 0x77, 0xbc, -0x70, 0xd4, 0x3a, 0x31, 0x44, 0x4a, 0x75, 0x2c, -0x74, 0xea, 0x7f, 0x32, 0xee, 0xf7, 0x39, 0xf0, -0x8f, 0x2f, 0xe3, 0x7c, 0x90, 0xb4, 0xfe, 0x87, -0xcf, 0x0f, 0x6f, 0x8b, 0x44, 0xcd, 0x46, 0xbe, -0x32, 0xef, 0xe8, 0x92, 0xa1, 0x7f, 0x96, 0xd3, -0xe3, 0x15, 0xee, 0x1e, 0x5c, 0xb5, 0xbf, 0x75, -0x0f, 0xea, 0x9f, 0xf9, 0x15, 0x6d, 0xa2, 0xbd, -0xee, 0xd5, 0x2d, 0x76, 0xfc, 0xb3, 0xb3, 0xdc, -0x89, 0xee, 0x5e, 0xea, 0x39, 0xd7, 0xf9, 0x1e, -0x3f, 0x31, 0x16, 0xaf, 0xf0, 0x46, 0x49, 0xf9, -0xce, 0x47, 0xbb, 0x43, 0xb0, 0x16, 0xd2, 0xdf, -0x4d, 0x51, 0xff, 0x75, 0xb6, 0x28, 0x83, 0xed, -0xb9, 0x6a, 0x6a, 0xfe, 0x27, 0xbd, 0x0c, 0x2a, -0xd2, 0x03, 0x27, 0xeb, 0xf2, 0xf2, 0x3f, 0xe9, -0xfc, 0x97, 0xf4, 0x07, 0xf0, 0x3f, 0xd8, 0x1f, -0xfb, 0xb0, 0x89, 0x96, 0x0d, 0x21, 0x74, 0x8e, -0xfa, 0xa3, 0x3c, 0xfd, 0xb1, 0xf3, 0xf3, 0x3f, -0xf9, 0xf3, 0x5f, 0xc6, 0x36, 0x24, 0xa3, 0x5f, -0x59, 0x8e, 0xfe, 0xd8, 0xfb, 0xec, 0xaf, 0x3d, -0xf5, 0xf9, 0xb0, 0xd9, 0xdf, 0x8b, 0xc1, 0x57, -0x14, 0xe6, 0xe6, 0x7f, 0x6c, 0xdd, 0x20, 0x0d, -0x03, 0xf9, 0x90, 0xe2, 0xbc, 0xfc, 0x0f, 0x3f, -0x1f, 0x0d, 0xd9, 0x9e, 0xe3, 0xfa, 0x87, 0x94, -0x97, 0x7d, 0x9d, 0xd5, 0x7f, 0x1d, 0xcf, 0x5f, -0xff, 0xf5, 0x87, 0xcc, 0x4f, 0x8e, 0xfe, 0xd8, -0x8b, 0xc5, 0x29, 0x1c, 0x57, 0xce, 0xfc, 0xd7, -0xac, 0xfc, 0x8e, 0xd4, 0x9e, 0xff, 0xb2, 0xf2, -0x7d, 0x99, 0x42, 0xe8, 0xdc, 0xfc, 0x4f, 0x99, -0xd5, 0x16, 0xdb, 0x93, 0xdf, 0xb1, 0xe7, 0xea, -0x8f, 0x4d, 0xb2, 0x1a, 0x65, 0xe7, 0xe2, 0x7f, -0x1c, 0xf9, 0xaf, 0xc5, 0xe9, 0x78, 0x54, 0x9b, -0x97, 0xff, 0x49, 0x45, 0x37, 0x3c, 0xf6, 0x1d, -0xd3, 0x5e, 0xee, 0x4f, 0xe2, 0x7f, 0xb2, 0xf4, -0xcf, 0x53, 0xf7, 0x87, 0xb4, 0xf7, 0x47, 0x9a, -0xa2, 0x3f, 0xa4, 0xb9, 0x1e, 0x9c, 0xfd, 0x91, -0xf2, 0x19, 0x39, 0xf3, 0x5f, 0x38, 0xba, 0xd9, -0xb9, 0xf5, 0x3f, 0x79, 0xcf, 0x47, 0xcb, 0x63, -0x38, 0xf3, 0x5f, 0xaf, 0x19, 0x30, 0xe9, 0x3c, -0x87, 0x85, 0xc5, 0x46, 0x5b, 0xec, 0x0c, 0xfe, -0x27, 0x8d, 0x7f, 0x8c, 0xfc, 0x17, 0xa7, 0x7d, -0x48, 0x37, 0xc7, 0x3f, 0x2e, 0x35, 0x65, 0xe4, -0x39, 0x1f, 0x36, 0xcd, 0x6e, 0x61, 0x37, 0xa4, -0x22, 0x2e, 0xf3, 0x9e, 0x8a, 0xff, 0xb1, 0xb7, -0x79, 0xb1, 0x60, 0xcf, 0x54, 0xe7, 0xc3, 0x1a, -0x22, 0x6d, 0x62, 0xc0, 0xda, 0x22, 0x2e, 0x6b, -0xcf, 0xcf, 0xff, 0xd8, 0xf1, 0xcf, 0x6b, 0x79, -0xf9, 0x9f, 0xbc, 0xe7, 0xa3, 0x99, 0x46, 0x43, -0x5e, 0xfd, 0x4f, 0x2a, 0xff, 0xb5, 0x9b, 0x24, -0x0c, 0x23, 0x6c, 0x1a, 0xf9, 0xcf, 0x87, 0xc5, -0x8f, 0xa2, 0xc2, 0xfc, 0x3a, 0xd4, 0x74, 0xbc, -0xb6, 0xe9, 0x7f, 0xd2, 0xfc, 0x4f, 0xea, 0xb3, -0xbd, 0x25, 0xf5, 0xb5, 0x8a, 0xe1, 0x9c, 0xfa, -0x1f, 0xf3, 0xf9, 0xbc, 0x3f, 0x76, 0xc7, 0x8d, -0x67, 0x30, 0xed, 0x05, 0x1f, 0x47, 0x18, 0xec, -0x59, 0xcb, 0xf1, 0xcf, 0x67, 0x50, 0xff, 0x9c, -0xe7, 0x7c, 0x58, 0x0e, 0x03, 0xa2, 0xa6, 0xf7, -0x88, 0xf1, 0xc0, 0x97, 0x81, 0x7f, 0x1c, 0xe7, -0xc3, 0xa6, 0xf2, 0x5f, 0x67, 0xe5, 0x7b, 0xd0, -0x18, 0x11, 0xf1, 0x7c, 0xd8, 0x25, 0x8e, 0xfe, -0x90, 0x7a, 0x66, 0xfe, 0x6b, 0xc0, 0xdd, 0xce, -0xbc, 0x07, 0x1f, 0x5d, 0x98, 0x94, 0xd0, 0xcc, -0xf7, 0xcf, 0x91, 0xff, 0x6a, 0xbf, 0x2a, 0x65, -0x18, 0x85, 0xab, 0xf3, 0xf4, 0x9e, 0x3c, 0xf8, -0x87, 0xd3, 0x3e, 0x7c, 0x1b, 0x2b, 0x18, 0xf3, -0xe9, 0xca, 0x76, 0x44, 0xce, 0xf3, 0xd1, 0x78, -0xd8, 0x8a, 0x8a, 0xc6, 0xc0, 0xff, 0x22, 0x16, -0x0a, 0x28, 0x13, 0xd2, 0x35, 0x6c, 0x98, 0x7f, -0x6a, 0xd3, 0xff, 0x98, 0xef, 0x63, 0xf5, 0xc7, -0x76, 0xcc, 0x4f, 0x46, 0x05, 0x50, 0xae, 0xfc, -0xd7, 0x10, 0xf7, 0xde, 0x4b, 0x70, 0x9b, 0x3f, -0x35, 0xff, 0x93, 0xc2, 0x3f, 0xd1, 0xd2, 0x54, -0xb4, 0x8a, 0xd9, 0x03, 0xd9, 0xbb, 0xb9, 0xf4, -0x3f, 0x4e, 0xfd, 0x73, 0xec, 0x13, 0xf8, 0x1f, -0x8f, 0xa1, 0xb6, 0x52, 0x42, 0x83, 0x46, 0x22, -0x8c, 0xad, 0xb7, 0xca, 0xd4, 0x46, 0x75, 0x90, -0x2b, 0x64, 0xb2, 0xea, 0xbf, 0xde, 0xd5, 0xf8, -0x78, 0xdf, 0xc3, 0xec, 0xe7, 0x90, 0x3b, 0xf6, -0xa7, 0xef, 0x9d, 0x60, 0xc6, 0x40, 0x3e, 0xfe, -0x27, 0x3d, 0xde, 0x24, 0x43, 0x3b, 0xc7, 0x8c, -0x42, 0x66, 0x53, 0xff, 0xf3, 0x7e, 0x2e, 0xfd, -0xcf, 0xfb, 0x19, 0x68, 0xf9, 0x2c, 0xbc, 0x1e, -0x31, 0x80, 0x90, 0xfc, 0x5c, 0x0e, 0xfc, 0x93, -0x85, 0x76, 0x4c, 0xa3, 0x34, 0x0f, 0xfe, 0x79, -0x3c, 0x4f, 0x7c, 0x9f, 0x1a, 0xff, 0x84, 0x46, -0x61, 0x89, 0x94, 0x32, 0x8c, 0x2b, 0x90, 0x07, -0xff, 0xbc, 0x6b, 0xe7, 0x67, 0xec, 0x34, 0x69, -0x5e, 0xfc, 0x73, 0x9d, 0x33, 0xac, 0x2b, 0x7f, -0x2c, 0xfe, 0x99, 0x2a, 0xff, 0x95, 0x85, 0x87, -0xc9, 0xa8, 0x62, 0xbf, 0xd2, 0xff, 0xc9, 0xf8, -0x47, 0xa9, 0x9f, 0x2a, 0xff, 0x95, 0x0d, 0x03, -0xa8, 0x01, 0x84, 0x42, 0x78, 0x62, 0xc8, 0xfc, -0x33, 0x22, 0xc3, 0x3f, 0xd6, 0xfe, 0xce, 0x3a, -0x1f, 0xc4, 0x2c, 0x7b, 0x7f, 0x99, 0x27, 0xc2, -0x52, 0x27, 0xc6, 0x2a, 0x78, 0x50, 0xc8, 0xb4, -0xa9, 0xf0, 0x4f, 0x8a, 0x36, 0x54, 0x3e, 0x11, -0xff, 0xe4, 0x9e, 0x9f, 0xbf, 0xcb, 0x85, 0x7f, -0xde, 0x72, 0x7a, 0x9b, 0x50, 0x96, 0xff, 0xf4, -0x4d, 0xa5, 0xff, 0xe1, 0xc3, 0x9c, 0x12, 0xff, -0x64, 0xaf, 0xb7, 0xde, 0x0c, 0x3c, 0xe9, 0xc4, -0x3f, 0x0e, 0xfd, 0x8f, 0x3b, 0x97, 0xe1, 0xc4, -0x3f, 0x23, 0xb9, 0xf7, 0xe3, 0x53, 0xe3, 0x9f, -0x29, 0xf1, 0xc0, 0x27, 0xe2, 0x1f, 0xe1, 0x8f, -0xc4, 0x3f, 0xd2, 0x7f, 0x10, 0xfe, 0x31, 0x8d, -0x42, 0xab, 0xf0, 0xed, 0x93, 0xf0, 0xcf, 0x75, -0x59, 0xe3, 0xbd, 0x6e, 0x2a, 0xfd, 0x8f, 0x69, -0x60, 0x63, 0xc0, 0xd6, 0xdc, 0xf9, 0x2f, 0x21, -0x83, 0xff, 0xe1, 0xfa, 0x9f, 0x3b, 0xf2, 0xe8, -0x9f, 0x33, 0xce, 0x07, 0xc9, 0x3b, 0xde, 0x7c, -0xfa, 0x9f, 0xa5, 0x9f, 0x94, 0xff, 0x2a, 0xb7, -0x9a, 0x60, 0xa7, 0xdf, 0x5f, 0xba, 0x00, 0x73, -0xff, 0x10, 0xfc, 0x63, 0x33, 0x4a, 0xfe, 0x48, -0xfc, 0xd3, 0xfc, 0x49, 0xf8, 0x27, 0x8b, 0xff, -0x11, 0xa7, 0xc6, 0x3f, 0x53, 0xe6, 0xdf, 0xf3, -0x9f, 0x0f, 0x9b, 0xc3, 0xe8, 0x59, 0xef, 0x9b, -0xe2, 0x7c, 0xd8, 0x5c, 0x86, 0x30, 0x85, 0xfe, -0x27, 0x37, 0xff, 0xe3, 0x38, 0x1f, 0xc4, 0x91, -0xbf, 0x30, 0x0e, 0xba, 0x32, 0x03, 0xd9, 0x44, -0x14, 0x1b, 0x65, 0xcf, 0xc8, 0xc2, 0x3f, 0xe6, -0xdb, 0x06, 0x92, 0xb3, 0xef, 0x22, 0xa7, 0x84, -0xb7, 0x8c, 0x63, 0x4d, 0x4e, 0xeb, 0x07, 0x3e, -0x51, 0xff, 0xb3, 0xe2, 0x9b, 0x85, 0xf6, 0xf1, -0xaa, 0x19, 0xfa, 0x1f, 0x35, 0x53, 0xff, 0xe3, -0xb2, 0x85, 0xf5, 0x3c, 0xf8, 0x27, 0x63, 0x74, -0x55, 0x19, 0x8c, 0x90, 0x3b, 0x27, 0xfe, 0x31, -0xef, 0x2f, 0x31, 0x85, 0xaf, 0x46, 0x46, 0x2c, -0x2f, 0xfe, 0xc9, 0xd8, 0xc6, 0x2e, 0xf9, 0x24, -0xfc, 0x33, 0xa5, 0x7e, 0x23, 0xff, 0xf9, 0xb0, -0x4e, 0x43, 0xc8, 0x8d, 0x7f, 0x9c, 0xfc, 0x4f, -0x64, 0xd0, 0x40, 0x44, 0xc1, 0x3a, 0x06, 0x84, -0xaa, 0x32, 0xfb, 0x43, 0x16, 0xaf, 0x73, 0x8c, -0xf7, 0x05, 0xef, 0x3e, 0xf1, 0xbd, 0xb6, 0x94, -0xfe, 0x76, 0x94, 0x4e, 0xc8, 0x99, 0xfd, 0x21, -0xaf, 0xcd, 0x31, 0x5e, 0xa4, 0x7d, 0xcc, 0x2b, -0xf7, 0xe8, 0xd7, 0x39, 0xf1, 0xcf, 0x45, 0x6d, -0x30, 0xba, 0xa8, 0xda, 0x73, 0x54, 0xac, 0x63, -0x46, 0xbd, 0xea, 0x39, 0x21, 0x5e, 0x92, 0x26, -0xa1, 0x1e, 0xdb, 0x8a, 0xe6, 0xe4, 0x7f, 0x46, -0x90, 0x64, 0x96, 0xf1, 0xb4, 0x38, 0xda, 0x8d, -0xa7, 0x51, 0x6f, 0x27, 0xef, 0xc8, 0x87, 0x33, -0x1a, 0x01, 0xd9, 0xfb, 0xff, 0x74, 0x77, 0x53, -0x9f, 0x0a, 0x32, 0x31, 0xda, 0x57, 0x91, 0x22, -0x48, 0x09, 0x33, 0x64, 0xc7, 0xf7, 0x65, 0xae, -0x1f, 0xbd, 0x7c, 0xc4, 0xac, 0x66, 0x0d, 0x73, -0xa3, 0x88, 0x92, 0x51, 0xf9, 0x70, 0x85, 0xb3, -0x11, 0xd0, 0xb8, 0xad, 0xfe, 0x6b, 0x94, 0x1c, -0xa5, 0xfb, 0xc2, 0x81, 0xed, 0xee, 0xb9, 0xdc, -0x98, 0xcf, 0x27, 0x8a, 0xee, 0x73, 0x34, 0xea, -0x49, 0xd7, 0x7f, 0xc5, 0x84, 0x67, 0xa4, 0xcb, -0xd1, 0x25, 0x6b, 0xb6, 0xbe, 0x26, 0x3e, 0xad, -0x5d, 0x8e, 0xb6, 0xac, 0x29, 0x19, 0xab, 0xba, -0xa8, 0x7d, 0x48, 0xf3, 0xd5, 0x7f, 0xe9, 0xca, -0xcf, 0xe0, 0x42, 0xac, 0x39, 0xec, 0xdd, 0x2e, -0xf2, 0x36, 0xb6, 0x61, 0x63, 0x3f, 0xd2, 0x5e, -0x97, 0x17, 0xff, 0xd4, 0xc2, 0x41, 0xbd, 0x36, -0xec, 0xde, 0x4e, 0xde, 0x84, 0x83, 0x94, 0x19, -0x31, 0xc4, 0x3f, 0xba, 0x9a, 0x87, 0xff, 0xd1, -0x0b, 0xd6, 0x66, 0xf8, 0x2b, 0x74, 0xcb, 0xfb, -0x92, 0xce, 0xc6, 0x35, 0x76, 0xfc, 0x73, 0x0d, -0x3c, 0x1d, 0x9d, 0x1f, 0x73, 0xaf, 0x25, 0x27, -0xe1, 0x69, 0xca, 0x0c, 0xd4, 0x3f, 0x3f, 0xcd, -0x2b, 0xa4, 0x72, 0xd6, 0x7f, 0xc9, 0xb2, 0x76, -0x4e, 0x69, 0xa2, 0x5e, 0x55, 0x4c, 0xc0, 0x39, -0x60, 0x06, 0x88, 0x03, 0x0c, 0x08, 0xc5, 0xf5, -0x7c, 0xfc, 0x4f, 0x1f, 0x5c, 0x51, 0x5a, 0xba, -0xbc, 0x67, 0xc4, 0x71, 0x8d, 0x1b, 0x47, 0xf9, -0x7a, 0xc8, 