[PATCH 0/2] Update UniPhier devicetree
Migrate the USB node to the original node after updating dwc3-generic and dwc3-uniphier. https://lists.denx.de/pipermail/u-boot/2023-February/509635.html
And synchronize UniPhier devicetree with Linux v6.2.
Kunihiko Hayashi (2): ARM: dts: uniphier: Switch USB node to the original ARM: dts: uniphier: Sync DT with Linux v6.2
arch/arm/dts/uniphier-ld11-global.dts | 4 + arch/arm/dts/uniphier-ld11-ref.dts | 6 +- arch/arm/dts/uniphier-ld11.dtsi | 94 +++++----- arch/arm/dts/uniphier-ld20.dtsi | 150 ++++++++-------- arch/arm/dts/uniphier-ld4-ref.dts | 10 +- arch/arm/dts/uniphier-ld4.dtsi | 76 ++++---- arch/arm/dts/uniphier-pro4-ace.dts | 8 + arch/arm/dts/uniphier-pro4-ref.dts | 18 +- arch/arm/dts/uniphier-pro4-sanji.dts | 6 +- arch/arm/dts/uniphier-pro4.dtsi | 247 ++++++++++++++++--------- arch/arm/dts/uniphier-pro5.dtsi | 101 ++++++----- arch/arm/dts/uniphier-pxs2-gentil.dts | 4 + arch/arm/dts/uniphier-pxs2.dtsi | 197 ++++++++++---------- arch/arm/dts/uniphier-pxs3-ref.dts | 18 +- arch/arm/dts/uniphier-pxs3.dtsi | 248 ++++++++++++++++---------- arch/arm/dts/uniphier-sld8-ref.dts | 10 +- arch/arm/dts/uniphier-sld8.dtsi | 77 ++++---- 17 files changed, 761 insertions(+), 513 deletions(-)
UniPhier DT applies its own USB node for U-Boot due to the USB driver constrains. After solving this issue, u-boot allows the original USB node.
After switching USB node, synchronization of USB node with Linux becomes possible.
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- arch/arm/dts/uniphier-ld20.dtsi | 21 +---------------- arch/arm/dts/uniphier-pro4.dtsi | 42 ++------------------------------- arch/arm/dts/uniphier-pxs2.dtsi | 42 ++------------------------------- arch/arm/dts/uniphier-pxs3.dtsi | 42 ++------------------------------- 4 files changed, 7 insertions(+), 140 deletions(-)
diff --git a/arch/arm/dts/uniphier-ld20.dtsi b/arch/arm/dts/uniphier-ld20.dtsi index 4549935c42..1aad4cff5b 100644 --- a/arch/arm/dts/uniphier-ld20.dtsi +++ b/arch/arm/dts/uniphier-ld20.dtsi @@ -744,7 +744,7 @@ }; };
- _usb: usb@65a00000 { + usb: usb@65a00000 { compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65a00000 0xcd00>; @@ -894,25 +894,6 @@ }; };
- /* FIXME: U-Boot own node */ - usb: usb@65b00000 { - compatible = "socionext,uniphier-ld20-dwc3"; - reg = <0x65b00000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb0>, <&pinctrl_usb1>, - <&pinctrl_usb2>, <&pinctrl_usb3>; - dwc3@65a00000 { - compatible = "snps,dwc3"; - reg = <0x65a00000 0x10000>; - interrupts = <0 134 4>; - dr_mode = "host"; - tx-fifo-resize; - }; - }; - pcie: pcie@66000000 { compatible = "socionext,uniphier-pcie", "snps,dw-pcie"; status = "disabled"; diff --git a/arch/arm/dts/uniphier-pro4.dtsi b/arch/arm/dts/uniphier-pro4.dtsi index 9dae4e9b23..cd706f485e 100644 --- a/arch/arm/dts/uniphier-pro4.dtsi +++ b/arch/arm/dts/uniphier-pro4.dtsi @@ -503,7 +503,7 @@ }; };
- _usb0: usb@65a00000 { + usb0: usb@65a00000 { compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65a00000 0xcd00>; @@ -556,26 +556,7 @@ }; };
- /* FIXME: U-Boot own node */ - usb0: usb@65b00000 { - compatible = "socionext,uniphier-pro4-dwc3"; - status = "disabled"; - reg = <0x65b00000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb0>; - dwc3@65a00000 { - compatible = "snps,dwc3"; - reg = <0x65a00000 0x10000>; - interrupts = <0 134 4>; - dr_mode = "host"; - tx-fifo-resize; - }; - }; - - _usb1: usb@65c00000 { + usb1: usb@65c00000 { compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65c00000 0xcd00>; @@ -617,25 +598,6 @@ }; };
- /* FIXME: U-Boot own node */ - usb1: usb@65d00000 { - compatible = "socionext,uniphier-pro4-dwc3"; - status = "disabled"; - reg = <0x65d00000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb1>; - dwc3@65c00000 { - compatible = "snps,dwc3"; - reg = <0x65c00000 0x10000>; - interrupts = <0 137 4>; - dr_mode = "host"; - tx-fifo-resize; - }; - }; - nand: nand-controller@68000000 { compatible = "socionext,uniphier-denali-nand-v5a"; status = "disabled"; diff --git a/arch/arm/dts/uniphier-pxs2.dtsi b/arch/arm/dts/uniphier-pxs2.dtsi index 7a8b6c10f4..0364bdce7e 100644 --- a/arch/arm/dts/uniphier-pxs2.dtsi +++ b/arch/arm/dts/uniphier-pxs2.dtsi @@ -593,7 +593,7 @@ }; };
