[U-Boot] [PATCH 1/6] spi: kirkwood_spi.c: Add compatible match ID for Armada 375
This enables this driver for the Marvell Armada 375 SoC.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr Cc: Jagan Teki jteki@openedev.com --- drivers/spi/kirkwood_spi.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/spi/kirkwood_spi.c b/drivers/spi/kirkwood_spi.c index 7890796..80cdbd0 100644 --- a/drivers/spi/kirkwood_spi.c +++ b/drivers/spi/kirkwood_spi.c @@ -315,6 +315,7 @@ static const struct dm_spi_ops mvebu_spi_ops = { };
static const struct udevice_id mvebu_spi_ids[] = { + { .compatible = "marvell,armada-375-spi" }, { .compatible = "marvell,armada-380-spi" }, { .compatible = "marvell,armada-xp-spi" }, { }
This patch adds support for the mvpp2 ethernet controller which is integrated in the Marvell Armada 375 SoC. This port is based on the Linux driver (v4.4), which has been stripped of the in U-Boot unused portions.
Tested on the Marvell Armada 375 eval board db-88f6720.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr Cc: Joe Hershberger joe.hershberger@gmail.com --- drivers/net/Kconfig | 8 + drivers/net/Makefile | 1 + drivers/net/mvpp2.c | 4222 ++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 4231 insertions(+) create mode 100644 drivers/net/mvpp2.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index bc2f51d..bcb4c96 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -94,6 +94,14 @@ config ETH_DESIGNWARE 100Mbit and 1 Gbit operation. You must enable CONFIG_PHYLIB to provide the PHY (physical media interface).
+config MVPP2 + bool "Marvell Armada 375 network interface support" + depends on ARMADA_375 + select PHYLIB + help + This driver supports the network interface units in the + Marvell ARMADA 375 SoC. + config PCH_GBE bool "Intel Platform Controller Hub EG20T GMAC driver" depends on DM_ETH && DM_PCI diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 33a81ee..fbedd04 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -42,6 +42,7 @@ obj-$(CONFIG_MPC5xxx_FEC) += mpc5xxx_fec.o obj-$(CONFIG_MPC512x_FEC) += mpc512x_fec.o obj-$(CONFIG_MVGBE) += mvgbe.o obj-$(CONFIG_MVNETA) += mvneta.o +obj-$(CONFIG_MVPP2) += mvpp2.o obj-$(CONFIG_NATSEMI) += natsemi.o obj-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o obj-$(CONFIG_DRIVER_AX88796L) += ax88796.o ne2000_base.o diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c new file mode 100644 index 0000000..09dfc7e --- /dev/null +++ b/drivers/net/mvpp2.c @@ -0,0 +1,4222 @@ +/* + * Driver for Marvell PPv2 network controller for Armada 375 SoC. + * + * Copyright (C) 2014 Marvell + * + * Marcin Wojtas mw@semihalf.com + * + * U-Boot version: + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <net.h> +#include <netdev.h> +#include <config.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <phy.h> +#include <miiphy.h> +#include <watchdog.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <linux/compat.h> +#include <linux/mbus.h> + +DECLARE_GLOBAL_DATA_PTR; + +#if !defined(CONFIG_PHYLIB) +# error Marvell mvpp2 requires PHYLIB +#endif + +/* Some linux -> U-Boot compatibility stuff */ +#define netdev_err(dev, fmt, args...) \ + printf(fmt, ##args) +#define netdev_warn(dev, fmt, args...) \ + printf(fmt, ##args) +#define netdev_info(dev, fmt, args...) \ + printf(fmt, ##args) +#define netdev_dbg(dev, fmt, args...) \ + printf(fmt, ##args) + +#define ETH_ALEN 6 /* Octets in one ethernet addr */ + +#define ETH_P_IP 0x0800 /* Internet Protocol packet */ +#define ETH_P_PPP_SES 0x8864 /* PPPoE session messages */ +#define ETH_P_ARP 0x0806 /* Address Resolution packet */ +#define ETH_P_IPV6 0x86DD /* IPv6 over bluebook */ + +#define __verify_pcpu_ptr(ptr) \ +do { \ + const void __percpu *__vpp_verify = (typeof((ptr) + 0))NULL; \ + (void)__vpp_verify; \ +} while (0) + +#define VERIFY_PERCPU_PTR(__p) \ +({ \ + __verify_pcpu_ptr(__p); \ + (typeof(*(__p)) __kernel __force *)(__p); \ +}) + +#define per_cpu_ptr(ptr, cpu) ({ (void)(cpu); VERIFY_PERCPU_PTR(ptr); }) +#define smp_processor_id() 0 +#define num_present_cpus() 1 +#define for_each_present_cpu(cpu) \ + for ((cpu) = 0; (cpu) < 1; (cpu)++) + +#define NET_SKB_PAD max(32, MVPP2_CPU_D_CACHE_LINE_SIZE) + +#define CONFIG_NR_CPUS 1 +#define ETH_HLEN 14 /* Total octets in header */ + +/* 2(HW hdr) 14(MAC hdr) 4(CRC) 32(extra for cache prefetch) */ +#define WRAP (2 + ETH_HLEN + 4 + 32) +#define MTU 1500 +#define RX_BUFFER_SIZE (ALIGN(MTU + WRAP, ARCH_DMA_MINALIGN)) + +#define MVPP2_SMI_TIMEOUT 10000 + +/* RX Fifo Registers */ +#define MVPP2_RX_DATA_FIFO_SIZE_REG(port) (0x00 + 4 * (port)) +#define MVPP2_RX_ATTR_FIFO_SIZE_REG(port) (0x20 + 4 * (port)) +#define MVPP2_RX_MIN_PKT_SIZE_REG 0x60 +#define MVPP2_RX_FIFO_INIT_REG 0x64 + +/* RX DMA Top Registers */ +#define MVPP2_RX_CTRL_REG(port) (0x140 + 4 * (port)) +#define MVPP2_RX_LOW_LATENCY_PKT_SIZE(s) (((s) & 0xfff) << 16) +#define MVPP2_RX_USE_PSEUDO_FOR_CSUM_MASK BIT(31) +#define MVPP2_POOL_BUF_SIZE_REG(pool) (0x180 + 4 * (pool)) +#define MVPP2_POOL_BUF_SIZE_OFFSET 5 +#define MVPP2_RXQ_CONFIG_REG(rxq) (0x800 + 4 * (rxq)) +#define MVPP2_SNOOP_PKT_SIZE_MASK 0x1ff +#define MVPP2_SNOOP_BUF_HDR_MASK BIT(9) +#define MVPP2_RXQ_POOL_SHORT_OFFS 20 +#define MVPP2_RXQ_POOL_SHORT_MASK 0x700000 +#define MVPP2_RXQ_POOL_LONG_OFFS 24 +#define MVPP2_RXQ_POOL_LONG_MASK 0x7000000 +#define MVPP2_RXQ_PACKET_OFFSET_OFFS 28 +#define MVPP2_RXQ_PACKET_OFFSET_MASK 0x70000000 +#define MVPP2_RXQ_DISABLE_MASK BIT(31) + +/* Parser Registers */ +#define MVPP2_PRS_INIT_LOOKUP_REG 0x1000 +#define MVPP2_PRS_PORT_LU_MAX 0xf +#define MVPP2_PRS_PORT_LU_MASK(port) (0xff << ((port) * 4)) +#define MVPP2_PRS_PORT_LU_VAL(port, val) ((val) << ((port) * 4)) +#define MVPP2_PRS_INIT_OFFS_REG(port) (0x1004 + ((port) & 4)) +#define MVPP2_PRS_INIT_OFF_MASK(port) (0x3f << (((port) % 4) * 8)) +#define MVPP2_PRS_INIT_OFF_VAL(port, val) ((val) << (((port) % 4) * 8)) +#define MVPP2_PRS_MAX_LOOP_REG(port) (0x100c + ((port) & 4)) +#define MVPP2_PRS_MAX_LOOP_MASK(port) (0xff << (((port) % 4) * 8)) +#define MVPP2_PRS_MAX_LOOP_VAL(port, val) ((val) << (((port) % 4) * 8)) +#define MVPP2_PRS_TCAM_IDX_REG 0x1100 +#define MVPP2_PRS_TCAM_DATA_REG(idx) (0x1104 + (idx) * 4) +#define MVPP2_PRS_TCAM_INV_MASK BIT(31) +#define MVPP2_PRS_SRAM_IDX_REG 0x1200 +#define MVPP2_PRS_SRAM_DATA_REG(idx) (0x1204 + (idx) * 4) +#define MVPP2_PRS_TCAM_CTRL_REG 0x1230 +#define MVPP2_PRS_TCAM_EN_MASK BIT(0) + +/* Classifier Registers */ +#define MVPP2_CLS_MODE_REG 0x1800 +#define MVPP2_CLS_MODE_ACTIVE_MASK BIT(0) +#define MVPP2_CLS_PORT_WAY_REG 0x1810 +#define MVPP2_CLS_PORT_WAY_MASK(port) (1 << (port)) +#define MVPP2_CLS_LKP_INDEX_REG 0x1814 +#define MVPP2_CLS_LKP_INDEX_WAY_OFFS 6 +#define MVPP2_CLS_LKP_TBL_REG 0x1818 +#define MVPP2_CLS_LKP_TBL_RXQ_MASK 0xff +#define MVPP2_CLS_LKP_TBL_LOOKUP_EN_MASK BIT(25) +#define MVPP2_CLS_FLOW_INDEX_REG 0x1820 +#define MVPP2_CLS_FLOW_TBL0_REG 0x1824 +#define MVPP2_CLS_FLOW_TBL1_REG 0x1828 +#define MVPP2_CLS_FLOW_TBL2_REG 0x182c +#define MVPP2_CLS_OVERSIZE_RXQ_LOW_REG(port) (0x1980 + ((port) * 4)) +#define MVPP2_CLS_OVERSIZE_RXQ_LOW_BITS 3 +#define MVPP2_CLS_OVERSIZE_RXQ_LOW_MASK 0x7 +#define MVPP2_CLS_SWFWD_P2HQ_REG(port) (0x19b0 + ((port) * 4)) +#define MVPP2_CLS_SWFWD_PCTRL_REG 0x19d0 +#define MVPP2_CLS_SWFWD_PCTRL_MASK(port) (1 << (port)) + +/* Descriptor Manager Top Registers */ +#define MVPP2_RXQ_NUM_REG 0x2040 +#define MVPP2_RXQ_DESC_ADDR_REG 0x2044 +#define MVPP2_RXQ_DESC_SIZE_REG 0x2048 +#define MVPP2_RXQ_DESC_SIZE_MASK 0x3ff0 +#define MVPP2_RXQ_STATUS_UPDATE_REG(rxq) (0x3000 + 4 * (rxq)) +#define MVPP2_RXQ_NUM_PROCESSED_OFFSET 0 +#define MVPP2_RXQ_NUM_NEW_OFFSET 16 +#define MVPP2_RXQ_STATUS_REG(rxq) (0x3400 + 4 * (rxq)) +#define MVPP2_RXQ_OCCUPIED_MASK 0x3fff +#define MVPP2_RXQ_NON_OCCUPIED_OFFSET 16 +#define MVPP2_RXQ_NON_OCCUPIED_MASK 0x3fff0000 +#define MVPP2_RXQ_THRESH_REG 0x204c +#define MVPP2_OCCUPIED_THRESH_OFFSET 0 +#define MVPP2_OCCUPIED_THRESH_MASK 0x3fff +#define MVPP2_RXQ_INDEX_REG 0x2050 +#define MVPP2_TXQ_NUM_REG 0x2080 +#define MVPP2_TXQ_DESC_ADDR_REG 0x2084 +#define MVPP2_TXQ_DESC_SIZE_REG 0x2088 +#define MVPP2_TXQ_DESC_SIZE_MASK 0x3ff0 +#define MVPP2_AGGR_TXQ_UPDATE_REG 0x2090 +#define MVPP2_TXQ_THRESH_REG 0x2094 +#define MVPP2_TRANSMITTED_THRESH_OFFSET 16 +#define MVPP2_TRANSMITTED_THRESH_MASK 0x3fff0000 +#define MVPP2_TXQ_INDEX_REG 0x2098 +#define MVPP2_TXQ_PREF_BUF_REG 0x209c +#define MVPP2_PREF_BUF_PTR(desc) ((desc) & 0xfff) +#define MVPP2_PREF_BUF_SIZE_4 (BIT(12) | BIT(13)) +#define MVPP2_PREF_BUF_SIZE_16 (BIT(12) | BIT(14)) +#define MVPP2_PREF_BUF_THRESH(val) ((val) << 17) +#define MVPP2_TXQ_DRAIN_EN_MASK BIT(31) +#define MVPP2_TXQ_PENDING_REG 0x20a0 +#define MVPP2_TXQ_PENDING_MASK 0x3fff +#define MVPP2_TXQ_INT_STATUS_REG 0x20a4 +#define MVPP2_TXQ_SENT_REG(txq) (0x3c00 + 4 * (txq)) +#define MVPP2_TRANSMITTED_COUNT_OFFSET 16 +#define MVPP2_TRANSMITTED_COUNT_MASK 0x3fff0000 +#define MVPP2_TXQ_RSVD_REQ_REG 0x20b0 +#define MVPP2_TXQ_RSVD_REQ_Q_OFFSET 16 +#define MVPP2_TXQ_RSVD_RSLT_REG 0x20b4 +#define MVPP2_TXQ_RSVD_RSLT_MASK 0x3fff +#define MVPP2_TXQ_RSVD_CLR_REG 0x20b8 +#define MVPP2_TXQ_RSVD_CLR_OFFSET 16 +#define MVPP2_AGGR_TXQ_DESC_ADDR_REG(cpu) (0x2100 + 4 * (cpu)) +#define MVPP2_AGGR_TXQ_DESC_SIZE_REG(cpu) (0x2140 + 4 * (cpu)) +#define MVPP2_AGGR_TXQ_DESC_SIZE_MASK 0x3ff0 +#define MVPP2_AGGR_TXQ_STATUS_REG(cpu) (0x2180 + 4 * (cpu)) +#define MVPP2_AGGR_TXQ_PENDING_MASK 0x3fff +#define MVPP2_AGGR_TXQ_INDEX_REG(cpu) (0x21c0 + 4 * (cpu)) + +/* MBUS bridge registers */ +#define MVPP2_WIN_BASE(w) (0x4000 + ((w) << 2)) +#define MVPP2_WIN_SIZE(w) (0x4020 + ((w) << 2)) +#define MVPP2_WIN_REMAP(w) (0x4040 + ((w) << 2)) +#define MVPP2_BASE_ADDR_ENABLE 0x4060 + +/* Interrupt Cause and Mask registers */ +#define MVPP2_ISR_RX_THRESHOLD_REG(rxq) (0x5200 + 4 * (rxq)) +#define MVPP2_ISR_RXQ_GROUP_REG(rxq) (0x5400 + 4 * (rxq)) +#define MVPP2_ISR_ENABLE_REG(port) (0x5420 + 4 * (port)) +#define MVPP2_ISR_ENABLE_INTERRUPT(mask) ((mask) & 0xffff) +#define MVPP2_ISR_DISABLE_INTERRUPT(mask) (((mask) << 16) & 0xffff0000) +#define MVPP2_ISR_RX_TX_CAUSE_REG(port) (0x5480 + 4 * (port)) +#define MVPP2_CAUSE_RXQ_OCCUP_DESC_ALL_MASK 0xffff +#define MVPP2_CAUSE_TXQ_OCCUP_DESC_ALL_MASK 0xff0000 +#define MVPP2_CAUSE_RX_FIFO_OVERRUN_MASK BIT(24) +#define MVPP2_CAUSE_FCS_ERR_MASK BIT(25) +#define MVPP2_CAUSE_TX_FIFO_UNDERRUN_MASK BIT(26) +#define MVPP2_CAUSE_TX_EXCEPTION_SUM_MASK BIT(29) +#define MVPP2_CAUSE_RX_EXCEPTION_SUM_MASK BIT(30) +#define MVPP2_CAUSE_MISC_SUM_MASK BIT(31) +#define MVPP2_ISR_RX_TX_MASK_REG(port) (0x54a0 + 4 * (port)) +#define MVPP2_ISR_PON_RX_TX_MASK_REG 0x54bc +#define MVPP2_PON_CAUSE_RXQ_OCCUP_DESC_ALL_MASK 0xffff +#define MVPP2_PON_CAUSE_TXP_OCCUP_DESC_ALL_MASK 0x3fc00000 +#define MVPP2_PON_CAUSE_MISC_SUM_MASK BIT(31) +#define MVPP2_ISR_MISC_CAUSE_REG 0x55b0 + +/* Buffer Manager registers */ +#define MVPP2_BM_POOL_BASE_REG(pool) (0x6000 + ((pool) * 4)) +#define MVPP2_BM_POOL_BASE_ADDR_MASK 0xfffff80 +#define MVPP2_BM_POOL_SIZE_REG(pool) (0x6040 + ((pool) * 4)) +#define MVPP2_BM_POOL_SIZE_MASK 0xfff0 +#define MVPP2_BM_POOL_READ_PTR_REG(pool) (0x6080 + ((pool) * 4)) +#define MVPP2_BM_POOL_GET_READ_PTR_MASK 0xfff0 +#define MVPP2_BM_POOL_PTRS_NUM_REG(pool) (0x60c0 + ((pool) * 4)) +#define MVPP2_BM_POOL_PTRS_NUM_MASK 0xfff0 +#define MVPP2_BM_BPPI_READ_PTR_REG(pool) (0x6100 + ((pool) * 4)) +#define MVPP2_BM_BPPI_PTRS_NUM_REG(pool) (0x6140 + ((pool) * 4)) +#define MVPP2_BM_BPPI_PTR_NUM_MASK 0x7ff +#define MVPP2_BM_BPPI_PREFETCH_FULL_MASK BIT(16) +#define MVPP2_BM_POOL_CTRL_REG(pool) (0x6200 + ((pool) * 4)) +#define MVPP2_BM_START_MASK BIT(0) +#define MVPP2_BM_STOP_MASK BIT(1) +#define MVPP2_BM_STATE_MASK BIT(4) +#define MVPP2_BM_LOW_THRESH_OFFS 8 +#define MVPP2_BM_LOW_THRESH_MASK 0x7f00 +#define MVPP2_BM_LOW_THRESH_VALUE(val) ((val) << \ + MVPP2_BM_LOW_THRESH_OFFS) +#define MVPP2_BM_HIGH_THRESH_OFFS 16 +#define MVPP2_BM_HIGH_THRESH_MASK 0x7f0000 +#define MVPP2_BM_HIGH_THRESH_VALUE(val) ((val) << \ + MVPP2_BM_HIGH_THRESH_OFFS) +#define MVPP2_BM_INTR_CAUSE_REG(pool) (0x6240 + ((pool) * 4)) +#define MVPP2_BM_RELEASED_DELAY_MASK BIT(0) +#define MVPP2_BM_ALLOC_FAILED_MASK BIT(1) +#define MVPP2_BM_BPPE_EMPTY_MASK BIT(2) +#define MVPP2_BM_BPPE_FULL_MASK BIT(3) +#define MVPP2_BM_AVAILABLE_BP_LOW_MASK BIT(4) +#define MVPP2_BM_INTR_MASK_REG(pool) (0x6280 + ((pool) * 4)) +#define MVPP2_BM_PHY_ALLOC_REG(pool) (0x6400 + ((pool) * 4)) +#define MVPP2_BM_PHY_ALLOC_GRNTD_MASK BIT(0) +#define MVPP2_BM_VIRT_ALLOC_REG 0x6440 +#define MVPP2_BM_PHY_RLS_REG(pool) (0x6480 + ((pool) * 4)) +#define MVPP2_BM_PHY_RLS_MC_BUFF_MASK BIT(0) +#define MVPP2_BM_PHY_RLS_PRIO_EN_MASK BIT(1) +#define MVPP2_BM_PHY_RLS_GRNTD_MASK BIT(2) +#define MVPP2_BM_VIRT_RLS_REG 0x64c0 +#define MVPP2_BM_MC_RLS_REG 0x64c4 +#define MVPP2_BM_MC_ID_MASK 0xfff +#define MVPP2_BM_FORCE_RELEASE_MASK BIT(12) + +/* TX Scheduler registers */ +#define MVPP2_TXP_SCHED_PORT_INDEX_REG 0x8000 +#define MVPP2_TXP_SCHED_Q_CMD_REG 0x8004 +#define MVPP2_TXP_SCHED_ENQ_MASK 0xff +#define MVPP2_TXP_SCHED_DISQ_OFFSET 8 +#define MVPP2_TXP_SCHED_CMD_1_REG 0x8010 +#define MVPP2_TXP_SCHED_PERIOD_REG 0x8018 +#define MVPP2_TXP_SCHED_MTU_REG 0x801c +#define MVPP2_TXP_MTU_MAX 0x7FFFF +#define MVPP2_TXP_SCHED_REFILL_REG 0x8020 +#define MVPP2_TXP_REFILL_TOKENS_ALL_MASK 0x7ffff +#define MVPP2_TXP_REFILL_PERIOD_ALL_MASK 0x3ff00000 +#define MVPP2_TXP_REFILL_PERIOD_MASK(v) ((v) << 20) +#define MVPP2_TXP_SCHED_TOKEN_SIZE_REG 0x8024 +#define MVPP2_TXP_TOKEN_SIZE_MAX 0xffffffff +#define MVPP2_TXQ_SCHED_REFILL_REG(q) (0x8040 + ((q) << 2)) +#define MVPP2_TXQ_REFILL_TOKENS_ALL_MASK 0x7ffff +#define MVPP2_TXQ_REFILL_PERIOD_ALL_MASK 0x3ff00000 +#define MVPP2_TXQ_REFILL_PERIOD_MASK(v) ((v) << 20) +#define MVPP2_TXQ_SCHED_TOKEN_SIZE_REG(q) (0x8060 + ((q) << 2)) +#define MVPP2_TXQ_TOKEN_SIZE_MAX 0x7fffffff +#define MVPP2_TXQ_SCHED_TOKEN_CNTR_REG(q) (0x8080 + ((q) << 2)) +#define MVPP2_TXQ_TOKEN_CNTR_MAX 0xffffffff + +/* TX general registers */ +#define MVPP2_TX_SNOOP_REG 0x8800 +#define MVPP2_TX_PORT_FLUSH_REG 0x8810 +#define MVPP2_TX_PORT_FLUSH_MASK(port) (1 << (port)) + +/* LMS registers */ +#define MVPP2_SRC_ADDR_MIDDLE 0x24 +#define MVPP2_SRC_ADDR_HIGH 0x28 +#define MVPP2_PHY_AN_CFG0_REG 0x34 +#define MVPP2_PHY_AN_STOP_SMI0_MASK BIT(7) +#define MVPP2_MIB_COUNTERS_BASE(port) (0x1000 + ((port) >> 1) * \ + 0x400 + (port) * 0x400) +#define MVPP2_MIB_LATE_COLLISION 0x7c +#define MVPP2_ISR_SUM_MASK_REG 0x220c +#define MVPP2_MNG_EXTENDED_GLOBAL_CTRL_REG 0x305c +#define MVPP2_EXT_GLOBAL_CTRL_DEFAULT 0x27 + +/* Per-port registers */ +#define MVPP2_GMAC_CTRL_0_REG 0x0 +#define MVPP2_GMAC_PORT_EN_MASK BIT(0) +#define MVPP2_GMAC_MAX_RX_SIZE_OFFS 2 +#define MVPP2_GMAC_MAX_RX_SIZE_MASK 0x7ffc +#define MVPP2_GMAC_MIB_CNTR_EN_MASK BIT(15) +#define MVPP2_GMAC_CTRL_1_REG 0x4 +#define MVPP2_GMAC_PERIODIC_XON_EN_MASK BIT(1) +#define MVPP2_GMAC_GMII_LB_EN_MASK BIT(5) +#define MVPP2_GMAC_PCS_LB_EN_BIT 6 +#define MVPP2_GMAC_PCS_LB_EN_MASK BIT(6) +#define MVPP2_GMAC_SA_LOW_OFFS 7 +#define MVPP2_GMAC_CTRL_2_REG 0x8 +#define MVPP2_GMAC_INBAND_AN_MASK BIT(0) +#define MVPP2_GMAC_PCS_ENABLE_MASK BIT(3) +#define MVPP2_GMAC_PORT_RGMII_MASK BIT(4) +#define MVPP2_GMAC_PORT_RESET_MASK BIT(6) +#define MVPP2_GMAC_AUTONEG_CONFIG 0xc +#define MVPP2_GMAC_FORCE_LINK_DOWN BIT(0) +#define MVPP2_GMAC_FORCE_LINK_PASS BIT(1) +#define MVPP2_GMAC_CONFIG_MII_SPEED BIT(5) +#define MVPP2_GMAC_CONFIG_GMII_SPEED BIT(6) +#define MVPP2_GMAC_AN_SPEED_EN BIT(7) +#define MVPP2_GMAC_FC_ADV_EN BIT(9) +#define MVPP2_GMAC_CONFIG_FULL_DUPLEX BIT(12) +#define MVPP2_GMAC_AN_DUPLEX_EN BIT(13) +#define MVPP2_GMAC_PORT_FIFO_CFG_1_REG 0x1c +#define MVPP2_GMAC_TX_FIFO_MIN_TH_OFFS 6 +#define MVPP2_GMAC_TX_FIFO_MIN_TH_ALL_MASK 0x1fc0 +#define MVPP2_GMAC_TX_FIFO_MIN_TH_MASK(v) (((v) << 6) & \ + MVPP2_GMAC_TX_FIFO_MIN_TH_ALL_MASK) + +#define MVPP2_CAUSE_TXQ_SENT_DESC_ALL_MASK 0xff + +/* Descriptor ring Macros */ +#define MVPP2_QUEUE_NEXT_DESC(q, index) \ + (((index) < (q)->last_desc) ? ((index) + 1) : 0) + +/* SMI: 0xc0054 -> offset 0x54 to lms_base */ +#define MVPP2_SMI 0x0054 +#define MVPP2_PHY_REG_MASK 0x1f +/* SMI register fields */ +#define MVPP2_SMI_DATA_OFFS 0 /* Data */ +#define MVPP2_SMI_DATA_MASK (0xffff << MVPP2_SMI_DATA_OFFS) +#define MVPP2_SMI_DEV_ADDR_OFFS 16 /* PHY device address */ +#define MVPP2_SMI_REG_ADDR_OFFS 21 /* PHY device reg addr*/ +#define MVPP2_SMI_OPCODE_OFFS 26 /* Write/Read opcode */ +#define MVPP2_SMI_OPCODE_READ (1 << MVPP2_SMI_OPCODE_OFFS) +#define MVPP2_SMI_READ_VALID (1 << 27) /* Read Valid */ +#define MVPP2_SMI_BUSY (1 << 28) /* Busy */ + +#define MVPP2_PHY_ADDR_MASK 0x1f +#define MVPP2_PHY_REG_MASK 0x1f + +/* Various constants */ + +/* Coalescing */ +#define MVPP2_TXDONE_COAL_PKTS_THRESH 15 +#define MVPP2_TXDONE_HRTIMER_PERIOD_NS 1000000UL +#define MVPP2_RX_COAL_PKTS 32 +#define MVPP2_RX_COAL_USEC 100 + +/* The two bytes Marvell header. Either contains a special value used + * by Marvell switches when a specific hardware mode is enabled (not + * supported by this driver) or is filled automatically by zeroes on + * the RX side. Those two bytes being at the front of the Ethernet + * header, they allow to have the IP header aligned on a 4 bytes + * boundary automatically: the hardware skips those two bytes on its + * own. + */ +#define MVPP2_MH_SIZE 2 +#define MVPP2_ETH_TYPE_LEN 2 +#define MVPP2_PPPOE_HDR_SIZE 8 +#define MVPP2_VLAN_TAG_LEN 4 + +/* Lbtd 802.3 type */ +#define MVPP2_IP_LBDT_TYPE 0xfffa + +#define MVPP2_CPU_D_CACHE_LINE_SIZE 32 +#define MVPP2_TX_CSUM_MAX_SIZE 9800 + +/* Timeout constants */ +#define MVPP2_TX_DISABLE_TIMEOUT_MSEC 1000 +#define MVPP2_TX_PENDING_TIMEOUT_MSEC 1000 + +#define MVPP2_TX_MTU_MAX 0x7ffff + +/* Maximum number of T-CONTs of PON port */ +#define MVPP2_MAX_TCONT 16 + +/* Maximum number of supported ports */ +#define MVPP2_MAX_PORTS 4 + +/* Maximum number of TXQs used by single port */ +#define MVPP2_MAX_TXQ 8 + +/* Maximum number of RXQs used by single port */ +#define MVPP2_MAX_RXQ 8 + +/* Default number of TXQs in use */ +#define MVPP2_DEFAULT_TXQ 1 + +/* Dfault number of RXQs in use */ +#define MVPP2_DEFAULT_RXQ 1 +#define CONFIG_MV_ETH_RXQ 8 /* increment by 8 */ + +/* Total number of RXQs available to all ports */ +#define MVPP2_RXQ_TOTAL_NUM (MVPP2_MAX_PORTS * MVPP2_MAX_RXQ) + +/* Max number of Rx descriptors */ +#define MVPP2_MAX_RXD 16 + +/* Max number of Tx descriptors */ +#define MVPP2_MAX_TXD 16 + +/* Amount of Tx descriptors that can be reserved at once by CPU */ +#define MVPP2_CPU_DESC_CHUNK 64 + +/* Max number of Tx descriptors in each aggregated queue */ +#define MVPP2_AGGR_TXQ_SIZE 256 + +/* Descriptor aligned size */ +#define MVPP2_DESC_ALIGNED_SIZE 32 + +/* Descriptor alignment mask */ +#define MVPP2_TX_DESC_ALIGN (MVPP2_DESC_ALIGNED_SIZE - 1) + +/* RX FIFO constants */ +#define MVPP2_RX_FIFO_PORT_DATA_SIZE 0x2000 +#define MVPP2_RX_FIFO_PORT_ATTR_SIZE 0x80 +#define MVPP2_RX_FIFO_PORT_MIN_PKT 0x80 + +/* RX buffer constants */ +#define MVPP2_SKB_SHINFO_SIZE \ + 0 + +#define MVPP2_RX_PKT_SIZE(mtu) \ + ALIGN((mtu) + MVPP2_MH_SIZE + MVPP2_VLAN_TAG_LEN + \ + ETH_HLEN + ETH_FCS_LEN, MVPP2_CPU_D_CACHE_LINE_SIZE) + +#define MVPP2_RX_BUF_SIZE(pkt_size) ((pkt_size) + NET_SKB_PAD) +#define MVPP2_RX_TOTAL_SIZE(buf_size) ((buf_size) + MVPP2_SKB_SHINFO_SIZE) +#define MVPP2_RX_MAX_PKT_SIZE(total_size) \ + ((total_size) - NET_SKB_PAD - MVPP2_SKB_SHINFO_SIZE) + +#define MVPP2_BIT_TO_BYTE(bit) ((bit) / 8) + +/* IPv6 max L3 address size */ +#define MVPP2_MAX_L3_ADDR_SIZE 16 + +/* Port flags */ +#define MVPP2_F_LOOPBACK BIT(0) + +/* Marvell tag types */ +enum mvpp2_tag_type { + MVPP2_TAG_TYPE_NONE = 0, + MVPP2_TAG_TYPE_MH = 1, + MVPP2_TAG_TYPE_DSA = 2, + MVPP2_TAG_TYPE_EDSA = 3, + MVPP2_TAG_TYPE_VLAN = 4, + MVPP2_TAG_TYPE_LAST = 5 +}; + +/* Parser constants */ +#define MVPP2_PRS_TCAM_SRAM_SIZE 256 +#define MVPP2_PRS_TCAM_WORDS 6 +#define MVPP2_PRS_SRAM_WORDS 4 +#define MVPP2_PRS_FLOW_ID_SIZE 64 +#define MVPP2_PRS_FLOW_ID_MASK 0x3f +#define MVPP2_PRS_TCAM_ENTRY_INVALID 1 +#define MVPP2_PRS_TCAM_DSA_TAGGED_BIT BIT(5) +#define MVPP2_PRS_IPV4_HEAD 0x40 +#define MVPP2_PRS_IPV4_HEAD_MASK 0xf0 +#define MVPP2_PRS_IPV4_MC 0xe0 +#define MVPP2_PRS_IPV4_MC_MASK 0xf0 +#define MVPP2_PRS_IPV4_BC_MASK 0xff +#define MVPP2_PRS_IPV4_IHL 0x5 +#define MVPP2_PRS_IPV4_IHL_MASK 0xf +#define MVPP2_PRS_IPV6_MC 0xff +#define MVPP2_PRS_IPV6_MC_MASK 0xff +#define MVPP2_PRS_IPV6_HOP_MASK 0xff +#define MVPP2_PRS_TCAM_PROTO_MASK 0xff +#define MVPP2_PRS_TCAM_PROTO_MASK_L 0x3f +#define MVPP2_PRS_DBL_VLANS_MAX 100 + +/* Tcam structure: + * - lookup ID - 4 bits + * - port ID - 1 byte + * - additional information - 1 byte + * - header data - 8 bytes + * The fields are represented by MVPP2_PRS_TCAM_DATA_REG(5)->(0). + */ +#define MVPP2_PRS_AI_BITS 8 +#define MVPP2_PRS_PORT_MASK 0xff +#define MVPP2_PRS_LU_MASK 0xf +#define MVPP2_PRS_TCAM_DATA_BYTE(offs) \ + (((offs) - ((offs) % 2)) * 2 + ((offs) % 2)) +#define MVPP2_PRS_TCAM_DATA_BYTE_EN(offs) \ + (((offs) * 2) - ((offs) % 2) + 2) +#define MVPP2_PRS_TCAM_AI_BYTE 16 +#define MVPP2_PRS_TCAM_PORT_BYTE 17 +#define MVPP2_PRS_TCAM_LU_BYTE 20 +#define MVPP2_PRS_TCAM_EN_OFFS(offs) ((offs) + 2) +#define MVPP2_PRS_TCAM_INV_WORD 5 +/* Tcam entries ID */ +#define MVPP2_PE_DROP_ALL 0 +#define MVPP2_PE_FIRST_FREE_TID 1 +#define MVPP2_PE_LAST_FREE_TID (MVPP2_PRS_TCAM_SRAM_SIZE - 31) +#define MVPP2_PE_IP6_EXT_PROTO_UN (MVPP2_PRS_TCAM_SRAM_SIZE - 30) +#define MVPP2_PE_MAC_MC_IP6 (MVPP2_PRS_TCAM_SRAM_SIZE - 29) +#define MVPP2_PE_IP6_ADDR_UN (MVPP2_PRS_TCAM_SRAM_SIZE - 28) +#define MVPP2_PE_IP4_ADDR_UN (MVPP2_PRS_TCAM_SRAM_SIZE - 27) +#define MVPP2_PE_LAST_DEFAULT_FLOW (MVPP2_PRS_TCAM_SRAM_SIZE - 26) +#define MVPP2_PE_FIRST_DEFAULT_FLOW (MVPP2_PRS_TCAM_SRAM_SIZE - 19) +#define MVPP2_PE_EDSA_TAGGED (MVPP2_PRS_TCAM_SRAM_SIZE - 18) +#define MVPP2_PE_EDSA_UNTAGGED (MVPP2_PRS_TCAM_SRAM_SIZE - 17) +#define MVPP2_PE_DSA_TAGGED (MVPP2_PRS_TCAM_SRAM_SIZE - 16) +#define MVPP2_PE_DSA_UNTAGGED (MVPP2_PRS_TCAM_SRAM_SIZE - 15) +#define MVPP2_PE_ETYPE_EDSA_TAGGED (MVPP2_PRS_TCAM_SRAM_SIZE - 14) +#define MVPP2_PE_ETYPE_EDSA_UNTAGGED (MVPP2_PRS_TCAM_SRAM_SIZE - 13) +#define MVPP2_PE_ETYPE_DSA_TAGGED (MVPP2_PRS_TCAM_SRAM_SIZE - 12) +#define MVPP2_PE_ETYPE_DSA_UNTAGGED (MVPP2_PRS_TCAM_SRAM_SIZE - 11) +#define MVPP2_PE_MH_DEFAULT (MVPP2_PRS_TCAM_SRAM_SIZE - 10) +#define MVPP2_PE_DSA_DEFAULT (MVPP2_PRS_TCAM_SRAM_SIZE - 9) +#define MVPP2_PE_IP6_PROTO_UN (MVPP2_PRS_TCAM_SRAM_SIZE - 8) +#define MVPP2_PE_IP4_PROTO_UN (MVPP2_PRS_TCAM_SRAM_SIZE - 7) +#define MVPP2_PE_ETH_TYPE_UN (MVPP2_PRS_TCAM_SRAM_SIZE - 6) +#define MVPP2_PE_VLAN_DBL (MVPP2_PRS_TCAM_SRAM_SIZE - 5) +#define MVPP2_PE_VLAN_NONE (MVPP2_PRS_TCAM_SRAM_SIZE - 4) +#define MVPP2_PE_MAC_MC_ALL (MVPP2_PRS_TCAM_SRAM_SIZE - 3) +#define MVPP2_PE_MAC_PROMISCUOUS (MVPP2_PRS_TCAM_SRAM_SIZE - 2) +#define MVPP2_PE_MAC_NON_PROMISCUOUS (MVPP2_PRS_TCAM_SRAM_SIZE - 1) + +/* Sram structure + * The fields are represented by MVPP2_PRS_TCAM_DATA_REG(3)->(0). + */ +#define MVPP2_PRS_SRAM_RI_OFFS 0 +#define MVPP2_PRS_SRAM_RI_WORD 0 +#define MVPP2_PRS_SRAM_RI_CTRL_OFFS 32 +#define MVPP2_PRS_SRAM_RI_CTRL_WORD 1 +#define MVPP2_PRS_SRAM_RI_CTRL_BITS 32 +#define MVPP2_PRS_SRAM_SHIFT_OFFS 64 +#define MVPP2_PRS_SRAM_SHIFT_SIGN_BIT 72 +#define MVPP2_PRS_SRAM_UDF_OFFS 73 +#define MVPP2_PRS_SRAM_UDF_BITS 8 +#define MVPP2_PRS_SRAM_UDF_MASK 0xff +#define MVPP2_PRS_SRAM_UDF_SIGN_BIT 81 +#define MVPP2_PRS_SRAM_UDF_TYPE_OFFS 82 +#define MVPP2_PRS_SRAM_UDF_TYPE_MASK 0x7 +#define MVPP2_PRS_SRAM_UDF_TYPE_L3 1 +#define MVPP2_PRS_SRAM_UDF_TYPE_L4 4 +#define MVPP2_PRS_SRAM_OP_SEL_SHIFT_OFFS 85 +#define MVPP2_PRS_SRAM_OP_SEL_SHIFT_MASK 0x3 +#define MVPP2_PRS_SRAM_OP_SEL_SHIFT_ADD 1 +#define MVPP2_PRS_SRAM_OP_SEL_SHIFT_IP4_ADD 2 +#define MVPP2_PRS_SRAM_OP_SEL_SHIFT_IP6_ADD 3 +#define MVPP2_PRS_SRAM_OP_SEL_UDF_OFFS 87 +#define MVPP2_PRS_SRAM_OP_SEL_UDF_BITS 2 +#define MVPP2_PRS_SRAM_OP_SEL_UDF_MASK 0x3 +#define MVPP2_PRS_SRAM_OP_SEL_UDF_ADD 0 +#define MVPP2_PRS_SRAM_OP_SEL_UDF_IP4_ADD 2 +#define MVPP2_PRS_SRAM_OP_SEL_UDF_IP6_ADD 3 +#define MVPP2_PRS_SRAM_OP_SEL_BASE_OFFS 89 +#define MVPP2_PRS_SRAM_AI_OFFS 90 +#define MVPP2_PRS_SRAM_AI_CTRL_OFFS 98 +#define MVPP2_PRS_SRAM_AI_CTRL_BITS 8 +#define MVPP2_PRS_SRAM_AI_MASK 0xff +#define MVPP2_PRS_SRAM_NEXT_LU_OFFS 106 +#define MVPP2_PRS_SRAM_NEXT_LU_MASK 0xf +#define MVPP2_PRS_SRAM_LU_DONE_BIT 110 +#define MVPP2_PRS_SRAM_LU_GEN_BIT 111 + +/* Sram result info bits assignment */ +#define MVPP2_PRS_RI_MAC_ME_MASK 0x1 +#define MVPP2_PRS_RI_DSA_MASK 0x2 +#define MVPP2_PRS_RI_VLAN_MASK 0xc +#define MVPP2_PRS_RI_VLAN_NONE ~(BIT(2) | BIT(3)) +#define MVPP2_PRS_RI_VLAN_SINGLE BIT(2) +#define MVPP2_PRS_RI_VLAN_DOUBLE BIT(3) +#define MVPP2_PRS_RI_VLAN_TRIPLE (BIT(2) | BIT(3)) +#define MVPP2_PRS_RI_CPU_CODE_MASK 0x70 +#define MVPP2_PRS_RI_CPU_CODE_RX_SPEC BIT(4) +#define MVPP2_PRS_RI_L2_CAST_MASK 0x600 +#define MVPP2_PRS_RI_L2_UCAST ~(BIT(9) | BIT(10)) +#define MVPP2_PRS_RI_L2_MCAST BIT(9) +#define MVPP2_PRS_RI_L2_BCAST BIT(10) +#define MVPP2_PRS_RI_PPPOE_MASK 0x800 +#define MVPP2_PRS_RI_L3_PROTO_MASK 0x7000 +#define MVPP2_PRS_RI_L3_UN ~(BIT(12) | BIT(13) | BIT(14)) +#define MVPP2_PRS_RI_L3_IP4 BIT(12) +#define MVPP2_PRS_RI_L3_IP4_OPT BIT(13) +#define MVPP2_PRS_RI_L3_IP4_OTHER (BIT(12) | BIT(13)) +#define MVPP2_PRS_RI_L3_IP6 BIT(14) +#define MVPP2_PRS_RI_L3_IP6_EXT (BIT(12) | BIT(14)) +#define MVPP2_PRS_RI_L3_ARP (BIT(13) | BIT(14)) +#define MVPP2_PRS_RI_L3_ADDR_MASK 0x18000 +#define MVPP2_PRS_RI_L3_UCAST ~(BIT(15) | BIT(16)) +#define MVPP2_PRS_RI_L3_MCAST BIT(15) +#define MVPP2_PRS_RI_L3_BCAST (BIT(15) | BIT(16)) +#define MVPP2_PRS_RI_IP_FRAG_MASK 0x20000 +#define MVPP2_PRS_RI_UDF3_MASK 0x300000 +#define MVPP2_PRS_RI_UDF3_RX_SPECIAL BIT(21) +#define MVPP2_PRS_RI_L4_PROTO_MASK 0x1c00000 +#define MVPP2_PRS_RI_L4_TCP BIT(22) +#define MVPP2_PRS_RI_L4_UDP BIT(23) +#define MVPP2_PRS_RI_L4_OTHER (BIT(22) | BIT(23)) +#define MVPP2_PRS_RI_UDF7_MASK 0x60000000 +#define MVPP2_PRS_RI_UDF7_IP6_LITE BIT(29) +#define MVPP2_PRS_RI_DROP_MASK 0x80000000 + +/* Sram additional info bits assignment */ +#define MVPP2_PRS_IPV4_DIP_AI_BIT BIT(0) +#define MVPP2_PRS_IPV6_NO_EXT_AI_BIT BIT(0) +#define MVPP2_PRS_IPV6_EXT_AI_BIT BIT(1) +#define MVPP2_PRS_IPV6_EXT_AH_AI_BIT BIT(2) +#define MVPP2_PRS_IPV6_EXT_AH_LEN_AI_BIT BIT(3) +#define MVPP2_PRS_IPV6_EXT_AH_L4_AI_BIT BIT(4) +#define MVPP2_PRS_SINGLE_VLAN_AI 0 +#define MVPP2_PRS_DBL_VLAN_AI_BIT BIT(7) + +/* DSA/EDSA type */ +#define MVPP2_PRS_TAGGED true +#define MVPP2_PRS_UNTAGGED false +#define MVPP2_PRS_EDSA true +#define MVPP2_PRS_DSA false + +/* MAC entries, shadow udf */ +enum mvpp2_prs_udf { + MVPP2_PRS_UDF_MAC_DEF, + MVPP2_PRS_UDF_MAC_RANGE, + MVPP2_PRS_UDF_L2_DEF, + MVPP2_PRS_UDF_L2_DEF_COPY, + MVPP2_PRS_UDF_L2_USER, +}; + +/* Lookup ID */ +enum mvpp2_prs_lookup { + MVPP2_PRS_LU_MH, + MVPP2_PRS_LU_MAC, + MVPP2_PRS_LU_DSA, + MVPP2_PRS_LU_VLAN, + MVPP2_PRS_LU_L2, + MVPP2_PRS_LU_PPPOE, + MVPP2_PRS_LU_IP4, + MVPP2_PRS_LU_IP6, + MVPP2_PRS_LU_FLOWS, + MVPP2_PRS_LU_LAST, +}; + +/* L3 cast enum */ +enum mvpp2_prs_l3_cast { + MVPP2_PRS_L3_UNI_CAST, + MVPP2_PRS_L3_MULTI_CAST, + MVPP2_PRS_L3_BROAD_CAST +}; + +/* Classifier constants */ +#define MVPP2_CLS_FLOWS_TBL_SIZE 512 +#define MVPP2_CLS_FLOWS_TBL_DATA_WORDS 3 +#define MVPP2_CLS_LKP_TBL_SIZE 64 + +/* BM constants */ +#define MVPP2_BM_POOLS_NUM 1 +#define MVPP2_BM_LONG_BUF_NUM 16 +#define MVPP2_BM_SHORT_BUF_NUM 16 +#define MVPP2_BM_POOL_SIZE_MAX (16*1024 - MVPP2_BM_POOL_PTR_ALIGN/4) +#define MVPP2_BM_POOL_PTR_ALIGN 128 +#define MVPP2_BM_SWF_LONG_POOL(port) 0 + +/* BM cookie (32 bits) definition */ +#define MVPP2_BM_COOKIE_POOL_OFFS 8 +#define MVPP2_BM_COOKIE_CPU_OFFS 24 + +/* BM short pool packet size + * These value assure that for SWF the total number + * of bytes allocated for each buffer will be 512 + */ +#define MVPP2_BM_SHORT_PKT_SIZE MVPP2_RX_MAX_PKT_SIZE(512) + +enum mvpp2_bm_type { + MVPP2_BM_FREE, + MVPP2_BM_SWF_LONG, + MVPP2_BM_SWF_SHORT +}; + +/* Definitions */ + +/* Shared Packet Processor resources */ +struct mvpp2 { + /* Shared registers' base addresses */ + void __iomem *base; + void __iomem *lms_base; + + /* List of pointers to port structures */ + struct mvpp2_port **port_list; + + /* Aggregated TXQs */ + struct mvpp2_tx_queue *aggr_txqs; + + /* BM pools */ + struct mvpp2_bm_pool *bm_pools; + + /* PRS shadow table */ + struct mvpp2_prs_shadow *prs_shadow; + /* PRS auxiliary table for double vlan entries control */ + bool *prs_double_vlans; + + /* Tclk value */ + u32 tclk; + + struct mii_dev *bus; +}; + +struct mvpp2_pcpu_stats { + u64 rx_packets; + u64 rx_bytes; + u64 tx_packets; + u64 tx_bytes; +}; + +struct mvpp2_port { + u8 id; + + int irq; + + struct mvpp2 *priv; + + /* Per-port registers' base address */ + void __iomem *base; + + struct mvpp2_rx_queue **rxqs; + struct mvpp2_tx_queue **txqs; + + int pkt_size; + + u32 pending_cause_rx; + + /* Per-CPU port control */ + struct mvpp2_port_pcpu __percpu *pcpu; + + /* Flags */ + unsigned long flags; + + u16 tx_ring_size; + u16 rx_ring_size; + struct mvpp2_pcpu_stats __percpu *stats; + + struct phy_device *phy_dev; + phy_interface_t phy_interface; + int phy_node; + int phyaddr; + int init; + unsigned int link; + unsigned int duplex; + unsigned int speed; + + struct mvpp2_bm_pool *pool_long; + struct mvpp2_bm_pool *pool_short; + + /* Index of first port's physical RXQ */ + u8 first_rxq; + + u8 dev_addr[ETH_ALEN]; +}; + +/* The mvpp2_tx_desc and mvpp2_rx_desc structures describe the + * layout of the transmit and reception DMA descriptors, and their + * layout is therefore defined by the hardware design + */ + +#define MVPP2_TXD_L3_OFF_SHIFT 0 +#define MVPP2_TXD_IP_HLEN_SHIFT 8 +#define MVPP2_TXD_L4_CSUM_FRAG BIT(13) +#define MVPP2_TXD_L4_CSUM_NOT BIT(14) +#define MVPP2_TXD_IP_CSUM_DISABLE BIT(15) +#define MVPP2_TXD_PADDING_DISABLE BIT(23) +#define MVPP2_TXD_L4_UDP BIT(24) +#define MVPP2_TXD_L3_IP6 BIT(26) +#define MVPP2_TXD_L_DESC BIT(28) +#define MVPP2_TXD_F_DESC BIT(29) + +#define MVPP2_RXD_ERR_SUMMARY BIT(15) +#define MVPP2_RXD_ERR_CODE_MASK (BIT(13) | BIT(14)) +#define MVPP2_RXD_ERR_CRC 0x0 +#define MVPP2_RXD_ERR_OVERRUN BIT(13) +#define MVPP2_RXD_ERR_RESOURCE (BIT(13) | BIT(14)) +#define MVPP2_RXD_BM_POOL_ID_OFFS 16 +#define MVPP2_RXD_BM_POOL_ID_MASK (BIT(16) | BIT(17) | BIT(18)) +#define MVPP2_RXD_HWF_SYNC BIT(21) +#define MVPP2_RXD_L4_CSUM_OK BIT(22) +#define MVPP2_RXD_IP4_HEADER_ERR BIT(24) +#define MVPP2_RXD_L4_TCP BIT(25) +#define MVPP2_RXD_L4_UDP BIT(26) +#define MVPP2_RXD_L3_IP4 BIT(28) +#define MVPP2_RXD_L3_IP6 BIT(30) +#define MVPP2_RXD_BUF_HDR BIT(31) + +struct mvpp2_tx_desc { + u32 command; /* Options used by HW for packet transmitting.*/ + u8 packet_offset; /* the offset from the buffer beginning */ + u8 phys_txq; /* destination queue ID */ + u16 data_size; /* data size of transmitted packet in bytes */ + u32 buf_phys_addr; /* physical addr of transmitted buffer */ + u32 buf_cookie; /* cookie for access to TX buffer in tx path */ + u32 reserved1[3]; /* hw_cmd (for future use, BM, PON, PNC) */ + u32 reserved2; /* reserved (for future use) */ +}; + +struct mvpp2_rx_desc { + u32 status; /* info about received packet */ + u16 reserved1; /* parser_info (for future use, PnC) */ + u16 data_size; /* size of received packet in bytes */ + u32 buf_phys_addr; /* physical address of the buffer */ + u32 buf_cookie; /* cookie for access to RX buffer in rx path */ + u16 reserved2; /* gem_port_id (for future use, PON) */ + u16 reserved3; /* csum_l4 (for future use, PnC) */ + u8 reserved4; /* bm_qset (for future use, BM) */ + u8 reserved5; + u16 reserved6; /* classify_info (for future use, PnC) */ + u32 reserved7; /* flow_id (for future use, PnC) */ + u32 reserved8; +}; + +/* Per-CPU Tx queue control */ +struct mvpp2_txq_pcpu { + int cpu; + + /* Number of Tx DMA descriptors in the descriptor ring */ + int size; + + /* Number of currently used Tx DMA descriptor in the + * descriptor ring + */ + int count; + + /* Number of Tx DMA descriptors reserved for each CPU */ + int reserved_num; + + /* Index of last TX DMA descriptor that was inserted */ + int txq_put_index; + + /* Index of the TX DMA descriptor to be cleaned up */ + int txq_get_index; +}; + +struct mvpp2_tx_queue { + /* Physical number of this Tx queue */ + u8 id; + + /* Logical number of this Tx queue */ + u8 log_id; + + /* Number of Tx DMA descriptors in the descriptor ring */ + int size; + + /* Number of currently used Tx DMA descriptor in the descriptor ring */ + int count; + + /* Per-CPU control of physical Tx queues */ + struct mvpp2_txq_pcpu __percpu *pcpu; + + u32 done_pkts_coal; + + /* Virtual address of thex Tx DMA descriptors array */ + struct mvpp2_tx_desc *descs; + + /* DMA address of the Tx DMA descriptors array */ + dma_addr_t descs_phys; + + /* Index of the last Tx DMA descriptor */ + int last_desc; + + /* Index of the next Tx DMA descriptor to process */ + int next_desc_to_proc; +}; + +struct mvpp2_rx_queue { + /* RX queue number, in the range 0-31 for physical RXQs */ + u8 id; + + /* Num of rx descriptors in the rx descriptor ring */ + int size; + + u32 pkts_coal; + u32 time_coal; + + /* Virtual address of the RX DMA descriptors array */ + struct mvpp2_rx_desc *descs; + + /* DMA address of the RX DMA descriptors array */ + dma_addr_t descs_phys; + + /* Index of the last RX DMA descriptor */ + int last_desc; + + /* Index of the next RX DMA descriptor to process */ + int next_desc_to_proc; + + /* ID of port to which physical RXQ is mapped */ + int port; + + /* Port's logic RXQ number to which physical RXQ is mapped */ + int logic_rxq; +}; + +union mvpp2_prs_tcam_entry { + u32 word[MVPP2_PRS_TCAM_WORDS]; + u8 byte[MVPP2_PRS_TCAM_WORDS * 4]; +}; + +union mvpp2_prs_sram_entry { + u32 word[MVPP2_PRS_SRAM_WORDS]; + u8 byte[MVPP2_PRS_SRAM_WORDS * 4]; +}; + +struct mvpp2_prs_entry { + u32 index; + union mvpp2_prs_tcam_entry tcam; + union mvpp2_prs_sram_entry sram; +}; + +struct mvpp2_prs_shadow { + bool valid; + bool finish; + + /* Lookup ID */ + int lu; + + /* User defined offset */ + int udf; + + /* Result info */ + u32 ri; + u32 ri_mask; +}; + +struct mvpp2_cls_flow_entry { + u32 index; + u32 data[MVPP2_CLS_FLOWS_TBL_DATA_WORDS]; +}; + +struct mvpp2_cls_lookup_entry { + u32 lkpid; + u32 way; + u32 data; +}; + +struct mvpp2_bm_pool { + /* Pool number in the range 0-7 */ + int id; + enum mvpp2_bm_type type; + + /* Buffer Pointers Pool External (BPPE) size */ + int size; + /* Number of buffers for this pool */ + int buf_num; + /* Pool buffer size */ + int buf_size; + /* Packet size */ + int pkt_size; + + /* BPPE virtual base address */ + u32 *virt_addr; + /* BPPE physical base address */ + dma_addr_t phys_addr; + + /* Ports using BM pool */ + u32 port_map; + + /* Occupied buffers indicator */ + int in_use_thresh; +}; + +struct mvpp2_buff_hdr { + u32 next_buff_phys_addr; + u32 next_buff_virt_addr; + u16 byte_count; + u16 info; + u8 reserved1; /* bm_qset (for future use, BM) */ +}; + +/* Buffer header info bits */ +#define MVPP2_B_HDR_INFO_MC_ID_MASK 0xfff +#define MVPP2_B_HDR_INFO_MC_ID(info) ((info) & MVPP2_B_HDR_INFO_MC_ID_MASK) +#define MVPP2_B_HDR_INFO_LAST_OFFS 12 +#define MVPP2_B_HDR_INFO_LAST_MASK BIT(12) +#define MVPP2_B_HDR_INFO_IS_LAST(info) \ + ((info & MVPP2_B_HDR_INFO_LAST_MASK) >> MVPP2_B_HDR_INFO_LAST_OFFS) + +/* Static declaractions */ + +/* Number of RXQs used by single port */ +static int rxq_number = MVPP2_DEFAULT_RXQ; +/* Number of TXQs used by single port */ +static int txq_number = MVPP2_DEFAULT_TXQ; + +#define MVPP2_DRIVER_NAME "mvpp2" +#define MVPP2_DRIVER_VERSION "1.0" + +/* + * U-Boot internal data, mostly uncached buffers for descriptors and data + */ +struct buffer_location { + struct mvpp2_tx_desc *aggr_tx_descs; + struct mvpp2_tx_desc *tx_descs; + struct mvpp2_rx_desc *rx_descs; + u32 *bm_pool[MVPP2_BM_POOLS_NUM]; + u32 *rx_buffer[MVPP2_BM_LONG_BUF_NUM]; + struct mvpp2 *priv; + int first_rxq; +}; + +/* + * All 4 interfaces use the same global buffer, since only one interface + * can be enabled at once + */ +static struct buffer_location buffer_loc; + +/* + * Page table entries are set to 1MB, or multiples of 1MB + * (not < 1MB). driver uses less bd's so use 1MB bdspace. + */ +#define BD_SPACE (1 << 20) + +/* Utility/helper methods */ + +static void mvpp2_write(struct mvpp2 *priv, u32 offset, u32 data) +{ + writel(data, priv->base + offset); +} + +static u32 mvpp2_read(struct mvpp2 *priv, u32 offset) +{ + return readl(priv->base + offset); +} + +static void mvpp2_txq_inc_get(struct mvpp2_txq_pcpu *txq_pcpu) +{ + txq_pcpu->txq_get_index++; + if (txq_pcpu->txq_get_index == txq_pcpu->size) + txq_pcpu->txq_get_index = 0; +} + +/* Get number of physical egress port */ +static inline int mvpp2_egress_port(struct mvpp2_port *port) +{ + return MVPP2_MAX_TCONT + port->id; +} + +/* Get number of physical TXQ */ +static inline int mvpp2_txq_phys(int port, int txq) +{ + return (MVPP2_MAX_TCONT + port) * MVPP2_MAX_TXQ + txq; +} + +/* Parser configuration routines */ + +/* Update parser tcam and sram hw entries */ +static int mvpp2_prs_hw_write(struct mvpp2 *priv, struct mvpp2_prs_entry *pe) +{ + int i; + + if (pe->index > MVPP2_PRS_TCAM_SRAM_SIZE - 1) + return -EINVAL; + + /* Clear entry invalidation bit */ + pe->tcam.word[MVPP2_PRS_TCAM_INV_WORD] &= ~MVPP2_PRS_TCAM_INV_MASK; + + /* Write tcam index - indirect access */ + mvpp2_write(priv, MVPP2_PRS_TCAM_IDX_REG, pe->index); + for (i = 0; i < MVPP2_PRS_TCAM_WORDS; i++) + mvpp2_write(priv, MVPP2_PRS_TCAM_DATA_REG(i), pe->tcam.word[i]); + + /* Write sram index - indirect access */ + mvpp2_write(priv, MVPP2_PRS_SRAM_IDX_REG, pe->index); + for (i = 0; i < MVPP2_PRS_SRAM_WORDS; i++) + mvpp2_write(priv, MVPP2_PRS_SRAM_DATA_REG(i), pe->sram.word[i]); + + return 0; +} + +/* Read tcam entry from hw */ +static int mvpp2_prs_hw_read(struct mvpp2 *priv, struct mvpp2_prs_entry *pe) +{ + int i; + + if (pe->index > MVPP2_PRS_TCAM_SRAM_SIZE - 1) + return -EINVAL; + + /* Write tcam index - indirect access */ + mvpp2_write(priv, MVPP2_PRS_TCAM_IDX_REG, pe->index); + + pe->tcam.word[MVPP2_PRS_TCAM_INV_WORD] = mvpp2_read(priv, + MVPP2_PRS_TCAM_DATA_REG(MVPP2_PRS_TCAM_INV_WORD)); + if (pe->tcam.word[MVPP2_PRS_TCAM_INV_WORD] & MVPP2_PRS_TCAM_INV_MASK) + return MVPP2_PRS_TCAM_ENTRY_INVALID; + + for (i = 0; i < MVPP2_PRS_TCAM_WORDS; i++) + pe->tcam.word[i] = mvpp2_read(priv, MVPP2_PRS_TCAM_DATA_REG(i)); + + /* Write sram index - indirect access */ + mvpp2_write(priv, MVPP2_PRS_SRAM_IDX_REG, pe->index); + for (i = 0; i < MVPP2_PRS_SRAM_WORDS; i++) + pe->sram.word[i] = mvpp2_read(priv, MVPP2_PRS_SRAM_DATA_REG(i)); + + return 0; +} + +/* Invalidate tcam hw entry */ +static void mvpp2_prs_hw_inv(struct mvpp2 *priv, int index) +{ + /* Write index - indirect access */ + mvpp2_write(priv, MVPP2_PRS_TCAM_IDX_REG, index); + mvpp2_write(priv, MVPP2_PRS_TCAM_DATA_REG(MVPP2_PRS_TCAM_INV_WORD), + MVPP2_PRS_TCAM_INV_MASK); +} + +/* Enable shadow table entry and set its lookup ID */ +static void mvpp2_prs_shadow_set(struct mvpp2 *priv, int index, int lu) +{ + priv->prs_shadow[index].valid = true; + priv->prs_shadow[index].lu = lu; +} + +/* Update ri fields in shadow table entry */ +static void mvpp2_prs_shadow_ri_set(struct mvpp2 *priv, int index, + unsigned int ri, unsigned int ri_mask) +{ + priv->prs_shadow[index].ri_mask = ri_mask; + priv->prs_shadow[index].ri = ri; +} + +/* Update lookup field in tcam sw entry */ +static void mvpp2_prs_tcam_lu_set(struct mvpp2_prs_entry *pe, unsigned int lu) +{ + int enable_off = MVPP2_PRS_TCAM_EN_OFFS(MVPP2_PRS_TCAM_LU_BYTE); + + pe->tcam.byte[MVPP2_PRS_TCAM_LU_BYTE] = lu; + pe->tcam.byte[enable_off] = MVPP2_PRS_LU_MASK; +} + +/* Update mask for single port in tcam sw entry */ +static void mvpp2_prs_tcam_port_set(struct mvpp2_prs_entry *pe, + unsigned int port, bool add) +{ + int enable_off = MVPP2_PRS_TCAM_EN_OFFS(MVPP2_PRS_TCAM_PORT_BYTE); + + if (add) + pe->tcam.byte[enable_off] &= ~(1 << port); + else + pe->tcam.byte[enable_off] |= 1 << port; +} + +/* Update port map in tcam sw entry */ +static void mvpp2_prs_tcam_port_map_set(struct mvpp2_prs_entry *pe, + unsigned int ports) +{ + unsigned char port_mask = MVPP2_PRS_PORT_MASK; + int enable_off = MVPP2_PRS_TCAM_EN_OFFS(MVPP2_PRS_TCAM_PORT_BYTE); + + pe->tcam.byte[MVPP2_PRS_TCAM_PORT_BYTE] = 0; + pe->tcam.byte[enable_off] &= ~port_mask; + pe->tcam.byte[enable_off] |= ~ports & MVPP2_PRS_PORT_MASK; +} + +/* Obtain port map from tcam sw entry */ +static unsigned int mvpp2_prs_tcam_port_map_get(struct mvpp2_prs_entry *pe) +{ + int enable_off = MVPP2_PRS_TCAM_EN_OFFS(MVPP2_PRS_TCAM_PORT_BYTE); + + return ~(pe->tcam.byte[enable_off]) & MVPP2_PRS_PORT_MASK; +} + +/* Set byte of data and its enable bits in tcam sw entry */ +static void mvpp2_prs_tcam_data_byte_set(struct mvpp2_prs_entry *pe, + unsigned int offs, unsigned char byte, + unsigned char enable) +{ + pe->tcam.byte[MVPP2_PRS_TCAM_DATA_BYTE(offs)] = byte; + pe->tcam.byte[MVPP2_PRS_TCAM_DATA_BYTE_EN(offs)] = enable; +} + +/* Get byte of data and its enable bits from tcam sw entry */ +static void mvpp2_prs_tcam_data_byte_get(struct mvpp2_prs_entry *pe, + unsigned int offs, unsigned char *byte, + unsigned char *enable) +{ + *byte = pe->tcam.byte[MVPP2_PRS_TCAM_DATA_BYTE(offs)]; + *enable = pe->tcam.byte[MVPP2_PRS_TCAM_DATA_BYTE_EN(offs)]; +} + +/* Set ethertype in tcam sw entry */ +static void mvpp2_prs_match_etype(struct mvpp2_prs_entry *pe, int offset, + unsigned short ethertype) +{ + mvpp2_prs_tcam_data_byte_set(pe, offset + 0, ethertype >> 8, 0xff); + mvpp2_prs_tcam_data_byte_set(pe, offset + 1, ethertype & 0xff, 0xff); +} + +/* Set bits in sram sw entry */ +static void mvpp2_prs_sram_bits_set(struct mvpp2_prs_entry *pe, int bit_num, + int val) +{ + pe->sram.byte[MVPP2_BIT_TO_BYTE(bit_num)] |= (val << (bit_num % 8)); +} + +/* Clear bits in sram sw entry */ +static void mvpp2_prs_sram_bits_clear(struct mvpp2_prs_entry *pe, int bit_num, + int val) +{ + pe->sram.byte[MVPP2_BIT_TO_BYTE(bit_num)] &= ~(val << (bit_num % 8)); +} + +/* Update ri bits in sram sw entry */ +static void mvpp2_prs_sram_ri_update(struct mvpp2_prs_entry *pe, + unsigned int bits, unsigned int mask) +{ + unsigned int i; + + for (i = 0; i < MVPP2_PRS_SRAM_RI_CTRL_BITS; i++) { + int ri_off = MVPP2_PRS_SRAM_RI_OFFS; + + if (!