[U-Boot] [PATCH v2 0/9] FPGA subsystem changes
Tom reported me one warning in spear board and I have run buildman for all boards which have xilinx_desc in board folder.
Below is the report for this patch series.
Thanks, Michal
[u-boot]$ ./tools/buildman/buildman -b xnext/fpga apf27 zynq spear astro balloon3 pmc440 gen860t mvsmr mt_ventoux -se Summary of 10 commits for 35 boards (4 threads, 1 job per thread) 01: Merge branch 'next' of git://git.denx.de/u-boot-sh m68k: + astro_mcf5373l +/mnt/disk/xnext/fpga/.bm-work/00/arch/m68k/cpu/mcf532x/cpu_init.c: In function 'cpu_init_f': +/mnt/disk/xnext/fpga/.bm-work/00/arch/m68k/cpu/mcf532x/cpu_init.c:211:10: warning: unused variable 'wdog' [-Wunused-variable] +/mnt/disk/xnext/fpga/.bm-work/00/arch/m68k/lib/bootm.c: In function 'do_bootm_linux': +/mnt/disk/xnext/fpga/.bm-work/00/arch/m68k/lib/bootm.c:53:8: warning: unused variable 'rd_len' [-Wunused-variable] +/mnt/disk/xnext/fpga/.bm-work/00/arch/m68k/lib/bootm.c:99:12: warning: 'initrd_start' may be used uninitialized in this function [-Wuninitialized] +/mnt/disk/xnext/fpga/.bm-work/00/arch/m68k/lib/bootm.c:99:12: warning: 'initrd_end' may be used uninitialized in this function [-Wuninitialized] +/mnt/disk/xnext/fpga/.bm-work/00/arch/m68k/lib/bootm.c:99:12: warning: 'cmd_start' may be used uninitialized in this function [-Wuninitialized] +/mnt/disk/xnext/fpga/.bm-work/00/arch/m68k/lib/bootm.c:99:12: warning: 'cmd_end' may be used uninitialized in this function [-Wuninitialized] +/mnt/disk/xnext/fpga/.bm-work/00/board/astro/mcf5373l/mcf5373l.c: In function 'initdram': +/mnt/disk/xnext/fpga/.bm-work/00/board/astro/mcf5373l/mcf5373l.c:83:5: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness [-Wpointer-sign] +/mnt/disk/xnext/fpga/.bm-work/00/include/common.h:470:6: note: expected 'long int *' but argument is of type 'long unsigned int *' +/mnt/disk/xnext/fpga/.bm-work/00/board/astro/mcf5373l/fpga.c:168:2: warning: initialization from incompatible pointer type [enabled by default] +/mnt/disk/xnext/fpga/.bm-work/00/board/astro/mcf5373l/fpga.c:168:2: warning: (near initialization for 'altera_fns.write') [enabled by default] +/mnt/disk/xnext/fpga/.bm-work/00/board/astro/mcf5373l/fpga.c: In function 'astro5373l_altera_load': +/mnt/disk/xnext/fpga/.bm-work/00/board/astro/mcf5373l/fpga.c:196:20: warning: assignment from incompatible pointer type [enabled by default] 02: fpga: spartan2: Avoid CamelCase 03: fpga: spartan3: Avoid CamelCase 04: fpga: virtex2: Avoid CamelCase 05: fpga: xilinx: Avoid CamelCase for in Xilinx_desc 06: fpga: xilinx: Fix the rest of CamelCases 07: fpga: xilinx: Simplify load/dump/info function handling 08: fpga: zynq: Remove sparse warnings 09: fpga: zynq: Use helper functions for zynq dma 10: fpga: zynq: Use helper function zynq_validate_bitstream
Changes in v2: - Fix compilation errors in Astro - Exchange fpga_op and name in xilinx_desc because spartan2/3, virtex2 are not using names. - Fix warning reported by Tom board/spear/x600/fpga.c:177:2: warning: initialization from incompatible pointer type [enabled by default] board/spear/x600/fpga.c:177:2: warning: (near initialization for ‘fpga[0].name’) [enabled by default] - Add fix for apf27 and astro
Michal Simek (7): fpga: spartan2: Avoid CamelCase fpga: spartan3: Avoid CamelCase fpga: virtex2: Avoid CamelCase fpga: xilinx: Avoid CamelCase for in Xilinx_desc fpga: xilinx: Fix the rest of CamelCases fpga: xilinx: Simplify load/dump/info function handling fpga: zynq: Remove sparse warnings
Siva Durga Prasad Paladugu (2): fpga: zynq: Use helper functions for zynq dma fpga: zynq: Use helper function zynq_validate_bitstream
board/armadeus/apf27/fpga.c | 7 +- board/astro/mcf5373l/fpga.c | 47 +++---- board/balloon3/balloon3.c | 4 +- board/esd/pmc440/fpga.c | 8 +- board/gen860t/fpga.c | 6 +- board/matrix_vision/mvsmr/fpga.c | 6 +- board/spear/x600/fpga.c | 4 +- board/teejet/mt_ventoux/mt_ventoux.c | 4 +- board/xilinx/zynq/board.c | 14 +-- drivers/fpga/spartan2.c | 46 ++++--- drivers/fpga/spartan3.c | 46 ++++--- drivers/fpga/virtex2.c | 40 +++--- drivers/fpga/xilinx.c | 179 +++------------------------ drivers/fpga/zynqpl.c | 234 +++++++++++++++++++++-------------- include/spartan2.h | 72 ++++++----- include/spartan3.h | 84 ++++++------- include/virtex2.h | 66 +++++----- include/xilinx.h | 65 +++++----- include/zynqpl.h | 16 ++- 19 files changed, 438 insertions(+), 510 deletions(-)
-- 1.8.2.3
No functional changes.
Changes in v2: None
board/esd/pmc440/fpga.c | 2 +- board/matrix_vision/mvsmr/fpga.c | 2 +- drivers/fpga/spartan2.c | 40 ++++++++++++++++++++-------------------- drivers/fpga/xilinx.c | 14 +++++++------- include/spartan2.h | 32 ++++++++++++++++---------------- include/xilinx.h | 2 +- 6 files changed, 46 insertions(+), 46 deletions(-)
diff --git a/board/esd/pmc440/fpga.c b/board/esd/pmc440/fpga.c index b7b62dd94dbb..cef205088270 100644 --- a/board/esd/pmc440/fpga.c +++ b/board/esd/pmc440/fpga.c @@ -47,7 +47,7 @@ Xilinx_Spartan3_Slave_Serial_fns pmc440_fpga_fns = { }; #endif
-Xilinx_Spartan2_Slave_Serial_fns ngcc_fpga_fns = { +xilinx_spartan2_slave_serial_fns ngcc_fpga_fns = { ngcc_fpga_pre_config_fn, ngcc_fpga_pgm_fn, ngcc_fpga_clk_fn, diff --git a/board/matrix_vision/mvsmr/fpga.c b/board/matrix_vision/mvsmr/fpga.c index 88035a9e9e39..639bc7c75b9d 100644 --- a/board/matrix_vision/mvsmr/fpga.c +++ b/board/matrix_vision/mvsmr/fpga.c @@ -27,7 +27,7 @@ Xilinx_Spartan3_Slave_Serial_fns fpga_fns = { };
Xilinx_desc spartan3 = { - Xilinx_Spartan2, + xilinx_spartan2, slave_serial, XILINX_XC3S200_SIZE, (void *) &fpga_fns, diff --git a/drivers/fpga/spartan2.c b/drivers/fpga/spartan2.c index 6eab1b51e556..bd317095c656 100644 --- a/drivers/fpga/spartan2.c +++ b/drivers/fpga/spartan2.c @@ -31,29 +31,29 @@ #define CONFIG_SYS_FPGA_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ #endif
-static int Spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int Spartan2_sp_info(Xilinx_desc *desc ); */ +static int spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan2_sp_info(Xilinx_desc *desc ); */
-static int Spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int Spartan2_ss_info(Xilinx_desc *desc ); */ +static int spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan2_ss_info(Xilinx_desc *desc ); */
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int Spartan2_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan2_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Load\n", __FUNCTION__); - ret_val = Spartan2_ss_load (desc, buf, bsize); + ret_val = spartan2_ss_load(desc, buf, bsize); break;
case slave_parallel: PRINTF ("%s: Launching Slave Parallel Load\n", __FUNCTION__); - ret_val = Spartan2_sp_load (desc, buf, bsize); + ret_val = spartan2_sp_load(desc, buf, bsize); break;
default: @@ -64,19 +64,19 @@ int Spartan2_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Dump\n", __FUNCTION__); - ret_val = Spartan2_ss_dump (desc, buf, bsize); + ret_val = spartan2_ss_dump(desc, buf, bsize); break;
case slave_parallel: PRINTF ("%s: Launching Slave Parallel Dump\n", __FUNCTION__); - ret_val = Spartan2_sp_dump (desc, buf, bsize); + ret_val = spartan2_sp_dump(desc, buf, bsize); break;
default: @@ -87,7 +87,7 @@ int Spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Spartan2_info( Xilinx_desc *desc ) +int spartan2_info(Xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -96,10 +96,10 @@ int Spartan2_info( Xilinx_desc *desc ) /* ------------------------------------------------------------------------- */ /* Spartan-II Slave Parallel Generic Implementation */
-static int Spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan2_Slave_Parallel_fns *fn = desc->iface_fns; + xilinx_spartan2_slave_parallel_fns *fn = desc->iface_fns;
PRINTF ("%s: start with interface functions @ 0x%p\n", __FUNCTION__, fn); @@ -248,10 +248,10 @@ static int Spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int Spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan2_Slave_Parallel_fns *fn = desc->iface_fns; + xilinx_spartan2_slave_parallel_fns *fn = desc->iface_fns;
if (fn) { unsigned char *data = (unsigned char *) buf; @@ -296,10 +296,10 @@ static int Spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize)
-static int Spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan2_Slave_Serial_fns *fn = desc->iface_fns; + xilinx_spartan2_slave_serial_fns *fn = desc->iface_fns; int i; unsigned char val;
@@ -439,7 +439,7 @@ static int Spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int Spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { /* Readback is only available through the Slave Parallel and */ /* boundary-scan interfaces. */ diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 2e0db535d474..47bbf3951406 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -149,11 +149,11 @@ int xilinx_load(Xilinx_desc *desc, const void *buf, size_t bsize) printf ("%s: Invalid device descriptor\n", __FUNCTION__); } else switch (desc->family) { - case Xilinx_Spartan2: + case xilinx_spartan2: #if defined(CONFIG_FPGA_SPARTAN2) PRINTF ("%s: Launching the Spartan-II Loader...\n", __FUNCTION__); - ret_val = Spartan2_load (desc, buf, bsize); + ret_val = spartan2_load(desc, buf, bsize); #else printf ("%s: No support for Spartan-II devices.\n", __FUNCTION__); @@ -206,11 +206,11 @@ int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize) printf ("%s: Invalid device descriptor\n", __FUNCTION__); } else switch (desc->family) { - case Xilinx_Spartan2: + case xilinx_spartan2: #if defined(CONFIG_FPGA_SPARTAN2) PRINTF ("%s: Launching the Spartan-II Reader...\n", __FUNCTION__); - ret_val = Spartan2_dump (desc, buf, bsize); + ret_val = spartan2_dump(desc, buf, bsize); #else printf ("%s: No support for Spartan-II devices.\n", __FUNCTION__); @@ -262,7 +262,7 @@ int xilinx_info (Xilinx_desc * desc) if (xilinx_validate (desc, (char *)__FUNCTION__)) { printf ("Family: \t"); switch (desc->family) { - case Xilinx_Spartan2: + case xilinx_spartan2: printf ("Spartan-II\n"); break; case Xilinx_Spartan3: @@ -316,9 +316,9 @@ int xilinx_info (Xilinx_desc * desc) if (desc->iface_fns) { printf ("Device Function Table @ 0x%p\n", desc->iface_fns); switch (desc->family) { - case Xilinx_Spartan2: + case xilinx_spartan2: #if defined(CONFIG_FPGA_SPARTAN2) - Spartan2_info (desc); + spartan2_info(desc); #else /* just in case */ printf ("%s: No support for Spartan-II devices.\n", diff --git a/include/spartan2.h b/include/spartan2.h index 087a27d3cc04..a9fc68acc890 100644 --- a/include/spartan2.h +++ b/include/spartan2.h @@ -10,9 +10,9 @@
#include <xilinx.h>
-extern int Spartan2_load(Xilinx_desc *desc, const void *image, size_t size); -extern int Spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -extern int Spartan2_info(Xilinx_desc *desc); +int spartan2_load(Xilinx_desc *desc, const void *image, size_t size); +int spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +int spartan2_info(Xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { @@ -29,7 +29,7 @@ typedef struct { Xilinx_busy_fn busy; Xilinx_abort_fn abort; Xilinx_post_fn post; -} Xilinx_Spartan2_Slave_Parallel_fns; +} xilinx_spartan2_slave_parallel_fns;
/* Slave Serial Implementation function table */ typedef struct { @@ -40,7 +40,7 @@ typedef struct { Xilinx_done_fn done; Xilinx_wr_fn wr; Xilinx_post_fn post; -} Xilinx_Spartan2_Slave_Serial_fns; +} xilinx_spartan2_slave_serial_fns;
/* Device Image Sizes *********************************************************************/ @@ -63,36 +63,36 @@ typedef struct { *********************************************************************/ /* Spartan-II devices */ #define XILINX_XC2S15_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S15_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S15_SIZE, fn_table, cookie }
#define XILINX_XC2S30_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S30_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S30_SIZE, fn_table, cookie }