0x87, 0x7f, 0xfc, 0x98, 0xff, 0x32, -0xda, 0x62, 0xdf, 0x81, 0x6d, 0xb1, 0x93, 0x9e, -0xb8, 0x7b, 0x2e, 0x24, 0xa8, 0x73, 0x7e, 0xd2, -0xf5, 0x7d, 0x23, 0xdc, 0x9f, 0xa4, 0xea, 0xbf, -0x8c, 0x63, 0x61, 0x49, 0x05, 0x74, 0x19, 0xc7, -0x4c, 0xe7, 0xea, 0xff, 0xa3, 0xfc, 0x70, 0xfa, -0x81, 0x48, 0x25, 0xca, 0x7e, 0xf0, 0x7c, 0x10, -0x66, 0x8c, 0x90, 0x42, 0xe8, 0xa0, 0xb7, 0xe5, -0x3d, 0x1f, 0x64, 0x8b, 0xb9, 0xba, 0x8c, 0x6c, -0x97, 0x1c, 0x23, 0x1e, 0xd2, 0xb1, 0x2d, 0x96, -0x9a, 0x4f, 0x29, 0x85, 0x7f, 0xcc, 0xfb, 0x93, -0xe5, 0x4f, 0xc0, 0x45, 0x6d, 0x5f, 0x34, 0xb0, -0xcb, 0x3d, 0x8f, 0x1c, 0x43, 0xe3, 0x49, 0xb2, -0x18, 0x8e, 0x43, 0x9d, 0x89, 0x88, 0xee, 0xce, -0xea, 0xff, 0xa3, 0x8e, 0xcb, 0x78, 0x4c, 0x79, -0x67, 0xca, 0xd0, 0xad, 0x30, 0xd4, 0x9a, 0x1f, -0xff, 0x2c, 0x33, 0xf8, 0x1f, 0x1e, 0xdd, 0xaa, -0x8c, 0xb6, 0x3f, 0x9e, 0xfc, 0xf8, 0x47, 0xab, -0x5d, 0xef, 0x7e, 0x2c, 0xdd, 0x16, 0x7b, 0x0e, -0x33, 0x02, 0x0e, 0x45, 0x8a, 0x13, 0xff, 0xfc, -0x1c, 0x16, 0x68, 0xee, 0x21, 0x72, 0xde, 0x34, -0xd6, 0x70, 0xd9, 0x33, 0xde, 0x2f, 0xe7, 0xc4, -0x3f, 0x4f, 0xd1, 0xf9, 0x61, 0xb6, 0x6c, 0x7e, -0x63, 0x18, 0x43, 0xd8, 0x16, 0xdb, 0x1f, 0x30, -0xce, 0x87, 0xcd, 0xae, 0xff, 0x2a, 0x08, 0xc3, -0x18, 0xca, 0xbc, 0x81, 0x6d, 0xa2, 0xb9, 0xa1, -0x8b, 0x61, 0x8a, 0x8d, 0x47, 0xec, 0x42, 0x94, -0xd3, 0xf6, 0xfc, 0x17, 0xaf, 0x76, 0xf7, 0x3e, -0xd4, 0x69, 0x18, 0xab, 0x14, 0xf1, 0x3c, 0x9e, -0x97, 0x97, 0x97, 0xff, 0xc1, 0x5f, 0xeb, 0x97, -0x71, 0xfe, 0xe7, 0xb2, 0xd2, 0x82, 0xd3, 0x52, -0x0d, 0x17, 0xfc, 0x8b, 0xf2, 0xeb, 0x7f, 0xd4, -0x3e, 0xd9, 0x07, 0xee, 0x48, 0x24, 0x49, 0xfb, -0xd4, 0x5a, 0xe2, 0xa7, 0x44, 0x6d, 0x7b, 0x46, -0xf3, 0xe5, 0xab, 0xff, 0x2a, 0x18, 0xa0, 0x7b, -0xd9, 0xb2, 0xee, 0x29, 0x25, 0x03, 0xb1, 0xbd, -0x6a, 0xa0, 0xcd, 0xb5, 0x9a, 0x5c, 0x25, 0x3f, -0x45, 0x55, 0x07, 0xfe, 0x71, 0xf4, 0xff, 0x61, -0x17, 0x77, 0x9a, 0x68, 0x27, 0xa0, 0xb9, 0xa2, -0xae, 0xfd, 0x6c, 0x62, 0x9d, 0xc2, 0xaa, 0x37, -0x33, 0xf2, 0x5f, 0xbe, 0xf4, 0xdb, 0x96, 0x28, -0xe2, 0x1c, 0xb8, 0xa0, 0xed, 0xcb, 0x83, 0x7f, -0x46, 0x32, 0xf1, 0x4f, 0xb1, 0xad, 0x0d, 0x54, -0x8e, 0xfa, 0x2f, 0x7e, 0x3e, 0x08, 0x36, 0xd9, -0x88, 0xa4, 0x67, 0x5b, 0x85, 0x41, 0x3c, 0x16, -0x36, 0x1f, 0xfe, 0x91, 0xcf, 0x42, 0x55, 0xd4, -0x3d, 0x4c, 0x50, 0xa4, 0xbe, 0x20, 0xe6, 0xde, -0x45, 0xfc, 0x10, 0x81, 0xaa, 0xbc, 0xf5, 0x5f, -0x2b, 0xa1, 0xca, 0xd6, 0x26, 0x2b, 0xe9, 0x6a, -0x20, 0x25, 0x10, 0xa1, 0x2a, 0xcd, 0x5d, 0xff, -0x15, 0x83, 0x5b, 0xe0, 0x47, 0x50, 0xa9, 0xb9, -0xdb, 0xc9, 0xab, 0xf2, 0x53, 0x30, 0x3f, 0xc4, -0xbe, 0xd6, 0xeb, 0xe0, 0x5e, 0xad, 0x92, 0xe6, -0xae, 0xff, 0xda, 0xdd, 0xfd, 0x15, 0x38, 0x4b, -0x17, 0xc6, 0xbc, 0x6b, 0xc5, 0x93, 0x78, 0x3e, -0x08, 0xb6, 0xfd, 0x71, 0x91, 0xe7, 0xe9, 0xde, -0x58, 0x9e, 0xfa, 0xaf, 0x22, 0x9c, 0x9f, 0x67, -0x29, 0xaf, 0xff, 0xe2, 0xa3, 0x0b, 0xba, 0x51, -0xf1, 0x62, 0xf5, 0xb7, 0xc9, 0x81, 0x7f, 0xde, -0x8f, 0xb6, 0x24, 0x1f, 0xc0, 0xfa, 0xe5, 0x97, -0x51, 0xb6, 0x31, 0x22, 0xfe, 0x58, 0x1e, 0x8c, -0xde, 0x18, 0x0b, 0xe4, 0xcc, 0x7f, 0x3d, 0x31, -0x7d, 0x3f, 0x6c, 0xa4, 0x0b, 0x34, 0xb9, 0x9d, -0x5c, 0xa5, 0x6f, 0xd4, 0x2a, 0x87, 0xdc, 0xe1, -0x9d, 0x57, 0xe9, 0x5d, 0xe9, 0xfe, 0x3f, 0x19, -0xe7, 0x83, 0x20, 0xfe, 0xf9, 0xb1, 0x3a, 0x07, -0x0f, 0x6d, 0xac, 0x80, 0xef, 0xc1, 0x1c, 0xea, -0xbe, 0x0d, 0xcf, 0xc3, 0xa5, 0xce, 0xfe, 0x3f, -0x76, 0xfc, 0xc3, 0x69, 0x46, 0x8c, 0x56, 0x2a, -0x6c, 0x87, 0xb9, 0xd4, 0x5d, 0x1d, 0x11, 0xf0, -0x8a, 0xa3, 0xff, 0x8f, 0x33, 0xff, 0xf5, 0xae, -0x34, 0x97, 0xc1, 0x18, 0x12, 0x40, 0x75, 0x84, -0xee, 0x9d, 0x25, 0x3e, 0x80, 0x1d, 0xe7, 0xa8, -0x3d, 0x7e, 0xd9, 0xeb, 0xbf, 0x38, 0x5e, 0xd2, -0x38, 0xff, 0xf3, 0xae, 0xd6, 0xd8, 0xbe, 0x35, -0x3a, 0xed, 0xac, 0x41, 0x53, 0x3b, 0xf8, 0x1f, -0xf3, 0xfd, 0x05, 0xe5, 0x59, 0xb8, 0x12, 0x6d, -0xa1, 0xc5, 0x49, 0xd2, 0xc4, 0xe6, 0xa7, 0x4a, -0xf7, 0x0c, 0x89, 0x8b, 0xfd, 0x2f, 0x43, 0x0b, -0x75, 0xe7, 0xac, 0xff, 0x62, 0xf8, 0x47, 0x63, -0x41, 0x1c, 0x93, 0xa4, 0x01, 0xe8, 0xe9, 0xe2, -0xc2, 0x42, 0x3f, 0xe6, 0x2f, 0x3a, 0xa6, 0xc2, -0x3f, 0x7e, 0xbd, 0x28, 0x4e, 0x7e, 0x06, 0x3f, -0x55, 0x6b, 0x74, 0xb9, 0xbb, 0xb4, 0x1a, 0xf0, -0x3c, 0xd9, 0x29, 0xf8, 0x1f, 0x99, 0x77, 0xdf, -0x7a, 0x80, 0xc1, 0xc2, 0xb5, 0xba, 0x0c, 0x44, -0xda, 0x42, 0xe5, 0x40, 0x77, 0x9e, 0xfa, 0x2f, -0x86, 0x7f, 0x2e, 0xaa, 0x8d, 0x78, 0xda, 0xe9, -0x96, 0xe8, 0xef, 0xb0, 0xed, 0x0c, 0x15, 0x54, -0x38, 0xaa, 0x3a, 0xc7, 0xeb, 0xc0, 0x3f, 0xca, -0x84, 0x31, 0xa8, 0x75, 0x1a, 0x9e, 0x2e, 0xe7, -0xd5, 0xc4, 0x21, 0x8d, 0x7d, 0x56, 0x5d, 0xf9, -0xeb, 0xbf, 0x26, 0x23, 0x46, 0xfd, 0x97, 0x92, -0x99, 0x36, 0xcd, 0x9d, 0xff, 0x72, 0xf4, 0xff, -0x39, 0x93, 0x32, 0xe6, 0xe2, 0x95, 0x3b, 0xa6, -0xcc, 0x7f, 0x39, 0x13, 0xa3, 0xfd, 0xd6, 0x41, -0x3c, 0x3d, 0xb9, 0xf9, 0x9f, 0x9b, 0x4c, 0xf4, -0x18, 0x32, 0xdb, 0x28, 0xdd, 0xb4, 0x2e, 0x9b, -0xff, 0x51, 0xa7, 0xa7, 0xeb, 0xbf, 0x94, 0x09, -0xa9, 0xc1, 0x89, 0x9f, 0xa5, 0x94, 0x90, 0xcc, -0x51, 0xff, 0x95, 0xc5, 0xf6, 0xfc, 0xf1, 0xf9, -0x2f, 0x0b, 0x78, 0x4f, 0xc1, 0xff, 0x08, 0xc6, -0x40, 0x4a, 0x9c, 0xc0, 0x58, 0xc8, 0xc2, 0x3f, -0x59, 0xfb, 0x2f, 0x18, 0x94, 0xea, 0xa5, 0xd4, -0xc6, 0x21, 0x17, 0xff, 0x23, 0x18, 0x41, 0xdf, -0xe8, 0xff, 0x33, 0xe2, 0x72, 0x12, 0x41, 0x1d, -0x5f, 0xcf, 0xc4, 0x3f, 0x6c, 0xbd, 0x09, 0x4d, -0xfd, 0xab, 0x82, 0x7f, 0x6a, 0xd4, 0x7f, 0x79, -0x17, 0x8b, 0xd8, 0xd2, 0xb5, 0x49, 0x2f, 0x09, -0x0a, 0xc7, 0xa3, 0x1f, 0xd2, 0xa6, 0xd1, 0xac, -0xfc, 0xd7, 0x44, 0x3a, 0x4d, 0xdc, 0xac, 0x4f, -0xfb, 0x60, 0xc6, 0x25, 0xb8, 0x47, 0x30, 0xe6, -0x47, 0x4b, 0x11, 0x41, 0x9f, 0xc8, 0xff, 0x10, -0x73, 0xfe, 0x85, 0x66, 0x7d, 0x55, 0xbc, 0x35, -0x7f, 0xfd, 0x57, 0xff, 0x27, 0xe6, 0xbf, 0xcc, -0xb4, 0xd7, 0x4d, 0xe9, 0x61, 0xf2, 0x19, 0x98, -0x69, 0xe7, 0x7f, 0xd2, 0xf5, 0x5f, 0x65, 0x83, -0x12, 0x4e, 0xda, 0x8a, 0x1c, 0xdb, 0x58, 0xdf, -0x94, 0xf9, 0xaf, 0x1c, 0x69, 0xaf, 0x4f, 0xca, -0x7f, 0xd9, 0x84, 0x40, 0xb3, 0xff, 0x63, 0xf9, -0x9f, 0xff, 0xd8, 0xfc, 0x97, 0xf2, 0x47, 0xf3, -0x3f, 0x19, 0xc6, 0xd9, 0x7f, 0x57, 0xfe, 0xcb, -0xb8, 0xd8, 0x6a, 0xbf, 0x4d, 0xca, 0xec, 0xa8, -0x93, 0x91, 0xff, 0x4a, 0xa3, 0x9d, 0x22, 0x6e, -0x14, 0x18, 0x57, 0xa4, 0x3f, 0x94, 0xff, 0x11, -0x9c, 0x85, 0xff, 0x53, 0xd4, 0x7f, 0x19, 0x65, -0x5f, 0x70, 0x47, 0x3e, 0xfe, 0x27, 0xb3, 0xfe, -0xeb, 0x93, 0xf4, 0xcf, 0xf0, 0x87, 0xdc, 0x3f, -0x45, 0xfd, 0xd7, 0x27, 0xf1, 0x3f, 0xa9, 0xfa, -0x2f, 0x3b, 0xdb, 0x33, 0x22, 0x35, 0x0a, 0x19, -0xfa, 0xe7, 0x74, 0xff, 0xc3, 0xbc, 0xfc, 0x8f, -0x18, 0xd4, 0x72, 0xf0, 0x3f, 0x59, 0xf5, 0x5f, -0x39, 0x8d, 0x3c, 0xf5, 0x5f, 0x79, 0x8d, 0x5c, -0xfc, 0x4f, 0x8e, 0x32, 0xf0, 0x1c, 0xf8, 0x47, -0x2b, 0xc8, 0x8e, 0x56, 0x48, 0xfb, 0xe4, 0x8b, -0x5f, 0x99, 0xfc, 0xcf, 0x08, 0x1b, 0x1d, 0x73, -0x9b, 0xfb, 0xf9, 0x15, 0x14, 0x46, 0x06, 0x74, -0x47, 0xff, 0xc3, 0x4c, 0xfe, 0x27, 0x61, 0xe8, -0x7f, 0x54, 0xa7, 0xfe, 0x27, 0xbd, 0xbf, 0xcb, -0xa8, 0xff, 0xaa, 0xcd, 0xcd, 0xa7, 0xa5, 0xf1, -0x4f, 0x56, 0xfd, 0x57, 0x4a, 0xe8, 0xd2, 0xd0, -0x6f, 0xbf, 0x72, 0x3a, 0x3f, 0xff, 0x63, 0x13, -0x7e, 0x4c, 0x9b, 0x2a, 0xff, 0x65, 0xd2, 0x3e, -0x1e, 0x6e, 0x48, 0xbc, 0xec, 0xeb, 0x92, 0x72, -0x8f, 0xf1, 0x53, 0xbe, 0xfa, 0x2f, 0x52, 0xa2, -0x17, 0xe7, 0x12, 0xf6, 0xe4, 0xaa, 0xff, 0x2a, -0x4c, 0xd5, 0x7f, 0x7d, 0x82, 0xfe, 0xd9, 0x76, -0x3e, 0x88, 0x84, 0xf3, 0x53, 0xc4, 0x69, 0x1f, -0xd9, 0x9c, 0x1f, 0x81, 0x17, 0xc2, 0x3b, 0xeb, -0xbf, 0x6c, 0xd9, 0xbd, 0xc6, 0x53, 0x9e, 0xa7, -0x90, 0xf6, 0x51, 0x79, 0xfc, 0x7d, 0x4f, 0x9b, -0x68, 0x6f, 0xc6, 0x83, 0x83, 0x6d, 0xfd, 0x7f, -0x9c, 0xfc, 0x4f, 0xf3, 0x60, 0x06, 0x11, 0x04, -0x86, 0xfe, 0xe7, 0x2a, 0x73, 0x3d, 0x1c, 0x29, -0x40, 0xd8, 0xd3, 0x9b, 0xf4, 0x26, 0xd8, 0xfe, -0x8b, 0xe1, 0xe7, 0x30, 0xfb, 0xb5, 0x76, 0x0a, -0xfc, 0xa3, 0xf3, 0xfc, 0x97, 0xef, 0x8c, 0xbb, -0x3b, 0xf4, 0x26, 0xef, 0xff, 0xec, 0x5e, 0x88, -0x07, 0xb9, 0xe6, 0xd5, 0xff, 0x24, 0x0a, 0x8c, -0xfd, 0xb8, 0x1b, 0xd8, 0xd7, 0xf7, 0x30, 0x57, -0x9f, 0xfa, 0xb2, 0xf3, 0xa1, 0x69, 0xfe, 0x27, -0xa9, 0xec, 0xe1, 0xa2, 0x29, 0xe6, 0xc4, 0xce, -0xc2, 0x0f, 0x54, 0xdf, 0x80, 0x3b, 0x16, 0x09, -0x28, 0x99, 0xf3, 0x69, 0xeb, 0xff, 0xcc, 0xf5, -0xb7, 0x75, 0x3a, 0x0b, 0x43, 0x6f, 0x92, 0xd7, -0x60, 0x9f, 0xee, 0xdd, 0xef, 0x0e, 