(mask & BIT(i))) + continue; + + if (bits & BIT(i)) + mvpp2_prs_sram_bits_set(pe, ri_off + i, 1); + else + mvpp2_prs_sram_bits_clear(pe, ri_off + i, 1); + + mvpp2_prs_sram_bits_set(pe, MVPP2_PRS_SRAM_RI_CTRL_OFFS + i, 1); + } +} + +/* Update ai bits in sram sw entry */ +static void mvpp2_prs_sram_ai_update(struct mvpp2_prs_entry *pe, + unsigned int bits, unsigned int mask) +{ + unsigned int i; + int ai_off = MVPP2_PRS_SRAM_AI_OFFS; + + for (i = 0; i < MVPP2_PRS_SRAM_AI_CTRL_BITS; i++) { + + if (!(mask & BIT(i))) + continue; + + if (bits & BIT(i)) + mvpp2_prs_sram_bits_set(pe, ai_off + i, 1); + else + mvpp2_prs_sram_bits_clear(pe, ai_off + i, 1); + + mvpp2_prs_sram_bits_set(pe, MVPP2_PRS_SRAM_AI_CTRL_OFFS + i, 1); + } +} + +/* Read ai bits from sram sw entry */ +static int mvpp2_prs_sram_ai_get(struct mvpp2_prs_entry *pe) +{ + u8 bits; + int ai_off = MVPP2_BIT_TO_BYTE(MVPP2_PRS_SRAM_AI_OFFS); + int ai_en_off = ai_off + 1; + int ai_shift = MVPP2_PRS_SRAM_AI_OFFS % 8; + + bits = (pe->sram.byte[ai_off] >> ai_shift) | + (pe->sram.byte[ai_en_off] << (8 - ai_shift)); + + return bits; +} + +/* In sram sw entry set lookup ID field of the tcam key to be used in the next + * lookup interation + */ +static void mvpp2_prs_sram_next_lu_set(struct mvpp2_prs_entry *pe, + unsigned int lu) +{ + int sram_next_off = MVPP2_PRS_SRAM_NEXT_LU_OFFS; + + mvpp2_prs_sram_bits_clear(pe, sram_next_off, + MVPP2_PRS_SRAM_NEXT_LU_MASK); + mvpp2_prs_sram_bits_set(pe, sram_next_off, lu); +} + +/* In the sram sw entry set sign and value of the next lookup offset + * and the offset value generated to the classifier + */ +static void mvpp2_prs_sram_shift_set(struct mvpp2_prs_entry *pe, int shift, + unsigned int op) +{ + /* Set sign */ + if (shift < 0) { + mvpp2_prs_sram_bits_set(pe, MVPP2_PRS_SRAM_SHIFT_SIGN_BIT, 1); + shift = 0 - shift; + } else { + mvpp2_prs_sram_bits_clear(pe, MVPP2_PRS_SRAM_SHIFT_SIGN_BIT, 1); + } + + /* Set value */ + pe->sram.byte[MVPP2_BIT_TO_BYTE(MVPP2_PRS_SRAM_SHIFT_OFFS)] = + (unsigned char)shift; + + /* Reset and set operation */ + mvpp2_prs_sram_bits_clear(pe, MVPP2_PRS_SRAM_OP_SEL_SHIFT_OFFS, + MVPP2_PRS_SRAM_OP_SEL_SHIFT_MASK); + mvpp2_prs_sram_bits_set(pe, MVPP2_PRS_SRAM_OP_SEL_SHIFT_OFFS, op); + + /* Set base offset as current */ + mvpp2_prs_sram_bits_clear(pe, MVPP2_PRS_SRAM_OP_SEL_BASE_OFFS, 1); +} + +/* In the sram sw entry set sign and value of the user defined offset + * generated to the classifier + */ +static void mvpp2_prs_sram_offset_set(struct mvpp2_prs_entry *pe, + unsigned int type, int offset, + unsigned int op) +{ + /* Set sign */ + if (offset < 0) { + mvpp2_prs_sram_bits_set(pe, MVPP2_PRS_SRAM_UDF_SIGN_BIT, 1); + offset = 0 - offset; + } else { + mvpp2_prs_sram_bits_clear(pe, MVPP2_PRS_SRAM_UDF_SIGN_BIT, 1); + } + + /* Set value */ + mvpp2_prs_sram_bits_clear(pe, MVPP2_PRS_SRAM_UDF_OFFS, + MVPP2_PRS_SRAM_UDF_MASK); + mvpp2_prs_sram_bits_set(pe, MVPP2_PRS_SRAM_UDF_OFFS, offset); + pe->sram.byte[MVPP2_BIT_TO_BYTE(MVPP2_PRS_SRAM_UDF_OFFS + + MVPP2_PRS_SRAM_UDF_BITS)] &= + ~(MVPP2_PRS_SRAM_UDF_MASK >> (8 - (MVPP2_PRS_SRAM_UDF_OFFS % 8))); + pe->sram.byte[MVPP2_BIT_TO_BYTE(MVPP2_PRS_SRAM_UDF_OFFS + + MVPP2_PRS_SRAM_UDF_BITS)] |= + (offset >> (8 - (MVPP2_PRS_SRAM_UDF_OFFS % 8))); + + /* Set offset type */ + mvpp2_prs_sram_bits_clear(pe, MVPP2_PRS_SRAM_UDF_TYPE_OFFS, + MVPP2_PRS_SRAM_UDF_TYPE_MASK); + mvpp2_prs_sram_bits_set(pe, MVPP2_PRS_SRAM_UDF_TYPE_OFFS, type); + + /* Set offset operation */ + mvpp2_prs_sram_bits_clear(pe, MVPP2_PRS_SRAM_OP_SEL_UDF_OFFS, + MVPP2_PRS_SRAM_OP_SEL_UDF_MASK); + mvpp2_prs_sram_bits_set(pe, MVPP2_PRS_SRAM_OP_SEL_UDF_OFFS, op); + + pe->sram.byte[MVPP2_BIT_TO_BYTE(MVPP2_PRS_SRAM_OP_SEL_UDF_OFFS + + MVPP2_PRS_SRAM_OP_SEL_UDF_BITS)] &= + ~(MVPP2_PRS_SRAM_OP_SEL_UDF_MASK >> + (8 - (MVPP2_PRS_SRAM_OP_SEL_UDF_OFFS % 8))); + + pe->sram.byte[MVPP2_BIT_TO_BYTE(MVPP2_PRS_SRAM_OP_SEL_UDF_OFFS + + MVPP2_PRS_SRAM_OP_SEL_UDF_BITS)] |= + (op >> (8 - (MVPP2_PRS_SRAM_OP_SEL_UDF_OFFS % 8))); + + /* Set base offset as current */ + mvpp2_prs_sram_bits_clear(pe, MVPP2_PRS_SRAM_OP_SEL_BASE_OFFS, 1); +} + +/* Find parser flow entry */ +static struct mvpp2_prs_entry *mvpp2_prs_flow_find(struct mvpp2 *priv, int flow) +{ + struct mvpp2_prs_entry *pe; + int tid; + + pe = kzalloc(sizeof(*pe), GFP_KERNEL); + if (!pe) + return NULL; + mvpp2_prs_tcam_lu_set(pe, MVPP2_PRS_LU_FLOWS); + + /* Go through the all entires with MVPP2_PRS_LU_FLOWS */ + for (tid = MVPP2_PRS_TCAM_SRAM_SIZE - 1; tid >= 0; tid--) { + u8 bits; + + if (!priv->prs_shadow[tid].valid || + priv->prs_shadow[tid].lu != MVPP2_PRS_LU_FLOWS) + continue; + + pe->index = tid; + mvpp2_prs_hw_read(priv, pe); + bits = mvpp2_prs_sram_ai_get(pe); + + /* Sram store classification lookup ID in AI bits [5:0] */ + if ((bits & MVPP2_PRS_FLOW_ID_MASK) == flow) + return pe; + } + kfree(pe); + + return NULL; +} + +/* Return first free tcam index, seeking from start to end */ +static int mvpp2_prs_tcam_first_free(struct mvpp2 *priv, unsigned char start, + unsigned char end) +{ + int tid; + + if (start > end) + swap(start, end); + + if (end >= MVPP2_PRS_TCAM_SRAM_SIZE) + end = MVPP2_PRS_TCAM_SRAM_SIZE - 1; + + for (tid = start; tid <= end; tid++) { + if (!priv->prs_shadow[tid].valid) + return tid; + } + + return -EINVAL; +} + +/* Enable/disable dropping all mac da's */ +static void mvpp2_prs_mac_drop_all_set(struct mvpp2 *priv, int port, bool add) +{ + struct mvpp2_prs_entry pe; + + if (priv->prs_shadow[MVPP2_PE_DROP_ALL].valid) { + /* Entry exist - update port only */ + pe.index = MVPP2_PE_DROP_ALL; + mvpp2_prs_hw_read(priv, &pe); + } else { + /* Entry doesn't exist - create new */ + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_MAC); + pe.index = MVPP2_PE_DROP_ALL; + + /* Non-promiscuous mode for all ports - DROP unknown packets */ + mvpp2_prs_sram_ri_update(&pe, MVPP2_PRS_RI_DROP_MASK, + MVPP2_PRS_RI_DROP_MASK); + + mvpp2_prs_sram_bits_set(&pe, MVPP2_PRS_SRAM_LU_GEN_BIT, 1); + mvpp2_prs_sram_next_lu_set(&pe, MVPP2_PRS_LU_FLOWS); + + /* Update shadow table */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_MAC); + + /* Mask all ports */ + mvpp2_prs_tcam_port_map_set(&pe, 0); + } + + /* Update port mask */ + mvpp2_prs_tcam_port_set(&pe, port, add); + + mvpp2_prs_hw_write(priv, &pe); +} + +/* Set port to promiscuous mode */ +static void mvpp2_prs_mac_promisc_set(struct mvpp2 *priv, int port, bool add) +{ + struct mvpp2_prs_entry pe; + + /* Promiscuous mode - Accept unknown packets */ + + if (priv->prs_shadow[MVPP2_PE_MAC_PROMISCUOUS].valid) { + /* Entry exist - update port only */ + pe.index = MVPP2_PE_MAC_PROMISCUOUS; + mvpp2_prs_hw_read(priv, &pe); + } else { + /* Entry doesn't exist - create new */ + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_MAC); + pe.index = MVPP2_PE_MAC_PROMISCUOUS; + + /* Continue - set next lookup */ + mvpp2_prs_sram_next_lu_set(&pe, MVPP2_PRS_LU_DSA); + + /* Set result info bits */ + mvpp2_prs_sram_ri_update(&pe, MVPP2_PRS_RI_L2_UCAST, + MVPP2_PRS_RI_L2_CAST_MASK); + + /* Shift to ethertype */ + mvpp2_prs_sram_shift_set(&pe, 2 * ETH_ALEN, + MVPP2_PRS_SRAM_OP_SEL_SHIFT_ADD); + + /* Mask all ports */ + mvpp2_prs_tcam_port_map_set(&pe, 0); + + /* Update shadow table */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_MAC); + } + + /* Update port mask */ + mvpp2_prs_tcam_port_set(&pe, port, add); + + mvpp2_prs_hw_write(priv, &pe); +} + +/* Accept multicast */ +static void mvpp2_prs_mac_multi_set(struct mvpp2 *priv, int port, int index, + bool add) +{ + struct mvpp2_prs_entry pe; + unsigned char da_mc; + + /* Ethernet multicast address first byte is + * 0x01 for IPv4 and 0x33 for IPv6 + */ + da_mc = (index == MVPP2_PE_MAC_MC_ALL) ? 0x01 : 0x33; + + if (priv->prs_shadow[index].valid) { + /* Entry exist - update port only */ + pe.index = index; + mvpp2_prs_hw_read(priv, &pe); + } else { + /* Entry doesn't exist - create new */ + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_MAC); + pe.index = index; + + /* Continue - set next lookup */ + mvpp2_prs_sram_next_lu_set(&pe, MVPP2_PRS_LU_DSA); + + /* Set result info bits */ + mvpp2_prs_sram_ri_update(&pe, MVPP2_PRS_RI_L2_MCAST, + MVPP2_PRS_RI_L2_CAST_MASK); + + /* Update tcam entry data first byte */ + mvpp2_prs_tcam_data_byte_set(&pe, 0, da_mc, 0xff); + + /* Shift to ethertype */ + mvpp2_prs_sram_shift_set(&pe, 2 * ETH_ALEN, + MVPP2_PRS_SRAM_OP_SEL_SHIFT_ADD); + + /* Mask all ports */ + mvpp2_prs_tcam_port_map_set(&pe, 0); + + /* Update shadow table */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_MAC); + } + + /* Update port mask */ + mvpp2_prs_tcam_port_set(&pe, port, add); + + mvpp2_prs_hw_write(priv, &pe); +} + +/* Parser per-port initialization */ +static void mvpp2_prs_hw_port_init(struct mvpp2 *priv, int port, int lu_first, + int lu_max, int offset) +{ + u32 val; + + /* Set lookup ID */ + val = mvpp2_read(priv, MVPP2_PRS_INIT_LOOKUP_REG); + val &= ~MVPP2_PRS_PORT_LU_MASK(port); + val |= MVPP2_PRS_PORT_LU_VAL(port, lu_first); + mvpp2_write(priv, MVPP2_PRS_INIT_LOOKUP_REG, val); + + /* Set maximum number of loops for packet received from port */ + val = mvpp2_read(priv, MVPP2_PRS_MAX_LOOP_REG(port)); + val &= ~MVPP2_PRS_MAX_LOOP_MASK(port); + val |= MVPP2_PRS_MAX_LOOP_VAL(port, lu_max); + mvpp2_write(priv, MVPP2_PRS_MAX_LOOP_REG(port), val); + + /* Set initial offset for packet header extraction for the first + * searching loop + */ + val = mvpp2_read(priv, MVPP2_PRS_INIT_OFFS_REG(port)); + val &= ~MVPP2_PRS_INIT_OFF_MASK(port); + val |= MVPP2_PRS_INIT_OFF_VAL(port, offset); + mvpp2_write(priv, MVPP2_PRS_INIT_OFFS_REG(port), val); +} + +/* Default flow entries initialization for all ports */ +static void mvpp2_prs_def_flow_init(struct mvpp2 *priv) +{ + struct mvpp2_prs_entry pe; + int port; + + for (port = 0; port < MVPP2_MAX_PORTS; port++) { + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_FLOWS); + pe.index = MVPP2_PE_FIRST_DEFAULT_FLOW - port; + + /* Mask all ports */ + mvpp2_prs_tcam_port_map_set(&pe, 0); + + /* Set flow ID*/ + mvpp2_prs_sram_ai_update(&pe, port, MVPP2_PRS_FLOW_ID_MASK); + mvpp2_prs_sram_bits_set(&pe, MVPP2_PRS_SRAM_LU_DONE_BIT, 1); + + /* Update shadow table and hw entry */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_FLOWS); + mvpp2_prs_hw_write(priv, &pe); + } +} + +/* Set default entry for Marvell Header field */ +static void mvpp2_prs_mh_init(struct mvpp2 *priv) +{ + struct mvpp2_prs_entry pe; + + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + + pe.index = MVPP2_PE_MH_DEFAULT; + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_MH); + mvpp2_prs_sram_shift_set(&pe, MVPP2_MH_SIZE, + MVPP2_PRS_SRAM_OP_SEL_SHIFT_ADD); + mvpp2_prs_sram_next_lu_set(&pe, MVPP2_PRS_LU_MAC); + + /* Unmask all ports */ + mvpp2_prs_tcam_port_map_set(&pe, MVPP2_PRS_PORT_MASK); + + /* Update shadow table and hw entry */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_MH); + mvpp2_prs_hw_write(priv, &pe); +} + +/* Set default entires (place holder) for promiscuous, non-promiscuous and + * multicast MAC addresses + */ +static void mvpp2_prs_mac_init(struct mvpp2 *priv) +{ + struct mvpp2_prs_entry pe; + + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + + /* Non-promiscuous mode for all ports - DROP unknown packets */ + pe.index = MVPP2_PE_MAC_NON_PROMISCUOUS; + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_MAC); + + mvpp2_prs_sram_ri_update(&pe, MVPP2_PRS_RI_DROP_MASK, + MVPP2_PRS_RI_DROP_MASK); + mvpp2_prs_sram_bits_set(&pe, MVPP2_PRS_SRAM_LU_GEN_BIT, 1); + mvpp2_prs_sram_next_lu_set(&pe, MVPP2_PRS_LU_FLOWS); + + /* Unmask all ports */ + mvpp2_prs_tcam_port_map_set(&pe, MVPP2_PRS_PORT_MASK); + + /* Update shadow table and hw entry */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_MAC); + mvpp2_prs_hw_write(priv, &pe); + + /* place holders only - no ports */ + mvpp2_prs_mac_drop_all_set(priv, 0, false); + mvpp2_prs_mac_promisc_set(priv, 0, false); + mvpp2_prs_mac_multi_set(priv, MVPP2_PE_MAC_MC_ALL, 0, false); + mvpp2_prs_mac_multi_set(priv, MVPP2_PE_MAC_MC_IP6, 0, false); +} + +/* Match basic ethertypes */ +static int mvpp2_prs_etype_init(struct mvpp2 *priv) +{ + struct mvpp2_prs_entry pe; + int tid; + + /* Ethertype: PPPoE */ + tid = mvpp2_prs_tcam_first_free(priv, MVPP2_PE_FIRST_FREE_TID, + MVPP2_PE_LAST_FREE_TID); + if (tid < 0) + return tid; + + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_L2); + pe.index = tid; + + mvpp2_prs_match_etype(&pe, 0, ETH_P_PPP_SES); + + mvpp2_prs_sram_shift_set(&pe, MVPP2_PPPOE_HDR_SIZE, + MVPP2_PRS_SRAM_OP_SEL_SHIFT_ADD); + mvpp2_prs_sram_next_lu_set(&pe, MVPP2_PRS_LU_PPPOE); + mvpp2_prs_sram_ri_update(&pe, MVPP2_PRS_RI_PPPOE_MASK, + MVPP2_PRS_RI_PPPOE_MASK); + + /* Update shadow table and hw entry */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_L2); + priv->prs_shadow[pe.index].udf = MVPP2_PRS_UDF_L2_DEF; + priv->prs_shadow[pe.index].finish = false; + mvpp2_prs_shadow_ri_set(priv, pe.index, MVPP2_PRS_RI_PPPOE_MASK, + MVPP2_PRS_RI_PPPOE_MASK); + mvpp2_prs_hw_write(priv, &pe); + + /* Ethertype: ARP */ + tid = mvpp2_prs_tcam_first_free(priv, MVPP2_PE_FIRST_FREE_TID, + MVPP2_PE_LAST_FREE_TID); + if (tid < 0) + return tid; + + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_L2); + pe.index = tid; + + mvpp2_prs_match_etype(&pe, 0, ETH_P_ARP); + + /* Generate flow in the next iteration*/ + mvpp2_prs_sram_next_lu_set(&pe, MVPP2_PRS_LU_FLOWS); + mvpp2_prs_sram_bits_set(&pe, MVPP2_PRS_SRAM_LU_GEN_BIT, 1); + mvpp2_prs_sram_ri_update(&pe, MVPP2_PRS_RI_L3_ARP, + MVPP2_PRS_RI_L3_PROTO_MASK); + /* Set L3 offset */ + mvpp2_prs_sram_offset_set(&pe, MVPP2_PRS_SRAM_UDF_TYPE_L3, + MVPP2_ETH_TYPE_LEN, + MVPP2_PRS_SRAM_OP_SEL_UDF_ADD); + + /* Update shadow table and hw entry */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_L2); + priv->prs_shadow[pe.index].udf = MVPP2_PRS_UDF_L2_DEF; + priv->prs_shadow[pe.index].finish = true; + mvpp2_prs_shadow_ri_set(priv, pe.index, MVPP2_PRS_RI_L3_ARP, + MVPP2_PRS_RI_L3_PROTO_MASK); + mvpp2_prs_hw_write(priv, &pe); + + /* Ethertype: LBTD */ + tid = mvpp2_prs_tcam_first_free(priv, MVPP2_PE_FIRST_FREE_TID, + MVPP2_PE_LAST_FREE_TID); + if (tid < 0) + return tid; + + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_L2); + pe.index = tid; + + mvpp2_prs_match_etype(&pe, 0, MVPP2_IP_LBDT_TYPE); + + /* Generate flow in the next iteration*/ + mvpp2_prs_sram_next_lu_set(&pe, MVPP2_PRS_LU_FLOWS); + mvpp2_prs_sram_bits_set(&pe, MVPP2_PRS_SRAM_LU_GEN_BIT, 1); + mvpp2_prs_sram_ri_update(&pe, MVPP2_PRS_RI_CPU_CODE_RX_SPEC | + MVPP2_PRS_RI_UDF3_RX_SPECIAL, + MVPP2_PRS_RI_CPU_CODE_MASK | + MVPP2_PRS_RI_UDF3_MASK); + /* Set L3 offset */ + mvpp2_prs_sram_offset_set(&pe, MVPP2_PRS_SRAM_UDF_TYPE_L3, + MVPP2_ETH_TYPE_LEN, + MVPP2_PRS_SRAM_OP_SEL_UDF_ADD); + + /* Update shadow table and hw entry */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_L2); + priv->prs_shadow[pe.index].udf = MVPP2_PRS_UDF_L2_DEF; + priv->prs_shadow[pe.index].finish = true; + mvpp2_prs_shadow_ri_set(priv, pe.index, MVPP2_PRS_RI_CPU_CODE_RX_SPEC | + MVPP2_PRS_RI_UDF3_RX_SPECIAL, + MVPP2_PRS_RI_CPU_CODE_MASK | + MVPP2_PRS_RI_UDF3_MASK); + mvpp2_prs_hw_write(priv, &pe); + + /* Ethertype: IPv4 without options */ + tid = mvpp2_prs_tcam_first_free(priv, MVPP2_PE_FIRST_FREE_TID, + MVPP2_PE_LAST_FREE_TID); + if (tid < 0) + return tid; + + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_L2); + pe.index = tid; + + mvpp2_prs_match_etype(&pe, 0, ETH_P_IP); + mvpp2_prs_tcam_data_byte_set(&pe, MVPP2_ETH_TYPE_LEN, + MVPP2_PRS_IPV4_HEAD | MVPP2_PRS_IPV4_IHL, + MVPP2_PRS_IPV4_HEAD_MASK | + MVPP2_PRS_IPV4_IHL_MASK); + + mvpp2_prs_sram_next_lu_set(&pe, MVPP2_PRS_LU_IP4); + mvpp2_prs_sram_ri_update(&pe, MVPP2_PRS_RI_L3_IP4, + MVPP2_PRS_RI_L3_PROTO_MASK); + /* Skip eth_type + 4 bytes of IP header */ + mvpp2_prs_sram_shift_set(&pe, MVPP2_ETH_TYPE_LEN + 4, + MVPP2_PRS_SRAM_OP_SEL_SHIFT_ADD); + /* Set L3 offset */ + mvpp2_prs_sram_offset_set(&pe, MVPP2_PRS_SRAM_UDF_TYPE_L3, + MVPP2_ETH_TYPE_LEN, + MVPP2_PRS_SRAM_OP_SEL_UDF_ADD); + + /* Update shadow table and hw entry */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_L2); + priv->prs_shadow[pe.index].udf = MVPP2_PRS_UDF_L2_DEF; + priv->prs_shadow[pe.index].finish = false; + mvpp2_prs_shadow_ri_set(priv, pe.index, MVPP2_PRS_RI_L3_IP4, + MVPP2_PRS_RI_L3_PROTO_MASK); + mvpp2_prs_hw_write(priv, &pe); + + /* Ethertype: IPv4 with options */ + tid = mvpp2_prs_tcam_first_free(priv, MVPP2_PE_FIRST_FREE_TID, + MVPP2_PE_LAST_FREE_TID); + if (tid < 0) + return tid; + + pe.index = tid; + + /* Clear tcam data before updating */ + pe.tcam.byte[MVPP2_PRS_TCAM_DATA_BYTE(MVPP2_ETH_TYPE_LEN)] = 0x0; + pe.tcam.byte[MVPP2_PRS_TCAM_DATA_BYTE_EN(MVPP2_ETH_TYPE_LEN)] = 0x0; + + mvpp2_prs_tcam_data_byte_set(&pe, MVPP2_ETH_TYPE_LEN, + MVPP2_PRS_IPV4_HEAD, + MVPP2_PRS_IPV4_HEAD_MASK); + + /* Clear ri before updating */ + pe.sram.word[MVPP2_PRS_SRAM_RI_WORD] = 0x0; + pe.sram.word[MVPP2_PRS_SRAM_RI_CTRL_WORD] = 0x0; + mvpp2_prs_sram_ri_update(&pe, MVPP2_PRS_RI_L3_IP4_OPT, + MVPP2_PRS_RI_L3_PROTO_MASK); + + /* Update shadow table and hw entry */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_L2); + priv->prs_shadow[pe.index].udf = MVPP2_PRS_UDF_L2_DEF; + priv->prs_shadow[pe.index].finish = false; + mvpp2_prs_shadow_ri_set(priv, pe.index, MVPP2_PRS_RI_L3_IP4_OPT, + MVPP2_PRS_RI_L3_PROTO_MASK); + mvpp2_prs_hw_write(priv, &pe); + + /* Ethertype: IPv6 without options */ + tid = mvpp2_prs_tcam_first_free(priv, MVPP2_PE_FIRST_FREE_TID, + MVPP2_PE_LAST_FREE_TID); + if (tid < 0) + return tid; + + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_L2); + pe.index = tid; + + mvpp2_prs_match_etype(&pe, 0, ETH_P_IPV6); + + /* Skip DIP of IPV6 header */ + mvpp2_prs_sram_shift_set(&pe, MVPP2_ETH_TYPE_LEN + 8 + + MVPP2_MAX_L3_ADDR_SIZE, + MVPP2_PRS_SRAM_OP_SEL_SHIFT_ADD); + mvpp2_prs_sram_next_lu_set(&pe, MVPP2_PRS_LU_IP6); + mvpp2_prs_sram_ri_update(&pe, MVPP2_PRS_RI_L3_IP6, + MVPP2_PRS_RI_L3_PROTO_MASK); + /* Set L3 offset */ + mvpp2_prs_sram_offset_set(&pe, MVPP2_PRS_SRAM_UDF_TYPE_L3, + MVPP2_ETH_TYPE_LEN, + MVPP2_PRS_SRAM_OP_SEL_UDF_ADD); + + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_L2); + priv->prs_shadow[pe.index].udf = MVPP2_PRS_UDF_L2_DEF; + priv->prs_shadow[pe.index].finish = false; + mvpp2_prs_shadow_ri_set(priv, pe.index, MVPP2_PRS_RI_L3_IP6, + MVPP2_PRS_RI_L3_PROTO_MASK); + mvpp2_prs_hw_write(priv, &pe); + + /* Default entry for MVPP2_PRS_LU_L2 - Unknown ethtype */ + memset(&pe, 0, sizeof(struct mvpp2_prs_entry)); + mvpp2_prs_tcam_lu_set(&pe, MVPP2_PRS_LU_L2); + pe.index = MVPP2_PE_ETH_TYPE_UN; + + /* Unmask all ports */ + mvpp2_prs_tcam_port_map_set(&pe, MVPP2_PRS_PORT_MASK); + + /* Generate flow in the next iteration*/ + mvpp2_prs_sram_bits_set(&pe, MVPP2_PRS_SRAM_LU_GEN_BIT, 1); + mvpp2_prs_sram_next_lu_set(&pe, MVPP2_PRS_LU_FLOWS); + mvpp2_prs_sram_ri_update(&pe, MVPP2_PRS_RI_L3_UN, + MVPP2_PRS_RI_L3_PROTO_MASK); + /* Set L3 offset even it's unknown L3 */ + mvpp2_prs_sram_offset_set(&pe, MVPP2_PRS_SRAM_UDF_TYPE_L3, + MVPP2_ETH_TYPE_LEN, + MVPP2_PRS_SRAM_OP_SEL_UDF_ADD); + + /* Update shadow table and hw entry */ + mvpp2_prs_shadow_set(priv, pe.index, MVPP2_PRS_LU_L2); + priv->prs_shadow[pe.index].udf = MVPP2_PRS_UDF_L2_DEF; + priv->prs_shadow[pe.index].finish = true; + mvpp2_prs_shadow_ri_set(priv, pe.index, MVPP2_PRS_RI_L3_UN, + MVPP2_PRS_RI_L3_PROTO_MASK); + mvpp2_prs_hw_write(priv, &pe); + + return 0; +} + +/* Parser default initialization */ +static int mvpp2_prs_default_init(struct udevice *dev, + struct mvpp2 *priv) +{ + int