[U-Boot] [PATCH 07/26] common: move TOTAL_MALLOC_LEN to include/common.h
Signed-off-by: Heiko Schocher hs@denx.de --- - changes since v1: add m68k and mips
arch/m68k/lib/board.c | 8 -------- arch/mips/lib/board.c | 8 -------- arch/powerpc/lib/board.c | 10 ---------- include/common.h | 9 +++++++++ 4 files changed, 9 insertions(+), 26 deletions(-)
diff --git a/arch/m68k/lib/board.c b/arch/m68k/lib/board.c index acbdc58..ae9478a 100644 --- a/arch/m68k/lib/board.c +++ b/arch/m68k/lib/board.c @@ -79,14 +79,6 @@ extern flash_info_t flash_info[];
#include <environment.h>
-#if ( ((CONFIG_ENV_ADDR+CONFIG_ENV_SIZE) < CONFIG_SYS_MONITOR_BASE) || \ - (CONFIG_ENV_ADDR >= (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN)) ) || \ - defined(CONFIG_ENV_IS_IN_NVRAM) -#define TOTAL_MALLOC_LEN (CONFIG_SYS_MALLOC_LEN + CONFIG_ENV_SIZE) -#else -#define TOTAL_MALLOC_LEN CONFIG_SYS_MALLOC_LEN -#endif - extern ulong __init_end; extern ulong _end;
diff --git a/arch/mips/lib/board.c b/arch/mips/lib/board.c index 2f259cb..0044b19 100644 --- a/arch/mips/lib/board.c +++ b/arch/mips/lib/board.c @@ -39,14 +39,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#if ( ((CONFIG_ENV_ADDR+CONFIG_ENV_SIZE) < CONFIG_SYS_MONITOR_BASE) || \ - (CONFIG_ENV_ADDR >= (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN)) ) || \ - defined(CONFIG_ENV_IS_IN_NVRAM) -#define TOTAL_MALLOC_LEN (CONFIG_SYS_MALLOC_LEN + CONFIG_ENV_SIZE) -#else -#define TOTAL_MALLOC_LEN CONFIG_SYS_MALLOC_LEN -#endif - #undef DEBUG
extern int timer_init(void); diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index 0e00d86..6c9cda2 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -118,16 +118,6 @@ extern int board_start_ide(void);
-#if defined(CONFIG_ENV_IS_EMBEDDED) -#define TOTAL_MALLOC_LEN CONFIG_SYS_MALLOC_LEN -#elif ( ((CONFIG_ENV_ADDR+CONFIG_ENV_SIZE) < CONFIG_SYS_MONITOR_BASE) || \ - (CONFIG_ENV_ADDR >= (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN)) ) || \ - defined(CONFIG_ENV_IS_IN_NVRAM) -#define TOTAL_MALLOC_LEN (CONFIG_SYS_MALLOC_LEN + CONFIG_ENV_SIZE) -#else -#define TOTAL_MALLOC_LEN CONFIG_SYS_MALLOC_LEN -#endif - #if !defined(CONFIG_SYS_MEM_TOP_HIDE) #define CONFIG_SYS_MEM_TOP_HIDE 0 #endif diff --git a/include/common.h b/include/common.h index 6a79ec2..07717ec 100644 --- a/include/common.h +++ b/include/common.h @@ -189,6 +189,15 @@ typedef void (interrupt_handler_t)(void *); #define MIN(x, y) min(x, y) #define MAX(x, y) max(x, y)
+#if defined(CONFIG_ENV_IS_EMBEDDED) +#define TOTAL_MALLOC_LEN CONFIG_SYS_MALLOC_LEN +#elif ( ((CONFIG_ENV_ADDR+CONFIG_ENV_SIZE) < CONFIG_SYS_MONITOR_BASE) || \ + (CONFIG_ENV_ADDR >= (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN)) ) || \ + defined(CONFIG_ENV_IS_IN_NVRAM) +#define TOTAL_MALLOC_LEN (CONFIG_SYS_MALLOC_LEN + CONFIG_ENV_SIZE) +#else +#define TOTAL_MALLOC_LEN CONFIG_SYS_MALLOC_LEN +#endif
/** * container_of - cast a member of a structure out to the containing structure
Heiko Schocher
