[PATCH v3 0/3] Allow disabling driver model for I2C in SPL
At present if U-Boot proper uses driver model for I2C, then SPL has to also. While this is desirable, it places a significant barrier to moving to driver model in some cases. For example, with a space-constrained SPL it may be necessary to enable CONFIG_SPL_OF_PLATDATA which involves adjusting some drivers.
This patch introduces a separate Kconfig symbols for enabling DM_I2C and DM_I2C_GPIO support in SPL.
This will also help to get away from dirty workarounds to achieve non-DM I2C support for SPL, which is currently used in some board header files like:
ifdef CONFIG_SPL_BUILD undef CONFIG_DM_I2C endif
All occurences were replaced automatically using these bash cmds: $ find . -type f -exec sed -i 's/ifndef CONFIG_DM_I2C/if !CONFIG_IS_ENABLED(DM_I2C)/g' {} + $ find . -type f -exec sed -i 's/ifdef CONFIG_DM_I2C/if CONFIG_IS_ENABLED(DM_I2C)/g' {} + $ find . -type f -exec sed -i 's/defined(CONFIG_DM_I2C)/CONFIG_IS_ENABLED(DM_I2C)/g' {} + $ find . -type f -exec sed -i 's/ifndef CONFIG_DM_I2C_GPIO/if !CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} + $ find . -type f -exec sed -i 's/ifdef CONFIG_DM_I2C_GPIO/if CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} + $ find . -type f -exec sed -i 's/defined(CONFIG_DM_I2C_GPIO)/CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
Azure CI results: https://dev.azure.com/igoropaniuk/u-boot/_build/results?buildId=6&view=r...
Changes in v3: - Drop undefs for CONFIG_DM_I2C and moved that to board defconfigs - Rebased on the latest master
Changes in v2: - Applied R-b tags from Simon and Heiko - Added additional patches that replace CONFIG_DM_I2C undefs with CONFIG_SPL_DM_I2C for SPL build case (this should be moved to board defconfigs by board maintainers)
Igor Opaniuk (3): dm: i2c: allow disabling driver model in SPL board: freescale: drop CONFIG_DM_I2C undefs dm: i2c: use CONFIG_IS_ENABLED macro for DM_I2C/DM_I2C_GPIO
.../include/asm/arch-fsl-layerscape/config.h | 2 +- arch/arm/include/asm/arch-lpc32xx/i2c.h | 2 +- arch/arm/include/asm/mach-imx/mxc_i2c.h | 2 +- arch/arm/include/asm/omap_i2c.h | 2 +- arch/arm/mach-imx/i2c-mxv7.c | 2 +- arch/arm/mach-keystone/ddr3_spd.c | 2 +- arch/arm/mach-kirkwood/include/mach/config.h | 2 +- arch/arm/mach-omap2/am33xx/board.c | 2 +- arch/arm/mach-omap2/am33xx/clk_synthesizer.c | 6 +- arch/arm/mach-omap2/boot-common.c | 2 +- arch/arm/mach-omap2/clocks-common.c | 2 +- arch/arm/mach-sunxi/board.c | 2 +- arch/powerpc/include/asm/fsl_i2c.h | 2 +- board/freescale/common/dcu_sii9022a.c | 2 +- board/freescale/common/diu_ch7301.c | 2 +- board/freescale/common/emc2305.c | 4 +- board/freescale/common/qixis.c | 4 +- board/freescale/common/sys_eeprom.c | 20 ++-- board/freescale/common/vid.c | 24 ++--- board/freescale/common/vsc3316_3308.c | 10 +- board/freescale/ls1012aqds/ls1012aqds.c | 2 +- board/freescale/ls1012ardb/eth.c | 2 +- board/freescale/ls1012ardb/ls1012ardb.c | 12 +-- board/freescale/ls1021aqds/dcu.c | 6 +- board/freescale/ls1021aqds/ls1021aqds.c | 2 +- board/freescale/ls1021atwr/ls1021atwr.c | 2 +- board/freescale/ls1028a/ls1028a.c | 2 +- board/freescale/ls1043aqds/ls1043aqds.c | 4 +- board/freescale/ls1046afrwy/ls1046afrwy.c | 2 +- board/freescale/ls1046aqds/ls1046aqds.c | 2 +- board/freescale/ls1088a/eth_ls1088aqds.c | 16 +-- board/freescale/ls1088a/ls1088a.c | 60 ++++++------ board/freescale/ls2080aqds/eth.c | 14 +-- board/freescale/ls2080aqds/ls2080aqds.c | 4 +- board/freescale/ls2080ardb/ls2080ardb.c | 2 +- board/freescale/lx2160a/lx2160a.c | 2 +- board/freescale/p1010rdb/p1010rdb.c | 8 +- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 2 +- board/freescale/t102xrdb/t102xrdb.c | 2 +- board/freescale/t208xqds/t208xqds.c | 2 +- board/friendlyarm/nanopi2/onewire.c | 6 +- board/keymile/common/ivm.c | 2 +- board/samsung/common/misc.c | 2 +- board/samsung/trats/trats.c | 10 +- board/samsung/trats2/trats2.c | 10 +- board/sunxi/board.c | 2 +- board/ti/am335x/board.c | 8 +- board/ti/am335x/mux.c | 2 +- board/ti/am43xx/board.c | 12 +-- board/ti/common/board_detect.c | 4 +- board/ti/ks2_evm/board_k2g.c | 2 +- board/wandboard/wandboard.c | 4 +- cmd/eeprom.c | 6 +- cmd/i2c.c | 98 +++++++++---------- configs/imx8mp_evk_defconfig | 1 + ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + .../ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + doc/driver-model/i2c-howto.rst | 2 +- drivers/ddr/fsl/main.c | 8 +- drivers/i2c/Kconfig | 21 ++++ drivers/i2c/Makefile | 4 +- drivers/i2c/davinci_i2c.c | 4 +- drivers/i2c/designware_i2c.c | 4 +- drivers/i2c/fsl_i2c.c | 6 +- drivers/i2c/ihs_i2c.c | 42 ++++---- drivers/i2c/lpc32xx_i2c.c | 4 +- drivers/i2c/mv_i2c.c | 2 +- drivers/i2c/mvtwsi.c | 16 +-- drivers/i2c/mxc_i2c.c | 4 +- drivers/i2c/omap24xx_i2c.c | 2 +- drivers/misc/Makefile | 2 +- drivers/power/palmas.c | 2 +- drivers/power/pmic/pmic_tps62362.c | 6 +- drivers/power/pmic/pmic_tps65217.c | 14 +-- drivers/power/pmic/pmic_tps65218.c | 4 +- drivers/power/pmic/pmic_tps65910.c | 6 +- drivers/power/twl4030.c | 2 +- drivers/power/twl6030.c | 2 +- drivers/tpm/tpm_atmel_twi.c | 6 +- drivers/usb/host/ohci-lpc32xx.c | 8 +- include/_exports.h | 2 +- include/config_fallbacks.h | 2 +- include/configs/MPC8548CDS.h | 2 +- include/configs/P1010RDB.h | 2 +- include/configs/P2041RDB.h | 2 +- include/configs/T102xRDB.h | 2 +- include/configs/T104xRDB.h | 3 +- include/configs/T208xQDS.h | 2 +- include/configs/T208xRDB.h | 2 +- include/configs/T4240RDB.h | 2 +- include/configs/am43xx_evm.h | 2 +- include/configs/corenet_ds.h | 2 +- include/configs/imx8mp_evk.h | 1 - include/configs/ls1012a_common.h | 2 +- include/configs/ls1021aiot.h | 2 +- include/configs/ls1021aqds.h | 2 +- include/configs/ls1021atsn.h | 2 +- include/configs/ls1021atwr.h | 3 +- include/configs/ls1028a_common.h | 2 +- include/configs/ls1043a_common.h | 2 +- include/configs/ls1046a_common.h | 3 +- include/configs/ls1088a_common.h | 2 +- include/configs/ls1088aqds.h | 2 +- include/configs/ls2080a_common.h | 2 +- include/configs/ls2080aqds.h | 2 +- include/configs/ls2080ardb.h | 2 +- include/configs/p1_p2_rdb_pc.h | 2 +- include/configs/phycore_imx8mp.h | 1 - include/configs/sunxi-common.h | 2 +- include/configs/ti_armv7_common.h | 2 +- include/exports.h | 2 +- include/i2c.h | 2 +- include/palmas.h | 2 +- include/twl4030.h | 2 +- include/twl6030.h | 2 +- 116 files changed, 339 insertions(+), 319 deletions(-)
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Heiko Schocher hs@denx.de Signed-off-by: Igor Opaniuk igor.opaniuk@foundries.io
(no changes since v2)
Changes in v2: - R-b tags applied (Simon and Heiko)
drivers/i2c/Kconfig | 21 +++++++++++++++++++++ drivers/i2c/Makefile | 4 ++-- drivers/misc/Makefile | 2 +- 3 files changed, 24 insertions(+), 3 deletions(-)
diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 403602fddf..5fce14122d 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -14,6 +14,17 @@ config DM_I2C device (bus child) info is kept as parent plat. The interface is defined in include/i2c.h.
+config SPL_DM_I2C + bool "Enable Driver Model for I2C drivers in SPL" + depends on SPL_DM && DM_I2C + default y + help + Enable driver model for I2C. The I2C uclass interface: probe, read, + write and speed, is implemented with the bus drivers operations, + which provide methods for bus setting and data transfer. Each chip + device (bus child) info is kept as parent platdata. The interface + is defined in include/i2c.h. + config I2C_CROS_EC_TUNNEL tristate "Chrome OS EC tunnel I2C bus" depends on CROS_EC @@ -61,6 +72,16 @@ config DM_I2C_GPIO bindings are supported. Binding info: doc/device-tree-bindings/i2c/i2c-gpio.txt
+config SPL_DM_I2C_GPIO + bool "Enable Driver Model for software emulated I2C bus driver in SPL" + depends on SPL_DM && DM_I2C_GPIO && SPL_DM_GPIO && SPL_GPIO_SUPPORT + default y + help + Enable the i2c bus driver emulation by using the GPIOs. The bus GPIO + configuration is given by the device tree. Kernel-style device tree + bindings are supported. + Binding info: doc/device-tree-bindings/i2c/i2c-gpio.txt + config SYS_I2C_AT91 bool "Atmel I2C driver" depends on DM_I2C && ARCH_AT91 diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 29aab0f9e3..acd27ac29d 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -2,9 +2,9 @@ # # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. -obj-$(CONFIG_DM_I2C) += i2c-uclass.o +obj-$(CONFIG_$(SPL_)DM_I2C) += i2c-uclass.o ifdef CONFIG_ACPIGEN -obj-$(CONFIG_DM_I2C) += acpi_i2c.o +obj-$(CONFIG_$(SPL_)DM_I2C) += acpi_i2c.o endif obj-$(CONFIG_$(SPL_)DM_I2C_GPIO) += i2c-gpio.o obj-$(CONFIG_$(SPL_)I2C_CROS_EC_TUNNEL) += cros_ec_tunnel.o diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index d737203704..1a49396007 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -17,7 +17,7 @@ obj-$(CONFIG_SANDBOX) += p2sb_sandbox.o p2sb_emul.o obj-$(CONFIG_SANDBOX) += swap_case.o endif
-ifdef CONFIG_DM_I2C +ifdef CONFIG_$(SPL_)DM_I2C ifndef CONFIG_SPL_BUILD obj-$(CONFIG_SANDBOX) += i2c_eeprom_emul.o endif
Hello Igor,
Changes in v2:
Applied to u-boot-i2c.git master
Thanks!
bye, Heiko
Drop CONFIG_DM_I2C undefs from board header files, and make them disabled on these boards in defconfigs instead.
Disabling on Kconfig symbol was done automatically with this script:
cd configs files=(*ls1046a*) files2=(*T104*RDB*) files3=(ls1021atwr_*) files4=("imx8mp_evk_defconfig phycore-imx8mp_defconfig") combine=("${files[@]}" "${files2[@]}" "${files3[@]}" "${files4[@]}") cd ..
for item in ${combine[*]} do echo "Adjusting $item" echo "# CONFIG_SPL_DM_I2C is not set" >> configs/$item make $item && make savedefconfig && cp defconfig configs/$item done
Signed-off-by: Igor Opaniuk igor.opaniuk@foundries.io ---
Changes in v3: - Drop CONFIG_DM_I2C undefs from board header files (instead of replacing them with another undef for CONFIG_SPL_DM_I2C), and make them disabled on these boards in defconfigs.
configs/imx8mp_evk_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + include/configs/T104xRDB.h | 1 - include/configs/imx8mp_evk.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/phycore_imx8mp.h | 1 - 9 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index e70c430616..47a52eedb9 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -69,6 +69,7 @@ CONFIG_CLK_IMX8MP=y CONFIG_MXC_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y +# CONFIG_SPL_DM_I2C is not set CONFIG_SYS_I2C_MXC=y CONFIG_LED=y CONFIG_LED_GPIO=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index e51dab0788..bce548d59c 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -52,6 +52,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DM_I2C=y +# CONFIG_SPL_DM_I2C is not set CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index 0a2c71f919..21a144afe2 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -50,6 +50,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DM_I2C=y +# CONFIG_SPL_DM_I2C is not set CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/phycore-imx8mp_defconfig b/configs/phycore-imx8mp_defconfig index 3d662e8b48..d09841a7f6 100644 --- a/configs/phycore-imx8mp_defconfig +++ b/configs/phycore-imx8mp_defconfig @@ -63,6 +63,7 @@ CONFIG_CLK_COMPOSITE_CCF=y CONFIG_CLK_IMX8MP=y CONFIG_MXC_GPIO=y CONFIG_DM_I2C=y +# CONFIG_SPL_DM_I2C is not set CONFIG_SYS_I2C_MXC=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index aee00a86cf..cf0f982375 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -30,7 +30,6 @@ #define CONFIG_SPL_SKIP_RELOCATE #define CONFIG_SPL_COMMON_INIT_DDR #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE -#undef CONFIG_DM_I2C #endif #define RESET_VECTOR_OFFSET 0x27FFC #define BOOT_PAGE_OFFSET 0x27000 diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 4850b1b934..61a5c6fb79 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -37,7 +37,6 @@ #define CONFIG_POWER_I2C #define CONFIG_POWER_PCA9450
-#undef CONFIG_DM_I2C #define CONFIG_SYS_I2C
#endif diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index dfb56437d9..068e744a61 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -442,7 +442,6 @@
#ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_MONITOR_BASE CONFIG_SPL_TEXT_BASE -#undef CONFIG_DM_I2C #else #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ #endif diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 32658cf641..0c32fceec2 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -16,7 +16,6 @@ #define SPL_NO_QSPI #define SPL_NO_USB #define SPL_NO_SATA -#undef CONFIG_DM_I2C #endif #if defined(CONFIG_SPL_BUILD) && \ (defined(CONFIG_NAND_BOOT) || defined(CONFIG_QSPI_BOOT)) diff --git a/include/configs/phycore_imx8mp.h b/include/configs/phycore_imx8mp.h index 889dd36e6e..0490049850 100644 --- a/include/configs/phycore_imx8mp.h +++ b/include/configs/phycore_imx8mp.h @@ -33,7 +33,6 @@ #define CONFIG_POWER_I2C #define CONFIG_POWER_PCA9450
#endif
Hello Igor,
Changes in v3:
Thanks!
bye, Heiko
Use CONFIG_IS_ENABLED() macro, which provides more convenient way to check $(SPL)DM_I2C/$(SPL)DM_I2C_GPIO configs for both SPL and U-Boot proper.
CONFIG_IS_ENABLED(DM_I2C) expands to: - 1 if CONFIG_SPL_BUILD is undefined and CONFIG_DM_I2C is set to 'y', - 1 if CONFIG_SPL_BUILD is defined and CONFIG_SPL_DM_I2C is set to 'y', - 0 otherwise.
