[U-Boot] [PATCH v5 2/3] Add TI816X support
Signed-off-by: Antoine Tenart atenart@adeneo-embedded.com --- arch/arm/cpu/armv7/am33xx/Makefile | 1 + arch/arm/cpu/armv7/am33xx/clock_ti814x.c | 95 ----- arch/arm/cpu/armv7/am33xx/clock_ti816x.c | 445 ++++++++++++++++++++ arch/arm/cpu/armv7/am33xx/emif4.c | 2 + arch/arm/include/asm/arch-am33xx/clock.h | 4 + arch/arm/include/asm/arch-am33xx/clock_ti81xx.h | 142 +++++++ arch/arm/include/asm/arch-am33xx/ddr_defs.h | 35 +- arch/arm/include/asm/arch-am33xx/hardware.h | 10 +- arch/arm/include/asm/arch-am33xx/hardware_am33xx.h | 6 + arch/arm/include/asm/arch-am33xx/hardware_ti814x.h | 6 + arch/arm/include/asm/arch-am33xx/hardware_ti816x.h | 57 +++ arch/arm/include/asm/arch-am33xx/mmc_host_def.h | 3 + arch/arm/include/asm/arch-am33xx/mux.h | 2 + arch/arm/include/asm/arch-am33xx/mux_ti816x.h | 363 ++++++++++++++++ arch/arm/include/asm/arch-am33xx/spl.h | 11 +- 15 files changed, 1065 insertions(+), 117 deletions(-) create mode 100644 arch/arm/cpu/armv7/am33xx/clock_ti816x.c create mode 100644 arch/arm/include/asm/arch-am33xx/clock_ti81xx.h create mode 100644 arch/arm/include/asm/arch-am33xx/hardware_ti816x.h create mode 100644 arch/arm/include/asm/arch-am33xx/mux_ti816x.h
diff --git a/arch/arm/cpu/armv7/am33xx/Makefile b/arch/arm/cpu/armv7/am33xx/Makefile index f4ccd2a..8cb7efb 100644 --- a/arch/arm/cpu/armv7/am33xx/Makefile +++ b/arch/arm/cpu/armv7/am33xx/Makefile @@ -18,6 +18,7 @@ LIB = $(obj)lib$(SOC).o
COBJS-$(CONFIG_AM33XX) += clock_am33xx.o COBJS-$(CONFIG_TI814X) += clock_ti814x.o +COBJS-$(CONFIG_TI816X) += clock_ti816x.o COBJS-$(CONFIG_AM33XX) += clock.o COBJS += sys_info.o COBJS += mem.o diff --git a/arch/arm/cpu/armv7/am33xx/clock_ti814x.c b/arch/arm/cpu/armv7/am33xx/clock_ti814x.c index ca7d7ad..17913e7 100644 --- a/arch/arm/cpu/armv7/am33xx/clock_ti814x.c +++ b/arch/arm/cpu/armv7/am33xx/clock_ti814x.c @@ -108,103 +108,8 @@ struct ad_pll {
#define OSC_SRC_CTRL (PLL_SUBSYS_BASE + 0x2C0)
-/* PRCM */ #define ENET_CLKCTRL_CMPL 0x30000
-#define CM_DEFAULT_BASE (PRCM_BASE + 0x0500) - -struct cm_def { - unsigned int resv0[2]; - unsigned int l3fastclkstctrl; - unsigned int resv1[1]; - unsigned int pciclkstctrl; - unsigned int resv2[1]; - unsigned int ducaticlkstctrl; - unsigned int resv3[1]; - unsigned int emif0clkctrl; - unsigned int emif1clkctrl; - unsigned int dmmclkctrl; - unsigned int fwclkctrl; - unsigned int resv4[10]; - unsigned int usbclkctrl; - unsigned int resv5[1]; - unsigned int sataclkctrl; - unsigned int resv6[4]; - unsigned int ducaticlkctrl; - unsigned int pciclkctrl; -}; - -#define CM_ALWON_BASE (PRCM_BASE + 0x1400) - -struct cm_alwon { - unsigned int l3slowclkstctrl; - unsigned int ethclkstctrl; - unsigned int l3medclkstctrl; - unsigned int mmu_clkstctrl; - unsigned int mmucfg_clkstctrl; - unsigned int ocmc0clkstctrl; - unsigned int vcpclkstctrl; - unsigned int mpuclkstctrl; - unsigned int sysclk4clkstctrl; - unsigned int sysclk5clkstctrl; - unsigned int sysclk6clkstctrl; - unsigned int rtcclkstctrl; - unsigned int l3fastclkstctrl; - unsigned int resv0[67]; - unsigned int mcasp0clkctrl; - unsigned int mcasp1clkctrl; - unsigned int mcasp2clkctrl; - unsigned int mcbspclkctrl; - unsigned int uart0clkctrl; - unsigned int uart1clkctrl; - unsigned int uart2clkctrl; - unsigned int gpio0clkctrl; - unsigned int gpio1clkctrl; - unsigned int i2c0clkctrl; - unsigned int i2c1clkctrl; - unsigned int mcasp345clkctrl; - unsigned int atlclkctrl; - unsigned int mlbclkctrl; - unsigned int pataclkctrl; - unsigned int resv1[1]; - unsigned int uart3clkctrl; - unsigned int uart4clkctrl; - unsigned int uart5clkctrl; - unsigned int wdtimerclkctrl; - unsigned int spiclkctrl; - unsigned int mailboxclkctrl; - unsigned int spinboxclkctrl; - unsigned int mmudataclkctrl; - unsigned int resv2[2]; - unsigned int mmucfgclkctrl; - unsigned int resv3[2]; - unsigned int ocmc0clkctrl; - unsigned int vcpclkctrl; - unsigned int resv4[2]; - unsigned int controlclkctrl; - unsigned int resv5[2]; - unsigned int gpmcclkctrl; - unsigned int ethernet0clkctrl; - unsigned int ethernet1clkctrl; - unsigned int mpuclkctrl; - unsigned int debugssclkctrl; - unsigned int l3clkctrl; - unsigned int l4hsclkctrl; - unsigned int l4lsclkctrl; - unsigned int rtcclkctrl; - unsigned int tpccclkctrl; - unsigned int tptc0clkctrl; - unsigned int tptc1clkctrl; - unsigned int tptc2clkctrl; - unsigned int tptc3clkctrl; - unsigned int resv7[4]; - unsigned int dcan01clkctrl; - unsigned int mmchs0clkctrl; - unsigned int mmchs1clkctrl; - unsigned int mmchs2clkctrl; - unsigned int custefuseclkctrl; -}; - #define SATA_PLL_BASE (CTRL_BASE + 0x0720)
