[PATCH v2 0/4] sandbox: exception handling
Currently if an exception SIGILL, SIGBUS, SIGSEGV occurs the sandbox stops execution. This does not match the behavior on other architectures.
Instead print the current program counter and if any the involved UEFI binaries. Then depending on a customizing system either reset the system or exit to the OS.
When testing UEFI binaries like the Self Certification Test exceptions may occur. Without information about the UEFI binary where the exception was caused it is difficult to analyze the cause.
The exception command is implemented for the sandbox. This command allows to trigger SIGILL or SIGSEGV.
v2: add a customizing switch set SA_NODEFER flag for sigaction provide a unit test for the exception command
Heinrich Schuchardt (4): sandbox: add handler for exceptions cmd: sandbox: implement exception command efi_selftest: implement exception test for sandbox test: unit test for exception command
arch/Kconfig | 1 + arch/sandbox/Kconfig | 9 ++++ arch/sandbox/cpu/os.c | 40 ++++++++++++++++++ arch/sandbox/cpu/start.c | 4 ++ arch/sandbox/lib/interrupts.c | 35 ++++++++++++++++ cmd/Kconfig | 2 +- cmd/Makefile | 1 + cmd/sandbox/Makefile | 3 ++ cmd/sandbox/exception.c | 41 +++++++++++++++++++ include/os.h | 17 ++++++++ .../efi_selftest_miniapp_exception.c | 2 + test/py/tests/test_sandbox_exit.py | 24 +++++++++++ 12 files changed, 178 insertions(+), 1 deletion(-) create mode 100644 cmd/sandbox/Makefile create mode 100644 cmd/sandbox/exception.c
-- 2.28.0
Add a handler for SIGILL, SIGBUS, SIGSEGV.
When an exception occurs print the program counter and the loaded UEFI binaries and reset the system if CONFIG_SANDBOX_CRASH_RESET=y or exit to the OS otherwise.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: add a customizing switch set SA_NODEFER flag for sigaction --- arch/sandbox/Kconfig | 9 ++++++++ arch/sandbox/cpu/os.c | 40 +++++++++++++++++++++++++++++++++++ arch/sandbox/cpu/start.c | 4 ++++ arch/sandbox/lib/interrupts.c | 35 ++++++++++++++++++++++++++++++ include/os.h | 17 +++++++++++++++ 5 files changed, 105 insertions(+)
diff --git a/arch/sandbox/Kconfig b/arch/sandbox/Kconfig index 65f988e736..f83282d9d5 100644 --- a/arch/sandbox/Kconfig +++ b/arch/sandbox/Kconfig @@ -51,6 +51,15 @@ config HOST_64BIT
endchoice
+config SANDBOX_CRASH_RESET + bool "Reset on crash" + help + If an illegal instruction or an illegal memory access occurs, the + sandbox by default writes a crash dump and exits. If you set this + flag, the sandbox is reset instead. This may be useful when running + test suites like the UEFI self certification test which continue + with the next test after a crash. + config SANDBOX_BITS_PER_LONG int default 32 if HOST_32BIT diff --git a/arch/sandbox/cpu/os.c b/arch/sandbox/cpu/os.c index 0d8efd83f6..b56fa04a34 100644 --- a/arch/sandbox/cpu/os.c +++ b/arch/sandbox/cpu/os.c @@ -3,6 +3,8 @@ * Copyright (c) 2011 The Chromium OS Authors. */
+#define _GNU_SOURCE + #include <dirent.h> #include <errno.h> #include <fcntl.h> @@ -15,11 +17,13 @@ #include <string.h> #include <termios.h> #include <time.h> +#include <ucontext.h> #include <unistd.h> #include <sys/mman.h> #include <sys/stat.h> #include <sys/time.h> #include <sys/types.h> +#include <linux/compiler_attributes.h> #include <linux/types.h>
#include <asm/getopt.h> @@ -191,6 +195,42 @@ static void os_sigint_handler(int sig) raise(SIGINT); }
