[PATCH 1/2] env: ubi: add support of command env erase
Add support of opts erase for ubi env backend, this opts is used by command 'env erase'.
This command only zero-fill the env UBI volume CONFIG_ENV_UBI_VOLUME and CONFIG_ENV_UBI_VOLUME_REDUND, so the saved environment becomes invalid.
This patch introduces a local define ENV_UBI_VOLUME_REDUND only to avoid #if in the code, as CONFIG_ENV_UBI_VOLUME_REDUND is only defined when CONFIG_SYS_REDUNDAND_ENVIRONMENT is defined.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
env/ubi.c | 40 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 40 insertions(+)
diff --git a/env/ubi.c b/env/ubi.c index eb21c4f38b49..445d34fedb89 100644 --- a/env/ubi.c +++ b/env/ubi.c @@ -28,6 +28,12 @@
DECLARE_GLOBAL_DATA_PTR;
+#if CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define ENV_UBI_VOLUME_REDUND CONFIG_ENV_UBI_VOLUME_REDUND +#else +#define ENV_UBI_VOLUME_REDUND "invalid" +#endif + #ifdef CONFIG_CMD_SAVEENV #ifdef CONFIG_SYS_REDUNDAND_ENVIRONMENT static int env_ubi_save(void) @@ -177,9 +183,43 @@ static int env_ubi_load(void) } #endif /* CONFIG_SYS_REDUNDAND_ENVIRONMENT */
+static int env_ubi_erase(void) +{ + ALLOC_CACHE_ALIGN_BUFFER(char, env_buf, CONFIG_ENV_SIZE); + int ret = 0; + + if (ubi_part(CONFIG_ENV_UBI_PART, UBI_VID_OFFSET)) { + printf("\n** Cannot find mtd partition "%s"\n", + CONFIG_ENV_UBI_PART); + return 1; + } + + memset(env_buf, 0x0, CONFIG_ENV_SIZE); + + if (ubi_volume_write(CONFIG_ENV_UBI_VOLUME, + (void *)env_buf, CONFIG_ENV_SIZE)) { + printf("\n** Unable to erase env to %s:%s **\n", + CONFIG_ENV_UBI_PART, + CONFIG_ENV_UBI_VOLUME); + ret = 1; + } + if (IS_ENABLED(CONFIG_SYS_REDUNDAND_ENVIRONMENT)) { + if (ubi_volume_write(ENV_UBI_VOLUME_REDUND, + (void *)env_buf, CONFIG_ENV_SIZE)) { + printf("\n** Unable to erase env to %s:%s **\n", + CONFIG_ENV_UBI_PART, + ENV_UBI_VOLUME_REDUND); + ret = 1; + } + } + + return ret; +} + U_BOOT_ENV_LOCATION(ubi) = { .location = ENVL_UBI, ENV_NAME("UBI") .load = env_ubi_load, .save = env_save_ptr(env_ubi_save), + .erase = ENV_ERASE_PTR(env_ubi_erase), };
Add trace in env save to indicate any errors to end user and avoid silent output when the command 'env erase' is not executed as it is done in env_save with commit 8968288cb477 ("env: add failing trace in env_save")
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
env/env.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/env/env.c b/env/env.c index 69848fb06080..06078c7f3744 100644 --- a/env/env.c +++ b/env/env.c @@ -311,11 +311,15 @@ int env_erase(void) if (drv) { int ret;
- if (!drv->erase) + if (!drv->erase) { + printf("not possible\n"); return -ENODEV; + }
- if (!env_has_inited(drv->location)) + if (!env_has_inited(drv->location)) { + printf("not initialized\n"); return -ENODEV; + }
printf("Erasing Environment on %s... ", drv->name); ret = drv->erase();
Hi Patrick
if (!drv->erase)
if (!drv->erase) {
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Hello Patrick,
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com Reviewed-by: Heiko Schocher hs@denx.de
Hi Patrick
- ALLOC_CACHE_ALIGN_BUFFER(char, env_buf, CONFIG_ENV_SIZE);
- int ret = 0;
- if (ubi_part(CONFIG_ENV_UBI_PART, UBI_VID_OFFSET)) {
printf("\n** Cannot find mtd partition \"%s\"\n",
return 1;
- memset(env_buf, 0x0, CONFIG_ENV_SIZE);
- if (ubi_volume_write(CONFIG_ENV_UBI_VOLUME,
ret = 1;
- if (IS_ENABLED(CONFIG_SYS_REDUNDAND_ENVIRONMENT)) {
ret = 1;
- return ret;
- .erase = ENV_ERASE_PTR(env_ubi_erase),
Thanks Patrice
Hello Patrick,
bye, Heiko
- int ret = 0;
return 1;
ret = 1;
ret = 1;
- return ret;
Heiko Schocher
Patrice CHOTARD
Patrick Delaunay
