[PATCH v3 0/3] Sync UDMA bindings from kernel
UDMA DT bindings have deviated from kernel's DT for AM654 and J721e. This series updates UDMA driver and sync DT bindings
Tested OSPI and CPSW on AM654 and J721e after the changes
v3: Drop unused PSIL entries in 1/3 and compile files that are required for given SoC to reduce memory footprint.
v2: Collect R-by Update patch 2/3 to note about DT incompatibility
Vignesh Raghavendra (3): dma: ti: Add static PSIL endpoint information dma: ti: k3-udma: Update driver to use static endpoint Data arm: dts: k3-am65/j721e: Sync DMA DT bindings from Kernel DT
arch/arm/dts/k3-am65-mcu.dtsi | 44 ++++++ arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 121 ++------------- .../k3-j721e-common-proc-board-u-boot.dtsi | 118 ++------------ arch/arm/dts/k3-j721e-mcu-wakeup.dtsi | 43 ++++++ drivers/dma/ti/Kconfig | 4 + drivers/dma/ti/Makefile | 4 + drivers/dma/ti/k3-psil-am654.c | 89 +++++++++++ drivers/dma/ti/k3-psil-j721e.c | 47 ++++++ drivers/dma/ti/k3-psil-priv.h | 43 ++++++ drivers/dma/ti/k3-psil.c | 42 +++++ drivers/dma/ti/k3-psil.h | 67 ++++++++ drivers/dma/ti/k3-udma.c | 145 ++++++++++++------ include/dt-bindings/dma/k3-udma.h | 31 ---- 13 files changed, 510 insertions(+), 288 deletions(-) create mode 100644 drivers/dma/ti/k3-psil-am654.c create mode 100644 drivers/dma/ti/k3-psil-j721e.c create mode 100644 drivers/dma/ti/k3-psil-priv.h create mode 100644 drivers/dma/ti/k3-psil.c create mode 100644 drivers/dma/ti/k3-psil.h delete mode 100644 include/dt-bindings/dma/k3-udma.h
Much of PSIL endpoint configuration for a given SoC can be known at compile time, therefore pass them for platform specific data instead of DT.
Add per SoC's specific PSIL endpoint data. This is to bring driver in sync with upstream DT.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Reviewed-by: Grygorii Strashko grygorii.strashko@ti.com --- drivers/dma/ti/Kconfig | 3 ++ drivers/dma/ti/Makefile | 4 ++ drivers/dma/ti/k3-psil-am654.c | 89 ++++++++++++++++++++++++++++++++++ drivers/dma/ti/k3-psil-j721e.c | 47 ++++++++++++++++++ drivers/dma/ti/k3-psil-priv.h | 43 ++++++++++++++++ drivers/dma/ti/k3-psil.c | 42 ++++++++++++++++ drivers/dma/ti/k3-psil.h | 67 +++++++++++++++++++++++++ 7 files changed, 295 insertions(+) create mode 100644 drivers/dma/ti/k3-psil-am654.c create mode 100644 drivers/dma/ti/k3-psil-j721e.c create mode 100644 drivers/dma/ti/k3-psil-priv.h create mode 100644 drivers/dma/ti/k3-psil.c create mode 100644 drivers/dma/ti/k3-psil.h
diff --git a/drivers/dma/ti/Kconfig b/drivers/dma/ti/Kconfig index 3d5498326c..9d7a1efb2b 100644 --- a/drivers/dma/ti/Kconfig +++ b/drivers/dma/ti/Kconfig @@ -12,3 +12,6 @@ config TI_K3_NAVSS_UDMA help Support for UDMA used in K3 devices. endif + +config TI_K3_PSIL + bool diff --git a/drivers/dma/ti/Makefile b/drivers/dma/ti/Makefile index de2f9ac91a..4ea9c626cc 100644 --- a/drivers/dma/ti/Makefile +++ b/drivers/dma/ti/Makefile @@ -1,3 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+
obj-$(CONFIG_TI_K3_NAVSS_UDMA) += k3-udma.o +obj-$(CONFIG_TI_K3_PSIL) += k3-psil-data.o +k3-psil-data-y += k3-psil.o +k3-psil-data-$(CONFIG_SOC_K3_AM6) += k3-psil-am654.o +k3-psil-data-$(CONFIG_SOC_K3_J721E) += k3-psil-j721e.o diff --git a/drivers/dma/ti/k3-psil-am654.c b/drivers/dma/ti/k3-psil-am654.c new file mode 100644 index 0000000000..f95d99cfd3 --- /dev/null +++ b/drivers/dma/ti/k3-psil-am654.c @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com + * Author: Peter Ujfalusi peter.ujfalusi@ti.com + */ + +#include <linux/kernel.h> + +#include "k3-psil-priv.h" + +#define PSIL_ETHERNET(x) \ + { \ + .thread_id = x, \ + .ep_config = { \ + .ep_type = PSIL_EP_NATIVE, \ + .pkt_mode = 1, \ + .needs_epib = 1, \ + .psd_size = 16, \ + }, \ + } + +/* PSI-L source thread IDs, used for RX (DMA_DEV_TO_MEM) */ +static struct psil_ep am654_src_ep_map[] = { + /* PRU_ICSSG0 */ + PSIL_ETHERNET(0x4100), + PSIL_ETHERNET(0x4101), + PSIL_ETHERNET(0x4102), + PSIL_ETHERNET(0x4103), + /* PRU_ICSSG1 */ + PSIL_ETHERNET(0x4200), + PSIL_ETHERNET(0x4201), + PSIL_ETHERNET(0x4202), + PSIL_ETHERNET(0x4203), + /* PRU_ICSSG2 */ + PSIL_ETHERNET(0x4300), + PSIL_ETHERNET(0x4301), + PSIL_ETHERNET(0x4302), + PSIL_ETHERNET(0x4303), + /* CPSW0 */ + PSIL_ETHERNET(0x7000), +}; + +/* PSI-L destination thread IDs, used for TX (DMA_MEM_TO_DEV) */ +static struct psil_ep am654_dst_ep_map[] = { + /* PRU_ICSSG0 */ + PSIL_ETHERNET(0xc100), + PSIL_ETHERNET(0xc101), + PSIL_ETHERNET(0xc102), + PSIL_ETHERNET(0xc103), + PSIL_ETHERNET(0xc104), + PSIL_ETHERNET(0xc105), + PSIL_ETHERNET(0xc106), + PSIL_ETHERNET(0xc107), + /* PRU_ICSSG1 */ + PSIL_ETHERNET(0xc200), + PSIL_ETHERNET(0xc201), + PSIL_ETHERNET(0xc202), + PSIL_ETHERNET(0xc203), + PSIL_ETHERNET(0xc204), + PSIL_ETHERNET(0xc205), + PSIL_ETHERNET(0xc206), + PSIL_ETHERNET(0xc207), + /* PRU_ICSSG2 */ + PSIL_ETHERNET(0xc300), + PSIL_ETHERNET(0xc301), + PSIL_ETHERNET(0xc302), + PSIL_ETHERNET(0xc303), + PSIL_ETHERNET(0xc304), + PSIL_ETHERNET(0xc305), + PSIL_ETHERNET(0xc306), + PSIL_ETHERNET(0xc307), + /* CPSW0 */ + PSIL_ETHERNET(0xf000), + PSIL_ETHERNET(0xf001), + PSIL_ETHERNET(0xf002), + PSIL_ETHERNET(0xf003), + PSIL_ETHERNET(0xf004), + PSIL_ETHERNET(0xf005), + PSIL_ETHERNET(0xf006), + PSIL_ETHERNET(0xf007), +}; + +struct psil_ep_map am654_ep_map = { + .name = "am654", + .src = am654_src_ep_map, + .src_count = ARRAY_SIZE(am654_src_ep_map), + .dst = am654_dst_ep_map, + .dst_count = ARRAY_SIZE(am654_dst_ep_map), +}; diff --git a/drivers/dma/ti/k3-psil-j721e.c b/drivers/dma/ti/k3-psil-j721e.c new file mode 100644 index 0000000000..105ffd946f --- /dev/null +++ b/drivers/dma/ti/k3-psil-j721e.c @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com + * Author: Peter Ujfalusi peter.ujfalusi@ti.com + */ + +#include <linux/kernel.h> + +#include "k3-psil-priv.h" + +#define PSIL_ETHERNET(x) \ + { \ + .thread_id = x, \ + .ep_config = { \ + .ep_type = PSIL_EP_NATIVE, \ + .pkt_mode = 1, \ + .needs_epib = 1, \ + .psd_size = 16, \ + }, \ + } + +/* PSI-L source thread IDs, used for RX (DMA_DEV_TO_MEM) */ +static struct psil_ep j721e_src_ep_map[] = { + /* CPSW0 */ + PSIL_ETHERNET(0x7000), +}; + +/* PSI-L destination thread IDs, used for TX (DMA_MEM_TO_DEV) */ +static struct psil_ep j721e_dst_ep_map[] = { + /* CPSW0 */ + PSIL_ETHERNET(0xf000), + PSIL_ETHERNET(0xf001), + PSIL_ETHERNET(0xf002), + PSIL_ETHERNET(0xf003), + PSIL_ETHERNET(0xf004), + PSIL_ETHERNET(0xf005), + PSIL_ETHERNET(0xf006), + PSIL_ETHERNET(0xf007), +}; + +struct psil_ep_map j721e_ep_map = { + .name = "j721e", + .src = j721e_src_ep_map, + .src_count = ARRAY_SIZE(j721e_src_ep_map), + .dst = j721e_dst_ep_map, + .dst_count = ARRAY_SIZE(j721e_dst_ep_map), +}; diff --git a/drivers/dma/ti/k3-psil-priv.h b/drivers/dma/ti/k3-psil-priv.h new file mode 100644 index 0000000000..d3a38322b1 --- /dev/null +++ b/drivers/dma/ti/k3-psil-priv.h @@ -0,0 +1,43 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com + */ + +#ifndef K3_PSIL_PRIV_H_ +#define K3_PSIL_PRIV_H_ + +#include "k3-psil.h" + +struct psil_ep { + u32 thread_id; + struct psil_endpoint_config