+static void os_signal_handler(int sig, siginfo_t *info, void *con) +{ + ucontext_t __maybe_unused *context = con; + unsigned long pc; + +#if defined(__x86_64__) + pc = context->uc_mcontext.gregs[REG_RIP]; +#elif defined(__aarch64__) + pc = context->uc_mcontext.pc; +#elif defined(__riscv) + pc = context->uc_mcontext.__gregs[REG_PC]; +#else + const char msg[] = + "\nUnsupported architecture, cannot read program counter\n"; + + os_write(1, msg, sizeof(msg)); + pc = 0; +#endif + + os_signal_action(sig, pc); +} + +int os_setup_signal_handlers(void) +{ + struct sigaction act; + + act.sa_sigaction = os_signal_handler; + sigemptyset(&act.sa_mask); + act.sa_flags = SA_SIGINFO | SA_NODEFER; + if (sigaction(SIGILL, &act, NULL) || + sigaction(SIGBUS, &act, NULL) || + sigaction(SIGSEGV, &act, NULL)) + return -1; + return 0; +} + /* Put tty into raw mode so <tab> and <ctrl+c> work */ void os_tty_raw(int fd, bool allow_sigs) { diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index a03e5aa0b3..f6c98545e0 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -451,6 +451,10 @@ int main(int argc, char *argv[]) if (ret) goto err;
+ ret = os_setup_signal_handlers(); + if (ret) + goto err; + #if CONFIG_VAL(SYS_MALLOC_F_LEN) gd->malloc_base = CONFIG_MALLOC_F_ADDR; #endif diff --git a/arch/sandbox/lib/interrupts.c b/arch/sandbox/lib/interrupts.c index 21f761ac3b..9c2c60b8c6 100644 --- a/arch/sandbox/lib/interrupts.c +++ b/arch/sandbox/lib/interrupts.c @@ -6,7 +6,13 @@ */
#include <common.h> +#include <efi_loader.h> #include <irq_func.h> +#include <os.h> +#include <asm-generic/signal.h> +#include <asm/u-boot-sandbox.h> + +DECLARE_GLOBAL_DATA_PTR;
int interrupt_init(void) { @@ -21,3 +27,32 @@ int disable_interrupts(void) { return 0; } + +void os_signal_action(int sig, unsigned long pc) +{ + efi_restore_gd(); + + switch (sig) { + case SIGILL: + printf("\nIllegal instruction\n"); + break; + case SIGBUS: + printf("\nBus error\n"); + break; + case SIGSEGV: + printf("\nSegmentation violation\n"); + break; + default: + break; + } + printf("pc = 0x%lx, ", pc); + printf("pc_reloc = 0x%lx\n\n", pc - gd->reloc_off); + efi_print_image_infos((void *)pc); + + if (IS_ENABLED(CONFIG_SANDBOX_CRASH_RESET)) { + printf("resetting ...\n\n"); + sandbox_reset(); + } else { + sandbox_exit(); + } +} diff --git a/include/os.h b/include/os.h index 1fe44f3510..0913b47b3a 100644 --- a/include/os.h +++ b/include/os.h @@ -407,4 +407,21 @@ void *os_find_text_base(void); */ void os_relaunch(char *argv[]);
+/** + * os_setup_signal_handlers() - setup signal handlers + * + * Install signal handlers for SIGBUS and SIGSEGV. + * + * Return: 0 for success + */ +int os_setup_signal_handlers(void); + +/** + * os_signal_action() - handle a signal + * + * @sig: signal + * @pc: program counter + */ +void os_signal_action(int sig, unsigned long pc); + #endif -- 2.28.0
Hi Heinrich,
Do you think a command-line flag might be useful too/instead?
On 17.11.20 00:53, Simon Glass wrote:
Hi Heinrich,
For my needs the CONFIG flag is enough.
I could not find the mail for patch 2/4 in my inbox. I have tested on aarch64 that the exception work here too.
Best regards
Heinrich
Hi Heinrich,
Best regards
Heinrich
Applied to u-boot-dm, thanks!
Implement the commands
* exception undefined - execute an illegal instruction * exception sigsegv - cause a segment violation
Here is a possible output:
=> exception undefined Illegal instruction pc = 0x55eb8d0a7575, pc_reloc = 0x57575 Resetting ...
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Simon Glass sjg@chromium.org --- v2: no change --- cmd/Kconfig | 2 +- cmd/Makefile | 1 + cmd/sandbox/Makefile | 3 +++ cmd/sandbox/exception.c | 41 +++++++++++++++++++++++++++++++++++++++++ 4 files changed, 46 insertions(+), 1 deletion(-) create mode 100644 cmd/sandbox/Makefile create mode 100644 cmd/sandbox/exception.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 1595de999b..f9b72449c5 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1682,7 +1682,7 @@ config CMD_EFIDEBUG
config CMD_EXCEPTION bool "exception - raise exception" - depends on ARM || RISCV || X86 + depends on ARM || RISCV || SANDBOX || X86 help Enable the 'exception' command which allows to raise an exception.