err, index, i; + + /* Enable tcam table */ + mvpp2_write(priv, MVPP2_PRS_TCAM_CTRL_REG, MVPP2_PRS_TCAM_EN_MASK); + + /* Clear all tcam and sram entries */ + for (index = 0; index < MVPP2_PRS_TCAM_SRAM_SIZE; index++) { + mvpp2_write(priv, MVPP2_PRS_TCAM_IDX_REG, index); + for (i = 0; i < MVPP2_PRS_TCAM_WORDS; i++) + mvpp2_write(priv, MVPP2_PRS_TCAM_DATA_REG(i), 0); + + mvpp2_write(priv, MVPP2_PRS_SRAM_IDX_REG, index); + for (i = 0; i < MVPP2_PRS_SRAM_WORDS; i++) + mvpp2_write(priv, MVPP2_PRS_SRAM_DATA_REG(i), 0); + } + + /* Invalidate all tcam entries */ + for (index = 0; index < MVPP2_PRS_TCAM_SRAM_SIZE; index++) + mvpp2_prs_hw_inv(priv, index); + + priv->prs_shadow = devm_kcalloc(dev, MVPP2_PRS_TCAM_SRAM_SIZE, + sizeof(struct mvpp2_prs_shadow), + GFP_KERNEL); + if (!priv->prs_shadow) + return -ENOMEM; + + /* Always start from lookup = 0 */ + for (index = 0; index < MVPP2_MAX_PORTS; index++) + mvpp2_prs_hw_port_init(priv, index, MVPP2_PRS_LU_MH, + MVPP2_PRS_PORT_LU_MAX, 0); + + mvpp2_prs_def_flow_init(priv); + + mvpp2_prs_mh_init(priv); + + mvpp2_prs_mac_init(priv); + + err = mvpp2_prs_etype_init(priv); + if (err) + return err; + + return 0; +} + +/* Compare MAC DA with tcam entry data */ +static bool mvpp2_prs_mac_range_equals(struct mvpp2_prs_entry *pe, + const u8 *da, unsigned char *mask) +{ + unsigned char tcam_byte, tcam_mask; + int index; + + for (index = 0; index < ETH_ALEN; index++) { + mvpp2_prs_tcam_data_byte_get(pe, index, &tcam_byte, &tcam_mask); + if (tcam_mask != mask[index]) + return false; + + if ((tcam_mask & tcam_byte) != (da[index] & mask[index])) + return false; + } + + return true; +} + +/* Find tcam entry with matched pair <MAC DA, port> */ +static struct mvpp2_prs_entry * +mvpp2_prs_mac_da_range_find(struct mvpp2 *priv, int pmap, const u8 *da, + unsigned char *mask, int udf_type) +{ + struct mvpp2_prs_entry *pe; + int tid; + + pe = kzalloc(sizeof(*pe), GFP_KERNEL); + if (!pe) + return NULL; + mvpp2_prs_tcam_lu_set(pe, MVPP2_PRS_LU_MAC); + + /* Go through the all entires with MVPP2_PRS_LU_MAC */ + for (tid = MVPP2_PE_FIRST_FREE_TID; + tid <= MVPP2_PE_LAST_FREE_TID; tid++) { + unsigned int entry_pmap; + + if (!priv->prs_shadow[tid].valid || + (priv->prs_shadow[tid].lu != MVPP2_PRS_LU_MAC) || + (priv->prs_shadow[tid].udf != udf_type)) + continue; + + pe->index = tid; + mvpp2_prs_hw_read(priv, pe); + entry_pmap = mvpp2_prs_tcam_port_map_get(pe); + + if (mvpp2_prs_mac_range_equals(pe, da, mask) && + entry_pmap == pmap) + return pe; + } + kfree(pe); + + return NULL; +} + +/* Update parser's mac da entry */ +static int mvpp2_prs_mac_da_accept(struct mvpp2 *priv, int port, + const u8 *da, bool add) +{ + struct mvpp2_prs_entry *pe; + unsigned int pmap, len, ri; + unsigned char mask[ETH_ALEN] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff }; + int tid; + + /* Scan TCAM and see if entry with this <MAC DA, port> already exist */ + pe = mvpp2_prs_mac_da_range_find(priv, (1 << port), da, mask, + MVPP2_PRS_UDF_MAC_DEF); + + /* No such entry */ + if (!pe) { + if (!add) + return 0; + + /* Create new TCAM entry */ + /* Find first range mac entry*/ + for (tid = MVPP2_PE_FIRST_FREE_TID; + tid <= MVPP2_PE_LAST_FREE_TID; tid++) + if (priv->prs_shadow[tid].valid && + (priv->prs_shadow[tid].lu == MVPP2_PRS_LU_MAC) && + (priv->prs_shadow[tid].udf == + MVPP2_PRS_UDF_MAC_RANGE)) + break; + + /* Go through the all entries from first to last */ + tid = mvpp2_prs_tcam_first_free(priv, MVPP2_PE_FIRST_FREE_TID, + tid - 1); + if (tid < 0) + return tid; + + pe = kzalloc(sizeof(*pe), GFP_KERNEL); + if (!pe) + return -1; + mvpp2_prs_tcam_lu_set(pe, MVPP2_PRS_LU_MAC); + pe->index = tid; + + /* Mask all ports */ + mvpp2_prs_tcam_port_map_set(pe, 0); + } + + /* Update port mask */ + mvpp2_prs_tcam_port_set(pe, port, add); + + /* Invalidate the entry if no ports are left enabled */ + pmap = mvpp2_prs_tcam_port_map_get(pe); + if (pmap == 0) { + if (add) { + kfree(pe); + return -1; + } + mvpp2_prs_hw_inv(priv, pe->index); + priv->prs_shadow[pe->index].valid = false; + kfree(pe); + return 0; + } + + /* Continue - set next lookup */ + mvpp2_prs_sram_next_lu_set(pe, MVPP2_PRS_LU_DSA); + + /* Set match on DA */ + len = ETH_ALEN; + while (len--) + mvpp2_prs_tcam_data_byte_set(pe, len, da[len], 0xff); + + /* Set result info bits */ + ri = MVPP2_PRS_RI_L2_UCAST | MVPP2_PRS_RI_MAC_ME_MASK; + + mvpp2_prs_sram_ri_update(pe, ri, MVPP2_PRS_RI_L2_CAST_MASK | + MVPP2_PRS_RI_MAC_ME_MASK); + mvpp2_prs_shadow_ri_set(priv, pe->index, ri, MVPP2_PRS_RI_L2_CAST_MASK | + MVPP2_PRS_RI_MAC_ME_MASK); + + /* Shift to ethertype */ + mvpp2_prs_sram_shift_set(pe, 2 * ETH_ALEN, + MVPP2_PRS_SRAM_OP_SEL_SHIFT_ADD); + + /* Update shadow table and hw entry */ + priv->prs_shadow[pe->index].udf = MVPP2_PRS_UDF_MAC_DEF; + mvpp2_prs_shadow_set(priv, pe->index, MVPP2_PRS_LU_MAC); + mvpp2_prs_hw_write(priv, pe); + + kfree(pe); + + return 0; +} + +static int mvpp2_prs_update_mac_da(struct mvpp2_port *port, const u8 *da) +{ + int err; + + /* Remove old parser entry */ + err = mvpp2_prs_mac_da_accept(port->priv, port->id, port->dev_addr, + false); + if (err) + return err; + + /* Add new parser entry */ + err = mvpp2_prs_mac_da_accept(port->priv, port->id, da, true); + if (err) + return err; + + /* Set addr in the device */ + memcpy(port->dev_addr, da, ETH_ALEN); + + return 0; +} + +/* Set prs flow for the port */ +static int mvpp2_prs_def_flow(struct mvpp2_port *port) +{ + struct mvpp2_prs_entry *pe; + int tid; + + pe = mvpp2_prs_flow_find(port->priv, port->id); + + /* Such entry not exist */ + if (!pe) { + /* Go through the all entires from last to first */ + tid = mvpp2_prs_tcam_first_free(port->priv, + MVPP2_PE_LAST_FREE_TID, + MVPP2_PE_FIRST_FREE_TID); + if (tid < 0) + return tid; + + pe = kzalloc(sizeof(*pe), GFP_KERNEL); + if (!pe) + return -ENOMEM; + + mvpp2_prs_tcam_lu_set(pe, MVPP2_PRS_LU_FLOWS); + pe->index = tid; + + /* Set flow ID*/ + mvpp2_prs_sram_ai_update(pe, port->id, MVPP2_PRS_FLOW_ID_MASK); + mvpp2_prs_sram_bits_set(pe, MVPP2_PRS_SRAM_LU_DONE_BIT, 1); + + /* Update shadow table */ + mvpp2_prs_shadow_set(port->priv, pe->index, MVPP2_PRS_LU_FLOWS); + } + + mvpp2_prs_tcam_port_map_set(pe, (1 << port->id)); + mvpp2_prs_hw_write(port->priv, pe); + kfree(pe); + + return 0; +} + +/* Classifier configuration routines */ + +/* Update classification flow table registers */ +static void mvpp2_cls_flow_write(struct mvpp2 *priv, + struct mvpp2_cls_flow_entry *fe) +{ + mvpp2_write(priv, MVPP2_CLS_FLOW_INDEX_REG, fe->index); + mvpp2_write(priv, MVPP2_CLS_FLOW_TBL0_REG, fe->data[0]); + mvpp2_write(priv, MVPP2_CLS_FLOW_TBL1_REG, fe->data[1]); + mvpp2_write(priv, MVPP2_CLS_FLOW_TBL2_REG, fe->data[2]); +} + +/* Update classification lookup table register */ +static void mvpp2_cls_lookup_write(struct mvpp2 *priv, + struct mvpp2_cls_lookup_entry *le) +{ + u32 val; + + val = (le->way << MVPP2_CLS_LKP_INDEX_WAY_OFFS) | le->lkpid; + mvpp2_write(priv, MVPP2_CLS_LKP_INDEX_REG, val); + mvpp2_write(priv, MVPP2_CLS_LKP_TBL_REG, le->data); +} + +/* Classifier default initialization */ +static void mvpp2_cls_init(struct mvpp2 *priv) +{ + struct mvpp2_cls_lookup_entry le; + struct mvpp2_cls_flow_entry fe; + int index; + + /* Enable classifier */ + mvpp2_write(priv, MVPP2_CLS_MODE_REG, MVPP2_CLS_MODE_ACTIVE_MASK); + + /* Clear classifier flow table */ + memset(&fe.data, 0, MVPP2_CLS_FLOWS_TBL_DATA_WORDS); + for (index = 0; index < MVPP2_CLS_FLOWS_TBL_SIZE; index++) { + fe.index = index; + mvpp2_cls_flow_write(priv, &fe); + } + + /* Clear classifier lookup table */ + le.data = 0; + for (index = 0; index < MVPP2_CLS_LKP_TBL_SIZE; index++) { + le.lkpid = index; + le.way = 0; + mvpp2_cls_lookup_write(priv, &le); + + le.way = 1; + mvpp2_cls_lookup_write(priv, &le); + } +} + +static void mvpp2_cls_port_config(struct mvpp2_port *port) +{ + struct mvpp2_cls_lookup_entry le; + u32 val; + + /* Set way for the port */ + val = mvpp2_read(port->priv, MVPP2_CLS_PORT_WAY_REG); + val &= ~MVPP2_CLS_PORT_WAY_MASK(port->id); + mvpp2_write(port->priv, MVPP2_CLS_PORT_WAY_REG, val); + + /* Pick the entry to be accessed in lookup ID decoding table + * according to the way and lkpid. + */ + le.lkpid = port->id; + le.way = 0; + le.data = 0; + + /* Set initial CPU queue for receiving packets */ + le.data &= ~MVPP2_CLS_LKP_TBL_RXQ_MASK; + le.data |= port->first_rxq; + + /* Disable classification engines */ + le.data &= ~MVPP2_CLS_LKP_TBL_LOOKUP_EN_MASK; + + /* Update lookup ID table entry */ + mvpp2_cls_lookup_write(port->priv, &le); +} + +/* Set CPU queue number for oversize packets */ +static void mvpp2_cls_oversize_rxq_set(struct mvpp2_port *port) +{ + u32 val; + + mvpp2_write(port->priv, MVPP2_CLS_OVERSIZE_RXQ_LOW_REG(port->id), + port->first_rxq & MVPP2_CLS_OVERSIZE_RXQ_LOW_MASK); + + mvpp2_write(port->priv, MVPP2_CLS_SWFWD_P2HQ_REG(port->id), + (port->first_rxq >> MVPP2_CLS_OVERSIZE_RXQ_LOW_BITS)); + + val = mvpp2_read(port->priv, MVPP2_CLS_SWFWD_PCTRL_REG); + val |= MVPP2_CLS_SWFWD_PCTRL_MASK(port->id); + mvpp2_write(port->priv, MVPP2_CLS_SWFWD_PCTRL_REG, val); +} + +/* Buffer Manager configuration routines */ + +/* Create pool */ +static int mvpp2_bm_pool_create(struct udevice *dev, + struct mvpp2 *priv, + struct mvpp2_bm_pool *bm_pool, int size) +{ + u32 val; + + bm_pool->virt_addr = buffer_loc.bm_pool[bm_pool->id]; + bm_pool->phys_addr = (dma_addr_t)buffer_loc.bm_pool[bm_pool->id]; + if (!bm_pool->virt_addr) + return -ENOMEM; + + if (!IS_ALIGNED((u32)bm_pool->virt_addr, MVPP2_BM_POOL_PTR_ALIGN)) { + dev_err(&pdev->dev, "BM pool %d is not %d bytes aligned\n", + bm_pool->id, MVPP2_BM_POOL_PTR_ALIGN); + return -ENOMEM; + } + + mvpp2_write(priv, MVPP2_BM_POOL_BASE_REG(bm_pool->id), + bm_pool->phys_addr); + mvpp2_write(priv, MVPP2_BM_POOL_SIZE_REG(bm_pool->id), size); + + val = mvpp2_read(priv, MVPP2_BM_POOL_CTRL_REG(bm_pool->id)); + val |= MVPP2_BM_START_MASK; + mvpp2_write(priv, MVPP2_BM_POOL_CTRL_REG(bm_pool->id), val); + + bm_pool->type = MVPP2_BM_FREE; + bm_pool->size = size; + bm_pool->pkt_size = 0; + bm_pool->buf_num = 0; + + return 0; +} + +/* Set pool buffer size */ +static void mvpp2_bm_pool_bufsize_set(struct mvpp2 *priv, + struct mvpp2_bm_pool *bm_pool, + int buf_size) +{ + u32 val; + + bm_pool->buf_size = buf_size; + + val = ALIGN(buf_size, 1 << MVPP2_POOL_BUF_SIZE_OFFSET); + mvpp2_write(priv, MVPP2_POOL_BUF_SIZE_REG(bm_pool->id), val); +} + +/* Free all buffers from the pool */ +static void mvpp2_bm_bufs_free(struct udevice *dev, struct mvpp2 *priv, + struct mvpp2_bm_pool *bm_pool) +{ + bm_pool->buf_num = 0; +} + +/* Cleanup pool */ +static int mvpp2_bm_pool_destroy(struct udevice *dev, + struct mvpp2 *priv, + struct mvpp2_bm_pool *bm_pool) +{ + u32 val; + + mvpp2_bm_bufs_free(dev, priv, bm_pool); + if (bm_pool->buf_num) { + dev_err(dev, "cannot free all buffers in pool %d\n", bm_pool->id); + return 0; + } + + val = mvpp2_read(priv, MVPP2_BM_POOL_CTRL_REG(bm_pool->id)); + val |= MVPP2_BM_STOP_MASK; + mvpp2_write(priv, MVPP2_BM_POOL_CTRL_REG(bm_pool->id), val); + + return 0; +} + +static int mvpp2_bm_pools_init(struct udevice *dev, + struct mvpp2 *priv) +{ + int i, err, size; + struct mvpp2_bm_pool *bm_pool; + + /* Create all pools with maximum size */ + size = MVPP2_BM_POOL_SIZE_MAX; + for (i = 0; i < MVPP2_BM_POOLS_NUM; i++) { + bm_pool = &priv->bm_pools[i]; + bm_pool->id = i; + err = mvpp2_bm_pool_create(dev, priv, bm_pool, size); + if (err) + goto err_unroll_pools; + mvpp2_bm_pool_bufsize_set(priv, bm_pool, 0); + } + return 0; + +err_unroll_pools: + dev_err(&pdev->dev, "failed to create BM pool %d, size %d\n", i, size); + for (i = i - 1; i >= 0; i--) + mvpp2_bm_pool_destroy(dev, priv, &priv->bm_pools[i]); + return err; +} + +static int mvpp2_bm_init(struct udevice *dev, struct mvpp2 *priv) +{ + int i, err; + + for (i = 0; i < MVPP2_BM_POOLS_NUM; i++) { + /* Mask BM all interrupts */ + mvpp2_write(priv, MVPP2_BM_INTR_MASK_REG(i), 0); + /* Clear BM cause register */ + mvpp2_write(priv, MVPP2_BM_INTR_CAUSE_REG(i), 0); + } + + /* Allocate and initialize BM pools */ + priv->bm_pools = devm_kcalloc(dev, MVPP2_BM_POOLS_NUM, + sizeof(struct mvpp2_bm_pool), GFP_KERNEL); + if (!priv->bm_pools) + return -ENOMEM; + + err = mvpp2_bm_pools_init(dev, priv); + if (err < 0) + return err; + return 0; +} + +/* Attach long pool to rxq */ +static void mvpp2_rxq_long_pool_set(struct mvpp2_port *port, + int lrxq, int long_pool) +{ + u32 val; + int prxq; + + /* Get queue physical ID */ + prxq = port->rxqs[lrxq]->id; + + val = mvpp2_read(port->priv, MVPP2_RXQ_CONFIG_REG(prxq)); + val &= ~MVPP2_RXQ_POOL_LONG_MASK; + val |= ((long_pool << MVPP2_RXQ_POOL_LONG_OFFS) & + MVPP2_RXQ_POOL_LONG_MASK); + + mvpp2_write(port->priv, MVPP2_RXQ_CONFIG_REG(prxq), val); +} + +/* Set pool number in a BM cookie */ +static inline u32 mvpp2_bm_cookie_pool_set(u32 cookie, int pool) +{ + u32 bm; + + bm = cookie & ~(0xFF << MVPP2_BM_COOKIE_POOL_OFFS); + bm |= ((pool & 0xFF) << MVPP2_BM_COOKIE_POOL_OFFS); + + return bm; +} + +/* Get pool number from a BM cookie */ +static inline int mvpp2_bm_cookie_pool_get(u32 cookie) +{ + return (cookie >> MVPP2_BM_COOKIE_POOL_OFFS) & 0xFF; +} + +/* Release buffer to BM */ +static inline void mvpp2_bm_pool_put(struct mvpp2_port *port, int pool, + u32 buf_phys_addr, u32 buf_virt_addr) +{ + mvpp2_write(port->priv, MVPP2_BM_VIRT_RLS_REG, buf_virt_addr); + mvpp2_write(port->priv, MVPP2_BM_PHY_RLS_REG(pool), buf_phys_addr); +} + +/* Refill BM pool */ +static void mvpp2_pool_refill(struct mvpp2_port *port, u32 bm, + u32 phys_addr, u32 cookie) +{ + int pool = mvpp2_bm_cookie_pool_get(bm); + + mvpp2_bm_pool_put(port, pool, phys_addr, cookie); +} + +/* Allocate buffers for the pool */ +static int mvpp2_bm_bufs_add(struct mvpp2_port *port, + struct mvpp2_bm_pool *bm_pool, int buf_num) +{ + int i; + u32 bm; + + if (buf_num < 0 || + (buf_num + bm_pool->buf_num > bm_pool->size)) { + netdev_err(port->dev, + "cannot allocate %d buffers for pool %d\n", + buf_num, bm_pool->id); + return 0; + } + + bm = mvpp2_bm_cookie_pool_set(0, bm_pool->id); + for (i = 0; i < buf_num; i++) { + mvpp2_pool_refill(port, bm, (u32)buffer_loc.rx_buffer[i], + (u32)buffer_loc.rx_buffer[i]); + } + + /* Update BM driver with number of buffers added to pool */ + bm_pool->buf_num += i; + bm_pool->in_use_thresh = bm_pool->buf_num / 4; + + return i; +} + +/* Notify the driver that BM pool is being used as specific type and return the + * pool pointer on success + */ +static struct mvpp2_bm_pool * +mvpp2_bm_pool_use(struct mvpp2_port *port, int pool, enum mvpp2_bm_type type, + int pkt_size) +{ + struct mvpp2_bm_pool *new_pool = &port->priv->bm_pools[pool]; + int num; + + if (new_pool->type != MVPP2_BM_FREE && new_pool->type != type) { + netdev_err(port->dev, "mixing pool types is forbidden\n"); + return NULL; + } + + if (new_pool->type == MVPP2_BM_FREE) + new_pool->type = type; + + /* Allocate buffers in case BM pool is used as long pool, but packet + * size doesn't match MTU or BM pool hasn't being used yet + */ + if (((type == MVPP2_BM_SWF_LONG) && (pkt_size > new_pool->pkt_size)) || + (new_pool->pkt_size == 0)) { + int pkts_num; + + /* Set default buffer number or free all the buffers in case + * the pool is not empty + */ + pkts_num = new_pool->buf_num; + if (pkts_num == 0) + pkts_num = type == MVPP2_BM_SWF_LONG ? + MVPP2_BM_LONG_BUF_NUM : + MVPP2_BM_SHORT_BUF_NUM; + else + mvpp2_bm_bufs_free(NULL, + port->priv, new_pool); + + new_pool->pkt_size = pkt_size; + + /* Allocate buffers for this pool */ + num = mvpp2_bm_bufs_add(port, new_pool, pkts_num); + if (num != pkts_num) { + dev_err(dev, "pool %d: %d of %d allocated\n", + new_pool->id, num, pkts_num); + return NULL; + } + } + + mvpp2_bm_pool_bufsize_set(port->priv, new_pool, + MVPP2_RX_BUF_SIZE(new_pool->pkt_size)); + + return new_pool; +} + +/* Initialize pools for swf */ +static int mvpp2_swf_bm_pool_init(struct mvpp2_port *port) +{ + int rxq; + + if (!port->pool_long) { + port->pool_long = + mvpp2_bm_pool_use(port, MVPP2_BM_SWF_LONG_POOL(port->id), + MVPP2_BM_SWF_LONG, + port->pkt_size); + if (!port->pool_long) + return -ENOMEM; + + port->pool_long->port_map |= (1 << port->id); + + for (rxq = 0; rxq < rxq_number; rxq++) + mvpp2_rxq_long_pool_set(port, rxq, port->pool_long->id); + } + + return 0; +} + +/* Port configuration routines */ + +static void mvpp2_port_mii_set(struct mvpp2_port *port) +{ + u32 val; + + val = readl(port->base + MVPP2_GMAC_CTRL_2_REG); + + switch (port->phy_interface) { + case PHY_INTERFACE_MODE_SGMII: + val |= MVPP2_GMAC_INBAND_AN_MASK; + break; + case PHY_INTERFACE_MODE_RGMII: + val |= MVPP2_GMAC_PORT_RGMII_MASK; + default: + val &= ~MVPP2_GMAC_PCS_ENABLE_MASK; + } + + writel(val, port->base + MVPP2_GMAC_CTRL_2_REG); +} + +static void mvpp2_port_fc_adv_enable(struct mvpp2_port *port) +{ + u32 val; + + val = readl(port->base + MVPP2_GMAC_AUTONEG_CONFIG); + val |= MVPP2_GMAC_FC_ADV_EN; + writel(val, port->base + MVPP2_GMAC_AUTONEG_CONFIG); +} + +static void mvpp2_port_enable(struct mvpp2_port *port) +{ + u32 val; + + val = readl(port->base + MVPP2_GMAC_CTRL_0_REG); + val |= MVPP2_GMAC_PORT_EN_MASK; + val |= MVPP2_GMAC_MIB_CNTR_EN_MASK; + writel(val, port->base + MVPP2_GMAC_CTRL_0_REG); +} + +static void mvpp2_port_disable(struct mvpp2_port *port) +{ + u32 val; + + val = readl(port->base + MVPP2_GMAC_CTRL_0_REG); + val &= ~(MVPP2_GMAC_PORT_EN_MASK); + writel(val, port->base + MVPP2_GMAC_CTRL_0_REG); +} + +/* Set IEEE 802.3x Flow Control Xon Packet Transmission Mode */ +static void mvpp2_port_periodic_xon_disable(struct mvpp2_port *port) +{ + u32 val; + + val = readl(port->base + MVPP2_GMAC_CTRL_1_REG) & + ~MVPP2_GMAC_PERIODIC_XON_EN_MASK; + writel(val, port->base + MVPP2_GMAC_CTRL_1_REG); +} + +/* Configure loopback port */ +static void mvpp2_port_loopback_set(struct mvpp2_port *port) +{ + u32 val; + + val = readl(port->base + MVPP2_GMAC_CTRL_1_REG); + + if (port->speed == 1000) + val |= MVPP2_GMAC_GMII_LB_EN_MASK; + else + val &= ~MVPP2_GMAC_GMII_LB_EN_MASK; + + if (port->phy_interface == PHY_INTERFACE_MODE_SGMII) + val |= MVPP2_GMAC_PCS_LB_EN_MASK; + else + val &= ~MVPP2_GMAC_PCS_LB_EN_MASK; + + writel(val, port->base + MVPP2_GMAC_CTRL_1_REG); +} + +static void mvpp2_port_reset(struct mvpp2_port *port) +{ + u32 val; + + val = readl(port->base + MVPP2_GMAC_CTRL_2_REG) & + ~MVPP2_GMAC_PORT_RESET_MASK; + writel(val, port->base + MVPP2_GMAC_CTRL_2_REG); + + while (readl(port->base + MVPP2_GMAC_CTRL_2_REG) & + MVPP2_GMAC_PORT_RESET_MASK) + continue; +} + +/* Change maximum receive size of the port */ +static inline void mvpp2_gmac_max_rx_size_set(struct mvpp2_port *port) +{ + u32 val; + + val = readl(port->base + MVPP2_GMAC_CTRL_0_REG); + val &= ~MVPP2_GMAC_MAX_RX_SIZE_MASK; + val |= (((port->pkt_size - MVPP2_MH_SIZE) / 2) << + MVPP2_GMAC_MAX_RX_SIZE_OFFS); + writel(val, port->base + MVPP2_GMAC_CTRL_0_REG); +} + +/* Set defaults to the MVPP2 port */ +static void mvpp2_defaults_set(struct mvpp2_port *port) +{ + int tx_port_num, val, queue, ptxq, lrxq; + + /* Configure port to loopback if needed */ + if (port->flags & MVPP2_F_LOOPBACK) + mvpp2_port_loopback_set(port); + + /* Update TX FIFO MIN Threshold */ + val = readl(port->base + MVPP2_GMAC_PORT_FIFO_CFG_1_REG); + val &= ~MVPP2_GMAC_TX_FIFO_MIN_TH_ALL_MASK; + /* Min. TX threshold must be less than minimal packet length */ + val |= MVPP2_GMAC_TX_FIFO_MIN_TH_MASK(64 - 4 - 2); + writel(val, port->base + MVPP2_GMAC_PORT_FIFO_CFG_1_REG); + + /* Disable Legacy WRR, Disable EJP, Release from reset */ + tx_port_num = mvpp2_egress_port(port); + mvpp2_write(port->priv, MVPP2_TXP_SCHED_PORT_INDEX_REG, + tx_port_num); + mvpp2_write(port->priv, MVPP2_TXP_SCHED_CMD_1_REG, 0); + + /* Close bandwidth for all queues */ + for (queue = 0; queue < MVPP2_MAX_TXQ; queue++) { + ptxq = mvpp2_txq_phys(port->id, queue); + mvpp2_write(port->priv, + MVPP2_TXQ_SCHED_TOKEN_CNTR_REG(ptxq), 0); + } + + /* Set refill period to 1 usec, refill tokens + * and bucket size to maximum + */ + mvpp2_write(port->priv, MVPP2_TXP_SCHED_PERIOD_REG, 0xc8); + val = mvpp2_read(port->priv, MVPP2_TXP_SCHED_REFILL_REG); + val &= ~MVPP2_TXP_REFILL_PERIOD_ALL_MASK; + val |= MVPP2_TXP_REFILL_PERIOD_MASK(1); + val |= MVPP2_TXP_REFILL_TOKENS_ALL_MASK; + mvpp2_write(port->priv, MVPP2_TXP_SCHED_REFILL_REG, val); + val = MVPP2_TXP_TOKEN_SIZE_MAX; + mvpp2_write(port->priv, MVPP2_TXP_SCHED_TOKEN_SIZE_REG, val); + + /* Set MaximumLowLatencyPacketSize value to 256 */ + mvpp2_write(port->priv, MVPP2_RX_CTRL_REG(port->id), + MVPP2_RX_USE_PSEUDO_FOR_CSUM_MASK | + MVPP2_RX_LOW_LATENCY_PKT_SIZE(256)); + + /* Enable Rx cache snoop */ + for (lrxq = 0; lrxq < rxq_number; lrxq++) { + queue = port->rxqs[lrxq]->id; + val = mvpp2_read(port->priv, MVPP2_RXQ_CONFIG_REG(queue)); + val |= MVPP2_SNOOP_PKT_SIZE_MASK | + MVPP2_SNOOP_BUF_HDR_MASK; + mvpp2_write(port->priv, MVPP2_RXQ_CONFIG_REG(queue), val); + } +} + +/* Enable/disable receiving packets */ +static void mvpp2_ingress_enable(struct mvpp2_port *port) +{ + u32 val; + int lrxq, queue; + + for (lrxq = 0; lrxq < rxq_number; lrxq++) { + queue = port->rxqs[lrxq]->id; + val = mvpp2_read(port->priv, MVPP2_RXQ_CONFIG_REG(queue)); + val &= ~MVPP2_RXQ_DISABLE_MASK; + mvpp2_write(port->priv, MVPP2_RXQ_CONFIG_REG(queue), val); + } +} + +static void mvpp2_ingress_disable(struct mvpp2_port *port) +{ + u32 val; + int lrxq, queue; + + for (lrxq = 0; lrxq < rxq_number; lrxq++) { + queue = port->rxqs[lrxq]->id; + val = mvpp2_read(port->priv, MVPP2_RXQ_CONFIG_REG(queue)); + val |= MVPP2_RXQ_DISABLE_MASK; + mvpp2_write(port->priv, MVPP2_RXQ_CONFIG_REG(queue), val); + } +} + +/* Enable transmit via physical egress queue + * - HW starts take descriptors from DRAM + */ +static void mvpp2_egress_enable(struct mvpp2_port *port) +{ + u32 qmap; + int queue; + int tx_port_num = mvpp2_egress_port(port); + + /* Enable all initialized TXs. */ + qmap = 0; + for (queue = 0; queue < txq_number; queue++) { + struct mvpp2_tx_queue *txq = port->txqs[queue]; + + if (txq->descs != NULL) + qmap |= (1 << queue); + } + + mvpp2_write(port->priv, MVPP2_TXP_SCHED_PORT_INDEX_REG, tx_port_num); + mvpp2_write(port->priv, MVPP2_TXP_SCHED_Q_CMD_REG, qmap); +} + +/* Disable transmit via physical egress queue + * - HW doesn't take descriptors from DRAM + */ +static void mvpp2_egress_disable(struct mvpp2_port *port) +{ + u32 reg_data; + int delay; + int tx_port_num = mvpp2_egress_port(port); + + /* Issue stop command for active channels only */ + mvpp2_write(port->priv, MVPP2_TXP_SCHED_PORT_INDEX_REG, tx_port_num); + reg_data = (mvpp2_read(port->priv, MVPP2_TXP_SCHED_Q_CMD_REG)) & + MVPP2_TXP_SCHED_ENQ_MASK; + if (reg_data != 0) + mvpp2_write(port->priv, MVPP2_TXP_SCHED_Q_CMD_REG, + (reg_data << MVPP2_TXP_SCHED_DISQ_OFFSET)); + + /* Wait for all Tx activity to terminate. */ + delay = 0; + do { + if (delay >= MVPP2_TX_DISABLE_TIMEOUT_MSEC) { + netdev_warn(port->dev, + "Tx stop timed out, status=0x%08x\n", + reg_data); + break; + } + mdelay(1); + delay++; + + /* Check port TX Command register that all + * Tx queues are stopped + */ + reg_data = mvpp2_read(port->priv, MVPP2_TXP_SCHED_Q_CMD_REG); + } while (reg_data & MVPP2_TXP_SCHED_ENQ_MASK); +} + +/* Rx descriptors helper methods */ + +/* Get number of Rx descriptors occupied by received packets */ +static inline int +mvpp2_rxq_received(struct mvpp2_port *port, int rxq_id) +{ + u32 val = mvpp2_read(port->priv, MVPP2_RXQ_STATUS_REG(rxq_id)); + + return val & MVPP2_RXQ_OCCUPIED_MASK; +} + +/* Update Rx queue status with the number of occupied and available + * Rx descriptor slots. + */ +static inline void +mvpp2_rxq_status_update(struct mvpp2_port *port, int rxq_id, + int used_count, int free_count) +{ + /* Decrement the number of used descriptors and increment count + * increment the number of free descriptors. + */ + u32 val = used_count | (free_count << MVPP2_RXQ_NUM_NEW_OFFSET); + + mvpp2_write(port->priv, MVPP2_RXQ_STATUS_UPDATE_REG(rxq_id), val); +} + +/* Get pointer to next RX descriptor to be processed by SW */ +static inline struct mvpp2_rx_desc * +mvpp2_rxq_next_desc_get(struct mvpp2_rx_queue *rxq) +{ + int rx_desc = rxq->next_desc_to_proc; + + rxq->next_desc_to_proc = MVPP2_QUEUE_NEXT_DESC(rxq, rx_desc); + prefetch(rxq->descs + rxq->next_desc_to_proc); + return rxq->descs + rx_desc; +} + +/* Set rx queue offset */ +static void mvpp2_rxq_offset_set(struct mvpp2_port *port, + int prxq, int offset) +{ + u32 val; + + /* Convert offset from bytes to units of 32 bytes */ + offset = offset >> 5; + + val = mvpp2_read(port->priv, MVPP2_RXQ_CONFIG_REG(prxq)); + val &= ~MVPP2_RXQ_PACKET_OFFSET_MASK; + + /* Offset is in */ + val |= ((offset << MVPP2_RXQ_PACKET_OFFSET_OFFS) & + MVPP2_RXQ_PACKET_OFFSET_MASK); + + mvpp2_write(port->priv, MVPP2_RXQ_CONFIG_REG(prxq), val); +} + +/* Obtain BM cookie information from descriptor */ +static u32 mvpp2_bm_cookie_build(struct mvpp2_rx_desc *rx_desc) +{ + int pool = (rx_desc->status & MVPP2_RXD_BM_POOL_ID_MASK) >> + MVPP2_RXD_BM_POOL_ID_OFFS; + int cpu = smp_processor_id(); + + return ((pool & 0xFF) << MVPP2_BM_COOKIE_POOL_OFFS) | + ((cpu & 0xFF) << MVPP2_BM_COOKIE_CPU_OFFS); +} + +/* Tx descriptors helper methods */ + +/* Get number of Tx descriptors waiting to be transmitted by HW */ +static int mvpp2_txq_pend_desc_num_get(struct mvpp2_port *port, + struct mvpp2_tx_queue *txq) +{ + u32 val; + + mvpp2_write(port->priv, MVPP2_TXQ_NUM_REG, txq->id); + val = mvpp2_read(port->priv, MVPP2_TXQ_PENDING_REG); + + return val & MVPP2_TXQ_PENDING_MASK; +} + +/* Get pointer to next Tx descriptor to be processed (send) by HW */ +static struct mvpp2_tx_desc * +mvpp2_txq_next_desc_get(struct mvpp2_tx_queue *txq) +{ + int tx_desc = txq->next_desc_to_proc; + + txq->next_desc_to_proc = MVPP2_QUEUE_NEXT_DESC(txq, tx_desc); + return txq->descs + tx_desc; +} + +/* Update HW with number of aggregated Tx descriptors to be sent */ +static void mvpp2_aggr_txq_pend_desc_add(struct mvpp2_port *port, int pending) +{ + /* aggregated access - relevant TXQ number is written in TX desc */ + mvpp2_write(port->priv, MVPP2_AGGR_TXQ_UPDATE_REG, pending); +} + +/* Get number of sent descriptors and decrement counter. + * The number of sent descriptors is returned. + * Per-CPU access + */ +static inline int mvpp2_txq_sent_desc_proc(struct mvpp2_port *port, + struct mvpp2_tx_queue *txq) +{ + u32 val; + + /* Reading status reg resets transmitted descriptor counter */ + val = mvpp2_read(port->priv, MVPP2_TXQ_SENT_REG(txq->id)); + + return (val & MVPP2_TRANSMITTED_COUNT_MASK) >> + MVPP2_TRANSMITTED_COUNT_OFFSET; +} + +static void mvpp2_txq_sent_counter_clear(void *arg) +{ + struct mvpp2_port *port = arg; + int queue; + + for (queue = 0; queue < txq_number; queue++) { + int id = port->txqs[queue]->id; + + mvpp2_read(port->priv, MVPP2_TXQ_SENT_REG(id)); + } +} + +/* Set max sizes for Tx queues */ +static void mvpp2_txp_max_tx_size_set(struct mvpp2_port *port) +{ + u32 val, size, mtu; + int txq, tx_port_num; + + mtu = port->pkt_size * 8; + if (mtu > MVPP2_TXP_MTU_MAX) + mtu = MVPP2_TXP_MTU_MAX; + + /* WA for wrong Token bucket update: Set MTU value = 3*real MTU value */ + mtu = 3 * mtu; + + /* Indirect access to registers */ + tx_port_num = mvpp2_egress_port(port); + mvpp2_write(port->priv, MVPP2_TXP_SCHED_PORT_INDEX_REG, tx_port_num); + + /* Set MTU */ + val = mvpp2_read(port->priv, MVPP2_TXP_SCHED_MTU_REG); + val &= ~MVPP2_TXP_MTU_MAX; + val |= mtu; + mvpp2_write(port->priv, MVPP2_TXP_SCHED_MTU_REG, val); + + /* TXP token size and all TXQs token size must be larger that MTU */ + val = mvpp2_read(port->priv, MVPP2_TXP_SCHED_TOKEN_SIZE_REG); + size = val & MVPP2_TXP_TOKEN_SIZE_MAX; + if (size < mtu) { + size = mtu; + val &= ~MVPP2_TXP_TOKEN_SIZE_MAX; + val |= size; + mvpp2_write(port->priv, MVPP2_TXP_SCHED_TOKEN_SIZE_REG, val); + } + + for (txq = 0; txq < txq_number; txq++) { + val = mvpp2_read(port->priv, + MVPP2_TXQ_SCHED_TOKEN_SIZE_REG(txq)); + size = val & MVPP2_TXQ_TOKEN_SIZE_MAX; + + if (size < mtu) { + size = mtu; + val &= ~MVPP2_TXQ_TOKEN_SIZE_MAX; + val |= size; + mvpp2_write(port->priv, + MVPP2_TXQ_SCHED_TOKEN_SIZE_REG(txq), + val); + } + } +} + +/* Free Tx queue skbuffs */ +static void mvpp2_txq_bufs_free(struct mvpp2_port *port, + struct mvpp2_tx_queue *txq, + struct mvpp2_txq_pcpu *txq_pcpu, int num) +{ + int i; + + for (i = 0; i < num; i++) + mvpp2_txq_inc_get(txq_pcpu); +} + +static inline struct mvpp2_rx_queue *mvpp2_get_rx_queue(struct mvpp2_port *port, + u32 cause) +{ + int queue = fls(cause) - 1; + + return port->rxqs[queue]; +} + +static inline struct mvpp2_tx_queue *mvpp2_get_tx_queue(struct mvpp2_port *port, + u32 cause) +{ + int queue = fls(cause) - 1; + + return port->txqs[queue]; +} + +/* Rx/Tx queue initialization/cleanup methods */ + +/* Allocate and initialize descriptors for aggr TXQ */ +static int mvpp2_aggr_txq_init(struct udevice *dev, + struct mvpp2_tx_queue *aggr_txq, + int desc_num, int cpu, + struct mvpp2 *priv) +{ + /* Allocate memory for TX descriptors */ + aggr_txq->descs = buffer_loc.aggr_tx_descs; + aggr_txq->descs_phys = (dma_addr_t)buffer_loc.aggr_tx_descs; + if (!aggr_txq->descs) + return -ENOMEM; + + /* Make sure descriptor address is cache line size aligned */ + BUG_ON(aggr_txq->descs != + PTR_ALIGN(aggr_txq->descs, MVPP2_CPU_D_CACHE_LINE_SIZE)); + + aggr_txq->last_desc = aggr_txq->size - 1; + + /* Aggr TXQ no reset WA */ + aggr_txq->next_desc_to_proc = mvpp2_read(priv, + MVPP2_AGGR_TXQ_INDEX_REG(cpu)); + + /* Set Tx descriptors queue starting address */ + /* indirect access */ + mvpp2_write(priv, MVPP2_AGGR_TXQ_DESC_ADDR_REG(cpu), + aggr_txq->descs_phys); + mvpp2_write(priv, MVPP2_AGGR_TXQ_DESC_SIZE_REG(cpu), desc_num); + + return 0; +} + +/* Create a specified Rx queue */ +static int mvpp2_rxq_init(struct mvpp2_port *port, + struct mvpp2_rx_queue *rxq) + +{ + rxq->size = port->rx_ring_size; + + /* Allocate memory for RX descriptors */ + rxq->descs = buffer_loc.rx_descs; + rxq->descs_phys = (dma_addr_t)buffer_loc.rx_descs; + if (!rxq->descs) + return -ENOMEM; + + BUG_ON(rxq->descs != + PTR_ALIGN(rxq->descs, MVPP2_CPU_D_CACHE_LINE_SIZE)); + + rxq->last_desc = rxq->size - 1; + + /* Zero occupied and non-occupied counters - direct access */ + mvpp2_write(port->priv, MVPP2_RXQ_STATUS_REG(rxq->id), 0); + + /* Set Rx descriptors queue starting address - indirect access */ + mvpp2_write(port->priv, MVPP2_RXQ_NUM_REG, rxq->id); + mvpp2_write(port->priv, MVPP2_RXQ_DESC_ADDR_REG, rxq->descs_phys); + mvpp2_write(port->priv, MVPP2_RXQ_DESC_SIZE_REG, rxq->size); + mvpp2_write(port->priv, MVPP2_RXQ_INDEX_REG, 0); + + /* Set Offset */ + mvpp2_rxq_offset_set(port, rxq->id, NET_SKB_PAD); + + /* Add number of descriptors ready for receiving packets */ + mvpp2_rxq_status_update(port, rxq->id, 0, rxq->size); + + return 0; +} + +/* Push packets received by the RXQ to BM pool */ +static void mvpp2_rxq_drop_pkts(struct mvpp2_port *port, + struct mvpp2_rx_queue *rxq) +{ + int rx_received, i; + + rx_received = mvpp2_rxq_received(port, rxq->id); + if (!rx_received) + return; + + for (i = 0; i < rx_received; i++) { + struct mvpp2_rx_desc *rx_desc = mvpp2_rxq_next_desc_get(rxq); + u32 bm = mvpp2_bm_cookie_build(rx_desc); + + mvpp2_pool_refill(port, bm, rx_desc->buf_phys_addr, + rx_desc->buf_cookie); + } + mvpp2_rxq_status_update(port, rxq->id, rx_received, rx_received); +} + +/* Cleanup Rx queue */ +static void mvpp2_rxq_deinit(struct mvpp2_port *port, + struct mvpp2_rx_queue *rxq) +{ + mvpp2_rxq_drop_pkts(port, rxq); + + rxq->descs = NULL; + rxq->last_desc = 0; + rxq->next_desc_to_proc = 0; + rxq->descs_phys = 0; + + /* Clear Rx descriptors queue starting address and size; + * free descriptor number + */ + mvpp2_write(port->priv, MVPP2_RXQ_STATUS_REG(rxq->id), 0); + mvpp2_write(port->priv, MVPP2_RXQ_NUM_REG, rxq->id); + mvpp2_write(port->priv, MVPP2_RXQ_DESC_ADDR_REG, 0); + mvpp2_write(port->priv, MVPP2_RXQ_DESC_SIZE_REG, 0); +} + +/* Create and initialize a Tx queue */ +static int mvpp2_txq_init(struct mvpp2_port *port, + struct mvpp2_tx_queue *txq) +{ + u32 val; + int cpu, desc, desc_per_txq, tx_port_num; + struct mvpp2_txq_pcpu *txq_pcpu; + + txq->size = port->tx_ring_size; + + /* Allocate memory for Tx descriptors */ + txq->descs = buffer_loc.tx_descs; + txq->descs_phys = (dma_addr_t)buffer_loc.tx_descs; + if (!txq->descs) + return -ENOMEM; + + /* Make sure descriptor address is cache line size aligned */ + BUG_ON(txq->descs != + PTR_ALIGN(txq->descs, MVPP2_CPU_D_CACHE_LINE_SIZE)); + + txq->last_desc = txq->size - 1; + + /* Set Tx descriptors queue starting address - indirect access */ + mvpp2_write(port->priv, MVPP2_TXQ_NUM_REG, txq->id); + mvpp2_write(port->priv, MVPP2_TXQ_DESC_ADDR_REG, txq->descs_phys); + mvpp2_write(port->priv, MVPP2_TXQ_DESC_SIZE_REG, txq->size & + MVPP2_TXQ_DESC_SIZE_MASK); + mvpp2_write(port->priv, MVPP2_TXQ_INDEX_REG, 0); + mvpp2_write(port->priv, MVPP2_TXQ_RSVD_CLR_REG, + txq->id << MVPP2_TXQ_RSVD_CLR_OFFSET); + val = mvpp2_read(port->priv, MVPP2_TXQ_PENDING_REG); + val &= ~MVPP2_TXQ_PENDING_MASK; + mvpp2_write(port->priv, MVPP2_TXQ_PENDING_REG, val); + + /* Calculate base address in prefetch buffer. We reserve 16 descriptors + * for each existing TXQ. + * TCONTS for PON port must be continuous from 0 to MVPP2_MAX_TCONT + * GBE ports assumed to be continious from 0 to MVPP2_MAX_PORTS + */ + desc_per_txq = 16; + desc = (port->id * MVPP2_MAX_TXQ * desc_per_txq) + + (txq->log_id * desc_per_txq); + + mvpp2_write(port->priv, MVPP2_TXQ_PREF_BUF_REG, + MVPP2_PREF_BUF_PTR(desc) | MVPP2_PREF_BUF_SIZE_16 | + MVPP2_PREF_BUF_THRESH(desc_per_txq/2)); + + /* WRR / EJP configuration - indirect access */ + tx_port_num = mvpp2_egress_port(port); + mvpp2_write(port->priv, MVPP2_TXP_SCHED_PORT_INDEX_REG, tx_port_num); + + val = mvpp2_read(port->priv, MVPP2_TXQ_SCHED_REFILL_REG(txq->log_id)); + val &= ~MVPP2_TXQ_REFILL_PERIOD_ALL_MASK; + val |= MVPP2_TXQ_REFILL_PERIOD_MASK(1); + val |= MVPP2_TXQ_REFILL_TOKENS_ALL_MASK; + mvpp2_write(port->priv, MVPP2_TXQ_SCHED_REFILL_REG(txq->log_id), val); + + val = MVPP2_TXQ_TOKEN_SIZE_MAX; + mvpp2_write(port->priv, MVPP2_TXQ_SCHED_TOKEN_SIZE_REG(txq->log_id), + val); + + for_each_present_cpu(cpu) { + txq_pcpu = per_cpu_ptr(txq->pcpu, cpu); + txq_pcpu->size = txq->size; + } + + return 0; +} + +/* Free allocated TXQ resources */ +static void mvpp2_txq_deinit(struct mvpp2_port *port, + struct mvpp2_tx_queue *txq) +{ + txq->descs = NULL; + txq->last_desc = 0; + txq->next_desc_to_proc = 0; + txq->descs_phys = 0; + + /* Set minimum bandwidth for disabled TXQs */ + mvpp2_write(port->priv, MVPP2_TXQ_SCHED_TOKEN_CNTR_REG(txq->id), 0); + + /* Set Tx descriptors queue starting address and size */ + mvpp2_write(port->priv, MVPP2_TXQ_NUM_REG, txq->id); + mvpp2_write(port->priv, MVPP2_TXQ_DESC_ADDR_REG, 0); + mvpp2_write(port->priv, MVPP2_TXQ_DESC_SIZE_REG, 0); +} + +/* Cleanup Tx ports */ +static void mvpp2_txq_clean(struct mvpp2_port *port, struct mvpp2_tx_queue *txq) +{ + struct mvpp2_txq_pcpu *txq_pcpu; + int delay, pending, cpu; + u32 val; + + mvpp2_write(port->priv, MVPP2_TXQ_NUM_REG, txq->id); + val = mvpp2_read(port->priv, MVPP2_TXQ_PREF_BUF_REG); + val |= MVPP2_TXQ_DRAIN_EN_MASK; + mvpp2_write(port->priv, MVPP2_TXQ_PREF_BUF_REG, val); + + /* The napi queue has been stopped so wait for all packets + * to be transmitted. + */ + delay = 0; + do { + if (delay >= MVPP2_TX_PENDING_TIMEOUT_MSEC) { + netdev_warn(port->dev, + "port %d: cleaning queue %d timed out\n", + port->id, txq->log_id); + break; + } + mdelay(1); + delay++; + + pending = mvpp2_txq_pend_desc_num_get(port, txq); + } while (pending); + + val &= ~MVPP2_TXQ_DRAIN_EN_MASK; + mvpp2_write(port->priv, MVPP2_TXQ_PREF_BUF_REG, val); + + for_each_present_cpu(cpu) { + txq_pcpu = per_cpu_ptr(txq->pcpu, cpu); + + /* Release all packets */ + mvpp2_txq_bufs_free(port, txq, txq_pcpu, txq_pcpu->count); + + /* Reset queue */ + txq_pcpu->count = 0; + txq_pcpu->txq_put_index = 0; + txq_pcpu->txq_get_index = 0; + } +} + +/* Cleanup all Tx queues */ +static void mvpp2_cleanup_txqs(struct mvpp2_port *port) +{ + struct mvpp2_tx_queue *txq; + int queue; + u32 val; + + val = mvpp2_read(port->priv, MVPP2_TX_PORT_FLUSH_REG); + + /* Reset Tx ports and delete Tx queues */ + val |= MVPP2_TX_PORT_FLUSH_MASK(port->id); + mvpp2_write(port->priv, MVPP2_TX_PORT_FLUSH_REG, val); + + for (queue = 0; queue < txq_number; queue++) { + txq = port->txqs[queue]; + mvpp2_txq_clean(port, txq); + mvpp2_txq_deinit(port, txq); + } + + mvpp2_txq_sent_counter_clear(port); + + val &= ~MVPP2_TX_PORT_FLUSH_MASK(port->id); + mvpp2_write(port->priv, MVPP2_TX_PORT_FLUSH_REG, val); +} + +/* Cleanup all Rx queues */ +static void mvpp2_cleanup_rxqs(struct mvpp2_port *port) +{ + int queue; + + for (queue = 0; queue < rxq_number; queue++) + mvpp2_rxq_deinit(port, port->rxqs[queue]); +} + +/* Init all Rx queues for port */ +static int mvpp2_setup_rxqs(struct mvpp2_port *port) +{ + int queue, err; + + for (queue = 0; queue < rxq_number; queue++) { + err = mvpp2_rxq_init(port, port->rxqs[queue]); + if (err) + goto err_cleanup; + } + return 0; + +err_cleanup: + mvpp2_cleanup_rxqs(port); + return err; +} + +/* Init all tx queues for port */ +static int mvpp2_setup_txqs(struct mvpp2_port *port) +{ + struct mvpp2_tx_queue *txq; + int queue, err; + + for (queue = 0; queue < txq_number; queue++) { + txq = port->txqs[queue]; + err = mvpp2_txq_init(port, txq); + if (err) + goto err_cleanup; + } + + mvpp2_txq_sent_counter_clear(port); + return 0; + +err_cleanup: + mvpp2_cleanup_txqs(port); + return err; +} + +/* Adjust link */ +static void mvpp2_link_event(struct mvpp2_port *port) +{ + struct phy_device *phydev = port->phy_dev; + int status_change = 0; + u32 val; + + if (phydev->link) { + if ((port->speed != phydev->speed) || + (port->duplex != phydev->duplex)) { + u32 val; + + val = readl(port->base + MVPP2_GMAC_AUTONEG_CONFIG); + val &= ~(MVPP2_GMAC_CONFIG_MII_SPEED | + MVPP2_GMAC_CONFIG_GMII_SPEED | + MVPP2_GMAC_CONFIG_FULL_DUPLEX | + MVPP2_GMAC_AN_SPEED_EN | + MVPP2_GMAC_AN_DUPLEX_EN); + + if (phydev->duplex) + val |= MVPP2_GMAC_CONFIG_FULL_DUPLEX; + + if (phydev->speed == SPEED_1000) + val |= MVPP2_GMAC_CONFIG_GMII_SPEED; + else if (phydev->speed == SPEED_100) + val |= MVPP2_GMAC_CONFIG_MII_SPEED; + + writel(val, port->base + MVPP2_GMAC_AUTONEG_CONFIG); + + port->duplex = phydev->duplex; + port->speed = phydev->speed; + } + } + + if (phydev->link != port->link) { + if (!phydev->link) { + port->duplex = -1; + port->speed = 0; + } + + port->link = phydev->link; + status_change = 1; + } + + if (status_change) { + if (phydev->link) { + val = readl(port->base + MVPP2_GMAC_AUTONEG_CONFIG); + val |= (MVPP2_GMAC_FORCE_LINK_PASS | + MVPP2_GMAC_FORCE_LINK_DOWN); + writel(val, port->base + MVPP2_GMAC_AUTONEG_CONFIG); + mvpp2_egress_enable(port); + mvpp2_ingress_enable(port); + } else { + mvpp2_ingress_disable(port); + mvpp2_egress_disable(port); + } + } +} + +/* Main RX/TX processing routines */ + +/* Display more error info */ +static void mvpp2_rx_error(struct mvpp2_port *port, + struct mvpp2_rx_desc *rx_desc) +{ + u32 status = rx_desc->status; + + switch (status & MVPP2_RXD_ERR_CODE_MASK) { + case MVPP2_RXD_ERR_CRC: + netdev_err(port->dev, "bad rx status %08x (crc error), size=%d\n", + status, rx_desc->data_size); + break; + case MVPP2_RXD_ERR_OVERRUN: + netdev_err(port->dev, "bad rx status %08x (overrun error), size=%d\n", + status, rx_desc->data_size); + break; + case MVPP2_RXD_ERR_RESOURCE: + netdev_err(port->dev, "bad rx status %08x (resource error), size=%d\n", + status, rx_desc->data_size); + break; + } +} + +/* Reuse skb if possible, or allocate a new skb and add it to BM pool */ +static int mvpp2_rx_refill(struct mvpp2_port *port, + struct mvpp2_bm_pool *bm_pool, + u32 bm, u32 phys_addr) +{ + mvpp2_pool_refill(port, bm, phys_addr, phys_addr); + return 0; +} + +/* Set hw internals when starting port */ +static void mvpp2_start_dev(struct mvpp2_port *port) +{ + mvpp2_gmac_max_rx_size_set(port); + mvpp2_txp_max_tx_size_set(port); + + mvpp2_port_enable(port); +} + +/* Set hw internals when stopping port */ +static void mvpp2_stop_dev(struct mvpp2_port *port) +{ + /* Stop new packets from arriving to RXQs */ + mvpp2_ingress_disable(port); + + mvpp2_egress_disable(port); + mvpp2_port_disable(port); +} + +static int mvpp2_phy_connect(struct udevice *dev, struct mvpp2_port *port) +{ + struct phy_device *phy_dev; + + if (!port->init || port->link == 0) { + phy_dev = phy_connect(port->priv->bus, port->phyaddr, dev, + port->phy_interface); + port->phy_dev = phy_dev; + if (!phy_dev) { + netdev_err(port->dev, "cannot connect to phy\n"); + return -ENODEV; + } + phy_dev->supported &= PHY_GBIT_FEATURES; + phy_dev->advertising = phy_dev->supported; + + port->phy_dev = phy_dev; + port->link = 0; + port->duplex = 0; + port->speed = 0; + + phy_config(phy_dev); + phy_startup(phy_dev); + if (!phy_dev->link) { + printf("%s: No link\n", phy_dev->dev->name); + return -1; + } + + port->init = 1; + } else { + mvpp2_egress_enable(port); + mvpp2_ingress_enable(port); + } + + return 0; +} + +static int mvpp2_open(struct udevice *dev, struct mvpp2_port *port) +{ + unsigned char mac_bcast[ETH_ALEN] = { + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff }; + int err; + + err = mvpp2_prs_mac_da_accept(port->priv, port->id, mac_bcast, true); + if (err) { + netdev_err(dev, "mvpp2_prs_mac_da_accept BC failed\n"); + return err; + } + err = mvpp2_prs_mac_da_accept(port->priv, port->id, + port->dev_addr, true); + if (err) { + netdev_err(dev, "mvpp2_prs_mac_da_accept MC failed\n"); + return err; + } + err = mvpp2_prs_def_flow(port); + if (err) { + netdev_err(dev, "mvpp2_prs_def_flow failed\n"); + return err; + } + + /* Allocate the Rx/Tx queues */ + err = mvpp2_setup_rxqs(port); + if (err) { + netdev_err(port->dev, "cannot allocate Rx queues\n"); + return err; + } + + err = mvpp2_setup_txqs(port); + if (err) { + netdev_err(port->dev, "cannot allocate Tx queues\n"); + return err; + } + + err = mvpp2_phy_connect(dev, port); + if (err < 0) + return err; + + mvpp2_link_event(port); + + mvpp2_start_dev(port); + + return 0; +} + +/* No Device ops here in U-Boot */ + +/* Driver initialization */ + +static void mvpp2_port_power_up(struct mvpp2_port *port) +{ + mvpp2_port_mii_set(port); + mvpp2_port_periodic_xon_disable(port); + mvpp2_port_fc_adv_enable(port); + mvpp2_port_reset(port); +} + +/* Initialize port HW */ +static int mvpp2_port_init(struct udevice *dev, struct mvpp2_port *port) +{ + struct mvpp2 *priv = port->priv; + struct mvpp2_txq_pcpu *txq_pcpu; + int queue, cpu, err; + + if (port->first_rxq + rxq_number > MVPP2_RXQ_TOTAL_NUM) + return -EINVAL; + + /* Disable port */ + mvpp2_egress_disable(port); + mvpp2_port_disable(port); + + port->txqs = devm_kcalloc(dev, txq_number, sizeof(*port->txqs), + GFP_KERNEL); + if (!port->txqs) + return -ENOMEM; + + /* Associate physical Tx queues to this port and initialize. + * The mapping is predefined. + */ + for (queue = 0; queue < txq_number; queue++) { + int queue_phy_id = mvpp2_txq_phys(port->id, queue); + struct mvpp2_tx_queue *txq; + + txq = devm_kzalloc(dev, sizeof(*txq), GFP_KERNEL); + if (!txq) + return -ENOMEM; + + txq->pcpu = devm_kzalloc(dev, sizeof(struct mvpp2_txq_pcpu), + GFP_KERNEL); + if (!txq->pcpu) + return -ENOMEM; + + txq->id = queue_phy_id; + txq->log_id = queue; + txq->done_pkts_coal = MVPP2_TXDONE_COAL_PKTS_THRESH; + for_each_present_cpu(cpu) { + txq_pcpu = per_cpu_ptr(txq->pcpu, cpu); + txq_pcpu->cpu = cpu; + } + + port->txqs[queue] = txq; + } + + port->rxqs = devm_kcalloc(dev, rxq_number, sizeof(*port->rxqs), + GFP_KERNEL); + if (!port->rxqs) + return -ENOMEM; + + /* Allocate and initialize Rx queue for this port */ + for (queue = 0; queue < rxq_number; queue++) { + struct mvpp2_rx_queue *rxq; + + /* Map physical Rx queue to port's logical Rx queue */ + rxq = devm_kzalloc(dev, sizeof(*rxq), GFP_KERNEL); + if (!rxq) + return -ENOMEM; + /* Map this Rx queue to a physical queue */ + rxq->id = port->first_rxq + queue; + rxq->port = port->id; + rxq->logic_rxq = queue; + + port->rxqs[queue] = rxq; + } + + /* Configure Rx queue group interrupt for this port */ + mvpp2_write(priv, MVPP2_ISR_RXQ_GROUP_REG(port->id), CONFIG_MV_ETH_RXQ); + + /* Create Rx descriptor rings */ + for (queue = 0; queue < rxq_number; queue++) { + struct mvpp2_rx_queue *rxq = port->rxqs[queue]; + + rxq->size = port->rx_ring_size; + rxq->pkts_coal = MVPP2_RX_COAL_PKTS; + rxq->time_coal = MVPP2_RX_COAL_USEC; + } + + mvpp2_ingress_disable(port); + + /* Port default configuration */ + mvpp2_defaults_set(port); + + /* Port's classifier configuration */ + mvpp2_cls_oversize_rxq_set(port); + mvpp2_cls_port_config(port); + + /* Provide an initial Rx packet size */ + port->pkt_size = MVPP2_RX_PKT_SIZE(PKTSIZE_ALIGN); + + /* Initialize pools for swf */ + err = mvpp2_swf_bm_pool_init(port); + if (err) + return err; + + return 0; +} + +/* Ports initialization */ +static int mvpp2_port_probe(struct udevice *dev, + struct mvpp2_port *port, + int port_node, + struct mvpp2 *priv, + int *next_first_rxq) +{ + int phy_node; + u32 id; + u32 phyaddr; + const char *phy_mode_str; + int phy_mode = -1; + int priv_common_regs_num = 2; + int err; + + phy_node = fdtdec_lookup_phandle(gd->fdt_blob, port_node, "phy"); + if (phy_node < 0) { + dev_err(&pdev->dev, "missing phy\n"); + return -ENODEV; + } + + phy_mode_str = fdt_getprop(gd->fdt_blob, port_node, "phy-mode", NULL); + if (phy_mode_str) + phy_mode = phy_get_interface_by_name(phy_mode_str); + if (phy_mode == -1) { + dev_err(&pdev->dev, "incorrect phy mode\n"); + return -EINVAL; + } + + id = fdtdec_get_int(gd->fdt_blob, port_node, "port-id", -1); + if (id == -1) { + dev_err(&pdev->dev, "missing port-id value\n"); + return -EINVAL; + } + + phyaddr = fdtdec_get_int(gd->fdt_blob, phy_node, "reg", 0); + + port->priv = priv; + port->id = id; + port->first_rxq = *next_first_rxq; + port->phy_node = phy_node; + port->phy_interface = phy_mode; + port->phyaddr = phyaddr; + + port->base = (void __iomem *)dev_get_addr_index(dev->parent, + priv_common_regs_num + + id); + if (IS_ERR(port->base)) + return PTR_ERR(port->base); + + port->tx_ring_size = MVPP2_MAX_TXD; + port->rx_ring_size = MVPP2_MAX_RXD; + + err = mvpp2_port_init(dev, port); + if (err < 0) { + dev_err(&pdev->dev, "failed to init port %d\n", id); + return err; + } + mvpp2_port_power_up(port); + + /* Increment the first Rx queue number to be used by the next port */ + *next_first_rxq += CONFIG_MV_ETH_RXQ; + priv->port_list[id] = port; + return 0; +} + +/* Initialize decoding windows */ +static void mvpp2_conf_mbus_windows(const struct mbus_dram_target_info *dram, + struct mvpp2 *priv) +{ + u32 win_enable; + int i; + + for (i = 0; i < 6; i++) { + mvpp2_write(priv, MVPP2_WIN_BASE(i), 0); + mvpp2_write(priv, MVPP2_WIN_SIZE(i), 0); + + if (i < 4) + mvpp2_write(priv, MVPP2_WIN_REMAP(i), 0); + } + + win_enable = 0; + + for (i = 0; i < dram->num_cs; i++) { + const struct mbus_dram_window *cs = dram->cs + i; + + mvpp2_write(priv, MVPP2_WIN_BASE(i), + (cs->base & 0xffff0000) | (cs->mbus_attr << 8) | + dram->mbus_dram_target_id); + + mvpp2_write(priv, MVPP2_WIN_SIZE(i), + (cs->size - 1) & 0xffff0000); + + win_enable |= (1 << i); + } + + mvpp2_write(priv, MVPP2_BASE_ADDR_ENABLE, win_enable); +} + +/* Initialize Rx FIFO's */ +static void mvpp2_rx_fifo_init(struct mvpp2 *priv) +{ + int port; + + for (port = 0; port < MVPP2_MAX_PORTS; port++) { + mvpp2_write(priv, MVPP2_RX_DATA_FIFO_SIZE_REG(port), + MVPP2_RX_FIFO_PORT_DATA_SIZE); + mvpp2_write(priv, MVPP2_RX_ATTR_FIFO_SIZE_REG(port), + MVPP2_RX_FIFO_PORT_ATTR_SIZE); + } + + mvpp2_write(priv, MVPP2_RX_MIN_PKT_SIZE_REG, + MVPP2_RX_FIFO_PORT_MIN_PKT); + mvpp2_write(priv, MVPP2_RX_FIFO_INIT_REG, 0x1); +} + +/* Initialize network controller common part HW */ +static int mvpp2_init(struct udevice *dev, struct mvpp2 *priv) +{ + const struct mbus_dram_target_info *dram_target_info; + int err, i; + u32 val; + + /* Checks for hardware constraints (U-Boot uses only one rxq) */ + if ((rxq_number > MVPP2_MAX_RXQ) || (txq_number > MVPP2_MAX_TXQ)) { + dev_err(&pdev->dev, "invalid queue size parameter\n"); + return -EINVAL; + } + + /* MBUS windows configuration */ + dram_target_info = mvebu_mbus_dram_info(); + if (dram_target_info) + mvpp2_conf_mbus_windows(dram_target_info, priv); + + /* Disable HW PHY polling */ + val = readl(priv->lms_base + MVPP2_PHY_AN_CFG0_REG); + val |= MVPP2_PHY_AN_STOP_SMI0_MASK; + writel(val, priv->lms_base + MVPP2_PHY_AN_CFG0_REG); + + /* Allocate and initialize aggregated TXQs */ + priv->aggr_txqs = devm_kcalloc(dev, num_present_cpus(), + sizeof(struct mvpp2_tx_queue), + GFP_KERNEL); + if (!priv->aggr_txqs) + return -ENOMEM; + + for_each_present_cpu(i) { + priv->aggr_txqs[i].id = i; + priv->aggr_txqs[i].size = MVPP2_AGGR_TXQ_SIZE; + err = mvpp2_aggr_txq_init(dev, &priv->aggr_txqs[i], + MVPP2_AGGR_TXQ_SIZE, i, priv); + if (err < 0) + return err; + } + + /* Rx Fifo Init */ + mvpp2_rx_fifo_init(priv); + + /* Reset Rx queue group interrupt configuration */ + for (i = 0; i < MVPP2_MAX_PORTS; i++) + mvpp2_write(priv, MVPP2_ISR_RXQ_GROUP_REG(i), + CONFIG_MV_ETH_RXQ); + + writel(MVPP2_EXT_GLOBAL_CTRL_DEFAULT, + priv->lms_base + MVPP2_MNG_EXTENDED_GLOBAL_CTRL_REG); + + /* Allow cache snoop when transmiting packets */ + mvpp2_write(priv, MVPP2_TX_SNOOP_REG, 0x1); + + /* Buffer Manager initialization */ + err = mvpp2_bm_init(dev, priv); + if (err < 0) + return err; + + /* Parser default initialization */ + err = mvpp2_prs_default_init(dev, priv); + if (err < 0) + return err; + + /* Classifier default initialization */ + mvpp2_cls_init(priv); + + return 0; +} + +/* SMI / MDIO functions */ + +static int smi_wait_ready(struct mvpp2 *priv) +{ + u32 timeout = MVPP2_SMI_TIMEOUT; + u32 smi_reg; + + /* wait till the SMI is not busy */ + do { + /* read smi register */ + smi_reg = readl(priv->lms_base + MVPP2_SMI); + if (timeout-- == 0) { + printf("Error: SMI busy timeout\n"); + return -EFAULT; + } + } while (smi_reg & MVPP2_SMI_BUSY); + + return 0; +} + +/* + * mpp2_mdio_read - miiphy_read callback function. + * + * Returns 16bit phy register value, or 0xffff on error + */ +static int mpp2_mdio_read(struct mii_dev *bus, int addr, int devad, int reg) +{ + struct mvpp2 *priv = bus->priv; + u32 smi_reg; + u32 timeout; + + /* check parameters */ + if (addr > MVPP2_PHY_ADDR_MASK) { + printf("Error: Invalid PHY address %d\n", addr); + return -EFAULT; + } + + if (reg > MVPP2_PHY_REG_MASK) { + printf("Err: Invalid register offset %d\n", reg); + return -EFAULT; + } + + /* wait till the SMI is not busy */ + if (smi_wait_ready(priv) < 0) + return -EFAULT; + + /* fill the phy address and regiser offset and read opcode */ + smi_reg = (addr << MVPP2_SMI_DEV_ADDR_OFFS) + | (reg << MVPP2_SMI_REG_ADDR_OFFS) + | MVPP2_SMI_OPCODE_READ; + + /* write the smi register */ + writel(smi_reg, priv->lms_base + MVPP2_SMI); + + /* wait till read value is ready */ + timeout = MVPP2_SMI_TIMEOUT; + + do { + /* read smi register */ + smi_reg = readl(priv->lms_base + MVPP2_SMI); + if (timeout-- == 0) { + printf("Err: SMI read ready timeout\n"); + return -EFAULT; + } + } while (!(smi_reg & MVPP2_SMI_READ_VALID)); + + /* Wait for the data to update in the SMI register */ + for (timeout = 0; timeout < MVPP2_SMI_TIMEOUT; timeout++) + ; + + return readl(priv->lms_base + MVPP2_SMI) & MVPP2_SMI_DATA_MASK; +} + +/* + * mpp2_mdio_write - miiphy_write callback function. + * + * Returns 0 if write succeed, -EINVAL on bad parameters + * -ETIME on timeout + */ +static int mpp2_mdio_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value) +{ + struct mvpp2 *priv = bus->priv; + u32 smi_reg; + + /* check parameters */ + if (addr > MVPP2_PHY_ADDR_MASK) { + printf("Error: Invalid PHY address %d\n", addr); + return -EFAULT; + } + + if (reg > MVPP2_PHY_REG_MASK) { + printf("Err: Invalid register offset %d\n", reg); + return -EFAULT; + } + + /* wait till the SMI is not busy */ + if (smi_wait_ready(priv) < 0) + return -EFAULT; + + /* fill the phy addr and reg offset and write opcode and data */ + smi_reg = value << MVPP2_SMI_DATA_OFFS; + smi_reg |= (addr << MVPP2_SMI_DEV_ADDR_OFFS) + | (reg << MVPP2_SMI_REG_ADDR_OFFS); + smi_reg &= ~MVPP2_SMI_OPCODE_READ; + + /* write the smi register */ + writel(smi_reg, priv->lms_base + MVPP2_SMI); + + return 0; +} + +static int mvpp2_probe(struct udevice *dev) +{ + struct mvpp2_port *port = dev_get_priv(dev); + struct mvpp2 *priv; + struct mii_dev *bus; + void *bd_space; + int err; + u32 size = 0; + int i; + + /* + * This function is called multiple times. For each controller. + * But we only need to do the main controller probing once. So + * lets only do the port probing here, if called not for the + * first time. + */ + if (buffer_loc.tx_descs) { + priv = buffer_loc.priv; + port->priv = priv; + + err = mvpp2_port_probe(dev, port, dev->of_offset, priv, + &buffer_loc.first_rxq); + + return 0; + } + + /* + * U-Boot special buffer handling: + * + * Allocate buffer area for descs and rx_buffers. This is only + * done once for all interfaces. As only one interface can + * be active. Make this area DMA save by disabling the D-cache + */ + + /* Align buffer area for descs and rx_buffers to 1MiB */ + bd_space = memalign(1 << MMU_SECTION_SHIFT, BD_SPACE); + mmu_set_region_dcache_behaviour((u32)bd_space, BD_SPACE, DCACHE_OFF); + + buffer_loc.aggr_tx_descs = (struct mvpp2_tx_desc *)bd_space; + size += MVPP2_AGGR_TXQ_SIZE * MVPP2_DESC_ALIGNED_SIZE; + + buffer_loc.tx_descs = (struct mvpp2_tx_desc *)((u32)bd_space + size); + size += MVPP2_MAX_TXD * MVPP2_DESC_ALIGNED_SIZE; + + buffer_loc.rx_descs = (struct mvpp2_rx_desc *)((u32)bd_space + size); + size += MVPP2_MAX_RXD * MVPP2_DESC_ALIGNED_SIZE; + + for (i = 0; i < MVPP2_BM_POOLS_NUM; i++) { + buffer_loc.bm_pool[i] = (u32 *)((u32)bd_space + size); + size += MVPP2_BM_POOL_SIZE_MAX * sizeof(u32); + } + + for (i = 0; i < MVPP2_BM_LONG_BUF_NUM; i++) { + buffer_loc.rx_buffer[i] = (u32 *)((u32)bd_space + size); + size += RX_BUFFER_SIZE; + } + + /* + * This is done only once, for the first controller that is + * probed. Here the common structures are initialized. + */ + priv = calloc(1, sizeof(struct mvpp2)); + if (!priv) + return -ENOMEM; + + /* And save pointer to main mvpp2 struct */ + port->priv = priv; + buffer_loc.priv = priv; + + priv->base = (void *)dev_get_addr_index(dev->parent, 0); + if (IS_ERR(priv->base)) + return PTR_ERR(priv->base); + + priv->lms_base = (void *)dev_get_addr_index(dev->parent, 1); + if (IS_ERR(priv->lms_base)) + return PTR_ERR(priv->lms_base); + + /* Initialize network controller */ + err = mvpp2_init(dev, priv); + if (err < 0) { + dev_err(&pdev->dev, "failed to initialize controller\n"); + return err; + } + + err = mvpp2_port_probe(dev, port, dev->of_offset, priv, + &buffer_loc.first_rxq); + + /* + * Finally create and register the MDIO bus driver + */ + bus = mdio_alloc(); + if (!bus) { + printf("Failed to allocate MDIO bus\n"); + return -ENOMEM; + } + + bus->read = mpp2_mdio_read; + bus->write = mpp2_mdio_write; + snprintf(bus->name, sizeof(bus->name), dev->name); + bus->priv = (void *)priv; + priv->bus = bus; + + return mdio_register(bus); +} + +static int mvpp2_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct mvpp2_port *port = dev_get_priv(dev); + struct mvpp2_rx_desc *rx_desc; + struct mvpp2_bm_pool *bm_pool; + dma_addr_t phys_addr; + u32 bm, rx_status; + int pool, rx_bytes, err; + int rx_received; + struct mvpp2_rx_queue *rxq; + u32 cause_rx_tx, cause_rx, cause_misc; + u8 *data; + + cause_rx_tx = mvpp2_read(port->priv, + MVPP2_ISR_RX_TX_CAUSE_REG(port->id)); + cause_rx_tx &= ~MVPP2_CAUSE_TXQ_OCCUP_DESC_ALL_MASK; + cause_misc = cause_rx_tx & MVPP2_CAUSE_MISC_SUM_MASK; + if (!cause_rx_tx && !cause_misc) + return 0; + + cause_rx = cause_rx_tx & MVPP2_CAUSE_RXQ_OCCUP_DESC_ALL_MASK; + + /* Process RX packets */ + cause_rx |= port->pending_cause_rx; + rxq = mvpp2_get_rx_queue(port, cause_rx); + + /* Get number of received packets and clamp the to-do */ + rx_received = mvpp2_rxq_received(port, rxq->id); + + /* Return if no packets are received */ + if (!rx_received) + return 0; + + rx_desc = mvpp2_rxq_next_desc_get(rxq); + rx_status = rx_desc->status; + rx_bytes = rx_desc->data_size - MVPP2_MH_SIZE; + phys_addr = rx_desc->buf_phys_addr; + + bm = mvpp2_bm_cookie_build(rx_desc); + pool = mvpp2_bm_cookie_pool_get(bm); + bm_pool = &port->priv->bm_pools[pool]; + + /* Check if buffer header is used */ + if (rx_status & MVPP2_RXD_BUF_HDR) + return 0; + + /* In case of an error, release the requested buffer pointer + * to the Buffer Manager. This request process is controlled + * by the hardware, and the information about the buffer is + * comprised by the RX descriptor. + */ + if (rx_status & MVPP2_RXD_ERR_SUMMARY) { + mvpp2_rx_error(port, rx_desc); + /* Return the buffer to the pool */ + mvpp2_pool_refill(port, bm, rx_desc->buf_phys_addr, + rx_desc->buf_cookie); + return 0; + } + + err = mvpp2_rx_refill(port, bm_pool, bm, phys_addr); + if (err) { + netdev_err(port->dev, "failed to refill BM pools\n"); + return 0; + } + + /* Update Rx queue management counters */ + mb(); + mvpp2_rxq_status_update(port, rxq->id, 1, 1); + + /* give packet to stack - skip on first n bytes */ + data = (u8 *)phys_addr + 2 + 32; + + if (rx_bytes <= 0) + return 0; + + /* + * No cache invalidation needed here, since the rx_buffer's are + * located in a uncached memory region + */ + *packetp = data; + + return rx_bytes; +} + +/* Drain Txq */ +static void mvpp2_txq_drain(struct mvpp2_port *port, struct mvpp2_tx_queue *txq, + int enable) +{ + u32 val; + + mvpp2_write(port->priv, MVPP2_TXQ_NUM_REG, txq->id); + val = mvpp2_read(port->priv, MVPP2_TXQ_PREF_BUF_REG); + if (enable) + val |= MVPP2_TXQ_DRAIN_EN_MASK; + else + val &= ~MVPP2_TXQ_DRAIN_EN_MASK; + mvpp2_write(port->priv, MVPP2_TXQ_PREF_BUF_REG, val); +} + +static int mvpp2_send(struct udevice *dev, void *packet, int length) +{ + struct mvpp2_port *port = dev_get_priv(dev); + struct mvpp2_tx_queue *txq, *aggr_txq; + struct mvpp2_tx_desc *tx_desc; + int tx_done; + int timeout; + + txq = port->txqs[0]; + aggr_txq = &port->priv->aggr_txqs[smp_processor_id()]; + + /* Get a descriptor for the first part of the packet */ + tx_desc = mvpp2_txq_next_desc_get(aggr_txq); + tx_desc->phys_txq = txq->id; + tx_desc->data_size = length; + tx_desc->packet_offset = (u32)packet & MVPP2_TX_DESC_ALIGN; + tx_desc->buf_phys_addr = (u32)packet & ~MVPP2_TX_DESC_ALIGN; + /* First and Last descriptor */ + tx_desc->command = MVPP2_TXD_L4_CSUM_NOT | MVPP2_TXD_IP_CSUM_DISABLE + | MVPP2_TXD_F_DESC | MVPP2_TXD_L_DESC; + + /* Flush tx data */ + flush_dcache_range((u32)packet, (u32)packet + length); + + /* Enable transmit */ + mb(); + mvpp2_aggr_txq_pend_desc_add(port, 1); + + mvpp2_write(port->priv, MVPP2_TXQ_NUM_REG, txq->id); + + timeout = 0; + do { + if (timeout++ > 10000) { + printf("timeout: packet not sent from aggregated to phys TXQ\n"); + return 0; + } + tx_done = mvpp2_txq_pend_desc_num_get(port, txq); + } while (tx_done); + + /* Enable TXQ drain */ + mvpp2_txq_drain(port, txq, 1); + + timeout = 0; + do { + if (timeout++ > 10000) { + printf("timeout: packet not sent\n"); + return 0; + } + tx_done = mvpp2_txq_sent_desc_proc(port, txq); + } while (!tx_done); + + /* Disable TXQ drain */ + mvpp2_txq_drain(port, txq, 0); + + return 0; +} + +static int mvpp2_start(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct mvpp2_port *port = dev_get_priv(dev); + + /* Load current MAC address */ + memcpy(port->dev_addr, pdata->enetaddr, ETH_ALEN); + + /* Reconfigure parser accept the original MAC address */ + mvpp2_prs_update_mac_da(port, port->dev_addr); + + mvpp2_port_power_up(port); + + mvpp2_open(dev, port); + + return 0; +} + +static void mvpp2_stop(struct udevice *dev) +{ + struct mvpp2_port *port = dev_get_priv(dev); + + mvpp2_stop_dev(port); + mvpp2_cleanup_rxqs(port); + mvpp2_cleanup_txqs(port); +} + +static const struct eth_ops mvpp2_ops = { + .start = mvpp2_start, + .send = mvpp2_send, + .recv = mvpp2_recv, + .stop = mvpp2_stop, +}; + +static struct driver mvpp2_driver = { + .name = "mvpp2", + .id = UCLASS_ETH, + .probe = mvpp2_probe, + .ops = &mvpp2_ops, + .priv_auto_alloc_size = sizeof(struct mvpp2_port), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; + +/* + * Use a MISC device to bind the n instances (child nodes) of the + * network base controller in UCLASS_ETH. + */ +static int mvpp2_base_bind(struct udevice *parent) +{ + const void *blob = gd->fdt_blob; + int node = parent->of_offset; + struct uclass_driver *drv; + struct udevice *dev; + struct eth_pdata *plat; + char *name; + int subnode; + u32 id; + + /* Lookup eth driver */ + drv = lists_uclass_lookup(UCLASS_ETH); + if (!drv) { + puts("Cannot find eth driver\n"); + return -ENOENT; + } + + fdt_for_each_subnode(blob, subnode, node) { + /* Skip disabled ports */ + if (!fdtdec_get_is_enabled(blob, subnode)) + continue; + + plat = calloc(1, sizeof(*plat)); + if (!plat) + return -ENOMEM; + + id = fdtdec_get_int(blob, subnode, "port-id", -1); + + name = calloc(1, 16); + sprintf(name, "mvpp2-%d", id); + + /* Create child device UCLASS_ETH and bind it */ + device_bind(parent, &mvpp2_driver, name, plat, subnode, &dev); + dev->of_offset = subnode; + } + + return 0; +} + +static const struct udevice_id mvpp2_ids[] = { + { .compatible = "marvell,armada-375-pp2" }, + { } +}; + +U_BOOT_DRIVER(mvpp2_base) = { + .name = "mvpp2_base", + .id = UCLASS_MISC, + .of_match = mvpp2_ids, + .bind = mvpp2_base_bind, +};
Hi Joe,
On 15.03.2016 17:35, Stefan Roese wrote:
This patch adds support for the mvpp2 ethernet controller which is integrated in the Marvell Armada 375 SoC. This port is based on the Linux driver (v4.4), which has been stripped of the in U-Boot unused portions.