Reviewed-by: Heiko Schocher hs@denx.de Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Igor Opaniuk igor.opaniuk@foundries.io
Changes in v2: - Added R-b tags (Heiko and Simon)
.../include/asm/arch-fsl-layerscape/config.h | 2 +- arch/arm/include/asm/arch-lpc32xx/i2c.h | 2 +- arch/arm/include/asm/mach-imx/mxc_i2c.h | 2 +- arch/arm/include/asm/omap_i2c.h | 2 +- arch/arm/mach-imx/i2c-mxv7.c | 2 +- arch/arm/mach-keystone/ddr3_spd.c | 2 +- arch/arm/mach-kirkwood/include/mach/config.h | 2 +- arch/arm/mach-omap2/am33xx/board.c | 2 +- arch/arm/mach-omap2/am33xx/clk_synthesizer.c | 6 +- arch/arm/mach-omap2/boot-common.c | 2 +- arch/arm/mach-omap2/clocks-common.c | 2 +- arch/arm/mach-sunxi/board.c | 2 +- arch/powerpc/include/asm/fsl_i2c.h | 2 +- board/freescale/common/dcu_sii9022a.c | 2 +- board/freescale/common/diu_ch7301.c | 2 +- board/freescale/common/emc2305.c | 4 +- board/freescale/common/qixis.c | 4 +- board/freescale/common/sys_eeprom.c | 20 ++-- board/freescale/common/vid.c | 24 ++--- board/freescale/common/vsc3316_3308.c | 10 +- board/freescale/ls1012aqds/ls1012aqds.c | 2 +- board/freescale/ls1012ardb/eth.c | 2 +- board/freescale/ls1012ardb/ls1012ardb.c | 12 +-- board/freescale/ls1021aqds/dcu.c | 6 +- board/freescale/ls1021aqds/ls1021aqds.c | 2 +- board/freescale/ls1021atwr/ls1021atwr.c | 2 +- board/freescale/ls1028a/ls1028a.c | 2 +- board/freescale/ls1043aqds/ls1043aqds.c | 4 +- board/freescale/ls1046afrwy/ls1046afrwy.c | 2 +- board/freescale/ls1046aqds/ls1046aqds.c | 2 +- board/freescale/ls1088a/eth_ls1088aqds.c | 16 +-- board/freescale/ls1088a/ls1088a.c | 60 ++++++------ board/freescale/ls2080aqds/eth.c | 14 +-- board/freescale/ls2080aqds/ls2080aqds.c | 4 +- board/freescale/ls2080ardb/ls2080ardb.c | 2 +- board/freescale/lx2160a/lx2160a.c | 2 +- board/freescale/p1010rdb/p1010rdb.c | 8 +- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 2 +- board/freescale/t102xrdb/t102xrdb.c | 2 +- board/freescale/t208xqds/t208xqds.c | 2 +- board/friendlyarm/nanopi2/onewire.c | 6 +- board/keymile/common/ivm.c | 2 +- board/samsung/common/misc.c | 2 +- board/samsung/trats/trats.c | 10 +- board/samsung/trats2/trats2.c | 10 +- board/sunxi/board.c | 2 +- board/ti/am335x/board.c | 8 +- board/ti/am335x/mux.c | 2 +- board/ti/am43xx/board.c | 12 +-- board/ti/common/board_detect.c | 4 +- board/ti/ks2_evm/board_k2g.c | 2 +- board/wandboard/wandboard.c | 4 +- cmd/eeprom.c | 6 +- cmd/i2c.c | 98 +++++++++---------- doc/driver-model/i2c-howto.rst | 2 +- drivers/ddr/fsl/main.c | 8 +- drivers/i2c/davinci_i2c.c | 4 +- drivers/i2c/designware_i2c.c | 4 +- drivers/i2c/fsl_i2c.c | 6 +- drivers/i2c/ihs_i2c.c | 42 ++++---- drivers/i2c/lpc32xx_i2c.c | 4 +- drivers/i2c/mv_i2c.c | 2 +- drivers/i2c/mvtwsi.c | 16 +-- drivers/i2c/mxc_i2c.c | 4 +- drivers/i2c/omap24xx_i2c.c | 2 +- drivers/power/palmas.c | 2 +- drivers/power/pmic/pmic_tps62362.c | 6 +- drivers/power/pmic/pmic_tps65217.c | 14 +-- drivers/power/pmic/pmic_tps65218.c | 4 +- drivers/power/pmic/pmic_tps65910.c | 6 +- drivers/power/twl4030.c | 2 +- drivers/power/twl6030.c | 2 +- drivers/tpm/tpm_atmel_twi.c | 6 +- drivers/usb/host/ohci-lpc32xx.c | 8 +- include/_exports.h | 2 +- include/config_fallbacks.h | 2 +- include/configs/MPC8548CDS.h | 2 +- include/configs/P1010RDB.h | 2 +- include/configs/P2041RDB.h | 2 +- include/configs/T102xRDB.h | 2 +- include/configs/T104xRDB.h | 2 +- include/configs/T208xQDS.h | 2 +- include/configs/T208xRDB.h | 2 +- include/configs/T4240RDB.h | 2 +- include/configs/am43xx_evm.h | 2 +- include/configs/corenet_ds.h | 2 +- include/configs/ls1012a_common.h | 2 +- include/configs/ls1021aiot.h | 2 +- include/configs/ls1021aqds.h | 2 +- include/configs/ls1021atsn.h | 2 +- include/configs/ls1021atwr.h | 2 +- include/configs/ls1028a_common.h | 2 +- include/configs/ls1043a_common.h | 2 +- include/configs/ls1046a_common.h | 2 +- include/configs/ls1088a_common.h | 2 +- include/configs/ls1088aqds.h | 2 +- include/configs/ls2080a_common.h | 2 +- include/configs/ls2080aqds.h | 2 +- include/configs/ls2080ardb.h | 2 +- include/configs/p1_p2_rdb_pc.h | 2 +- include/configs/sunxi-common.h | 2 +- include/configs/ti_armv7_common.h | 2 +- include/exports.h | 2 +- include/i2c.h | 2 +- include/palmas.h | 2 +- include/twl4030.h | 2 +- include/twl6030.h | 2 +- 107 files changed, 311 insertions(+), 311 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index a9bd8b24fd..da7ca0587c 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -183,7 +183,7 @@ #elif defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define TZPC_BASE 0x02200000 #define TZPCDECPROT_0_SET_BASE (TZPC_BASE + 0x804) -#if !defined(CONFIG_DM_I2C) +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_EARLY_INIT #endif diff --git a/arch/arm/include/asm/arch-lpc32xx/i2c.h b/arch/arm/include/asm/arch-lpc32xx/i2c.h index f39b14001b..3918178d3a 100644 --- a/arch/arm/include/asm/arch-lpc32xx/i2c.h +++ b/arch/arm/include/asm/arch-lpc32xx/i2c.h @@ -22,7 +22,7 @@ struct lpc32xx_i2c_base { u32 stxfl; };
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) enum { I2C_0, I2C_1, I2C_2, }; diff --git a/arch/arm/include/asm/mach-imx/mxc_i2c.h b/arch/arm/include/asm/mach-imx/mxc_i2c.h index c016aa7474..e8b330f33d 100644 --- a/arch/arm/include/asm/mach-imx/mxc_i2c.h +++ b/arch/arm/include/asm/mach-imx/mxc_i2c.h @@ -53,7 +53,7 @@ struct mxc_i2c_bus { #if CONFIG_IS_ENABLED(CLK) struct clk per_clk; #endif -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) int (*idle_bus_fn)(void *p); void *idle_bus_data; #else diff --git a/arch/arm/include/asm/omap_i2c.h b/arch/arm/include/asm/omap_i2c.h index ec7a145f17..9f0f272234 100644 --- a/arch/arm/include/asm/omap_i2c.h +++ b/arch/arm/include/asm/omap_i2c.h @@ -3,7 +3,7 @@ #ifndef _OMAP_I2C_H #define _OMAP_I2C_H
/* Information about a GPIO bank */ struct omap_i2c_plat { diff --git a/arch/arm/mach-imx/i2c-mxv7.c b/arch/arm/mach-imx/i2c-mxv7.c index e6c74bf77e..d36347d8e8 100644 --- a/arch/arm/mach-imx/i2c-mxv7.c +++ b/arch/arm/mach-imx/i2c-mxv7.c @@ -102,7 +102,7 @@ int setup_i2c(unsigned i2c_index, int speed, int slave_addr, if (ret) goto err_idle;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) bus_i2c_init(i2c_index, speed, slave_addr, force_idle_bus, p); #endif
diff --git a/arch/arm/mach-keystone/ddr3_spd.c b/arch/arm/mach-keystone/ddr3_spd.c index 3803449c2b..c4a1908af8 100644 --- a/arch/arm/mach-keystone/ddr3_spd.c +++ b/arch/arm/mach-keystone/ddr3_spd.c @@ -404,7 +404,7 @@ static void init_ddr3param(struct ddr3_spd_cb *spd_cb, static int ddr3_read_spd(ddr3_spd_eeprom_t *spd_params) { int ret; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) int old_bus;
i2c_init(CONFIG_SYS_DAVINCI_I2C_SPEED, CONFIG_SYS_DAVINCI_I2C_SLAVE); diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h index 3bd032e087..4794f7aa9d 100644 --- a/arch/arm/mach-kirkwood/include/mach/config.h +++ b/arch/arm/mach-kirkwood/include/mach/config.h @@ -96,7 +96,7 @@ /* * I2C related stuff */ -#if defined(CONFIG_CMD_I2C) && !defined(CONFIG_DM_I2C) +#if defined(CONFIG_CMD_I2C) && !CONFIG_IS_ENABLED(DM_I2C) #ifndef CONFIG_SYS_I2C_SOFT #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MVTWSI diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index e17898d8fb..53b01fd7fc 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -112,7 +112,7 @@ U_BOOT_DRVINFOS(am33xx_uarts) = { # endif };
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) static const struct omap_i2c_plat am33xx_i2c[] = { { I2C_BASE1, 100000, OMAP_I2C_REV_V2}, { I2C_BASE2, 100000, OMAP_I2C_REV_V2}, diff --git a/arch/arm/mach-omap2/am33xx/clk_synthesizer.c b/arch/arm/mach-omap2/am33xx/clk_synthesizer.c index ff1bfaf84b..59f0d8ea71 100644 --- a/arch/arm/mach-omap2/am33xx/clk_synthesizer.c +++ b/arch/arm/mach-omap2/am33xx/clk_synthesizer.c @@ -29,7 +29,7 @@ static int clk_synthesizer_reg_read(struct udevice *dev, int addr, u8 *buf) /* Enable Bye read */ addr = addr | CLK_SYNTHESIZER_BYTE_MODE;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) /* Send the command byte */ rc = i2c_write(CLK_SYNTHESIZER_I2C_ADDR, addr, 1, buf, 1); if (rc) @@ -72,7 +72,7 @@ static int clk_synthesizer_reg_write(struct udevice *dev, int addr, u8 val) cmd[0] = addr | CLK_SYNTHESIZER_BYTE_MODE; cmd[1] = val;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) rc = i2c_write(CLK_SYNTHESIZER_I2C_ADDR, addr, 1, cmd, 2); #else rc = dm_i2c_write(dev, addr, cmd, 2); @@ -96,7 +96,7 @@ int setup_clock_synthesizer(struct clk_synth *data) int rc; u8 val = 0; struct udevice *dev = NULL; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) rc = i2c_probe(CLK_SYNTHESIZER_I2C_ADDR); if (rc) { printf("i2c probe failed at address 0x%x\n", diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index cb9d7fdb15..0bebc4469d 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -201,7 +201,7 @@ void spl_board_init(void) #if defined(CONFIG_SPL_NAND_SUPPORT) || defined(CONFIG_SPL_ONENAND_SUPPORT) gpmc_init(); #endif -#if defined(CONFIG_SPL_I2C_SUPPORT) && !defined(CONFIG_DM_I2C) +#if defined(CONFIG_SPL_I2C_SUPPORT) && !CONFIG_IS_ENABLED(DM_I2C) i2c_init(CONFIG_SYS_OMAP24_I2C_SPEED, CONFIG_SYS_OMAP24_I2C_SLAVE); #endif #if defined(CONFIG_AM33XX) && defined(CONFIG_SPL_MUSB_NEW_SUPPORT) diff --git a/arch/arm/mach-omap2/clocks-common.c b/arch/arm/mach-omap2/clocks-common.c index 757fa3801a..14b638a651 100644 --- a/arch/arm/mach-omap2/clocks-common.c +++ b/arch/arm/mach-omap2/clocks-common.c @@ -912,7 +912,7 @@ void prcm_init(void) enable_basic_uboot_clocks(); }
-#if !defined(CONFIG_DM_I2C) +#if !CONFIG_IS_ENABLED(DM_I2C) void gpi2c_init(void) { static int gpi2c = 1; diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index ae6bc656d9..e3c138d4b2 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -222,7 +222,7 @@ void s_init(void) clock_init(); timer_init(); gpio_init(); -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_init_board(); #endif eth_init_board(); diff --git a/arch/powerpc/include/asm/fsl_i2c.h b/arch/powerpc/include/asm/fsl_i2c.h index 73105fa8e4..1b1766180a 100644 --- a/arch/powerpc/include/asm/fsl_i2c.h +++ b/arch/powerpc/include/asm/fsl_i2c.h @@ -68,7 +68,7 @@ typedef struct fsl_i2c_base { u8 res6[0xE8]; } fsl_i2c_t;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct fsl_i2c_dev { struct fsl_i2c_base __iomem *base; /* register base */ u32 i2c_clk; diff --git a/board/freescale/common/dcu_sii9022a.c b/board/freescale/common/dcu_sii9022a.c index 832ae258f1..9137d246ea 100644 --- a/board/freescale/common/dcu_sii9022a.c +++ b/board/freescale/common/dcu_sii9022a.c @@ -64,7 +64,7 @@ int dcu_set_dvi_encoder(struct fb_videomode *videomode) u8 temp; u16 temp1, temp2; u32 temp3; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; int ret;
diff --git a/board/freescale/common/diu_ch7301.c b/board/freescale/common/diu_ch7301.c index 02a271895b..05e6a3acf1 100644 --- a/board/freescale/common/diu_ch7301.c +++ b/board/freescale/common/diu_ch7301.c @@ -53,7 +53,7 @@ int diu_set_dvi_encoder(unsigned int pixclock) u8 temp;
temp = I2C_DVI_TEST_PATTERN_VAL; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev;
ret = i2c_get_chip_for_busnum(CONFIG_SYS_I2C_DVI_BUS_NUM, diff --git a/board/freescale/common/emc2305.c b/board/freescale/common/emc2305.c index 050b679f3c..56e177538c 100644 --- a/board/freescale/common/emc2305.c +++ b/board/freescale/common/emc2305.c @@ -23,7 +23,7 @@ void set_fan_speed(u8 data, int chip_addr) I2C_EMC2305_FAN5};
for (index = 0; index < NUM_OF_FANS; index++) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) if (i2c_write(chip_addr, Fan[index], 1, &data, 1) != 0) { printf("Error: failed to change fan speed @%x\n", Fan[index]); @@ -47,7 +47,7 @@ void emc2305_init(int chip_addr) u8 data;
data = I2C_EMC2305_CMD; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) if (i2c_write(chip_addr, I2C_EMC2305_CONF, 1, &data, 1) != 0) printf("Error: failed to configure EMC2305\n"); #else diff --git a/board/freescale/common/qixis.c b/board/freescale/common/qixis.c index 1696c24e27..2bb838cea6 100644 --- a/board/freescale/common/qixis.c +++ b/board/freescale/common/qixis.c @@ -32,7 +32,7 @@ #ifdef CONFIG_SYS_I2C_FPGA_ADDR u8 qixis_read_i2c(unsigned int reg) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) return i2c_reg_read(CONFIG_SYS_I2C_FPGA_ADDR, reg); #else struct udevice *dev; @@ -47,7 +47,7 @@ u8 qixis_read_i2c(unsigned int reg) void qixis_write_i2c(unsigned int reg, u8 value) { u8 val = value; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_reg_write(CONFIG_SYS_I2C_FPGA_ADDR, reg, val); #else struct udevice *dev; diff --git a/board/freescale/common/sys_eeprom.c b/board/freescale/common/sys_eeprom.c index 33ae4c15ba..be0fda0638 100644 --- a/board/freescale/common/sys_eeprom.c +++ b/board/freescale/common/sys_eeprom.c @@ -152,7 +152,7 @@ static int read_eeprom(void) { int ret; #ifdef CONFIG_SYS_EEPROM_BUS_NUM -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) unsigned int bus; #endif #endif @@ -161,13 +161,13 @@ static int read_eeprom(void) return 0;
#ifdef CONFIG_SYS_EEPROM_BUS_NUM -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) bus = i2c_get_bus_num(); i2c_set_bus_num(CONFIG_SYS_EEPROM_BUS_NUM); #endif #endif
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_read(CONFIG_SYS_I2C_EEPROM_ADDR, 0, CONFIG_SYS_I2C_EEPROM_ADDR_LEN, (void *)&e, sizeof(e)); @@ -186,7 +186,7 @@ static int read_eeprom(void) #endif
#ifdef CONFIG_SYS_EEPROM_BUS_NUM -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_set_bus_num(bus); #endif #endif @@ -223,7 +223,7 @@ static int prog_eeprom(void) int i; void *p; #ifdef CONFIG_SYS_EEPROM_BUS_NUM -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) unsigned int bus; #endif #endif @@ -237,7 +237,7 @@ static int prog_eeprom(void) #endif update_crc();
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #ifdef CONFIG_SYS_EEPROM_BUS_NUM bus = i2c_get_bus_num(); i2c_set_bus_num(CONFIG_SYS_EEPROM_BUS_NUM); @@ -250,7 +250,7 @@ static int prog_eeprom(void) * complete a given write. */ for (i = 0, p = &e; i < sizeof(e); i += 8, p += 8) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(CONFIG_SYS_I2C_EEPROM_ADDR, i, CONFIG_SYS_I2C_EEPROM_ADDR_LEN, p, min((int)(sizeof(e) - i), 8)); @@ -279,7 +279,7 @@ static int prog_eeprom(void) /* Verify the write by reading back the EEPROM and comparing */ struct eeprom e2;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_read(CONFIG_SYS_I2C_EEPROM_ADDR, 0, CONFIG_SYS_I2C_EEPROM_ADDR_LEN, (void *)&e2, sizeof(e2)); @@ -302,7 +302,7 @@ static int prog_eeprom(void) ret = -1; }