ep_config; +}; + +/** + * struct psil_ep_map - PSI-L thread ID configuration maps + * @name: Name of the map, set it to the name of the SoC + * @src: Array of source PSI-L thread configurations + * @src_count: Number of entries in the src array + * @dst: Array of destination PSI-L thread configurations + * @dst_count: Number of entries in the dst array + * + * In case of symmetric configuration for a matching src/dst thread (for example + * 0x4400 and 0xc400) only the src configuration can be present. If no dst + * configuration found the code will look for (dst_thread_id & ~0x8000) to find + * the symmetric match. + */ +struct psil_ep_map { + char *name; + struct psil_ep *src; + int src_count; + struct psil_ep *dst; + int dst_count; +}; + +struct psil_endpoint_config *psil_get_ep_config(u32 thread_id); + +/* SoC PSI-L endpoint maps */ +extern struct psil_ep_map am654_ep_map; +extern struct psil_ep_map j721e_ep_map; + +#endif /* K3_PSIL_PRIV_H_ */ diff --git a/drivers/dma/ti/k3-psil.c b/drivers/dma/ti/k3-psil.c new file mode 100644 index 0000000000..b5c92b2829 --- /dev/null +++ b/drivers/dma/ti/k3-psil.c @@ -0,0 +1,42 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com + * Author: Peter Ujfalusi peter.ujfalusi@ti.com + */ + +#include <linux/kernel.h> +#include <linux/err.h> + +#include "k3-psil-priv.h" + +static const struct psil_ep_map *soc_ep_map; + +struct psil_endpoint_config *psil_get_ep_config(u32 thread_id) +{ + int i; + + if (!soc_ep_map) { + if (IS_ENABLED(CONFIG_SOC_K3_AM6)) + soc_ep_map = &am654_ep_map; + else if (IS_ENABLED(CONFIG_SOC_K3_J721E)) + soc_ep_map = &j721e_ep_map; + } + + if (thread_id & K3_PSIL_DST_THREAD_ID_OFFSET && soc_ep_map->dst) { + /* check in destination thread map */ + for (i = 0; i < soc_ep_map->dst_count; i++) { + if (soc_ep_map->dst[i].thread_id == thread_id) + return &soc_ep_map->dst[i].ep_config; + } + } + + thread_id &= ~K3_PSIL_DST_THREAD_ID_OFFSET; + if (soc_ep_map->src) { + for (i = 0; i < soc_ep_map->src_count; i++) { + if (soc_ep_map->src[i].thread_id == thread_id) + return &soc_ep_map->src[i].ep_config; + } + } + + return ERR_PTR(-ENOENT); +} diff --git a/drivers/dma/ti/k3-psil.h b/drivers/dma/ti/k3-psil.h new file mode 100644 index 0000000000..53c61b4595 --- /dev/null +++ b/drivers/dma/ti/k3-psil.h @@ -0,0 +1,67 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com + */ + +#ifndef K3_PSIL_H_ +#define K3_PSIL_H_ + +#include <linux/types.h> + +#define K3_PSIL_DST_THREAD_ID_OFFSET 0x8000 + +struct device; + +/** + * enum udma_tp_level - Channel Throughput Levels + * @UDMA_TP_NORMAL: Normal channel + * @UDMA_TP_HIGH: High Throughput channel + * @UDMA_TP_ULTRAHIGH: Ultra High Throughput channel + */ +enum udma_tp_level { + UDMA_TP_NORMAL = 0, + UDMA_TP_HIGH, + UDMA_TP_ULTRAHIGH, + UDMA_TP_LAST, +}; + +/** + * enum psil_endpoint_type - PSI-L Endpoint type + * @PSIL_EP_NATIVE: Normal channel + * @PSIL_EP_PDMA_XY: XY mode PDMA + * @PSIL_EP_PDMA_MCAN: MCAN mode PDMA + * @PSIL_EP_PDMA_AASRC: AASRC mode PDMA + */ +enum psil_endpoint_type { + PSIL_EP_NATIVE = 0, + PSIL_EP_PDMA_XY, + PSIL_EP_PDMA_MCAN, + PSIL_EP_PDMA_AASRC, +}; + +/** + * struct psil_endpoint_config - PSI-L Endpoint configuration + * @ep_type: PSI-L endpoint type + * @pkt_mode: If set, the channel must be in Packet mode, otherwise in + * TR mode + * @notdpkt: TDCM must be suppressed on the TX channel + * @needs_epib: Endpoint needs EPIB + * @psd_size: If set, PSdata is used by the endpoint + * @channel_tpl: Desired throughput level for the channel + * @pdma_acc32: ACC32 must be enabled on the PDMA side + * @pdma_burst: BURST must be enabled on the PDMA side + */ +struct psil_endpoint_config { + enum psil_endpoint_type ep_type; + + unsigned pkt_mode:1; + unsigned notdpkt:1; + unsigned needs_epib:1; + u32 psd_size; + enum udma_tp_level channel_tpl; + + /* PDMA properties, valid for PSIL_EP_PDMA_* */ + unsigned pdma_acc32:1; + unsigned pdma_burst:1; +}; +#endif /* K3_PSIL_H_ */
