[U-Boot] [PATCH v2 0/2] power: pmic: Add support for LP873X family of PMICs
The series adds support for LP873X family of PMICs. Implements functions to configure regulators. Enable/Disable Get/Set voltages of regulators.
Keerthy (2): power: pmic: lp873x: Add the base pmic support power: regulator: lp873x: Add regulator support
drivers/power/pmic/Kconfig | 7 + drivers/power/pmic/Makefile | 1 + drivers/power/pmic/lp873x.c | 90 ++++++++ drivers/power/regulator/Kconfig | 8 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/lp873x_regulator.c | 357 +++++++++++++++++++++++++++++ include/power/lp873x.h | 19 ++ 7 files changed, 483 insertions(+) create mode 100644 drivers/power/pmic/lp873x.c create mode 100644 drivers/power/regulator/lp873x_regulator.c create mode 100644 include/power/lp873x.h
Add support to bind the regulators/child nodes with the pmic.
Signed-off-by: Keerthy j-keerthy@ti.com ---
Changes in v2:
* Added pmic read/write functions.
drivers/power/pmic/Kconfig | 7 ++++ drivers/power/pmic/Makefile | 1 + drivers/power/pmic/lp873x.c | 90 +++++++++++++++++++++++++++++++++++++++++++++ include/power/lp873x.h | 19 ++++++++++ 4 files changed, 117 insertions(+) create mode 100644 drivers/power/pmic/lp873x.c create mode 100644 include/power/lp873x.h
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index 92931c5..00fcacb 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -142,3 +142,10 @@ config PMIC_PALMAS ---help--- The PALMAS is a PMIC containing several LDOs, SMPS. This driver binds the pmic children. + +config PMIC_LP873X + bool "Enable driver for Texas Instruments LP873X PMIC" + depends on DM_PMIC + ---help--- + The LP873X is a PMIC containing couple of LDOs and couple of SMPS. + This driver binds the pmic children. diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 828c0cf..334a24f 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -16,6 +16,7 @@ obj-$(CONFIG_PMIC_RK808) += rk808.o obj-$(CONFIG_PMIC_TPS65090) += tps65090.o obj-$(CONFIG_PMIC_S5M8767) += s5m8767.o obj-$(CONFIG_$(SPL_)PMIC_PALMAS) += palmas.o +obj-$(CONFIG_$(SPL_)PMIC_LP873X) += lp873x.o
obj-$(CONFIG_POWER_LTC3676) += pmic_ltc3676.o obj-$(CONFIG_POWER_MAX77696) += pmic_max77696.o diff --git a/drivers/power/pmic/lp873x.c b/drivers/power/pmic/lp873x.c new file mode 100644 index 0000000..b727b8b --- /dev/null +++ b/drivers/power/pmic/lp873x.c @@ -0,0 +1,90 @@ +/* + * (C) Copyright 2016 Texas Instruments Incorporated, <www.ti.com> + * Keerthy j-keerthy@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <errno.h> +#include <dm.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/regulator.h> +#include <power/lp873x.h> +#include <dm/device.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct pmic_child_info pmic_children_info[] = { + { .prefix = "ldo", .driver = LP873X_LDO_DRIVER }, + { .prefix = "buck", .driver = LP873X_BUCK_DRIVER }, + { }, +}; + +static int lp873x_write(struct udevice *dev, uint reg, const uint8_t *buff, + int len) +{ + if (dm_i2c_reg_write(dev, reg, *buff)) { + error("write error to device: %p register: %#x!", dev, reg); + return -EIO; + } + + return 0; +} + +static int lp873x_read(struct udevice *dev, uint reg, uint8_t *buff, int len) +{ + int ret; + + ret = dm_i2c_reg_read(dev, reg); + if (ret < 0) { + error("read error %d from device: %p register: %#x!", ret, dev, + reg); + return -EIO; + } + + return ret; +} + +static int