[U-Boot-Users] kb9202 build error
hi,
i'm trying to build u-boot v1.1.6 for the kwikbyte kb9202 board. the build fails with an error message in assembly code:
make kb9202_config make CROSS_COMPILE=arm-linux- all ... arm-linux-gcc -D__ASSEMBLY__ -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x21f00000 -I/data/private/prog/embedded/kb9202/u-boot-1.1.6/include -fno-builtin -ffreestanding -nostdinc -isystem /data/private/prog/embedded/toolchains/eldk_4.1/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mabi=apcs-gnu -c -o start.o start.S start.S: Assembler messages: start.S:185: Error: invalid constant -- `sub r0,r0,#(0x0200+128*1024)' start.S:375: Error: invalid constant -- `sub r13,r13,#((32*1024)+(0x0200+128*1024))' start.S:376: Error: invalid constant -- `sub r2,r2,#((32*1024)+(0x0200+128*1024))' start.S:381: Error: invalid constant -- `sub r13,r13,#((32*1024)+(0x0200+128*1024))' start.S:382: Error: invalid constant -- `sub r2,r2,#((32*1024)+(0x0200+128*1024))' start.S:387: Error: invalid constant -- `sub r13,r13,#((32*1024)+(0x0200+128*1024))' start.S:388: Error: invalid constant -- `sub r2,r2,#((32*1024)+(0x0200+128*1024))' start.S:393: Error: invalid constant -- `sub r13,r13,#((32*1024)+(0x0200+128*1024))' start.S:394: Error: invalid constant -- `sub r2,r2,#((32*1024)+(0x0200+128*1024))' start.S:399: Error: invalid constant -- `sub r13,r13,#((32*1024)+(0x0200+128*1024))' start.S:400: Error: invalid constant -- `sub r2,r2,#((32*1024)+(0x0200+128*1024))' start.S:424: Error: invalid constant -- `sub r13,r13,#((32*1024)+(0x0200+128*1024))' start.S:425: Error: invalid constant -- `sub r2,r2,#((32*1024)+(0x0200+128*1024))' start.S:430: Error: invalid constant -- `sub r13,r13,#((32*1024)+(0x0200+128*1024))' start.S:431: Error: invalid constant -- `sub r2,r2,#((32*1024)+(0x0200+128*1024))' make[1]: *** [start.o] Error 1 make[1]: Leaving directory `/data/private/prog/embedded/kb9202/u-boot-1.1.6/cpu/arm920t' make: *** [cpu/arm920t/start.o] Error 2
the toolchain is eldk v4.1, the behaviour with eldk-uclibc v4.1 is the same. the host system is debian etch.
any idea what could be going wrong?
thanks
Matthias Kaehlcke