struct sata_pll { diff --git a/arch/arm/cpu/armv7/am33xx/clock_ti816x.c b/arch/arm/cpu/armv7/am33xx/clock_ti816x.c new file mode 100644 index 0000000..ace4a5a --- /dev/null +++ b/arch/arm/cpu/armv7/am33xx/clock_ti816x.c @@ -0,0 +1,445 @@ +/* + * clock_ti816x.c + * + * Clocks for TI816X based boards + * + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> + * Antoine Tenart, atenart@adeneo-embedded.com + * + * Based on TI-PSP-04.00.02.14 : + * + * Copyright (C) 2009, Texas Instruments, Incorporated + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/arch/ddr_defs.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clock.h> +#include <asm/arch/hardware.h> +#include <asm/io.h> + +#include <asm/emif.h> + +#define CM_PLL_BASE (CTRL_BASE + 0x0400) + +/* Main PLL */ +#define MAIN_N 64 +#define MAIN_P 0x1 +#define MAIN_INTFREQ1 0x8 +#define MAIN_FRACFREQ1 0x800000 +#define MAIN_MDIV1 0x2 +#define MAIN_INTFREQ2 0xE +#define MAIN_FRACFREQ2 0x0 +#define MAIN_MDIV2 0x1 +#define MAIN_INTFREQ3 0x8 +#define MAIN_FRACFREQ3 0xAAAAB0 +#define MAIN_MDIV3 0x3 +#define MAIN_INTFREQ4 0x9 +#define MAIN_FRACFREQ4 0x55554F +#define MAIN_MDIV4 0x3 +#define MAIN_INTFREQ5 0x9 +#define MAIN_FRACFREQ5 0x374BC6 +#define MAIN_MDIV5 0xC +#define MAIN_MDIV6 0x48 +#define MAIN_MDIV7 0x4 + +/* DDR PLL */ +#if defined(CONFIG_TI816X_DDR_PLL_400) /* 400 MHz */ +#define DDR_N 59 +#define DDR_P 0x1 +#define DDR_MDIV1 0x4 +#define DDR_INTFREQ2 0x8 +#define DDR_FRACFREQ2 0xD99999 +#define DDR_MDIV2 0x1E +#define DDR_INTFREQ3 0x8 +#define DDR_FRACFREQ3 0x0 +#define DDR_MDIV3 0x4 +#define DDR_INTFREQ4 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ4 0x0 +#define DDR_MDIV4 0x4 +#define DDR_INTFREQ5 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ5 0x0 +#define DDR_MDIV5 0x4 +#elif defined(CONFIG_TI816X_DDR_PLL_531) /* 531 MHz */ +#define DDR_N 59 +#define DDR_P 0x1 +#define DDR_MDIV1 0x3 +#define DDR_INTFREQ2 0x8 +#define DDR_FRACFREQ2 0xD99999 +#define DDR_MDIV2 0x1E +#define DDR_INTFREQ3 0x8 +#define DDR_FRACFREQ3 0x0 +#define DDR_MDIV3 0x4 +#define DDR_INTFREQ4 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ4 0x0 +#define DDR_MDIV4 0x4 +#define DDR_INTFREQ5 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ5 0x0 +#define DDR_MDIV5 0x4 +#elif defined(CONFIG_TI816X_DDR_PLL_675) /* 675 MHz */ +#define DDR_N 50 +#define DDR_P 0x1 +#define DDR_MDIV1 0x2 +#define DDR_INTFREQ2 0x9 +#define DDR_FRACFREQ2 0x0 +#define DDR_MDIV2 0x19 +#define DDR_INTFREQ3 0x13 +#define DDR_FRACFREQ3 0x800000 +#define DDR_MDIV3 0x2 +#define DDR_INTFREQ4 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ4 0x0 +#define DDR_MDIV4 0x4 +#define DDR_INTFREQ5 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ5 0x0 +#define DDR_MDIV5 0x4 +#elif defined(CONFIG_TI816X_DDR_PLL_796) /* 796 MHz */ +#define DDR_N 59 +#define DDR_P 0x1 +#define DDR_MDIV1 0x2 +#define DDR_INTFREQ2 0x8 +#define DDR_FRACFREQ2 0xD99999 +#define DDR_MDIV2 0x1E +#define DDR_INTFREQ3 0x8 +#define DDR_FRACFREQ3 0x0 +#define DDR_MDIV3 0x4 +#define DDR_INTFREQ4 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ4 0x0 +#define DDR_MDIV4 0x4 +#define DDR_INTFREQ5 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ5 0x0 +#define DDR_MDIV5 0x4 +#endif + +#define CONTROL_STATUS (CTRL_BASE + 0x40) +#define DDR_RCD (CTRL_BASE + 0x070C) +#define CM_TIMER1_CLKSEL (PRCM_BASE + 0x390) +#define DMM_PAT_BASE_ADDR (DMM_BASE + 0x420) +#define CM_ALWON_CUST_EFUSE_CLKCTRL (PRCM_BASE + 0x1628) + +#define INTCPS_SYSCONFIG 0x48200010 +#define CM_SYSCLK10_CLKSEL 0x48180324 + +struct cm_pll { + unsigned int mainpll_ctrl; /* offset 0x400 */ + unsigned int mainpll_pwd; + unsigned int mainpll_freq1; + unsigned int mainpll_div1; + unsigned int mainpll_freq2; + unsigned int mainpll_div2; + unsigned int mainpll_freq3; + unsigned int mainpll_div3; + unsigned int mainpll_freq4; + unsigned int mainpll_div4; + unsigned int mainpll_freq5; + unsigned int mainpll_div5; + unsigned int resv0[1]; + unsigned int mainpll_div6; + unsigned int resv1[1]; + unsigned int mainpll_div7; + unsigned int ddrpll_ctrl; /* offset 0x440 */ + unsigned int ddrpll_pwd; + unsigned int resv2[1]; + unsigned int ddrpll_div1; + unsigned int ddrpll_freq2; + unsigned int ddrpll_div2; + unsigned int ddrpll_freq3; + unsigned int ddrpll_div3; + unsigned int ddrpll_freq4; + unsigned int ddrpll_div4; + unsigned int ddrpll_freq5; + unsigned int ddrpll_div5; + unsigned int videopll_ctrl; /* offset 0x470 */ + unsigned int videopll_pwd; + unsigned int videopll_freq1; + unsigned int videopll_div1; + unsigned int videopll_freq2; + unsigned int videopll_div2; + unsigned int