[PATCH] net: Use phys_addr_t for SMC net device addresses
Use same type as eth_device->iobase and support addresses greater than INT_MAX.
Signed-off-by: Peter Hoyes Peter.Hoyes@arm.com --- drivers/net/smc91111.c | 2 +- drivers/net/smc911x.c | 2 +- include/netdev.h | 4 ++-- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/net/smc91111.c b/drivers/net/smc91111.c index ec4e8e928c..61d7f3df69 100644 --- a/drivers/net/smc91111.c +++ b/drivers/net/smc91111.c @@ -1269,7 +1269,7 @@ static void print_packet( byte * buf, int length ) } #endif
-int smc91111_initialize(u8 dev_num, int base_addr) +int smc91111_initialize(u8 dev_num, phys_addr_t base_addr) { struct smc91111_priv *priv; struct eth_device *dev; diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c index 3afebee440..8f420261fa 100644 --- a/drivers/net/smc911x.c +++ b/drivers/net/smc911x.c @@ -478,7 +478,7 @@ static int smc911x_recv(struct eth_device *dev) return ret; }
-int smc911x_initialize(u8 dev_num, int base_addr) +int smc911x_initialize(u8 dev_num, phys_addr_t base_addr) { struct smc911x_priv *priv; int ret; diff --git a/include/netdev.h b/include/netdev.h index b960c42106..00a0993a83 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -70,8 +70,8 @@ int rtl8169_initialize(struct bd_info *bis); int scc_initialize(struct bd_info *bis); int sh_eth_initialize(struct bd_info *bis); int skge_initialize(struct bd_info *bis); -int smc91111_initialize(u8 dev_num, int base_addr); -int smc911x_initialize(u8 dev_num, int base_addr); +int smc91111_initialize(u8 dev_num, phys_addr_t base_addr); +int smc911x_initialize(u8 dev_num, phys_addr_t base_addr); int uec_standard_init(struct bd_info *bis); int uli526x_initialize(struct bd_info *bis); int armada100_fec_register(unsigned long base_addr);
-int smc911x_initialize(u8 dev_num, int base_addr) +int smc911x_initialize(u8 dev_num, phys_addr_t base_addr) { struct smc911x_priv *priv; int ret; diff --git a/include/netdev.h b/include/netdev.h index b960c42106..00a0993a83 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -70,8 +70,8 @@ int rtl8169_initialize(struct bd_info *bis); int scc_initialize(struct bd_info *bis); int sh_eth_initialize(struct bd_info *bis); int skge_initialize(struct bd_info *bis); -int smc91111_initialize(u8 dev_num, int base_addr); -int smc911x_initialize(u8 dev_num, int base_addr); +int smc91111_initialize(u8 dev_num, phys_addr_t base_addr); +int smc911x_initialize(u8 dev_num, phys_addr_t base_addr); int uec_standard_init(struct bd_info *bis); int uli526x_initialize(struct bd_info *bis); int armada100_fec_register(unsigned long base_addr); -- 2.25.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Indeed, a signed(!) int is really a poor choice for a base address.
Reviewed-by: Andre Przywara andre.przywara@arm.com
Cheers, Andre
Cheers, Andre
Applied to u-boot-net/network-master Thanks, Ramon.
Andre Przywara
Peter Hoyes
Ramon Fried