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #ifdef CONFIG_SYS_EEPROM_BUS_NUM i2c_set_bus_num(bus); #endif @@ -594,7 +594,7 @@ unsigned int get_cpu_board_revision(void) u8 minor; /* 0x05 Board revision, minor */ } be;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_read(CONFIG_SYS_I2C_EEPROM_ADDR, 0, CONFIG_SYS_I2C_EEPROM_ADDR_LEN, (void *)&be, sizeof(be)); #else diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index 2617f61520..20f5421da0 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -65,14 +65,14 @@ static int find_ir_chip_on_i2c(void) u8 byte; int i; const int ir_i2c_addr[] = {0x38, 0x08, 0x09}; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; #endif
/* Check all the address */ for (i = 0; i < (sizeof(ir_i2c_addr)/sizeof(ir_i2c_addr[0])); i++) { i2caddress = ir_i2c_addr[i]; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_read(i2caddress, IR36021_MFR_ID_OFFSET, 1, (void *)&byte, sizeof(byte)); @@ -117,12 +117,12 @@ static int read_voltage_from_INA220(int i2caddress) int i, ret, voltage_read = 0; u16 vol_mon; u8 buf[2]; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; #endif
for (i = 0; i < NUM_READINGS; i++) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_read(I2C_VOL_MONITOR_ADDR, I2C_VOL_MONITOR_BUS_V_OFFSET, 1, (void *)&buf, 2); @@ -160,12 +160,12 @@ static int read_voltage_from_IR(int i2caddress) int i, ret, voltage_read = 0; u16 vol_mon; u8 buf; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; #endif
for (i = 0; i < NUM_READINGS; i++) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_read(i2caddress, IR36021_LOOP1_VOUT_OFFSET, 1, (void *)&buf, 1); @@ -213,7 +213,7 @@ static int read_voltage_from_LTC(int i2caddress) int ret, vcode = 0; u8 chan = PWM_CHANNEL0;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) /* select the PAGE 0 using PMBus commands PAGE for VDD*/ ret = i2c_write(I2C_VOL_MONITOR_ADDR, PMBUS_CMD_PAGE, 1, &chan, 1); @@ -229,7 +229,7 @@ static int read_voltage_from_LTC(int i2caddress) return ret; }
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) /*read the output voltage using PMBus command READ_VOUT*/ ret = i2c_read(I2C_VOL_MONITOR_ADDR, PMBUS_CMD_READ_VOUT, 1, (void *)&vcode, 2); @@ -344,7 +344,7 @@ static int set_voltage_to_IR(int i2caddress, int vdd) vid = DIV_ROUND_UP(vdd - 245, 5); #endif
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(i2caddress, IR36021_LOOP1_MANUAL_ID_OFFSET, 1, (void *)&vid, sizeof(vid)); #else @@ -392,7 +392,7 @@ static int set_voltage_to_LTC(int i2caddress, int vdd) vdd & 0xFF, (vdd & 0xFF00) >> 8};
/* Write the desired voltage code to the regulator */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) /* Check write protect state */ ret = i2c_read(I2C_VOL_MONITOR_ADDR, PMBUS_CMD_WRITE_PROTECT, 1, @@ -621,7 +621,7 @@ int adjust_vdd(ulong vdd_override) }
/* check IR chip work on Intel mode*/ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_read(i2caddress, IR36021_INTEL_MODE_OOFSET, 1, (void *)&buf, 1); @@ -803,7 +803,7 @@ int adjust_vdd(ulong vdd_override) }
/* check IR chip work on Intel mode*/ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_read(i2caddress, IR36021_INTEL_MODE_OOFSET, 1, (void *)&buf, 1); diff --git a/board/freescale/common/vsc3316_3308.c b/board/freescale/common/vsc3316_3308.c index 8aceb8ef17..c51f3c5aca 100644 --- a/board/freescale/common/vsc3316_3308.c +++ b/board/freescale/common/vsc3316_3308.c @@ -34,7 +34,7 @@ int vsc_if_enable(unsigned int vsc_addr)
/* enable 2-wire Serial InterFace (I2C) */ data = 0x02; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) int ret, bus_num = 0; struct udevice *dev;
@@ -62,7 +62,7 @@ int vsc3316_config(unsigned int vsc_addr, int8_t con_arr[][2], debug("VSC:Initializing VSC3316 at I2C address 0x%2x" " for Tx\n", vsc_addr);
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) int bus_num = 0; struct udevice *dev;
@@ -185,7 +185,7 @@ int vsc3308_config_adjust(unsigned int vsc_addr, const int8_t con_arr[][2], debug("VSC:Initializing VSC3308 at I2C address 0x%x for Tx\n", vsc_addr);
@@ -385,7 +385,7 @@ int vsc3308_config(unsigned int vsc_addr, const int8_t con_arr[][2],
debug("VSC:Initializing VSC3308 at I2C address 0x%x" " for Tx\n", vsc_addr); -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) int bus_num = 0; struct udevice *dev;
@@ -509,7 +509,7 @@ void vsc_wp_config(unsigned int vsc_addr)
/* For new crosspoint configuration to occur, WP bit of * CORE_CONFIG_REG should be set 1 and then reset to 0 */ -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) int ret, bus_num = 0; struct udevice *dev;
diff --git a/board/freescale/ls1012aqds/ls1012aqds.c b/board/freescale/ls1012aqds/ls1012aqds.c index 7bea45c8ae..0d17cc82a5 100644 --- a/board/freescale/ls1012aqds/ls1012aqds.c +++ b/board/freescale/ls1012aqds/ls1012aqds.c @@ -111,7 +111,7 @@ int misc_init_r(void) u8 mux_sdhc_cd = 0x80; int bus_num = 0;
diff --git a/board/freescale/ls1012ardb/eth.c b/board/freescale/ls1012ardb/eth.c index 2241d061dd..bb3fbc71ef 100644 --- a/board/freescale/ls1012ardb/eth.c +++ b/board/freescale/ls1012ardb/eth.c @@ -29,7 +29,7 @@ static inline void ls1012ardb_reset_phy(void) { #ifdef CONFIG_TARGET_LS1012ARDB /* Through reset IO expander reset both RGMII and SGMII PHYs */ -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; int ret;
diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index 30b43ea135..8782988da9 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -42,7 +42,7 @@ int checkboard(void) puts("Board: LS1012ARDB ");
/* Initialize i2c early for Serial flash bank information */ -#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev;
ret = i2c_get_chip_for_busnum(bus_num, I2C_MUX_IO_ADDR, @@ -194,7 +194,7 @@ int esdhc_status_fixup(void *blob, const char *compat) u8 io = 0; int ret, bus_num = 0;
ret = i2c_get_chip_for_busnum(bus_num, I2C_MUX_IO_ADDR, @@ -233,7 +233,7 @@ int esdhc_status_fixup(void *blob, const char *compat) * 10 - eMMC Memory * 11 - SPI */ -#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_read(dev, I2C_MUX_IO_0, &io, 1); #else ret = i2c_read(I2C_MUX_IO_ADDR, I2C_MUX_IO_0, 1, &io, 1); @@ -272,7 +272,7 @@ static int switch_to_bank1(void) u8 data = 0xf4, chip_addr = 0x24, offset_addr = 0x03; int ret, bus_num = 0;
ret = i2c_get_chip_for_busnum(bus_num, chip_addr, @@ -337,7 +337,7 @@ static int switch_to_bank2(void) u8 chip_addr = 0x24; int ret, i, bus_num = 0;
ret = i2c_get_chip_for_busnum(bus_num, chip_addr, @@ -360,7 +360,7 @@ static int switch_to_bank2(void) * CS routed to SPI memory bank2 */ for (i = 0; i < sizeof(data); i++) { -#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_write(dev, offset_addr[i], &data[i], 1); #else /* Non DM I2C support - will be removed */ ret = i2c_write(chip_addr, offset_addr[i], 1, &data[i], 1); diff --git a/board/freescale/ls1021aqds/dcu.c b/board/freescale/ls1021aqds/dcu.c index b648a7872b..d9c1e65fff 100644 --- a/board/freescale/ls1021aqds/dcu.c +++ b/board/freescale/ls1021aqds/dcu.c @@ -19,7 +19,7 @@ DECLARE_GLOBAL_DATA_PTR; static int select_i2c_ch_pca9547(u8 ch, int bus_num) { int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev;
ret = i2c_get_chip_for_busnum(bus_num, I2C_MUX_PCA_ADDR_PRI, @@ -64,7 +64,7 @@ int platform_dcu_init(struct fb_info *fbinfo, u8 ch;
/* Mux I2C3+I2C4 as HSYNC+VSYNC */ -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev;
/* QIXIS device mount on I2C1 bus*/ @@ -112,7 +112,7 @@ int platform_dcu_init(struct fb_info *fbinfo, pixval = 1000000000 / dcu_fb_videomode->pixclock; pixval *= 1000;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_set_bus_num(CONFIG_SYS_I2C_DVI_BUS_NUM); #endif select_i2c_ch_pca9547(I2C_MUX_CH_CH7301, diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 4169a0fc85..aa1f6025c1 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -144,7 +144,7 @@ unsigned long get_board_ddr_clk(void) int select_i2c_ch_pca9547(u8 ch, int bus_num) { int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev;
ret = i2c_get_chip_for_busnum(bus_num, I2C_MUX_PCA_ADDR_PRI, diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index 2889bd8ded..a79d045da2 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -457,7 +457,7 @@ void ls1twr_program_regulator(void) #define MC34VR500_ADDR 0x8 #define MC34VR500_DEVICEID 0x4 #define MC34VR500_DEVICEID_MASK 0x0f -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; int ret;
diff --git a/board/freescale/ls1028a/ls1028a.c b/board/freescale/ls1028a/ls1028a.c index e37e3a3c16..eb4d7ce48d 100644 --- a/board/freescale/ls1028a/ls1028a.c +++ b/board/freescale/ls1028a/ls1028a.c @@ -91,7 +91,7 @@ int board_init(void) #if defined(CONFIG_TARGET_LS1028ARDB) u8 val = I2C_MUX_CH_DEFAULT;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_MUX_PCA_ADDR_PRI, 0x0b, 1, &val, 1); #else struct udevice *dev; diff --git a/board/freescale/ls1043aqds/ls1043aqds.c b/board/freescale/ls1043aqds/ls1043aqds.c index ef0f2e6122..92cc20fc04 100644 --- a/board/freescale/ls1043aqds/ls1043aqds.c +++ b/board/freescale/ls1043aqds/ls1043aqds.c @@ -282,7 +282,7 @@ int select_i2c_ch_pca9547(u8 ch, int bus_num) { int ret;
ret = i2c_get_chip_for_busnum(bus_num, I2C_MUX_PCA_ADDR_PRI, @@ -337,7 +337,7 @@ void board_retimer_init(void) /* Retimer is connected to I2C1_CH7_CH5 */ select_i2c_ch_pca9547(I2C_MUX_CH7, bus_num); reg = I2C_MUX_CH5; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; int ret;
diff --git a/board/freescale/ls1046afrwy/ls1046afrwy.c b/board/freescale/ls1046afrwy/ls1046afrwy.c index 4ebf77b1ad..b4de3dbb34 100644 --- a/board/freescale/ls1046afrwy/ls1046afrwy.c +++ b/board/freescale/ls1046afrwy/ls1046afrwy.c @@ -41,7 +41,7 @@ int select_i2c_ch_pca9547(u8 ch, int bus_num) { int ret;
ret = i2c_get_chip_for_busnum(bus_num, I2C_MUX_PCA_ADDR_PRI, diff --git a/board/freescale/ls1046aqds/ls1046aqds.c b/board/freescale/ls1046aqds/ls1046aqds.c index 33b10277af..421939c30c 100644 --- a/board/freescale/ls1046aqds/ls1046aqds.c +++ b/board/freescale/ls1046aqds/ls1046aqds.c @@ -278,7 +278,7 @@ u32 get_lpuart_clk(void) int select_i2c_ch_pca9547(u8 ch, int bus_num) { int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev;
ret = i2c_get_chip_for_busnum(bus_num, I2C_MUX_PCA_ADDR_PRI, diff --git a/board/freescale/ls1088a/eth_ls1088aqds.c b/board/freescale/ls1088a/eth_ls1088aqds.c index bf4f57e6f8..140733de6a 100644 --- a/board/freescale/ls1088a/eth_ls1088aqds.c +++ b/board/freescale/ls1088a/eth_ls1088aqds.c @@ -114,12 +114,12 @@ static void sgmii_configure_repeater(int dpmac) {0x18, NULL}, {0x23, ®_val[3]}, {0x2d, ®_val[4]}, {4, ®_val[5]}, }; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *udev; #endif
/* Set I2c to Slot 1 */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(0x77, 0, 0, &a, 1); #else ret = i2c_get_chip_for_busnum(0, 0x77, 1, &udev); @@ -173,7 +173,7 @@ static void sgmii_configure_repeater(int dpmac) return; }
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) i2c_get_chip_for_busnum(0, i2c_phy_addr, 1, &udev); #endif
@@ -184,7 +184,7 @@ static void sgmii_configure_repeater(int dpmac) reg_pair[5].val = &ch_b_eq[i]; reg_pair[6].val = &ch_b_ctl2[j]; for (k = 0; k < 10; k++) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(i2c_phy_addr, reg_pair[k].addr, 1, reg_pair[k].val, 1); @@ -257,12 +257,12 @@ static void qsgmii_configure_repeater(int dpmac) const char *dev = mdio_names[EMI1_SLOT1]; int ret = 0; unsigned short value; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *udev; #endif
/* Set I2c to Slot 1 */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(0x77, 0, 0, &a, 1); #else ret = i2c_get_chip_for_busnum(0, 0x77, 1, &udev); @@ -304,7 +304,7 @@ static void qsgmii_configure_repeater(int dpmac) return; }
@@ -316,7 +316,7 @@ static void qsgmii_configure_repeater(int dpmac) reg_pair[6].val = &ch_b_ctl2[j];
for (k = 0; k < 10; k++) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(i2c_phy_addr, reg_pair[k].addr, 1, reg_pair[k].val, 1); diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 5d19702a05..b1250a62a2 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -378,7 +378,7 @@ int select_i2c_ch_pca9547(u8 ch) { int ret;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); #else struct udevice *dev; @@ -405,7 +405,7 @@ void board_retimer_init(void)
/* Access to Control/Shared register */ reg = 0x0; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR, 0xff, 1, ®, 1); #else struct udevice *dev; @@ -415,7 +415,7 @@ void board_retimer_init(void) #endif
/* Read device revision and ID */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_read(I2C_RETIMER_ADDR, 1, 1, ®, 1); #else dm_i2c_read(dev, 1, ®, 1); @@ -424,20 +424,20 @@ void board_retimer_init(void)
/* Enable Broadcast. All writes target all channel register sets */ reg = 0x0c; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR, 0xff, 1, ®, 1); #else dm_i2c_write(dev, 0xff, ®, 1); #endif
/* Reset Channel Registers */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_read(I2C_RETIMER_ADDR, 0, 1, ®, 1); #else dm_i2c_read(dev, 0, ®, 1); #endif reg |= 0x4; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR, 0, 1, ®, 1); #else dm_i2c_write(dev, 0, ®, 1); @@ -445,45 +445,45 @@ void board_retimer_init(void)
/* Set data rate as 10.3125 Gbps */ reg = 0x90; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR, 0x60, 1, ®, 1); #else dm_i2c_write(dev, 0x60, ®, 1); #endif reg = 0xb3; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR, 0x61, 1, ®, 1); #else dm_i2c_write(dev, 0x61, ®, 1); #endif reg = 0x90; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR, 0x62, 1, ®, 1); #else dm_i2c_write(dev, 0x62, ®, 1); #endif reg = 0xb3; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR, 0x63, 1, ®, 1); #else dm_i2c_write(dev, 0x63, ®, 1); #endif reg = 0xcd; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR, 0x64, 1, ®, 1); #else dm_i2c_write(dev, 0x64, ®, 1); #endif