#define XILINX_XC2S50_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S50_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S50_SIZE, fn_table, cookie }
#define XILINX_XC2S100_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S100_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S100_SIZE, fn_table, cookie }
#define XILINX_XC2S150_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S150_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S150_SIZE, fn_table, cookie }
#define XILINX_XC2S200_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S200_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S200_SIZE, fn_table, cookie }
#define XILINX_XC2S50E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S50E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S50E_SIZE, fn_table, cookie }
#define XILINX_XC2S100E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S100E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S100E_SIZE, fn_table, cookie }
#define XILINX_XC2S150E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S150E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S150E_SIZE, fn_table, cookie }
#define XILINX_XC2S200E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S200E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S200E_SIZE, fn_table, cookie }
#define XILINX_XC2S300E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S300E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S300E_SIZE, fn_table, cookie }
#endif /* _SPARTAN2_H_ */ diff --git a/include/xilinx.h b/include/xilinx.h index 00a585e5fc31..9d870b2d8481 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -26,7 +26,7 @@ typedef enum { /* typedef Xilinx_iface */
typedef enum { /* typedef Xilinx_Family */ min_xilinx_type, /* low range check value */ - Xilinx_Spartan2, /* Spartan-II Family */ + xilinx_spartan2, /* Spartan-II Family */ Xilinx_VirtexE, /* Virtex-E Family */ Xilinx_Virtex2, /* Virtex2 Family */ Xilinx_Spartan3, /* Spartan-III Family */ -- 1.8.2.3
Changes in v2: None
board/armadeus/apf27/fpga.c | 4 ++-- board/astro/mcf5373l/fpga.c | 4 ++-- board/balloon3/balloon3.c | 2 +- board/esd/pmc440/fpga.c | 4 ++-- board/matrix_vision/mvsmr/fpga.c | 2 +- board/spear/x600/fpga.c | 2 +- board/teejet/mt_ventoux/mt_ventoux.c | 2 +- drivers/fpga/spartan3.c | 40 ++++++++++++++++++------------------ drivers/fpga/xilinx.c | 14 ++++++------- include/spartan3.h | 38 +++++++++++++++++----------------- include/xilinx.h | 2 +- 11 files changed, 57 insertions(+), 57 deletions(-)
diff --git a/board/armadeus/apf27/fpga.c b/board/armadeus/apf27/fpga.c index 0c08c0640ef2..56fde200e794 100644 --- a/board/armadeus/apf27/fpga.c +++ b/board/armadeus/apf27/fpga.c @@ -26,7 +26,7 @@ * Spartan2 code is used to download our Spartan 3 :) code is compatible. * Just take care about the file size */ -Xilinx_Spartan3_Slave_Parallel_fns fpga_fns = { +xilinx_spartan3_slave_parallel_fns fpga_fns = { fpga_pre_fn, fpga_pgm_fn, fpga_init_fn, @@ -43,7 +43,7 @@ Xilinx_Spartan3_Slave_Parallel_fns fpga_fns = { };
Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { - {Xilinx_Spartan3, + {xilinx_spartan3, slave_parallel, 1196128l/8, (void *)&fpga_fns, diff --git a/board/astro/mcf5373l/fpga.c b/board/astro/mcf5373l/fpga.c index c679ad7f65c6..152ff1f58c97 100644 --- a/board/astro/mcf5373l/fpga.c +++ b/board/astro/mcf5373l/fpga.c @@ -363,7 +363,7 @@ int xilinx_fastwr_fn(void *buf, size_t len, int flush, int cookie) * relocated at runtime. * FIXME: relocation not yet working for coldfire, see below! */ -Xilinx_Spartan3_Slave_Serial_fns xilinx_fns = { +xilinx_spartan3_slave_serial_fns xilinx_fns = { xilinx_pre_config_fn, xilinx_pgm_fn, xilinx_clk_fn, @@ -375,7 +375,7 @@ Xilinx_Spartan3_Slave_Serial_fns xilinx_fns = { };
Xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { - {Xilinx_Spartan3, + {xilinx_spartan3, slave_serial, XILINX_XC3S4000_SIZE, (void *)&xilinx_fns, diff --git a/board/balloon3/balloon3.c b/board/balloon3/balloon3.c index 04e0574658ac..4aa66052da9c 100644 --- a/board/balloon3/balloon3.c +++ b/board/balloon3/balloon3.c @@ -191,7 +191,7 @@ int fpga_cs_fn(int assert_clk, int flush, int cookie) return assert_clk; }
-Xilinx_Spartan3_Slave_Parallel_fns balloon3_fpga_fns = { +xilinx_spartan3_slave_parallel_fns balloon3_fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_init_fn, diff --git a/board/esd/pmc440/fpga.c b/board/esd/pmc440/fpga.c index cef205088270..18a1b63088d6 100644 --- a/board/esd/pmc440/fpga.c +++ b/board/esd/pmc440/fpga.c @@ -20,7 +20,7 @@ DECLARE_GLOBAL_DATA_PTR; #define USE_SP_CODE
#ifdef USE_SP_CODE -Xilinx_Spartan3_Slave_Parallel_fns pmc440_fpga_fns = { +xilinx_spartan3_slave_parallel_fns pmc440_fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_init_fn, @@ -36,7 +36,7 @@ Xilinx_Spartan3_Slave_Parallel_fns pmc440_fpga_fns = { fpga_post_config_fn, }; #else -Xilinx_Spartan3_Slave_Serial_fns pmc440_fpga_fns = { +xilinx_spartan3_slave_serial_fns pmc440_fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_clk_fn, diff --git a/board/matrix_vision/mvsmr/fpga.c b/board/matrix_vision/mvsmr/fpga.c index 639bc7c75b9d..b20745524394 100644 --- a/board/matrix_vision/mvsmr/fpga.c +++ b/board/matrix_vision/mvsmr/fpga.c @@ -16,7 +16,7 @@ #include "fpga.h" #include "mvsmr.h"
-Xilinx_Spartan3_Slave_Serial_fns fpga_fns = { +xilinx_spartan3_slave_serial_fns fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_clk_fn, diff --git a/board/spear/x600/fpga.c b/board/spear/x600/fpga.c index c06c99477777..c26eba42845c 100644 --- a/board/spear/x600/fpga.c +++ b/board/spear/x600/fpga.c @@ -163,7 +163,7 @@ static int fpga_wr_fn(int assert_write, int flush, int cookie) return assert_write; }
-static Xilinx_Spartan3_Slave_Serial_fns x600_fpga_fns = { +static xilinx_spartan3_slave_serial_fns x600_fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_clk_fn, diff --git a/board/teejet/mt_ventoux/mt_ventoux.c b/board/teejet/mt_ventoux/mt_ventoux.c index c32d554ea429..a36176494e42 100644 --- a/board/teejet/mt_ventoux/mt_ventoux.c +++ b/board/teejet/mt_ventoux/mt_ventoux.c @@ -190,7 +190,7 @@ int fpga_clk_fn(int assert_clk, int flush, int cookie) return assert_clk; }
-Xilinx_Spartan3_Slave_Serial_fns mt_ventoux_fpga_fns = { +xilinx_spartan3_slave_serial_fns mt_ventoux_fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_clk_fn, diff --git a/drivers/fpga/spartan3.c b/drivers/fpga/spartan3.c index 3edc5c2c66a6..e40abbfb9460 100644 --- a/drivers/fpga/spartan3.c +++ b/drivers/fpga/spartan3.c @@ -35,29 +35,29 @@ #define CONFIG_SYS_FPGA_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ #endif
-static int Spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int Spartan3_sp_info(Xilinx_desc *desc ); */ +static int spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan3_sp_info(Xilinx_desc *desc ); */
-static int Spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int Spartan3_ss_info(Xilinx_desc *desc); */ +static int spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan3_ss_info(Xilinx_desc *desc); */
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int Spartan3_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan3_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Load\n", __FUNCTION__); - ret_val = Spartan3_ss_load (desc, buf, bsize); + ret_val = spartan3_ss_load(desc, buf, bsize); break;
case slave_parallel: PRINTF ("%s: Launching Slave Parallel Load\n", __FUNCTION__); - ret_val = Spartan3_sp_load (desc, buf, bsize); + ret_val = spartan3_sp_load(desc, buf, bsize); break;
default: @@ -68,19 +68,19 @@ int Spartan3_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Dump\n", __FUNCTION__); - ret_val = Spartan3_ss_dump (desc, buf, bsize); + ret_val = spartan3_ss_dump(desc, buf, bsize); break;
case slave_parallel: PRINTF ("%s: Launching Slave Parallel Dump\n", __FUNCTION__); - ret_val = Spartan3_sp_dump (desc, buf, bsize); + ret_val = spartan3_sp_dump(desc, buf, bsize); break;
default: @@ -91,7 +91,7 @@ int Spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Spartan3_info( Xilinx_desc *desc ) +int spartan3_info(Xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -100,10 +100,10 @@ int Spartan3_info( Xilinx_desc *desc ) /* ------------------------------------------------------------------------- */ /* Spartan-II Slave Parallel Generic Implementation */
-static int Spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan3_Slave_Parallel_fns *fn = desc->iface_fns; + xilinx_spartan3_slave_parallel_fns *fn = desc->iface_fns;
PRINTF ("%s: start with interface functions @ 0x%p\n", __FUNCTION__, fn); @@ -254,10 +254,10 @@ static int Spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int Spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan3_Slave_Parallel_fns *fn = desc->iface_fns; + xilinx_spartan3_slave_parallel_fns *fn = desc->iface_fns;
if (fn) { unsigned char *data = (unsigned char *) buf; @@ -302,10 +302,10 @@ static int Spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize)
-static int Spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan3_Slave_Serial_fns *fn = desc->iface_fns; + xilinx_spartan3_slave_serial_fns *fn = desc->iface_fns; int i; unsigned char val;
@@ -457,7 +457,7 @@ static int Spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int Spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { /* Readback is only available through the Slave Parallel and */ /* boundary-scan interfaces. */ diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 47bbf3951406..7d93d641f6aa 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -159,11 +159,11 @@ int xilinx_load(Xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); #endif break; - case Xilinx_Spartan3: + case xilinx_spartan3: #if defined(CONFIG_FPGA_SPARTAN3) PRINTF ("%s: Launching the Spartan-III Loader...\n", __FUNCTION__); - ret_val = Spartan3_load (desc, buf, bsize); + ret_val = spartan3_load(desc, buf, bsize); #else printf ("%s: No support for Spartan-III devices.\n", __FUNCTION__); @@ -216,11 +216,11 @@ int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); #endif break; - case Xilinx_Spartan3: + case xilinx_spartan3: #if defined(CONFIG_FPGA_SPARTAN3) PRINTF ("%s: Launching the Spartan-III Reader...\n", __FUNCTION__); - ret_val = Spartan3_dump (desc, buf, bsize); + ret_val = spartan3_dump(desc, buf, bsize); #else printf ("%s: No support for Spartan-III devices.\n", __FUNCTION__); @@ -265,7 +265,7 @@ int xilinx_info (Xilinx_desc * desc) case xilinx_spartan2: printf ("Spartan-II\n"); break; - case Xilinx_Spartan3: + case xilinx_spartan3: printf ("Spartan-III\n"); break; case Xilinx_Virtex2: @@ -325,9 +325,9 @@ int xilinx_info (Xilinx_desc * desc) __FUNCTION__); #endif break; - case Xilinx_Spartan3: + case xilinx_spartan3: #if defined(CONFIG_FPGA_SPARTAN3) - Spartan3_info (desc); + spartan3_info(desc); #else /* just in case */ printf ("%s: No support for Spartan-III devices.\n", diff --git a/include/spartan3.h b/include/spartan3.h index 72e7c0ddd002..93ca8a40bc34 100644 --- a/include/spartan3.h +++ b/include/spartan3.h @@ -10,9 +10,9 @@
#include <xilinx.h>
-extern int Spartan3_load(Xilinx_desc *desc, const void *image, size_t size); -extern int Spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -extern int Spartan3_info(Xilinx_desc *desc); +int spartan3_load(Xilinx_desc *desc, const void *image, size_t size); +int spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +int spartan3_info(Xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { @@ -29,7 +29,7 @@ typedef struct { Xilinx_busy_fn busy; Xilinx_abort_fn abort; Xilinx_post_fn post; -} Xilinx_Spartan3_Slave_Parallel_fns; +} xilinx_spartan3_slave_parallel_fns;
/* Slave Serial Implementation function table */ typedef struct { @@ -42,7 +42,7 @@ typedef struct { Xilinx_post_fn post; Xilinx_bwr_fn bwr; /* block write function */ Xilinx_abort_fn abort; -} Xilinx_Spartan3_Slave_Serial_fns; +} xilinx_spartan3_slave_serial_fns;
