[U-Boot] [PATCH] powerpc: Add cpu_secondary_init_r to allow for initialization post env setup
We can simplify some cpu/SoC level initialization by moving it to be after the environment and non-volatile storage is setup as there might be dependancies on such things in various boot configurations.
For example for FSL SoC's with QE if we boot from NAND we need it setup to extra the ucode image to initialize the QE. If we always do this after environment & non-volatile storage is working we can have the code be the same regardless of NOR, NAND, SPI, MMC boot.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * This is really second version of the cpu_late_init_r patch - changed where we call cpu_secondary_init_r to be right after env_relocate
arch/powerpc/cpu/mpc85xx/cpu_init.c | 15 +++++++++------ arch/powerpc/lib/board.c | 14 ++++++++++++++ 2 files changed, 23 insertions(+), 6 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 8ece970..215b7b3 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -384,12 +384,6 @@ int cpu_init_r(void)
enable_cpc();
-#ifdef CONFIG_QE - uint qe_base = CONFIG_SYS_IMMR + 0x00080000; /* QE immr base */ - qe_init(qe_base); - qe_reset(); -#endif - /* needs to be in ram since code uses global static vars */ fsl_serdes_init();
@@ -449,3 +443,12 @@ int sata_initialize(void) return 1; } #endif + +void cpu_secondary_init_r(void) +{ +#ifdef CONFIG_QE + uint qe_base = CONFIG_SYS_IMMR + 0x00080000; /* QE immr base */ + qe_init(qe_base); + qe_reset(); +#endif +} diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index b88cf6b..38ca1f8 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -186,6 +186,12 @@ int __board_flash_wp_on(void) } int board_flash_wp_on(void) __attribute__((weak, alias("__board_flash_wp_on")));
+void __cpu_secondary_init_r(void) +{ +} +void cpu_secondary_init_r(void) +__attribute__((weak, alias("__cpu_secondary_init_r"))); + static int init_func_ram (void) { #ifdef CONFIG_BOARD_TYPES @@ -798,6 +804,14 @@ void board_init_r (gd_t *id, ulong dest_addr) env_relocate ();
/* + * after non-volatile devices & environment is setup and cpu code have + * another round to deal with any initialization that might require + * full access to the environment or loading of some image (firmware) + * from a non-volatile device + */ + cpu_secondary_init_r(); + + /* * Fill in missing fields of bd_info. * We do this here, where we have "normal" access to the * environment; we used to do this still running from ROM,
- This is really second version of the cpu_late_init_r patch
enable_cpc();
-#ifdef CONFIG_QE
- qe_init(qe_base);
- qe_reset();
-#endif
- qe_init(qe_base);
- qe_reset();
- cpu_secondary_init_r();
- Fill in missing fields of bd_info.
- We do this here, where we have "normal" access to the
- environment; we used to do this still running from ROM,
-- 1.6.0.6
Wolfgang,
Any comments on this, based on the discussion here:
http://lists.denx.de/pipermail/u-boot/2011-January/086567.html http://lists.denx.de/pipermail/u-boot/2011-February/086711.html
- k
Dear Kumar Gala,
In message 1E454B65-B8DC-4276-B6DD-7D4A3F5229CD@kernel.crashing.org you wrote:
Not really. I mean, I don't object.
On Feb 3, 2011, at 1:15 PM, Wolfgang Denk wrote:
Dear Kumar Gala,
Ok, thanks. I'll pull this into my 'next' tree.
- k
applied to 85xx next
- k
Kumar Gala
