[U-Boot] [PATCH] 85xx: Cleanup whitespace in mpc8536ds.c
--- board/freescale/mpc8536ds/mpc8536ds.c | 16 +++++----------- 1 files changed, 5 insertions(+), 11 deletions(-)
diff --git a/board/freescale/mpc8536ds/mpc8536ds.c b/board/freescale/mpc8536ds/mpc8536ds.c index 5bd20ce..032d732 100644 --- a/board/freescale/mpc8536ds/mpc8536ds.c +++ b/board/freescale/mpc8536ds/mpc8536ds.c @@ -256,14 +256,13 @@ pci_init_board(void) } else { printf (" PCIE3: disabled\n"); } - - } +} #else gur->devdisr |= MPC85xx_DEVDISR_PCIE3; /* disable */ #endif
#ifdef CONFIG_PCIE1 - { +{ volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; struct pci_controller *hose = &pcie1_hose; int pcie_ep = (host_agent == 5); @@ -315,14 +314,13 @@ pci_init_board(void) } else { printf (" PCIE1: disabled\n"); } - - } +} #else gur->devdisr |= MPC85xx_DEVDISR_PCIE; /* disable */ #endif
#ifdef CONFIG_PCIE2 - { +{ volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE2_ADDR; struct pci_controller *hose = &pcie2_hose; int pcie_ep = (host_agent == 3); @@ -372,13 +370,11 @@ pci_init_board(void) } else { printf (" PCIE2: disabled\n"); } - - } +} #else gur->devdisr |= MPC85xx_DEVDISR_PCIE2; /* disable */ #endif
- #ifdef CONFIG_PCI1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; @@ -391,7 +387,6 @@ pci_init_board(void) uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; /* PORDEVSR[14] */ uint pci_clk_sel = gur->porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; /* PORPLLSR[16] */
- if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { printf ("\n PCI: %d bit, %s MHz, %s, %s, %s (base address %x)\n", (pci_32) ? 32 : 64, @@ -441,7 +436,6 @@ pci_init_board(void) #endif }
- int board_early_init_r(void) { const unsigned int flashbase = CONFIG_SYS_FLASH_BASE;
Kumar Gala
