[PATCH] arm64: dts: imx8m{m, n}-venice-gw7902: add gpio pins for new board revision
Add gpio pins present on new board revision: * LTE modem support (imx8mm-gw7902 only) - lte_pwr# - lte_rst - lte_int * M2 power enable - m2_pwr_en * off-board 4.0V supply - vdd_4p0_en
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/dts/imx8mm-venice-gw7902-u-boot.dtsi | 14 ++++++++++++++ arch/arm/dts/imx8mm-venice-gw7902.dts | 12 ++++++++---- arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi | 14 ++++++++++++++ arch/arm/dts/imx8mn-venice-gw7902.dts | 8 ++++---- 4 files changed, 40 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/imx8mm-venice-gw7902-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-gw7902-u-boot.dtsi index f21e46b12dd7..d58a7d14b631 100644 --- a/arch/arm/dts/imx8mm-venice-gw7902-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-gw7902-u-boot.dtsi @@ -6,6 +6,13 @@ #include "imx8mm-venice-u-boot.dtsi"
&gpio1 { + m2pwren { + gpio-hog; + output-low; + gpios = <8 GPIO_ACTIVE_HIGH>; + line-name = "m2_pwren"; + }; + m2rst { gpio-hog; output-low; @@ -96,6 +103,13 @@ line-name = "app_gpio1"; };
+ vdd4p0en { + gpio-hog; + output-low; + gpios = <22 GPIO_ACTIVE_HIGH>; + line-name = "vdd_4p0_en"; + }; + uart1rs485 { gpio-hog; output-low; diff --git a/arch/arm/dts/imx8mm-venice-gw7902.dts b/arch/arm/dts/imx8mm-venice-gw7902.dts index 31f4c735fe4f..921bffae0cc9 100644 --- a/arch/arm/dts/imx8mm-venice-gw7902.dts +++ b/arch/arm/dts/imx8mm-venice-gw7902.dts @@ -261,7 +261,7 @@
&gpio1 { gpio-line-names = "", "", "", "", "", "", "", "", - "", "", "", "", "", "m2_reset", "", "m2_wdis#", + "m2_pwr_en", "", "", "", "", "m2_reset", "", "m2_wdis#", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", ""; }; @@ -283,7 +283,8 @@ &gpio4 { gpio-line-names = "", "", "", "", "", "", "", "", "", "", "", "amp_gpio3", "amp_gpio2", "", "amp_gpio1", "", - "", "", "", "", "amp_gpio4", "app_gpio1", "", "uart1_rs485", + "lte_pwr#", "lte_rst", "lte_int", "", + "amp_gpio4", "app_gpio1", "vdd_4p0_en", "uart1_rs485", "", "uart1_term", "uart1_half", "app_gpio2", "mipi_gpio1", "", "", ""; }; @@ -738,14 +739,19 @@ pinctrl_hog: hoggrp { fsl,pins = < MX8MM_IOMUXC_NAND_CE0_B_GPIO3_IO1 0x40000159 /* M2_GDIS# */ + MX8MM_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x40000041 /* M2_PWR_EN */ MX8MM_IOMUXC_GPIO1_IO13_GPIO1_IO13 0x40000041 /* M2_RESET */ MX8MM_IOMUXC_NAND_DATA01_GPIO3_IO7 0x40000119 /* M2_OFF# */ MX8MM_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x40000159 /* M2_WDIS# */ + MX8MM_IOMUXC_SAI1_TXD6_GPIO4_IO18 0x40000041 /* LTE_INT */ + MX8MM_IOMUXC_SAI1_TXD5_GPIO4_IO17 0x40000041 /* LTE_RST# */ + MX8MM_IOMUXC_SAI1_TXD4_GPIO4_IO16 0x40000041 /* LTE_PWR */ MX8MM_IOMUXC_SAI1_TXD2_GPIO4_IO14 0x40000041 /* AMP GPIO1 */ MX8MM_IOMUXC_SAI1_TXD0_GPIO4_IO12 0x40000041 /* AMP GPIO2 */ MX8MM_IOMUXC_SAI1_TXC_GPIO4_IO11 0x40000041 /* AMP GPIO3 */ MX8MM_IOMUXC_SAI1_MCLK_GPIO4_IO20 0x40000041 /* AMP_GPIO4 */ MX8MM_IOMUXC_SAI2_RXFS_GPIO4_IO21 0x40000041 /* APP GPIO1 */ + MX8MM_IOMUXC_SAI2_RXC_GPIO4_IO22 0x40000041 /* VDD_4P0_EN */ MX8MM_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x40000041 /* APP GPIO2 */ MX8MM_IOMUXC_SD1_DATA6_GPIO2_IO8 0x40000041 /* UART2_EN# */ MX8MM_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x40000041 /* MIPI_GPIO1 */ @@ -779,8 +785,6 @@ MX8MM_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f MX8MM_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x19 /* RST# */ MX8MM_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x19 /* IRQ# */ - MX8MM_IOMUXC_GPIO1_IO08_ENET1_1588_EVENT0_IN 0x141 - MX8MM_IOMUXC_GPIO1_IO09_ENET1_1588_EVENT0_OUT 0x141 >; };
diff --git a/arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi index 17e6828c79f8..10656ce903a5 100644 --- a/arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi @@ -6,6 +6,13 @@ #include "imx8mn-venice-u-boot.dtsi"
&gpio1 { + m2pwren { + gpio-hog; + output-low; + gpios = <8 GPIO_ACTIVE_HIGH>; + line-name = "m2_pwren"; + }; + m2rst { gpio-hog; output-low; @@ -54,6 +61,13 @@ line-name = "app_gpio1"; };
+ vdd4p0en { + gpio-hog; + output-low; + gpios = <22 GPIO_ACTIVE_HIGH>; + line-name = "vdd_4p0_en"; + }; + uart1rs485 { gpio-hog; output-low; diff --git a/arch/arm/dts/imx8mn-venice-gw7902.dts b/arch/arm/dts/imx8mn-venice-gw7902.dts index dd4302ac1de4..029ccdbee7d5 100644 --- a/arch/arm/dts/imx8mn-venice-gw7902.dts +++ b/arch/arm/dts/imx8mn-venice-gw7902.dts @@ -256,7 +256,7 @@
&gpio1 { gpio-line-names = "", "", "", "", "", "", "", "", - "", "", "", "", "", "m2_reset", "", "m2_wdis#", + "m2_pwr_en", "", "", "", "", "m2_reset", "", "m2_wdis#", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", ""; }; @@ -278,7 +278,7 @@ &gpio4 { gpio-line-names = "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", - "", "", "", "", "", "app_gpio1", "", "uart1_rs485", + "", "", "", "", "", "app_gpio1", "vdd_4p0_en", "uart1_rs485", "", "uart1_term", "uart1_half", "app_gpio2", "mipi_gpio1", "", "", ""; }; @@ -689,10 +689,12 @@ pinctrl_hog: hoggrp { fsl,pins = < MX8MN_IOMUXC_NAND_CE0_B_GPIO3_IO1 0x40000159 /* M2_GDIS# */ + MX8MN_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x40000041 /* M2_PWR_EN */ MX8MN_IOMUXC_GPIO1_IO13_GPIO1_IO13 0x40000041 /* M2_RESET */ MX8MN_IOMUXC_NAND_DATA01_GPIO3_IO7 0x40000119 /* M2_OFF# */ MX8MN_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x40000159 /* M2_WDIS# */ MX8MN_IOMUXC_SAI2_RXFS_GPIO4_IO21 0x40000041 /* APP GPIO1 */ + MX8MN_IOMUXC_SAI2_RXC_GPIO4_IO22 0x40000041 /* VDD_4P0_EN */ MX8MN_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x40000041 /* APP GPIO2 */ MX8MN_IOMUXC_SD1_DATA6_GPIO2_IO8 0x40000041 /* UART2_EN# */ MX8MN_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x40000041 /* MIPI_GPIO1 */ @@ -726,8 +728,6 @@ MX8MN_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f MX8MN_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x19 /* RST# */ MX8MN_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x19 /* IRQ# */ - MX8MN_IOMUXC_GPIO1_IO08_ENET1_1588_EVENT0_IN 0x141 - MX8MN_IOMUXC_GPIO1_IO09_ENET1_1588_EVENT0_OUT 0x141 >; };
- LTE modem support (imx8mm-gw7902 only)
- lte_pwr#
- lte_rst
- lte_int
- M2 power enable
- m2_pwr_en
- off-board 4.0V supply
- vdd_4p0_en
Best regards, Stefano Babic
sbabic@denx.de
Tim Harvey