videopll_freq3; + unsigned int videopll_div3; + unsigned int resv3[4]; + unsigned int audiopll_ctrl; /* offset 0x4A0 */ + unsigned int audiopll_pwd; + unsigned int resv4[2]; + unsigned int audiopll_freq2; + unsigned int audiopll_div2; + unsigned int audiopll_freq3; + unsigned int audiopll_div3; + unsigned int audiopll_freq4; + unsigned int audiopll_div4; + unsigned int audiopll_freq5; + unsigned int audiopll_div5; +}; + +const struct cm_alwon *cmalwon = (struct cm_alwon *)CM_ALWON_BASE; +const struct cm_def *cmdef = (struct cm_def *)CM_DEFAULT_BASE; +const struct cm_pll *cmpll = (struct cm_pll *)CM_PLL_BASE; +const struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE; + +void enable_dmm_clocks(void) +{ + writel(PRCM_MOD_EN, &cmdef->l3fastclkstctrl); + writel(PRCM_MOD_EN, &cmdef->emif0clkctrl); + writel(PRCM_MOD_EN, &cmdef->emif1clkctrl); + + /* Wait for clocks to be active */ + while ((readl(&cmdef->l3fastclkstctrl) & 0x300) != 0x300) + ; + /* Wait for emif0 to be fully functional, including OCP */ + while (((readl(&cmdef->emif0clkctrl) >> 17) & 0x3) != 0) + ; + /* Wait for emif1 to be fully functional, including OCP */ + while (((readl(&cmdef->emif1clkctrl) >> 17) & 0x3) != 0) + ; + + writel(PRCM_MOD_EN, &cmdef->dmmclkctrl); + /* Wait for dmm to be fully functional, including OCP */ + while (((readl(&cmdef->dmmclkctrl) >> 17) & 0x3) != 0) + ; + + /* Enable Tiled Access */ + writel(0x80000000, DMM_PAT_BASE_ADDR); +} + +/* assume delay is aprox at least 1us */ +static void ddr_delay(int d) +{ + int i; + + /* + * read a control register. + * this is a bit more delay and cannot be optimized by the compiler + * assuming one read takes 200 cycles and A8 is runing 1 GHz + * somewhat conservative setting + */ + for (i = 0; i < 50*d; i++) + readl(CONTROL_STATUS); +} + +static void main_pll_init_ti816x(void) +{ + u32 main_pll_ctrl = 0; + + /* Put the PLL in bypass mode by setting BIT2 in its ctrl reg */ + main_pll_ctrl = readl(&cmpll->mainpll_ctrl); + main_pll_ctrl &= 0xFFFFFFFB; + main_pll_ctrl |= BIT(2); + writel(main_pll_ctrl, &cmpll->mainpll_ctrl); + + /* Enable PLL by setting BIT3 in its ctrl reg */ + main_pll_ctrl = readl(&cmpll->mainpll_ctrl); + main_pll_ctrl &= 0xFFFFFFF7; + main_pll_ctrl |= BIT(3); + writel(main_pll_ctrl, &cmpll->mainpll_ctrl); + + /* Write the values of N,P in the CTRL reg */ + main_pll_ctrl = readl(&cmpll->mainpll_ctrl); + main_pll_ctrl &= 0xFF; + main_pll_ctrl |= (MAIN_N<<16 | MAIN_P<<8); + writel(main_pll_ctrl, &cmpll->mainpll_ctrl); + + /* Power up clock1-7 */ + writel(0x0, &cmpll->mainpll_pwd); + + /* Program the freq and divider values for clock1-7 */ + writel((1<<31 | 1<<28 | (MAIN_INTFREQ1<<24) | MAIN_FRACFREQ1), + &cmpll->mainpll_freq1); + writel(((1<<8) | MAIN_MDIV1), &cmpll->mainpll_div1); + + writel((1<<31 | 1<<28 | (MAIN_INTFREQ2<<24) | MAIN_FRACFREQ2), + &cmpll->mainpll_freq2); + writel(((1<<8) | MAIN_MDIV2), &cmpll->mainpll_div2); + + writel((1<<31 | 1<<28 | (MAIN_INTFREQ3<<24) | MAIN_FRACFREQ3), + &cmpll->mainpll_freq3); + writel(((1<<8) | MAIN_MDIV3), &cmpll->mainpll_div3); + + writel((1<<31 | 1<<28 | (MAIN_INTFREQ4<<24) | MAIN_FRACFREQ4), + &cmpll->mainpll_freq4); + writel(((1<<8) | MAIN_MDIV4), &cmpll->mainpll_div4); + + writel((1<<31 | 1<<28 | (MAIN_INTFREQ5<<24) | MAIN_FRACFREQ5), + &cmpll->mainpll_freq5); + writel(((1<<8) | MAIN_MDIV5), &cmpll->mainpll_div5); + + writel((1<<8 | MAIN_MDIV6), &cmpll->mainpll_div6); + + writel((1<<8 | MAIN_MDIV7), &cmpll->mainpll_div7); + + /* Wait for PLL to lock */ + while ((readl(&cmpll->mainpll_ctrl) & BIT(7)) != BIT(7)) + ; + + /* Put the PLL in normal mode, disable bypass */ + main_pll_ctrl = readl(&cmpll->mainpll_ctrl); + main_pll_ctrl &= 0xFFFFFFFB; + writel(main_pll_ctrl, &cmpll->mainpll_ctrl); +} + +static void ddr_pll_bypass_ti816x(void) +{ + u32 ddr_pll_ctrl = 0; + + /* Put the PLL in bypass mode by setting BIT2 in its ctrl reg */ + ddr_pll_ctrl = readl(&cmpll->ddrpll_ctrl); + ddr_pll_ctrl &= 0xFFFFFFFB; + ddr_pll_ctrl |= BIT(2); + writel(ddr_pll_ctrl, &cmpll->ddrpll_ctrl); +} + +static void ddr_pll_init_ti816x(void) +{ + u32 ddr_pll_ctrl = 0; + /* Enable PLL by setting BIT3 in its ctrl reg */ + ddr_pll_ctrl = readl(&cmpll->ddrpll_ctrl); + ddr_pll_ctrl &= 0xFFFFFFF7; + ddr_pll_ctrl |= BIT(3); + writel(ddr_pll_ctrl, &cmpll->ddrpll_ctrl); + + /* Write the values of N,P in the CTRL reg */ + ddr_pll_ctrl = readl(&cmpll->ddrpll_ctrl); + ddr_pll_ctrl &= 0xFF; + ddr_pll_ctrl |= (DDR_N<<16 | DDR_P<<8); + writel(ddr_pll_ctrl, &cmpll->ddrpll_ctrl); + + ddr_delay(10); + + /* Power up clock1-5 */ + writel(0x0, &cmpll->ddrpll_pwd); + + /* Program the freq and