Tested on the Marvell Armada 375 eval board db-88f6720.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr Cc: Joe Hershberger joe.hershberger@gmail.com
Joe, did you have the time to take a look at this driver implementation? If you have no objections, I would like to push this via the marvell / mvebu git tree into mainline to avoid merge conflicts.
So please let me know what you think.
Thanks, Stefan
Hit Stefan,
Sorry for the delay.
drivers/net/Kconfig | 8 + drivers/net/Makefile | 1 + drivers/net/mvpp2.c | 4222 ++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 4231 insertions(+) create mode 100644 drivers/net/mvpp2.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index bc2f51d..bcb4c96 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -94,6 +94,14 @@ config ETH_DESIGNWARE 100Mbit and 1 Gbit operation. You must enable CONFIG_PHYLIB to provide the PHY (physical media interface).
+config MVPP2
bool "Marvell Armada 375 network interface support"
depends on ARMADA_375
select PHYLIB
help
This driver supports the network interface units in the
Marvell ARMADA 375 SoC.
config PCH_GBE bool "Intel Platform Controller Hub EG20T GMAC driver" depends on DM_ETH && DM_PCI diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 33a81ee..fbedd04 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -42,6 +42,7 @@ obj-$(CONFIG_MPC5xxx_FEC) += mpc5xxx_fec.o obj-$(CONFIG_MPC512x_FEC) += mpc512x_fec.o obj-$(CONFIG_MVGBE) += mvgbe.o obj-$(CONFIG_MVNETA) += mvneta.o +obj-$(CONFIG_MVPP2) += mvpp2.o obj-$(CONFIG_NATSEMI) += natsemi.o obj-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o obj-$(CONFIG_DRIVER_AX88796L) += ax88796.o ne2000_base.o diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c new file mode 100644 index 0000000..09dfc7e --- /dev/null +++ b/drivers/net/mvpp2.c @@ -0,0 +1,4222 @@ +/*
- Driver for Marvell PPv2 network controller for Armada 375 SoC.
- Copyright (C) 2014 Marvell
- Marcin Wojtas mw@semihalf.com
- U-Boot version:
- Copyright (C) 2016 Stefan Roese sr@denx.de
- This file is licensed under the terms of the GNU General Public
- License version 2. This program is licensed "as is" without any
- warranty of any kind, whether express or implied.
+#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <net.h> +#include <netdev.h> +#include <config.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <phy.h> +#include <miiphy.h> +#include <watchdog.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <linux/compat.h> +#include <linux/mbus.h>
+DECLARE_GLOBAL_DATA_PTR;
+#if !defined(CONFIG_PHYLIB) +# error Marvell mvpp2 requires PHYLIB +#endif
This isn't needed since you "select" PHYLIB in the Kconfig.
+/* Some linux -> U-Boot compatibility stuff */ +#define netdev_err(dev, fmt, args...) \
printf(fmt, ##args)
+#define netdev_warn(dev, fmt, args...) \
printf(fmt, ##args)
+#define netdev_info(dev, fmt, args...) \
printf(fmt, ##args)
+#define netdev_dbg(dev, fmt, args...) \
printf(fmt, ##args)
+#define ETH_ALEN 6 /* Octets in one ethernet addr */
+#define ETH_P_IP 0x0800 /* Internet Protocol packet */
Already available in include/net.h as PROT_IP
+#define ETH_P_PPP_SES 0x8864 /* PPPoE session messages */
Add this to include/net.h as PROT_PPP_SES
+#define ETH_P_ARP 0x0806 /* Address Resolution packet */
Already available in include/net.h as PROT_ARP
+#define ETH_P_IPV6 0x86DD /* IPv6 over bluebook */
Add this to include/net.h as PROT_IPV6
+#define __verify_pcpu_ptr(ptr) \ +do { \
const void __percpu *__vpp_verify = (typeof((ptr) + 0))NULL; \
(void)__vpp_verify; \
+} while (0)
+#define VERIFY_PERCPU_PTR(__p) \ +({ \
__verify_pcpu_ptr(__p); \
(typeof(*(__p)) __kernel __force *)(__p); \
+#define per_cpu_ptr(ptr, cpu) ({ (void)(cpu); VERIFY_PERCPU_PTR(ptr); }) +#define smp_processor_id() 0 +#define num_present_cpus() 1 +#define for_each_present_cpu(cpu) \
for ((cpu) = 0; (cpu) < 1; (cpu)++)
+#define NET_SKB_PAD max(32, MVPP2_CPU_D_CACHE_LINE_SIZE)
+#define CONFIG_NR_CPUS 1 +#define ETH_HLEN 14 /* Total octets in header */
Already available in include/net.h as ETHER_HDR_SIZE.
+/* 2(HW hdr) 14(MAC hdr) 4(CRC) 32(extra for cache prefetch) */ +#define WRAP (2 + ETH_HLEN + 4 + 32) +#define MTU 1500 +#define RX_BUFFER_SIZE (ALIGN(MTU + WRAP, ARCH_DMA_MINALIGN))
<snip - constants>
- Page table entries are set to 1MB, or multiples of 1MB
- (not < 1MB). driver uses less bd's so use 1MB bdspace.
+#define BD_SPACE (1 << 20)
It would be great if this long list of constants lived in a header file instead of the top of the source.
+/* Utility/helper methods */
+static void mvpp2_write(struct mvpp2 *priv, u32 offset, u32 data) +{
writel(data, priv->base + offset);
+static u32 mvpp2_read(struct mvpp2 *priv, u32 offset) +{
return readl(priv->base + offset);
<snip>
if (!phy_dev) {
return -ENODEV;
port->link = 0;
port->duplex = 0;
port->speed = 0;
return -1;
port->init = 1;
} else {
int err;
if (err) {
return err;
if (err) {
return err;
if (err) {
return err;
if (err) {
return err;
if (err) {
return err;
if (err < 0)
return err;
return -EINVAL;
/* Disable port */
GFP_KERNEL);
if (!port->txqs)
return -ENOMEM;
if (!txq)
return -ENOMEM;
GFP_KERNEL);
if (!txq->pcpu)
return -ENOMEM;
GFP_KERNEL);
if (!port->rxqs)
return -ENOMEM;
if (!rxq)
return -ENOMEM;
if (err)
return err;
int port_node,
struct mvpp2 *priv,
int phy_node;
u32 id;
u32 phyaddr;
int phy_mode = -1;
int err;
if (phy_node < 0) {
return -ENODEV;
if (phy_mode_str)
return -EINVAL;
if (id == -1) {
return -EINVAL;
port->priv = priv;
port->id = id;
+ id);
if (err < 0) {
return err;
struct mvpp2 *priv)
u32 win_enable;
int i;
if (i < 4)
win_enable = 0;
int port;
int err, i;
u32 val;
return -EINVAL;
GFP_KERNEL);
return -ENOMEM;
if (err < 0)
return err;
/* Rx Fifo Init */
CONFIG_MV_ETH_RXQ);
if (err < 0)
return err;
if (err < 0)
return err;
u32 smi_reg;
do {
return -EFAULT;
- mpp2_mdio_read - miiphy_read callback function.
- Returns 16bit phy register value, or 0xffff on error
u32 smi_reg;
u32 timeout;
return -EFAULT;
return -EFAULT;
return -EFAULT;
do {
return -EFAULT;
- mpp2_mdio_write - miiphy_write callback function.
- Returns 0 if write succeed, -EINVAL on bad parameters
- -ETIME on timeout
u16 value)
u32 smi_reg;
return -EFAULT;
return -EFAULT;
return -EFAULT;
struct mvpp2 *priv;
void *bd_space;
int err;
u32 size = 0;
int i;
* first time.
port->priv = priv;
DMA save -> DMA-safe
Any reason this isn't in the probe function for the MISC class parent driver?
if (!priv)
return -ENOMEM;
port->priv = priv;
if (err < 0) {
return err;
bus = mdio_alloc();
if (!bus) {
return -ENOMEM;
priv->bus = bus;
u32 bm, rx_status;
int rx_received;
u8 *data;
if (!rx_received)
if (err) {
mb();
if (rx_bytes <= 0)
*packetp = data;
return rx_bytes;
int enable)
u32 val;
if (enable)
else
int tx_done;
int timeout;
/* Flush tx data */
mb();
timeout = 0;
do {
} while (tx_done);
timeout = 0;
do {
} while (!tx_done);
.send = mvpp2_send,
.recv = mvpp2_recv,
.stop = mvpp2_stop,
.name = "mvpp2",
.id = UCLASS_ETH,
.ops = &mvpp2_ops,
- Use a MISC device to bind the n instances (child nodes) of the
- network base controller in UCLASS_ETH.
char *name;
int subnode;
u32 id;
if (!drv) {
return -ENOENT;
continue;
if (!plat)
return -ENOMEM;
.id = UCLASS_MISC,
2.7.3
Mostly looks good to me.
-Joe
Hi Joe,
No problem. Thanks for the review.
+config MVPP2
select PHYLIB
help
- config PCH_GBE bool "Intel Platform Controller Hub EG20T GMAC driver" depends on DM_ETH && DM_PCI
- U-Boot version:
Good catch. Removed in v2.
printf(fmt, ##args)
printf(fmt, ##args)
printf(fmt, ##args)
printf(fmt, ##args)
Changed to use these U-Boot defines instead. Thanks.
Does it perhaps make sense to globally change all those U-Boot defines to the Linux ones instead?
+} while (0)
<snip - constants>
I'm not a big fan of using headers, when the macros / defines etc are only referenced by this one file. Additionally, the original Linux driver also includes all this in the C file. So it makes syncing easier. I would like to keep it in one file.
<snip>
if (!phy_dev) {
return -ENODEV;
port->link = 0;
port->duplex = 0;
port->speed = 0;
return -1;
port->init = 1;
} else {
int err;
if (err) {
return err;
if (err) {
return err;
if (err) {
return err;
if (err) {
return err;
if (err) {
return err;
if (err < 0)
return err;
return -EINVAL;
/* Disable port */
GFP_KERNEL);
if (!port->txqs)
return -ENOMEM;
if (!txq)
return -ENOMEM;
GFP_KERNEL);
if (!txq->pcpu)
return -ENOMEM;
GFP_KERNEL);
if (!port->rxqs)
return -ENOMEM;
if (!rxq)
return -ENOMEM;
if (err)
return err;
int port_node,
struct mvpp2 *priv,
int phy_node;
u32 id;
u32 phyaddr;
int phy_mode = -1;
int err;
if (phy_node < 0) {
return -ENODEV;
if (phy_mode_str)
return -EINVAL;
if (id == -1) {
return -EINVAL;
port->priv = priv;
port->id = id;
+ id);
if (err < 0) {
return err;
struct mvpp2 *priv)
u32 win_enable;
int i;
if (i < 4)
win_enable = 0;
int port;
int err, i;
u32 val;
return -EINVAL;
GFP_KERNEL);
return -ENOMEM;
if (err < 0)
return err;
/* Rx Fifo Init */
CONFIG_MV_ETH_RXQ);
if (err < 0)
return err;
if (err < 0)
return err;
u32 smi_reg;
do {
return -EFAULT;
u32 smi_reg;
u32 timeout;
return -EFAULT;
return -EFAULT;
return -EFAULT;
do {
return -EFAULT;
- -ETIME on timeout
u16 value)
u32 smi_reg;
return -EFAULT;
return -EFAULT;
return -EFAULT;
struct mvpp2 *priv;
void *bd_space;
int err;
u32 size = 0;
int i;
* first time.
port->priv = priv;
Fixed.
Not really. I've moved most of this into the new probe function of the parent driver. Looks much cleaner this may. Thanks.
if (!priv)
return -ENOMEM;
port->priv = priv;
if (err < 0) {
return err;
bus = mdio_alloc();
if (!bus) {
return -ENOMEM;
priv->bus = bus;
u32 bm, rx_status;
int rx_received;
u8 *data;
if (!rx_received)
if (err) {
mb();
if (rx_bytes <= 0)
*packetp = data;
return rx_bytes;
int enable)
u32 val;
if (enable)
else
int tx_done;
int timeout;
/* Flush tx data */
mb();
timeout = 0;
do {
} while (tx_done);
timeout = 0;
do {
} while (!tx_done);
.send = mvpp2_send,
.recv = mvpp2_recv,
.stop = mvpp2_stop,
.name = "mvpp2",
.id = UCLASS_ETH,
.ops = &mvpp2_ops,
char *name;
int subnode;
u32 id;
if (!drv) {
return -ENOENT;
continue;
if (!plat)
return -ENOMEM;
.id = UCLASS_MISC,
2.7.3
Thanks for the review. v2 coming shortly...
Thanks, Stefan
Hi Stefan,
On Wed, Mar 23, 2016 at 1:39 AM, Stefan Roese sr@denx.de wrote:
Hi Joe,
+config MVPP2
select PHYLIB
help
- U-Boot version:
printf(fmt, ##args)
printf(fmt, ##args)
printf(fmt, ##args)
printf(fmt, ##args)
That sounds like a good idea to me.
+} while (0)
<snip - constants>
OK.
<snip>
dev,
if (!phy_dev) {
return -ENODEV;
port->link = 0;
port->duplex = 0;
port->speed = 0;
return -1;
port->init = 1;
} else {
int err;
true);
if (err) {
return err;
if (err) {
return err;
if (err) {
return err;
if (err) {
return err;
if (err) {
return err;
if (err < 0)
return err;
return -EINVAL;
/* Disable port */
GFP_KERNEL);
if (!port->txqs)
return -ENOMEM;
if (!txq)
return -ENOMEM;
mvpp2_txq_pcpu),
GFP_KERNEL);
if (!txq->pcpu)
return -ENOMEM;
GFP_KERNEL);
if (!port->rxqs)
return -ENOMEM;
if (!rxq)
return -ENOMEM;
CONFIG_MV_ETH_RXQ);
if (err)
return err;
int port_node,
struct mvpp2 *priv,
int phy_node;
u32 id;
u32 phyaddr;
int phy_mode = -1;
int err;
if (phy_node < 0) {
return -ENODEV;
NULL);
if (phy_mode_str)
return -EINVAL;
if (id == -1) {
return -EINVAL;
port->priv = priv;
port->id = id;
+ id);
if (err < 0) {
return err;
port */
struct mvpp2 *priv)
u32 win_enable;
int i;
if (i < 4)
win_enable = 0;
int port;
int err, i;
u32 val;
return -EINVAL;
GFP_KERNEL);
return -ENOMEM;
if (err < 0)
return err;
/* Rx Fifo Init */
CONFIG_MV_ETH_RXQ);
if (err < 0)
return err;
if (err < 0)
return err;
u32 smi_reg;
do {
return -EFAULT;
u32 smi_reg;
u32 timeout;
return -EFAULT;
return -EFAULT;
return -EFAULT;
do {
return -EFAULT;
- -ETIME on timeout
u16 value)
u32 smi_reg;
return -EFAULT;
return -EFAULT;
return -EFAULT;
struct mvpp2 *priv;
void *bd_space;
int err;
u32 size = 0;
int i;
* first time.
port->priv = priv;
Fixed.
DCACHE_OFF);
size);
size);
if (!priv)
return -ENOMEM;
port->priv = priv;
if (err < 0) {
return err;
bus = mdio_alloc();
if (!bus) {
return -ENOMEM;
priv->bus = bus;
u32 bm, rx_status;
int rx_received;
u8 *data;
if (!rx_received)
if (err) {
mb();
if (rx_bytes <= 0)
*packetp = data;
return rx_bytes;
int enable)
u32 val;
if (enable)
else
int tx_done;
int timeout;
/* Flush tx data */
mb();
timeout = 0;
do {
to phys TXQ\n");
} while (tx_done);
timeout = 0;
do {
} while (!tx_done);
.send = mvpp2_send,
.recv = mvpp2_recv,
.stop = mvpp2_stop,
.name = "mvpp2",
.id = UCLASS_ETH,
.ops = &mvpp2_ops,
char *name;
int subnode;
u32 id;
if (!drv) {
return -ENOENT;
continue;
if (!plat)
return -ENOMEM;
&dev);
.id = UCLASS_MISC,
2.7.3
Thanks, Stefan
This will be needed by the upcoming Marvell Armada 375 dts files.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- include/dt-bindings/phy/phy.h | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+) create mode 100644 include/dt-bindings/phy/phy.h
diff --git a/include/dt-bindings/phy/phy.h b/include/dt-bindings/phy/phy.h new file mode 100644 index 0000000..6c90193 --- /dev/null +++ b/include/dt-bindings/phy/phy.h @@ -0,0 +1,19 @@ +/* + * + * This header provides constants for the phy framework + * + * Copyright (C) 2014 STMicroelectronics + * Author: Gabriel Fernandez gabriel.fernandez@st.com + * License terms: GNU General Public License (GPL), version 2 + */ + +#ifndef _DT_BINDINGS_PHY +#define _DT_BINDINGS_PHY + +#define PHY_NONE 0 +#define PHY_TYPE_SATA 1 +#define PHY_TYPE_PCIE 2 +#define PHY_TYPE_USB2 3 +#define PHY_TYPE_USB3 4 + +#endif /* _DT_BINDINGS_PHY */
Applied to u-boot-marvell/master.
Thanks, Stefan
This patch adds basic support for the Armada 375. Please note that currently the SerDes and DDR3 init code for the A375 is not included / enabled. This will be done in a later, follow-up patch.
Right now, this A375 mainline U-Boot can only be used by chainloading it via the original Marvell U-Boot. This can be done via this command:
=> tftpboot 00800000 a375/u-boot-dtb.bin;go 00800000
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/cpu.c | 64 +++++++++++++++++++++++++++++-- arch/arm/mach-mvebu/include/mach/config.h | 5 ++- arch/arm/mach-mvebu/include/mach/cpu.h | 5 +++ arch/arm/mach-mvebu/include/mach/soc.h | 19 ++++++++- arch/arm/mach-mvebu/spl.c | 3 ++ 6 files changed, 92 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index b96b81b..ac009a3 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -15,6 +15,7 @@ else obj-y = cpu.o obj-y += dram.o ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_ARMADA_375) += ../../../drivers/ddr/marvell/axp/xor.o obj-$(CONFIG_ARMADA_38X) += ../../../drivers/ddr/marvell/a38x/xor.o obj-$(CONFIG_ARMADA_XP) += ../../../drivers/ddr/marvell/axp/xor.o endif diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 30b175c..9913802 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -54,17 +54,57 @@ int mvebu_soc_family(void) case SOC_MV78260_ID: case SOC_MV78460_ID: return MVEBU_SOC_AXP; + + case SOC_88F6720_ID: + return MVEBU_SOC_A375; + case SOC_88F6810_ID: case SOC_88F6820_ID: case SOC_88F6828_ID: return MVEBU_SOC_A38X; } + return MVEBU_SOC_UNKNOWN; }
#if defined(CONFIG_DISPLAY_CPUINFO)
-#if defined(CONFIG_ARMADA_38X) +#if defined(CONFIG_ARMADA_375) +/* SAR frequency values for Armada 375 */ +static const struct sar_freq_modes sar_freq_tab[] = { + { 0, 0x0, 266, 133, 266 }, + { 1, 0x0, 333, 167, 167 }, + { 2, 0x0, 333, 167, 222 }, + { 3, 0x0, 333, 167, 333 }, + { 4, 0x0, 400, 200, 200 }, + { 5, 0x0, 400, 200, 267 }, + { 6, 0x0, 400, 200, 400 }, + { 7, 0x0, 500, 250, 250 }, + { 8, 0x0, 500, 250, 334 }, + { 9, 0x0, 500, 250, 500 }, + { 10, 0x0, 533, 267, 267 }, + { 11, 0x0, 533, 267, 356 }, + { 12, 0x0, 533, 267, 533 }, + { 13, 0x0, 600, 300, 300 }, + { 14, 0x0, 600, 300, 400 }, + { 15, 0x0, 600, 300, 600 }, + { 16, 0x0, 666, 333, 333 }, + { 17, 0x0, 666, 333, 444 }, + { 18, 0x0, 666, 333, 666 }, + { 19, 0x0, 800, 400, 267 }, + { 20, 0x0, 800, 400, 400 }, + { 21, 0x0, 800, 400, 534 }, + { 22, 0x0, 900, 450, 300 }, + { 23, 0x0, 900, 450, 450 }, + { 24, 0x0, 900, 450, 600 }, + { 25, 0x0, 1000, 500, 500 }, + { 26, 0x0, 1000, 500, 667 }, + { 27, 0x0, 1000, 333, 500 }, + { 28, 0x0, 400, 400, 400 }, + { 29, 0x0, 1100, 550, 550 }, + { 0xff, 0xff, 0, 0, 0 } /* 0xff marks end of array */ +}; +#elif defined(CONFIG_ARMADA_38X) /* SAR frequency values for Armada 38x */ static const struct sar_freq_modes sar_freq_tab[] = { { 0x0, 0x0, 666, 333, 333 }, @@ -98,9 +138,13 @@ void get_sar_freq(struct sar_freq_modes *sar_freq) u32 freq; int i;
+#if defined(CONFIG_ARMADA_375) + val = readl(CONFIG_SAR2_REG); /* SAR - Sample At Reset */ +#else val = readl(CONFIG_SAR_REG); /* SAR - Sample At Reset */ +#endif freq = (val & SAR_CPU_FREQ_MASK) >> SAR_CPU_FREQ_OFFS; -#if !defined(CONFIG_ARMADA_38X) +#if defined(SAR2_CPU_FREQ_MASK) /* * Shift CPU0 clock frequency select bit from SAR2 register * into correct position @@ -110,7 +154,7 @@ void get_sar_freq(struct sar_freq_modes *sar_freq) #endif for (i = 0; sar_freq_tab[i].val != 0xff; i++) { if (sar_freq_tab[i].val == freq) { -#if defined(CONFIG_ARMADA_38X) +#if defined(CONFIG_ARMADA_375) || defined(CONFIG_ARMADA_38X) *sar_freq = sar_freq_tab[i]; return; #else @@ -152,6 +196,9 @@ int print_cpuinfo(void) case SOC_MV78460_ID: puts("MV78460-"); break; + case SOC_88F6720_ID: + puts("MV88F6720-"); + break; case SOC_88F6810_ID: puts("MV88F6810-"); break; @@ -180,6 +227,17 @@ int print_cpuinfo(void) } }
+ if (mvebu_soc_family() == MVEBU_SOC_A375) { + switch (revid) { + case MV_88F67XX_A0_ID: + puts("A0"); + break; + default: + printf("?? (%x)", revid); + break; + } + } + if (mvebu_soc_family() == MVEBU_SOC_A38X) { switch (revid) { case MV_88F68XX_Z1_ID: diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index cc1fc5f..b8a8c62 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -17,7 +17,8 @@
-#if defined(CONFIG_ARMADA_XP) || defined(CONFIG_ARMADA_38X) +#if defined(CONFIG_ARMADA_XP) || defined(CONFIG_ARMADA_375) \ + || defined(CONFIG_ARMADA_38X) /* * Set this for the common xor register definitions needed in dram.c * for A38x as well here. @@ -78,8 +79,10 @@ #ifdef CONFIG_CMD_NET #define CONFIG_CMD_MII #define CONFIG_MII /* expose smi ove miiphy interface */ +#if !defined(CONFIG_ARMADA_375) #define CONFIG_MVNETA /* Enable Marvell Gbe Controller Driver */ #define CONFIG_PHYLIB +#endif #define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ #define CONFIG_PHY_GIGE /* GbE speed/duplex detect */ #define CONFIG_ARP_TIMEOUT 200 diff --git a/arch/arm/mach-mvebu/include/mach/cpu.h b/arch/arm/mach-mvebu/include/mach/cpu.h index 017d55f..b71574d 100644 --- a/arch/arm/mach-mvebu/include/mach/cpu.h +++ b/arch/arm/mach-mvebu/include/mach/cpu.h @@ -58,6 +58,7 @@ enum cpu_attrib {
enum { MVEBU_SOC_AXP, + MVEBU_SOC_A375, MVEBU_SOC_A38X, MVEBU_SOC_UNKNOWN, }; @@ -86,7 +87,11 @@ struct mbus_win { * Ref: Datasheet sec:A.28 */ struct mvebu_system_registers { +#if defined(CONFIG_ARMADA_375) + u8 pad1[0x54]; +#else u8 pad1[0x60]; +#endif u32 rstoutn_mask; /* 0x60 */ u32 sys_soft_rst; /* 0x64 */ }; diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index b317940..a12be2a 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -14,10 +14,14 @@ #define SOC_MV78230_ID 0x7823 #define SOC_MV78260_ID 0x7826 #define SOC_MV78460_ID 0x7846 +#define SOC_88F6720_ID 0x6720 #define SOC_88F6810_ID 0x6810 #define SOC_88F6820_ID 0x6820 #define SOC_88F6828_ID 0x6828
+/* A375 revisions */ +#define MV_88F67XX_A0_ID 0x3 + /* A38x revisions */ #define MV_88F68XX_Z1_ID 0x0 #define MV_88F68XX_A0_ID 0x4 @@ -106,7 +110,20 @@ #define BOOTROM_ERR_MODE_MASK (0xf << BOOTROM_ERR_MODE_OFFS) #define BOOTROM_ERR_MODE_UART 0x6
-#if defined(CONFIG_ARMADA_38X) +#if defined(CONFIG_ARMADA_375) +/* SAR values for Armada 375 */ +#define CONFIG_SAR_REG (MVEBU_REGISTER(0xe8200)) +#define CONFIG_SAR2_REG (MVEBU_REGISTER(0xe8204)) + +#define SAR_CPU_FREQ_OFFS 17 +#define SAR_CPU_FREQ_MASK (0x1f << SAR_CPU_FREQ_OFFS) + +#define BOOT_DEV_SEL_OFFS 3 +#define BOOT_DEV_SEL_MASK (0x3f << BOOT_DEV_SEL_OFFS) + +#define BOOT_FROM_UART 0x30 +#define BOOT_FROM_SPI 0x38 +#elif defined(CONFIG_ARMADA_38X) /* SAR values for Armada 38x */ #define CONFIG_SAR_REG (MVEBU_REGISTER(0x18600))
diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index 0879873..ac5bb2c 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -99,11 +99,14 @@ void board_init_f(ulong dummy)
timer_init();
+ /* Armada 375 does not support SerDes and DDR3 init yet */ +#if !defined(CONFIG_ARMADA_375) /* First init the serdes PHY's */ serdes_phy_config();
/* Setup DDR */ ddr3_init(); +#endif
/* * Return to the BootROM to continue the Marvell xmodem
Thanks, Stefan
This patch adds basic support for the Marvell A375 eval board. Tested are the following interfaces: - I2C - SPI - SPI NOR - Ethernet (mvpp2), port 0 & 1
Currently the A375 SerDes and DDR3 init code is not intergrated. So the SPL U-Boot is not fully functional.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/Kconfig | 2 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-375-db.dts | 216 +++++++++++ arch/arm/dts/armada-375.dtsi | 658 ++++++++++++++++++++++++++++++++++ arch/arm/mach-mvebu/Kconfig | 12 +- board/Marvell/db-88f6720/MAINTAINERS | 6 + board/Marvell/db-88f6720/Makefile | 7 + board/Marvell/db-88f6720/db-88f6720.c | 91 +++++ board/Marvell/db-88f6720/kwbimage.cfg | 12 + configs/db-88f6720_defconfig | 28 ++ include/configs/db-88f6720.h | 120 +++++++ 11 files changed, 1151 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/armada-375-db.dts create mode 100644 arch/arm/dts/armada-375.dtsi create mode 100644 board/Marvell/db-88f6720/MAINTAINERS create mode 100644 board/Marvell/db-88f6720/Makefile create mode 100644 board/Marvell/db-88f6720/db-88f6720.c create mode 100644 board/Marvell/db-88f6720/kwbimage.cfg create mode 100644 configs/db-88f6720_defconfig create mode 100644 include/configs/db-88f6720.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 653ecc8..26e4e7f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -111,7 +111,7 @@ config KIRKWOOD select CPU_ARM926EJS
config ARCH_MVEBU - bool "Marvell MVEBU family (Armada XP/38x)" + bool "Marvell MVEBU family (Armada XP/375/38x)" select CPU_V7 select SUPPORT_SPL select OF_CONTROL diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 578038b..c37f24e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -49,6 +49,7 @@ dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra210-p2571.dtb