/* Select VCO Divider to full rate (000) */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_read(I2C_RETIMER_ADDR, 0x2F, 1, ®, 1); #else dm_i2c_read(dev, 0x2F, ®, 1); #endif reg &= 0x0f; reg |= 0x70; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR, 0x2F, 1, ®, 1); #else dm_i2c_write(dev, 0x2F, ®, 1); @@ -495,7 +495,7 @@ void board_retimer_init(void)
/* Access to Control/Shared register */ reg = 0x0; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR2, 0xff, 1, ®, 1); #else i2c_get_chip_for_busnum(0, I2C_RETIMER_ADDR2, 1, &dev); @@ -503,7 +503,7 @@ void board_retimer_init(void) #endif
/* Read device revision and ID */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_read(I2C_RETIMER_ADDR2, 1, 1, ®, 1); #else dm_i2c_read(dev, 1, ®, 1); @@ -512,20 +512,20 @@ void board_retimer_init(void)
/* Enable Broadcast. All writes target all channel register sets */ reg = 0x0c; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR2, 0xff, 1, ®, 1); #else dm_i2c_write(dev, 0xff, ®, 1); #endif
/* Reset Channel Registers */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_read(I2C_RETIMER_ADDR2, 0, 1, ®, 1); #else dm_i2c_read(dev, 0, ®, 1); #endif reg |= 0x4; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR2, 0, 1, ®, 1); #else dm_i2c_write(dev, 0, ®, 1); @@ -533,45 +533,45 @@ void board_retimer_init(void)
/* Set data rate as 10.3125 Gbps */ reg = 0x90; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR2, 0x60, 1, ®, 1); #else dm_i2c_write(dev, 0x60, ®, 1); #endif reg = 0xb3; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR2, 0x61, 1, ®, 1); #else dm_i2c_write(dev, 0x61, ®, 1); #endif reg = 0x90; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR2, 0x62, 1, ®, 1); #else dm_i2c_write(dev, 0x62, ®, 1); #endif reg = 0xb3; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR2, 0x63, 1, ®, 1); #else dm_i2c_write(dev, 0x63, ®, 1); #endif reg = 0xcd; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR2, 0x64, 1, ®, 1); #else dm_i2c_write(dev, 0x64, ®, 1); #endif
/* Select VCO Divider to full rate (000) */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_read(I2C_RETIMER_ADDR2, 0x2F, 1, ®, 1); #else dm_i2c_read(dev, 0x2F, ®, 1); #endif reg &= 0x0f; reg |= 0x70; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_write(I2C_RETIMER_ADDR2, 0x2F, 1, ®, 1); #else dm_i2c_write(dev, 0x2F, ®, 1); @@ -639,7 +639,7 @@ int get_serdes_volt(void) u8 chan = PWM_CHANNEL0;
/* Select the PAGE 0 using PMBus commands PAGE for VDD */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(I2C_SVDD_MONITOR_ADDR, PMBUS_CMD_PAGE, 1, &chan, 1); #else @@ -657,7 +657,7 @@ int get_serdes_volt(void) }
/* Read the output voltage using PMBus command READ_VOUT */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_read(I2C_SVDD_MONITOR_ADDR, PMBUS_CMD_READ_VOUT, 1, (void *)&vcode, 2); #else @@ -678,7 +678,7 @@ int set_serdes_volt(int svdd) svdd & 0xFF, (svdd & 0xFF00) >> 8};
/* Write the desired voltage code to the SVDD regulator */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(I2C_SVDD_MONITOR_ADDR, PMBUS_CMD_PAGE_PLUS_WRITE, 1, (void *)&buff, 5); #else @@ -719,7 +719,7 @@ int set_serdes_volt(int svdd) printf("SVDD changing of RDB\n");
/* Read the BRDCFG54 via CLPD */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_read(CONFIG_SYS_I2C_FPGA_ADDR, QIXIS_BRDCFG4_OFFSET, 1, (void *)&brdcfg4, 1); #else @@ -739,7 +739,7 @@ int set_serdes_volt(int svdd) brdcfg4 = brdcfg4 | 0x08;
/* Write to the BRDCFG4 */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(CONFIG_SYS_I2C_FPGA_ADDR, QIXIS_BRDCFG4_OFFSET, 1, (void *)&brdcfg4, 1); #else diff --git a/board/freescale/ls2080aqds/eth.c b/board/freescale/ls2080aqds/eth.c index 4b7f85540d..914cd0a9ab 100644 --- a/board/freescale/ls2080aqds/eth.c +++ b/board/freescale/ls2080aqds/eth.c @@ -125,12 +125,12 @@ static void sgmii_configure_repeater(int serdes_port) };
int *riser_phy_addr = &xqsgii_riser_phy_addr[0]; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *udev; #endif
/* Set I2c to Slot 1 */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(0x77, 0, 0, &a, 1); #else ret = i2c_get_chip_for_busnum(0, 0x77, 1, &udev); @@ -151,7 +151,7 @@ static void sgmii_configure_repeater(int serdes_port) mii_bus = 1; dpmac_id = dpmac + 9; a = 0xb; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(0x76, 0, 0, &a, 1); #else ret = i2c_get_chip_for_busnum(0, 0x76, 1, &udev); @@ -198,7 +198,7 @@ static void sgmii_configure_repeater(int serdes_port) reg_pair[6].val = &ch_b_ctl2[j];
for (k = 0; k < 10; k++) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(i2c_addr[dpmac], reg_pair[k].addr, 1, reg_pair[k].val, 1); @@ -277,12 +277,12 @@ static void qsgmii_configure_repeater(int dpmac) const char *dev = "LS2080A_QDS_MDIO0"; int ret = 0; unsigned short value; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *udev; #endif
/* Set I2c to Slot 1 */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(0x77, 0, 0, &a, 1); #else ret = i2c_get_chip_for_busnum(0, 0x77, 1, &udev); @@ -347,7 +347,7 @@ static void qsgmii_configure_repeater(int dpmac) reg_pair[6].val = &ch_b_ctl2[j];
for (k = 0; k < 10; k++) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(i2c_phy_addr, reg_pair[k].addr, 1, reg_pair[k].val, 1); diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 3eb40f5e2a..866d413f90 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -163,7 +163,7 @@ unsigned long get_board_ddr_clk(void) int select_i2c_ch_pca9547(u8 ch) { int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev;
ret = i2c_get_chip_for_busnum(0, I2C_MUX_PCA_ADDR_PRI, 1, &dev); @@ -237,7 +237,7 @@ int board_init(void) select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT);
#ifdef CONFIG_RTC_ENABLE_32KHZ_OUTPUT -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) rtc_enable_32khz_output(0, CONFIG_SYS_I2C_RTC_ADDR); #else rtc_enable_32khz_output(); diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index c7e9c1dacf..a5c9cbe3b5 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -166,7 +166,7 @@ int select_i2c_ch_pca9547(u8 ch) { int ret;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); #else struct udevice *dev; diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index ea027bec56..13a64b878f 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -82,7 +82,7 @@ int select_i2c_ch_pca9547(u8 ch) { int ret;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); #else struct udevice *dev; diff --git a/board/freescale/p1010rdb/p1010rdb.c b/board/freescale/p1010rdb/p1010rdb.c index 4c3a03e7cd..1219698184 100644 --- a/board/freescale/p1010rdb/p1010rdb.c +++ b/board/freescale/p1010rdb/p1010rdb.c @@ -140,7 +140,7 @@ int config_board_mux(int ctrl_type) ccsr_gur_t __iomem *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); u8 tmp;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; int ret; #if defined(CONFIG_TARGET_P1010RDB_PA) @@ -376,7 +376,7 @@ int i2c_pca9557_read(int type) u8 val; int bus_num = I2C_PCA9557_BUS_NUM;
@@ -418,7 +418,7 @@ int checkboard(void) printf("Board: %sRDB-PA, ", cpu->name); #elif defined(CONFIG_TARGET_P1010RDB_PB) printf("Board: %sRDB-PB, ", cpu->name); -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; int ret;
@@ -461,7 +461,7 @@ int checkboard(void) case 0xe: puts("SDHC\n"); val = 0x60; /* set pca9557 pin input/output */ -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) dm_i2c_write(dev, 3, &val, 1); #else i2c_write(I2C_PCA9557_ADDR2, 3, 1, &val, 1); diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index 4584f0147b..8273384f2d 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -173,7 +173,7 @@ int checkboard(void) in_8(&cpld_data->pcba_rev) & 0x0F);
/* Initialize i2c early for rom_loc and flash bank information */ - #if defined(CONFIG_DM_I2C) + #if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; int ret;
diff --git a/board/freescale/t102xrdb/t102xrdb.c b/board/freescale/t102xrdb/t102xrdb.c index bb775eb2d3..4112bfd830 100644 --- a/board/freescale/t102xrdb/t102xrdb.c +++ b/board/freescale/t102xrdb/t102xrdb.c @@ -258,7 +258,7 @@ static u32 t1023rdb_ctrl(u32 ctrl_type) u8 tmp; int bus_num = I2C_PCA6408_BUS_NUM;
diff --git a/board/freescale/t208xqds/t208xqds.c b/board/freescale/t208xqds/t208xqds.c index f3af8d5292..d6df88889e 100644 --- a/board/freescale/t208xqds/t208xqds.c +++ b/board/freescale/t208xqds/t208xqds.c @@ -82,7 +82,7 @@ int select_i2c_ch_pca9547(u8 ch, int bus_num) { int ret;
ret = i2c_get_chip_for_busnum(bus_num, I2C_MUX_PCA_ADDR_PRI, 1, &dev); diff --git a/board/friendlyarm/nanopi2/onewire.c b/board/friendlyarm/nanopi2/onewire.c index 994befb1ec..fb356639be 100644 --- a/board/friendlyarm/nanopi2/onewire.c +++ b/board/friendlyarm/nanopi2/onewire.c @@ -35,7 +35,7 @@ static int bus_type = -1; static int lcd_id = -1; static unsigned short lcd_fwrev; static int current_brightness = -1; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) static struct udevice *i2c_dev; #endif
@@ -182,7 +182,7 @@ static int onewire_i2c_do_request(unsigned char req, unsigned char *buf) tx[0] = req; tx[1] = crc8_ow(req << 24, 8);
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) if (dm_i2c_write(i2c_dev, 0, tx, 2)) return -EIO;
@@ -214,7 +214,7 @@ static void onewire_i2c_init(void) unsigned char buf[4]; int ret;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_chip_for_busnum(ONEWIRE_I2C_BUS, ONEWIRE_I2C_ADDR, 0, &i2c_dev); #else diff --git a/board/keymile/common/ivm.c b/board/keymile/common/ivm.c index bc8ffd56e1..9a3a856be0 100644 --- a/board/keymile/common/ivm.c +++ b/board/keymile/common/ivm.c @@ -333,7 +333,7 @@ static int ivm_populate_env(unsigned char *buf, int len, int mac_address_offset) int ivm_read_eeprom(unsigned char *buf, int len, int mac_address_offset) { int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *eedev = NULL;
ret = i2c_get_chip_for_busnum(CONFIG_KM_IVM_BUS, diff --git a/board/samsung/common/misc.c b/board/samsung/common/misc.c index 837463ba78..bdc999dfec 100644 --- a/board/samsung/common/misc.c +++ b/board/samsung/common/misc.c @@ -116,7 +116,7 @@ void set_board_info(void) #ifdef CONFIG_LCD_MENU static int power_key_pressed(u32 reg) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ +#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ struct pmic *pmic; u32 status; u32 mask; diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 2e80dbbc84..d06687620c 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -52,7 +52,7 @@ int exynos_init(void) return 0; }
-#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ +#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ static void trats_low_power_mode(void) { struct exynos4_clock *clk = @@ -114,7 +114,7 @@ static void trats_low_power_mode(void)
int exynos_power_init(void) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ +#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ int chrg, ret; struct power_battery *pb; struct pmic *p_fg, *p_chrg, *p_muic, *p_bat; @@ -293,7 +293,7 @@ int board_usb_init(int index, enum usb_init_type init)
int g_dnl_board_usb_cable_connected(void) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ +#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ struct pmic *muic = pmic_get("MAX8997_MUIC"); if (!muic) return 0; @@ -415,7 +415,7 @@ void exynos_reset_lcd(void)
int lcd_power(void) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ +#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); if (!p) @@ -439,7 +439,7 @@ int lcd_power(void)
int mipi_power(void) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ +#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); if (!p) diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index 69e0ef192d..59e6fbf4b0 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -129,7 +129,7 @@ int exynos_init(void)
int exynos_power_init(void) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ +#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ int chrg; struct power_battery *pb; struct pmic *p_chrg, *p_muic, *p_fg, *p_bat; @@ -192,7 +192,7 @@ int exynos_power_init(void) #ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ +#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ int ret = 0; unsigned int val; struct pmic *p, *p_pmic, *p_muic; @@ -269,7 +269,7 @@ int board_usb_init(int index, enum usb_init_type init)
int g_dnl_board_usb_cable_connected(void) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ +#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ struct pmic *muic = pmic_get("MAX77693_MUIC"); if (!muic) return 0; @@ -288,7 +288,7 @@ int g_dnl_board_usb_cable_connected(void) #ifdef CONFIG_LCD int mipi_power(void) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ +#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ struct pmic *p = pmic_get("MAX77686_PMIC");
/* LDO8 VMIPI_1.0V_AP */ @@ -302,7 +302,7 @@ int mipi_power(void)
void exynos_lcd_power_on(void) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ +#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ struct pmic *p = pmic_get("MAX77686_PMIC");
/* LCD_2.2V_EN: GPC0[1] */ diff --git a/board/sunxi/board.c b/board/sunxi/board.c index e42b61e906..d24503224d 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -292,7 +292,7 @@ int board_init(void) } }
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) /* * Temporary workaround for enabling I2C clocks until proper sunxi DM * clk, reset and pinctrl drivers land. diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 3cc0e4b91c..c285ac7552 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -76,7 +76,7 @@ static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; void do_board_detect(void) { enable_i2c0_pin_mux(); -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_init(CONFIG_SYS_OMAP24_I2C_SPEED, CONFIG_SYS_OMAP24_I2C_SLAVE); #endif if (ti_i2c_eeprom_am_get(CONFIG_EEPROM_BUS_ADDRESS, @@ -335,7 +335,7 @@ static void scale_vcores_bone(int freq) if (board_is_bone() && !strncmp(board_ti_get_rev(), "00A1", 4)) return;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) if (i2c_probe(TPS65217_CHIP_PM)) return; #else @@ -434,7 +434,7 @@ void scale_vcores_generic(int freq) * 1.10V. For MPU voltage we need to switch based on * the frequency we are running at. */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) if (i2c_probe(TPS65910_CTRL_I2C_ADDR)) return; #else @@ -468,7 +468,7 @@ void gpi2c_init(void)