/* Device Image Sizes *********************************************************************/ @@ -73,46 +73,46 @@ typedef struct { *********************************************************************/ /* Spartan-III devices */ #define XILINX_XC3S50_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S50_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S50_SIZE, fn_table, cookie }
#define XILINX_XC3S200_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S200_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S200_SIZE, fn_table, cookie }
#define XILINX_XC3S400_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S400_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S400_SIZE, fn_table, cookie }
#define XILINX_XC3S1000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S1000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1000_SIZE, fn_table, cookie }
#define XILINX_XC3S1500_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S1500_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1500_SIZE, fn_table, cookie }
#define XILINX_XC3S2000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S2000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S2000_SIZE, fn_table, cookie }
#define XILINX_XC3S4000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S4000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S4000_SIZE, fn_table, cookie }
#define XILINX_XC3S5000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S5000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S5000_SIZE, fn_table, cookie }
/* Spartan-3E devices */ #define XILINX_XC3S100E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S100E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S100E_SIZE, fn_table, cookie }
#define XILINX_XC3S250E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S250E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S250E_SIZE, fn_table, cookie }
#define XILINX_XC3S500E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S500E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S500E_SIZE, fn_table, cookie }
#define XILINX_XC3S1200E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S1200E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1200E_SIZE, fn_table, cookie }
#define XILINX_XC3S1600E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S1600E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1600E_SIZE, fn_table, cookie }
#define XILINX_XC6SLX4_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINK_XC6SLX4_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINK_XC6SLX4_SIZE, fn_table, cookie }
#endif /* _SPARTAN3_H_ */ diff --git a/include/xilinx.h b/include/xilinx.h index 9d870b2d8481..365c0c358eb4 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -29,7 +29,7 @@ typedef enum { /* typedef Xilinx_Family */ xilinx_spartan2, /* Spartan-II Family */ Xilinx_VirtexE, /* Virtex-E Family */ Xilinx_Virtex2, /* Virtex2 Family */ - Xilinx_Spartan3, /* Spartan-III Family */ + xilinx_spartan3, /* Spartan-III Family */ xilinx_zynq, /* Zynq Family */ max_xilinx_type /* insert all new types before this */ } Xilinx_Family; /* end, typedef Xilinx_Family */ -- 1.8.2.3
Changes in v2: None
board/gen860t/fpga.c | 4 ++-- drivers/fpga/virtex2.c | 34 +++++++++++++++++----------------- drivers/fpga/xilinx.c | 14 +++++++------- include/virtex2.h | 34 +++++++++++++++++----------------- include/xilinx.h | 2 +- 5 files changed, 44 insertions(+), 44 deletions(-)
diff --git a/board/gen860t/fpga.c b/board/gen860t/fpga.c index b7984dd0fec1..48a4222ac410 100644 --- a/board/gen860t/fpga.c +++ b/board/gen860t/fpga.c @@ -40,7 +40,7 @@ DECLARE_GLOBAL_DATA_PTR; /* Note that these are pointers to code that is in Flash. They will be * relocated at runtime. */ -Xilinx_Virtex2_Slave_SelectMap_fns fpga_fns = { +xilinx_virtex2_slave_selectmap_fns fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_init_fn, @@ -57,7 +57,7 @@ Xilinx_Virtex2_Slave_SelectMap_fns fpga_fns = { };
Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { - {Xilinx_Virtex2, + {xilinx_virtex2, slave_selectmap, XILINX_XC2V3000_SIZE, (void *) &fpga_fns, diff --git a/drivers/fpga/virtex2.c b/drivers/fpga/virtex2.c index b5a895d41a73..1cd9046a2487 100644 --- a/drivers/fpga/virtex2.c +++ b/drivers/fpga/virtex2.c @@ -84,25 +84,25 @@ #define CONFIG_SYS_FPGA_WAIT_CONFIG CONFIG_SYS_HZ/5 /* 200 ms */ #endif
-static int Virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize);
-static int Virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize);
-int Virtex2_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int virtex2_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Load\n", __FUNCTION__); - ret_val = Virtex2_ss_load (desc, buf, bsize); + ret_val = virtex2_ss_load(desc, buf, bsize); break;
case slave_selectmap: PRINTF ("%s: Launching Slave Parallel Load\n", __FUNCTION__); - ret_val = Virtex2_ssm_load (desc, buf, bsize); + ret_val = virtex2_ssm_load(desc, buf, bsize); break;
default: @@ -112,19 +112,19 @@ int Virtex2_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Dump\n", __FUNCTION__); - ret_val = Virtex2_ss_dump (desc, buf, bsize); + ret_val = virtex2_ss_dump(desc, buf, bsize); break;
case slave_parallel: PRINTF ("%s: Launching Slave Parallel Dump\n", __FUNCTION__); - ret_val = Virtex2_ssm_dump (desc, buf, bsize); + ret_val = virtex2_ssm_dump(desc, buf, bsize); break;
default: @@ -134,7 +134,7 @@ int Virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Virtex2_info (Xilinx_desc * desc) +int virtex2_info(Xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -153,10 +153,10 @@ int Virtex2_info (Xilinx_desc * desc) * INIT_B and DONE lines. If both are high, configuration has * succeeded. Congratulations! */ -static int Virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; - Xilinx_Virtex2_Slave_SelectMap_fns *fn = desc->iface_fns; + xilinx_virtex2_slave_selectmap_fns *fn = desc->iface_fns;
PRINTF ("%s:%d: Start with interface functions @ 0x%p\n", __FUNCTION__, __LINE__, fn); @@ -352,10 +352,10 @@ static int Virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) /* * Read the FPGA configuration data */ -static int Virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; - Xilinx_Virtex2_Slave_SelectMap_fns *fn = desc->iface_fns; + xilinx_virtex2_slave_selectmap_fns *fn = desc->iface_fns;
if (fn) { unsigned char *data = (unsigned char *) buf; @@ -404,13 +404,13 @@ static int Virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int Virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) { printf ("%s: Slave Serial Loading is unsupported\n", __FUNCTION__); return FPGA_FAIL; }
-static int Virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { printf ("%s: Slave Serial Dumping is unsupported\n", __FUNCTION__); return FPGA_FAIL; diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 7d93d641f6aa..6953535f0823 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -169,11 +169,11 @@ int xilinx_load(Xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); #endif break; - case Xilinx_Virtex2: + case xilinx_virtex2: #if defined(CONFIG_FPGA_VIRTEX2) PRINTF ("%s: Launching the Virtex-II Loader...\n", __FUNCTION__); - ret_val = Virtex2_load (desc, buf, bsize); + ret_val = virtex2_load(desc, buf, bsize); #else printf ("%s: No support for Virtex-II devices.\n", __FUNCTION__); @@ -226,11 +226,11 @@ int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); #endif break; - case Xilinx_Virtex2: + case xilinx_virtex2: #if defined( CONFIG_FPGA_VIRTEX2) PRINTF ("%s: Launching the Virtex-II Reader...\n", __FUNCTION__); - ret_val = Virtex2_dump (desc, buf, bsize); + ret_val = virtex2_dump(desc, buf, bsize); #else printf ("%s: No support for Virtex-II devices.\n", __FUNCTION__); @@ -268,7 +268,7 @@ int xilinx_info (Xilinx_desc * desc) case xilinx_spartan3: printf ("Spartan-III\n"); break; - case Xilinx_Virtex2: + case xilinx_virtex2: printf ("Virtex-II\n"); break; case xilinx_zynq: @@ -334,9 +334,9 @@ int xilinx_info (Xilinx_desc * desc) __FUNCTION__); #endif break; - case Xilinx_Virtex2: + case xilinx_virtex2: #if defined(CONFIG_FPGA_VIRTEX2) - Virtex2_info (desc); + virtex2_info(desc); #else /* just in case */ printf ("%s: No support for Virtex-II devices.\n", diff --git a/include/virtex2.h b/include/virtex2.h index 2e9a4f52da3d..1e6624ca9627 100644 --- a/include/virtex2.h +++ b/include/virtex2.h @@ -11,9 +11,9 @@
#include <xilinx.h>
-extern int Virtex2_load(Xilinx_desc *desc, const void *image, size_t size); -extern int Virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -extern int Virtex2_info(Xilinx_desc *desc); +int virtex2_load(Xilinx_desc *desc, const void *image, size_t size); +int virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +int virtex2_info(Xilinx_desc *desc);
/* * Slave SelectMap Implementation function table. @@ -32,7 +32,7 @@ typedef struct { Xilinx_busy_fn busy; Xilinx_abort_fn abort; Xilinx_post_fn post; -} Xilinx_Virtex2_Slave_SelectMap_fns; +} xilinx_virtex2_slave_selectmap_fns;
/* Slave Serial Implementation function table */ typedef struct { @@ -40,7 +40,7 @@ typedef struct { Xilinx_clk_fn clk; Xilinx_rdata_fn rdata; Xilinx_wdata_fn wdata; -} Xilinx_Virtex2_Slave_Serial_fns; +} xilinx_virtex2_slave_serial_fns;
/* Device Image Sizes (in bytes) *********************************************************************/ @@ -60,39 +60,39 @@ typedef struct { /* Descriptor Macros *********************************************************************/ #define XILINX_XC2V40_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V40_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V40_SIZE, fn_table, cookie }
#define XILINX_XC2V80_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V80_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V80_SIZE, fn_table, cookie }
#define XILINX_XC2V250_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V250_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V250_SIZE, fn_table, cookie }
#define XILINX_XC2V500_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V500_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V500_SIZE, fn_table, cookie }
#define XILINX_XC2V1000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V1000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V1000_SIZE, fn_table, cookie }
#define XILINX_XC2V1500_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V1500_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V1500_SIZE, fn_table, cookie }
#define XILINX_XC2V2000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V2000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V2000_SIZE, fn_table, cookie }
#define XILINX_XC2V3000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V3000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V3000_SIZE, fn_table, cookie }
#define XILINX_XC2V4000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V4000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V4000_SIZE, fn_table, cookie }
#define XILINX_XC2V6000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V6000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V6000_SIZE, fn_table, cookie }
#define XILINX_XC2V8000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V8000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V8000_SIZE, fn_table, cookie }
#define XILINX_XC2V10000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V10000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V10000_SIZE, fn_table, cookie }
#endif /* _VIRTEX2_H_ */ diff --git a/include/xilinx.h b/include/xilinx.h index 365c0c358eb4..fa89fb68351b 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -28,7 +28,7 @@ typedef enum { /* typedef Xilinx_Family */ min_xilinx_type, /* low range check value */ xilinx_spartan2, /* Spartan-II Family */ Xilinx_VirtexE, /* Virtex-E Family */ - Xilinx_Virtex2, /* Virtex2 Family */ + xilinx_virtex2, /* Virtex2 Family */ xilinx_spartan3, /* Spartan-III Family */ xilinx_zynq, /* Zynq Family */ max_xilinx_type /* insert all new types before this */ -- 1.8.2.3
