[U-Boot] [PATCH v2] cmd: env: print a message when setting UEFI variable failed
Error message will alert a user that setting/deleting a variable failed.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- Changes in v2 (May 24, 2019) * change a message to "Out of memory" * add more error messages --- cmd/nvedit_efi.c | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/cmd/nvedit_efi.c b/cmd/nvedit_efi.c index 2805e8182b41..88d6ca1cd7f2 100644 --- a/cmd/nvedit_efi.c +++ b/cmd/nvedit_efi.c @@ -373,6 +373,8 @@ int do_env_set_efi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
for ( ; argc > 0; argc--, argv++) if (append_value(&value, &size, argv[0]) < 0) { + printf("## Failed to process an argument, %s\n", + argv[0]); ret = CMD_RET_FAILURE; goto out; } @@ -381,6 +383,7 @@ int do_env_set_efi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) len = utf8_utf16_strnlen(var_name, strlen(var_name)); var_name16 = malloc((len + 1) * 2); if (!var_name16) { + printf("## Out of memory (%ld bytes)\n", (len + 1) * 2); ret = CMD_RET_FAILURE; goto out; } @@ -392,7 +395,13 @@ int do_env_set_efi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) EFI_VARIABLE_BOOTSERVICE_ACCESS | EFI_VARIABLE_RUNTIME_ACCESS, size, value)); - ret = (ret == EFI_SUCCESS ? CMD_RET_SUCCESS : CMD_RET_FAILURE); + if (ret == EFI_SUCCESS) { + ret = CMD_RET_SUCCESS; + } else { + printf("## Failed to set EFI variable (%ld)\n", + ret & ~EFI_ERROR_MASK); + ret = CMD_RET_FAILURE; + } out: free(value); free(var_name16);
- change a message to "Out of memory"
- add more error messages
cmd/nvedit_efi.c: In function ‘do_env_set_efi’: cmd/nvedit_efi.c:386:31: warning: format ‘%ld’ expects argument of type ‘long int’, but argument 2 has type ‘size_t’ {aka ‘unsigned int’} [-Wformat=] printf("## Out of memory (%ld bytes)\n", (len + 1) * 2); ~~^ ~~~~~~~~~~~~~ %d
If you want to print the number of bytes use %zu. But why should the user care if it is 10 bytes or 100 bytes that could not be assigned? If he is out of memory here anyway the system is messed up.
- if (ret == EFI_SUCCESS) {
- } else {
ret has type size_t so this has to %zu.
Think of a non-developer user who bought a device with pre-installedö U-Boot. What would he do with the error code?
Best regards
Heinrich
Can you please clarify what you want me to do? Otherwise, I cannot submit a next version.
- } else {
Ditto.
Thanks, -Takahiro Akashi
Best regards
Heinrich
I would suggest to leave the size information away.
- } else {
Ditto.
I would suggest to leave the return code away.
Best regards
Heinrich
Best regards
Heinrich
- } out: free(value); free(var_name16);
AKASHI Takahiro