Update driver to use static PSIL endpoint Data instead of DT. This will allow DT bindings to be in sync with kernel's DT.
Note that this patch breaks networking and OSPI boot as driver changes are not backward compatible with existing DT. Subsequent commit will update the DT to make it compatible with updated driver.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Reviewed-by: Grygorii Strashko grygorii.strashko@ti.com --- drivers/dma/ti/Kconfig | 1 + drivers/dma/ti/k3-udma.c | 145 +++++++++++++++++++++++++++------------ 2 files changed, 103 insertions(+), 43 deletions(-)
diff --git a/drivers/dma/ti/Kconfig b/drivers/dma/ti/Kconfig index 9d7a1efb2b..9cbd5f334d 100644 --- a/drivers/dma/ti/Kconfig +++ b/drivers/dma/ti/Kconfig @@ -8,6 +8,7 @@ config TI_K3_NAVSS_UDMA select DMA select TI_K3_NAVSS_RINGACC select TI_K3_NAVSS_PSILCFG + select TI_K3_PSIL default n help Support for UDMA used in K3 devices. diff --git a/drivers/dma/ti/k3-udma.c b/drivers/dma/ti/k3-udma.c index 2ce16c8e27..5fc8692e19 100644 --- a/drivers/dma/ti/k3-udma.c +++ b/drivers/dma/ti/k3-udma.c @@ -22,7 +22,6 @@ #include <dma.h> #include <dma-uclass.h> #include <linux/delay.h> -#include <dt-bindings/dma/k3-udma.h> #include <linux/bitmap.h> #include <linux/err.h> #include <linux/soc/ti/k3-navss-ringacc.h> @@ -31,6 +30,7 @@ #include <linux/soc/ti/ti_sci_protocol.h>
#include "k3-udma-hwdef.h" +#include "k3-psil-priv.h"
#if BITS_PER_LONG == 64 #define RINGACC_RING_USE_PROXY (0) @@ -69,6 +69,21 @@ struct udma_rchan { struct k3_nav_ring *r_ring; /* Receive ring*/ };
+#define UDMA_FLAG_PDMA_ACC32 BIT(0) +#define UDMA_FLAG_PDMA_BURST BIT(1) +#define UDMA_FLAG_TDTYPE BIT(2) + +struct udma_match_data { + u32 psil_base; + bool enable_memcpy_support; + u32 flags; + u32 statictr_z_mask; + u32 rchan_oes_offset; + + u8 tpl_levels; + u32 level_start_idx[]; +}; + struct udma_rflow { int id; }; @@ -114,6 +129,8 @@ struct udma_dev { struct udma_rchan *rchans; struct udma_rflow *rflows;
+ struct udma_match_data *match_data; + struct udma_chan *channels; u32 psil_base;
@@ -1293,12 +1310,8 @@ static int udma_probe(struct udevice *dev) if (IS_ERR(ud->ringacc)) return PTR_ERR(ud->ringacc);
- ud->psil_base = dev_read_u32_default(dev, "ti,psil-base", 0); - if (!ud->psil_base) { - dev_info(dev, - "Missing ti,psil-base property, using %d.\n", ret); - return -EINVAL; - } + ud->match_data = (void *)dev_get_driver_data(dev); + ud->psil_base = ud->match_data->psil_base;
ret = uclass_get_device_by_phandle(UCLASS_FIRMWARE, dev, "ti,sci", &tisci_dev); @@ -1723,8 +1736,7 @@ static int udma_of_xlate(struct dma *dma, struct ofnode_phandle_args *args) { struct udma_dev *ud = dev_get_priv(dma->dev); struct udma_chan *uc = &ud->channels[0]; - ofnode chconf_node, slave_node; - char prop[50]; + struct psil_endpoint_config *ep_config; u32 val;
for (val = 0; val < ud->ch_count; val++) { @@ -1736,42 +1748,26 @@ static int udma_of_xlate(struct dma *dma, struct ofnode_phandle_args *args) if (val == ud->ch_count) return -EBUSY;