Changes in v2: None
board/armadeus/apf27/fpga.c | 2 +- board/astro/mcf5373l/fpga.c | 2 +- board/balloon3/balloon3.c | 2 +- board/esd/pmc440/fpga.c | 2 +- board/gen860t/fpga.c | 2 +- board/matrix_vision/mvsmr/fpga.c | 2 +- board/spear/x600/fpga.c | 2 +- board/teejet/mt_ventoux/mt_ventoux.c | 2 +- board/xilinx/zynq/board.c | 14 +++++++------- drivers/fpga/spartan2.c | 26 +++++++++++++------------- drivers/fpga/spartan3.c | 26 +++++++++++++------------- drivers/fpga/virtex2.c | 22 +++++++++++----------- drivers/fpga/xilinx.c | 14 +++++++------- drivers/fpga/zynqpl.c | 6 +++--- include/spartan2.h | 6 +++--- include/spartan3.h | 6 +++--- include/virtex2.h | 6 +++--- include/xilinx.h | 10 +++++----- include/zynqpl.h | 6 +++--- 19 files changed, 79 insertions(+), 79 deletions(-)
diff --git a/board/armadeus/apf27/fpga.c b/board/armadeus/apf27/fpga.c index 56fde200e794..7d6e1e462c99 100644 --- a/board/armadeus/apf27/fpga.c +++ b/board/armadeus/apf27/fpga.c @@ -42,7 +42,7 @@ xilinx_spartan3_slave_parallel_fns fpga_fns = { fpga_post_fn, };
-Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { +xilinx_desc fpga[CONFIG_FPGA_COUNT] = { {xilinx_spartan3, slave_parallel, 1196128l/8, diff --git a/board/astro/mcf5373l/fpga.c b/board/astro/mcf5373l/fpga.c index 152ff1f58c97..9dc82c5737c2 100644 --- a/board/astro/mcf5373l/fpga.c +++ b/board/astro/mcf5373l/fpga.c @@ -374,7 +374,7 @@ xilinx_spartan3_slave_serial_fns xilinx_fns = { xilinx_fastwr_fn };
-Xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { +xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { {xilinx_spartan3, slave_serial, XILINX_XC3S4000_SIZE, diff --git a/board/balloon3/balloon3.c b/board/balloon3/balloon3.c index 4aa66052da9c..aa108ca15390 100644 --- a/board/balloon3/balloon3.c +++ b/board/balloon3/balloon3.c @@ -207,7 +207,7 @@ xilinx_spartan3_slave_parallel_fns balloon3_fpga_fns = { fpga_post_config_fn, };
-Xilinx_desc fpga = XILINX_XC3S1000_DESC(slave_parallel, +xilinx_desc fpga = XILINX_XC3S1000_DESC(slave_parallel, (void *)&balloon3_fpga_fns, 0);
/* Initialize the FPGA */ diff --git a/board/esd/pmc440/fpga.c b/board/esd/pmc440/fpga.c index 18a1b63088d6..f876da855b13 100644 --- a/board/esd/pmc440/fpga.c +++ b/board/esd/pmc440/fpga.c @@ -57,7 +57,7 @@ xilinx_spartan2_slave_serial_fns ngcc_fpga_fns = { ngcc_fpga_post_config_fn };
-Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { +xilinx_desc fpga[CONFIG_FPGA_COUNT] = { XILINX_XC3S1200E_DESC( #ifdef USE_SP_CODE slave_parallel, diff --git a/board/gen860t/fpga.c b/board/gen860t/fpga.c index 48a4222ac410..dd0ef707d6d5 100644 --- a/board/gen860t/fpga.c +++ b/board/gen860t/fpga.c @@ -56,7 +56,7 @@ xilinx_virtex2_slave_selectmap_fns fpga_fns = { fpga_post_config_fn };
-Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { +xilinx_desc fpga[CONFIG_FPGA_COUNT] = { {xilinx_virtex2, slave_selectmap, XILINX_XC2V3000_SIZE, diff --git a/board/matrix_vision/mvsmr/fpga.c b/board/matrix_vision/mvsmr/fpga.c index b20745524394..518992578c1e 100644 --- a/board/matrix_vision/mvsmr/fpga.c +++ b/board/matrix_vision/mvsmr/fpga.c @@ -26,7 +26,7 @@ xilinx_spartan3_slave_serial_fns fpga_fns = { 0 };
-Xilinx_desc spartan3 = { +xilinx_desc spartan3 = { xilinx_spartan2, slave_serial, XILINX_XC3S200_SIZE, diff --git a/board/spear/x600/fpga.c b/board/spear/x600/fpga.c index c26eba42845c..b256222e1864 100644 --- a/board/spear/x600/fpga.c +++ b/board/spear/x600/fpga.c @@ -173,7 +173,7 @@ static xilinx_spartan3_slave_serial_fns x600_fpga_fns = { fpga_post_config_fn, };
-static Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { +static xilinx_desc fpga[CONFIG_FPGA_COUNT] = { XILINX_XC3S1200E_DESC(slave_serial, &x600_fpga_fns, 0) };
diff --git a/board/teejet/mt_ventoux/mt_ventoux.c b/board/teejet/mt_ventoux/mt_ventoux.c index a36176494e42..b4a0a72bd0fe 100644 --- a/board/teejet/mt_ventoux/mt_ventoux.c +++ b/board/teejet/mt_ventoux/mt_ventoux.c @@ -200,7 +200,7 @@ xilinx_spartan3_slave_serial_fns mt_ventoux_fpga_fns = { fpga_post_config_fn, };
-Xilinx_desc fpga = XILINX_XC6SLX4_DESC(slave_serial, +xilinx_desc fpga = XILINX_XC6SLX4_DESC(slave_serial, (void *)&mt_ventoux_fpga_fns, 0);
/* Initialize the FPGA */ diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 485a5e4a2492..c8cc2bc93446 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -14,15 +14,15 @@ DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_FPGA -Xilinx_desc fpga; +xilinx_desc fpga;
/* It can be done differently */ -Xilinx_desc fpga010 = XILINX_XC7Z010_DESC(0x10); -Xilinx_desc fpga015 = XILINX_XC7Z015_DESC(0x15); -Xilinx_desc fpga020 = XILINX_XC7Z020_DESC(0x20); -Xilinx_desc fpga030 = XILINX_XC7Z030_DESC(0x30); -Xilinx_desc fpga045 = XILINX_XC7Z045_DESC(0x45); -Xilinx_desc fpga100 = XILINX_XC7Z100_DESC(0x100); +xilinx_desc fpga010 = XILINX_XC7Z010_DESC(0x10); +xilinx_desc fpga015 = XILINX_XC7Z015_DESC(0x15); +xilinx_desc fpga020 = XILINX_XC7Z020_DESC(0x20); +xilinx_desc fpga030 = XILINX_XC7Z030_DESC(0x30); +xilinx_desc fpga045 = XILINX_XC7Z045_DESC(0x45); +xilinx_desc fpga100 = XILINX_XC7Z100_DESC(0x100); #endif
int board_init(void) diff --git a/drivers/fpga/spartan2.c b/drivers/fpga/spartan2.c index bd317095c656..0796729436cb 100644 --- a/drivers/fpga/spartan2.c +++ b/drivers/fpga/spartan2.c @@ -31,17 +31,17 @@ #define CONFIG_SYS_FPGA_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ #endif
-static int spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int spartan2_sp_info(Xilinx_desc *desc ); */ +static int spartan2_sp_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan2_sp_dump(xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan2_sp_info(xilinx_desc *desc ); */
-static int spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int spartan2_ss_info(Xilinx_desc *desc ); */ +static int spartan2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan2_ss_info(xilinx_desc *desc ); */
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int spartan2_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan2_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -64,7 +64,7 @@ int spartan2_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -87,7 +87,7 @@ int spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan2_info(Xilinx_desc *desc) +int spartan2_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -96,7 +96,7 @@ int spartan2_info(Xilinx_desc *desc) /* ------------------------------------------------------------------------- */ /* Spartan-II Slave Parallel Generic Implementation */
-static int spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan2_slave_parallel_fns *fn = desc->iface_fns; @@ -248,7 +248,7 @@ static int spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_sp_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan2_slave_parallel_fns *fn = desc->iface_fns; @@ -296,7 +296,7 @@ static int spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize)
-static int spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan2_slave_serial_fns *fn = desc->iface_fns; @@ -439,7 +439,7 @@ static int spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) { /* Readback is only available through the Slave Parallel and */ /* boundary-scan interfaces. */ diff --git a/drivers/fpga/spartan3.c b/drivers/fpga/spartan3.c index e40abbfb9460..1304b4c646e3 100644 --- a/drivers/fpga/spartan3.c +++ b/drivers/fpga/spartan3.c @@ -35,17 +35,17 @@ #define CONFIG_SYS_FPGA_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ #endif
-static int spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int spartan3_sp_info(Xilinx_desc *desc ); */ +static int spartan3_sp_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan3_sp_dump(xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan3_sp_info(xilinx_desc *desc ); */
-static int spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int spartan3_ss_info(Xilinx_desc *desc); */ +static int spartan3_ss_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan3_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan3_ss_info(xilinx_desc *desc); */
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int spartan3_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan3_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -68,7 +68,7 @@ int spartan3_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -91,7 +91,7 @@ int spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan3_info(Xilinx_desc *desc) +int spartan3_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -100,7 +100,7 @@ int spartan3_info(Xilinx_desc *desc) /* ------------------------------------------------------------------------- */ /* Spartan-II Slave Parallel Generic Implementation */
-static int spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan3_slave_parallel_fns *fn = desc->iface_fns; @@ -254,7 +254,7 @@ static int spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_sp_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan3_slave_parallel_fns *fn = desc->iface_fns; @@ -302,7 +302,7 @@ static int spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize)
-static int spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan3_slave_serial_fns *fn = desc->iface_fns; @@ -457,7 +457,7 @@ static int spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) { /* Readback is only available through the Slave Parallel and */ /* boundary-scan interfaces. */ diff --git a/drivers/fpga/virtex2.c b/drivers/fpga/virtex2.c index 1cd9046a2487..a582bf2d7987 100644 --- a/drivers/fpga/virtex2.c +++ b/drivers/fpga/virtex2.c @@ -84,13 +84,13 @@ #define CONFIG_SYS_FPGA_WAIT_CONFIG CONFIG_SYS_HZ/5 /* 200 ms */ #endif
-static int virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ssm_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ssm_dump(xilinx_desc *desc, const void *buf, size_t bsize);
-static int virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize);
-int virtex2_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int virtex2_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -112,7 +112,7 @@ int virtex2_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -134,7 +134,7 @@ int virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int virtex2_info(Xilinx_desc *desc) +int virtex2_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -153,7 +153,7 @@ int virtex2_info(Xilinx_desc *desc) * INIT_B and DONE lines. If both are high, configuration has * succeeded. Congratulations! */ -static int virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ssm_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; xilinx_virtex2_slave_selectmap_fns *fn = desc->iface_fns; @@ -352,7 +352,7 @@ static int virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) /* * Read the FPGA configuration data */ -static int virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ssm_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; xilinx_virtex2_slave_selectmap_fns *fn = desc->iface_fns; @@ -404,13 +404,13 @@ static int virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) { printf ("%s: Slave Serial Loading is unsupported\n", __FUNCTION__); return FPGA_FAIL; }
-static int virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) { printf ("%s: Slave Serial Dumping is unsupported\n", __FUNCTION__); return FPGA_FAIL; diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 6953535f0823..b0e9cb35a31e 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -31,7 +31,7 @@ #endif
/* Local Static Functions */ -static int xilinx_validate (Xilinx_desc * desc, char *fn); +static int xilinx_validate(xilinx_desc *desc, char *fn);
@@ -43,7 +43,7 @@ int fpga_loadbitstream(int devnum, char *fpgadata, size_t size) unsigned char *dataptr; unsigned int i; const fpga_desc *desc; - Xilinx_desc *xdesc; + xilinx_desc *xdesc;