if (first_time) { enable_i2c0_pin_mux(); -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_init(CONFIG_SYS_OMAP24_I2C_SPEED, CONFIG_SYS_OMAP24_I2C_SLAVE); #endif diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c index 6fb2c009ba..03adcd2b76 100644 --- a/board/ti/am335x/mux.c +++ b/board/ti/am335x/mux.c @@ -333,7 +333,7 @@ static unsigned short detect_daughter_board_profile(void) { unsigned short val;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) if (i2c_probe(I2C_CPLD_ADDR)) return PROFILE_NONE;
diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 62ed37cb48..c172d1c277 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -392,7 +392,7 @@ void scale_vcores_generic(u32 m) { int mpu_vdd, ddr_volt;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) if (i2c_probe(TPS65218_CHIP_PM)) return; #else @@ -450,7 +450,7 @@ void scale_vcores_idk(u32 m) { int mpu_vdd;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) if (i2c_probe(TPS62362_I2C_ADDR)) return; #else @@ -491,7 +491,7 @@ void gpi2c_init(void)
if (first_time) { enable_i2c0_pin_mux(); -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_init(CONFIG_SYS_OMAP24_I2C_SPEED, CONFIG_SYS_OMAP24_I2C_SLAVE); #endif @@ -631,14 +631,14 @@ void sdram_init(void) int power_init_board(void) { int rc; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) struct pmic *p = NULL; #endif if (board_is_idk()) { rc = power_tps62362_init(0); if (rc) goto done; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) p = pmic_get("TPS62362"); if (!p || pmic_probe(p)) goto done; @@ -648,7 +648,7 @@ int power_init_board(void) rc = power_tps65218_init(0); if (rc) goto done; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) p = pmic_get("TPS65218_PMIC"); if (!p || pmic_probe(p)) goto done; diff --git a/board/ti/common/board_detect.c b/board/ti/common/board_detect.c index 8b3b4bc825..de92eb0981 100644 --- a/board/ti/common/board_detect.c +++ b/board/ti/common/board_detect.c @@ -22,7 +22,7 @@
#include "board_detect.h"
-#if !defined(CONFIG_DM_I2C) +#if !CONFIG_IS_ENABLED(DM_I2C) /** * ti_i2c_eeprom_init - Initialize an i2c bus and probe for a device * @i2c_bus: i2c bus number to initialize @@ -89,7 +89,7 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr, u32 hdr_read; int rc;
-#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; struct udevice *bus;
diff --git a/board/ti/ks2_evm/board_k2g.c b/board/ti/ks2_evm/board_k2g.c index 2be86d6d26..5229afad63 100644 --- a/board/ti/ks2_evm/board_k2g.c +++ b/board/ti/ks2_evm/board_k2g.c @@ -259,7 +259,7 @@ int board_fit_config_name_match(const char *name) #if defined(CONFIG_DTB_RESELECT) static int k2g_alt_board_detect(void) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) int rc;
rc = i2c_set_bus_num(1); diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index e0e01b1a4a..56cab0b176 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -53,7 +53,7 @@ DECLARE_GLOBAL_DATA_PTR; #define REV_DETECTION IMX_GPIO_NR(2, 28)
/* Speed defined in Kconfig is only applicable when not using DM_I2C. */ -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) #define I2C1_SPEED_NON_DM 0 #define I2C2_SPEED_NON_DM 0 #else @@ -258,7 +258,7 @@ static void do_enable_hdmi(struct display_info_t const *dev)
static int detect_i2c(struct display_info_t const *dev) { -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *bus, *udev; int rc;
diff --git a/cmd/eeprom.c b/cmd/eeprom.c index 7fa62bba8f..b3fd37c827 100644 --- a/cmd/eeprom.c +++ b/cmd/eeprom.c @@ -61,7 +61,7 @@ #endif #endif
-#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) static int eeprom_i2c_bus; #endif
@@ -73,7 +73,7 @@ __weak int eeprom_write_enable(unsigned dev_addr, int state) void eeprom_init(int bus) { /* I2C EEPROM */ -#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) eeprom_i2c_bus = bus; #elif defined(CONFIG_SYS_I2C) if (bus >= 0) @@ -132,7 +132,7 @@ static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, { int ret = 0;
ret = i2c_get_chip_for_busnum(eeprom_i2c_bus, addr[0], diff --git a/cmd/i2c.c b/cmd/i2c.c index aae2dd41fe..5d0e207874 100644 --- a/cmd/i2c.c +++ b/cmd/i2c.c @@ -124,13 +124,13 @@ static uchar i2c_no_probes[] = CONFIG_SYS_I2C_NOPROBES; * For legacy code, this is not stored, so we need to use a suitable * default. */ -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) #define DEFAULT_ADDR_LEN (-1) #else #define DEFAULT_ADDR_LEN 1 #endif
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) static struct udevice *i2c_cur_bus;
static int cmd_i2c_set_bus_num(unsigned int busnum) @@ -209,7 +209,7 @@ void i2c_init_board(void) * * Returns I2C bus speed in Hz. */ -#if !defined(CONFIG_SYS_I2C) && !defined(CONFIG_DM_I2C) +#if !defined(CONFIG_SYS_I2C) && !CONFIG_IS_ENABLED(DM_I2C) /* * TODO: Implement architecture-specific get/set functions * Should go away, if we switched completely to new multibus support @@ -298,7 +298,7 @@ static int do_i2c_read(struct cmd_tbl *cmdtp, int flag, int argc, int alen; u_char *memaddr; int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; #endif
@@ -329,7 +329,7 @@ static int do_i2c_read(struct cmd_tbl *cmdtp, int flag, int argc, */ memaddr = (u_char *)simple_strtoul(argv[4], NULL, 16);
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_cur_bus_chip(chip, &dev); if (!ret && alen != -1) ret = i2c_set_chip_offset_len(dev, alen); @@ -352,7 +352,7 @@ static int do_i2c_write(struct cmd_tbl *cmdtp, int flag, int argc, int alen; u_char *memaddr; int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; struct dm_i2c_chip *i2c_chip; #endif @@ -384,7 +384,7 @@ static int do_i2c_write(struct cmd_tbl *cmdtp, int flag, int argc, */ length = simple_strtoul(argv[4], NULL, 16);
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_cur_bus_chip(chip, &dev); if (!ret && alen != -1) ret = i2c_set_chip_offset_len(dev, alen); @@ -402,7 +402,7 @@ static int do_i2c_write(struct cmd_tbl *cmdtp, int flag, int argc, * a page boundary. No write delay upon completion, take this * into account if linking commands. */ -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) i2c_chip->flags &= ~DM_I2C_CHIP_WR_ADDRESS; ret = dm_i2c_write(dev, devaddr, memaddr, length); #else @@ -416,7 +416,7 @@ static int do_i2c_write(struct cmd_tbl *cmdtp, int flag, int argc, * write transactions of one byte each */ while (length-- > 0) { -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) i2c_chip->flags |= DM_I2C_CHIP_WR_ADDRESS; ret = dm_i2c_write(dev, devaddr++, memaddr++, 1); #else @@ -435,7 +435,7 @@ static int do_i2c_write(struct cmd_tbl *cmdtp, int flag, int argc, return 0; }
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) static int do_i2c_flags(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { @@ -520,7 +520,7 @@ static int do_i2c_md(struct cmd_tbl *cmdtp, int flag, int argc, int alen; int j, nbytes, linebytes; int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; #endif
@@ -562,7 +562,7 @@ static int do_i2c_md(struct cmd_tbl *cmdtp, int flag, int argc, length = simple_strtoul(argv[3], NULL, 16); }
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_cur_bus_chip(chip, &dev); if (!ret && alen != -1) ret = i2c_set_chip_offset_len(dev, alen); @@ -583,7 +583,7 @@ static int do_i2c_md(struct cmd_tbl *cmdtp, int flag, int argc,
linebytes = (nbytes > DISP_LINE_LEN) ? DISP_LINE_LEN : nbytes;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_read(dev, addr, linebuf, linebytes); #else ret = i2c_read(chip, addr, alen, linebuf, linebytes); @@ -641,7 +641,7 @@ static int do_i2c_mw(struct cmd_tbl *cmdtp, int flag, int argc, uchar byte; int count; int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; #endif
@@ -661,7 +661,7 @@ static int do_i2c_mw(struct cmd_tbl *cmdtp, int flag, int argc, if (alen > 3) return CMD_RET_USAGE;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_cur_bus_chip(chip, &dev); if (!ret && alen != -1) ret = i2c_set_chip_offset_len(dev, alen); @@ -682,7 +682,7 @@ static int do_i2c_mw(struct cmd_tbl *cmdtp, int flag, int argc, count = 1;
while (count-- > 0) { -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_write(dev, addr++, &byte, 1); #else ret = i2c_write(chip, addr++, alen, &byte, 1); @@ -730,7 +730,7 @@ static int do_i2c_crc(struct cmd_tbl *cmdtp, int flag, int argc, ulong crc; ulong err; int ret = 0; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; #endif
@@ -750,7 +750,7 @@ static int do_i2c_crc(struct cmd_tbl *cmdtp, int flag, int argc, if (alen > 3) return CMD_RET_USAGE;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_cur_bus_chip(chip, &dev); if (!ret && alen != -1) ret = i2c_set_chip_offset_len(dev, alen); @@ -770,7 +770,7 @@ static int do_i2c_crc(struct cmd_tbl *cmdtp, int flag, int argc, crc = 0; err = 0; while (count-- > 0) { -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_read(dev, addr, &byte, 1); #else ret = i2c_read(chip, addr, alen, &byte, 1); @@ -814,7 +814,7 @@ static int mod_i2c_mem(struct cmd_tbl *cmdtp, int incrflag, int flag, int argc, int size = 1; int nbytes; int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; #endif
@@ -851,7 +851,7 @@ static int mod_i2c_mem(struct cmd_tbl *cmdtp, int incrflag, int flag, int argc, return CMD_RET_USAGE; }
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_cur_bus_chip(chip, &dev); if (!ret && alen != -1) ret = i2c_set_chip_offset_len(dev, alen); @@ -865,7 +865,7 @@ static int mod_i2c_mem(struct cmd_tbl *cmdtp, int incrflag, int flag, int argc, */ do { printf("%08lx:", addr); -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_read(dev, addr, (uchar *)&data, size); #else ret = i2c_read(chip, addr, alen, (uchar *)&data, size); @@ -912,7 +912,7 @@ static int mod_i2c_mem(struct cmd_tbl *cmdtp, int incrflag, int flag, int argc, * good enough to not time out */ bootretry_reset_cmd_timeout(); -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_write(dev, addr, (uchar *)&data, size); #else @@ -964,7 +964,7 @@ static int do_i2c_probe(struct cmd_tbl *cmdtp, int flag, int argc, unsigned int bus = GET_BUS_NUM; #endif /* NOPROBES */ int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *bus, *dev;
if (i2c_get_cur_bus(&bus)) @@ -990,7 +990,7 @@ static int do_i2c_probe(struct cmd_tbl *cmdtp, int flag, int argc, if (skip) continue; #endif -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_probe(bus, j, 0, &dev); #else ret = i2c_probe(j); @@ -1039,7 +1039,7 @@ static int do_i2c_loop(struct cmd_tbl *cmdtp, int flag, int argc, u_char bytes[16]; int delay; int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; #endif
@@ -1058,7 +1058,7 @@ static int do_i2c_loop(struct cmd_tbl *cmdtp, int flag, int argc, alen = get_alen(argv[2], DEFAULT_ADDR_LEN); if (alen > 3) return CMD_RET_USAGE; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_cur_bus_chip(chip, &dev); if (!ret && alen != -1) ret = i2c_set_chip_offset_len(dev, alen); @@ -1084,7 +1084,7 @@ static int do_i2c_loop(struct cmd_tbl *cmdtp, int flag, int argc, * Run the loop... */ while (1) { -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_read(dev, addr, bytes, length); #else ret = i2c_read(chip, addr, alen, bytes, length); @@ -1165,7 +1165,7 @@ static int do_sdram(struct cmd_tbl *cmdtp, int flag, int argc, u_char data[128]; u_char cksum; int j, ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; #endif
@@ -1221,7 +1221,7 @@ static int do_sdram(struct cmd_tbl *cmdtp, int flag, int argc, */ chip = simple_strtoul (argv[1], NULL, 16);
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_cur_bus_chip(chip, &dev); if (!ret) ret = dm_i2c_read(dev, 0, data, sizeof(data)); @@ -1664,7 +1664,7 @@ int do_edid(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) uint chip; struct edid1_info edid; int ret; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; #endif
@@ -1674,7 +1674,7 @@ int do_edid(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) }
chip = simple_strtoul(argv[1], NULL, 16); -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_cur_bus_chip(chip, &dev); if (!ret) ret = dm_i2c_read(dev, 0, (uchar *)&edid, sizeof(edid)); @@ -1695,7 +1695,7 @@ int do_edid(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) } #endif /* CONFIG_I2C_EDID */
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) static void show_bus(struct udevice *bus) { struct udevice *dev; @@ -1725,13 +1725,13 @@ static void show_bus(struct udevice *bus) * * Returns zero always. */ -#if defined(CONFIG_SYS_I2C) || defined(CONFIG_DM_I2C) +#if defined(CONFIG_SYS_I2C) || CONFIG_IS_ENABLED(DM_I2C) static int do_i2c_show_bus(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { if (argc == 1) { /* show all busses */ -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *bus; struct uclass *uc; int ret; @@ -1766,7 +1766,7 @@ static int do_i2c_show_bus(struct cmd_tbl *cmdtp, int flag, int argc,
/* show specific bus */ i = simple_strtoul(argv[1], NULL, 10); -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *bus; int ret;
@@ -1812,7 +1812,7 @@ static int do_i2c_show_bus(struct cmd_tbl *cmdtp, int flag, int argc, * on error. */ #if defined(CONFIG_SYS_I2C) || defined(CONFIG_I2C_MULTI_BUS) || \ - defined(CONFIG_DM_I2C) + CONFIG_IS_ENABLED(DM_I2C) static int do_i2c_bus_num(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { @@ -1821,7 +1821,7 @@ static int do_i2c_bus_num(struct cmd_tbl *cmdtp, int flag, int argc,
if (argc == 1) { /* querying current setting */ -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *bus;
if (!i2c_get_cur_bus(&bus)) @@ -1841,7 +1841,7 @@ static int do_i2c_bus_num(struct cmd_tbl *cmdtp, int flag, int argc, } #endif printf("Setting bus to %d\n", bus_no); -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = cmd_i2c_set_bus_num(bus_no); #else ret = i2c_set_bus_num(bus_no); @@ -1869,14 +1869,14 @@ static int do_i2c_bus_speed(struct cmd_tbl *cmdtp, int flag, int argc, { int speed, ret=0;