divider values for clock1-3 */ + writel(((0<<8) | DDR_MDIV1), &cmpll->ddrpll_div1); + ddr_delay(1); + writel(((1<<8) | DDR_MDIV1), &cmpll->ddrpll_div1); + writel((1<<31 | 1<<28 | (DDR_INTFREQ2<<24) | DDR_FRACFREQ2), + &cmpll->ddrpll_freq2); + writel(((1<<8) | DDR_MDIV2), &cmpll->ddrpll_div2); + writel(((0<<8) | DDR_MDIV3), &cmpll->ddrpll_div3); + ddr_delay(1); + writel(((1<<8) | DDR_MDIV3), &cmpll->ddrpll_div3); + ddr_delay(1); + writel((0<<31 | 1<<28 | (DDR_INTFREQ3<<24) | DDR_FRACFREQ3), + &cmpll->ddrpll_freq3); + ddr_delay(1); + writel((1<<31 | 1<<28 | (DDR_INTFREQ3<<24) | DDR_FRACFREQ3), + &cmpll->ddrpll_freq3); + + ddr_delay(5); + + /* Wait for PLL to lock */ + while ((readl(&cmpll->ddrpll_ctrl) & BIT(7)) != BIT(7)) + ; + + /* Power up RCD */ + writel(BIT(0), DDR_RCD); +} + +static void peripheral_enable(void) +{ + /* Wake-up the l3_slow clock */ + writel(PRCM_MOD_EN, &cmalwon->l3slowclkstctrl); + + /* + * Note on Timers: + * There are 8 timers(0-7) out of which timer 0 is a secure timer. + * Timer 0 mux should not be changed + * + * To access the timer registers we need the to be + * enabled which is what we do in the first step + */ + + /* Enable timer1 */ + writel(PRCM_MOD_EN, &cmalwon->timer1clkctrl); + /* Select timer1 clock to be CLKIN (27MHz) */ + writel(BIT(1), CM_TIMER1_CLKSEL); + + /* Wait for timer1 to be ON-ACTIVE */ + while (((readl(&cmalwon->l3slowclkstctrl) + & (0x80000<<1))>>20) != 1) + ; + /* Wait for timer1 to be enabled */ + while (((readl(&cmalwon->timer1clkctrl) & 0x30000)>>16) != 0) + ; + /* Active posted mode */ + writel(PRCM_MOD_EN, (DM_TIMER1_BASE + 0x54)); + while (readl(DM_TIMER1_BASE + 0x10) & BIT(0)) + ; + /* Start timer1 */ + writel(BIT(0), (DM_TIMER1_BASE + 0x38)); + + /* eFuse */ + writel(PRCM_MOD_EN, CM_ALWON_CUST_EFUSE_CLKCTRL); + while (readl(CM_ALWON_CUST_EFUSE_CLKCTRL) != PRCM_MOD_EN) + ; + + /* Enable gpio0 */ + writel(PRCM_MOD_EN, &cmalwon->gpio0clkctrl); + while (readl(&cmalwon->gpio0clkctrl) != PRCM_MOD_EN) + ; + writel((BIT(8)), &cmalwon->gpio0clkctrl); + + /* Enable spi */ + writel(PRCM_MOD_EN, &cmalwon->spiclkctrl); + while (readl(&cmalwon->spiclkctrl) != PRCM_MOD_EN) + ; + + /* Enable i2c0 */ + writel(PRCM_MOD_EN, &cmalwon->i2c0clkctrl); + while (readl(&cmalwon->i2c0clkctrl) != PRCM_MOD_EN) + ; + + /* Enable ethernet0 */ + writel(PRCM_MOD_EN, &cmalwon->ethclkstctrl); + writel(PRCM_MOD_EN, &cmalwon->ethernet0clkctrl); + writel(PRCM_MOD_EN, &cmalwon->ethernet1clkctrl); + + /* Enable hsmmc */ + writel(PRCM_MOD_EN, &cmalwon->sdioclkctrl); + while (readl(&cmalwon->sdioclkctrl) != PRCM_MOD_EN) + ; +} + +void setup_clocks_for_console(void) +{ + /* Fix ROM code bug - from TI-PSP-04.00.02.14 */ + writel(0x0, CM_SYSCLK10_CLKSEL); + + ddr_pll_bypass_ti816x(); + + /* Enable uart0-2 */ + writel(PRCM_MOD_EN, &cmalwon->uart0clkctrl); + while (readl(&cmalwon->uart0clkctrl) != PRCM_MOD_EN) + ; + writel(PRCM_MOD_EN, &cmalwon->uart1clkctrl); + while (readl(&cmalwon->uart1clkctrl) != PRCM_MOD_EN) + ; + writel(PRCM_MOD_EN, &cmalwon->uart2clkctrl); + while (readl(&cmalwon->uart2clkctrl) != PRCM_MOD_EN) + ; + while ((readl(&cmalwon->l3slowclkstctrl) & 0x2100) != 0x2100) + ; +} + +void prcm_init(void) +{ + /* Enable the control */ + writel(PRCM_MOD_EN, &cmalwon->controlclkctrl); + + main_pll_init_ti816x(); + ddr_pll_init_ti816x(); + + /* + * With clk freqs setup to desired values, + * enable the required peripherals + */ + peripheral_enable(); +} diff --git a/arch/arm/cpu/armv7/am33xx/emif4.c b/arch/arm/cpu/armv7/am33xx/emif4.c index 3abb609..7340c4b 100644 --- a/arch/arm/cpu/armv7/am33xx/emif4.c +++ b/arch/arm/cpu/armv7/am33xx/emif4.c @@ -94,7 +94,9 @@ void config_ddr(unsigned int pll, unsigned int ioctrl, const struct emif_regs *regs, int nr) { ddr_pll_config(pll); +#ifndef CONFIG_TI816X config_vtp(nr); +#endif config_cmd_ctrl(ctrl, nr);
config_ddr_data(data, nr); diff --git a/arch/arm/include/asm/arch-am33xx/clock.h b/arch/arm/include/asm/arch-am33xx/clock.h index ff9d616..f212add 100644 --- a/arch/arm/include/asm/arch-am33xx/clock.h +++ b/arch/arm/include/asm/arch-am33xx/clock.h @@ -21,6 +21,10 @@
#include <asm/arch/clocks_am33xx.h>
+#ifdef CONFIG_TI81XX +#include <asm/arch/clock_ti81xx.h> +#endif + #define LDELAY 1000000
