[U-Boot] [PATCH] socfpga: initialize designware ethernet
Enable initialization fo designware ethernet controller. With this patch, ethernet works in my configuration, provided I set ethernet address in the environment.
Signed-off-by: Pavel Machek pavel@denx.de
diff --git a/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h b/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h index f564046..a6d1680 100644 --- a/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h +++ b/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h @@ -14,5 +14,7 @@ #define SOCFPGA_CLKMGR_ADDRESS 0xffd04000 #define SOCFPGA_RSTMGR_ADDRESS 0xffd05000 #define SOCFPGA_SYSMGR_ADDRESS 0xffd08000 +#define SOCFPGA_EMAC0_ADDRESS 0xff700000 +#define SOCFPGA_EMAC1_ADDRESS 0xff702000
#endif /* _SOCFPGA_BASE_ADDRS_H_ */ diff --git a/board/altera/socfpga/socfpga_cyclone5.c b/board/altera/socfpga/socfpga_cyclone5.c index a960eb6..2214ab7 100644 --- a/board/altera/socfpga/socfpga_cyclone5.c +++ b/board/altera/socfpga/socfpga_cyclone5.c @@ -1,5 +1,6 @@ /* * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2014 Pavel Machek, pavel@denx.de * * SPDX-License-Identifier: GPL-2.0+ */ @@ -7,7 +8,7 @@ #include <common.h> #include <asm/arch/reset_manager.h> #include <asm/io.h> - +#include <miiphy.h> #include <netdev.h>
DECLARE_GLOBAL_DATA_PTR; @@ -67,5 +68,11 @@ int overwrite_console(void) /* We know all the init functions have been run now */ int board_eth_init(bd_t *bis) { +#if !defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) && !defined(CONFIG_SPL_BUILD) + /* initialize and register the emac */ + int rval = designware_initialize(CONFIG_EMAC_BASE, CONFIG_PHY_INTERFACE_MODE); + return rval; +#else return 0; +#endif } diff --git a/include/configs/socfpga_cyclone5.h b/include/configs/socfpga_cyclone5.h index 0254249..c9c8e53 100644 --- a/include/configs/socfpga_cyclone5.h +++ b/include/configs/socfpga_cyclone5.h @@ -206,6 +209,38 @@ #define CONFIG_ENV_IS_NOWHERE
/* + * network support + */ +#ifndef CONFIG_SOCFPGA_VIRTUAL_TARGET +#define CONFIG_DESIGNWARE_ETH 1 +#endif + +#ifdef CONFIG_DESIGNWARE_ETH +#define CONFIG_EMAC0_BASE SOCFPGA_EMAC0_ADDRESS +#define CONFIG_EMAC1_BASE SOCFPGA_EMAC1_ADDRESS +/* console support for network */ +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +/* designware */ +#define CONFIG_NET_MULTI +#define CONFIG_DW_ALTDESCRIPTOR +#define CONFIG_DW_SEARCH_PHY +#define CONFIG_MII +#define CONFIG_PHY_GIGE +#define CONFIG_DW_AUTONEG +#define CONFIG_AUTONEG_TIMEOUT (15 * CONFIG_SYS_HZ) +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9021 +/* EMAC controller and PHY used */ +#define CONFIG_EMAC_BASE CONFIG_EMAC1_BASE +#define CONFIG_EPHY_PHY_ADDR CONFIG_EPHY1_PHY_ADDR +#define CONFIG_PHY_INTERFACE_MODE PHY_INTERFACE_MODE_RGMII +#endif /* CONFIG_DESIGNWARE_ETH */ + +/* * SPL "Second Program Loader" aka Initial Software */
On Friday, July 11, 2014 at 11:45:56 AM, Pavel Machek wrote: [...]
- Copyright (C) 2012 Altera Corporation <www.altera.com>
- Copyright (C) 2014 Pavel Machek, pavel@denx.de
NAK ;-) Can you please keep the email address in this extremely relevant comment in the same format as above (in the <> chars) .