if (i2c_get_cur_bus(&bus)) return 1; #endif if (argc == 1) { -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) speed = dm_i2c_get_bus_speed(bus); #else speed = i2c_get_bus_speed(); @@ -1886,7 +1886,7 @@ static int do_i2c_bus_speed(struct cmd_tbl *cmdtp, int flag, int argc, } else { speed = simple_strtoul(argv[1], NULL, 10); printf("Setting bus speed to %d Hz\n", speed); -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_set_bus_speed(bus, speed); #else ret = i2c_set_bus_speed(speed); @@ -1942,7 +1942,7 @@ static int do_i2c_nm(struct cmd_tbl *cmdtp, int flag, int argc, static int do_i2c_reset(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { -#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *bus;
if (i2c_get_cur_bus(&bus)) @@ -1960,12 +1960,12 @@ static int do_i2c_reset(struct cmd_tbl *cmdtp, int flag, int argc, }
static struct cmd_tbl cmd_i2c_sub[] = { -#if defined(CONFIG_SYS_I2C) || defined(CONFIG_DM_I2C) +#if defined(CONFIG_SYS_I2C) || CONFIG_IS_ENABLED(DM_I2C) U_BOOT_CMD_MKENT(bus, 1, 1, do_i2c_show_bus, "", ""), #endif U_BOOT_CMD_MKENT(crc32, 3, 1, do_i2c_crc, "", ""), #if defined(CONFIG_SYS_I2C) || \ - defined(CONFIG_I2C_MULTI_BUS) || defined(CONFIG_DM_I2C) + defined(CONFIG_I2C_MULTI_BUS) || CONFIG_IS_ENABLED(DM_I2C) U_BOOT_CMD_MKENT(dev, 1, 1, do_i2c_bus_num, "", ""), #endif /* CONFIG_I2C_MULTI_BUS */ #if defined(CONFIG_I2C_EDID) @@ -1979,7 +1979,7 @@ static struct cmd_tbl cmd_i2c_sub[] = { U_BOOT_CMD_MKENT(probe, 0, 1, do_i2c_probe, "", ""), U_BOOT_CMD_MKENT(read, 5, 1, do_i2c_read, "", ""), U_BOOT_CMD_MKENT(write, 6, 0, do_i2c_write, "", ""), -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) U_BOOT_CMD_MKENT(flags, 2, 1, do_i2c_flags, "", ""), U_BOOT_CMD_MKENT(olen, 2, 1, do_i2c_olen, "", ""), #endif @@ -2036,13 +2036,13 @@ static int do_i2c(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) /***************************************************/ #ifdef CONFIG_SYS_LONGHELP static char i2c_help_text[] = -#if defined(CONFIG_SYS_I2C) || defined(CONFIG_DM_I2C) +#if defined(CONFIG_SYS_I2C) || CONFIG_IS_ENABLED(DM_I2C) "bus [muxtype:muxaddr:muxchannel] - show I2C bus info\n" "i2c " /* That's the prefix for the crc32 command below. */ #endif "crc32 chip address[.0, .1, .2] count - compute CRC32 checksum\n" #if defined(CONFIG_SYS_I2C) || \ - defined(CONFIG_I2C_MULTI_BUS) || defined(CONFIG_DM_I2C) + defined(CONFIG_I2C_MULTI_BUS) || CONFIG_IS_ENABLED(DM_I2C) "i2c dev [dev] - show or set current I2C bus\n" #endif /* CONFIG_I2C_MULTI_BUS */ #if defined(CONFIG_I2C_EDID) @@ -2057,7 +2057,7 @@ static char i2c_help_text[] = "i2c read chip address[.0, .1, .2] length memaddress - read to memory\n" "i2c write memaddress chip address[.0, .1, .2] length [-s] - write memory\n" " to I2C; the -s option selects bulk write in a single transaction\n" -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) "i2c flags chip [flags] - set or get chip flags\n" "i2c olen chip [offset_length] - set or get chip offset length\n" #endif diff --git a/doc/driver-model/i2c-howto.rst b/doc/driver-model/i2c-howto.rst index 938b707d3d..27e7440cd4 100644 --- a/doc/driver-model/i2c-howto.rst +++ b/doc/driver-model/i2c-howto.rst @@ -25,7 +25,7 @@ forward to convert these, at some point there may come a patch to remove them! Here is a suggested approach for converting your I2C driver over to driver model. Please feel free to update this file with your ideas and suggestions.
-- #ifdef out all your own I2C driver code (#ifndef CONFIG_DM_I2C) +- #ifdef out all your own I2C driver code (#if !CONFIG_IS_ENABLED(DM_I2C)) - Define CONFIG_DM_I2C for your board, vendor or architecture - If the board does not already use driver model, you need CONFIG_DM also - Your board should then build, but will not work fully since there will be diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index c02badd4a8..8e147160b9 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -86,7 +86,7 @@ u8 spd_i2c_addr[CONFIG_SYS_NUM_DDR_CTLRS][CONFIG_DIMM_SLOTS_PER_CTLR] = {
#endif
-#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) #define DEV_TYPE struct udevice #else /* Local udevice */ @@ -106,7 +106,7 @@ static int ddr_i2c_read(DEV_TYPE *dev, unsigned int addr, { int ret;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_read(dev, 0, buf, len); #else ret = i2c_read(dev->chip, addr, alen, buf, len); @@ -120,7 +120,7 @@ static int ddr_i2c_dummy_write(unsigned int chip_addr) { uint8_t buf = 0;
@@ -146,7 +146,7 @@ static void __get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) int ret; DEV_TYPE *dev;
-#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_chip_for_busnum(CONFIG_SYS_SPD_BUS_NUM, i2c_address, 1, &dev); if (ret) { diff --git a/drivers/i2c/davinci_i2c.c b/drivers/i2c/davinci_i2c.c index 7811abad80..a4abd25c39 100644 --- a/drivers/i2c/davinci_i2c.c +++ b/drivers/i2c/davinci_i2c.c @@ -21,7 +21,7 @@ #include <linux/delay.h> #include "davinci_i2c.h"
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) /* Information about i2c controller */ struct i2c_bus { int id; @@ -340,7 +340,7 @@ static int _davinci_i2c_probe_chip(struct i2c_regs *i2c_base, uint8_t chip) return rc; }
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) static struct i2c_regs *davinci_get_base(struct i2c_adapter *adap) { switch (adap->hwadapnr) { diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index 60111b8419..072803691e 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -598,7 +598,7 @@ static int __dw_i2c_init(struct i2c_regs *i2c_base, int speed, int slaveaddr) writel(IC_RX_TL, &i2c_base->ic_rx_tl); writel(IC_TX_TL, &i2c_base->ic_tx_tl); writel(IC_STOP_DET, &i2c_base->ic_intr_mask); -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) _dw_i2c_set_bus_speed(NULL, i2c_base, speed, IC_CLK); writel(slaveaddr, &i2c_base->ic_sar); #endif @@ -611,7 +611,7 @@ static int __dw_i2c_init(struct i2c_regs *i2c_base, int speed, int slaveaddr) return 0; }
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) /* * The legacy I2C functions. These need to get removed once * all users of this driver are converted to DM. diff --git a/drivers/i2c/fsl_i2c.c b/drivers/i2c/fsl_i2c.c index 875d30762e..4fe9fa57f4 100644 --- a/drivers/i2c/fsl_i2c.c +++ b/drivers/i2c/fsl_i2c.c @@ -39,7 +39,7 @@
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) static const struct fsl_i2c_base *i2c_base[4] = { (struct fsl_i2c_base *)(CONFIG_SYS_IMMR + CONFIG_SYS_FSL_I2C_OFFSET), #ifdef CONFIG_SYS_FSL_I2C2_OFFSET @@ -202,7 +202,7 @@ static uint set_i2c_bus_speed(const struct fsl_i2c_base *base, return speed; }
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) static uint get_i2c_clock(int bus) { if (bus) @@ -496,7 +496,7 @@ static uint __i2c_set_bus_speed(const struct fsl_i2c_base *base, return 0; }
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) static void fsl_i2c_init(struct i2c_adapter *adap, int speed, int slaveadd) { __i2c_init(i2c_base[adap->hwadapnr], speed, slaveadd, diff --git a/drivers/i2c/ihs_i2c.c b/drivers/i2c/ihs_i2c.c index f91a96a3aa..d1b7f56a79 100644 --- a/drivers/i2c/ihs_i2c.c +++ b/drivers/i2c/ihs_i2c.c @@ -6,7 +6,7 @@
#include <common.h> #include <i2c.h> -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) #include <dm.h> #include <regmap.h> #else @@ -17,7 +17,7 @@ #include <linux/bitops.h> #include <linux/delay.h>
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct ihs_i2c_priv { uint speed; struct regmap *map; @@ -90,7 +90,7 @@ enum { I2COP_READ = 1, };
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) static int wait_for_int(struct udevice *dev, int read) #else static int wait_for_int(bool read) @@ -98,11 +98,11 @@ static int wait_for_int(bool read) { u16 val; uint ctr = 0; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct ihs_i2c_priv *priv = dev_get_priv(dev); #endif
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ihs_i2c_get(priv->map, interrupt_status, &val); #else I2C_GET_REG(interrupt_status, &val); @@ -115,7 +115,7 @@ static int wait_for_int(bool read) debug("%s: timed out\n", __func__); return -ETIMEDOUT; } -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ihs_i2c_get(priv->map, interrupt_status, &val); #else I2C_GET_REG(interrupt_status, &val); @@ -125,7 +125,7 @@ static int wait_for_int(bool read) return (val & I2CINT_ERROR_EV) ? -EIO : 0; }
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) static int ihs_i2c_transfer(struct udevice *dev, uchar chip, uchar *buffer, int len, int read, bool is_last) #else @@ -136,13 +136,13 @@ static int ihs_i2c_transfer(uchar chip, uchar *buffer, int len, bool read, u16 val; u16 data; int res; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct ihs_i2c_priv *priv = dev_get_priv(dev); #endif
/* Clear interrupt status */ data = I2CINT_ERROR_EV | I2CINT_RECEIVE_EV | I2CINT_TRANSMIT_EV; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ihs_i2c_set(priv->map, interrupt_status, data); ihs_i2c_get(priv->map, interrupt_status, &val); #else @@ -156,7 +156,7 @@ static int ihs_i2c_transfer(uchar chip, uchar *buffer, int len, bool read,
if (len > 1) val |= buffer[1] << 8; -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ihs_i2c_set(priv->map, write_mailbox_ext, val); #else I2C_SET_REG(write_mailbox_ext, val); @@ -169,13 +169,13 @@ static int ihs_i2c_transfer(uchar chip, uchar *buffer, int len, bool read, | ((len > 1) ? I2CMB_2BYTE : 0) | (is_last ? 0 : I2CMB_HOLD_BUS);
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ihs_i2c_set(priv->map, write_mailbox, data); #else I2C_SET_REG(write_mailbox, data); #endif
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) res = wait_for_int(dev, read); #else res = wait_for_int(read); @@ -189,7 +189,7 @@ static int ihs_i2c_transfer(uchar chip, uchar *buffer, int len, bool read,
/* If we want to read, get the bytes from the mailbox */ if (read) { -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ihs_i2c_get(priv->map, read_mailbox_ext, &val); #else I2C_GET_REG(read_mailbox_ext, &val); @@ -202,7 +202,7 @@ static int ihs_i2c_transfer(uchar chip, uchar *buffer, int len, bool read, return 0; }
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) static int ihs_i2c_send_buffer(struct udevice *dev, uchar chip, u8 *data, int len, bool hold_bus, int read) #else static int ihs_i2c_send_buffer(uchar chip, u8 *data, int len, bool hold_bus, @@ -215,7 +215,7 @@ static int ihs_i2c_send_buffer(uchar chip, u8 *data, int len, bool hold_bus, int transfer = min(len, 2); bool is_last = len <= transfer;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) res = ihs_i2c_transfer(dev, chip, data, transfer, read, hold_bus ? false : is_last); #else @@ -232,21 +232,21 @@ static int ihs_i2c_send_buffer(uchar chip, u8 *data, int len, bool hold_bus, return 0; }
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) static int ihs_i2c_address(struct udevice *dev, uchar chip, u8 *addr, int alen, bool hold_bus) #else static int ihs_i2c_address(uchar chip, u8 *addr, int alen, bool hold_bus) #endif { -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) return ihs_i2c_send_buffer(dev, chip, addr, alen, hold_bus, I2COP_WRITE); #else return ihs_i2c_send_buffer(chip, addr, alen, hold_bus, I2COP_WRITE); #endif }
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) static int ihs_i2c_access(struct udevice *dev, uchar chip, u8 *addr, int alen, uchar *buffer, int len, int read) #else @@ -260,7 +260,7 @@ static int ihs_i2c_access(struct i2c_adapter *adap, uchar chip, u8 *addr, if (len <= 0) return -EINVAL;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) res = ihs_i2c_address(dev, chip, addr, alen, len); #else res = ihs_i2c_address(chip, addr, alen, len); @@ -268,14 +268,14 @@ static int ihs_i2c_access(struct i2c_adapter *adap, uchar chip, u8 *addr, if (res) return res;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) return ihs_i2c_send_buffer(dev, chip, buffer, len, false, read); #else return ihs_i2c_send_buffer(chip, buffer, len, false, read); #endif }
int ihs_i2c_probe(struct udevice *bus) { diff --git a/drivers/i2c/lpc32xx_i2c.c b/drivers/i2c/lpc32xx_i2c.c index ad11e978cc..f89f7955e4 100644 --- a/drivers/i2c/lpc32xx_i2c.c +++ b/drivers/i2c/lpc32xx_i2c.c @@ -42,7 +42,7 @@ #define LPC32XX_I2C_STAT_NAI 0x00000004 #define LPC32XX_I2C_STAT_TDI 0x00000001
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) static struct lpc32xx_i2c_base *lpc32xx_i2c[] = { (struct lpc32xx_i2c_base *)I2C1_BASE, (struct lpc32xx_i2c_base *)I2C2_BASE, @@ -224,7 +224,7 @@ static int __i2c_write(struct lpc32xx_i2c_base *base, u8 dev, uint addr, return 0; }
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) static void lpc32xx_i2c_init(struct i2c_adapter *adap, int requested_speed, int slaveadd) { diff --git a/drivers/i2c/mv_i2c.c b/drivers/i2c/mv_i2c.c index ef1007de14..20c5de0007 100644 --- a/drivers/i2c/mv_i2c.c +++ b/drivers/i2c/mv_i2c.c @@ -370,7 +370,7 @@ static int __i2c_write(struct mv_i2c *base, uchar chip, u8 *addr, int alen, return 0; }
static struct mv_i2c *base_glob;
diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index 37b1a06ee0..1e7b0a160e 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -15,7 +15,7 @@ #include <asm/io.h> #include <linux/bitops.h> #include <linux/compat.h> -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) #include <dm.h> #endif
@@ -26,7 +26,7 @@ DECLARE_GLOBAL_DATA_PTR; * settings */
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #if defined(CONFIG_ARCH_ORION5X) #include <asm/arch/orion5x.h> #elif (defined(CONFIG_ARCH_KIRKWOOD) || defined(CONFIG_ARCH_MVEBU)) @@ -42,7 +42,7 @@ DECLARE_GLOBAL_DATA_PTR; * On SUNXI, we get CONFIG_SYS_TCLK from this include, so we want to * always have it. */ -#if defined(CONFIG_DM_I2C) && defined(CONFIG_ARCH_SUNXI) +#if CONFIG_IS_ENABLED(DM_I2C) && defined(CONFIG_ARCH_SUNXI) #include <asm/arch/i2c.h> #endif
@@ -82,7 +82,7 @@ struct mvtwsi_registers {
#endif
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct mvtwsi_i2c_dev { /* TWSI Register base for the device */ struct mvtwsi_registers *base; @@ -183,7 +183,7 @@ inline uint calc_tick(uint speed) return (1000000000u / speed) + 100; }