- uc->dir = DMA_DEV_TO_MEM; - if (args->args[2] == UDMA_DIR_TX) + uc->slave_thread_id = args->args[0]; + if (uc->slave_thread_id & K3_PSIL_DST_THREAD_ID_OFFSET) uc->dir = DMA_MEM_TO_DEV; + else + uc->dir = DMA_DEV_TO_MEM;
- slave_node = ofnode_get_by_phandle(args->args[0]); - if (!ofnode_valid(slave_node)) { - dev_err(ud->dev, "slave node is missing\n"); - return -EINVAL; - } - - snprintf(prop, sizeof(prop), "ti,psil-config%u", args->args[1]); - chconf_node = ofnode_find_subnode(slave_node, prop); - if (!ofnode_valid(chconf_node)) { - dev_err(ud->dev, "Channel configuration node is missing\n"); - return -EINVAL; - } - - if (!ofnode_read_u32(chconf_node, "linux,udma-mode", &val)) { - if (val == UDMA_PKT_MODE) - uc->pkt_mode = true; + ep_config = psil_get_ep_config(uc->slave_thread_id); + if (IS_ERR(ep_config)) { + dev_err(ud->dev, "No configuration for psi-l thread 0x%04x\n", + uc->slave_thread_id); + uc->dir = DMA_MEM_TO_MEM; + uc->slave_thread_id = -1; + return false; }
- if (!ofnode_read_u32(chconf_node, "statictr-type", &val)) - uc->static_tr_type = val; + uc->pkt_mode = ep_config->pkt_mode;
- uc->needs_epib = ofnode_read_bool(chconf_node, "ti,needs-epib"); - if (!ofnode_read_u32(chconf_node, "ti,psd-size", &val)) - uc->psd_size = val; - uc->metadata_size = (uc->needs_epib ? 16 : 0) + uc->psd_size; - - if (ofnode_read_u32(slave_node, "ti,psil-base", &val)) { - dev_err(ud->dev, "ti,psil-base is missing\n"); - return -EINVAL; - } - - uc->slave_thread_id = val + args->args[1]; + uc->needs_epib = ep_config->needs_epib; + uc->psd_size = ep_config->psd_size; + uc->metadata_size = (uc->needs_epib ? CPPI5_INFO0_HDESC_EPIB_SIZE : 0) + uc->psd_size;
dma->id = uc->id; pr_debug("Allocated dma chn:%lu epib:%d psdata:%u meta:%u thread_id:%x\n", @@ -1859,10 +1855,73 @@ static const struct dma_ops udma_ops = { .get_cfg = udma_get_cfg, };
+static struct udma_match_data am654_main_data = { + .psil_base = 0x1000, + .enable_memcpy_support = true, + .statictr_z_mask = GENMASK(11, 0), + .rchan_oes_offset = 0x200, + .tpl_levels = 2, + .level_start_idx = { + [0] = 8, /* Normal channels */ + [1] = 0, /* High Throughput channels */ + }, +}; + +static struct udma_match_data am654_mcu_data = { + .psil_base = 0x6000, + .enable_memcpy_support = true, + .statictr_z_mask = GENMASK(11, 0), + .rchan_oes_offset = 0x200, + .tpl_levels = 2, + .level_start_idx = { + [0] = 2, /* Normal channels */ + [1] = 0, /* High Throughput channels */ + }, +}; + +static struct udma_match_data j721e_main_data = { + .psil_base = 0x1000, + .enable_memcpy_support = true, + .flags = UDMA_FLAG_PDMA_ACC32 | UDMA_FLAG_PDMA_BURST | UDMA_FLAG_TDTYPE, + .statictr_z_mask = GENMASK(23, 0), + .rchan_oes_offset = 0x400, + .tpl_levels = 3, + .level_start_idx = { + [0] = 16, /* Normal channels */ + [1] = 4, /* High Throughput channels */ + [2] = 0, /* Ultra High Throughput channels */ + }, +}; + +static struct udma_match_data j721e_mcu_data = { + .psil_base = 0x6000, + .enable_memcpy_support = true, + .flags = UDMA_FLAG_PDMA_ACC32 | UDMA_FLAG_PDMA_BURST | UDMA_FLAG_TDTYPE, + .statictr_z_mask = GENMASK(23, 0), + .rchan_oes_offset = 0x400, + .tpl_levels = 2, + .level_start_idx = { + [0] = 2, /* Normal channels */ + [1] = 0, /* High Throughput channels */ + }, +}; + static const struct udevice_id udma_ids[] = { - { .compatible = "ti,k3-navss-udmap" }, - { .compatible = "ti,j721e-navss-mcu-udmap" }, - { } + { + .compatible = "ti,am654-navss-main-udmap", + .data = (ulong)&am654_main_data, + }, + { + .compatible = "ti,am654-navss-mcu-udmap", + .data = (ulong)&am654_mcu_data, + }, { + .compatible = "ti,j721e-navss-main-udmap", + .data = (ulong)&j721e_main_data, + }, { + .compatible = "ti,j721e-navss-mcu-udmap", + .data = (ulong)&j721e_mcu_data, + }, + { /* Sentinel */ }, };
