[U-Boot] ARM Pull Request
Please pull The following changes since commit 56bdfa961242fc6acaeebc800640a12b28db3899: Dirk Eibach (1): ppc4xx: Remove check for PPC460EX from CompactCenter
git://git.denx.de/u-boot-arm.git master
David Brownell (1): rm9200 lowevel_init: don't touch reserved/readonly registers
David Hunter (1): pxa: Fix typo in GCDR(x)
Eric Benard (1): Add AT91SAM9260 to at91's lowlevel_init.S
cpu/arm920t/at91rm9200/lowlevel_init.S | 14 ++------------ cpu/arm926ejs/at91/lowlevel_init.S | 2 +- include/asm-arm/arch-pxa/pxa-regs.h | 2 +- include/configs/at91rm9200dk.h | 5 ----- include/configs/at91rm9200ek.h | 5 ----- include/configs/cmc_pu2.h | 5 ----- include/configs/csb637.h | 5 ----- include/configs/m501sk.h | 5 ----- include/configs/mp2usb.h | 5 ----- 9 files changed, 4 insertions(+), 44 deletions(-)
Best Regards, J.
Dear Jean-Christophe,
What's about
1. [PATCHv3 2-5/5] clean up omap3 configuration structs http://lists.denx.de/pipermail/u-boot/2009-May/052943.html http://lists.denx.de/pipermail/u-boot/2009-May/052945.html http://lists.denx.de/pipermail/u-boot/2009-May/052944.html http://lists.denx.de/pipermail/u-boot/2009-May/052946.html
-> Please see http://lists.denx.de/pipermail/u-boot/2009-July/057615.html
2. [PATCH 1-2/2] V2 remove omap3 compiler warning wrt v7_flush_dcache_all http://lists.denx.de/pipermail/u-boot/2009-July/055543.html http://lists.denx.de/pipermail/u-boot/2009-July/055544.html
-> Older patch applied, this is still expected to be applied:
http://lists.denx.de/pipermail/u-boot/2009-July/056859.html
3. PATCH: (Updated) Fix examples for OMAP3 boards... http://lists.denx.de/pipermail/u-boot/2009-July/056270.html
4. [PATCH]omap3: bug fix for NOR boot support http://lists.denx.de/pipermail/u-boot/2009-July/057819.html
Best regards
Dirk
Dear Jean-Christophe PLAGNIOL-VILLARD,
Applied, thanks.
Dirk Behme