dataptr = (unsigned char *)fpgadata; /* Find out fpga_description */ @@ -94,7 +94,7 @@ int fpga_loadbitstream(int devnum, char *fpgadata, size_t size) return FPGA_FAIL; } } else { - printf("%s: Please fill correct device ID to Xilinx_desc\n", + printf("%s: Please fill correct device ID to xilinx_desc\n", __func__); } printf(" part number = "%s"\n", buffer); @@ -141,7 +141,7 @@ int fpga_loadbitstream(int devnum, char *fpgadata, size_t size) return fpga_load(devnum, dataptr, swapsize); }
-int xilinx_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int xilinx_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume a failure */
@@ -198,7 +198,7 @@ int xilinx_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int xilinx_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume a failure */
@@ -255,7 +255,7 @@ int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int xilinx_info (Xilinx_desc * desc) +int xilinx_info(xilinx_desc *desc) { int ret_val = FPGA_FAIL;
@@ -369,7 +369,7 @@ int xilinx_info (Xilinx_desc * desc)
-static int xilinx_validate (Xilinx_desc * desc, char *fn) +static int xilinx_validate(xilinx_desc *desc, char *fn) { int ret_val = false;
diff --git a/drivers/fpga/zynqpl.c b/drivers/fpga/zynqpl.c index 923a1586d8b5..b4d0e2278c94 100644 --- a/drivers/fpga/zynqpl.c +++ b/drivers/fpga/zynqpl.c @@ -36,7 +36,7 @@ #define CONFIG_SYS_FPGA_PROG_TIME (CONFIG_SYS_HZ * 4) /* 4 s */ #endif
-int zynq_info(Xilinx_desc *desc) +int zynq_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -153,7 +153,7 @@ static void *check_data(u8 *buf, size_t bsize, u32 *swap) }
-int zynq_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) { unsigned long ts; /* Timestamp */ u32 partialbit = 0; @@ -358,7 +358,7 @@ int zynq_load(Xilinx_desc *desc, const void *buf, size_t bsize) return FPGA_SUCCESS; }
-int zynq_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int zynq_dump(xilinx_desc *desc, const void *buf, size_t bsize) { return FPGA_FAIL; } diff --git a/include/spartan2.h b/include/spartan2.h index a9fc68acc890..33b25e6b8b94 100644 --- a/include/spartan2.h +++ b/include/spartan2.h @@ -10,9 +10,9 @@
#include <xilinx.h>
-int spartan2_load(Xilinx_desc *desc, const void *image, size_t size); -int spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -int spartan2_info(Xilinx_desc *desc); +int spartan2_load(xilinx_desc *desc, const void *image, size_t size); +int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize); +int spartan2_info(xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { diff --git a/include/spartan3.h b/include/spartan3.h index 93ca8a40bc34..e06b99bff554 100644 --- a/include/spartan3.h +++ b/include/spartan3.h @@ -10,9 +10,9 @@
#include <xilinx.h>
-int spartan3_load(Xilinx_desc *desc, const void *image, size_t size); -int spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -int spartan3_info(Xilinx_desc *desc); +int spartan3_load(xilinx_desc *desc, const void *image, size_t size); +int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize); +int spartan3_info(xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { diff --git a/include/virtex2.h b/include/virtex2.h index 1e6624ca9627..dd47965aad3d 100644 --- a/include/virtex2.h +++ b/include/virtex2.h @@ -11,9 +11,9 @@
#include <xilinx.h>
-int virtex2_load(Xilinx_desc *desc, const void *image, size_t size); -int virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -int virtex2_info(Xilinx_desc *desc); +int virtex2_load(xilinx_desc *desc, const void *image, size_t size); +int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize); +int virtex2_info(xilinx_desc *desc);
/* * Slave SelectMap Implementation function table. diff --git a/include/xilinx.h b/include/xilinx.h index fa89fb68351b..5900c837440c 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -34,20 +34,20 @@ typedef enum { /* typedef Xilinx_Family */ max_xilinx_type /* insert all new types before this */ } Xilinx_Family; /* end, typedef Xilinx_Family */
-typedef struct { /* typedef Xilinx_desc */ +typedef struct { /* typedef xilinx_desc */ Xilinx_Family family; /* part type */ Xilinx_iface iface; /* interface type */ size_t size; /* bytes of data part can accept */ void *iface_fns; /* interface function table */ int cookie; /* implementation specific cookie */ char *name; /* device name in bitstream */ -} Xilinx_desc; /* end, typedef Xilinx_desc */ +} xilinx_desc; /* end, typedef xilinx_desc */
/* Generic Xilinx Functions *********************************************************************/ -extern int xilinx_load(Xilinx_desc *desc, const void *image, size_t size); -extern int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -extern int xilinx_info(Xilinx_desc *desc); +int xilinx_load(xilinx_desc *desc, const void *image, size_t size); +int xilinx_dump(xilinx_desc *desc, const void *buf, size_t bsize); +int xilinx_info(xilinx_desc *desc);
/* Board specific implementation specific function types *********************************************************************/ diff --git a/include/zynqpl.h b/include/zynqpl.h index c81446e9860c..fdee69110ce2 100644 --- a/include/zynqpl.h +++ b/include/zynqpl.h @@ -12,9 +12,9 @@
#include <xilinx.h>
-extern int zynq_load(Xilinx_desc *desc, const void *image, size_t size); -extern int zynq_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -extern int zynq_info(Xilinx_desc *desc); +int zynq_load(xilinx_desc *desc, const void *image, size_t size); +int zynq_dump(xilinx_desc *desc, const void *buf, size_t bsize); +int zynq_info(xilinx_desc *desc);
#define XILINX_ZYNQ_7010 0x2 #define XILINX_ZYNQ_7015 0x1b -- 1.8.2.3
board/astro/mcf5373l/fpga.c | 38 +++++++++++++++++++------------------- include/spartan2.h | 40 ++++++++++++++++++++-------------------- include/spartan3.h | 44 ++++++++++++++++++++++---------------------- include/virtex2.h | 34 +++++++++++++++++----------------- include/xilinx.h | 42 +++++++++++++++++++++--------------------- 5 files changed, 99 insertions(+), 99 deletions(-)
diff --git a/board/astro/mcf5373l/fpga.c b/board/astro/mcf5373l/fpga.c index 9dc82c5737c2..81ec19206577 100644 --- a/board/astro/mcf5373l/fpga.c +++ b/board/astro/mcf5373l/fpga.c @@ -203,7 +203,7 @@ int astro5373l_altera_load(void) }
/* Set the FPGA's PROG_B line to the specified level */ -int xilinx_pgm_fn(int assert, int flush, int cookie) +int xilinx_pgm_config_fn(int assert, int flush, int cookie) { gpio_t *gpiop = (gpio_t *)MMAP_GPIO;
@@ -218,7 +218,7 @@ int xilinx_pgm_fn(int assert, int flush, int cookie) * Test the state of the active-low FPGA INIT line. Return 1 on INIT * asserted (low). */ -int xilinx_init_fn(int cookie) +int xilinx_init_config_fn(int cookie) { gpio_t *gpiop = (gpio_t *)MMAP_GPIO;
@@ -226,7 +226,7 @@ int xilinx_init_fn(int cookie) }
/* Test the state of the active-high FPGA DONE pin */ -int xilinx_done_fn(int cookie) +int xilinx_done_config_fn(int cookie) { gpio_t *gpiop = (gpio_t *)MMAP_GPIO;
@@ -234,7 +234,7 @@ int xilinx_done_fn(int cookie) }
/* Abort an FPGA operation */ -int xilinx_abort_fn(int cookie) +int xilinx_abort_config_fn(int cookie) { gpio_t *gpiop = (gpio_t *)MMAP_GPIO; /* ensure all SPI peripherals and FPGAs are deselected */ @@ -300,7 +300,7 @@ int xilinx_post_config_fn(int cookie) return rc; }
-int xilinx_clk_fn(int assert_clk, int flush, int cookie) +int xilinx_clk_config_fn(int assert_clk, int flush, int cookie) { gpio_t *gpiop = (gpio_t *)MMAP_GPIO;
@@ -311,7 +311,7 @@ int xilinx_clk_fn(int assert_clk, int flush, int cookie) return assert_clk; }
-int xilinx_wr_fn(int assert_write, int flush, int cookie) +int xilinx_wr_config_fn(int assert_write, int flush, int cookie) { gpio_t *gpiop = (gpio_t *)MMAP_GPIO;
@@ -322,7 +322,7 @@ int xilinx_wr_fn(int assert_write, int flush, int cookie) return assert_write; }
-int xilinx_fastwr_fn(void *buf, size_t len, int flush, int cookie) +int xilinx_fastwr_config_fn(void *buf, size_t len, int flush, int cookie) { size_t bytecount = 0; gpio_t *gpiop = (gpio_t *)MMAP_GPIO; @@ -365,13 +365,13 @@ int xilinx_fastwr_fn(void *buf, size_t len, int flush, int cookie) */ xilinx_spartan3_slave_serial_fns xilinx_fns = { xilinx_pre_config_fn, - xilinx_pgm_fn, - xilinx_clk_fn, - xilinx_init_fn, - xilinx_done_fn, - xilinx_wr_fn, + xilinx_pgm_config_fn, + xilinx_clk_config_fn, + xilinx_init_config_fn, + xilinx_done_config_fn, + xilinx_wr_config_fn, 0, - xilinx_fastwr_fn + xilinx_fastwr_config_fn };
xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { @@ -395,12 +395,12 @@ int astro5373l_xilinx_load(void) * so set stuff here instead of static initialisation: */ xilinx_fns.pre = xilinx_pre_config_fn; - xilinx_fns.pgm = xilinx_pgm_fn; - xilinx_fns.clk = xilinx_clk_fn; - xilinx_fns.init = xilinx_init_fn; - xilinx_fns.done = xilinx_done_fn; - xilinx_fns.wr = xilinx_wr_fn; - xilinx_fns.bwr = xilinx_fastwr_fn; + xilinx_fns.pgm = xilinx_pgm_config_fn; + xilinx_fns.clk = xilinx_clk_config_fn; + xilinx_fns.init = xilinx_init_config_fn; + xilinx_fns.done = xilinx_done_config_fn; + xilinx_fns.wr = xilinx_wr_config_fn; + xilinx_fns.bwr = xilinx_fastwr_config_fn; xilinx_fpga[i].iface_fns = (void *)&xilinx_fns; fpga_add(fpga_xilinx, &xilinx_fpga[i]); } diff --git a/include/spartan2.h b/include/spartan2.h index 33b25e6b8b94..25db6e7a60db 100644 --- a/include/spartan2.h +++ b/include/spartan2.h @@ -16,30 +16,30 @@ int spartan2_info(xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { - Xilinx_pre_fn pre; - Xilinx_pgm_fn pgm; - Xilinx_init_fn init; - Xilinx_err_fn err; - Xilinx_done_fn done; - Xilinx_clk_fn clk; - Xilinx_cs_fn cs; - Xilinx_wr_fn wr; - Xilinx_rdata_fn rdata; - Xilinx_wdata_fn wdata; - Xilinx_busy_fn busy; - Xilinx_abort_fn abort; - Xilinx_post_fn post; + xilinx_pre_fn pre; + xilinx_pgm_fn pgm; + xilinx_init_fn init; + xilinx_err_fn err; + xilinx_done_fn done; + xilinx_clk_fn clk; + xilinx_cs_fn cs; + xilinx_wr_fn wr; + xilinx_rdata_fn rdata; + xilinx_wdata_fn wdata; + xilinx_busy_fn busy; + xilinx_abort_fn abort; + xilinx_post_fn post; } xilinx_spartan2_slave_parallel_fns;
/* Slave Serial Implementation function table */ typedef struct { - Xilinx_pre_fn pre; - Xilinx_pgm_fn pgm; - Xilinx_clk_fn clk; - Xilinx_init_fn init; - Xilinx_done_fn done; - Xilinx_wr_fn wr; - Xilinx_post_fn post; + xilinx_pre_fn pre; + xilinx_pgm_fn pgm; + xilinx_clk_fn clk; + xilinx_init_fn init; + xilinx_done_fn done; + xilinx_wr_fn wr; + xilinx_post_fn post; } xilinx_spartan2_slave_serial_fns;
/* Device Image Sizes diff --git a/include/spartan3.h b/include/spartan3.h index e06b99bff554..56698ac9c724 100644 --- a/include/spartan3.h +++ b/include/spartan3.h @@ -16,32 +16,32 @@ int spartan3_info(xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { - Xilinx_pre_fn pre; - Xilinx_pgm_fn pgm; - Xilinx_init_fn init; - Xilinx_err_fn err; - Xilinx_done_fn done; - Xilinx_clk_fn clk; - Xilinx_cs_fn cs; - Xilinx_wr_fn wr; - Xilinx_rdata_fn rdata; - Xilinx_wdata_fn wdata; - Xilinx_busy_fn busy; - Xilinx_abort_fn abort; - Xilinx_post_fn post; + xilinx_pre_fn pre; + xilinx_pgm_fn pgm; + xilinx_init_fn init; + xilinx_err_fn err; + xilinx_done_fn done; + xilinx_clk_fn clk; + xilinx_cs_fn cs; + xilinx_wr_fn wr; + xilinx_rdata_fn rdata; + xilinx_wdata_fn wdata; + xilinx_busy_fn busy; + xilinx_abort_fn abort; + xilinx_post_fn post; } xilinx_spartan3_slave_parallel_fns;
/* Slave Serial Implementation function table */ typedef struct { - Xilinx_pre_fn pre; - Xilinx_pgm_fn pgm; - Xilinx_clk_fn clk; - Xilinx_init_fn init; - Xilinx_done_fn done; - Xilinx_wr_fn wr; - Xilinx_post_fn post; - Xilinx_bwr_fn bwr; /* block write function */ - Xilinx_abort_fn abort; + xilinx_pre_fn pre; + xilinx_pgm_fn pgm; + xilinx_clk_fn clk; + xilinx_init_fn init; + xilinx_done_fn done; + xilinx_wr_fn wr; + xilinx_post_fn post; + xilinx_bwr_fn bwr; /* block write function */ + xilinx_abort_fn abort; } xilinx_spartan3_slave_serial_fns;