- int rval = designware_initialize(CONFIG_EMAC_BASE,
Can this all not go into cpu_eth_init() and into arch/arm/... instead ?
Best regards, Marek Vasut
Umm, note that above is web address and mine is email address :-).
No idea. When I move it to arch/arm/, like this, it still works, so I guess it can be moved.
Should I prepare new patch? Pavel
diff --git a/arch/arm/cpu/armv7/socfpga/misc.c b/arch/arm/cpu/armv7/socfpga/misc.c index 2f1c716..6c64f28 100644 --- a/arch/arm/cpu/armv7/socfpga/misc.c +++ b/arch/arm/cpu/armv7/socfpga/misc.c @@ -6,6 +6,8 @@
#include <common.h> #include <asm/io.h> +#include <miiphy.h> +#include <netdev.h>
@@ -14,3 +16,19 @@ int dram_init(void) gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); return 0; } + + +/* + * DesignWare Ethernet initialization + */ +/* We know all the init functions have been run now */ +int board_eth_init(bd_t *bis) +{ +#if !defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) && !defined(CONFIG_SPL_BUILD) + /* initialize and register the emac */ + return designware_initialize(CONFIG_EMAC_BASE, + CONFIG_PHY_INTERFACE_MODE); +#else + return 0; +#endif +} diff --git a/board/altera/socfpga/socfpga_cyclone5.c b/board/altera/socfpga/socfpga_cyclone5.c index 2214ab7..5cbe695 100644 --- a/board/altera/socfpga/socfpga_cyclone5.c +++ b/board/altera/socfpga/socfpga_cyclone5.c @@ -8,8 +8,6 @@ #include <common.h> #include <asm/arch/reset_manager.h> #include <asm/io.h> -#include <miiphy.h> -#include <netdev.h>
@@ -61,18 +59,3 @@ int overwrite_console(void) return 0; } #endif - -/* - * DesignWare Ethernet initialization - */ -/* We know all the init functions have been run now */ -int board_eth_init(bd_t *bis) -{ -#if !defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) && !defined(CONFIG_SPL_BUILD) - /* initialize and register the emac */ - int rval = designware_initialize(CONFIG_EMAC_BASE, CONFIG_PHY_INTERFACE_MODE); - return rval; -#else - return 0; -#endif -}
It still seems the email addresses are in those <> signs quite often ;-).
Yes please, but I can only give you a general guidance, I'm no socfpga expert.
Changes from v1: moved ethernet initialization to arch/arm, as suggested by Marek.
@@ -14,3 +16,19 @@ int dram_init(void) gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); return 0; } + + +/* + * DesignWare Ethernet initialization + */ +/* We know all the init functions have been run now */ +int board_eth_init(bd_t *bis) +{ +#if !defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) && !defined(CONFIG_SPL_BUILD) + /* initialize and register the emac */ + return designware_initialize(CONFIG_EMAC_BASE, + CONFIG_PHY_INTERFACE_MODE); +#else + return 0; +#endif +} diff --git a/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h b/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h index f564046..a6d1680 100644 --- a/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h +++ b/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h @@ -14,5 +14,7 @@ #define SOCFPGA_CLKMGR_ADDRESS 0xffd04000 #define SOCFPGA_RSTMGR_ADDRESS 0xffd05000 #define SOCFPGA_SYSMGR_ADDRESS 0xffd08000 +#define SOCFPGA_EMAC0_ADDRESS 0xff700000 +#define SOCFPGA_EMAC1_ADDRESS 0xff702000
#endif /* _SOCFPGA_BASE_ADDRS_H_ */ diff --git a/board/altera/socfpga/socfpga_cyclone5.c b/board/altera/socfpga/socfpga_cyclone5.c index a960eb6..5cbe695 100644 --- a/board/altera/socfpga/socfpga_cyclone5.c +++ b/board/altera/socfpga/socfpga_cyclone5.c @@ -8,8 +9,6 @@ #include <asm/arch/reset_manager.h> #include <asm/io.h>
-#include <netdev.h> - DECLARE_GLOBAL_DATA_PTR;
#if defined(CONFIG_DISPLAY_CPUINFO) @@ -60,12 +59,3 @@ int overwrite_console(void) return 0; } #endif - -/* - * DesignWare Ethernet initialization - */ -/* We know all the init functions have been run now */ -int board_eth_init(bd_t *bis) -{ - return 0; -} diff --git a/include/configs/socfpga_cyclone5.h b/include/configs/socfpga_cyclone5.h index 0254249..c9c8e53 100644 --- a/include/configs/socfpga_cyclone5.h +++ b/include/configs/socfpga_cyclone5.h @@ -206,6 +209,38 @@ #define CONFIG_ENV_IS_NOWHERE
On Sunday, July 13, 2014 at 10:06:50 AM, Pavel Machek wrote: [...]