U_BOOT_DRIVER(ti_edma3) = {
Sync DT bindings from kernel DT and move them to out of -u-boot.dtsi files.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Reviewed-by: Grygorii Strashko grygorii.strashko@ti.com --- arch/arm/dts/k3-am65-mcu.dtsi | 44 +++++++ arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 121 ++---------------- .../k3-j721e-common-proc-board-u-boot.dtsi | 118 ++--------------- arch/arm/dts/k3-j721e-mcu-wakeup.dtsi | 43 +++++++ include/dt-bindings/dma/k3-udma.h | 31 ----- 5 files changed, 112 insertions(+), 245 deletions(-) delete mode 100644 include/dt-bindings/dma/k3-udma.h
diff --git a/arch/arm/dts/k3-am65-mcu.dtsi b/arch/arm/dts/k3-am65-mcu.dtsi index bc9a87210d..d1a9fb5de6 100644 --- a/arch/arm/dts/k3-am65-mcu.dtsi +++ b/arch/arm/dts/k3-am65-mcu.dtsi @@ -102,4 +102,48 @@ #size-cells = <0>; }; }; + + mcu_navss { + compatible = "simple-mfd"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + dma-coherent; + dma-ranges; + + ti,sci-dev-id = <119>; + + mcu_ringacc: ringacc@2b800000 { + compatible = "ti,am654-navss-ringacc"; + reg = <0x0 0x2b800000 0x0 0x400000>, + <0x0 0x2b000000 0x0 0x400000>, + <0x0 0x28590000 0x0 0x100>, + <0x0 0x2a500000 0x0 0x40000>; + reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target"; + ti,num-rings = <286>; + ti,sci-rm-range-gp-rings = <0x2>; /* GP ring range */ + ti,dma-ring-reset-quirk; + ti,sci = <&dmsc>; + ti,sci-dev-id = <195>; + }; + + mcu_udmap: dma-controller@285c0000 { + compatible = "ti,am654-navss-mcu-udmap"; + reg = <0x0 0x285c0000 0x0 0x100>, + <0x0 0x2a800000 0x0 0x40000>, + <0x0 0x2aa00000 0x0 0x40000>; + reg-names = "gcfg", "rchanrt", "tchanrt"; + #dma-cells = <1>; + + ti,sci = <&dmsc>; + ti,sci-dev-id = <194>; + ti,ringacc = <&mcu_ringacc>; + + ti,sci-rm-range-tchan = <0x1>, /* TX_HCHAN */ + <0x2>; /* TX_CHAN */ + ti,sci-rm-range-rchan = <0x3>, /* RX_HCHAN */ + <0x4>; /* RX_CHAN */ + ti,sci-rm-range-rflow = <0x5>; /* GP RFLOW */ + }; + }; }; diff --git a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi index a7e5eb0553..1a40fa12b7 100644 --- a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi +++ b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi @@ -4,7 +4,6 @@ */
#include <dt-bindings/pinctrl/k3.h> -#include <dt-bindings/dma/k3-udma.h> #include <dt-bindings/net/ti-dp83867.h>
/ { @@ -47,51 +46,14 @@ &cbass_mcu { u-boot,dm-spl;
- navss_mcu: navss-mcu { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges; + mcu_navss { u-boot,dm-spl;
- ti,sci-dev-id = <119>; - - mcu_ringacc: ringacc@2b800000 { - compatible = "ti,am654-navss-ringacc"; - reg = <0x0 0x2b800000 0x0 0x400000>, - <0x0 0x2b000000 0x0 0x400000>, - <0x0 0x28590000 0x0 0x100>, - <0x0 0x2a500000 0x0 0x40000>; - reg-names = "rt", "fifos", - "proxy_gcfg", "proxy_target"; - ti,num-rings = <286>; - ti,sci-rm-range-gp-rings = <0x2>; /* GP ring range */ - ti,dma-ring-reset-quirk; - ti,sci = <&dmsc>; - ti,sci-dev-id = <195>; + ringacc@2b800000 { u-boot,dm-spl; };