dtb-$(CONFIG_ARCH_MVEBU) += \ + armada-375-db.dtb \ armada-388-clearfog.dtb \ armada-388-gp.dtb \ armada-xp-gp.dtb \ diff --git a/arch/arm/dts/armada-375-db.dts b/arch/arm/dts/armada-375-db.dts new file mode 100644 index 0000000..343349b --- /dev/null +++ b/arch/arm/dts/armada-375-db.dts @@ -0,0 +1,216 @@ +/* + * Device Tree file for Marvell Armada 375 evaluation board + * (DB-88F6720) + * + * Copyright (C) 2014 Marvell + * + * Gregory CLEMENT gregory.clement@free-electrons.com + * Thomas Petazzoni thomas.petazzoni@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include "armada-375.dtsi" + +/ { + model = "Marvell Armada 375 Development Board"; + compatible = "marvell,a375-db", "marvell,armada375"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + /* So that mvebu u-boot can update the MAC addresses */ + ethernet0 = ð0; + ethernet1 = ð1; + spi0 = &spi0; + }; + + memory { + device_type = "memory"; + reg = <0x00000000 0x40000000>; /* 1 GB */ + }; + + soc { + ranges = <MBUS_ID(0xf0, 0x01) 0 0xf1000000 0x100000 + MBUS_ID(0x01, 0x1d) 0 0xfff00000 0x100000 + MBUS_ID(0x09, 0x09) 0 0xf1100000 0x10000 + MBUS_ID(0x09, 0x05) 0 0xf1110000 0x10000>; + + internal-regs { + spi@10600 { + pinctrl-0 = <&spi0_pins>; + pinctrl-names = "default"; + /* + * SPI conflicts with NAND, so we disable it + * here, and select NAND as the enabled device + * by default. + */ + status = "okay"; + u-boot,dm-pre-reloc; + + spi-flash@0 { + u-boot,dm-pre-reloc; + #address-cells = <1>; + #size-cells = <1>; + compatible = "n25q128a13", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <108000000>; + }; + }; + + i2c@11000 { + status = "okay"; + clock-frequency = <100000>; + pinctrl-0 = <&i2c0_pins>; + pinctrl-names = "default"; + }; + + i2c@11100 { + status = "okay"; + clock-frequency = <100000>; + pinctrl-0 = <&i2c1_pins>; + pinctrl-names = "default"; + }; + + serial@12000 { + u-boot,dm-pre-reloc; + status = "okay"; + }; + + pinctrl { + sdio_st_pins: sdio-st-pins { + marvell,pins = "mpp44", "mpp45"; + marvell,function = "gpio"; + }; + }; + + sata@a0000 { + status = "okay"; + nr-ports = <2>; + }; + + nand: nand@d0000 { + pinctrl-0 = <&nand_pins>; + pinctrl-names = "default"; + status = "okay"; + num-cs = <1>; + marvell,nand-keep-config; + marvell,nand-enable-arbiter; + nand-on-flash-bbt; + nand-ecc-strength = <4>; + nand-ecc-step-size = <512>; + + partition@0 { + label = "U-Boot"; + reg = <0 0x800000>; + }; + partition@800000 { + label = "Linux"; + reg = <0x800000 0x800000>; + }; + partition@1000000 { + label = "Filesystem"; + reg = <0x1000000 0x3f000000>; + }; + }; + + usb@54000 { + status = "okay"; + }; + + usb3@58000 { + status = "okay"; + }; + + mvsdio@d4000 { + pinctrl-0 = <&sdio_pins &sdio_st_pins>; + pinctrl-names = "default"; + status = "okay"; + cd-gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>; + wp-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>; + }; + + mdio { + phy0: ethernet-phy@0 { + reg = <0>; + }; + + phy3: ethernet-phy@3 { + reg = <3>; + }; + }; + + ethernet@f0000 { + status = "okay"; + + eth0@c4000 { + status = "okay"; + phy = <&phy0>; + phy-mode = "rgmii-id"; + }; + + eth1@c5000 { + status = "okay"; + phy = <&phy3>; + phy-mode = "gmii"; + }; + }; + }; + + pcie-controller { + status = "okay"; + /* + * The two PCIe units are accessible through + * standard PCIe slots on the board. + */ + pcie@1,0 { + /* Port 0, Lane 0 */ + status = "okay"; + }; + pcie@2,0 { + /* Port 1, Lane 0 */ + status = "okay"; + }; + }; + }; +}; diff --git a/arch/arm/dts/armada-375.dtsi b/arch/arm/dts/armada-375.dtsi new file mode 100644 index 0000000..249c41c --- /dev/null +++ b/arch/arm/dts/armada-375.dtsi @@ -0,0 +1,658 @@ +/* + * Device Tree Include file for Marvell Armada 375 family SoC + * + * Copyright (C) 2014 Marvell + * + * Gregory CLEMENT gregory.clement@free-electrons.com + * Thomas Petazzoni thomas.petazzoni@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include "skeleton.dtsi" +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/phy/phy.h> + +#define MBUS_ID(target,attributes) (((target) << 24) | ((attributes) << 16)) + +/ { + model = "Marvell Armada 375 family SoC"; + compatible = "marvell,armada375"; + + aliases { + gpio0 = &gpio0; + gpio1 = &gpio1; + gpio2 = &gpio2; + serial0 = &uart0; + serial1 = &uart1; + }; + + clocks { + /* 2 GHz fixed main PLL */ + mainpll: mainpll { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <1000000000>; + }; + /* 25 MHz reference crystal */ + refclk: oscillator { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + enable-method = "marvell,armada-375-smp"; + + cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <0>; + }; + cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <1>; + }; + }; + + pmu { + compatible = "arm,cortex-a9-pmu"; + interrupts-extended = <&mpic 3>; + }; + + soc { + compatible = "marvell,armada375-mbus", "simple-bus"; + u-boot,dm-pre-reloc; + #address-cells = <2>; + #size-cells = <1>; + controller = <&mbusc>; + interrupt-parent = <&gic>; + pcie-mem-aperture = <0xe0000000 0x8000000>; + pcie-io-aperture = <0xe8000000 0x100000>; + + bootrom { + compatible = "marvell,bootrom"; + reg = <MBUS_ID(0x01, 0x1d) 0 0x100000>; + }; + + devbus-bootcs { + compatible = "marvell,mvebu-devbus"; + reg = <MBUS_ID(0xf0, 0x01) 0x10400 0x8>; + ranges = <0 MBUS_ID(0x01, 0x2f) 0 0xffffffff>; + #address-cells = <1>; + #size-cells = <1>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + devbus-cs0 { + compatible = "marvell,mvebu-devbus"; + reg = <MBUS_ID(0xf0, 0x01) 0x10408 0x8>; + ranges = <0 MBUS_ID(0x01, 0x3e) 0 0xffffffff>; + #address-cells = <1>; + #size-cells = <1>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + devbus-cs1 { + compatible = "marvell,mvebu-devbus"; + reg = <MBUS_ID(0xf0, 0x01) 0x10410 0x8>; + ranges = <0 MBUS_ID(0x01, 0x3d) 0 0xffffffff>; + #address-cells = <1>; + #size-cells = <1>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + devbus-cs2 { + compatible = "marvell,mvebu-devbus"; + reg = <MBUS_ID(0xf0, 0x01) 0x10418 0x8>; + ranges = <0 MBUS_ID(0x01, 0x3b) 0 0xffffffff>; + #address-cells = <1>; + #size-cells = <1>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + devbus-cs3 { + compatible = "marvell,mvebu-devbus"; + reg = <MBUS_ID(0xf0, 0x01) 0x10420 0x8>; + ranges = <0 MBUS_ID(0x01, 0x37) 0 0xffffffff>; + #address-cells = <1>; + #size-cells = <1>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + internal-regs { + compatible = "simple-bus"; + u-boot,dm-pre-reloc; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 MBUS_ID(0xf0, 0x01) 0 0x100000>; + + L2: cache-controller@8000 { + compatible = "arm,pl310-cache"; + reg = <0x8000 0x1000>; + cache-unified; + cache-level = <2>; + arm,double-linefill-incr = <1>; + arm,double-linefill-wrap = <0>; + arm,double-linefill = <1>; + prefetch-data = <1>; + }; + + scu@c000 { + compatible = "arm,cortex-a9-scu"; + reg = <0xc000 0x58>; + }; + + timer@c600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0xc600 0x20>; + interrupts = <GIC_PPI 13 (IRQ_TYPE_EDGE_RISING | GIC_CPU_MASK_SIMPLE(2))>; + clocks = <&coreclk 2>; + }; + + gic: interrupt-controller@d000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + #size-cells = <0>; + interrupt-controller; + reg = <0xd000 0x1000>, + <0xc100 0x100>; + }; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + compatible = "marvell,orion-mdio"; + reg = <0xc0054 0x4>; + clocks = <&gateclk 19>; + }; + + /* Network controller */ + ethernet@f0000 { + compatible = "marvell,armada-375-pp2"; + reg = <0xf0000 0xa000>, /* Packet Processor regs */ + <0xc0000 0x3060>, /* LMS regs */ + <0xc4000 0x100>, /* eth0 regs */ + <0xc5000 0x100>; /* eth1 regs */ + clocks = <&gateclk 3>, <&gateclk 19>; + clock-names = "pp_clk", "gop_clk"; + status = "disabled"; + + eth0: eth0@c4000 { + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + port-id = <0>; + status = "disabled"; + }; + + eth1: eth1@c5000 { + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + port-id = <1>; + status = "disabled"; + }; + }; + + rtc@10300 { + compatible = "marvell,orion-rtc"; + reg = <0x10300 0x20>; + interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; + }; + + spi0: spi@10600 { + compatible = "marvell,armada-375-spi", + "marvell,orion-spi"; + reg = <0x10600 0x50>; + #address-cells = <1>; + #size-cells = <0>; + cell-index = <0>; + interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + spi1: spi@10680 { + compatible = "marvell,armada-375-spi", + "marvell,orion-spi"; + reg = <0x10680 0x50>; + #address-cells = <1>; + #size-cells = <0>; + cell-index = <1>; + interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + i2c0: i2c@11000 { + compatible = "marvell,mv64xxx-i2c"; + reg = <0x11000 0x20>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; + timeout-ms = <1000>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + i2c1: i2c@11100 { + compatible = "marvell,mv64xxx-i2c"; + reg = <0x11100 0x20>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; + timeout-ms = <1000>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + uart0: serial@12000 { + compatible = "snps,dw-apb-uart"; + reg = <0x12000 0x100>; + reg-shift = <2>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + reg-io-width = <1>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + uart1: serial@12100 { + compatible = "snps,dw-apb-uart"; + reg = <0x12100 0x100>; + reg-shift = <2>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + reg-io-width = <1>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + pinctrl { + compatible = "marvell,mv88f6720-pinctrl"; + reg = <0x18000 0x24>; + + i2c0_pins: i2c0-pins { + marvell,pins = "mpp14", "mpp15"; + marvell,function = "i2c0"; + }; + + i2c1_pins: i2c1-pins { + marvell,pins = "mpp61", "mpp62"; + marvell,function = "i2c1"; + }; + + nand_pins: nand-pins { + marvell,pins = "mpp0", "mpp1", "mpp2", + "mpp3", "mpp4", "mpp5", + "mpp6", "mpp7", "mpp8", + "mpp9", "mpp10", "mpp11", + "mpp12", "mpp13"; + marvell,function = "nand"; + }; + + sdio_pins: sdio-pins { + marvell,pins = "mpp24", "mpp25", "mpp26", + "mpp27", "mpp28", "mpp29"; + marvell,function = "sd"; + }; + + spi0_pins: spi0-pins { + marvell,pins = "mpp0", "mpp1", "mpp4", + "mpp5", "mpp8", "mpp9"; + marvell,function = "spi0"; + }; + }; + + gpio0: gpio@18100 { + compatible = "marvell,orion-gpio"; + reg = <0x18100 0x40>; + ngpios = <32>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; + }; + + gpio1: gpio@18140 { + compatible = "marvell,orion-gpio"; + reg = <0x18140 0x40>; + ngpios = <32>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + }; + + gpio2: gpio@18180 { + compatible = "marvell,orion-gpio"; + reg = <0x18180 0x40>; + ngpios = <3>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + }; + + system-controller@18200 { + compatible = "marvell,armada-375-system-controller"; + reg = <0x18200 0x100>; + }; + + gateclk: clock-gating-control@18220 { + compatible = "marvell,armada-375-gating-clock"; + reg = <0x18220 0x4>; + clocks = <&coreclk 0>; + #clock-cells = <1>; + }; + + usbcluster: usb-cluster@18400 { + compatible = "marvell,armada-375-usb-cluster"; + reg = <0x18400 0x4>; + #phy-cells = <1>; + }; + + mbusc: mbus-controller@20000 { + compatible = "marvell,mbus-controller"; + reg = <0x20000 0x100>, <0x20180 0x20>; + }; + + mpic: interrupt-controller@20a00 { + compatible = "marvell,mpic"; + reg = <0x20a00 0x2d0>, <0x21070 0x58>; + #interrupt-cells = <1>; + #size-cells = <1>; + interrupt-controller; + msi-controller; + interrupts = <GIC_PPI 15 IRQ_TYPE_LEVEL_HIGH>; + }; + + timer@20300 { + compatible = "marvell,armada-375-timer", "marvell,armada-370-timer"; + reg = <0x20300 0x30>, <0x21040 0x30>; + interrupts-extended = <&gic GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, + <&mpic 5>, + <&mpic 6>; + clocks = <&coreclk 0>, <&refclk>; + clock-names = "nbclk", "fixed"; + }; + + watchdog@20300 { + compatible = "marvell,armada-375-wdt"; + reg = <0x20300 0x34>, <0x20704 0x4>, <0x18254 0x4>; + clocks = <&coreclk 0>, <&refclk>; + clock-names = "nbclk", "fixed"; + }; + + cpurst@20800 { + compatible = "marvell,armada-370-cpu-reset"; + reg = <0x20800 0x10>; + }; + + coherency-fabric@21010 { + compatible = "marvell,armada-375-coherency-fabric"; + reg = <0x21010 0x1c>; + }; + + usb@50000 { + compatible = "marvell,orion-ehci"; + reg = <0x50000 0x500>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gateclk 18>; + phys = <&usbcluster PHY_TYPE_USB2>; + phy-names = "usb"; + status = "disabled"; + }; + + usb@54000 { + compatible = "marvell,orion-ehci"; + reg = <0x54000 0x500>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gateclk 26>; + status = "disabled"; + }; + + usb3@58000 { + compatible = "marvell,armada-375-xhci"; + reg = <0x58000 0x20000>,<0x5b880 0x80>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gateclk 16>; + phys = <&usbcluster PHY_TYPE_USB3>; + phy-names = "usb"; + status = "disabled"; + }; + + xor@60800 { + compatible = "marvell,orion-xor"; + reg = <0x60800 0x100 + 0x60A00 0x100>; + clocks = <&gateclk 22>; + status = "okay"; + + xor00 { + interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; + dmacap,memcpy; + dmacap,xor; + }; + xor01 { + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + dmacap,memcpy; + dmacap,xor; + dmacap,memset; + }; + }; + + xor@60900 { + compatible = "marvell,orion-xor"; + reg = <0x60900 0x100 + 0x60b00 0x100>; + clocks = <&gateclk 23>; + status = "okay"; + + xor10 { + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; + dmacap,memcpy; + dmacap,xor; + }; + xor11 { + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + dmacap,memcpy; + dmacap,xor; + dmacap,memset; + }; + }; + + crypto@90000 { + compatible = "marvell,armada-375-crypto"; + reg = <0x90000 0x10000>; + reg-names = "regs"; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gateclk 30>, <&gateclk 31>, + <&gateclk 28>, <&gateclk 29>; + clock-names = "cesa0", "cesa1", + "cesaz0", "cesaz1"; + marvell,crypto-srams = <&crypto_sram0>, + <&crypto_sram1>; + marvell,crypto-sram-size = <0x800>; + }; + + sata@a0000 { + compatible = "marvell,orion-sata"; + reg = <0xa0000 0x5000>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gateclk 14>, <&gateclk 20>; + clock-names = "0", "1"; + status = "disabled"; + }; + + nand@d0000 { + compatible = "marvell,armada370-nand"; + reg = <0xd0000 0x54>; + #address-cells = <1>; + #size-cells = <1>; + interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gateclk 11>; + status = "disabled"; + }; + + mvsdio@d4000 { + compatible = "marvell,orion-sdio"; + reg = <0xd4000 0x200>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gateclk 17>; + bus-width = <4>; + cap-sdio-irq; + cap-sd-highspeed; + cap-mmc-highspeed; + status = "disabled"; + }; + + thermal@e8078 { + compatible = "marvell,armada375-thermal"; + reg = <0xe8078 0x4>, <0xe807c 0x8>; + status = "okay"; + }; + + coreclk: mvebu-sar@e8204 { + compatible = "marvell,armada-375-core-clock"; + reg = <0xe8204 0x04>; + #clock-cells = <1>; + }; + + coredivclk: corediv-clock@e8250 { + compatible = "marvell,armada-375-corediv-clock"; + reg = <0xe8250 0xc>; + #clock-cells = <1>; + clocks = <&mainpll>; + clock-output-names = "nand"; + }; + }; + + pcie-controller { + compatible = "marvell,armada-370-pcie"; + status = "disabled"; + device_type = "pci"; + + #address-cells = <3>; + #size-cells = <2>; + + msi-parent = <&mpic>; + bus-range = <0x00 0xff>; + + ranges = + <0x82000000 0 0x40000 MBUS_ID(0xf0, 0x01) 0x40000 0 0x00002000 + 0x82000000 0 0x44000 MBUS_ID(0xf0, 0x01) 0x44000 0 0x00002000 + 0x82000000 0x1 0 MBUS_ID(0x04, 0xe8) 0 1 0 /* Port 0 MEM */ + 0x81000000 0x1 0 MBUS_ID(0x04, 0xe0) 0 1 0 /* Port 0 IO */ + 0x82000000 0x2 0 MBUS_ID(0x04, 0xd8) 0 1 0 /* Port 1 MEM */ + 0x81000000 0x2 0 MBUS_ID(0x04, 0xd0) 0 1 0 /* Port 1 IO */>; + + pcie@1,0 { + device_type = "pci"; + assigned-addresses = <0x82000800 0 0x40000 0 0x2000>; + reg = <0x0800 0 0 0 0>; + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + ranges = <0x82000000 0 0 0x82000000 0x1 0 1 0 + 0x81000000 0 0 0x81000000 0x1 0 1 0>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + marvell,pcie-port = <0>; + marvell,pcie-lane = <0>; + clocks = <&gateclk 5>; + status = "disabled"; + }; + + pcie@2,0 { + device_type = "pci"; + assigned-addresses = <0x82000800 0 0x44000 0 0x2000>; + reg = <0x1000 0 0 0 0>; + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + ranges = <0x82000000 0 0 0x82000000 0x2 0 1 0 + 0x81000000 0 0 0x81000000 0x2 0 1 0>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + marvell,pcie-port = <0>; + marvell,pcie-lane = <1>; + clocks = <&gateclk 6>; + status = "disabled"; + }; + + }; + + crypto_sram0: sa-sram0 { + compatible = "mmio-sram"; + reg = <MBUS_ID(0x09, 0x09) 0 0x800>; + clocks = <&gateclk 30>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 MBUS_ID(0x09, 0x09) 0 0x800>; + }; + + crypto_sram1: sa-sram1 { + compatible = "mmio-sram"; + reg = <MBUS_ID(0x09, 0x05) 0 0x800>; + clocks = <&gateclk 31>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 MBUS_ID(0x09, 0x05) 0 0x800>; + }; + }; +}; diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 96a3313..220886a 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -1,5 +1,8 @@ if ARCH_MVEBU
+config ARMADA_375 + bool + config ARMADA_38X bool
@@ -23,13 +26,17 @@ config DB_88F6820_GP select ARMADA_38X
choice - prompt "Marvell MVEBU (Armada XP/38x) board select" + prompt "Marvell MVEBU (Armada XP/375/38x) board select" optional
config TARGET_CLEARFOG bool "Support ClearFog" select DB_88F6820_GP
+config TARGET_DB_88F6720 + bool "Support DB-88F6720 Armada 375" + select ARMADA_375 + config TARGET_DB_88F6820_GP bool "Support DB-88F6820-GP" select DB_88F6820_GP @@ -54,6 +61,7 @@ endchoice
config SYS_BOARD default "clearfog" if TARGET_CLEARFOG + default "db-88f6720" if TARGET_DB_88F6720 default "db-88f6820-gp" if TARGET_DB_88F6820_GP default "db-mv784mp-gp" if TARGET_DB_MV784MP_GP default "ds414" if TARGET_DS414 @@ -62,6 +70,7 @@ config SYS_BOARD
config SYS_CONFIG_NAME default "clearfog" if TARGET_CLEARFOG + default "db-88f6720" if TARGET_DB_88F6720 default "db-88f6820-gp" if TARGET_DB_88F6820_GP default "db-mv784mp-gp" if TARGET_DB_MV784MP_GP default "ds414" if TARGET_DS414 @@ -70,6 +79,7 @@ config SYS_CONFIG_NAME
config SYS_VENDOR default "Marvell" if TARGET_DB_MV784MP_GP + default "Marvell" if TARGET_DB_88F6720 default "Marvell" if TARGET_DB_88F6820_GP default "solidrun" if TARGET_CLEARFOG default "Synology" if TARGET_DS414 diff --git a/board/Marvell/db-88f6720/MAINTAINERS b/board/Marvell/db-88f6720/MAINTAINERS new file mode 100644 index 0000000..a27d1c2 --- /dev/null +++ b/board/Marvell/db-88f6720/MAINTAINERS @@ -0,0 +1,6 @@ +DB_88F6720 BOARD +M: Stefan Roese sr@denx.de +S: Maintained +F: board/Marvell/db-88f6720/ +F: include/configs/db-88f6720.h +F: configs/db-88f6720_defconfig diff --git a/board/Marvell/db-88f6720/Makefile b/board/Marvell/db-88f6720/Makefile new file mode 100644 index 0000000..7a5b512 --- /dev/null +++ b/board/Marvell/db-88f6720/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2016 Stefan Roese sr@denx.de +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := db-88f6720.o diff --git a/board/Marvell/db-88f6720/db-88f6720.c b/board/Marvell/db-88f6720/db-88f6720.c new file mode 100644 index 0000000..b6e00f3 --- /dev/null +++ b/board/Marvell/db-88f6720/db-88f6720.c @@ -0,0 +1,91 @@ +/* + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Those values and defines are taken from the Marvell U-Boot version + * "u-boot-2013.01-2014_T2.0" for the board Armada 375 DB-88F6720 + */ +#define DB_88F6720_MPP0_7 0x00020020 /* SPI */ +#define DB_88F6720_MPP8_15 0x22000022 /* SPI , I2C */ +#define DB_88F6720_MPP16_23 0x22222222 /* UART, TDM*/ +#define DB_88F6720_MPP24_31 0x33333333 /* SDIO, SPI1*/ +#define DB_88F6720_MPP32_39 0x04403330 /* SPI1, External SMI */ +#define DB_88F6720_MPP40_47 0x22002044 /* UART1, GE0, SATA0 LED */ +#define DB_88F6720_MPP48_55 0x22222222 /* GE0 */ +#define DB_88F6720_MPP56_63 0x04444422 /* GE0 , LED_MATRIX, GPIO */ +#define DB_88F6720_MPP64_67 0x014 /* LED_MATRIX, SATA1 LED*/ + +#define DB_88F6720_GPP_OUT_ENA_LOW 0xFFFFFFFF +#define DB_88F6720_GPP_OUT_ENA_MID 0x7FFFFFFF +#define DB_88F6720_GPP_OUT_ENA_HIGH 0xFFFFFFFF +#define DB_88F6720_GPP_OUT_VAL_LOW 0x0 +#define DB_88F6720_GPP_OUT_VAL_MID BIT(31) /* SATA Power output enable */ +#define DB_88F6720_GPP_OUT_VAL_HIGH 0x0 +#define DB_88F6720_GPP_POL_LOW 0x0 +#define DB_88F6720_GPP_POL_MID 0x0 +#define DB_88F6720_GPP_POL_HIGH 0x0 + +int board_early_init_f(void) +{ + /* Configure MPP */ + writel(DB_88F6720_MPP0_7, MVEBU_MPP_BASE + 0x00); + writel(DB_88F6720_MPP8_15, MVEBU_MPP_BASE + 0x04); + writel(DB_88F6720_MPP16_23, MVEBU_MPP_BASE + 0x08); + writel(DB_88F6720_MPP24_31, MVEBU_MPP_BASE + 0x0c); + writel(DB_88F6720_MPP32_39, MVEBU_MPP_BASE + 0x10); + writel(DB_88F6720_MPP40_47, MVEBU_MPP_BASE + 0x14); + writel(DB_88F6720_MPP48_55, MVEBU_MPP_BASE + 0x18); + writel(DB_88F6720_MPP56_63, MVEBU_MPP_BASE + 0x1c); + writel(DB_88F6720_MPP64_67, MVEBU_MPP_BASE + 0x20); + + /* Configure GPIO */ + /* Set GPP Out value */ + writel(DB_88F6720_GPP_OUT_VAL_LOW, MVEBU_GPIO0_BASE + 0x00); + writel(DB_88F6720_GPP_OUT_VAL_MID, MVEBU_GPIO1_BASE + 0x00); + writel(DB_88F6720_GPP_OUT_VAL_HIGH, MVEBU_GPIO2_BASE + 0x00); + + /* Set GPP Polarity */ + writel(DB_88F6720_GPP_POL_LOW, MVEBU_GPIO0_BASE + 0x0c); + writel(DB_88F6720_GPP_POL_MID, MVEBU_GPIO1_BASE + 0x0c); + writel(DB_88F6720_GPP_POL_HIGH, MVEBU_GPIO2_BASE + 0x0c); + + /* Set GPP Out Enable */ + writel(DB_88F6720_GPP_OUT_ENA_LOW, MVEBU_GPIO0_BASE + 0x04); + writel(DB_88F6720_GPP_OUT_ENA_MID, MVEBU_GPIO1_BASE + 0x04); + writel(DB_88F6720_GPP_OUT_ENA_HIGH, MVEBU_GPIO2_BASE + 0x04); + + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + return 0; +} + +int checkboard(void) +{ + puts("Board: Marvell DB-88F6720\n"); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + cpu_eth_init(bis); /* Built in controller(s) come first */ + return pci_eth_init(bis); +} diff --git a/board/Marvell/db-88f6720/kwbimage.cfg b/board/Marvell/db-88f6720/kwbimage.cfg new file mode 100644 index 0000000..1f748db --- /dev/null +++ b/board/Marvell/db-88f6720/kwbimage.cfg @@ -0,0 +1,12 @@ +# +# Copyright (C) 2014 Stefan Roese sr@denx.de +# + +# Armada XP uses version 1 image format +VERSION 1 + +# Boot Media configurations +BOOT_FROM spi + +# Binary Header (bin_hdr) with DDR3 training code +BINARY spl/u-boot-spl-dtb.bin 0000005b 00000068 diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig new file mode 100644 index 0000000..75bc1f0 --- /dev/null +++ b/configs/db-88f6720_defconfig @@ -0,0 +1,28 @@ +CONFIG_ARM=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_DB_88F6720=y +CONFIG_DEFAULT_DEVICE_TREE="armada-375-db" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_MISC=y +CONFIG_NAND_PXA3XX=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_MVPP2=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0xf1012000 +CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y diff --git a/include/configs/db-88f6720.h b/include/configs/db-88f6720.h new file mode 100644 index 0000000..7f19334 --- /dev/null +++ b/include/configs/db-88f6720.h @@ -0,0 +1,120 @@ +/* + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _CONFIG_DB_88F6720_H +#define _CONFIG_DB_88F6720_H + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_DISPLAY_BOARDINFO_LATE + +/* + * TEXT_BASE needs to be below 16MiB, since this area is scrubbed + * for DDR ECC byte filling in the SPL before loading the main + * U-Boot into it. + */ +#define CONFIG_SYS_TEXT_BASE 0x00800000 +#define CONFIG_SYS_TCLK 200000000 /* 200MHz */ + +/* + * Commands configuration + */ +#define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ENV +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_I2C +#define CONFIG_CMD_PING +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_CMD_TFTPPUT +#define CONFIG_CMD_TIME + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MVTWSI +#define CONFIG_I2C_MVTWSI_BASE0 MVEBU_TWSI_BASE +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_SYS_I2C_SPEED 100000 + +/* USB/EHCI configuration */ +#define CONFIG_EHCI_IS_TDI +#define CONFIG_USB_MAX_CONTROLLER_COUNT 3 + +/* SPI NOR flash default params, used by sf commands */ +#define CONFIG_SF_DEFAULT_SPEED 1000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 + +/* Environment in SPI NOR flash */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ +#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ +#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */ + +#define CONFIG_PHY_MARVELL /* there is a marvell phy */ +#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */ + +#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */ +#define CONFIG_SYS_ALT_MEMTEST + +/* Additional FS support/configuration */ +#define CONFIG_SUPPORT_VFAT + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* + * Memory layout while starting into the bin_hdr via the + * BootROM: + * + * 0x4000.4000 - 0x4003.4000 headers space (192KiB) + * 0x4000.4030 bin_hdr start address + * 0x4003.4000 - 0x4004.7c00 BootROM memory allocations (15KiB) + * 0x4007.fffc BootROM stack top + * + * The address space between 0x4007.fffc and 0x400f.fff is not locked in + * L2 cache thus cannot be used. + */ + +/* SPL */ +/* Defines for SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x40004030 +#define CONFIG_SPL_MAX_SIZE ((128 << 10) - 0x4030) + +#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) +#define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_MALLOC_SIMPLE +#endif + +#define CONFIG_SPL_STACK (0x40000000 + ((192 - 16) << 10)) +#define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4) + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT + +/* SPL related SPI defines */ +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SPL_SPI_BUS 0 +#define CONFIG_SPL_SPI_CS 0 +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 +#define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_OFFS + +#endif /* _CONFIG_DB_88F6720_H */
- I2C
- SPI
- SPI NOR
Thanks, Stefan
Armada 375 still has some problems with d-cache enabled in the ethernet driver (mvpp2). So lets keep the d-cache disabled until this is solved.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/mach-mvebu/cpu.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 9913802..fd66f59 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -536,8 +536,15 @@ void enable_caches(void) /* Avoid problem with e.g. neta ethernet driver */ invalidate_dcache_all();
- /* Enable D-cache. I-cache is already enabled in start.S */ - dcache_enable(); + /* + * Armada 375 still has some problems with d-cache enabled in the + * ethernet driver (mvpp2). So lets keep the d-cache disabled + * until this is solved. + */ + if (mvebu_soc_family() != MVEBU_SOC_A375) { + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); + } }
void v7_outer_cache_enable(void)
Thanks, Stefan
On 15 March 2016 at 22:05, Stefan Roese sr@denx.de wrote:
This enables this driver for the Marvell Armada 375 SoC.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr Cc: Jagan Teki jteki@openedev.com
Reviewed-by: Jagan Teki jteki@openedev.com
Thanks, Stefan
Jagan Teki
Joe Hershberger
Stefan Roese