0x64, 0xd7, -0x7f, 0x59, 0xf8, 0x76, 0x2f, 0x3c, 0x23, 0xa5, -0xf2, 0x83, 0xe7, 0x81, 0x37, 0xba, 0x59, 0x9f, -0xab, 0xff, 0x8f, 0x15, 0x4f, 0xc7, 0xc0, 0x58, -0x9f, 0xd7, 0x75, 0xb3, 0xcf, 0xea, 0x28, 0x65, -0x4f, 0xeb, 0x16, 0x03, 0x59, 0xf5, 0x4d, 0xce, -0xfe, 0xcf, 0xbd, 0x46, 0x1a, 0x74, 0x10, 0x7e, -0xc5, 0x8c, 0x9e, 0x0e, 0x12, 0x50, 0x5f, 0xcf, -0x5b, 0xff, 0xa5, 0x9b, 0x7c, 0x20, 0xd2, 0x62, -0x1d, 0x12, 0x76, 0x5b, 0x75, 0x95, 0x64, 0x1d, -0x6c, 0x9a, 0xee, 0xff, 0x33, 0xa4, 0x60, 0xfe, -0x8b, 0x81, 0x9c, 0x36, 0x72, 0x85, 0x7c, 0xd7, -0x88, 0xfe, 0xd7, 0x75, 0x3c, 0x12, 0xcb, 0xd7, -0xff, 0xc7, 0xcc, 0x7f, 0xb9, 0xa1, 0xf5, 0x25, -0xe8, 0xe7, 0x8d, 0x10, 0xab, 0x6a, 0xe1, 0x79, -0x7b, 0xff, 0x9f, 0xad, 0x8e, 0xfe, 0x3f, 0x65, -0x7b, 0x38, 0x68, 0xd9, 0x4a, 0xd9, 0xaf, 0x17, -0x14, 0x36, 0xba, 0x7d, 0xee, 0x1c, 0x7a, 0x2a, -0x27, 0xff, 0x83, 0x6c, 0x64, 0xb7, 0xb8, 0x05, -0x65, 0x0f, 0xf8, 0x6b, 0xad, 0xd2, 0x03, 0x4d, -0x49, 0x7b, 0x45, 0x9e, 0xad, 0xff, 0xb3, 0x95, -0x4f, 0x27, 0xb3, 0xd8, 0x46, 0x92, 0xcb, 0x9e, -0x9b, 0xe0, 0x27, 0xcc, 0xf0, 0xe7, 0xe6, 0x7f, -0x10, 0xff, 0x74, 0xcc, 0x4b, 0x76, 0x26, 0xc8, -0xb3, 0xb8, 0xed, 0x4a, 0xba, 0x6f, 0x45, 0x22, -0x28, 0x32, 0x3f, 0x29, 0xe7, 0xee, 0xff, 0x93, -0xd2, 0x1f, 0xce, 0xac, 0x26, 0xc5, 0xf2, 0x8e, -0x28, 0x43, 0xd7, 0x0a, 0xf1, 0xc0, 0xe3, 0x92, -0x59, 0xd8, 0x22, 0xf0, 0xf9, 0x3c, 0x69, 0x3d, -0x5f, 0x97, 0x76, 0xf3, 0xb2, 0x2f, 0xef, 0x6f, -0xc5, 0x83, 0x7c, 0xdb, 0xe5, 0x1d, 0x71, 0xfb, -0xe1, 0x08, 0x33, 0x3c, 0x79, 0xfa, 0x3f, 0x9b, -0xf1, 0x08, 0xf9, 0x9f, 0x3f, 0x20, 0xff, 0x95, -0x8e, 0x77, 0x03, 0x70, 0x94, 0x34, 0xb3, 0x68, -0xeb, 0xae, 0xce, 0x2a, 0x04, 0xcb, 0x3e, 0x1f, -0x6d, 0x26, 0x9e, 0xcf, 0xfe, 0x9a, 0xa9, 0x3f, -0x79, 0x3b, 0x83, 0x7f, 0xb0, 0xe1, 0x1f, 0xa8, -0x96, 0x78, 0x76, 0x0c, 0xf9, 0xc6, 0xcd, 0xd4, -0xb8, 0x5f, 0x3b, 0x98, 0x71, 0xbf, 0xad, 0xfe, -0x4b, 0x49, 0xe3, 0x9f, 0x18, 0x17, 0xc6, 0x5c, -0x13, 0x29, 0x84, 0x1d, 0xa9, 0x42, 0x30, 0x29, -0xab, 0xfe, 0x6b, 0x75, 0x45, 0x5a, 0xff, 0x4c, -0x51, 0xf6, 0xfc, 0x72, 0x84, 0x17, 0xc2, 0x3b, -0xf9, 0x07, 0x5b, 0xff, 0x67, 0xce, 0x87, 0xd4, -0x2e, 0xf5, 0xb6, 0x8b, 0xe7, 0xa5, 0xcb, 0xe0, -0xd5, 0xbc, 0xaf, 0x74, 0x0e, 0xc7, 0xde, 0xe6, -0x1d, 0x6f, 0xc4, 0x61, 0x25, 0x27, 0xfe, 0xb9, -0x6c, 0xe8, 0x7f, 0xae, 0x87, 0x97, 0xe0, 0x7a, -0x7d, 0xc5, 0xab, 0x0f, 0x5f, 0x2f, 0xf3, 0x83, -0xd5, 0xf0, 0xfe, 0x83, 0x99, 0xfc, 0x4f, 0x85, -0xa9, 0xff, 0x89, 0x85, 0x54, 0xce, 0x0f, 0xbb, -0x77, 0x11, 0xd5, 0x7e, 0x62, 0x5a, 0x06, 0xfe, -0x59, 0x9b, 0xd6, 0x3f, 0xff, 0x15, 0x3c, 0x9a, -0x6a, 0xfc, 0xa8, 0xe6, 0xef, 0xff, 0xd3, 0xa7, -0x18, 0xf8, 0xa7, 0x27, 0xea, 0x5a, 0x23, 0x3d, -0xca, 0xa6, 0xb1, 0xe7, 0xa1, 0xd0, 0xba, 0xac, -0x7c, 0x62, 0xf6, 0xf9, 0x68, 0xee, 0xc7, 0x66, -0xfc, 0x15, 0xf9, 0x15, 0x34, 0x20, 0x51, 0xbc, -0x26, 0x2b, 0x23, 0x96, 0x3e, 0x1f, 0x36, 0x01, -0xbb, 0xa4, 0x94, 0xba, 0xfb, 0x47, 0x78, 0x2c, -0x6c, 0xbb, 0x77, 0xbb, 0xdb, 0x81, 0x88, 0x78, -0xe3, 0x20, 0x5b, 0xff, 0x43, 0x73, 0xbd, 0x75, -0x89, 0x49, 0xf9, 0x84, 0xd0, 0x0c, 0x01, 0x49, -0x54, 0xf9, 0x1f, 0x22, 0xcf, 0xf9, 0xb0, 0x5d, -0xa9, 0xfc, 0x97, 0xca, 0x9c, 0xea, 0x49, 0x99, -0x6d, 0xe4, 0x47, 0x48, 0xa3, 0x7a, 0x5f, 0x46, -0x46, 0x2c, 0x91, 0x9d, 0x8f, 0x58, 0xc8, 0x16, -0xc9, 0xc3, 0x94, 0x7d, 0x26, 0x8b, 0x4b, 0x3c, -0xd0, 0x49, 0x32, 0xfd, 0xb3, 0xf9, 0x4f, 0xe0, -0xe7, 0x85, 0x7d, 0x1d, 0xbf, 0xdf, 0xf3, 0xea, -0x23, 0xb0, 0x20, 0xd9, 0xdd, 0x7e, 0x2f, 0xfb, -0x1e, 0xf3, 0x9e, 0x0f, 0x2b, 0x77, 0x9b, 0xf8, -0x67, 0xc6, 0x6f, 0xe4, 0x7f, 0x61, 0x86, 0x67, -0x44, 0x6c, 0x20, 0xbf, 0xcc, 0x7b, 0x3e, 0xac, -0x7f, 0x96, 0xe1, 0x6f, 0x57, 0xc5, 0xd9, 0xf7, -0x92, 0x12, 0xba, 0x0c, 0x5b, 0xfe, 0xc7, 0x94, -0xc2, 0xda, 0xfa, 0x3f, 0x7b, 0x9e, 0x6d, 0xe3, -0x41, 0xea, 0xdb, 0x9c, 0xff, 0x69, 0x19, 0xf6, -0x8e, 0x57, 0x35, 0xda, 0xe2, 0x97, 0x01, 0x84, -0xd2, 0xe7, 0xc3, 0x3e, 0x29, 0x5b, 0x78, 0xe6, -0x7a, 0x7c, 0xed, 0xdf, 0xba, 0x97, 0xb8, 0x66, -0x99, 0xb0, 0x27, 0x07, 0xff, 0x13, 0x83, 0xc7, -0x14, 0x7e, 0x71, 0xcc, 0xb8, 0x7f, 0xd0, 0x7d, -0x3b, 0xd9, 0x66, 0x43, 0x44, 0x24, 0xeb, 0x7c, -0x58, 0xac, 0xf7, 0xf1, 0xe8, 0x33, 0x9b, 0x48, -0x01, 0xf6, 0xb7, 0x41, 0x6f, 0x5f, 0x9d, 0x15, -0xef, 0xd2, 0xf5, 0x5f, 0xb2, 0xc4, 0xfc, 0x2d, -0xdb, 0x2d, 0xba, 0x9f, 0x13, 0x0b, 0xe0, 0xc5, -0x82, 0xda, 0x33, 0xde, 0xf8, 0xa7, 0xab, 0xa5, -0xcc, 0x8d, 0xa4, 0xad, 0xff, 0x33, 0x98, 0x78, -0xc9, 0x3d, 0x4c, 0xf8, 0x44, 0x45, 0x45, 0xab, -0xfe, 0x1d, 0x0f, 0x8a, 0xbd, 0xdb, 0xc0, 0x3f, -0xe6, 0xfd, 0x02, 0x18, 0x7a, 0x86, 0x92, 0x8b, -0xe2, 0x79, 0xdf, 0xcb, 0xcc, 0x28, 0x4e, 0x8a, -0xdf, 0x02, 0x34, 0xdc, 0x63, 0x58, 0x21, 0x4e, -0xf0, 0x04, 0x84, 0x2a, 0x7b, 0xff, 0x67, 0x16, -0xcd, 0x89, 0x51, 0xbd, 0x0e, 0x3d, 0x65, 0xb5, -0x7a, 0x5b, 0x94, 0x7c, 0x8a, 0xeb, 0x57, 0x57, -0xe4, 0x3d, 0x1f, 0xd6, 0x8c, 0xce, 0x04, 0x6f, -0x2b, 0x8a, 0xc3, 0x1d, 0x59, 0x7a, 0x57, 0x07, -0xfe, 0xe1, 0x65, 0x71, 0x6c, 0x12, 0x86, 0x71, -0x7e, 0x12, 0xdd, 0x7b, 0x49, 0xfa, 0x20, 0x6f, -0x39, 0x9b, 0xff, 0x81, 0x75, 0xe6, 0x7a, 0x18, -0x96, 0x8f, 0x0a, 0xcd, 0x89, 0xfb, 0xe7, 0x3e, -0xfc, 0x35, 0xf2, 0x22, 0xd7, 0xff, 0xa4, 0x89, -0x8e, 0x34, 0xff, 0xd3, 0x51, 0x60, 0x06, 0xf1, -0x19, 0xe7, 0x11, 0xff, 0x0c, 0x79, 0xf7, 0x89, -0xe7, 0xb1, 0xfe, 0x3d, 0xb1, 0x2a, 0x2f, 0xff, -0xf3, 0xf2, 0xa6, 0xfa, 0x33, 0xeb, 0xc6, 0x5b, -0x11, 0xed, 0xd4, 0x25, 0xef, 0xb7, 0xf3, 0x3f, -0xe4, 0x0d, 0x64, 0x14, 0x33, 0xf9, 0x1f, 0x84, -0x3d, 0x6d, 0x7d, 0x75, 0x1c, 0x08, 0x25, 0xed, -0xfc, 0xcf, 0x59, 0xa9, 0xc7, 0xb8, 0x32, 0xe6, -0xe0, 0x7f, 0xb0, 0x88, 0x40, 0x0e, 0x02, 0xfe, -0xf5, 0x79, 0x37, 0xf5, 0xb4, 0x10, 0x5a, 0x78, -0xd8, 0xa0, 0x5e, 0xcf, 0x39, 0xf8, 0x9f, 0x1e, -0xa1, 0x26, 0x05, 0x23, 0x25, 0x9f, 0xde, 0x93, -0xe6, 0x7f, 0x4a, 0x47, 0xa1, 0x47, 0xf2, 0x65, -0xd4, 0xbf, 0x97, 0xed, 0x61, 0x68, 0x84, 0x77, -0x63, 0xc6, 0xea, 0xad, 0x3a, 0xdd, 0xd9, 0x2f, -0xeb, 0x75, 0xa3, 0x11, 0x50, 0xd2, 0xc2, 0x4b, -0x67, 0xe0, 0x99, 0xd2, 0x49, 0x38, 0x80, 0xf3, -0x83, 0x30, 0xf8, 0x39, 0xe3, 0xfc, 0x8b, 0x7b, -0xd2, 0xf8, 0xe7, 0xb9, 0xcc, 0xfc, 0xd7, 0x1e, -0xd9, 0x90, 0xd9, 0x5b, 0x8f, 0x6d, 0x75, 0xe8, -0x5b, 0xf8, 0xf3, 0x3f, 0xb0, 0xf1, 0x3f, 0x1e, -0x5e, 0xef, 0xb6, 0x02, 0x5f, 0xbb, 0xd7, 0x5a, -0x06, 0x5c, 0xc8, 0x54, 0x8a, 0x33, 0xc0, 0xdf, -0xff, 0x23, 0xa7, 0xfe, 0x47, 0xf2, 0xf4, 0xdb, -0xb6, 0x5d, 0x1c, 0x18, 0x7b, 0xcc, 0xef, 0x25, -0xe6, 0xe4, 0x7f, 0x6e, 0xcb, 0xec, 0xff, 0xe3, -0xd4, 0x03, 0x2f, 0xea, 0xe0, 0x89, 0xb0, 0xf1, -0x2c, 0xfc, 0x63, 0xaa, 0x7d, 0x46, 0xbd, 0xf5, -0xa8, 0xff, 0xe9, 0xc2, 0x2b, 0x4b, 0x11, 0xff, -0x04, 0xfb, 0xbd, 0x0b, 0xf3, 0xeb, 0x7f, 0xd8, -0x32, 0xdb, 0xdb, 0x7a, 0x49, 0x9f, 0xac, 0xe6, -0x2b, 0x6a, 0x94, 0xdd, 0xcf, 0x96, 0xe2, 0x58, -0xab, 0xbd, 0xff, 0xcf, 0xa0, 0x89, 0x06, 0x2d, -0xe3, 0x0b, 0x0c, 0x5f, 0x19, 0xf9, 0x2f, 0xe5, -0x43, 0xc3, 0xb0, 0xf1, 0x3f, 0x57, 0x3f, 0x06, -0x9b, 0xa4, 0x94, 0xf7, 0x40, 0x63, 0xc5, 0xfa, -0xba, 0x53, 0x65, 0x9b, 0xd2, 0xf9, 0x2f, 0x6e, -0x9c, 0xb3, 0xea, 0xbf, 0x74, 0xf8, 0x21, 0x31, -0xbb, 0x1d, 0x92, 0x4d, 0x74, 0x1e, 0x27, 0x82, -0xc8, 0x26, 0x23, 0xdf, 0xf7, 0x43, 0xe1, 0x00, -0xdd, 0x81, 0x8a, 0xa0, 0x74, 0xff, 0xe7, 0x36, -0xc9, 0x54, 0x97, 0xf9, 0x06, 0xf9, 0x67, 0xf5, -0x7f, 0xc5, 0xd9, 0x32, 0xc3, 0x15, 0xb8, 0xc2, -0xf8, 0xbe, 0xc2, 0x19, 0xfc, 0x4f, 0x41, 0x37, -0x9c, 0x34, 0x40, 0x4e, 0xc2, 0xc0, 0x3f, 0x08, -0x7b, 0x8e, 0xc1, 0x3e, 0x66, 0x7c, 0x11, 0x5b, -0x43, 0xd7, 0x65, 0xe0, 0x1f, 0x16, 0x7f, 0x47, -0x24, 0x5b, 0xb6, 0xcb, 0xcd, 0xf9, 0x1f, 0xc1, -0xd0, 0xa3, 0x2a, 0x1b, 0x8c, 0x13, 0x63, 0xd3, -0xf8, 0xa7, 0x5b, 0x19, 0x16, 0x4d, 0x35, 0x2c, -0x31, 0x8c, 0x19, 0xd5, 0xe9, 0x78, 0x77, 0x43, -0x16, 0xfe, 0xc1, 0xfe, 0x87, 0x1c, 0xff, 0x88, -0x86, 0xfe, 0xb6, 0xc4, 0xc0, 0x3f, 0x8d, 0x3c, -0xfe, 0x4a, 0x07, 0x0d, 0xc3, 0x71, 0xfe, 0x85, -0x60, 0xaa, 0x73, 0xa5, 0xcd, 0xc2, 0x1d, 0xda, -0x0a, 0xb3, 0x11, 0xd0, 0x4c, 0x9b, 0x70, 0xc8, -0xc6, 0xff, 0x80, 0xa5, 0xfe, 0xed, 0xe2, 0x86, -0x2b, 0xea, 0x92, 0xf8, 0xa9, 0x53, 0x29, 0x3c, -0xe0, 0x5f, 0xea, 0xe0, 0x7f, 0xfa, 0x64, 0x4c, -0x43, 0x37, 0x1b, 0x7c, 0x8b, 0x11, 0x76, 0x89, -0x6a, 0xc3, 0x7b, 0xe2, 0x6c, 0xac, 0x88, 0x77, -0xf0, 0x3f, 