/*CM_<clock_domain>__CLKCTRL */ diff --git a/arch/arm/include/asm/arch-am33xx/clock_ti81xx.h b/arch/arm/include/asm/arch-am33xx/clock_ti81xx.h new file mode 100644 index 0000000..f069922 --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/clock_ti81xx.h @@ -0,0 +1,142 @@ +/* + * ti81xx.h + * + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> + * Antoine Tenart, atenart@adeneo-embedded.com + * + * This file is released under the terms of GPL v2 and any later version. + * See the file COPYING in the root directory of the source tree for details. + */ + +#ifndef _CLOCK_TI81XX_H_ +#define _CLOCK_TI81XX_H_ + +#define PRCM_MOD_EN 0x2 + +#define CM_DEFAULT_BASE (PRCM_BASE + 0x0500) +#define CM_ALWON_BASE (PRCM_BASE + 0x1400) + +struct cm_def { + unsigned int resv0[2]; + unsigned int l3fastclkstctrl; + unsigned int resv1[1]; + unsigned int pciclkstctrl; + unsigned int resv2[1]; + unsigned int ducaticlkstctrl; + unsigned int resv3[1]; + unsigned int emif0clkctrl; + unsigned int emif1clkctrl; + unsigned int dmmclkctrl; + unsigned int fwclkctrl; + unsigned int resv4[10]; + unsigned int usbclkctrl; + unsigned int resv5[1]; + unsigned int sataclkctrl; + unsigned int resv6[4]; + unsigned int ducaticlkctrl; + unsigned int pciclkctrl; +}; + +struct cm_alwon { + unsigned int l3slowclkstctrl; + unsigned int ethclkstctrl; + unsigned int l3medclkstctrl; + unsigned int mmu_clkstctrl; + unsigned int mmucfg_clkstctrl; + unsigned int ocmc0clkstctrl; +#if defined(CONFIG_TI814X) + unsigned int vcpclkstctrl; +#elif defined(CONFIG_TI816X) + unsigned int ocmc1clkstctrl; +#endif + unsigned int mpuclkstctrl; + unsigned int sysclk4clkstctrl; + unsigned int sysclk5clkstctrl; + unsigned int sysclk6clkstctrl; + unsigned int rtcclkstctrl; + unsigned int l3fastclkstctrl; + unsigned int resv0[67]; + unsigned int mcasp0clkctrl; + unsigned int mcasp1clkctrl; + unsigned int mcasp2clkctrl; + unsigned int mcbspclkctrl; + unsigned int uart0clkctrl; + unsigned int uart1clkctrl; + unsigned int uart2clkctrl; + unsigned int gpio0clkctrl; + unsigned int gpio1clkctrl; + unsigned int i2c0clkctrl; + unsigned int i2c1clkctrl; +#if defined(CONFIG_TI814X) + unsigned int mcasp345clkctrl; + unsigned int atlclkctrl; + unsigned int mlbclkctrl; + unsigned int pataclkctrl; + unsigned int resv1[1]; + unsigned int uart3clkctrl; + unsigned int uart4clkctrl; + unsigned int uart5clkctrl; +#elif defined(CONFIG_TI816X) + unsigned int resv1[1]; + unsigned int timer1clkctrl; + unsigned int timer2clkctrl; + unsigned int timer3clkctrl; + unsigned int timer4clkctrl; + unsigned int timer5clkctrl; + unsigned int timer6clkctrl; + unsigned int timer7clkctrl; +#endif + unsigned int wdtimerclkctrl; + unsigned int spiclkctrl; + unsigned int mailboxclkctrl; + unsigned int spinboxclkctrl; + unsigned int mmudataclkctrl; + unsigned int resv2[2]; + unsigned int mmucfgclkctrl; +#if defined(CONFIG_TI814X) + unsigned int resv3[2]; +#elif defined(CONFIG_TI816X) + unsigned int resv3[1]; + unsigned int sdioclkctrl; +#endif + unsigned int ocmc0clkctrl; +#if defined(CONFIG_TI814X) + unsigned int vcpclkctrl; +#elif defined(CONFIG_TI816X) + unsigned int ocmc1clkctrl; +#endif + unsigned int resv4[2]; + unsigned int controlclkctrl; + unsigned int resv5[2]; + unsigned int gpmcclkctrl; + unsigned int ethernet0clkctrl; + unsigned int ethernet1clkctrl; + unsigned int mpuclkctrl; +#if defined(CONFIG_TI814X) + unsigned int debugssclkctrl; +#elif defined(CONFIG_TI816X) + unsigned int resv6[1]; +#endif + unsigned int l3clkctrl; + unsigned int l4hsclkctrl; + unsigned int l4lsclkctrl; + unsigned int rtcclkctrl; + unsigned int tpccclkctrl; + unsigned int tptc0clkctrl; + unsigned int tptc1clkctrl; + unsigned int tptc2clkctrl; + unsigned int tptc3clkctrl; +#if defined(CONFIG_TI814X) + unsigned int resv6[4]; + unsigned int dcan01clkctrl; + unsigned int mmchs0clkctrl; + unsigned int mmchs1clkctrl; + unsigned int mmchs2clkctrl; + unsigned int custefuseclkctrl; +#elif defined(CONFIG_TI816X) + unsigned int sr0clkctrl; + unsigned int sr1clkctrl; +#endif +}; + +#endif /* _CLOCK_TI81XX_H_ */ diff --git a/arch/arm/include/asm/arch-am33xx/ddr_defs.h b/arch/arm/include/asm/arch-am33xx/ddr_defs.h index bb53a6a..374edbf 100644 --- a/arch/arm/include/asm/arch-am33xx/ddr_defs.h +++ b/arch/arm/include/asm/arch-am33xx/ddr_defs.h @@ -200,37 +200,46 @@ struct ddr_data_regs { * correspond to DATA1 registers defined here. */ struct ddr_regs { - unsigned int resv0[7]; - unsigned int cm0csratio; /* offset 0x01C */ + unsigned int resv0[3]; + unsigned int cm0config; /* offset 0x00C */ + unsigned int cm0configclk; /* offset 0x010 */ unsigned int resv1[2]; + unsigned int cm0csratio; /* offset 0x01C */ + unsigned int resv2[2]; unsigned int cm0dldiff; /* offset 0x028 */ unsigned int cm0iclkout; /* offset 0x02C */ - unsigned int resv2[8]; + unsigned int resv3[4]; + unsigned int cm1config; /* offset 0x040 */ + unsigned int cm1configclk; /* offset 0x044 */ + unsigned int resv4[2]; unsigned int cm1csratio; /* offset 0x050 */ - unsigned int