lp873x_bind(struct udevice *dev) +{ + int regulators_node; + const void *blob = gd->fdt_blob; + int children; + int node = dev->of_offset; + + regulators_node = fdt_subnode_offset(blob, node, "regulators"); + + if (regulators_node <= 0) { + printf("%s: %s reg subnode not found!", __func__, dev->name); + return -ENXIO; + } + + children = pmic_bind_children(dev, regulators_node, pmic_children_info); + if (!children) + printf("%s: %s - no child found\n", __func__, dev->name); + + /* Always return success for this device */ + return 0; +} + +static struct dm_pmic_ops lp873x_ops = { + .read = lp873x_read, + .write = lp873x_write, +}; + +static const struct udevice_id lp873x_ids[] = { + { .compatible = "ti,lp8732", .data = LP8732 }, + { .compatible = "ti,lp8733" , .data = LP8733 }, + { } +}; + +U_BOOT_DRIVER(pmic_lp873x) = { + .name = "lp873x_pmic", + .id = UCLASS_PMIC, + .of_match = lp873x_ids, + .bind = lp873x_bind, + .ops = &lp873x_ops, +}; diff --git a/include/power/lp873x.h b/include/power/lp873x.h new file mode 100644 index 0000000..e0c0711 --- /dev/null +++ b/include/power/lp873x.h @@ -0,0 +1,19 @@ +#define LP8732 0x0 +#define LP8733 0x1 + +#define LP873X_LDO_NUM 2 +#define LP873X_BUCK_NUM 2 + +/* Drivers name */ +#define LP873X_LDO_DRIVER "lp873x_ldo" +#define LP873X_BUCK_DRIVER "lp873x_buck" + +#define LP873X_BUCK_VOLT_MASK 0xFF +#define LP873X_BUCK_VOLT_MAX_HEX 0xFF +#define LP873X_BUCK_VOLT_MAX 3360000 +#define LP873X_BUCK_MODE_MASK 0x1 + +#define LP873X_LDO_VOLT_MASK 0x1F +#define LP873X_LDO_VOLT_MAX_HEX 0x19 +#define LP873X_LDO_VOLT_MAX 3300000 +#define LP873X_LDO_MODE_MASK 0x1
Changes in v2:
- Added pmic read/write functions.
The driver provides regulator set/get voltage enable/disable functions for lp873x family of PMICs.
Changes in v2:
* Used pmic_reg_read/pmic_reg_write instead of direct i2c read/write calls.
drivers/power/regulator/Kconfig | 8 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/lp873x_regulator.c | 357 +++++++++++++++++++++++++++++ 3 files changed, 366 insertions(+) create mode 100644 drivers/power/regulator/lp873x_regulator.c
diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index adb710a..84cf914 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -123,3 +123,11 @@ config DM_REGULATOR_PALMAS This enables implementation of driver-model regulator uclass features for REGULATOR PALMAS and the family of PALMAS PMICs. The driver implements get/set api for: value and enable. + +config DM_REGULATOR_LP873X + bool "Enable driver for LP873X PMIC regulators" + depends on PMIC_LP873X + ---help--- + This enables implementation of driver-model regulator uclass + features for REGULATOR LP873X and the family of LP873X PMICs. + The driver implements get/set api for: value and enable. diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index 75080d4..2093048 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -15,3 +15,4 @@ obj-$(CONFIG_REGULATOR_S5M8767) += s5m8767.o obj-$(CONFIG_DM_REGULATOR_SANDBOX) += sandbox.o obj-$(CONFIG_REGULATOR_TPS65090) += tps65090_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_PALMAS) += palmas_regulator.o +obj-$(CONFIG_$(SPL_)DM_REGULATOR_LP873X) += lp873x_regulator.o diff --git a/drivers/power/regulator/lp873x_regulator.c b/drivers/power/regulator/lp873x_regulator.c new file mode 100644 index 0000000..dcb19ff --- /dev/null +++ b/drivers/power/regulator/lp873x_regulator.c @@ -0,0 +1,357 @@ +/* + * (C) Copyright 2016 + * Texas Instruments Incorporated, <www.ti.com> + * + * Keerthy j-keerthy@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <errno.h> +#include <dm.