0x8a, 0x83, 0xcd, 0x78, 0x20, 0x5a, -0x35, 0x0c, 0x6f, 0x4b, 0x8d, 0xe6, 0x15, 0x34, -0x6c, 0xfd, 0x9f, 0xb7, 0x17, 0x9c, 0xe7, 0x65, -0x31, 0xec, 0x57, 0x34, 0xf6, 0xa5, 0x0c, 0xc2, -0x9f, 0x80, 0x47, 0x63, 0x34, 0x6b, 0xab, 0x32, -0xf9, 0x1f, 0x0e, 0x7b, 0x28, 0xb1, 0x1b, 0xa9, -0xfe, 0x87, 0x0c, 0xcc, 0x66, 0xf4, 0x7f, 0x46, -0xfe, 0xa7, 0x03, 0x9b, 0xcc, 0x63, 0xff, 0x1f, -0x41, 0x50, 0x35, 0xd1, 0x14, 0x42, 0xbb, 0x95, -0xc2, 0x61, 0x6e, 0xcc, 0xcc, 0xe4, 0x7f, 0x36, -0x9b, 0xe8, 0xd1, 0x30, 0x42, 0xc3, 0x69, 0xfd, -0xf3, 0x13, 0x52, 0x0e, 0xfe, 0xe7, 0xa8, 0x89, -0x66, 0x6d, 0x46, 0xb3, 0xc3, 0xc8, 0xe6, 0x7f, -0x1c, 0xb2, 0x28, 0x05, 0x85, 0xf1, 0xc5, 0xa9, -0x2b, 0x4b, 0xbd, 0x79, 0xcf, 0x87, 0xcd, 0x34, -0x8c, 0x9f, 0x3c, 0x8e, 0xfa, 0x77, 0xf6, 0x17, -0xde, 0xc7, 0x40, 0x4e, 0x49, 0xac, 0x34, 0x21, -0xed, 0x4b, 0xa1, 0x1d, 0x01, 0x61, 0xcf, 0x8a, -0x58, 0xeb, 0x6e, 0x38, 0x24, 0x94, 0x20, 0xb0, -0xef, 0x4e, 0xf3, 0x3f, 0x1b, 0xb3, 0xf8, 0x9f, -0x9b, 0xad, 0x30, 0xbd, 0x87, 0x3b, 0xa2, 0xa2, -0x60, 0x28, 0xcd, 0xff, 0x54, 0xa6, 0xf8, 0x9f, -0x8c, 0xb2, 0x77, 0xe3, 0x58, 0xd8, 0xc7, 0x0a, -0x0e, 0x30, 0x44, 0x54, 0xb1, 0x9e, 0xec, 0xb6, -0xf3, 0x3f, 0x4a, 0xba, 0xdb, 0x61, 0xd7, 0x7c, -0x66, 0xb4, 0x1a, 0xfe, 0x8a, 0x5d, 0xf9, 0x21, -0xc3, 0x3f, 0x2d, 0xc9, 0x62, 0x47, 0xff, 0xe7, -0x14, 0xff, 0x53, 0xe2, 0x70, 0xb3, 0x48, 0xe3, -0x6f, 0x75, 0xe0, 0x1f, 0x73, 0x7e, 0xb4, 0xf2, -0x2b, 0xda, 0x64, 0x9a, 0xed, 0x59, 0x62, 0x18, -0x5c, 0xd1, 0x7a, 0x81, 0xfd, 0x2f, 0xbe, 0x8c, -0xc2, 0x06, 0x16, 0xbf, 0xec, 0xe7, 0x5f, 0x68, -0x07, 0x14, 0xf3, 0xb5, 0x95, 0xf9, 0xd8, 0x4f, -0x0c, 0xf5, 0x27, 0x5c, 0x88, 0x78, 0x3a, 0xb4, -0x89, 0xce, 0x1f, 0xed, 0xb1, 0xeb, 0x7f, 0xa2, -0xf0, 0x98, 0x74, 0x40, 0xb2, 0xa1, 0xbb, 0x15, -0xeb, 0x2d, 0xfd, 0x4f, 0xe9, 0x29, 0x03, 0x11, -0x39, 0xfa, 0xff, 0x48, 0x56, 0x10, 0x47, 0xa3, -0xd6, 0x22, 0xa2, 0x0d, 0x0f, 0x9f, 0x0a, 0xf4, -0xb9, 0xfa, 0xff, 0x60, 0x34, 0x2f, 0xb4, 0x02, -0x4d, 0x83, 0x71, 0x22, 0xf9, 0x8b, 0x46, 0xfe, -0xe2, 0xa4, 0xf5, 0x3e, 0xdb, 0x72, 0xf2, 0x3f, -0x68, 0xfc, 0x85, 0x69, 0xb0, 0x27, 0x0c, 0x5b, -0xfe, 0xa7, 0x43, 0xb9, 0x24, 0x18, 0xfe, 0xfc, -0xab, 0x86, 0xfa, 0xd7, 0x93, 0x86, 0x01, 0x55, -0x16, 0x1e, 0x48, 0xc7, 0xeb, 0xfe, 0xae, 0x34, -0xff, 0xc3, 0xcb, 0xbe, 0x8a, 0x6d, 0xb2, 0x55, -0x1b, 0x9e, 0xb1, 0xf8, 0x1f, 0x29, 0x20, 0x3b, -0xd8, 0x09, 0x8b, 0xff, 0xe1, 0x15, 0xf1, 0x46, -0xe3, 0x20, 0x5f, 0x16, 0xff, 0xd3, 0x6f, 0xf2, -0x3f, 0x2f, 0x14, 0xd5, 0x61, 0x3d, 0xb2, 0x62, -0xcc, 0x18, 0xed, 0x55, 0xb1, 0x1f, 0x20, 0xd8, -0xea, 0xdf, 0xed, 0xfc, 0xcf, 0xbb, 0x52, 0x73, -0xc2, 0xb3, 0xaf, 0x33, 0x3d, 0x70, 0x75, 0xc2, -0xdf, 0x7c, 0xcc, 0x9b, 0xb3, 0xff, 0x4f, 0x2a, -0x7e, 0xa1, 0x3a, 0xc8, 0xd2, 0xff, 0xa4, 0xfe, -0x8b, 0x63, 0x33, 0xb2, 0xcf, 0x87, 0xbd, 0xd3, -0x95, 0xeb, 0x3c, 0xbe, 0xce, 0xe0, 0xbf, 0xff, -0x3c, 0x3e, 0xb9, 0x8b, 0x54, 0x42, 0xb7, 0xc6, -0xeb, 0x52, 0x6d, 0xc6, 0x27, 0x9c, 0x87, 0x78, -0xe7, 0xbf, 0xf3, 0x3c, 0xc4, 0xc1, 0xff, 0x64, -0xe7, 0x21, 0x0e, 0xe6, 0xfd, 0xe5, 0xff, 0x2b, -0xe7, 0x21, 0x6a, 0x86, 0x01, 0x9f, 0x70, 0x1e, -0xe2, 0x9d, 0x7f, 0xe4, 0x79, 0x88, 0xda, 0x1f, -0x39, 0xff, 0xda, 0x7f, 0x9d, 0x87, 0xf8, 0xef, -0xfb, 0xf7, 0x9f, 0xeb, 0xfc, 0xc1, 0xff, 0x7c, -0xf7, 0x93, 0xae, 0xb2, 0x0e, 0xd1, 0xdf, 0x4e, -0xca, 0x60, 0xa0, 0x7a, 0x47, 0x27, 0x03, 0x88, -0x65, 0x91, 0x2e, 0xa9, 0x72, 0x85, 0x3f, 0x44, -0x94, 0xc8, 0xa6, 0xb2, 0xbd, 0x62, 0xd6, 0xf7, -0x58, 0xe0, 0x17, 0x28, 0x84, 0x65, 0x05, 0x0a, -0x64, 0x21, 0x01, 0x21, 0xa8, 0xd0, 0xa6, 0xc9, -0xd3, 0x11, 0x61, 0x54, 0xe8, 0xd3, 0xfc, 0x02, -0x48, 0x99, 0xdf, 0xe3, 0xbd, 0x50, 0x19, 0x92, -0xf1, 0xf9, 0xf7, 0xaa, 0xea, 0x11, 0xe6, 0x0f, -0xb7, 0x75, 0x6f, 0x2a, 0x3c, 0xf3, 0x85, 0xee, -0x90, 0xaf, 0xa2, 0xfb, 0x97, 0x85, 0x95, 0x04, -0x3d, 0xa4, 0xe3, 0x7e, 0xa9, 0x02, 0x3f, 0x6a, -0xa1, 0x0c, 0x24, 0x79, 0xba, 0x0c, 0x4b, 0x81, -0x19, 0x52, 0x87, 0xc6, 0x1e, 0x3b, 0x8b, 0x16, -0x96, 0xe5, 0xf8, 0xde, 0x3b, 0x41, 0x6d, 0x93, -0xc1, 0x25, 0x91, 0xe7, 0x41, 0xa5, 0x1e, 0xfc, -0x3a, 0x96, 0xaa, 0x6a, 0x9b, 0xca, 0x0c, 0x4a, -0xd5, 0x60, 0x37, 0x57, 0x62, 0xda, 0xc7, 0x2b, -0x2a, 0x51, 0x03, 0x3e, 0x89, 0x40, 0x07, 0xf0, -0x7b, 0x8a, 0x84, 0x20, 0xba, 0x52, 0x62, 0xff, -0x5b, 0xcc, 0x9b, 0xd0, 0x65, 0xd5, 0x42, 0xc6, -0xf7, 0xd8, 0x59, 0x8d, 0xcf, 0xbf, 0x4f, 0x22, -0x9d, 0x92, 0x9a, 0xc0, 0xa7, 0x85, 0x3b, 0xaa, -0xe9, 0xa0, 0x4c, 0x5c, 0x40, 0x87, 0xaa, 0x55, -0xf6, 0xfc, 0x88, 0xe3, 0x76, 0x45, 0xa8, 0x86, -0x22, 0x80, 0x22, 0xe6, 0x9b, 0x24, 0xa5, 0x08, -0x5f, 0x47, 0x63, 0x17, 0xfb, 0xab, 0x7d, 0x1a, -0x66, 0x67, 0xf0, 0xa7, 0x8c, 0xf9, 0xdf, 0xe4, -0xaf, 0x1c, 0xf4, 0x7f, 0xd3, 0x35, 0x2b, 0xb4, -0x49, 0xde, 0xe1, 0x09, 0xb4, 0x2e, 0x9f, 0x15, -0xd9, 0x54, 0xb1, 0x50, 0x63, 0x7f, 0x88, 0x8a, -0xa1, 0x17, 0xd4, 0x4a, 0x8a, 0x48, 0xdd, 0xf1, -0x5f, 0x98, 0x26, 0x4d, 0xa7, 0x10, 0x92, 0x2b, -0xd4, 0x69, 0x52, 0x47, 0x9b, 0xda, 0xaa, 0x29, -0x74, 0x9a, 0xbf, 0x03, 0x27, 0xaa, 0x42, 0x2f, -0x58, 0xcc, 0xfe, 0x22, 0xad, 0x19, 0xf3, 0xf3, -0x4b, 0x55, 0x0d, 0xb1, 0x69, 0x91, 0xe8, 0x26, -0x58, 0xf8, 0x00, 0xb4, 0x8a, 0x8a, 0xc6, 0x8c, -0x9b, 0x20, 0x44, 0xca, 0x8e, 0xdc, 0xbb, 0xb8, -0xf2, 0x05, 0x4f, 0x6b, 0x96, 0x3f, 0xec, 0x20, -0x7c, 0x92, 0x99, 0xf7, 0x0b, 0x49, 0xdf, 0x84, -0x59, 0x63, 0xd3, 0xd4, 0xe9, 0x2f, 0x4a, 0x77, -0xea, 0xb3, 0xa2, 0x05, 0xc1, 0x8e, 0xad, 0xf0, -0x4d, 0xee, 0x78, 0xd3, 0xff, 0xba, 0xca, 0x2a, -0x25, 0x99, 0x2d, 0x1b, 0xe8, 0x62, 0xef, 0xe3, -0x69, 0xd7, 0x14, 0x3d, 0x12, 0x5c, 0xe8, 0xf2, -0x68, 0x11, 0x45, 0xf9, 0xa5, 0x52, 0x19, 0xf1, -0x2f, 0x15, 0x33, 0xfc, 0xa1, 0xaa, 0xb8, 0x54, -0xd0, 0x64, 0x36, 0x33, 0x4a, 0xa1, 0xa0, 0x16, -0x41, 0x52, 0x08, 0x40, 0x1b, 0xfe, 0x21, 0x42, -0x42, 0x35, 0xd5, 0x40, 0x6c, 0x73, 0xbc, 0x7e, -0x50, 0x57, 0x62, 0x05, 0x1e, 0x08, 0x49, 0x41, -0x0a, 0xc1, 0xcf, 0x79, 0x94, 0x56, 0x69, 0x28, -0x12, 0x0c, 0xde, 0x8f, 0x6e, 0xf0, 0x21, 0x86, -0xf4, 0x3b, 0x40, 0x0c, 0xd9, 0xee, 0x96, 0x18, -0x7e, 0x96, 0x29, 0xe0, 0xa4, 0xab, 0x20, 0x51, -0xad, 0x1a, 0x34, 0x29, 0x54, 0x08, 0x51, 0xfe, -0xc2, 0xaa, 0x28, 0xe3, 0xff, 0x43, 0x1d, 0xfe, -0xd0, 0x78, 0x39, 0xf6, 0x9f, 0xa3, 0x2a, 0xd2, -0x1d, 0xcc, 0x8e, 0x72, 0x9f, 0xaa, 0xda, 0x0c, -0x6a, 0xdd, 0xdd, 0xd4, 0x14, 0x8c, 0x53, 0xaa, -0xa9, 0x0a, 0x28, 0x63, 0x94, 0xb2, 0xeb, 0x8a, -0x86, 0x46, 0x0c, 0x18, 0x62, 0xe6, 0x57, 0xf8, -0x4f, 0x2f, 0xdb, 0xfc, 0x61, 0x53, 0x47, 0xe4, -0x47, 0xf4, 0xc6, 0xef, 0xdf, 0xfd, 0x67, 0x91, -0xce, 0x8e, 0x99, 0xb4, 0xa9, 0xe2, 0x33, 0x0f, -0x76, 0x74, 0x2e, 0xfd, 0x2b, 0x76, 0xe5, 0x3b, -0xd7, 0x2c, 0x5d, 0x2d, 0xb4, 0xea, 0x4d, 0x57, -0xef, 0xa9, 0x70, 0x2e, 0x08, 0xbe, 0x66, 0x94, -0x72, 0x42, 0x09, 0xa5, 0xec, 0x7b, 0x6a, 0xd7, -0x22, 0x94, 0x2d, 0x31, 0x6d, 0x29, 0xe0, 0x40, -0x69, 0x59, 0x59, 0x99, 0x85, 0xae, 0xcc, 0x7f, -0xf5, 0x84, 0x74, 0xf3, 0x55, 0x58, 0x2f, 0x09, -0x1d, 0x7c, 0xa8, 0xf5, 0x82, 0x20, 0xf3, 0x75, -0x5f, 0x2f, 0x77, 0x2f, 0x5b, 0x66, 0xbf, 0x37, -0xed, 0x0d, 0xee, 0xc9, 0xf2, 0x0f, 0x57, 0xee, -0x99, 0xa4, 0x90, 0xf1, 0x2f, 0xfd, 0xeb, 0xc7, -0xef, 0x67, 0xdc, 0xbf, 0xe4, 0x4a, 0xcb, 0x64, -0xe6, 0xab, 0xd8, 0xee, 0x7f, 0xe3, 0x0d, 0xf3, -0xfe, 0xe7, 0xde, 0x37, 0x8c, 0xf7, 0x5b, 0xa6, -0xf2, 0x57, 0xf7, 0xb4, 0x98, 0xf7, 0xdf, 0xf3, -0x07, 0xf9, 0xb7, 0x67, 0x5b, 0x3e, 0x4e, 0xdd, -0x66, 0xfd, 0x17, 0x27, 0x3f, 0x9e, 0xe2, 0xfe, -0x2b, 0x0b, 0x8c, 0xd1, 0xb5, 0x5c, 0x99, 0x34, -0x8c, 0xeb, 0x26, 0xaf, 0x64, 0x3d, 0xff, 0x17, -0x4b, 0xc5, 0xf5, 0xda, 0x29, 0x65, 0x11, 0x14, -0xf4, 0x1b, 0x46, 0x59, 0xf1, 0x2f, 0xc4, 0x6f, -0x68, 0xb7, 0x5a, 0x46, 0xfb, 0x9f, 0x48, 0xc5, -0xfa, 0x42, 0xeb, 0xfe, 0xcf, 0x2e, 0x93, 0xbe, -0x21, 0xdc, 0xaa, 0x7d, 0x99, 0x05, 0xff, 0x02, -0x66, 0x2c, 0xfd, 0x72, 0x45, 0xf9, 0x00, 0x33, -0xda, 0xb4, 0x56, 0xa5, 0x7c, 0x40, 0x60, 0x57, -0xc2, 0x5f, 0x56, 0xca, 0xf5, 0xe9, 0x26, 0x5e, -0x05, 0x4a, 0x04, 0xb5, 0xab, 0x4d, 0x2d, 0x95, -0xa5, 0x88, 0xa0, 0xd2, 0x94, 0x51, 0xc9, 0x8c, -0x3f, 0x91, 0xa5, 0x7b, 0xcd, 0x2b, 0xd6, 0xf1, -0x3e, 0xb8, 0xf4, 0xd8, 0x5e, 0x75, 0x35, 0x5c, -0x05, 0xdb, 0xa8, 0x10, 0x46, 0x43, 0x29, 0xb8, -0x57, 0x08, 0x0b, 0xab, 0xc9, 0x55, 0x15, 0x05, -0x54, 0xb8, 0xad, 0x63, 0xb5, 0xf6, 