/* Device Image Sizes diff --git a/include/virtex2.h b/include/virtex2.h index dd47965aad3d..d39286c7ab9b 100644 --- a/include/virtex2.h +++ b/include/virtex2.h @@ -19,27 +19,27 @@ int virtex2_info(xilinx_desc *desc); * Slave SelectMap Implementation function table. */ typedef struct { - Xilinx_pre_fn pre; - Xilinx_pgm_fn pgm; - Xilinx_init_fn init; - Xilinx_err_fn err; - Xilinx_done_fn done; - Xilinx_clk_fn clk; - Xilinx_cs_fn cs; - Xilinx_wr_fn wr; - Xilinx_rdata_fn rdata; - Xilinx_wdata_fn wdata; - Xilinx_busy_fn busy; - Xilinx_abort_fn abort; - Xilinx_post_fn post; + xilinx_pre_fn pre; + xilinx_pgm_fn pgm; + xilinx_init_fn init; + xilinx_err_fn err; + xilinx_done_fn done; + xilinx_clk_fn clk; + xilinx_cs_fn cs; + xilinx_wr_fn wr; + xilinx_rdata_fn rdata; + xilinx_wdata_fn wdata; + xilinx_busy_fn busy; + xilinx_abort_fn abort; + xilinx_post_fn post; } xilinx_virtex2_slave_selectmap_fns;
/* Slave Serial Implementation function table */ typedef struct { - Xilinx_pgm_fn pgm; - Xilinx_clk_fn clk; - Xilinx_rdata_fn rdata; - Xilinx_wdata_fn wdata; + xilinx_pgm_fn pgm; + xilinx_clk_fn clk; + xilinx_rdata_fn rdata; + xilinx_wdata_fn wdata; } xilinx_virtex2_slave_serial_fns;
/* Device Image Sizes (in bytes) diff --git a/include/xilinx.h b/include/xilinx.h index 5900c837440c..b72aece7c900 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -12,7 +12,7 @@
/* Xilinx types *********************************************************************/ -typedef enum { /* typedef Xilinx_iface */ +typedef enum { /* typedef xilinx_iface */ min_xilinx_iface_type, /* low range check value */ slave_serial, /* serial data and external clock */ master_serial, /* serial data w/ internal clock (not used) */ @@ -22,21 +22,21 @@ typedef enum { /* typedef Xilinx_iface */ slave_selectmap, /* slave SelectMap (virtex2) */ devcfg, /* devcfg interface (zynq) */ max_xilinx_iface_type /* insert all new types before this */ -} Xilinx_iface; /* end, typedef Xilinx_iface */ +} xilinx_iface; /* end, typedef xilinx_iface */
-typedef enum { /* typedef Xilinx_Family */ +typedef enum { /* typedef xilinx_family */ min_xilinx_type, /* low range check value */ xilinx_spartan2, /* Spartan-II Family */ - Xilinx_VirtexE, /* Virtex-E Family */ + xilinx_virtexE, /* Virtex-E Family */ xilinx_virtex2, /* Virtex2 Family */ xilinx_spartan3, /* Spartan-III Family */ xilinx_zynq, /* Zynq Family */ max_xilinx_type /* insert all new types before this */ -} Xilinx_Family; /* end, typedef Xilinx_Family */ +} xilinx_family; /* end, typedef xilinx_family */
typedef struct { /* typedef xilinx_desc */ - Xilinx_Family family; /* part type */ - Xilinx_iface iface; /* interface type */ + xilinx_family family; /* part type */ + xilinx_iface iface; /* interface type */ size_t size; /* bytes of data part can accept */ void *iface_fns; /* interface function table */ int cookie; /* implementation specific cookie */ @@ -51,19 +51,19 @@ int xilinx_info(xilinx_desc *desc);
/* Board specific implementation specific function types *********************************************************************/ -typedef int (*Xilinx_pgm_fn)( int assert_pgm, int flush, int cookie ); -typedef int (*Xilinx_init_fn)( int cookie ); -typedef int (*Xilinx_err_fn)( int cookie ); -typedef int (*Xilinx_done_fn)( int cookie ); -typedef int (*Xilinx_clk_fn)( int assert_clk, int flush, int cookie ); -typedef int (*Xilinx_cs_fn)( int assert_cs, int flush, int cookie ); -typedef int (*Xilinx_wr_fn)( int assert_write, int flush, int cookie ); -typedef int (*Xilinx_rdata_fn)( unsigned char *data, int cookie ); -typedef int (*Xilinx_wdata_fn)( unsigned char data, int flush, int cookie ); -typedef int (*Xilinx_busy_fn)( int cookie ); -typedef int (*Xilinx_abort_fn)( int cookie ); -typedef int (*Xilinx_pre_fn)( int cookie ); -typedef int (*Xilinx_post_fn)( int cookie ); -typedef int (*Xilinx_bwr_fn)( void *buf, size_t len, int flush, int cookie ); +typedef int (*xilinx_pgm_fn)(int assert_pgm, int flush, int cookie); +typedef int (*xilinx_init_fn)(int cookie); +typedef int (*xilinx_err_fn)(int cookie); +typedef int (*xilinx_done_fn)(int cookie); +typedef int (*xilinx_clk_fn)(int assert_clk, int flush, int cookie); +typedef int (*xilinx_cs_fn)(int assert_cs, int flush, int cookie); +typedef int (*xilinx_wr_fn)(int assert_write, int flush, int cookie); +typedef int (*xilinx_rdata_fn)(unsigned char *data, int cookie); +typedef int (*xilinx_wdata_fn)(unsigned char data, int flush, int cookie); +typedef int (*xilinx_busy_fn)(int cookie); +typedef int (*xilinx_abort_fn)(int cookie); +typedef int (*xilinx_pre_fn)(int cookie); +typedef int (*xilinx_post_fn)(int cookie); +typedef int (*xilinx_bwr_fn)(void *buf, size_t len, int flush, int cookie);
#endif /* _XILINX_H_ */ -- 1.8.2.3
Connect FPGA version with appropriate operations to remove huge switch-cases for every FPGA family. Tested on Zynq. Spartan2/Spartan3/Virtex2 just compile test.
Changes in v2: - Exchange fpga_op and name in xilinx_desc because spartan2/3, virtex2 are not using names. - Fix warning reported by Tom board/spear/x600/fpga.c:177:2: warning: initialization from incompatible pointer type [enabled by default] board/spear/x600/fpga.c:177:2: warning: (near initialization for ‘fpga[0].name’) [enabled by default] - Add fix for apf27 and astro
Based on http://permalink.gmane.org/gmane.comp.boot-loaders.u-boot/182419 I have checked that symbols are available in u-boot.map.
--- board/armadeus/apf27/fpga.c | 1 + board/astro/mcf5373l/fpga.c | 3 +- drivers/fpga/spartan2.c | 12 +++- drivers/fpga/spartan3.c | 12 +++- drivers/fpga/virtex2.c | 12 +++- drivers/fpga/xilinx.c | 159 ++------------------------------------------ drivers/fpga/zynqpl.c | 13 ++-- include/spartan2.h | 28 ++++---- include/spartan3.h | 36 +++++----- include/virtex2.h | 28 ++++---- include/xilinx.h | 7 ++ include/zynqpl.h | 16 ++--- 12 files changed, 104 insertions(+), 223 deletions(-)
diff --git a/board/armadeus/apf27/fpga.c b/board/armadeus/apf27/fpga.c index 7d6e1e462c99..65a4812c35b8 100644 --- a/board/armadeus/apf27/fpga.c +++ b/board/armadeus/apf27/fpga.c @@ -48,6 +48,7 @@ xilinx_desc fpga[CONFIG_FPGA_COUNT] = { 1196128l/8, (void *)&fpga_fns, 0, + &spartan3_op, "3s200aft256"} };
diff --git a/board/astro/mcf5373l/fpga.c b/board/astro/mcf5373l/fpga.c index 81ec19206577..1d044d96a563 100644 --- a/board/astro/mcf5373l/fpga.c +++ b/board/astro/mcf5373l/fpga.c @@ -379,7 +379,8 @@ xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { slave_serial, XILINX_XC3S4000_SIZE, (void *)&xilinx_fns, - 0} + 0, + &spartan3_op} };
/* Initialize the fpga. Return 1 on success, 0 on failure. */ diff --git a/drivers/fpga/spartan2.c b/drivers/fpga/spartan2.c index 0796729436cb..705405614033 100644 --- a/drivers/fpga/spartan2.c +++ b/drivers/fpga/spartan2.c @@ -41,7 +41,7 @@ static int spartan2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize);
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int spartan2_load(xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -64,7 +64,7 @@ int spartan2_load(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -87,7 +87,7 @@ int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan2_info(xilinx_desc *desc) +static int spartan2_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -447,3 +447,9 @@ static int spartan2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); return FPGA_FAIL; } + +struct xilinx_fpga_op spartan2_op = { + .load = spartan2_load, + .dump = spartan2_dump, + .info = spartan2_info, +}; diff --git a/drivers/fpga/spartan3.c b/drivers/fpga/spartan3.c index 1304b4c646e3..5c9412c2f63b 100644 --- a/drivers/fpga/spartan3.c +++ b/drivers/fpga/spartan3.c @@ -45,7 +45,7 @@ static int spartan3_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize);
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int spartan3_load(xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -68,7 +68,7 @@ int spartan3_load(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -91,7 +91,7 @@ int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan3_info(xilinx_desc *desc) +static int spartan3_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -465,3 +465,9 @@ static int spartan3_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); return FPGA_FAIL; } + +struct xilinx_fpga_op spartan3_op = { + .load = spartan3_load, + .dump = spartan3_dump, + .info = spartan3_info, +}; diff --git a/drivers/fpga/virtex2.c b/drivers/fpga/virtex2.c index a582bf2d7987..e092147edd10 100644 --- a/drivers/fpga/virtex2.c +++ b/drivers/fpga/virtex2.c @@ -90,7 +90,7 @@ static int virtex2_ssm_dump(xilinx_desc *desc, const void *buf, size_t bsize); static int virtex2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize); static int virtex2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize);
-int virtex2_load(xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -112,7 +112,7 @@ int virtex2_load(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -134,7 +134,7 @@ int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int virtex2_info(xilinx_desc *desc) +static int virtex2_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -417,3 +417,9 @@ static int virtex2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) }
/* vim: set ts=4 tw=78: */ + +struct xilinx_fpga_op virtex2_op = { + .load = virtex2_load, + .dump = virtex2_dump, + .info = virtex2_info, +}; diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index b0e9cb35a31e..8837f5c122e7 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -19,17 +19,6 @@ #include <spartan3.h> #include <zynqpl.h>
-#if 0 -#define FPGA_DEBUG -#endif - -/* Define FPGA_DEBUG to get debug printf's */ -#ifdef FPGA_DEBUG -#define PRINTF(fmt,args...) printf (fmt ,##args) -#else -#define PRINTF(fmt,args...) -#endif - /* Local Static Functions */ static int xilinx_validate(xilinx_desc *desc, char *fn);
@@ -143,116 +132,22 @@ int fpga_loadbitstream(int devnum, char *fpgadata, size_t size)
int xilinx_load(xilinx_desc *desc, const void *buf, size_t bsize) { - int ret_val = FPGA_FAIL; /* assume a failure */ - if (!xilinx_validate (desc, (char *)__FUNCTION__)) { printf ("%s: Invalid device descriptor\n", __FUNCTION__); - } else - switch (desc->family) { - case xilinx_spartan2: -#if defined(CONFIG_FPGA_SPARTAN2) - PRINTF ("%s: Launching the Spartan-II Loader...\n", - __FUNCTION__); - ret_val = spartan2_load(desc, buf, bsize); -#else - printf ("%s: No support for Spartan-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_spartan3: -#if defined(CONFIG_FPGA_SPARTAN3) - PRINTF ("%s: Launching the Spartan-III Loader...\n", - __FUNCTION__); - ret_val = spartan3_load(desc, buf, bsize); -#else - printf ("%s: No support for Spartan-III devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_virtex2: -#if defined(CONFIG_FPGA_VIRTEX2) - PRINTF ("%s: Launching the Virtex-II Loader...\n", - __FUNCTION__); - ret_val = virtex2_load(desc, buf, bsize); -#else - printf ("%s: No support for Virtex-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_zynq: -#if defined(CONFIG_FPGA_ZYNQPL) - PRINTF("%s: Launching the Zynq PL Loader...\n", - __func__); - ret_val = zynq_load(desc, buf, bsize); -#else - printf("%s: No support for Zynq devices.\n", - __func__); -#endif - break; - - default: - printf ("%s: Unsupported family type, %d\n", - __FUNCTION__, desc->family); - } + return FPGA_FAIL; + }
- return ret_val; + return desc->operations->load(desc, buf, bsize); }
int xilinx_dump(xilinx_desc *desc, const void *buf, size_t bsize) { - int ret_val = FPGA_FAIL; /* assume a failure */ - if (!xilinx_validate (desc, (char *)__FUNCTION__)) { printf ("%s: Invalid device descriptor\n", __FUNCTION__); - } else - switch (desc->family) { - case xilinx_spartan2: -#if defined(CONFIG_FPGA_SPARTAN2) - PRINTF ("%s: Launching the Spartan-II Reader...\n", - __FUNCTION__); - ret_val = spartan2_dump(desc, buf, bsize); -#else - printf ("%s: No support for Spartan-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_spartan3: -#if defined(CONFIG_FPGA_SPARTAN3) - PRINTF ("%s: Launching the Spartan-III Reader...\n", - __FUNCTION__); - ret_val = spartan3_dump(desc, buf, bsize); -#else - printf ("%s: No support for Spartan-III devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_virtex2: -#if defined( CONFIG_FPGA_VIRTEX2) - PRINTF ("%s: Launching the Virtex-II Reader...\n", - __FUNCTION__); - ret_val = virtex2_dump(desc, buf, bsize); -#else - printf ("%s: No support for Virtex-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_zynq: -#if defined(CONFIG_FPGA_ZYNQPL) - PRINTF("%s: Launching the Zynq PL Reader...\n", - __func__); - ret_val = zynq_dump(desc, buf, bsize); -#else - printf("%s: No support for Zynq devices.\n", - __func__); -#endif - break; - - default: - printf ("%s: Unsupported family type, %d\n", - __FUNCTION__, desc->family); - } + return FPGA_FAIL; + }