- DesignWare Ethernet initialization
This would be cpu_eth_init()
- return designware_initialize(CONFIG_EMAC_BASE,
+#else
+#endif +}
[...] Best regards, Marek Vasut
Changes from v2: use right function name after moving to arch/arm. Thanks to Marek.
Patch hand-edited so that it can be applied after the "timer counts down" fix.
diff --git a/arch/arm/cpu/armv7/socfpga/misc.c b/arch/arm/cpu/armv7/socfpga/misc.c index 2f1c716..bb71c91 100644 --- a/arch/arm/cpu/armv7/socfpga/misc.c +++ b/arch/arm/cpu/armv7/socfpga/misc.c @@ -6,6 +6,8 @@
@@ -14,3 +16,18 @@ int dram_init(void) gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); return 0; } + + +/* + * DesignWare Ethernet initialization + */ +int cpu_eth_init(bd_t *bis) +{ +#if !defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) && !defined(CONFIG_SPL_BUILD) + /* initialize and register the emac */ + return designware_initialize(CONFIG_EMAC_BASE, + CONFIG_PHY_INTERFACE_MODE); +#else + return 0; +#endif +} diff --git a/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h b/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h index f564046..a6d1680 100644 --- a/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h +++ b/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h @@ -14,5 +14,7 @@ #define SOCFPGA_CLKMGR_ADDRESS 0xffd04000 #define SOCFPGA_RSTMGR_ADDRESS 0xffd05000 #define SOCFPGA_SYSMGR_ADDRESS 0xffd08000 +#define SOCFPGA_EMAC0_ADDRESS 0xff700000 +#define SOCFPGA_EMAC1_ADDRESS 0xff702000
#endif /* _SOCFPGA_BASE_ADDRS_H_ */ diff --git a/board/altera/socfpga/socfpga_cyclone5.c b/board/altera/socfpga/socfpga_cyclone5.c index a960eb6..5cbe695 100644 --- a/board/altera/socfpga/socfpga_cyclone5.c +++ b/board/altera/socfpga/socfpga_cyclone5.c @@ -60,12 +59,3 @@ int overwrite_console(void) return 0; } #endif - -/* - * DesignWare Ethernet initialization - */ -/* We know all the init functions have been run now */ -int board_eth_init(bd_t *bis) -{ - return 0; -} diff --git a/include/configs/socfpga_cyclone5.h b/include/configs/socfpga_cyclone5.h index 0254249..cc4f690 100644 --- a/include/configs/socfpga_cyclone5.h +++ b/include/configs/socfpga_cyclone5.h @@ -201,12 +204,44 @@ #else #define CONFIG_SYS_TIMER_RATE 25000000 #endif #define CONFIG_SYS_TIMER_COUNTS_DOWN #define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMERBASE + 0x4)
btw. is there any reason why the patch is missing a diffstat ?
I had to hand-edit the patch to make it fit after the time fixes...
(Plus, I don't normally do diffstats as they are not required for kernel submissions.)
Pavel
Pavel Machek