diff --git a/cmd/Makefile b/cmd/Makefile index dd86675bf2..5b3400a840 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -193,6 +193,7 @@ obj-$(CONFIG_CMD_AVB) += avb.o
obj-$(CONFIG_ARM) += arm/ obj-$(CONFIG_RISCV) += riscv/ +obj-$(CONFIG_SANDBOX) += sandbox/ obj-$(CONFIG_X86) += x86/
obj-$(CONFIG_ARCH_MVEBU) += mvebu/ diff --git a/cmd/sandbox/Makefile b/cmd/sandbox/Makefile new file mode 100644 index 0000000000..24df023ece --- /dev/null +++ b/cmd/sandbox/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-$(CONFIG_CMD_EXCEPTION) += exception.o diff --git a/cmd/sandbox/exception.c b/cmd/sandbox/exception.c new file mode 100644 index 0000000000..1aa1d673ae --- /dev/null +++ b/cmd/sandbox/exception.c @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * The 'exception' command can be used for testing exception handling. + * + * Copyright (c) 2020, Heinrich Schuchardt xypron.glpk@gmx.de + */ + +#include <common.h> +#include <command.h> + +static int do_sigsegv(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + u8 *ptr = NULL; + + *ptr = 0; + return CMD_RET_FAILURE; +} + +static int do_undefined(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + asm volatile (".word 0xffff\n"); + return CMD_RET_FAILURE; +} + +static struct cmd_tbl cmd_sub[] = { + U_BOOT_CMD_MKENT(sigsegv, CONFIG_SYS_MAXARGS, 1, do_sigsegv, + "", ""), + U_BOOT_CMD_MKENT(undefined, CONFIG_SYS_MAXARGS, 1, do_undefined, + "", ""), +}; + +static char exception_help_text[] = + "<ex>\n" + " The following exceptions are available:\n" + " undefined - undefined instruction\n" + " sigsegv - illegal memory access\n" + ; + +#include <exception.h> -- 2.28.0
Provide a unit test that causes an illegal instruction to occur.
The test can be run with the following commands:
=> setenv efi_selftest exception => bootefi selftest
This might be the output:
Executing 'exception' EFI application triggers exception. Illegal instruction pc = 0x1444d016, pc_reloc = 0xffffaa078e8dd016 UEFI image [0x0000000000000000:0xffffffffffffffff] '/\selftest' UEFI image [0x000000001444b000:0x0000000014451fff] pc=0x2016 '/bug.efi' Resetting ...
It would tell us that the exception was triggered by an instruction 0x2016 bytes after the load address of the binary with filename /bug.efi.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: no change --- lib/efi_selftest/efi_selftest_miniapp_exception.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/lib/efi_selftest/efi_selftest_miniapp_exception.c b/lib/efi_selftest/efi_selftest_miniapp_exception.c index 63c63d75f1..59b7e5100a 100644 --- a/lib/efi_selftest/efi_selftest_miniapp_exception.c +++ b/lib/efi_selftest/efi_selftest_miniapp_exception.c @@ -33,6 +33,8 @@ efi_status_t EFIAPI efi_main(efi_handle_t handle, asm volatile (".word 0xe7f7defb\n"); #elif defined(CONFIG_RISCV) asm volatile (".word 0xffffffff\n"); +#elif defined(CONFIG_SANDBOX) + asm volatile (".word 0xffffffff\n"); #elif defined(CONFIG_X86) asm volatile (".word 0xffff\n"); #endif -- 2.28.0
v2: no change
Does this work on ARM hosts?
#endif
2.28.0
v2: no change
Yes it works on aarch64.
Best regards
Heinrich
#endif
2.28.0
v2: no change
Test that an exception SIGILL is answered by a reset on the sandbox if CONFIG_SANDBOX_CRASH_RESET=y or by exiting to the OS otherwise.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: new patch --- arch/Kconfig | 1 + test/py/tests/test_sandbox_exit.py | 24 ++++++++++++++++++++++++ 2 files changed, 25 insertions(+)
diff --git a/arch/Kconfig b/arch/Kconfig index 3aa99e08fc..b936d2dffc 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -112,6 +112,7 @@ config SANDBOX imply BITREVERSE select BLOBLIST imply CMD_DM + imply CMD_EXCEPTION imply CMD_GETTIME imply CMD_HASH imply CMD_IO diff --git a/test/py/tests/test_sandbox_exit.py b/test/py/tests/test_sandbox_exit.py index 2d242ae0f6..706f5fa359 100644 --- a/test/py/tests/test_sandbox_exit.py +++ b/test/py/tests/test_sandbox_exit.py @@ -19,3 +19,27 @@ def test_ctrl_c(u_boot_console):
u_boot_console.kill(signal.SIGINT) assert(u_boot_console.validate_exited()) + +@pytest.mark.boardspec('sandbox') +@pytest.mark.buildconfigspec('cmd_exception') +@pytest.mark.buildconfigspec('sandbox_crash_reset') +def test_exception_reset(u_boot_console): + """Test that SIGILL causes a reset.""" + + u_boot_console.run_command('exception undefined', wait_for_prompt=False) + m = u_boot_console.p.expect(['resetting ...', 'U-Boot']) + if m != 0: + raise Exception('SIGILL did not lead to reset') + m = u_boot_console.p.expect(['U-Boot', '=>']) + if m != 0: + raise Exception('SIGILL did not lead to reset') + u_boot_console.restart_uboot() + +@pytest.mark.boardspec('sandbox') +@pytest.mark.buildconfigspec('cmd_exception') +@pytest.mark.notbuildconfigspec('sandbox_crash_reset') +def test_exception_exit(u_boot_console): + """Test that SIGILL causes a reset.""" + + u_boot_console.run_command('exception undefined', wait_for_prompt=False) + assert(u_boot_console.validate_exited()) -- 2.28.0
v2: new patch