resv3[2]; + unsigned int resv5[2]; unsigned int cm1dldiff; /* offset 0x05C */ unsigned int cm1iclkout; /* offset 0x060 */ - unsigned int resv4[8]; + unsigned int resv6[4]; + unsigned int cm2config; /* offset 0x074 */ + unsigned int cm2configclk; /* offset 0x078 */ + unsigned int resv7[2]; unsigned int cm2csratio; /* offset 0x084 */ - unsigned int resv5[2]; + unsigned int resv8[2]; unsigned int cm2dldiff; /* offset 0x090 */ unsigned int cm2iclkout; /* offset 0x094 */ - unsigned int resv6[12]; + unsigned int resv9[12]; unsigned int dt0rdsratio0; /* offset 0x0C8 */ - unsigned int resv7[4]; + unsigned int resv10[4]; unsigned int dt0wdsratio0; /* offset 0x0DC */ - unsigned int resv8[4]; + unsigned int resv11[4]; unsigned int dt0wiratio0; /* offset 0x0F0 */ - unsigned int resv9; + unsigned int resv12; unsigned int dt0wimode0; /* offset 0x0F8 */ unsigned int dt0giratio0; /* offset 0x0FC */ - unsigned int resv10; + unsigned int resv13; unsigned int dt0gimode0; /* offset 0x104 */ unsigned int dt0fwsratio0; /* offset 0x108 */ - unsigned int resv11[4]; + unsigned int resv14[4]; unsigned int dt0dqoffset; /* offset 0x11C */ unsigned int dt0wrsratio0; /* offset 0x120 */ - unsigned int resv12[4]; + unsigned int resv15[4]; unsigned int dt0rdelays0; /* offset 0x134 */ unsigned int dt0dldiff0; /* offset 0x138 */ }; diff --git a/arch/arm/include/asm/arch-am33xx/hardware.h b/arch/arm/include/asm/arch-am33xx/hardware.h index 5a27f9c..5106d7b 100644 --- a/arch/arm/include/asm/arch-am33xx/hardware.h +++ b/arch/arm/include/asm/arch-am33xx/hardware.h @@ -23,6 +23,8 @@ #include <asm/arch/omap.h> #ifdef CONFIG_AM33XX #include <asm/arch/hardware_am33xx.h> +#elif defined(CONFIG_TI816X) +#include <asm/arch/hardware_ti816x.h> #elif defined(CONFIG_TI814X) #include <asm/arch/hardware_ti814x.h> #endif @@ -61,21 +63,13 @@ #define CM_CEFUSE 0x44E00A00 #define PRM_DEVICE 0x44E00F00
-/* VTP Base address */ -#define VTP1_CTRL_ADDR 0x48140E10 - /* DDR Base address */ #define DDR_CTRL_ADDR 0x44E10E04 #define DDR_CONTROL_BASE_ADDR 0x44E11404 -#define DDR_PHY_CMD_ADDR2 0x47C0C800 -#define DDR_PHY_DATA_ADDR2 0x47C0C8C8
/* UART */ #define DEFAULT_UART_BASE UART0_BASE
-#define DDRPHY_0_CONFIG_BASE (CTRL_BASE + 0x1400) -#define DDRPHY_CONFIG_BASE DDRPHY_0_CONFIG_BASE - /* GPMC Base address */ #define GPMC_BASE 0x50000000
diff --git a/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h b/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h index fa02f19..8df60ac 100644 --- a/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h +++ b/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h @@ -39,12 +39,18 @@
/* VTP Base address */ #define VTP0_CTRL_ADDR 0x44E10E0C +#define VTP1_CTRL_ADDR 0x48140E10
/* DDR Base address */ #define DDR_PHY_CMD_ADDR 0x44E12000 #define DDR_PHY_DATA_ADDR 0x44E120C8 +#define DDR_PHY_CMD_ADDR2 0x47C0C800 +#define DDR_PHY_DATA_ADDR2 0x47C0C8C8 #define DDR_DATA_REGS_NR 2
+#define DDRPHY_0_CONFIG_BASE (CTRL_BASE + 0x1400) +#define DDRPHY_CONFIG_BASE DDRPHY_0_CONFIG_BASE + /* CPSW Config space */ #define CPSW_MDIO_BASE 0x4A101000
diff --git a/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h b/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h index 8f9315c..2ac6b7d 100644 --- a/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h +++ b/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h @@ -39,12 +39,18 @@
/* VTP Base address */ #define VTP0_CTRL_ADDR 0x48140E0C +#define VTP1_CTRL_ADDR 0x48140E10
/* DDR Base address */ #define DDR_PHY_CMD_ADDR 0x47C0C400 #define DDR_PHY_DATA_ADDR 0x47C0C4C8 +#define DDR_PHY_CMD_ADDR2 0x47C0C800 +#define DDR_PHY_DATA_ADDR2 0x47C0C8C8 #define DDR_DATA_REGS_NR 4
+#define DDRPHY_0_CONFIG_BASE (CTRL_BASE + 0x1400) +#define DDRPHY_CONFIG_BASE DDRPHY_0_CONFIG_BASE + /* CPSW Config space */ #define CPSW_MDIO_BASE 0x4A100800
diff --git a/arch/arm/include/asm/arch-am33xx/hardware_ti816x.h b/arch/arm/include/asm/arch-am33xx/hardware_ti816x.h new file mode 100644 index 0000000..141b703 --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/hardware_ti816x.h @@ -0,0 +1,57 @@ +/* + * hardware_ti816x.h + * + * TI816x hardware specific header + * + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> + * Antoine Tenart, atenart@adeneo-embedded.com + * Based on TI-PSP-04.00.02.14 + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __AM33XX_HARDWARE_TI816X_H +#define __AM33XX_HARDWARE_TI816X_H + +/* Watchdog Timer */ +#define WDT_BASE 0x480C2000 + +/* Control Module Base Address */ +#define CTRL_BASE 0x48140000 + +/* PRCM Base Address */ +#define PRCM_BASE 0x48180000 + +/* VTP Base address */ +#define VTP0_CTRL_ADDR 