- mcu_udmap: udmap@285c0000 { - compatible = "ti,k3-navss-udmap"; - reg = <0x0 0x285c0000 0x0 0x100>, - <0x0 0x2a800000 0x0 0x40000>, - <0x0 0x2aa00000 0x0 0x40000>; - reg-names = "gcfg", "rchanrt", "tchanrt"; - #dma-cells = <3>; - - ti,ringacc = <&mcu_ringacc>; - ti,psil-base = <0x6000>; - - ti,sci = <&dmsc>; - ti,sci-dev-id = <194>; - - ti,sci-rm-range-tchan = <0x1>, /* TX_HCHAN */ - <0x2>; /* TX_CHAN */ - ti,sci-rm-range-rchan = <0x3>, /* RX_HCHAN */ - <0x4>; /* RX_CHAN */ - ti,sci-rm-range-rflow = <0x5>; /* GP RFLOW */ - dma-coherent; + dma-controller@285c0000 { u-boot,dm-spl; }; }; @@ -112,17 +74,16 @@ clocks = <&k3_clks 5 10>; clock-names = "fck"; power-domains = <&k3_pds 5 TI_SCI_PD_EXCLUSIVE>; - ti,psil-base = <0x7000>; - - dmas = <&mcu_udmap &mcu_cpsw 0 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 1 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 2 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 3 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 4 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 5 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 6 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 7 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 0 UDMA_DIR_RX>; + + dmas = <&mcu_udmap 0xf000>, + <&mcu_udmap 0xf001>, + <&mcu_udmap 0xf002>, + <&mcu_udmap 0xf003>, + <&mcu_udmap 0xf004>, + <&mcu_udmap 0xf005>, + <&mcu_udmap 0xf006>, + <&mcu_udmap 0xf007>, + <&mcu_udmap 0x7000>; dma-names = "tx0", "tx1", "tx2", "tx3", "tx4", "tx5", "tx6", "tx7", "rx"; @@ -148,62 +109,6 @@ #size-cells = <0>; bus_freq = <1000000>; }; - - ti,psil-config0 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config1 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config2 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config3 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config4 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config5 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config6 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config7 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; }; };
diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index 7b01e4204f..6273133303 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -3,7 +3,6 @@ * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ */
/ { @@ -46,50 +45,14 @@ }; };
- cbass_mcu_navss: mcu_navss { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - dma-coherent; - dma-ranges; - ranges; - - ti,sci-dev-id = <232>; + mcu_navss { u-boot,dm-spl;
- mcu_ringacc: ringacc@2b800000 { - compatible = "ti,am654-navss-ringacc"; - reg = <0x0 0x2b800000 0x0 0x400000>, - <0x0 0x2b000000 0x0 0x400000>, - <0x0 0x28590000 0x0 0x100>, - <0x0 0x2a500000 0x0 0x40000>; - reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target"; - ti,num-rings = <286>; - ti,sci-rm-range-gp-rings = <0x1>; /* GP ring range */ - ti,sci = <&dmsc>; - ti,sci-dev-id = <235>; + ringacc@2b800000 { u-boot,dm-spl; };
- mcu_udmap: udmap@31150000 { - compatible = "ti,j721e-navss-mcu-udmap"; - reg = <0x0 0x285c0000 0x0 0x100>, - <0x0 0x2a800000 0x0 0x40000>, - <0x0 0x2aa00000 0x0 0x40000>; - reg-names = "gcfg", "rchanrt", "tchanrt"; - #dma-cells = <3>; - - ti,ringacc = <&mcu_ringacc>; - ti,psil-base = <0x6000>; - - ti,sci = <&dmsc>; - ti,sci-dev-id = <236>; - - ti,sci-rm-range-tchan = <0x0d>, /* TX_CHAN */ - <0x0f>; /* TX_HCHAN */ - ti,sci-rm-range-rchan = <0x0a>, /* RX_CHAN */ - <0x0b>; /* RX_HCHAN */ - ti,sci-rm-range-rflow = <0x00>; /* GP RFLOW */ + dma-controller@285c0000 { u-boot,dm-spl; }; }; @@ -105,18 +68,17 @@ clocks = <&k3_clks 18 22>; clock-names = "fck"; power-domains = <&k3_pds 18 TI_SCI_PD_EXCLUSIVE>; - ti,psil-base = <0x7000>; cpsw-phy-sel = <&phy_sel>;