- return ret_val; + return desc->operations->dump(desc, buf, bsize); }
int xilinx_info(xilinx_desc *desc) @@ -315,47 +210,7 @@ int xilinx_info(xilinx_desc *desc)
if (desc->iface_fns) { printf ("Device Function Table @ 0x%p\n", desc->iface_fns); - switch (desc->family) { - case xilinx_spartan2: -#if defined(CONFIG_FPGA_SPARTAN2) - spartan2_info(desc); -#else - /* just in case */ - printf ("%s: No support for Spartan-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_spartan3: -#if defined(CONFIG_FPGA_SPARTAN3) - spartan3_info(desc); -#else - /* just in case */ - printf ("%s: No support for Spartan-III devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_virtex2: -#if defined(CONFIG_FPGA_VIRTEX2) - virtex2_info(desc); -#else - /* just in case */ - printf ("%s: No support for Virtex-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_zynq: -#if defined(CONFIG_FPGA_ZYNQPL) - zynq_info(desc); -#else - /* just in case */ - printf("%s: No support for Zynq devices.\n", - __func__); -#endif - /* Add new family types here */ - default: - /* we don't need a message here - we give one up above */ - ; - } + desc->operations->info(desc); } else printf ("No Device Function Table.\n");
diff --git a/drivers/fpga/zynqpl.c b/drivers/fpga/zynqpl.c index b4d0e2278c94..dcd34951ad68 100644 --- a/drivers/fpga/zynqpl.c +++ b/drivers/fpga/zynqpl.c @@ -36,7 +36,7 @@ #define CONFIG_SYS_FPGA_PROG_TIME (CONFIG_SYS_HZ * 4) /* 4 s */ #endif
-int zynq_info(xilinx_desc *desc) +static int zynq_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -152,8 +152,7 @@ static void *check_data(u8 *buf, size_t bsize, u32 *swap) return 0; }
- -int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) +static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) { unsigned long ts; /* Timestamp */ u32 partialbit = 0; @@ -358,7 +357,13 @@ int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) return FPGA_SUCCESS; }
-int zynq_dump(xilinx_desc *desc, const void *buf, size_t bsize) +static int zynq_dump(xilinx_desc *desc, const void *buf, size_t bsize) { return FPGA_FAIL; } + +struct xilinx_fpga_op zynq_op = { + .load = zynq_load, + .dump = zynq_dump, + .info = zynq_info, +}; diff --git a/include/spartan2.h b/include/spartan2.h index 25db6e7a60db..2aca954e73ab 100644 --- a/include/spartan2.h +++ b/include/spartan2.h @@ -10,10 +10,6 @@
#include <xilinx.h>
-int spartan2_load(xilinx_desc *desc, const void *image, size_t size); -int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize); -int spartan2_info(xilinx_desc *desc); - /* Slave Parallel Implementation function table */ typedef struct { xilinx_pre_fn pre; @@ -42,6 +38,8 @@ typedef struct { xilinx_post_fn post; } xilinx_spartan2_slave_serial_fns;
+extern struct xilinx_fpga_op spartan2_op; + /* Device Image Sizes *********************************************************************/ /* Spartan-II (2.5V) */ @@ -63,36 +61,36 @@ typedef struct { *********************************************************************/ /* Spartan-II devices */ #define XILINX_XC2S15_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S15_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S15_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S30_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S30_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S30_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S50_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S50_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S50_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S100_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S100_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S100_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S150_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S150_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S150_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S200_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S200_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S200_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S50E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S50E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S50E_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S100E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S100E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S100E_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S150E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S150E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S150E_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S200E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S200E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S200E_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S300E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S300E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S300E_SIZE, fn_table, cookie, &spartan2_op }
#endif /* _SPARTAN2_H_ */ diff --git a/include/spartan3.h b/include/spartan3.h index 56698ac9c724..d6d67a6e560c 100644 --- a/include/spartan3.h +++ b/include/spartan3.h @@ -10,10 +10,6 @@
#include <xilinx.h>
-int spartan3_load(xilinx_desc *desc, const void *image, size_t size); -int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize); -int spartan3_info(xilinx_desc *desc); - /* Slave Parallel Implementation function table */ typedef struct { xilinx_pre_fn pre; @@ -44,6 +40,8 @@ typedef struct { xilinx_abort_fn abort; } xilinx_spartan3_slave_serial_fns;
+extern struct xilinx_fpga_op spartan3_op; + /* Device Image Sizes *********************************************************************/ /* Spartan-III (1.2V) */ @@ -73,46 +71,48 @@ typedef struct { *********************************************************************/ /* Spartan-III devices */ #define XILINX_XC3S50_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S50_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S50_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S200_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S200_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S200_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S400_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S400_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S400_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S1000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S1000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1000_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S1500_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S1500_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1500_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S2000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S2000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S2000_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S4000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S4000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S4000_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S5000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S5000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S5000_SIZE, fn_table, cookie, &spartan3_op }
/* Spartan-3E devices */ #define XILINX_XC3S100E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S100E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S100E_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S250E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S250E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S250E_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S500E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S500E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S500E_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S1200E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S1200E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1200E_SIZE, fn_table, cookie, \ + &spartan3_op }
#define XILINX_XC3S1600E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S1600E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1600E_SIZE, fn_table, cookie, \ + &spartan3_op }
#define XILINX_XC6SLX4_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINK_XC6SLX4_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINK_XC6SLX4_SIZE, fn_table, cookie, &spartan3_op }
#endif /* _SPARTAN3_H_ */ diff --git a/include/virtex2.h b/include/virtex2.h index d39286c7ab9b..7b7825f513e3 100644 --- a/include/virtex2.h +++ b/include/virtex2.h @@ -11,9 +11,7 @@
#include <xilinx.h>
-int virtex2_load(xilinx_desc *desc, const void *image, size_t size); -int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize); -int virtex2_info(xilinx_desc *desc); +extern struct xilinx_fpga_op virtex2_op;
/* * Slave SelectMap Implementation function table. @@ -60,39 +58,39 @@ typedef struct { /* Descriptor Macros *********************************************************************/ #define XILINX_XC2V40_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V40_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V40_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V80_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V80_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V80_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V250_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V250_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V250_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V500_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V500_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V500_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V1000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V1000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V1000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V1500_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V1500_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V1500_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V2000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V2000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V2000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V3000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V3000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V3000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V4000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V4000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V4000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V6000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V6000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V6000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V8000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V8000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V8000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V10000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V10000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V10000_SIZE, fn_table, cookie, &virtex2_op }
#endif /* _VIRTEX2_H_ */ diff --git a/include/xilinx.h b/include/xilinx.h index b72aece7c900..9801267c593f 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -40,9 +40,16 @@ typedef struct { /* typedef xilinx_desc */ size_t size; /* bytes of data part can accept */ void *iface_fns; /* interface function table */ int cookie; /* implementation specific cookie */ + struct xilinx_fpga_op *operations; /* operations */ char *name; /* device name in bitstream */ } xilinx_desc; /* end, typedef xilinx_desc */