0x25, 0x28, -0xb0, 0xdd, 0xff, 0xd9, 0xd5, 0x05, 0x0d, 0xc2, -0xe7, 0xe9, 0x97, 0x97, 0x4a, 0xdd, 0x05, 0xdf, -0x14, 0x6e, 0xa5, 0x5f, 0x56, 0xcb, 0x13, 0x05, -0x77, 0xa6, 0x0c, 0x21, 0x75, 0xc5, 0xf6, 0x3e, -0xbf, 0xd0, 0xc2, 0xaa, 0x22, 0x4b, 0x84, 0xb9, -0x3e, 0x08, 0x43, 0x05, 0x14, 0x82, 0x60, 0x19, -0x5d, 0x92, 0x79, 0x25, 0x3d, 0xde, 0x5f, 0x68, -0xd2, 0xed, 0x42, 0x05, 0xbd, 0x49, 0x85, 0x2d, -0x92, 0x4f, 0x90, 0xf5, 0x90, 0xaa, 0x74, 0x4b, -0x6a, 0x87, 0x4c, 0x43, 0x41, 0xe5, 0x5e, 0x49, -0x65, 0xce, 0x93, 0x5d, 0xb1, 0xdf, 0xbf, 0xbc, -0xe0, 0xe6, 0x8e, 0x5b, 0x62, 0xb7, 0xf8, 0x0b, -0x5c, 0x05, 0xa1, 0x8e, 0xf6, 0xf8, 0x2d, 0xfe, -0x72, 0x57, 0xc1, 0x52, 0xda, 0xce, 0xae, 0x94, -0x93, 0x02, 0x8d, 0xb6, 0xab, 0x65, 0x4d, 0xe5, -0xb0, 0x30, 0x3d, 0x3f, 0xb3, 0x84, 0x69, 0xda, -0x9f, 0xeb, 0xe5, 0xb7, 0x48, 0xb3, 0x84, 0x2f, -0xc3, 0x9f, 0xeb, 0xd3, 0xd7, 0x17, 0xdc, 0x2a, -0x7c, 0x11, 0x6e, 0xd1, 0xcb, 0x83, 0xcc, 0x10, -0xd1, 0x58, 0x2c, 0x59, 0xf4, 0x0f, 0xbb, 0xdf, -0xcf, 0x1c, 0x47, 0x29, 0x48, 0x54, 0xc1, 0xa6, -0x37, 0x4a, 0x58, 0x40, 0x48, 0x88, 0x2e, 0x90, -0x85, 0x11, 0x89, 0x7d, 0x49, 0x0a, 0x95, 0x14, -0x16, 0x10, 0xd2, 0xef, 0xb3, 0x96, 0xc8, 0x5a, -0x04, 0xd4, 0xae, 0x0a, 0x95, 0x30, 0xd7, 0x0f, -0x95, 0x54, 0x36, 0x0c, 0x95, 0x19, 0x85, 0x29, -0x63, 0x69, 0xfa, 0x7d, 0x7e, 0xd1, 0x5e, 0x50, -0x2d, 0xfc, 0x37, 0xf8, 0x92, 0x56, 0x1e, 0x2d, -0x58, 0x63, 0x1a, 0x61, 0xe1, 0x04, 0x7c, 0x09, -0x52, 0xc6, 0xff, 0x82, 0x72, 0xc7, 0xfc, 0x88, -0x61, 0x38, 0xc1, 0xfe, 0x5e, 0x05, 0x94, 0x1b, -0x0d, 0xd8, 0x41, 0xe7, 0x76, 0xf6, 0x87, 0xfb, -0x5b, 0x66, 0x4c, 0x63, 0x06, 0xbd, 0x8a, 0x19, -0xb6, 0xf5, 0xc3, 0x1c, 0x5b, 0x87, 0x07, 0x3d, -0x53, 0x44, 0x52, 0x3a, 0x3c, 0x95, 0xad, 0xb2, -0x72, 0x84, 0x5d, 0x91, 0xd4, 0x9b, 0x98, 0x01, -0xc1, 0x7e, 0x4f, 0x90, 0x5d, 0xd1, 0xd3, 0xef, -0xc3, 0xfe, 0x05, 0xd9, 0x9e, 0x4a, 0xc4, 0x95, -0x91, 0x32, 0x74, 0x6e, 0x10, 0x4c, 0xb6, 0x98, -0x57, 0x6c, 0xf3, 0x43, 0x84, 0x20, 0x5d, 0xa9, -0xce, 0x90, 0xcb, 0x22, 0x29, 0x43, 0x3a, 0x22, -0x04, 0xfb, 0xb9, 0xf1, 0x22, 0xf3, 0xe7, 0x2b, -0xd5, 0x2f, 0xca, 0x92, 0xed, 0xfe, 0x5f, 0x84, -0x0a, 0xc2, 0x1d, 0xab, 0x55, 0xb6, 0xa8, 0x22, -0x86, 0x21, 0x97, 0x33, 0xa3, 0x7f, 0xb5, 0x7a, -0x95, 0x5c, 0xde, 0x59, 0xa0, 0xf6, 0xaf, 0x0e, -0xb2, 0x2b, 0xd4, 0x36, 0x3f, 0x21, 0x3e, 0x73, -0xd6, 0x14, 0xa6, 0x0c, 0x8f, 0x1a, 0x32, 0x0d, -0x36, 0x34, 0xfb, 0x78, 0x6f, 0x96, 0xc2, 0x1d, -0x15, 0x95, 0x37, 0xb5, 0xc1, 0x43, 0xcc, 0xb8, -0x9a, 0x0d, 0x73, 0x7a, 0x44, 0x5a, 0xc3, 0x66, -0xe0, 0xa6, 0xb6, 0xe9, 0x0f, 0xb1, 0x85, 0xe4, -0x51, 0x5b, 0xdb, 0xa6, 0xd3, 0xe9, 0x56, 0xc8, -0xf8, 0x6c, 0xb8, 0x60, 0xb5, 0xf0, 0x25, 0xf8, -0x2c, 0x95, 0x54, 0x6e, 0xfc, 0x39, 0x2d, 0x0f, -0x4b, 0xab, 0xe1, 0x26, 0x6e, 0x08, 0x15, 0xcc, -0x98, 0x4e, 0xcb, 0x35, 0xdb, 0xf7, 0x55, 0x08, -0x7f, 0x46, 0x6f, 0x09, 0x97, 0x6f, 0x97, 0x0a, -0x05, 0xb6, 0xcc, 0xc2, 0x65, 0x15, 0x05, 0x68, -0xdc, 0x62, 0x1a, 0xfc, 0x0a, 0x0b, 0x41, 0xe6, -0xfd, 0xfd, 0xa5, 0x1c, 0x56, 0xdf, 0xdc, 0x06, -0xa5, 0xec, 0x13, 0x58, 0x6a, 0x7c, 0x0b, 0x12, -0xba, 0xf1, 0x36, 0x09, 0xaf, 0x70, 0xc3, 0xda, -0xee, 0x03, 0x0c, 0xdc, 0x44, 0xa6, 0xd3, 0xae, -0xf0, 0xd7, 0x2a, 0x2a, 0x6e, 0x12, 0xff, 0x8c, -0xbe, 0x1a, 0xfe, 0x4c, 0x45, 0x31, 0x1a, 0xdb, -0xb8, 0x31, 0x6d, 0xba, 0x71, 0x45, 0x4b, 0xcf, -0x4f, 0xd7, 0x4d, 0x05, 0xdf, 0xe8, 0x40, 0x27, -0x70, 0xed, 0x0b, 0x45, 0x68, 0xfc, 0x49, 0x45, -0xf9, 0x0b, 0xec, 0xca, 0x29, 0xed, 0xcb, 0x68, -0xdc, 0xd6, 0x71, 0x2a, 0xfc, 0xb7, 0x15, 0xe5, -0x76, 0x7f, 0x72, 0x93, 0xf0, 0x0d, 0x7a, 0x2a, -0xbc, 0xa8, 0xa2, 0xf8, 0x05, 0x11, 0x8d, 0x69, -0x86, 0x71, 0xab, 0x71, 0xe5, 0x36, 0x8a, 0x4f, -0xb8, 0x56, 0x9f, 0x6e, 0xbb, 0x5f, 0xe2, 0xcf, -0x5f, 0xdd, 0xf6, 0x42, 0x41, 0xfa, 0xf9, 0x1b, -0x3d, 0x61, 0x7c, 0x3e, 0x2c, 0xec, 0xf0, 0x84, -0x5b, 0x2b, 0xec, 0xdf, 0x3b, 0xe0, 0x7a, 0x40, -0x27, 0x03, 0x86, 0xff, 0x69, 0x37, 0x1c, 0xd1, -0xad, 0xa6, 0x47, 0xba, 0x15, 0x1d, 0x11, 0xb5, -0xad, 0xb6, 0x42, 0xe1, 0x36, 0xba, 0x3a, 0x7c, -0x55, 0x05, 0xf3, 0x4e, 0x86, 0xc1, 0xfc, 0x0f, -0x73, 0x3b, 0x86, 0x51, 0xc9, 0x8c, 0x2f, 0x55, -0x94, 0xdb, 0xee, 0xff, 0xac, 0x56, 0x1e, 0x14, -0x56, 0xc2, 0x17, 0x41, 0xd2, 0x0b, 0xd6, 0x0b, -0xb7, 0xc2, 0x97, 0xa1, 0x3c, 0x6d, 0x08, 0xc1, -0x94, 0x91, 0x7e, 0x9f, 0xcf, 0xb6, 0x82, 0x1a, -0x93, 0xfd, 0x0c, 0x4d, 0x45, 0x20, 0x4c, 0x2b, -0xd8, 0x27, 0x28, 0xa4, 0x0d, 0x49, 0x35, 0x0c, -0x6a, 0x1b, 0xef, 0x72, 0x29, 0xbc, 0xa3, 0x42, -0xbd, 0x89, 0xdd, 0x8f, 0x6e, 0x87, 0x2d, 0x33, -0xc5, 0x66, 0x84, 0x0d, 0xc3, 0x7e, 0xbf, 0x36, -0xa7, 0x7d, 0xe9, 0x2d, 0xa5, 0x7f, 0x0e, 0x5d, -0xcc, 0xdb, 0x74, 0xb4, 0x57, 0xde, 0x22, 0x73, -0xb7, 0xf3, 0x67, 0x2a, 0x33, 0xc4, 0x82, 0x76, -0xf4, 0x3f, 0x72, 0x01, 0xd8, 0xe6, 0xc7, 0x2d, -0xb4, 0x27, 0x6e, 0x09, 0x96, 0xcb, 0x52, 0xab, -0xd0, 0xae, 0xdf, 0xa2, 0x96, 0x7b, 0x0a, 0xb8, -0x11, 0x64, 0x46, 0xc8, 0x30, 0xe4, 0x02, 0xcd, -0x36, 0x3f, 0xa0, 0x85, 0x15, 0x45, 0x92, 0x04, -0xc4, 0x2f, 0xa0, 0x74, 0x14, 0x72, 0x17, 0xc8, -0xb6, 0x65, 0xcc, 0x17, 0x02, 0x5e, 0xe1, 0x46, -0x1a, 0x01, 0x7d, 0xb6, 0xf5, 0xff, 0x69, 0xef, -0xfc, 0x42, 0xe3, 0x38, 0xee, 0x38, 0xfe, 0x9b, -0xbb, 0xd9, 0xf3, 0x9e, 0x7d, 0x72, 0x77, 0xa5, -0xbd, 0x66, 0xd5, 0x08, 0xb3, 0xfa, 0x53, 0x4b, -0xa6, 0xa4, 0xac, 0x82, 0x95, 0xba, 0x08, 0xa2, -0x39, 0xdd, 0x9d, 0x7c, 0x12, 0x8e, 0x7c, 0x96, -0x1c, 0xc5, 0x18, 0x53, 0xd6, 0x46, 0x34, 0x26, -0x50, 0x90, 0x0d, 0xa5, 0xee, 0x43, 0x9d, 0x39, -0xf5, 0x9c, 0xaa, 0xc5, 0x85, 0x8b, 0xac, 0x62, -0x19, 0x04, 0x3d, 0x13, 0xd5, 0xf4, 0x25, 0xd0, -0x42, 0x8d, 0xf3, 0xd6, 0x93, 0x62, 0xab, 0x2e, -0xf4, 0xc1, 0xa4, 0xaa, 0xc9, 0x43, 0xa9, 0x6c, -0xd0, 0x4b, 0xa1, 0x26, 0x2f, 0x86, 0xa2, 0x16, -0x45, 0xfd, 0xcd, 0xec, 0xdd, 0xed, 0xc8, 0x0d, -0x86, 0xa4, 0xd0, 0x42, 0x99, 0xef, 0xd3, 0x97, -0xd9, 0xb9, 0xd5, 0x6f, 0x67, 0x67, 0x7e, 0xf3, -0xf9, 0xed, 0xea, 0xa4, 0x58, 0x17, 0xe7, 0x37, -0xbd, 0xc2, 0xe2, 0xac, 0x04, 0x54, 0x30, 0x05, -0x52, 0xf2, 0x52, 0x9f, 0x87, 0x26, 0x21, 0x5a, -0xd0, 0x28, 0xf1, 0xe4, 0xd9, 0x1e, 0xcc, 0xf6, -0x30, 0x15, 0x4f, 0x73, 0x43, 0x98, 0x87, 0x20, -0x0c, 0x7c, 0x4c, 0x31, 0xff, 0xe0, 0x8e, 0x50, -0xcf, 0x3f, 0xd1, 0xf5, 0x5e, 0x61, 0x69, 0xb1, -0x4d, 0xbc, 0x12, 0xff, 0x29, 0x8f, 0x37, 0xf3, -0x4f, 0x00, 0x67, 0xa8, 0x30, 0x7b, 0x3c, 0x1c, -0xff, 0x17, 0xd0, 0xa8, 0xf1, 0xcb, 0xa4, 0x91, -0xa5, 0x9c, 0x3b, 0x3e, 0x49, 0x89, 0xd4, 0x59, -0xa3, 0x3e, 0x71, 0x63, 0xc2, 0xe0, 0xbc, 0x17, -0x2b, 0x0c, 0x4d, 0x24, 0x1a, 0x26, 0x19, 0x86, -0xc5, 0x6e, 0x3f, 0xa4, 0x82, 0x78, 0x11, 0xd6, -0xe1, 0x30, 0x62, 0x2d, 0xb6, 0xac, 0x83, 0x40, -0xdf, 0x98, 0xc8, 0x48, 0x4a, 0x7f, 0xa3, 0x9f, -0x1d, 0x2b, 0xb6, 0x2d, 0x94, 0x7f, 0x47, 0xfa, -0x6b, 0xc7, 0x58, 0x9b, 0x93, 0xbb, 0x47, 0xfa, -0x33, 0xe3, 0xc5, 0x36, 0x87, 0xde, 0x25, 0x9d, -0xb9, 0x63, 0xc5, 0x49, 0x8b, 0xaa, 0xfd, 0xbb, -0x8d, 0xf3, 0x2b, 0xdf, 0xf2, 0xa7, 0xe6, 0xe8, -0x7b, 0x68, 0x4e, 0xfb, 0x53, 0x57, 0xd3, 0xd2, -0x78, 0xa1, 0xa9, 0xc9, 0x16, 0x35, 0x7e, 0x23, -0xfc, 0xf6, 0x14, 0x6b, 0x14, 0xdf, 0x45, 0x58, -0xc0, 0x18, 0x65, 0x3c, 0x0b, 0x8d, 0x78, 0x76, -0x5d, 0x6f, 0x2e, 0xb0, 0x5d, 0x3a, 0x42, 0x60, -0x2e, 0xdc, 0xc8, 0x7c, 0x1b, 0x8d, 0xed, 0x96, -0xb3, 0x9d, 0x36, 0x9f, 0x3e, 0x67, 0xb9, 0xe5, -0x11, 0x34, 0x6a, 0xff, 0xb3, 0x45, 0x3b, 0x47, -0xf3, 0xc4, 0x61, 0x46, 0xd1, 0x3e, 0x49, 0x5f, -0x27, 0xe9, 0x5c, 0xbe, 0xe8, 0x9d, 0xa4, 0x27, -0x20, 0x9d, 0xbb, 0x27, 0x5a, 0xd2, 0x24, 0xad, -0xce, 0x07, 0xb3, 0x53, 0xa4, 0x40, 0xcb, 0x2b, -0x9b, 0xa2, 0xec, 0x99, 0x75, 0xc4, 0x7f, 0x28, -0x6e, 0x98, 0xce, 0x09, 0x57, 0x98, 0x2b, 0xea, -0xe9, 0xf7, 0x1a, 0xb1, 0x12, 0x54, 0xa1, 0x0f, -0xf6, 0x92, 0x18, 0x67, 0x55, 0xab, 0x8f, 0xa2, -0xa9, 0x44, 0xe6, 0x16, 0x1a, 0xb5, 0x7f, 0x2a, -0x31, 0x49, 0xca, 0xb5, 0x4e, 0x1f, 0x8e, 0xc5, -0x27, 0x61, 0xbd, 0x36, 0xe0, 0xb7, 0x44, 0xe6, -0xe0, 0xa4, 0x75, 0xf2, 0xee, 0xc0, 0xcb, 0x2d, -0x6a, 0x3c, 0x49, 0xe3, 0x62, 0xe6, 0x4c, 0xe5, -0x0d, 0xcf, 0xbe, 0x4f, 0x71, 0xf7, 0x9f, 0x7d, -0xc1, 0x33, 0xee, 0x23, 0x18, 0xfc, 0x39, 0x04, -0x83, 0x8b, 0xf1, 0x25, 0xfe, 0x3d, 0xef, 0x67, -0xea, 0xf8, 0xbf, 0x38, 0x36, 0xfc, 0xb0, 0x72, -0x7b, 0xf9, 0xa5, 0xe4, 0x3e, 0x61, 0x7e, 0xb3, -0xfc, 0xd2, 