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/regulator.h> +#include <power/lp873x.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const char lp873x_buck_ctrl[LP873X_BUCK_NUM] = {0x2, 0x4}; +static const char lp873x_buck_volt[LP873X_BUCK_NUM] = {0x6, 0x7}; +static const char lp873x_ldo_ctrl[LP873X_LDO_NUM] = {0x8, 0x9}; +static const char lp873x_ldo_volt[LP873X_LDO_NUM] = {0xA, 0xB}; + +static int lp873x_buck_enable(struct udevice *dev, int op, bool *enable) +{ + int ret; + unsigned int adr; + struct dm_regulator_uclass_platdata *uc_pdata; + + uc_pdata = dev_get_uclass_platdata(dev); + adr = uc_pdata->ctrl_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + ret &= LP873X_BUCK_MODE_MASK; + + if (ret) + *enable = true; + else + *enable = false; + + return 0; + } else if (op == PMIC_OP_SET) { + if (*enable) + ret |= LP873X_BUCK_MODE_MASK; + else + ret &= ~(LP873X_BUCK_MODE_MASK); + ret = pmic_reg_write(dev->parent, adr, ret); + if (ret) + return ret; + } + + return 0; +} + +static int lp873x_buck_volt2hex(int uV) +{ + if (uV > LP873X_BUCK_VOLT_MAX) + return -EINVAL; + else if (uV > 1400000) + return (uV - 1420000) / 20000 + 0x9E; + else if (uV > 730000) + return (uV - 735000) / 5000 + 0x18; + else if (uV >= 700000) + return (uV - 700000) / 10000 + 0x1; + else + return -EINVAL; +} + +static int lp873x_buck_hex2volt(int hex) +{ + if (hex > LP873X_BUCK_VOLT_MAX_HEX) + return -EINVAL; + else if (hex > 0x9D) + return 1400000 + (hex - 0x9D) * 20000; + else if (hex > 0x17) + return 730000 + (hex - 0x17) * 5000; + else if (hex >= 0x14) + return 700000 + (hex - 0x14) * 10000; + else + return -EINVAL; +} + +static int lp873x_buck_val(struct udevice *dev, int op, int *uV) +{ + unsigned int hex, adr; + int ret; + struct dm_regulator_uclass_platdata *uc_pdata; + + uc_pdata = dev_get_uclass_platdata(dev); + + if (op == PMIC_OP_GET) + *uV = 0; + + adr = uc_pdata->volt_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + ret &= LP873X_BUCK_VOLT_MASK; + ret = lp873x_buck_hex2volt(ret); + if (ret < 0) + return ret; + *uV = ret; + + return 0; + } + + hex = lp873x_buck_volt2hex(*uV); + if (hex < 0) + return hex; + + ret &= 0x0; + ret |= hex; + + ret = pmic_reg_write(dev->parent, adr, ret); + + return ret; +} + +static int lp873x_ldo_enable(struct udevice *dev, int op, bool *enable) +{ + int ret; + unsigned int adr; + struct dm_regulator_uclass_platdata *uc_pdata; + + uc_pdata = dev_get_uclass_platdata(dev); + adr = uc_pdata->ctrl_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + ret &= LP873X_LDO_MODE_MASK; + + if (ret) + *enable = true; + else + *enable = false; + + return 0; + } else if (op == PMIC_OP_SET) { + if (*enable) + ret |= LP873X_LDO_MODE_MASK; + else + ret &= ~(LP873X_LDO_MODE_MASK); + + ret = pmic_reg_write(dev->parent, adr, ret); + if (ret) + return ret; + } + + return 0; +} + +static int lp873x_ldo_volt2hex(int uV) +{ + if (uV > LP873X_LDO_VOLT_MAX) + return -EINVAL; + + return (uV - 800000) / 100000; +} + +static int lp873x_ldo_hex2volt(int hex) +{ + if (hex > LP873X_LDO_VOLT_MAX_HEX) + return -EINVAL; + + if (!hex) + return 0; + + return (hex * 100000) + 800000; +} + +static int lp873x_ldo_val(struct udevice *dev, int op, int *uV) +{ + unsigned int hex, adr; + int ret; + + struct dm_regulator_uclass_platdata *uc_pdata; + + if (op == PMIC_OP_GET) + *uV = 0; + + uc_pdata = dev_get_uclass_platdata(dev); + + adr = uc_pdata->volt_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + ret &= LP873X_LDO_VOLT_MASK; + ret = lp873x_ldo_hex2volt(ret); + if (ret < 0) + return ret; + *uV = ret; + return 0; + } + + hex = lp873x_ldo_volt2hex(*uV); + if (hex < 0) + return hex; + + ret &= ~LP873X_LDO_VOLT_MASK; + ret |= hex; + if (*uV > 1650000) + ret |= 0x80; + ret = pmic_reg_write(dev->parent, adr, ret); + + return ret; +} + +static int lp873x_ldo_probe(struct udevice *dev) +{ + struct dm_regulator_uclass_platdata *uc_pdata; + + uc_pdata = dev_get_uclass_platdata(dev); + uc_pdata->type = REGULATOR_TYPE_LDO; + + int idx = dev->driver_data; + if (idx >= LP873X_LDO_NUM) { + printf("Wrong ID for regulator\n"); + return -1; + } + + uc_pdata->ctrl_reg = lp873x_ldo_ctrl[idx]; + uc_pdata->volt_reg = lp873x_ldo_volt[idx]; + + return 0; +} + +static int ldo_get_value(struct udevice *dev) +{ + int uV; + int ret; + + ret = lp873x_ldo_val(dev, PMIC_OP_GET, &uV); + if (ret) + return ret; + + return uV; +} + +static int ldo_set_value(struct udevice *dev, int uV) +{ + return lp873x_ldo_val(dev, PMIC_OP_SET, &uV); +} + +static bool ldo_get_enable(struct udevice *dev) +{ + bool enable = false; + int ret; + + ret = lp873x_ldo_enable(dev, PMIC_OP_GET, &enable); + if (ret) + return ret; + + return enable; +} + +static int ldo_set_enable(struct udevice *dev, bool enable) +{ + return lp873x_ldo_enable(dev, PMIC_OP_SET, &enable); +} + +static int lp873x_buck_probe(struct udevice *dev) +{ + struct dm_regulator_uclass_platdata *uc_pdata; + int idx; + + uc_pdata = dev_get_uclass_platdata(dev); + uc_pdata->type = REGULATOR_TYPE_BUCK; + + idx = dev->driver_data; + if (idx >= LP873X_BUCK_NUM) { + printf("Wrong ID for regulator\n"); + return -1; + } + + uc_pdata->ctrl_reg = lp873x_buck_ctrl[idx]; + uc_pdata->volt_reg = lp873x_buck_volt[idx]; + + return 0; +} + +static int buck_get_value(struct udevice *dev) +{ + int uV; + int ret; + + ret = lp873x_buck_val(dev, PMIC_OP_GET, &uV); + if (ret) + return ret; + + return uV; +} + +static int buck_set_value(struct udevice *dev, int uV) +{ + return lp873x_buck_val(dev, PMIC_OP_SET, &uV); +} + +static bool buck_get_enable(struct udevice *dev) +{ + bool enable = false; + int ret; + + + ret = lp873x_buck_enable(dev, PMIC_OP_GET, &enable); + if (ret) + return ret; + + return enable; +} + +static int buck_set_enable(struct udevice *dev, bool enable) +{ + return lp873x_buck_enable(dev, PMIC_OP_SET, &enable); +} + +static const struct dm_regulator_ops lp873x_ldo_ops = { + .get_value = ldo_get_value, + .set_value = ldo_set_value, + .get_enable = ldo_get_enable, + .set_enable = ldo_set_enable, +}; + +U_BOOT_DRIVER(lp873x_ldo) = { + .name = LP873X_LDO_DRIVER, + .id = UCLASS_REGULATOR, + .ops = &lp873x_ldo_ops, + .probe = lp873x_ldo_probe, +}; + +static const struct dm_regulator_ops lp873x_buck_ops = { + .get_value = buck_get_value, + .set_value = buck_set_value, + .get_enable = buck_get_enable, + .set_enable = buck_set_enable, +}; + +U_BOOT_DRIVER(lp873x_buck) = { + .name = LP873X_BUCK_DRIVER, + .id = UCLASS_REGULATOR, + .ops = &lp873x_buck_ops, + .probe = lp873x_buck_probe, +};
Changes in v2:
- Used pmic_reg_read/pmic_reg_write instead of direct i2c read/write calls.
Keerthy