- dmas = <&mcu_udmap &mcu_cpsw 0 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 1 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 2 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 3 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 4 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 5 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 6 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 7 UDMA_DIR_TX>, - <&mcu_udmap &mcu_cpsw 0 UDMA_DIR_RX>; + dmas = <&mcu_udmap 0xf000>, + <&mcu_udmap 0xf001>, + <&mcu_udmap 0xf002>, + <&mcu_udmap 0xf003>, + <&mcu_udmap 0xf004>, + <&mcu_udmap 0xf005>, + <&mcu_udmap 0xf006>, + <&mcu_udmap 0xf007>, + <&mcu_udmap 0x7000>; dma-names = "tx0", "tx1", "tx2", "tx3", "tx4", "tx5", "tx6", "tx7", "rx"; @@ -152,62 +114,6 @@ ti,cpts-ext-ts-inputs = <4>; ti,cpts-periodic-outputs = <2>; }; - - ti,psil-config0 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config1 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config2 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config3 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config4 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config5 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config6 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; - - ti,psil-config7 { - linux,udma-mode = <UDMA_PKT_MODE>; - statictr-type = <PSIL_STATIC_TR_NONE>; - ti,needs-epib; - ti,psd-size = <16>; - }; }; };
diff --git a/arch/arm/dts/k3-j721e-mcu-wakeup.dtsi b/arch/arm/dts/k3-j721e-mcu-wakeup.dtsi index 2eed50aa5a..70d5bcaa72 100644 --- a/arch/arm/dts/k3-j721e-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j721e-mcu-wakeup.dtsi @@ -199,4 +199,47 @@ clocks = <&k3_clks 195 0>; power-domains = <&k3_pds 195 TI_SCI_PD_EXCLUSIVE>; }; + + mcu_navss { + compatible = "simple-mfd"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + dma-coherent; + dma-ranges; + + ti,sci-dev-id = <232>; + + mcu_ringacc: ringacc@2b800000 { + compatible = "ti,am654-navss-ringacc"; + reg = <0x0 0x2b800000 0x0 0x400000>, + <0x0 0x2b000000 0x0 0x400000>, + <0x0 0x28590000 0x0 0x100>, + <0x0 0x2a500000 0x0 0x40000>; + reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target"; + ti,num-rings = <286>; + ti,sci-rm-range-gp-rings = <0x1>; /* GP ring range */ + ti,sci = <&dmsc>; + ti,sci-dev-id = <235>; + }; + + mcu_udmap: dma-controller@285c0000 { + compatible = "ti,j721e-navss-mcu-udmap"; + reg = <0x0 0x285c0000 0x0 0x100>, + <0x0 0x2a800000 0x0 0x40000>, + <0x0 0x2aa00000 0x0 0x40000>; + reg-names = "gcfg", "rchanrt", "tchanrt"; + #dma-cells = <1>; + + ti,sci = <&dmsc>; + ti,sci-dev-id = <236>; + ti,ringacc = <&mcu_ringacc>; + + ti,sci-rm-range-tchan = <0x0d>, /* TX_CHAN */ + <0x0f>; /* TX_HCHAN */ + ti,sci-rm-range-rchan = <0x0a>, /* RX_CHAN */ + <0x0b>; /* RX_HCHAN */ + ti,sci-rm-range-rflow = <0x00>; /* GP RFLOW */ + }; + }; }; diff --git a/include/dt-bindings/dma/k3-udma.h b/include/dt-bindings/dma/k3-udma.h deleted file mode 100644 index 670e1232b4..0000000000 --- a/include/dt-bindings/dma/k3-udma.h +++ /dev/null @@ -1,31 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com - */ - -#ifndef __DT_TI_UDMA_H -#define __DT_TI_UDMA_H - -#define UDMA_TR_MODE 0 -#define UDMA_PKT_MODE 1 - -#define UDMA_DIR_TX 0 -#define UDMA_DIR_RX 1 - -#define PSIL_STATIC_TR_NONE 0 -#define PSIL_STATIC_TR_XY 1 -#define PSIL_STATIC_TR_MCAN 2 - -#define UDMA_PDMA_TR_XY(id) \ - ti,psil-config##id { \ - linux,udma-mode = <UDMA_TR_MODE>; \ - statictr-type = <PSIL_STATIC_TR_XY>; \ - } - -#define UDMA_PDMA_PKT_XY(id) \ - ti,psil-config##id { \ - linux,udma-mode = <UDMA_PKT_MODE>; \ - statictr-type = <PSIL_STATIC_TR_XY>; \ - } - -#endif /* __DT_TI_UDMA_H */
Applied to u-boot-ti.
Thanks and regards, Lokesh
Lokesh Vutla
Vignesh Raghavendra