0x48198358 +#define VTP1_CTRL_ADDR 0x4819A358 + +/* DDR Base address */ +#define DDR_PHY_CMD_ADDR 0x48198000 +#define DDR_PHY_DATA_ADDR 0x481980C8 +#define DDR_PHY_CMD_ADDR2 0x4819A000 +#define DDR_PHY_DATA_ADDR2 0x4819A0C8 +#define DDR_DATA_REGS_NR 4 + +/* UART */ +#define UART0_BASE 0x48020000 +#define UART1_BASE 0x48022000 +#define UART2_BASE 0x48024000 + +#define DDRPHY_0_CONFIG_BASE 0x48198000 +#define DDRPHY_1_CONFIG_BASE 0x4819A000 +#define DDRPHY_CONFIG_BASE ((emif == 0) ? \ + DDRPHY_0_CONFIG_BASE : DDRPHY_1_CONFIG_BASE) + +/* RTC base address */ +#define RTC_BASE 0x480C0000 + +#endif /* __AM33XX_HARDWARE_TI816X_H */ diff --git a/arch/arm/include/asm/arch-am33xx/mmc_host_def.h b/arch/arm/include/asm/arch-am33xx/mmc_host_def.h index 51ba791..724e252 100644 --- a/arch/arm/include/asm/arch-am33xx/mmc_host_def.h +++ b/arch/arm/include/asm/arch-am33xx/mmc_host_def.h @@ -27,6 +27,9 @@ #if defined(CONFIG_TI814X) #undef MMC_CLOCK_REFERENCE #define MMC_CLOCK_REFERENCE 192 /* MHz */ +#elif defined(CONFIG_TI816X) +#undef MMC_CLOCK_REFERENCE +#define MMC_CLOCK_REFERENCE 48 /* MHz */ #endif
#endif /* MMC_HOST_DEF_H */ diff --git a/arch/arm/include/asm/arch-am33xx/mux.h b/arch/arm/include/asm/arch-am33xx/mux.h index 1c6b65f..4caa4d8 100644 --- a/arch/arm/include/asm/arch-am33xx/mux.h +++ b/arch/arm/include/asm/arch-am33xx/mux.h @@ -23,6 +23,8 @@ #include <asm/arch/mux_am33xx.h> #elif defined(CONFIG_TI814X) #include <asm/arch/mux_ti814x.h> +#elif defined(CONFIG_TI816X) +#include <asm/arch/mux_ti816x.h> #endif
struct module_pin_mux { diff --git a/arch/arm/include/asm/arch-am33xx/mux_ti816x.h b/arch/arm/include/asm/arch-am33xx/mux_ti816x.h new file mode 100644 index 0000000..e4e5a48 --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/mux_ti816x.h @@ -0,0 +1,363 @@ +/* + * mux_ti816x.h + * + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> + * Antoine Tenart, atenart@adeneo-embedded.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _MUX_TI816X_H_ +#define _MUX_TI816X_H_ + +#include <common.h> +#include <asm/io.h> + +#define MUX_CFG(value, offset) \ + __raw_writel(value, (CTRL_BASE + offset)); + +#define PULLDOWN_EN (0x0 << 4) /* Pull Down Selection */ +#define PULLUP_EN (0x1 << 4) /* Pull Up Selection */ +#define PULLUDEN (0x0 << 3) /* Pull up enabled */ +#define PULLUDDIS (0x1 << 3) /* Pull up disabled */ +#define MODE(val) (val) /* used for Readability */ + + +/* + * PAD CONTROL OFFSETS + * Field names corresponds to the pad signal name + */ +struct pad_signals { + int pincntl1; + int pincntl2; + int pincntl3; + int pincntl4; + int pincntl5; + int pincntl6; + int pincntl7; + int pincntl8; + int pincntl9; + int pincntl10; + int pincntl11; + int pincntl12; + int pincntl13; + int pincntl14; + int pincntl15; + int pincntl16; + int pincntl17; + int pincntl18; + int pincntl19; + int pincntl20; + int pincntl21; + int pincntl22; + int pincntl23; + int pincntl24; + int pincntl25; + int pincntl26; + int pincntl27; + int pincntl28; + int pincntl29; + int pincntl30; + int pincntl31; + int pincntl32; + int pincntl33; + int pincntl34; + int pincntl35; + int pincntl36; + int pincntl37; + int pincntl38; + int pincntl39; + int pincntl40; + int pincntl41; + int pincntl42; + int pincntl43; + int pincntl44; + int pincntl45; + int pincntl46; + int pincntl47; + int pincntl48; + int pincntl49; + int pincntl50; + int pincntl51; + int pincntl52; + int pincntl53; + int pincntl54; + int pincntl55; + int pincntl56; + int pincntl57; + int pincntl58; + int pincntl59; + int pincntl60; + int pincntl61; + int pincntl62; + int pincntl63; + int pincntl64; + int pincntl65; + int pincntl66; + int pincntl67; + int pincntl68; + int pincntl69; + int pincntl70; + int pincntl71; + int pincntl72; + int pincntl73; + int pincntl74; + int pincntl75; + int pincntl76; + int pincntl77; + int pincntl78; + int pincntl79; + int pincntl80; + int pincntl81; + int pincntl82; + int pincntl83; + int pincntl84; + int pincntl85; + int pincntl86; + int pincntl87; + int pincntl88; + int pincntl89; + int pincntl90; + int pincntl91; + int pincntl92; + int pincntl93; + int pincntl94; + int pincntl95; + int pincntl96; + int pincntl97; + int pincntl98; + int pincntl99; + int pincntl100; + int pincntl101; + int pincntl102; + int pincntl103; + int pincntl104; + int pincntl105; + int pincntl106; + int pincntl107; + int pincntl108; + int pincntl109; + int pincntl110; + int pincntl111; + int pincntl112; + int pincntl113; + int pincntl114; + int pincntl115; + int pincntl116; + int pincntl117; + int pincntl118; + int pincntl119; + int pincntl120; + int pincntl121; + int pincntl122; + int pincntl123; + int