0xe8, 0xbe, 0x89, 0xb1, 0x07, 0xf3, -0xb7, 0x7b, 0xde, 0x4f, 0xee, 0x1b, 0x1e, 0x5b, -0x17, 0xe6, 0x90, 0x1a, 0xcf, 0xe0, 0xdb, 0xe3, -0x3b, 0x7f, 0xfc, 0xed, 0xd3, 0x27, 0x5b, 0xd2, -0xdc, 0x79, 0xfa, 0xc9, 0xd6, 0xe0, 0xa7, 0xc7, -0x37, 0xae, 0xed, 0x6c, 0x6e, 0x6f, 0x0d, 0x5e, -0x3e, 0xbe, 0x23, 0xcc, 0x36, 0xfc, 0x07, 0x7a, -0xf5, 0x46, 0xf2, 0xe0, 0xf0, 0x68, 0x65, 0x7e, -0x7a, 0x68, 0xeb, 0x4b, 0xb7, 0xb2, 0x3b, 0x95, -0x7f, 0xfc, 0xe0, 0xd5, 0x9f, 0x8f, 0xbe, 0xfd, -0xd1, 0x68, 0xe5, 0xfa, 0xf6, 0xd0, 0xce, 0x68, -0xef, 0x47, 0xa3, 0x4f, 0xaf, 0x6f, 0xaa, 0xfd, -0x87, 0x2e, 0x8f, 0x6f, 0x5c, 0xbb, 0xb3, 0xf9, -0x64, 0x6b, 0xa8, 0x1e, 0xc6, 0xf6, 0x90, 0x0c, -0x6c, 0xf3, 0x13, 0xec, 0x3f, 0xbe, 0x21, 0x23, -0x54, 0xfb, 0x77, 0x1f, 0x28, 0x6c, 0xcc, 0x7f, -0x63, 0xf3, 0xea, 0xd9, 0x41, 0xf1, 0xc1, 0x5f, -0xe3, 0x07, 0xd1, 0xfc, 0xa5, 0xed, 0x4e, 0xf9, -0xc9, 0x56, 0xb7, 0x2b, 0xcd, 0xdf, 0xbe, 0xbf, -0x2b, 0xa0, 0xec, 0x0c, 0x5b, 0xb2, 0x7a, 0x5b, -0x93, 0xb5, 0xae, 0x99, 0xcc, 0x12, 0xbc, 0x49, -0x5b, 0x56, 0x40, 0xb6, 0xd0, 0xe4, 0x4a, 0x0c, -0x8d, 0xdf, 0x4b, 0x89, 0x3a, 0x9e, 0x38, 0xff, -0x05, 0x1f, 0xba, 0x20, 0xb0, 0x50, 0x80, 0xa2, -0x7d, 0x57, 0x24, 0x6a, 0x34, 0x98, 0xa8, 0x4f, -0xc8, 0x16, 0x43, 0xed, 0x1f, 0x23, 0x81, 0xc8, -0xcf, 0x2e, 0x34, 0xf9, 0x70, 0x95, 0x78, 0x20, -0x8d, 0xe4, 0xc3, 0xa0, 0x75, 0x77, 0x7e, 0x46, -0xe6, 0x11, 0x90, 0x16, 0x2b, 0x21, 0xb6, 0xc9, -0xfd, 0xb0, 0xc4, 0x43, 0x6c, 0x73, 0x11, 0xe4, -0xce, 0x72, 0xc1, 0x6f, 0x27, 0xd4, 0xfe, 0x66, -0xee, 0x62, 0x32, 0xc5, 0xb3, 0x06, 0xcc, 0x4d, -0xbf, 0x0c, 0x1d, 0xe5, 0x3d, 0xe1, 0xc4, 0xe8, -0xe0, 0x47, 0x9b, 0xa6, 0xc7, 0x56, 0xe3, 0x01, -0x08, 0xea, 0x7c, 0x88, 0xd4, 0xe5, 0x5a, 0x2a, -0x1f, 0x2a, 0x26, 0x52, 0x12, 0xb1, 0x10, 0x97, -0x55, 0x20, 0xd6, 0x97, 0xfc, 0x5a, 0xa3, 0x55, -0xa1, 0xbd, 0x04, 0xf9, 0x30, 0xb0, 0x16, 0xe9, -0x41, 0x92, 0xe4, 0xc3, 0xc5, 0x5d, 0xcf, 0xac, -0x0e, 0xd1, 0xb1, 0xd2, 0x97, 0xab, 0xf9, 0x0f, -0xec, 0x3e, 0x7a, 0xba, 0xdc, 0x7a, 0x93, 0xfe, -0xd2, 0xee, 0x82, 0xb1, 0x52, 0x6b, 0x35, 0xf7, -0x81, 0xfd, 0x75, 0x2a, 0xcd, 0x9c, 0xf2, 0x76, -0xdc, 0xac, 0xb5, 0x40, 0x1b, 0x38, 0x0f, 0x8c, -0x8a, 0x24, 0x1d, 0xa7, 0x06, 0xbf, 0x92, 0xbb, -0x8d, 0x53, 0x33, 0xfc, 0xc8, 0xb0, 0xe8, 0x03, -0x35, 0x8a, 0xc9, 0x17, 0x2f, 0x60, 0x02, 0xde, -0x01, 0x59, 0xec, 0x31, 0x1c, 0xa4, 0x00, 0xeb, -0x3c, 0x6a, 0x92, 0xb0, 0xcc, 0xa5, 0xc8, 0x8c, -0x7e, 0x74, 0x7e, 0xf1, 0xf8, 0x8e, 0x5b, 0x1e, -0x16, 0xeb, 0x22, 0x71, 0x58, 0xf2, 0x81, 0x1b, -0x35, 0xc5, 0x93, 0xbb, 0x39, 0xab, 0x8b, 0x9a, -0xa5, 0x18, 0x1e, 0xda, 0xd5, 0xbf, 0x3e, 0xec, -0x32, 0xd1, 0xbb, 0x98, 0xf1, 0x6d, 0x9e, 0x68, -0x80, 0x09, 0x0d, 0x4d, 0x3b, 0x6f, 0xf6, 0xb7, -0x08, 0x8b, 0x05, 0xe2, 0x8b, 0x32, 0x82, 0xcc, -0x84, 0xc1, 0xd1, 0xbb, 0x0f, 0xd3, 0xa2, 0x45, -0xfc, 0xea, 0xf1, 0x34, 0xdc, 0x80, 0x83, 0x1e, -0x89, 0x9e, 0x28, 0xb0, 0x3a, 0x1f, 0x66, 0x0b, -0xb8, 0xdf, 0x49, 0x50, 0x2c, 0xe0, 0xb6, 0xe8, -0xff, 0x58, 0x80, 0x62, 0x65, 0xb5, 0x47, 0x1e, -0x32, 0x2b, 0xb5, 0xe6, 0xef, 0x43, 0x32, 0xf8, -0x77, 0x3e, 0xe4, 0xac, 0x81, 0x85, 0x4d, 0xd3, -0xfc, 0x7b, 0x11, 0x0c, 0xd3, 0xa3, 0x2f, 0x21, -0xcd, 0x9a, 0xad, 0x1b, 0xf8, 0x90, 0xd6, 0xcd, -0x6a, 0xd8, 0x92, 0xb2, 0x6a, 0x56, 0x14, 0x0f, -0x13, 0xfc, 0xe6, 0x8d, 0xe0, 0x4d, 0x17, 0x06, -0x90, 0xdf, 0x7e, 0x28, 0x2e, 0xd3, 0x93, 0xd7, -0xcb, 0xf0, 0xd0, 0x04, 0xb5, 0x79, 0x14, 0x0f, -0xf9, 0x2c, 0x3e, 0xf4, 0x9f, 0x69, 0xa9, 0x35, -0x2b, 0xda, 0x22, 0x19, 0x0e, 0xcf, 0x2f, 0x78, -0x38, 0x34, 0xb6, 0xb8, 0xf0, 0xba, 0x11, 0x2d, -0xb8, 0xbf, 0x47, 0xf3, 0x53, 0xc4, 0x53, 0x24, -0x0e, 0xe4, 0xd1, 0xd7, 0x8d, 0x8d, 0x37, 0xb5, -0x6e, 0x1a, 0x87, 0x86, 0x9b, 0xfb, 0x69, 0x01, -0x07, 0x3c, 0xc3, 0x9d, 0xc0, 0x70, 0x89, 0x58, -0x17, 0x56, 0x40, 0x85, 0xc9, 0x3c, 0x63, 0xa2, -0xe9, 0x53, 0x00, 0x31, 0xf3, 0x4d, 0x9c, 0x05, -0x8e, 0x88, 0x96, 0xd5, 0x6b, 0xa5, 0x72, 0xc3, -0x84, 0x2d, 0xa0, 0xc4, 0x33, 0x85, 0x34, 0x58, -0x0e, 0x3a, 0x4f, 0xb9, 0x53, 0x08, 0x8a, 0x7f, -0x0a, 0xd2, 0xae, 0xd1, 0x00, 0xc5, 0x54, 0x93, -0x18, 0x15, 0x5e, 0x25, 0x82, 0xdf, 0x3a, 0x82, -0xa3, 0x96, 0xb3, 0x26, 0xcd, 0x9b, 0x56, 0xfb, -0x5a, 0xe2, 0xbb, 0x04, 0x5b, 0x8a, 0xce, 0x3a, -0x96, 0x96, 0x1d, 0xec, 0xe8, 0xa9, 0x43, 0xca, -0xf5, 0x92, 0x84, 0x73, 0x81, 0x77, 0x04, 0xbd, -0x2e, 0x59, 0x8b, 0x5d, 0xe0, 0x4b, 0x68, 0x92, -0x6b, 0x20, 0x4c, 0x1b, 0x9a, 0xd8, 0x85, 0x92, -0x68, 0x51, 0xf2, 0x49, 0x31, 0x3f, 0x22, 0xe9, -0xf1, 0x0d, 0xd7, 0x8c, 0xf8, 0x90, 0x0e, 0x94, -0xcf, 0x04, 0x6d, 0xa7, 0xd2, 0x0f, 0xc9, 0x85, -0x2b, 0x02, 0x1d, 0xed, 0xd5, 0x66, 0x3c, 0x0c, -0xa1, 0x57, 0xa6, 0x1d, 0xe4, 0x73, 0x34, 0xa3, -0x21, 0x16, 0xce, 0xf0, 0xdd, 0x15, 0xab, 0x12, -0x0f, 0xce, 0x64, 0x4c, 0x32, 0x41, 0x62, 0x11, -0x6e, 0xa1, 0xf9, 0x4a, 0x80, 0x69, 0xe7, 0x1d, -0x2a, 0x5b, 0xd0, 0x84, 0x87, 0x5c, 0x75, 0x3f, -0xcd, 0x07, 0x70, 0x89, 0xec, 0x87, 0xec, 0x2c, -0x3c, 0x2a, 0x1f, 0x21, 0x07, 0x20, 0xcb, 0xed, -0x47, 0xf4, 0x12, 0x9a, 0xa3, 0x68, 0x7a, 0x2e, -0x81, 0x34, 0x11, 0x1f, 0x32, 0x32, 0x01, 0xde, -0x32, 0xf2, 0x21, 0xc6, 0xc3, 0x3d, 0xde, 0xee, -0xc7, 0x10, 0x0b, 0xf9, 0xb4, 0xc0, 0xc2, 0x02, -0x99, 0xe7, 0x41, 0x68, 0xb8, 0x12, 0x0f, 0xce, -0xb7, 0x9b, 0x72, 0xfe, 0xfc, 0xa4, 0x8c, 0x34, -0x58, 0xc5, 0x32, 0x6a, 0xb6, 0xdc, 0xe0, 0xc3, -0xb2, 0x98, 0x6f, 0x82, 0x0f, 0xd5, 0xf5, 0x45, -0x20, 0xe3, 0xb4, 0x86, 0xf3, 0xa7, 0x64, 0x79, -0x79, 0x13, 0x59, 0x8a, 0xa1, 0xc9, 0xa1, 0xa1, -0xa1, 0xc9, 0x44, 0x3c, 0xc6, 0x18, 0x96, 0x94, -0xf7, 0x1d, 0xdf, 0x30, 0x61, 0x2f, 0xae, 0x23, -0xa7, 0x4a, 0x52, 0x24, 0xeb, 0x15, 0x6b, 0xd8, -0x82, 0x06, 0xea, 0x86, 0x91, 0x28, 0x1e, 0x93, -0xfa, 0xb6, 0xe4, 0x43, 0xce, 0xba, 0x30, 0xdb, -0xc4, 0x91, 0x0f, 0x59, 0x1d, 0x0b, 0x9b, 0x06, -0x94, 0xf5, 0x35, 0xec, 0xb5, 0x96, 0x78, 0xd5, -0x33, 0x17, 0x63, 0x5d, 0x48, 0x83, 0x58, 0x62, -0x0b, 0x3e, 0x9c, 0x43, 0x12, 0xdb, 0x3b, 0x87, -0x09, 0xa3, 0x22, 0xf8, 0x70, 0x0e, 0x94, 0xf5, -0xc5, 0xae, 0xca, 0x24, 0x83, 0x39, 0xb7, 0xec, -0x49, 0x53, 0xc2, 0xfc, 0x63, 0xbb, 0xf0, 0x6d, -0x62, 0xf3, 0x3f, 0x04, 0x16, 0xa2, 0x4e, 0xac, -0x9d, 0x37, 0xd7, 0x17, 0xf6, 0xe7, 0xd3, 0xd0, -0x0e, 0x89, 0x8c, 0x59, 0xe1, 0x01, 0xdc, 0x88, -0x63, 0x46, 0xae, 0xc0, 0x4c, 0x1f, 0xe6, 0x9f, -0x18, 0xa9, 0xac, 0x61, 0x8e, 0x46, 0x53, 0x52, -0xd7, 0x57, 0xc0, 0x8e, 0xc0, 0x7e, 0x88, 0xcf, -0xd6, 0xaa, 0xfc, 0x08, 0xd9, 0x4f, 0xb2, 0xbc, -0xf2, 0x88, 0x9e, 0x6f, 0x11, 0x77, 0x90, 0x3f, -0x9a, 0x3e, 0x92, 0xdc, 0x1f, 0xc7, 0x3b, 0xc8, -0x9b, 0xe3, 0x53, 0xc4, 0xf2, 0xfb, 0x9b, 0xc1, -0xfe, 0x53, 0xf1, 0x05, 0xf8, 0x05, 0xf8, 0x2c, -0x65, 0xc5, 0x29, 0x7c, 0x88, 0xb9, 0x53, 0x9a, -0x95, 0x46, 0x8b, 0x7a, 0xbf, 0x28, 0x0c, 0xb0, -0x96, 0x62, 0x7c, 0xa2, 0xb2, 0xc0, 0xfb, 0x59, -0x4b, 0x26, 0xee, 0xc0, 0x3d, 0xda, 0x5f, 0x48, -0x15, 0x43, 0xc3, 0x52, 0x13, 0x71, 0xc7, 0x5a, -0x25, 0x56, 0x33, 0x9e, 0x2c, 0x0d, 0x56, 0x5c, -0x7f, 0xc4, 0x85, 0x1f, 0x95, 0x99, 0x30, 0xa6, -0x7d, 0x2d, 0x6c, 0x49, 0xd9, 0xd7, 0x21, 0x58, -0x29, 0x08, 0xc3, 0x2d, 0x65, 0x7c, 0xa0, 0x1b, -0xb3, 0xb4, 0xfa, 0xf2, 0xe4, 0xee, 0x67, 0xbc, -0xd7, 0x8a, 0xd6, 0x57, 0xa1, 0xc1, 0x87, 0x3c, -0x77, 0x4e, 0x98, 0x4e, 0xeb, 0x63, 0xe4, 0x43, -0x4b, 0x60, 0xe1, 0x22, 0x9c, 0xb3, 0xcd, 0x90, -0x0f, 0x9b, 0xe3, 0x99, 0x67, 0xb9, 0xd7, 0xed, -0xb4, 0x93, 0xcf, 0xf3, 0x13, 0xd3, 0x45, 0xdb, -0x31, 0xf2, 0xc4, 0x62, 0x0c, 0xd3, 0x8e, 0x81, -0xf9, 0x27, 0x07, 0xd8, 0x42, 0xf3, 0x40, 0xa2, -0xf5, 0x8e, 0xf3, 0x21, 0xac, 0x8c, 0xbb, 0x64, -0xe6, 0xb3, 0x66, 0x0d, 0x39, 0x37, 0x41, 0x14, -0x31, 0xc4, 0xac, 0xd7, 0x0b, 0x25, 0x88, 0x78, -0x5e, 0xf0, 0x21, 0x87, 0x2a, 0x43, 0x1a, 0xa4, -0xb1, 0x32, 0x43, 0x50, 0xa4, 0x2a, 0x28, 0x86, -0x26, 0xea, 0xcd, 0xf2, 0xaf, 0x91, 0x49, 0x46, -0x1f, 0x9c, 0x7d, 0xc5, 0x6d, 0x49, 0xb4, 0xb1, -0xf5, 0x07, 0x9d, 0x87, 0x53, 0x2d, 0xf1, 0x49, -0x34, 0x03, 0x87, 0x8d, 0xd7, 0xea, 0x46, 0xc9, -0x3f, 0x78, 0xbd, 0x3d, 0x17, 0x33, 0x4b, 0xc8, -0x87, 0xef, 0xfe, 0xbe, 0x47, 0xec, 0xfe, 0x7b, -0xbc, 0x74, 0x2d, 0x31, 0x23, 0x79, 0xa0, 0xbd, -0x01, 0x06, 0x4a, 0xfe, 0x01, 0xf8, 0xda, 0x5b, -0x23, 0x0f, 0xdf, 0xbd, 0xbd, 0xfc, 0x9d, 0x1b, -0x2f, 0xbe, 0x35, 0x26, 0xf8, 0xf0, 0xfd, 0x3a, -0x1f, 0x2e, 0x47, 0x7c, 0xb8, 0xeb, 