[PATCH 1/1] power: pmic_pca9450: fix PCA9450A I2C address
PCA9450A I2C address is 0x25. Fix it.
Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com --- drivers/power/pmic/pmic_pca9450.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/power/pmic/pmic_pca9450.c b/drivers/power/pmic/pmic_pca9450.c index 67a9090200..c0fb78c4cd 100644 --- a/drivers/power/pmic/pmic_pca9450.c +++ b/drivers/power/pmic/pmic_pca9450.c @@ -23,7 +23,7 @@ int power_pca9450a_init(unsigned char bus) p->name = pca9450_name; p->interface = PMIC_I2C; p->number_of_regs = PCA9450_REG_NUM; - p->hw.i2c.addr = 0x35; + p->hw.i2c.addr = 0x25; p->hw.i2c.tx_num = 1; p->bus = bus;
On Mon, 2020-06-29 at 10:42 +0200, Sébastien Szymanski wrote:
Caution: EXT Email
The address 0x35 is correct for PCA9540A. You are probably using PCA9540B/C which address is 0x25. If so, please call power_pca9450b_init.
Best regards, Ye Li
-- 2.26.2
Caution: EXT Email
No. I am using a PCA9450A chip and its address is 0x25:
# i2cget -f -y 0 0x25 0x00 0x10
Moreover, the datasheet says it's 0x25. [1]
[1] https://www.nxp.com/docs/en/data-sheet/PCA9450DS.pdf
Regards,
Best regards, Ye Li
-- 2.26.2
On Mon, 2020-06-29 at 12:11 +0200, Sébastien Szymanski wrote:
Caution: EXT Email
Caution: EXT Email
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus. com>
[1] https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2 Fwww.nxp.com%2Fdocs%2Fen%2Fdata- sheet%2FPCA9450DS.pdf&data=02%7C01%7Cye.li%40nxp.com%7Cf58d2e0f30 7045ca2b7408d81c14d040%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C1%7C6 37290222999360806&sdata=cLYNDpYxwFaDrMSq%2B%2F2bivTXw9a8BAkUgTf3% 2B5mWcWg%3D&reserved=0
Regards,
Our doc shows the i2c address has a choice by MTP.
The I2C address at Power-On Reset is as follows: • Write address: 0x6A ( MTP Option : 4A ) • Read address: 0x6B ( MTP Option : 4B )
And we also has an 8MM board (not for customer) using PCA9450A with 0x35 address.
Best regards, Ye Li
Best regards, Ye Li
-- 2.26.2
-- Sébastien Szymanski, Armadeus Systems Software engineer
Sébastien Szymanski
Ye Li