pincntl124; + int pincntl125; + int pincntl126; + int pincntl127; + int pincntl128; + int pincntl129; + int pincntl130; + int pincntl131; + int pincntl132; + int pincntl133; + int pincntl134; + int pincntl135; + int pincntl136; + int pincntl137; + int pincntl138; + int pincntl139; + int pincntl140; + int pincntl141; + int pincntl142; + int pincntl143; + int pincntl144; + int pincntl145; + int pincntl146; + int pincntl147; + int pincntl148; + int pincntl149; + int pincntl150; + int pincntl151; + int pincntl152; + int pincntl153; + int pincntl154; + int pincntl155; + int pincntl156; + int pincntl157; + int pincntl158; + int pincntl159; + int pincntl160; + int pincntl161; + int pincntl162; + int pincntl163; + int pincntl164; + int pincntl165; + int pincntl166; + int pincntl167; + int pincntl168; + int pincntl169; + int pincntl170; + int pincntl171; + int pincntl172; + int pincntl173; + int pincntl174; + int pincntl175; + int pincntl176; + int pincntl177; + int pincntl178; + int pincntl179; + int pincntl180; + int pincntl181; + int pincntl182; + int pincntl183; + int pincntl184; + int pincntl185; + int pincntl186; + int pincntl187; + int pincntl188; + int pincntl189; + int pincntl190; + int pincntl191; + int pincntl192; + int pincntl193; + int pincntl194; + int pincntl195; + int pincntl196; + int pincntl197; + int pincntl198; + int pincntl199; + int pincntl200; + int pincntl201; + int pincntl202; + int pincntl203; + int pincntl204; + int pincntl205; + int pincntl206; + int pincntl207; + int pincntl208; + int pincntl209; + int pincntl210; + int pincntl211; + int pincntl212; + int pincntl213; + int pincntl214; + int pincntl215; + int pincntl216; + int pincntl217; + int pincntl218; + int pincntl219; + int pincntl220; + int pincntl221; + int pincntl222; + int pincntl223; + int pincntl224; + int pincntl225; + int pincntl226; + int pincntl227; + int pincntl228; + int pincntl229; + int pincntl230; + int pincntl231; + int pincntl232; + int pincntl233; + int pincntl234; + int pincntl235; + int pincntl236; + int pincntl237; + int pincntl238; + int pincntl239; + int pincntl240; + int pincntl241; + int pincntl242; + int pincntl243; + int pincntl244; + int pincntl245; + int pincntl246; + int pincntl247; + int pincntl248; + int pincntl249; + int pincntl250; + int pincntl251; + int pincntl252; + int pincntl253; + int pincntl254; + int pincntl255; + int pincntl256; + int pincntl257; + int pincntl258; + int pincntl259; + int pincntl260; + int pincntl261; + int pincntl262; + int pincntl263; + int pincntl264; + int pincntl265; + int pincntl266; + int pincntl267; + int pincntl268; + int pincntl269; + int pincntl270; + int pincntl271; + int pincntl272; + int pincntl273; + int pincntl274; + int pincntl275; + int pincntl276; + int pincntl277; + int pincntl278; + int pincntl279; + int pincntl280; + int pincntl281; + int pincntl282; + int pincntl283; + int pincntl284; + int pincntl285; + int pincntl286; + int pincntl287; + int pincntl288; + int pincntl289; + int pincntl290; + int pincntl291; + int pincntl292; + int pincntl293; + int pincntl294; + int pincntl295; + int pincntl296; + int pincntl297; + int pincntl298; + int pincntl299; + int pincntl300; + int pincntl301; + int pincntl302; + int pincntl303; + int pincntl304; + int pincntl305; + int pincntl306; + int pincntl307; + int pincntl308; + int pincntl309; + int pincntl310; + int pincntl311; + int pincntl312; + int pincntl313; + int pincntl314; + int pincntl315; + int pincntl316; + int pincntl317; + int pincntl318; + int pincntl319; + int pincntl320; + int pincntl321; + int pincntl322; + int pincntl323; +}; + +#endif /* endif _MUX_TI816X_H_ */ diff --git a/arch/arm/include/asm/arch-am33xx/spl.h b/arch/arm/include/asm/arch-am33xx/spl.h index 4c23b27..6d7e8d6 100644 --- a/arch/arm/include/asm/arch-am33xx/spl.h +++ b/arch/arm/include/asm/arch-am33xx/spl.h @@ -23,6 +23,14 @@ #ifndef _ASM_ARCH_SPL_H_ #define _ASM_SPL_H_
+#if defined(CONFIG_TI816X) +#define BOOT_DEVICE_XIP 2 +#define BOOT_DEVICE_NAND 3 +#define BOOT_DEVICE_MMC1 6 +#define BOOT_DEVICE_MMC2 5 +#define BOOT_DEVICE_UART 0x43 +#define BOOT_DEVICE_MMC2_2 0xFF +#else #define BOOT_DEVICE_XIP 2 #define BOOT_DEVICE_NAND 5 #ifdef CONFIG_AM33XX @@ -37,11 +45,12 @@ #define BOOT_DEVICE_USBETH 68 #define BOOT_DEVICE_CPGMAC 70 #define BOOT_DEVICE_MMC2_2 0xFF +#endif
#ifdef CONFIG_AM33XX #define MMC_BOOT_DEVICES_START BOOT_DEVICE_MMC1 #define MMC_BOOT_DEVICES_END BOOT_DEVICE_MMC2 -#elif defined(CONFIG_TI814X) +#elif defined(CONFIG_TI81XX) #define MMC_BOOT_DEVICES_START BOOT_DEVICE_MMC2 #define MMC_BOOT_DEVICES_END BOOT_DEVICE_MMC1 #endif
TENART Antoine