0x19, 0xf7, -0x50, 0xc4, 0x87, 0xc7, 0x05, 0x1f, 0xee, 0xd4, -0xf9, 0xf0, 0x69, 0xc4, 0x87, 0xbb, 0x78, 0xec, -0xf3, 0xea, 0xab, 0x02, 0x0b, 0xff, 0x5a, 0xd9, -0xd9, 0x1e, 0xda, 0xaa, 0x83, 0x22, 0x12, 0xe3, -0x73, 0xf8, 0x50, 0xfe, 0xf4, 0xbf, 0x6f, 0x62, -0xff, 0x4f, 0x1b, 0xa0, 0x78, 0xf9, 0x79, 0x7c, -0x38, 0xd8, 0xe0, 0xc3, 0xee, 0x03, 0xe3, 0x1b, -0xf3, 0xfd, 0x9b, 0x4f, 0x1e, 0x0f, 0x5d, 0x7a, -0xa6, 0xff, 0xe3, 0x2f, 0x1e, 0xbd, 0x0f, 0x1e, -0x11, 0x2f, 0x28, 0x7c, 0xc8, 0xa6, 0xbe, 0xf8, -0x59, 0xb4, 0xb4, 0xb4, 0xb4, 0xb4, 0xb4, 0xb4, -0xb4, 0xb4, 0xb4, 0xb4, 0xfe, 0xdf, 0x25, 0x6b, -0x07, 0xaa, 0x6b, 0x07, 0x2d, 0x2d, 0x2d, 0x2d, -0x2d, 0x2d, 0x2d, 0x2d, 0x2d, 0x2d, 0xad, 0xe7, -0x4b, 0xd6, 0x0e, 0x09, 0x5d, 0x3b, 0x68, 0x69, -0x69, 0x69, 0x69, 0x69, 0x69, 0x69, 0x69, 0x69, -0x69, 0x3d, 0x5f, 0xb2, 0x76, 0x30, 0x65, 0xed, -0xf0, 0xbf, 0x0e, 0x45, 0x4b, 0x4b, 0x4b, 0x4b, -0x4b, 0x4b, 0x4b, 0x4b, 0x4b, 0x4b, 0xeb, 0xbf, -0x28, 0x5f, 0xfc, 0xd1, 0x24, 0xf8, 0xe7, 0x79, -0x1f, 0xb8, 0xf8, 0xce, 0x53, 0xdc, 0x07, 0xf6, -0xb9, 0xdf, 0x27, 0xd4, 0x3f, 0x6b, 0xf8, 0x50, -0x25, 0xd1, 0x39, 0x1f, 0x9f, 0x7e, 0xb6, 0xdf, -0xbf, 0x00, 0x34, 0x34, 0xbf, 0x69, 0xee, 0x33, -0x01, 0x00, diff --git a/board/esd/wuh405/wuh405.c b/board/esd/wuh405/wuh405.c deleted file mode 100644 index 71d16e4..0000000 --- a/board/esd/wuh405/wuh405.c +++ /dev/null @@ -1,171 +0,0 @@ -/* - * (C) Copyright 2001-2003 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/processor.h> -#include <command.h> -#include <malloc.h> - -/* ------------------------------------------------------------------------- */ - -#if 0 -#define FPGA_DEBUG -#endif - -/* fpga configuration data - gzip compressed and generated by bin2c */ -const unsigned char fpgadata[] = -{ -#include "fpgadata.c" -}; - -/* - * include common fpga code (for esd boards) - */ -#include "../common/fpga.c" - - -int board_early_init_f (void) -{ - /* - * IRQ 0-15 405GP internally generated; active high; level sensitive - * IRQ 16 405GP internally generated; active low; level sensitive - * IRQ 17-24 RESERVED - * IRQ 25 (EXT IRQ 0) CAN0; active low; level sensitive - * IRQ 26 (EXT IRQ 1) SER0 ; active low; level sensitive - * IRQ 27 (EXT IRQ 2) SER1; active low; level sensitive - * IRQ 28 (EXT IRQ 3) FPGA 0; active low; level sensitive - * IRQ 29 (EXT IRQ 4) FPGA 1; active low; level sensitive - * IRQ 30 (EXT IRQ 5) PCI INTA; active low; level sensitive - * IRQ 31 (EXT IRQ 6) COMPACT FLASH; active high; level sensitive - */ - mtdcr(UIC0SR, 0xFFFFFFFF); /* clear all ints */ - mtdcr(UIC0ER, 0x00000000); /* disable all ints */ - mtdcr(UIC0CR, 0x00000000); /* set all to be non-critical*/ - mtdcr(UIC0PR, 0xFFFFFF9F); /* set int polarities */ - mtdcr(UIC0TR, 0x10000000); /* set int trigger levels */ - mtdcr(UIC0VCR, 0x00000001); /* set vect base=0,INT0 highest priority*/ - mtdcr(UIC0SR, 0xFFFFFFFF); /* clear all ints */ - - /* - * EBC Configuration Register: set ready timeout to 512 ebc-clks -> ca. 15 us - */ - mtebc (EBC0_CFG, 0xa8400000); /* ebc always driven */ - - return 0; -} - -int misc_init_r (void) -{ - unsigned char *dst; - ulong len = sizeof(fpgadata); - int status; - int index; - int i; - - dst = malloc(CONFIG_SYS_FPGA_MAX_SIZE); - if (gunzip (dst, CONFIG_SYS_FPGA_MAX_SIZE, (uchar *)fpgadata, &len) != 0) { - printf ("GUNZIP ERROR - must RESET board to recover\n"); - do_reset (NULL, 0, 0, NULL); - } - - status = fpga_boot(dst, len); - if (status != 0) { - printf("\nFPGA: Booting failed "); - switch (status) { - case ERROR_FPGA_PRG_INIT_LOW: - printf("(Timeout: INIT not low after asserting PROGRAM*)\n "); - break; - case ERROR_FPGA_PRG_INIT_HIGH: - printf("(Timeout: INIT not high after deasserting PROGRAM*)\n "); - break; - case ERROR_FPGA_PRG_DONE: - printf("(Timeout: DONE not high after programming FPGA)\n "); - break; - } - - /* display infos on fpgaimage */ - index = 15; - for (i=0; i<4; i++) { - len = dst[index]; - printf("FPGA: %s\n", &(dst[index+1])); - index += len+3; - } - putc ('\n'); - /* delayed reboot */ - for (i=20; i>0; i--) { - printf("Rebooting in %2d seconds \r",i); - for (index=0;index<1000;index++) - udelay(1000); - } - putc ('\n'); - do_reset(NULL, 0, 0, NULL); - } - - puts("FPGA: "); - - /* display infos on fpgaimage */ - index = 15; - for (i=0; i<4; i++) { - len = dst[index]; - printf("%s ", &(dst[index+1])); - index += len+3; - } - putc ('\n'); - - free(dst); - - /* - * Reset FPGA via FPGA_DATA pin - */ - SET_FPGA(FPGA_PRG | FPGA_CLK); - udelay(1000); /* wait 1ms */ - SET_FPGA(FPGA_PRG | FPGA_CLK | FPGA_DATA); - udelay(1000); /* wait 1ms */ - - /* - * Reset external DUARTs - */ - out_be32((void *)GPIO0_OR, - in_be32((void *)GPIO0_OR) | CONFIG_SYS_DUART_RST); - udelay(10); /* wait 10us */ - out_be32((void *)GPIO0_OR, - in_be32((void *)GPIO0_OR) & ~CONFIG_SYS_DUART_RST); - udelay(1000); /* wait 1ms */ - - /* - * Enable interrupts in exar duart mcr[3] - */ - out_8((void *)(DUART0_BA + 4), 0x08); - out_8((void *)(DUART1_BA + 4), 0x08); - out_8((void *)(DUART2_BA + 4), 0x08); - out_8((void *)(DUART3_BA + 4), 0x08); - - return (0); -} - - -/* - * Check Board Identity: - */ - -int checkboard (void) -{ - char str[64]; - int i = getenv_f("serial#", str, sizeof(str)); - - puts ("Board: "); - - if (i == -1) { - puts ("### No HW ID - assuming WUH405"); - } else { - puts(str); - } - - putc ('\n'); - - return 0; -} diff --git a/configs/WUH405_defconfig b/configs/WUH405_defconfig deleted file mode 100644 index dadea20..0000000 --- a/configs/WUH405_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_WUH405=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index dfab3d5..a385bde 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +WUH405 ppc4xx 405ep - - Matthias Fuchs matthias.fuchs@esd.eu VOH405 ppc4xx 405ep - - Matthias Fuchs matthias.fuchs@esd.eu PMC405 ppc4xx 405gp - - Matthias Fuchs matthias.fuchs@esd.eu PCI405 ppc4xx 405gp - - Matthias Fuchs matthias.fuchs@esd.eu diff --git a/include/configs/WUH405.h b/include/configs/WUH405.h deleted file mode 100644 index e4f0d19..0000000 --- a/include/configs/WUH405.h +++ /dev/null @@ -1,346 +0,0 @@ -/* - * (C) Copyright 2004 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_IDENT_STRING " $Name: $" - -#define CONFIG_405EP 1 /* This is a PPC405 CPU */ -#define CONFIG_WUH405 1 /* ...on a WUH405 board */ - -#define CONFIG_SYS_TEXT_BASE 0xFFFC0000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ -#define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */ - -#define CONFIG_SYS_CLK_FREQ 33333300 /* external frequency to pll */ - -#define CONFIG_BAUDRATE 9600 -#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */ - -#undef CONFIG_BOOTARGS -#undef CONFIG_BOOTCOMMAND - -#define CONFIG_PREBOOT /* enable preboot variable */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ - -#define CONFIG_PPC4xx_EMAC -#define CONFIG_MII 1 /* MII PHY management */ -#define CONFIG_PHY_ADDR 0 /* PHY address */ -#define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */ - -#define CONFIG_PHY_CLK_FREQ EMAC_STACR_CLK_66MHZ /* 66 MHz OPB clock*/ - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_ELF -#define CONFIG_CMD_NAND -#define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_EEPROM - - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_RTC_MC146818 /* DS1685 is MC146818 compatible*/ -#define CONFIG_SYS_RTC_REG_BASE_ADDR 0xF0000500 /* RTC Base Address */ - -#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#undef CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_CONS_INDEX 2 /* Use UART1 */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_serial_clock() - -#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* no external serial clock used */ -#define CONFIG_SYS_BASE_BAUD 691200 - -/* The following table includes the supported baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE \ - { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ - 57600, 115200, 230400, 460800, 921600 } - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ -#define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */ - -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ - -#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ - -#define CONFIG_SYS_RX_ETH_BUFFER 16 /* use 16 rx buffer on 405 emac */ - -/*----------------------------------------------------------------------- - * NAND-FLASH stuff - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } -#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ -#define NAND_BIG_DELAY_US 25 - -#define CONFIG_SYS_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ -#define CONFIG_SYS_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ -#define CONFIG_SYS_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ -#define CONFIG_SYS_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */ - -#define CONFIG_SYS_NAND_SKIP_BAD_DOT_I 1 /* ".i" read skips bad blocks */ - -/*----------------------------------------------------------------------- - * PCI stuff - *----------------------------------------------------------------------- - */ -#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ -#define PCI_HOST_FORCE 1 /* configure as pci host */ -#define PCI_HOST_AUTO 2 /* detected via arbiter enable */ - -#define CONFIG_PCI /* include pci support */ -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ -#define CONFIG_PCI_HOST PCI_HOST_HOST /* select pci host function */ -#undef CONFIG_PCI_PNP /* do pci plug-and-play */ - /* resource configuration */ - -#undef CONFIG_PCI_SCAN_SHOW /* print pci devices @ startup */ - -#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x12FE /* PCI Vendor ID: esd gmbh */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID 0x0405 /* PCI Device ID: CPCI-405 */ -#define CONFIG_SYS_PCI_CLASSCODE 0x0b20 /* PCI Class Code: Processor/PPC*/ -#define CONFIG_SYS_PCI_PTM1LA 0x00000000 /* point to sdram */ -#define CONFIG_SYS_PCI_PTM1MS 0xfc000001 /* 64MB, enable hard-wired to 1 */ -#define CONFIG_SYS_PCI_PTM1PCI 0x00000000 /* Host: use this pci address */ -#define CONFIG_SYS_PCI_PTM2LA 0xffc00000 /* point to flash */ -#define CONFIG_SYS_PCI_PTM2MS 0xffc00001 /* 4MB, enable */ -#define CONFIG_SYS_PCI_PTM2PCI 0x04000000 /* Host: use this pci address */ - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFFFC0000 -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (256 * 1024) /* Reserve 256 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 1000 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_SYS_FLASH_WORD_SIZE unsigned short /* flash word size (width) */ -#define CONFIG_SYS_FLASH_ADDR0 0x5555 /* 1st address for flash config cycles */ -#define CONFIG_SYS_FLASH_ADDR1 0x2AAA /* 2nd address for flash config cycles */ -/* - * The following defines are added for buggy IOP480 byte interface. - * All other boards should use the standard values (CPCI405 etc.) - */ -#define CONFIG_SYS_FLASH_READ0 0x0000 /* 0 is standard */ -#define CONFIG_SYS_FLASH_READ1 0x0001 /* 1 is standard */ -#define CONFIG_SYS_FLASH_READ2 0x0002 /* 2 is standard */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ - -#if 0 /* test-only */ -#define CONFIG_SYS_JFFS2_FIRST_BANK 0 /* use for JFFS2 */ -#define CONFIG_SYS_JFFS2_NUM_BANKS 1 /* ! second bank contains U-Boot */ -#endif - -/*----------------------------------------------------------------------- - * Environment Variable setup - */ -#define CONFIG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ -#define CONFIG_ENV_OFFSET 0x100 /* environment starts at the beginning of the EEPROM */ -#define CONFIG_ENV_SIZE 0x700 /* 2048 bytes may be used for env vars*/ - /* total size of a CAT24WC16 is 2048 bytes */ - -#define CONFIG_SYS_NVRAM_BASE_ADDR 0xF0000500 /* NVRAM base address */ -#define CONFIG_SYS_NVRAM_SIZE 242 /* NVRAM size */ - -/*----------------------------------------------------------------------- - * I2C EEPROM (CAT24WC16) for environment - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_PPC4XX -#define CONFIG_SYS_I2C_PPC4XX_CH0 -#define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000 -#define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT28WC08 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ - /* 16 byte page write mode using*/ - /* last 4 bits of the address */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0xFFC00000 /* FLASH bank #0 */ - -/*----------------------------------------------------------------------- - * External Bus Controller (EBC) Setup - */ - -/* Memory Bank 0 (Flash Bank 0, NOR-FLASH) initialization */ -#define CONFIG_SYS_EBC_PB0AP 0x92015480 -/*#define CONFIG_SYS_EBC_PB0AP 0x08055880 /XXX* TWT=16,CSN=1,OEN=1,WBN=1,WBF=1,TH=4,SOR=1 */ -#define CONFIG_SYS_EBC_PB0CR 0xFFC5A000 /* BAS=0xFFC,BS=4MB,BU=R/W,BW=16bit */ - -/* Memory Bank 1 (Flash Bank 1, NAND-FLASH) initialization */ -#define CONFIG_SYS_EBC_PB1AP 0x92015480 -#define CONFIG_SYS_EBC_PB1CR 0xF4018000 /* BAS=0xF40,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 2 (8 Bit Peripheral: CAN, UART, RTC) initialization */ -#define CONFIG_SYS_EBC_PB2AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CONFIG_SYS_EBC_PB2CR 0xF0018000 /* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 3 (16 Bit Peripheral: FPGA internal, dig. IO) initialization */ -#define CONFIG_SYS_EBC_PB3AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CONFIG_SYS_EBC_PB3CR 0xF011A000 /* BAS=0xF01,BS=1MB,BU=R/W,BW=16bit */ - -#define CAN_BA 0xF0000000 /* CAN Base Address */ -#define DUART0_BA 0xF0000400 /* DUART Base Address */ -#define DUART1_BA 0xF0000408 /* DUART Base Address */ -#define DUART2_BA 0xF0000410 /* DUART Base Address */ -#define DUART3_BA 0xF0000418 /* DUART Base Address */ -#define RTC_BA 0xF0000500 /* RTC Base Address */ -#define CONFIG_SYS_NAND_BASE 0xF4000000 - -/*----------------------------------------------------------------------- - * FPGA stuff - */ -#define CONFIG_SYS_FPGA_SPARTAN2 1 /* using Xilinx Spartan 2 now */ -#define CONFIG_SYS_FPGA_MAX_SIZE 128*1024 /* 128kByte is enough for XC2S50E*/ - -/* FPGA program pin configuration */ -#define CONFIG_SYS_FPGA_PRG 0x04000000 /* FPGA program pin (ppc output) */ -#define CONFIG_SYS_FPGA_CLK 0x02000000 /* FPGA clk pin (ppc output) */ -#define CONFIG_SYS_FPGA_DATA 0x01000000 /* FPGA data pin (ppc output) */ -#define CONFIG_SYS_FPGA_INIT 0x00010000 /* FPGA init pin (ppc input) */ -#define CONFIG_SYS_FPGA_DONE 0x00008000 /* FPGA done pin (ppc input) */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in data cache) - */ -/* use on chip memory ( OCM ) for temperary stack until sdram is tested */ -#define CONFIG_SYS_TEMP_STACK_OCM 1 - -/* On Chip Memory location */ -#define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 -#define CONFIG_SYS_OCM_DATA_SIZE 0x1000 -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Definitions for GPIO setup (PPC405EP specific) - * - * GPIO0[0] - External Bus Controller BLAST output - * GPIO0[1-9] - Instruction trace outputs -> GPIO - * GPIO0[10-13] - External Bus Controller CS_1 - CS_4 outputs - * GPIO0[14-16] - External Bus Controller ABUS3-ABUS5 outputs -> GPIO - * GPIO0[17-23] - External Interrupts IRQ0 - IRQ6 inputs - * GPIO0[24-27] - UART0 control signal inputs/outputs - * GPIO0[28-29] - UART1 data signal input/output - * GPIO0[30-31] - EMAC0 and EMAC1 reject packet inputs - */ -#define CONFIG_SYS_GPIO0_OSRL 0x40000550 -#define CONFIG_SYS_GPIO0_OSRH 0x00000110 -#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 -#define CONFIG_SYS_GPIO0_ISR1H 0x15555445 -#define CONFIG_SYS_GPIO0_TSRL 0x00000000 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 -#define CONFIG_SYS_GPIO0_TCR 0xF7FE0014 - -#define CONFIG_SYS_DUART_RST (0x80000000 >> 14) - -/* - * Default speed selection (cpu_plb_opb_ebc) in mhz. - * This value will be set if iic boot eprom is disabled. - */ -#if 0 -#define PLLMR0_DEFAULT PLLMR0_266_133_66_33 -#define PLLMR1_DEFAULT PLLMR1_266_133_66_33 -#endif -#if 1 -#define PLLMR0_DEFAULT PLLMR0_200_100_50_33 -#define PLLMR1_DEFAULT PLLMR1_200_100_50_33 -#endif -#if 0 -#define PLLMR0_DEFAULT PLLMR0_133_66_66_33 -#define PLLMR1_DEFAULT PLLMR1_133_66_66_33 -#endif - -#endif /* __CONFIG_H */
On Mon, Jan 12, 2015 at 10:47:28PM +0100, Matthias Fuchs wrote:
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu
Matthias Fuchs
