[PATCH] board: freescale: p1_p2_rdb_pc: Remove I-flag from second L2 SRAM mapping
U-Boot for initial L2 SRAM uses L2 memory-mapping mode and not L2 with locked lines. P2020 reference manual about L2 memory-mapping mode says:
Accesses to memory-mapped SRAM are cacheable only in the corresponding e500 L1 caches.
So there is no need to set Caching-Inhibit I-bit for second part of initial L2 SRAM mapping in TLB entry. Remove it. First part of initial L2 SRAM mapping already does not have I-bit set.
For more details see also: https://lore.kernel.org/u-boot/20220508150844.qqxg452rs4wtf5bs@pali/
Signed-off-by: Pali Rohár pali@kernel.org --- board/freescale/p1_p2_rdb_pc/tlb.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/freescale/p1_p2_rdb_pc/tlb.c b/board/freescale/p1_p2_rdb_pc/tlb.c index 52acd22dc95a..74bf8cc58ff9 100644 --- a/board/freescale/p1_p2_rdb_pc/tlb.c +++ b/board/freescale/p1_p2_rdb_pc/tlb.c @@ -105,14 +105,14 @@ struct fsl_e_tlb_entry tlb_table[] = { #endif /* RAMBOOT/SPL */
#ifdef CONFIG_SYS_INIT_L2_ADDR - /* *I*G - L2SRAM */ + /* ***G - L2SRAM */ SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L2_ADDR, CONFIG_SYS_INIT_L2_ADDR_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, 0, 11, BOOKE_PAGESZ_256K, 1), #if CONFIG_SYS_L2_SIZE >= (256 << 10) SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L2_ADDR + 0x40000, CONFIG_SYS_INIT_L2_ADDR_PHYS + 0x40000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, 0, 12, BOOKE_PAGESZ_256K, 1) #endif #endif
Pali Rohár
