[U-Boot] [PATCH] ARM: DTS: Resync am3517-evm.dts with Linux 4.18-rc4
Several changes have been made to the AM3517-evm and the underlying am3517.dtsi file. This patch re-sync's the DTS and DTSI files with Linux.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/am3517-evm.dts b/arch/arm/dts/am3517-evm.dts index 0e4a125f78..98aadb0f81 100644 --- a/arch/arm/dts/am3517-evm.dts +++ b/arch/arm/dts/am3517-evm.dts @@ -8,11 +8,17 @@ /dts-v1/;
#include "am3517.dtsi" +#include "am3517-som.dtsi" +#include <dt-bindings/input/input.h>
/ { model = "TI AM3517 EVM (AM3517/05 TMDSEVM3517)"; compatible = "ti,am3517-evm", "ti,am3517", "ti,omap3";
+ aliases { + display0 = &lcd0; + }; + memory@80000000 { device_type = "memory"; reg = <0x80000000 0x10000000>; /* 256 MB */ @@ -24,6 +30,144 @@ regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; }; + + gpio-keys { + compatible = "gpio-keys-polled"; + poll-interval = <100>; + + user_pb { + label = "User Push Button"; + linux,code = <BTN_0>; + gpios = <&tca6416 5 GPIO_ACTIVE_LOW>; + }; + + user_sw_1 { + label = "User Switch 1"; + linux,code = <BTN_1>; + gpios = <&tca6416 8 GPIO_ACTIVE_LOW>; + }; + + user_sw_2 { + label = "User Switch 2"; + linux,code = <BTN_2>; + gpios = <&tca6416 9 GPIO_ACTIVE_LOW>; + }; + + user_sw_3 { + label = "User Switch 3"; + linux,code = <BTN_3>; + gpios = <&tca6416 10 GPIO_ACTIVE_LOW>; + }; + + user_sw_4 { + label = "User Switch 4"; + linux,code = <BTN_4>; + gpios = <&tca6416 11 GPIO_ACTIVE_LOW>; + }; + + user_sw_5 { + label = "User Switch 5"; + linux,code = <BTN_5>; + gpios = <&tca6416 12 GPIO_ACTIVE_LOW>; + }; + + user_sw_6 { + label = "User Switch 6"; + linux,code = <BTN_6>; + gpios = <&tca6416 13 GPIO_ACTIVE_LOW>; + }; + + user_sw_7 { + label = "User Switch 7"; + linux,code = <BTN_7>; + gpios = <&tca6416 14 GPIO_ACTIVE_LOW>; + }; + + user_sw_8 { + label = "User Switch 8"; + linux,code = <BTN_8>; + gpios = <&tca6416 15 GPIO_ACTIVE_LOW>; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + + pinctrl-names = "default"; + pinctrl-0 = <&leds_pins>; + + user_led_1 { + label = "am3517evm:green:user_led_1"; + gpios = <&tca6416 7 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + + user_led_2 { + label = "am3517evm:green:user_led_2"; + gpios = <&tca6416 6 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + + user_led_3 { + label = "am3517evm:green:user_led_3"; + gpios = <&gpio1 11 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; /* SD/MMC card activity */ + }; + + user_led_4 { + label = "am3517evm:green:user_led_4"; + gpios = <&gpio1 31 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + lcd0: display@0 { + compatible = "panel-dpi"; + label = "15"; + status = "okay"; + pinctrl-names = "default"; + enable-gpios = <&gpio6 16 GPIO_ACTIVE_HIGH>; /* gpio176, lcd INI */ + + port { + lcd_in: endpoint { + remote-endpoint = <&dpi_out>; + }; + }; + + panel-timing { + clock-frequency = <9000000>; + hactive = <480>; + vactive = <272>; + hfront-porch = <3>; + hback-porch = <2>; + hsync-len = <42>; + vback-porch = <3>; + vfront-porch = <4>; + vsync-len = <11>; + hsync-active = <0>; + vsync-active = <0>; + de-active = <1>; + pixelclk-active = <1>; + }; + }; + + bl: backlight { + compatible = "pwm-backlight"; + pinctrl-names = "default"; + pinctrl-0 = <&backlight_pins>; + pwms = <&pwm11 0 5000000 0>; + brightness-levels = <0 10 20 30 40 50 60 70 80 90 100>; + default-brightness-level = <7>; + enable-gpios = <&gpio6 22 GPIO_ACTIVE_HIGH>; /* gpio_182 */ + }; + + pwm11: dmtimer-pwm@11 { + compatible = "ti,omap-dmtimer-pwm"; + pinctrl-names = "default"; + pinctrl-0 = <&pwm_pins>; + ti,timers = <&timer11>; + #pwm-cells = <3>; + }; };
&davinci_emac { @@ -34,12 +178,32 @@ status = "okay"; };
-&i2c1 { - clock-frequency = <400000>; +&dss { + status = "ok"; + + pinctrl-names = "default"; + pinctrl-0 = <&dss_dpi_pins>; + + vdds_dsi-supply = <&vdd_io_reg>; + vdda_video-supply = <&vdd_io_reg>; + + port { + dpi_out: endpoint { + remote-endpoint = <&lcd_in>; + data-lines = <16>; + }; + }; };
&i2c2 { clock-frequency = <400000>; + /* User DIP swithes [1:8] / User LEDS [1:2] */ + tca6416: gpio@21 { + compatible = "ti,tca6416"; + reg = <0x21>; + gpio-controller; + #gpio-cells = <2>; + }; };
&i2c3 { @@ -47,8 +211,13 @@ };
&mmc1 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; vmmc-supply = <&vmmc_fixed>; bus-width = <4>; + wp-gpios = <&gpio4 30 GPIO_ACTIVE_HIGH>; /* gpio_126 */ + cd-gpios = <&gpio4 31 GPIO_ACTIVE_HIGH>; /* gpio_127 */ };
&mmc2 { @@ -59,3 +228,63 @@ status = "disabled"; };
+&omap3_pmx_core { + + leds_pins: pinmux_leds_pins { + pinctrl-single,pins = < + OMAP3_WKUP_IOPAD(0x2a24, PIN_OUTPUT_PULLUP | MUX_MODE4) /* jtag_emu0.gpio_11 */ + OMAP3_WKUP_IOPAD(0x2a26, PIN_OUTPUT_PULLUP | MUX_MODE4) /* jtag_emu1.gpio_31 */ + >; + }; + + mmc1_pins: pinmux_mmc1_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x2144, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_clk.sdmmc1_clk */ + OMAP3_CORE1_IOPAD(0x2146, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_cmd.sdmmc1_cmd */ + OMAP3_CORE1_IOPAD(0x2148, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_dat0.sdmmc1_dat0 */ + OMAP3_CORE1_IOPAD(0x214a, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_dat1.sdmmc1_dat1 */ + OMAP3_CORE1_IOPAD(0x214c, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_dat2.sdmmc1_dat2 */ + OMAP3_CORE1_IOPAD(0x214e, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_dat3.sdmmc1_dat3 */ + OMAP3_CORE1_IOPAD(0x2150, PIN_INPUT_PULLUP | MUX_MODE4) /* sdmmc1_dat4.gpio_126 */ + OMAP3_CORE1_IOPAD(0x2152, PIN_INPUT_PULLUP | MUX_MODE4) /* sdmmc1_dat5.gpio_127 */ + >; + }; + + pwm_pins: pinmux_pwm_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x21dc, PIN_OUTPUT | MUX_MODE1) /* mcspi2_cs0.gpt11_pwm */ + >; + }; + + backlight_pins: pinmux_backlight_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x21de, PIN_OUTPUT | MUX_MODE4) /* mcspi2_cs1.gpio_182 */ + >; + }; + + dss_dpi_pins: pinmux_dss_dpi_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x21d2, PIN_OUTPUT | MUX_MODE4) /* mcspi1_cs2.gpio_176 */ + OMAP3_CORE1_IOPAD(0x20d4, PIN_OUTPUT | MUX_MODE0) /* dss_pclk.dss_pclk */ + OMAP3_CORE1_IOPAD(0x20d6, PIN_OUTPUT | MUX_MODE0) /* dss_hsync.dss_hsync */ + OMAP3_CORE1_IOPAD(0x20d8, PIN_OUTPUT | MUX_MODE0) /* dss_vsync.dss_vsync */ + OMAP3_CORE1_IOPAD(0x20da, PIN_OUTPUT | MUX_MODE0) /* dss_acbias.dss_acbias */ + OMAP3_CORE1_IOPAD(0x20dc, PIN_OUTPUT | MUX_MODE0) /* dss_data0.dss_data0 */ + OMAP3_CORE1_IOPAD(0x20de, PIN_OUTPUT | MUX_MODE0) /* dss_data1.dss_data1 */ + OMAP3_CORE1_IOPAD(0x20e0, PIN_OUTPUT | MUX_MODE0) /* dss_data2.dss_data2 */ + OMAP3_CORE1_IOPAD(0x20e2, PIN_OUTPUT | MUX_MODE0) /* dss_data3.dss_data3 */ + OMAP3_CORE1_IOPAD(0x20e4, PIN_OUTPUT | MUX_MODE0) /* dss_data4.dss_data4 */ + OMAP3_CORE1_IOPAD(0x20e6, PIN_OUTPUT | MUX_MODE0) /* dss_data5.dss_data5 */ + OMAP3_CORE1_IOPAD(0x20e8, PIN_OUTPUT | MUX_MODE0) /* dss_data6.dss_data6 */ + OMAP3_CORE1_IOPAD(0x20ea, PIN_OUTPUT | MUX_MODE0) /* dss_data7.dss_data7 */ + OMAP3_CORE1_IOPAD(0x20ec, PIN_OUTPUT | MUX_MODE0) /* dss_data8.dss_data8 */ + OMAP3_CORE1_IOPAD(0x20ee, PIN_OUTPUT | MUX_MODE0) /* dss_data9.dss_data9 */ + OMAP3_CORE1_IOPAD(0x20f0, PIN_OUTPUT | MUX_MODE0) /* dss_data10.dss_data10 */ + OMAP3_CORE1_IOPAD(0x20f2, PIN_OUTPUT | MUX_MODE0) /* dss_data11.dss_data11 */ + OMAP3_CORE1_IOPAD(0x20f4, PIN_OUTPUT | MUX_MODE0) /* dss_data12.dss_data12 */ + OMAP3_CORE1_IOPAD(0x20f6, PIN_OUTPUT | MUX_MODE0) /* dss_data13.dss_data13 */ + OMAP3_CORE1_IOPAD(0x20f8, PIN_OUTPUT | MUX_MODE0) /* dss_data14.dss_data14 */ + OMAP3_CORE1_IOPAD(0x20fa, PIN_OUTPUT | MUX_MODE0) /* dss_data15.dss_data15 */ + >; + }; +}; diff --git a/arch/arm/dts/am3517-som.dtsi b/arch/arm/dts/am3517-som.dtsi new file mode 100644 index 0000000000..a6d5ff73c1 --- /dev/null +++ b/arch/arm/dts/am3517-som.dtsi @@ -0,0 +1,142 @@ +/* + * Copyright (C) 2016 Derald D. Woods woods.technical@gmail.com + * + * Based on am3517-evm.dts + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +/ { + cpus { + cpu@0 { + cpu0-supply = <&vdd_core_reg>; + }; + }; +}; + +&gpmc { + ranges = <0 0 0x30000000 0x1000000>; /* CS0: 16MB for NAND */ + + nand@0,0 { + compatible = "ti,omap2-nand"; + linux,mtd-name = "micron,mt29f4g16abchch"; + reg = <0 0 4>; /* CS0, offset 0, IO size 4 */ + nand-bus-width = <16>; + ti,nand-ecc-opt = "bch8"; + gpmc,sync-clk-ps = <0>; + gpmc,cs-on-ns = <0>; + gpmc,cs-rd-off-ns = <44>; + gpmc,cs-wr-off-ns = <44>; + gpmc,adv-on-ns = <6>; + gpmc,adv-rd-off-ns = <34>; + gpmc,adv-wr-off-ns = <44>; + gpmc,we-off-ns = <40>; + gpmc,oe-off-ns = <54>; + gpmc,access-ns = <64>; + gpmc,rd-cycle-ns = <82>; + gpmc,wr-cycle-ns = <82>; + gpmc,wr-access-ns = <40>; + gpmc,wr-data-mux-bus-ns = <0>; + gpmc,device-width = <2>; + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + + s35390a: s35390a@30 { + compatible = "sii,s35390a"; + reg = <0x30>; + + pinctrl-names = "default"; + pinctrl-0 = <&rtc_pins>; + interrupts-extended = <&gpio2 23 IRQ_TYPE_EDGE_FALLING>; /* gpio_55 */ + }; + + tps: tps65023@48 { + compatible = "ti,tps65023"; + reg = <0x48>; + + regulators { + vdd_core_reg: VDCDC1 { + regulator-name = "vdd_core"; + compatible = "regulator-fixed"; + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + + vdd_io_reg: VDCDC2 { + regulator-name = "vdd_io"; + compatible = "regulator-fixed"; + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vdd_1v8_reg: VDCDC3 { + regulator-name = "vdd_1v8"; + compatible = "regulator-fixed"; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vdd_usb18_reg: LDO1 { + regulator-name = "vdd_usb18"; + compatible = "regulator-fixed"; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vdd_usb33_reg: LDO2 { + regulator-name = "vdd_usb33"; + compatible = "regulator-fixed"; + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + }; + }; + + touchscreen: tsc2004@4b { + compatible = "ti,tsc2004"; + reg = <0x4b>; + + vio-supply = <&vdd_io_reg>; + + pinctrl-names = "default"; + pinctrl-0 = <&tsc2004_pins>; + interrupts-extended = <&gpio3 1 IRQ_TYPE_EDGE_RISING>; /* gpio_65 */ + + touchscreen-fuzz-x = <4>; + touchscreen-fuzz-y = <7>; + touchscreen-fuzz-pressure = <2>; + touchscreen-size-x = <480>; + touchscreen-size-y = <272>; + touchscreen-max-pressure = <2048>; + + ti,x-plate-ohms = <280>; + ti,esd-recovery-timeout-ms = <8000>; + }; +}; + +&omap3_pmx_core { + + rtc_pins: pinmux_rtc_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x20b6, PIN_INPUT_PULLUP | MUX_MODE4) /* gpmc_ncs4.gpio_55 */ + >; + }; + + tsc2004_pins: pinmux_tsc2004_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x20d2, PIN_INPUT | MUX_MODE4) /* gpmc_wait3.gpio_65 */ + >; + }; +}; diff --git a/arch/arm/dts/am3517.dtsi b/arch/arm/dts/am3517.dtsi index ca294914bb..4b6062b631 100644 --- a/arch/arm/dts/am3517.dtsi +++ b/arch/arm/dts/am3517.dtsi @@ -39,6 +39,8 @@ ti,davinci-ctrl-ram-size = <0x2000>; ti,davinci-rmii-en = /bits/ 8 <1>; local-mac-address = [ 00 00 00 00 00 00 ]; + clocks = <&emac_ick>; + clock-names = "ick"; };
davinci_mdio: ethernet@5c030000 { @@ -49,6 +51,8 @@ bus_freq = <1000000>; #address-cells = <1>; #size-cells = <0>; + clocks = <&emac_fck>; + clock-names = "fck"; };
uart4: serial@4809e000 {
Adam Ford