/* * twsi_get_base() - Get controller register base for specified adapter @@ -480,7 +480,7 @@ static uint __twsi_i2c_set_bus_speed(struct mvtwsi_registers *twsi, writel(baud, &twsi->baudrate);
/* Wait for controller for one tick */ -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ndelay(calc_tick(highest_speed)); #else ndelay(10000); @@ -515,7 +515,7 @@ static void __twsi_i2c_init(struct mvtwsi_registers *twsi, int speed, writel(slaveadd, &twsi->slave_address); writel(0, &twsi->xtnd_slave_addr); /* Assert STOP, but don't care for the result */ -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) (void) twsi_stop(twsi, calc_tick(*actual_speed)); #else (void) twsi_stop(twsi, 10000); @@ -682,7 +682,7 @@ static int __twsi_i2c_write(struct mvtwsi_registers *twsi, uchar chip, return status != 0 ? status : stop_status; }
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) static void twsi_i2c_init(struct i2c_adapter *adap, int speed, int slaveadd) { diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 0362ec6763..f5606ed4e3 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -393,7 +393,7 @@ static struct mxc_i2c_bus mxc_i2c_buses[] = { #endif };
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) int i2c_idle_bus(struct mxc_i2c_bus *i2c_bus) { if (i2c_bus && i2c_bus->idle_bus_fn) @@ -645,7 +645,7 @@ int __enable_i2c_clk(unsigned char enable, unsigned int i2c_num) int enable_i2c_clk(unsigned char enable, unsigned int i2c_num) __attribute__((weak, alias("__enable_i2c_clk")));
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) /* * Read data from I2C device * diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 1355dc274e..71f6f5f7ac 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -836,7 +836,7 @@ wr_exit: return i2c_error; }
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) /* * The legacy I2C functions. These need to get removed once * all users of this driver are converted to DM. diff --git a/drivers/power/palmas.c b/drivers/power/palmas.c index 2584bea38d..bf9173949c 100644 --- a/drivers/power/palmas.c +++ b/drivers/power/palmas.c @@ -176,7 +176,7 @@ int twl603x_enable_bb_charge(u8 bb_fields) return err; }
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) int palmas_i2c_write_u8(u8 chip_no, u8 reg, u8 val) { struct udevice *dev; diff --git a/drivers/power/pmic/pmic_tps62362.c b/drivers/power/pmic/pmic_tps62362.c index c3977fccc3..76fd14db59 100644 --- a/drivers/power/pmic/pmic_tps62362.c +++ b/drivers/power/pmic/pmic_tps62362.c @@ -10,7 +10,7 @@ #include <power/pmic.h> #include <power/tps62362.h>
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *tps62362_dev __attribute__((section(".data"))) = NULL; #endif
@@ -26,7 +26,7 @@ int tps62362_voltage_update(unsigned char reg, unsigned char volt_sel) if (reg > TPS62362_NUM_REGS) return 1;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) return i2c_write(TPS62362_I2C_ADDR, reg, 1, &volt_sel, 1); #else if (!tps62362_dev) @@ -35,7 +35,7 @@ int tps62362_voltage_update(unsigned char reg, unsigned char volt_sel) #endif }
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) int power_tps62362_init(unsigned char bus) { static const char name[] = "TPS62362"; diff --git a/drivers/power/pmic/pmic_tps65217.c b/drivers/power/pmic/pmic_tps65217.c index c839e31890..54b5bed99a 100644 --- a/drivers/power/pmic/pmic_tps65217.c +++ b/drivers/power/pmic/pmic_tps65217.c @@ -18,7 +18,7 @@ struct udevice *tps65217_dev __attribute__((section(".data"))) = NULL; */ int tps65217_reg_read(uchar src_reg, uchar *src_val) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) return i2c_read(TPS65217_CHIP_PM, src_reg, 1, src_val, 1); #else return dm_i2c_read(tps65217_dev, src_reg, src_val, 1); @@ -52,7 +52,7 @@ int tps65217_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val, * mask */ if (mask != TPS65217_MASK_ALL_BITS) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_read(TPS65217_CHIP_PM, dest_reg, 1, &read_val, 1); #else ret = dm_i2c_read(tps65217_dev, dest_reg, &read_val, 1); @@ -67,7 +67,7 @@ int tps65217_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val,
if (prot_level > 0) { xor_reg = dest_reg ^ TPS65217_PASSWORD_UNLOCK; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(TPS65217_CHIP_PM, TPS65217_PASSWORD, 1, &xor_reg, 1); #else @@ -77,7 +77,7 @@ int tps65217_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val, if (ret) return ret; } -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(TPS65217_CHIP_PM, dest_reg, 1, &dest_val, 1); #else ret = dm_i2c_write(tps65217_dev, dest_reg, &dest_val, 1); @@ -86,7 +86,7 @@ int tps65217_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val, return ret;
if (prot_level == TPS65217_PROT_LEVEL_2) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(TPS65217_CHIP_PM, TPS65217_PASSWORD, 1, &xor_reg, 1); #else @@ -96,7 +96,7 @@ int tps65217_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val, if (ret) return ret;
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) ret = i2c_write(TPS65217_CHIP_PM, dest_reg, 1, &dest_val, 1); #else ret = dm_i2c_write(tps65217_dev, dest_reg, &dest_val, 1); @@ -137,7 +137,7 @@ int tps65217_voltage_update(uchar dc_cntrl_reg, uchar volt_sel)
int power_tps65217_init(unsigned char bus) { -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev = NULL; int rc;
diff --git a/drivers/power/pmic/pmic_tps65218.c b/drivers/power/pmic/pmic_tps65218.c index 7c95e5e758..f8bae4545c 100644 --- a/drivers/power/pmic/pmic_tps65218.c +++ b/drivers/power/pmic/pmic_tps65218.c @@ -10,7 +10,7 @@ #include <power/pmic.h> #include <power/tps65218.h>
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) int tps65218_reg_read(uchar dest_reg, uchar *dest_val) { uchar read_val; @@ -225,7 +225,7 @@ int tps65218_lock_fseal(void) return 0; }
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) int power_tps65218_init(unsigned char bus) { static const char name[] = "TPS65218_PMIC"; diff --git a/drivers/power/pmic/pmic_tps65910.c b/drivers/power/pmic/pmic_tps65910.c index 4772de11be..84a58c28d8 100644 --- a/drivers/power/pmic/pmic_tps65910.c +++ b/drivers/power/pmic/pmic_tps65910.c @@ -12,7 +12,7 @@ struct udevice *tps65910_dev __attribute__((section(".data"))) = NULL;
static inline int tps65910_read_reg(int addr, uchar *buf) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) return i2c_read(TPS65910_CTRL_I2C_ADDR, addr, 1, buf, 1); #else int rc; @@ -27,7 +27,7 @@ static inline int tps65910_read_reg(int addr, uchar *buf)
static inline int tps65910_write_reg(int addr, uchar *buf) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) return i2c_write(TPS65910_CTRL_I2C_ADDR, addr, 1, buf, 1); #else return dm_i2c_reg_write(tps65910_dev, addr, *buf); @@ -36,7 +36,7 @@ static inline int tps65910_write_reg(int addr, uchar *buf)
int power_tps65910_init(unsigned char bus) { -#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev = NULL; int rc;
diff --git a/drivers/power/twl4030.c b/drivers/power/twl4030.c index f48af84e17..d3e8949af9 100644 --- a/drivers/power/twl4030.c +++ b/drivers/power/twl4030.c @@ -182,7 +182,7 @@ int do_poweroff(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) } #endif
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) int twl4030_i2c_write_u8(u8 chip_no, u8 reg, u8 val) { struct udevice *dev; diff --git a/drivers/power/twl6030.c b/drivers/power/twl6030.c index 60a5aaaf19..2b50a56faf 100644 --- a/drivers/power/twl6030.c +++ b/drivers/power/twl6030.c @@ -270,7 +270,7 @@ void twl6030_usb_device_settings() twl6030_i2c_write_u8(TWL6030_CHIP_PM, TWL6030_MISC2, value); }
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) int twl6030_i2c_write_u8(u8 chip_no, u8 reg, u8 val) { struct udevice *dev; diff --git a/drivers/tpm/tpm_atmel_twi.c b/drivers/tpm/tpm_atmel_twi.c index d9e4877c5c..2dcc2af67f 100644 --- a/drivers/tpm/tpm_atmel_twi.c +++ b/drivers/tpm/tpm_atmel_twi.c @@ -81,7 +81,7 @@ static int tpm_atmel_twi_xfer(struct udevice *dev, print_buffer(0, (void *)sendbuf, 1, send_size, 0); #endif
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) res = i2c_write(0x29, 0, 0, (uchar *)sendbuf, send_size); #else res = dm_i2c_write(dev, 0, sendbuf, send_size); @@ -92,7 +92,7 @@ static int tpm_atmel_twi_xfer(struct udevice *dev, }
start = get_timer(0); -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) while ((res = i2c_read(0x29, 0, 0, recvbuf, 10))) #else while ((res = dm_i2c_read(dev, 0, recvbuf, 10))) @@ -116,7 +116,7 @@ static int tpm_atmel_twi_xfer(struct udevice *dev, return -1; } else { *recv_len = hdr_recv_len; -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) res = i2c_read(0x29, 0, 0, recvbuf, *recv_len); #else res = dm_i2c_read(dev, 0, recvbuf, *recv_len); diff --git a/drivers/usb/host/ohci-lpc32xx.c b/drivers/usb/host/ohci-lpc32xx.c index afb9e29f78..3be0b311a3 100644 --- a/drivers/usb/host/ohci-lpc32xx.c +++ b/drivers/usb/host/ohci-lpc32xx.c @@ -86,7 +86,7 @@ static struct clk_pm_regs *clk_pwr = (struct clk_pm_regs *)CLK_PM_BASE;
static int isp1301_set_value(struct udevice *dev, int reg, u8 value) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) return i2c_write(ISP1301_I2C_ADDR, reg, 1, &value, 1); #else return dm_i2c_write(dev, reg, &value, 1); @@ -95,7 +95,7 @@ static int isp1301_set_value(struct udevice *dev, int reg, u8 value)
static void isp1301_configure(struct udevice *dev) { -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) i2c_set_bus_num(I2C_2); #endif
@@ -160,7 +160,7 @@ int usb_cpu_init(void) u32 ret; struct udevice *dev = NULL;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_chip_for_busnum(I2C_2, ISP1301_I2C_ADDR, 1, &dev); if (ret) { debug("%s: No bus %d\n", __func__, I2C_2); @@ -216,7 +216,7 @@ int usb_cpu_stop(void) struct udevice *dev = NULL; int ret = 0;
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) ret = i2c_get_chip_for_busnum(I2C_2, ISP1301_I2C_ADDR, 1, &dev); if (ret) { debug("%s: No bus %d\n", __func__, I2C_2); diff --git a/include/_exports.h b/include/_exports.h index aeb666c847..8030d70c0b 100644 --- a/include/_exports.h +++ b/include/_exports.h @@ -40,7 +40,7 @@ EXPORT_FUNC(simple_strtol, long, simple_strtol, const char *, char **, unsigned int) EXPORT_FUNC(strcmp, int, strcmp, const char *cs, const char *ct) -#if defined(CONFIG_CMD_I2C) && !defined(CONFIG_DM_I2C) +#if defined(CONFIG_CMD_I2C) && !CONFIG_IS_ENABLED(DM_I2C) EXPORT_FUNC(i2c_write, int, i2c_write, uchar, uint, int , uchar * , int) EXPORT_FUNC(i2c_read, int, i2c_read, uchar, uint, int , uchar * , int) #else diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index c18f19a550..a318926fe8 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -46,7 +46,7 @@ #define CONFIG_SYS_MAXARGS 16 #endif
-#ifdef CONFIG_DM_I2C +#if CONFIG_IS_ENABLED(DM_I2C) # ifdef CONFIG_SYS_I2C # error "Cannot define CONFIG_SYS_I2C when CONFIG_DM_I2C is used" # endif diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 4efc182ef8..0605f70ffc 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -296,7 +296,7 @@ extern unsigned long get_clock_freq(void); /* * I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_FSL_I2C_SPEED 400000 #define CONFIG_SYS_FSL_I2C_SLAVE 0x7F diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 806d154328..1b68fd1072 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -525,7 +525,7 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_FSL_I2C_SPEED 400000 #define CONFIG_SYS_FSL_I2C_SLAVE 0x7F diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 65d3dfa0f0..3895c2d0c7 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -259,7 +259,7 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_FSL_I2C_SPEED 400000 #define CONFIG_SYS_FSL_I2C_SLAVE 0x7F diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 201da871bd..35b11ad88a 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -422,7 +422,7 @@ unsigned long get_board_ddr_clk(void); #endif
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_FSL_I2C_SPEED 50000 /* I2C speed in Hz */ #define CONFIG_SYS_FSL_I2C_SLAVE 0x7F diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index cf0f982375..ea239f74c1 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -452,7 +452,7 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #endif
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed in Hz */ #define CONFIG_SYS_FSL_I2C2_SPEED 400000 diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 1735b170fd..f0ef365a85 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -377,7 +377,7 @@ unsigned long get_board_ddr_clk(void); /* * I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_FSL_I2C_SLAVE 0x7F #define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 30e38444c0..e467ef453d 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -322,7 +322,7 @@ unsigned long get_board_ddr_clk(void); /* * I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_FSL_I2C_SLAVE 0x7F #define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 7f831fb8bc..a04d9137b3 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -154,7 +154,7 @@ #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_FSL_I2C_SLAVE 0x7F #define CONFIG_SYS_FSL_I2C_OFFSET 0x118000 diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 8355b4abc0..6df6b49c80 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -26,7 +26,7 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2
/* Power */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_POWER #define CONFIG_POWER_I2C #endif diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 731f884f40..d0843c284e 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -269,7 +269,7 @@ #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_FSL_I2C_SPEED 400000 #define CONFIG_SYS_FSL_I2C_SLAVE 0x7F diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index f6b5d47c25..a908b0acb0 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -55,7 +55,7 @@ CONFIG_SYS_SCSI_MAX_LUN)
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #else #define CONFIG_I2C_SET_DEFAULT_BUS_NUM diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index cf4d60ad60..e2ae6e46c0 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -98,7 +98,7 @@ * I2C */