+struct xilinx_fpga_op { + int (*load)(xilinx_desc *, const void *, size_t); + int (*dump)(xilinx_desc *, const void *, size_t); + int (*info)(xilinx_desc *); +}; + /* Generic Xilinx Functions *********************************************************************/ int xilinx_load(xilinx_desc *desc, const void *image, size_t size); diff --git a/include/zynqpl.h b/include/zynqpl.h index fdee69110ce2..8a9ec3297fbe 100644 --- a/include/zynqpl.h +++ b/include/zynqpl.h @@ -12,9 +12,7 @@
#include <xilinx.h>
-int zynq_load(xilinx_desc *desc, const void *image, size_t size); -int zynq_dump(xilinx_desc *desc, const void *buf, size_t bsize); -int zynq_info(xilinx_desc *desc); +extern struct xilinx_fpga_op zynq_op;
#define XILINX_ZYNQ_7010 0x2 #define XILINX_ZYNQ_7015 0x1b @@ -33,21 +31,21 @@ int zynq_info(xilinx_desc *desc);
/* Descriptor Macros */ #define XILINX_XC7Z010_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z010_SIZE, NULL, cookie, "7z010" } +{ xilinx_zynq, devcfg, XILINX_XC7Z010_SIZE, NULL, cookie, &zynq_op, "7z010" }
#define XILINX_XC7Z015_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z015_SIZE, NULL, cookie, "7z015" } +{ xilinx_zynq, devcfg, XILINX_XC7Z015_SIZE, NULL, cookie, &zynq_op, "7z015" }
#define XILINX_XC7Z020_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z020_SIZE, NULL, cookie, "7z020" } +{ xilinx_zynq, devcfg, XILINX_XC7Z020_SIZE, NULL, cookie, &zynq_op, "7z020" }
#define XILINX_XC7Z030_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z030_SIZE, NULL, cookie, "7z030" } +{ xilinx_zynq, devcfg, XILINX_XC7Z030_SIZE, NULL, cookie, &zynq_op, "7z030" }
#define XILINX_XC7Z045_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z045_SIZE, NULL, cookie, "7z045" } +{ xilinx_zynq, devcfg, XILINX_XC7Z045_SIZE, NULL, cookie, &zynq_op, "7z045" }
#define XILINX_XC7Z100_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z100_SIZE, NULL, cookie, "7z100" } +{ xilinx_zynq, devcfg, XILINX_XC7Z100_SIZE, NULL, cookie, &zynq_op, "7z100" }
#endif /* _ZYNQPL_H_ */ -- 1.8.2.3
Warnings: drivers/fpga/zynqpl.c:150:32: warning: Using plain integer as NULL pointer drivers/fpga/zynqpl.c:152:16: warning: Using plain integer as NULL pointer
Changes in v2: None
drivers/fpga/zynqpl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/fpga/zynqpl.c b/drivers/fpga/zynqpl.c index dcd34951ad68..0a134e524c44 100644 --- a/drivers/fpga/zynqpl.c +++ b/drivers/fpga/zynqpl.c @@ -147,9 +147,9 @@ static void *check_data(u8 *buf, size_t bsize, u32 *swap) } /* Loop can be huge - support CTRL + C */ if (ctrlc()) - return 0; + return NULL; } - return 0; + return NULL; }
static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) -- 1.8.2.3
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Use zynq_dma_xfer_init, zynq_align_dma_buffer, zynq_dma_transfer helper function performing dma transfers so that the code can be reused easily for different cases of dma transfer.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
Changes in v2: None
drivers/fpga/zynqpl.c | 201 +++++++++++++++++++++++++++++--------------------- 1 file changed, 115 insertions(+), 86 deletions(-)
diff --git a/drivers/fpga/zynqpl.c b/drivers/fpga/zynqpl.c index 0a134e524c44..ef6d1caca410 100644 --- a/drivers/fpga/zynqpl.c +++ b/drivers/fpga/zynqpl.c @@ -152,70 +152,52 @@ static void *check_data(u8 *buf, size_t bsize, u32 *swap) return NULL; }
-static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) +static int zynq_dma_transfer(u32 srcbuf, u32 srclen, u32 dstbuf, u32 dstlen) { - unsigned long ts; /* Timestamp */ - u32 partialbit = 0; - u32 i, control, isr_status, status, swap, diff; - u32 *buf_start; + unsigned long ts; + u32 isr_status;
- /* Detect if we are going working with partial or full bitstream */ - if (bsize != desc->size) { - printf("%s: Working with partial bitstream\n", __func__); - partialbit = 1; - } - - buf_start = check_data((u8 *)buf, bsize, &swap); - if (!buf_start) - return FPGA_FAIL; - - /* Check if data is postpone from start */ - diff = (u32)buf_start - (u32)buf; - if (diff) { - printf("%s: Bitstream is not validated yet (diff %x)\n", - __func__, diff); - return FPGA_FAIL; - } + /* Set up the transfer */ + writel((u32)srcbuf, &devcfg_base->dma_src_addr); + writel(dstbuf, &devcfg_base->dma_dst_addr); + writel(srclen, &devcfg_base->dma_src_len); + writel(dstlen, &devcfg_base->dma_dst_len);
- if ((u32)buf < SZ_1M) { - printf("%s: Bitstream has to be placed up to 1MB (%x)\n", - __func__, (u32)buf); - return FPGA_FAIL; - } + isr_status = readl(&devcfg_base->int_sts);
- if ((u32)buf != ALIGN((u32)buf, ARCH_DMA_MINALIGN)) { - u32 *new_buf = (u32 *)ALIGN((u32)buf, ARCH_DMA_MINALIGN); + /* Polling the PCAP_INIT status for Set */ + ts = get_timer(0); + while (!(isr_status & DEVCFG_ISR_DMA_DONE)) { + if (isr_status & DEVCFG_ISR_ERROR_FLAGS_MASK) { + debug("%s: Error: isr = 0x%08X\n", __func__, + isr_status); + debug("%s: Write count = 0x%08X\n", __func__, + readl(&devcfg_base->write_count)); + debug("%s: Read count = 0x%08X\n", __func__, + readl(&devcfg_base->read_count));
- /* - * This might be dangerous but permits to flash if - * ARCH_DMA_MINALIGN is greater than header size - */ - if (new_buf > buf_start) { - debug("%s: Aligned buffer is after buffer start\n", - __func__); - new_buf -= ARCH_DMA_MINALIGN; + return FPGA_FAIL; } + if (get_timer(ts) > CONFIG_SYS_FPGA_PROG_TIME) { + printf("%s: Timeout wait for DMA to complete\n", + __func__); + return FPGA_FAIL; + } + isr_status = readl(&devcfg_base->int_sts); + }
- printf("%s: Align buffer at %x to %x(swap %d)\n", __func__, - (u32)buf_start, (u32)new_buf, swap); - - for (i = 0; i < (bsize/4); i++) - new_buf[i] = load_word(&buf_start[i], swap); - - swap = SWAP_DONE; - buf = new_buf; - } else if (swap != SWAP_DONE) { - /* For bitstream which are aligned */ - u32 *new_buf = (u32 *)buf; + debug("%s: DMA transfer is done\n", __func__);
- printf("%s: Bitstream is not swapped(%d) - swap it\n", __func__, - swap); + /* Clear out the DMA status */ + writel(DEVCFG_ISR_DMA_DONE, &devcfg_base->int_sts);
- for (i = 0; i < (bsize/4); i++) - new_buf[i] = load_word(&buf_start[i], swap); + return FPGA_SUCCESS; +}
- swap = SWAP_DONE; - } +static int zynq_dma_xfer_init(u32 partialbit) +{ + u32 status, control, isr_status; + unsigned long ts;
/* Clear loopback bit */ clrbits_le32(&devcfg_base->mctrl, DEVCFG_MCTRL_PCAP_LPBK); @@ -297,6 +279,83 @@ static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) writel(DEVCFG_STATUS_DMA_DONE_CNT_MASK, &devcfg_base->status); }
+ return FPGA_SUCCESS; +} + +static u32 *zynq_align_dma_buffer(u32 *buf, u32 len, u32 swap) +{ + u32 *new_buf; + u32 i; + + if ((u32)buf != ALIGN((u32)buf, ARCH_DMA_MINALIGN)) { + new_buf = (u32 *)ALIGN((u32)buf, ARCH_DMA_MINALIGN); + + /* + * This might be dangerous but permits to flash if + * ARCH_DMA_MINALIGN is greater than header size + */ + if (new_buf > buf) { + debug("%s: Aligned buffer is after buffer start\n", + __func__); + new_buf -= ARCH_DMA_MINALIGN; + } + printf("%s: Align buffer at %x to %x(swap %d)\n", __func__, + (u32)buf, (u32)new_buf, swap); + + for (i = 0; i < (len/4); i++) + new_buf[i] = load_word(&buf[i], swap); + + buf = new_buf; + } else if (swap != SWAP_DONE) { + /* For bitstream which are aligned */ + u32 *new_buf = (u32 *)buf; + + printf("%s: Bitstream is not swapped(%d) - swap it\n", __func__, + swap); + + for (i = 0; i < (len/4); i++) + new_buf[i] = load_word(&buf[i], swap); + } + + return buf; +} + +static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) +{ + unsigned long ts; /* Timestamp */ + u32 partialbit = 0; + u32 isr_status, swap, diff; + u32 *buf_start; + + /* Detect if we are going working with partial or full bitstream */ + if (bsize != desc->size) { + printf("%s: Working with partial bitstream\n", __func__); + partialbit = 1; + } + + buf_start = check_data((u8 *)buf, bsize, &swap); + if (!buf_start) + return FPGA_FAIL; + + /* Check if data is postpone from start */ + diff = (u32)buf_start - (u32)buf; + if (diff) { + printf("%s: Bitstream is not validated yet (diff %x)\n", + __func__, diff); + return FPGA_FAIL; + } + + if ((u32)buf < SZ_1M) { + printf("%s: Bitstream has to be placed up to 1MB (%x)\n", + __func__, (u32)buf); + return FPGA_FAIL; + } + + if (zynq_dma_xfer_init(partialbit)) + return FPGA_FAIL; + + buf = zynq_align_dma_buffer((u32 *)buf, bsize, swap); + debug("%s: Source = 0x%08X\n", __func__, (u32)buf); debug("%s: Size = %zu\n", __func__, bsize);
@@ -304,37 +363,10 @@ static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) flush_dcache_range((u32)buf, (u32)buf + roundup(bsize, ARCH_DMA_MINALIGN));
- /* Set up the transfer */ - writel((u32)buf | 1, &devcfg_base->dma_src_addr); - writel(0xFFFFFFFF, &devcfg_base->dma_dst_addr); - writel(bsize >> 2, &devcfg_base->dma_src_len); - writel(0, &devcfg_base->dma_dst_len); + if (zynq_dma_transfer((u32)buf | 1, bsize >> 2, 0xffffffff, 0)) + return FPGA_FAIL;
isr_status = readl(&devcfg_base->int_sts); - - /* Polling the PCAP_INIT status for Set */ - ts = get_timer(0); - while (!(isr_status & DEVCFG_ISR_DMA_DONE)) { - if (isr_status & DEVCFG_ISR_ERROR_FLAGS_MASK) { - debug("%s: Error: isr = 0x%08X\n", __func__, - isr_status); - debug("%s: Write count = 0x%08X\n", __func__, - readl(&devcfg_base->write_count)); - debug("%s: Read count = 0x%08X\n", __func__, - readl(&devcfg_base->read_count)); - - return FPGA_FAIL; - } - if (get_timer(ts) > CONFIG_SYS_FPGA_PROG_TIME) { - printf("%s: Timeout wait for DMA to complete\n", - __func__); - return FPGA_FAIL; - } - isr_status = readl(&devcfg_base->int_sts); - } - - debug("%s: DMA transfer is done\n", __func__); - /* Check FPGA configuration completion */ ts = get_timer(0); while (!(isr_status & DEVCFG_ISR_PCFG_DONE)) { @@ -348,9 +380,6 @@ static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize)
debug("%s: FPGA config done\n", __func__);
- /* Clear out the DMA status */ - writel(DEVCFG_ISR_DMA_DONE, &devcfg_base->int_sts); - if (!partialbit) zynq_slcr_devcfg_enable();
-- 1.8.2.3
Use helper function zynq_validate_bitstream so that the code can be reused easily for different cases of dma transfer.
Changes in v2: None
drivers/fpga/zynqpl.c | 32 +++++++++++++++++++++++++------- 1 file changed, 25 insertions(+), 7 deletions(-)
diff --git a/drivers/fpga/zynqpl.c b/drivers/fpga/zynqpl.c index ef6d1caca410..c066f21d79f3 100644 --- a/drivers/fpga/zynqpl.c +++ b/drivers/fpga/zynqpl.c @@ -320,20 +320,20 @@ static u32 *zynq_align_dma_buffer(u32 *buf, u32 len, u32 swap) return buf; }
-static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) +static int zynq_validate_bitstream(xilinx_desc *desc, const void *buf, + size_t bsize, u32 blocksize, u32 *swap, + u32 *partialbit) { - unsigned long ts; /* Timestamp */ - u32 partialbit = 0; - u32 isr_status, swap, diff; u32 *buf_start; + u32 diff;
/* Detect if we are going working with partial or full bitstream */ if (bsize != desc->size) { printf("%s: Working with partial bitstream\n", __func__); - partialbit = 1; + *partialbit = 1; } + buf_start = check_data((u8 *)buf, blocksize, swap);
- buf_start = check_data((u8 *)buf, bsize, &swap); if (!buf_start) return FPGA_FAIL;
@@ -351,7 +351,25 @@ static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) return FPGA_FAIL; }
- if (zynq_dma_xfer_init(partialbit)) + if (zynq_dma_xfer_init(*partialbit)) + return FPGA_FAIL; + + return 0; +} + + +static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) +{ + unsigned long ts; /* Timestamp */ + u32 partialbit = 0; + u32 isr_status, swap; + + /* + * send bsize inplace of blocksize as it was not a bitstream + * in chunks + */ + if (zynq_validate_bitstream(desc, buf, bsize, bsize, &swap, + &partialbit)) return FPGA_FAIL;
buf = zynq_align_dma_buffer((u32 *)buf, bsize, swap); -- 1.8.2.3
Michal Simek