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #else #define CONFIG_I2C_SET_DEFAULT_BUS_NUM diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index b4c70333de..7f65845283 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -330,7 +330,7 @@ unsigned long get_board_ddr_clk(void); /* * I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #else #define CONFIG_I2C_SET_DEFAULT_BUS_NUM diff --git a/include/configs/ls1021atsn.h b/include/configs/ls1021atsn.h index 996c970ec8..f76d5a1bd7 100644 --- a/include/configs/ls1021atsn.h +++ b/include/configs/ls1021atsn.h @@ -104,7 +104,7 @@ #define CONFIG_SYS_NS16550_CLK get_serial_clock()
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #else #define CONFIG_I2C_SET_DEFAULT_BUS_NUM diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 068e744a61..d6783db2c2 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -208,7 +208,7 @@ /* * I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #else #define CONFIG_I2C_SET_DEFAULT_BUS_NUM diff --git a/include/configs/ls1028a_common.h b/include/configs/ls1028a_common.h index 1c4af7d176..31fcdae986 100644 --- a/include/configs/ls1028a_common.h +++ b/include/configs/ls1028a_common.h @@ -44,7 +44,7 @@ #endif
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #endif
diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 4e3e1a946b..29a3790c45 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -149,7 +149,7 @@ #endif
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ #define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 0c32fceec2..0c3978a922 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -133,7 +133,7 @@ #endif
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ #define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index b9a956b90b..d574e7e592 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -61,7 +61,7 @@ #endif
diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 1626e65056..0dcf844303 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -26,7 +26,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_DDR_CLK_FREQ 100000000 #else #define CONFIG_QIXIS_I2C_ACCESS -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C_EARLY_INIT #endif #define CONFIG_SYS_CLK_FREQ get_board_sys_clk() diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 1042555a8c..2ed6584073 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -74,7 +74,7 @@ #endif
diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 9e174afb92..b3fce1b7f7 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -16,7 +16,7 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FSL_QSPI #define CONFIG_QIXIS_I2C_ACCESS -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C_EARLY_INIT #endif #define CONFIG_SYS_I2C_IFDR_DIV 0x7e diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index ab4214c265..8626a1d5e6 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -13,7 +13,7 @@ #ifdef CONFIG_TARGET_LS2081ARDB #define CONFIG_QIXIS_I2C_ACCESS #endif -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C_EARLY_INIT #endif #endif diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index a9bf213d8b..066311a97e 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -463,7 +463,7 @@ #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
/* I2C */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_FSL_I2C_SPEED 400000 #define CONFIG_SYS_FSL_I2C_SLAVE 0x7F diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 000f386470..7bfabc9571 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -207,7 +207,7 @@ defined CONFIG_I2C2_ENABLE || defined CONFIG_I2C3_ENABLE || \ defined CONFIG_I2C4_ENABLE || defined CONFIG_R_I2C_ENABLE #define CONFIG_SYS_I2C_MVTWSI -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SPEED 400000 #define CONFIG_SYS_I2C_SLAVE 0x7f diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 0c9856a11a..f13e9e5264 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -87,7 +87,7 @@ #define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */
/* If DM_I2C, enable non-DM I2C support */ -#if !defined(CONFIG_DM_I2C) +#if !CONFIG_IS_ENABLED(DM_I2C) #define CONFIG_I2C #define CONFIG_SYS_I2C #endif diff --git a/include/exports.h b/include/exports.h index faf0f59244..f9e2e4359e 100644 --- a/include/exports.h +++ b/include/exports.h @@ -48,7 +48,7 @@ long simple_strtol(const char *cp, char **endp, unsigned int base); int strcmp(const char *cs, const char *ct); unsigned long ustrtoul(const char *cp, char **endp, unsigned int base); unsigned long long ustrtoull(const char *cp, char **endp, unsigned int base); -#if defined(CONFIG_CMD_I2C) && !defined(CONFIG_DM_I2C) +#if defined(CONFIG_CMD_I2C) && !CONFIG_IS_ENABLED(DM_I2C) int i2c_write (uchar, uint, int , uchar* , int); int i2c_read (uchar, uint, int , uchar* , int); #endif diff --git a/include/i2c.h b/include/i2c.h index e45e33f503..7ae0c42706 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -581,7 +581,7 @@ extern struct acpi_ops i2c_acpi_ops; */ int acpi_i2c_of_to_plat(struct udevice *dev);
/* * WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING diff --git a/include/palmas.h b/include/palmas.h index 20c7e489c1..e259a4d04b 100644 --- a/include/palmas.h +++ b/include/palmas.h @@ -117,7 +117,7 @@ #define BB_VSEL_VBAT (3 << 1) #define BB_CHRG_EN (1 << 0)
-#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) /* * Functions to read and write from TPS659038/TWL6035/TWL6037 * or other Palmas family of TI PMICs diff --git a/include/twl4030.h b/include/twl4030.h index ef05193996..0a6d85a7c1 100644 --- a/include/twl4030.h +++ b/include/twl4030.h @@ -648,7 +648,7 @@ * examples are TWL4030_PM_RECEIVER_VMMC1_DEV_GRP and * TWL4030_LED_LEDEN. */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) static inline int twl4030_i2c_write_u8(u8 chip_no, u8 reg, u8 val) { return i2c_write(chip_no, reg, 1, &val, 1); diff --git a/include/twl6030.h b/include/twl6030.h index 41f17de3ab..05d476f804 100644 --- a/include/twl6030.h +++ b/include/twl6030.h @@ -186,7 +186,7 @@ struct twl6030_data{ };
/* Functions to read and write from TWL6030 */ -#ifndef CONFIG_DM_I2C +#if !CONFIG_IS_ENABLED(DM_I2C) static inline int twl6030_i2c_write_u8(u8 chip_no, u8 reg, u8 val) { return i2c_write(chip_no, reg, 1, &val, 1);
On Tue, Feb 09, 2021 at 01:52:45PM +0200, Igor Opaniuk wrote:
Use CONFIG_IS_ENABLED() macro, which provides more convenient way to check $(SPL)DM_I2C/$(SPL)DM_I2C_GPIO configs for both SPL and U-Boot proper.
CONFIG_IS_ENABLED(DM_I2C) expands to:
- 1 if CONFIG_SPL_BUILD is undefined and CONFIG_DM_I2C is set to 'y',
- 1 if CONFIG_SPL_BUILD is defined and CONFIG_SPL_DM_I2C is set to 'y',
- 0 otherwise.
All occurences were replaced automatically using these bash cmds: $ find . -type f -exec sed -i 's/ifndef CONFIG_DM_I2C/if !CONFIG_IS_ENABLED(DM_I2C)/g' {} + $ find . -type f -exec sed -i 's/ifdef CONFIG_DM_I2C/if CONFIG_IS_ENABLED(DM_I2C)/g' {} + $ find . -type f -exec sed -i 's/defined(CONFIG_DM_I2C)/CONFIG_IS_ENABLED(DM_I2C)/g' {} + $ find . -type f -exec sed -i 's/ifndef CONFIG_DM_I2C_GPIO/if !CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} + $ find . -type f -exec sed -i 's/ifdef CONFIG_DM_I2C_GPIO/if CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} + $ find . -type f -exec sed -i 's/defined(CONFIG_DM_I2C_GPIO)/CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
Reviewed-by: Heiko Schocher hs@denx.de Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Igor Opaniuk igor.opaniuk@foundries.io
-----Original Message----- From: Igor Opaniuk igor.opaniuk@foundries.io Sent: Tuesday, February 9, 2021 5:23 PM To: u-boot@lists.denx.de Cc: ricardo@foundries.io; Michael Scott mike@foundries.io; jorge@foundries.io; sjg@chromium.org; trini@konsulko.com; Igor Opaniuk igor.opaniuk@foundries.io; Heiko Schocher hs@denx.de; Adam Ford aford173@gmail.com; Alison Wang alison.wang@nxp.com; Andre Przywara andre.przywara@arm.com; Ashish Kumar ashish.kumar@nxp.com; Ashok Reddy Soma ashok.reddy.soma@xilinx.com; Bhaskar Upadhaya bhaskar.upadhaya@nxp.com; Biwen Li biwen.li@nxp.com; Fabio Estevam festevam@gmail.com; Faiz Abbas faiz_abbas@ti.com; Feng Li feng.li_2@nxp.com; Frieder Schrempf frieder.schrempf@kontron.de; Hans de Goede hdegoede@redhat.com; Heinrich Schuchardt xypron.glpk@gmx.de; Holger Brunck <holger.brunck@hitachi- powergrids.com>; Z.q. Hou zhiqiang.hou@nxp.com; Jaehoon Chung jh80.chung@samsung.com; Jagan Teki jagan@amarulasolutions.com; Jernej Skrabec jernej.skrabec@siol.net; Jonas Smedegaard dr@jones.dk; Kuldeep Singh kuldeep.singh@nxp.com; Lokesh Vutla lokeshvutla@ti.com; Lukasz Majewski lukma@denx.de; Madalin Bucur (OSS) madalin.bucur@oss.nxp.com; Manish Tomar manish.tomar@nxp.com; Marek Szyprowski m.szyprowski@samsung.com; Marek Vasut marex@denx.de; Masahiro Yamada masahiroy@kernel.org; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; Michael Walle michael@walle.cc; Michal Simek michal.simek@xilinx.com; Mingkai Hu mingkai.hu@nxp.com; dl-uboot-imx uboot-imx@nxp.com; Neil Armstrong narmstrong@baylibre.com; Niel Fourie lusus@denx.de; Ovidiu Panait ovidiu.panait@windriver.com; Pali Rohár pali@kernel.org; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Pramod Kumar pramod.kumar_1@nxp.com; Priyanka Jain priyanka.jain@nxp.com; Priyanka Singh priyanka.singh@nxp.com; Qiang Zhao qiang.zhao@nxp.com; Rai Harninder harninder.rai@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Stefan Bosch stefan_b@posteo.net; Stefan Roese sr@denx.de; Stefano Babic sbabic@denx.de; Sudhanshu Gupta sudhanshu.gupta@nxp.com; Suman Anna s-anna@ti.com; Sumit Garg sumit.garg@nxp.com; Andy Tang andy.tang@nxp.com; Udit Agarwal udit.agarwal@nxp.com; Vitaly Andrianov vitalya@ti.com; Vladimir Oltean olteanv@gmail.com; Wasim Khan wasim.khan@nxp.com; Wolfgang Denk wd@denx.de Subject: [PATCH v3 3/3] dm: i2c: use CONFIG_IS_ENABLED macro for DM_I2C/DM_I2C_GPIO
- 0 otherwise.
Reviewed-by: Priyanka Jain priyanka.jain@nxp.com
Hello Igor,
- 0 otherwise.
(no changes since v2)
Changes in v2:
- Added R-b tags (Heiko and Simon)
.../include/asm/arch-fsl-layerscape/config.h | 2 +- arch/arm/include/asm/arch-lpc32xx/i2c.h | 2 +- arch/arm/include/asm/mach-imx/mxc_i2c.h | 2 +- arch/arm/include/asm/omap_i2c.h | 2 +- arch/arm/mach-imx/i2c-mxv7.c | 2 +- arch/arm/mach-keystone/ddr3_spd.c | 2 +- arch/arm/mach-kirkwood/include/mach/config.h | 2 +- arch/arm/mach-omap2/am33xx/board.c | 2 +- arch/arm/mach-omap2/am33xx/clk_synthesizer.c | 6 +- arch/arm/mach-omap2/boot-common.c | 2 +- arch/arm/mach-omap2/clocks-common.c | 2 +- arch/arm/mach-sunxi/board.c | 2 +- arch/powerpc/include/asm/fsl_i2c.h | 2 +- board/freescale/common/dcu_sii9022a.c | 2 +- board/freescale/common/diu_ch7301.c | 2 +- board/freescale/common/emc2305.c | 4 +- board/freescale/common/qixis.c | 4 +- board/freescale/common/sys_eeprom.c | 20 ++-- board/freescale/common/vid.c | 24 ++--- board/freescale/common/vsc3316_3308.c | 10 +- board/freescale/ls1012aqds/ls1012aqds.c | 2 +- board/freescale/ls1012ardb/eth.c | 2 +- board/freescale/ls1012ardb/ls1012ardb.c | 12 +-- board/freescale/ls1021aqds/dcu.c | 6 +- board/freescale/ls1021aqds/ls1021aqds.c | 2 +- board/freescale/ls1021atwr/ls1021atwr.c | 2 +- board/freescale/ls1028a/ls1028a.c | 2 +- board/freescale/ls1043aqds/ls1043aqds.c | 4 +- board/freescale/ls1046afrwy/ls1046afrwy.c | 2 +- board/freescale/ls1046aqds/ls1046aqds.c | 2 +- board/freescale/ls1088a/eth_ls1088aqds.c | 16 +-- board/freescale/ls1088a/ls1088a.c | 60 ++++++------ board/freescale/ls2080aqds/eth.c | 14 +-- board/freescale/ls2080aqds/ls2080aqds.c | 4 +- board/freescale/ls2080ardb/ls2080ardb.c | 2 +- board/freescale/lx2160a/lx2160a.c | 2 +- board/freescale/p1010rdb/p1010rdb.c | 8 +- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 2 +- board/freescale/t102xrdb/t102xrdb.c | 2 +- board/freescale/t208xqds/t208xqds.c | 2 +- board/friendlyarm/nanopi2/onewire.c | 6 +- board/keymile/common/ivm.c | 2 +- board/samsung/common/misc.c | 2 +- board/samsung/trats/trats.c | 10 +- board/samsung/trats2/trats2.c | 10 +- board/sunxi/board.c | 2 +- board/ti/am335x/board.c | 8 +- board/ti/am335x/mux.c | 2 +- board/ti/am43xx/board.c | 12 +-- board/ti/common/board_detect.c | 4 +- board/ti/ks2_evm/board_k2g.c | 2 +- board/wandboard/wandboard.c | 4 +- cmd/eeprom.c | 6 +- cmd/i2c.c | 98 +++++++++---------- doc/driver-model/i2c-howto.rst | 2 +- drivers/ddr/fsl/main.c | 8 +- drivers/i2c/davinci_i2c.c | 4 +- drivers/i2c/designware_i2c.c | 4 +- drivers/i2c/fsl_i2c.c | 6 +- drivers/i2c/ihs_i2c.c | 42 ++++---- drivers/i2c/lpc32xx_i2c.c | 4 +- drivers/i2c/mv_i2c.c | 2 +- drivers/i2c/mvtwsi.c | 16 +-- drivers/i2c/mxc_i2c.c | 4 +- drivers/i2c/omap24xx_i2c.c | 2 +- drivers/power/palmas.c | 2 +- drivers/power/pmic/pmic_tps62362.c | 6 +- drivers/power/pmic/pmic_tps65217.c | 14 +-- drivers/power/pmic/pmic_tps65218.c | 4 +- drivers/power/pmic/pmic_tps65910.c | 6 +- drivers/power/twl4030.c | 2 +- drivers/power/twl6030.c | 2 +- drivers/tpm/tpm_atmel_twi.c | 6 +- drivers/usb/host/ohci-lpc32xx.c | 8 +- include/_exports.h | 2 +- include/config_fallbacks.h | 2 +- include/configs/MPC8548CDS.h | 2 +- include/configs/P1010RDB.h | 2 +- include/configs/P2041RDB.h | 2 +- include/configs/T102xRDB.h | 2 +- include/configs/T104xRDB.h | 2 +- include/configs/T208xQDS.h | 2 +- include/configs/T208xRDB.h | 2 +- include/configs/T4240RDB.h | 2 +- include/configs/am43xx_evm.h | 2 +- include/configs/corenet_ds.h | 2 +- include/configs/ls1012a_common.h | 2 +- include/configs/ls1021aiot.h | 2 +- include/configs/ls1021aqds.h | 2 +- include/configs/ls1021atsn.h | 2 +- include/configs/ls1021atwr.h | 2 +- include/configs/ls1028a_common.h | 2 +- include/configs/ls1043a_common.h | 2 +- include/configs/ls1046a_common.h | 2 +- include/configs/ls1088a_common.h | 2 +- include/configs/ls1088aqds.h | 2 +- include/configs/ls2080a_common.h | 2 +- include/configs/ls2080aqds.h | 2 +- include/configs/ls2080ardb.h | 2 +- include/configs/p1_p2_rdb_pc.h | 2 +- include/configs/sunxi-common.h | 2 +- include/configs/ti_armv7_common.h | 2 +- include/exports.h | 2 +- include/i2c.h | 2 +- include/palmas.h | 2 +- include/twl4030.h | 2 +- include/twl6030.h | 2 +- 107 files changed, 311 insertions(+), 311 deletions(-)
Applied to u-boot-i2c.git master
Thanks!
bye, Heiko
Heiko Schocher
Igor Opaniuk
Priyanka Jain