- _usb0: usb@65a00000 { + usb0: usb@65a00000 { compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65a00000 0xcd00>; @@ -689,26 +689,7 @@ }; };
- /* FIXME: U-Boot own node */ - usb0: usb@65b00000 { - compatible = "socionext,uniphier-pxs2-dwc3"; - status = "disabled"; - reg = <0x65b00000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb0>, <&pinctrl_usb2>; - dwc3@65a00000 { - compatible = "snps,dwc3"; - reg = <0x65a00000 0x10000>; - interrupts = <0 134 4>; - dr_mode = "host"; - tx-fifo-resize; - }; - }; - - _usb1: usb@65c00000 { + usb1: usb@65c00000 { compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65c00000 0xcd00>; @@ -792,25 +773,6 @@ }; };
- /* FIXME: U-Boot own node */ - usb1: usb@65d00000 { - compatible = "socionext,uniphier-pxs2-dwc3"; - status = "disabled"; - reg = <0x65d00000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb1>, <&pinctrl_usb3>; - dwc3@65c00000 { - compatible = "snps,dwc3"; - reg = <0x65c00000 0x10000>; - interrupts = <0 137 4>; - dr_mode = "host"; - tx-fifo-resize; - }; - }; - nand: nand-controller@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; diff --git a/arch/arm/dts/uniphier-pxs3.dtsi b/arch/arm/dts/uniphier-pxs3.dtsi index 004656c992..410bf51e52 100644 --- a/arch/arm/dts/uniphier-pxs3.dtsi +++ b/arch/arm/dts/uniphier-pxs3.dtsi @@ -595,7 +595,7 @@ }; };
- _usb0: usb@65a00000 { + usb0: usb@65a00000 { compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65a00000 0xcd00>; @@ -697,26 +697,7 @@ }; };
- /* FIXME: U-Boot own node */ - usb0: usb@65b00000 { - compatible = "socionext,uniphier-pxs3-dwc3"; - status = "disabled"; - reg = <0x65b00000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb0>, <&pinctrl_usb2>; - dwc3@65a00000 { - compatible = "snps,dwc3"; - reg = <0x65a00000 0x10000>; - interrupts = <0 134 4>; - dr_mode = "host"; - tx-fifo-resize; - }; - }; - - _usb1: usb@65c00000 { + usb1: usb@65c00000 { compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65c00000 0xcd00>; @@ -810,25 +791,6 @@ }; };
- /* FIXME: U-Boot own node */ - usb1: usb@65d00000 { - compatible = "socionext,uniphier-pxs3-dwc3"; - status = "disabled"; - reg = <0x65d00000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb1>, <&pinctrl_usb3>; - dwc3@65c00000 { - compatible = "snps,dwc3"; - reg = <0x65c00000 0x10000>; - interrupts = <0 137 4>; - dr_mode = "host"; - tx-fifo-resize; - }; - }; - pcie: pcie@66000000 { compatible = "socionext,uniphier-pcie", "snps,dw-pcie"; status = "disabled";
Very nice
Acked-by: Marek Vasut marex@denx.de
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com Acked-by: Marek Vasut marex@denx.de
Synchronize devicetree sources with Linux v6.2.
- Use GIC interrupt definitions - Add reg properties in USB-glue and SoC-glue node - Fix node names to follow the generic names list in DT specification - Add L2 cache and AHCI nodes - Update nand and pcie nodes - And some trivial fixes
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- arch/arm/dts/uniphier-ld11-global.dts | 4 + arch/arm/dts/uniphier-ld11-ref.dts | 6 +- arch/arm/dts/uniphier-ld11.dtsi | 94 ++++++------ arch/arm/dts/uniphier-ld20.dtsi | 129 +++++++++------- arch/arm/dts/uniphier-ld4-ref.dts | 10 +- arch/arm/dts/uniphier-ld4.dtsi | 76 ++++++---- arch/arm/dts/uniphier-pro4-ace.dts | 8 + arch/arm/dts/uniphier-pro4-ref.dts | 18 ++- arch/arm/dts/uniphier-pro4-sanji.dts | 6 +- arch/arm/dts/uniphier-pro4.dtsi | 205 +++++++++++++++++++------ arch/arm/dts/uniphier-pro5.dtsi | 101 +++++++------ arch/arm/dts/uniphier-pxs2-gentil.dts | 4 + arch/arm/dts/uniphier-pxs2.dtsi | 155 ++++++++++++------- arch/arm/dts/uniphier-pxs3-ref.dts | 18 ++- arch/arm/dts/uniphier-pxs3.dtsi | 206 +++++++++++++++++++------- arch/arm/dts/uniphier-sld8-ref.dts | 10 +- arch/arm/dts/uniphier-sld8.dtsi | 77 ++++++---- 17 files changed, 754 insertions(+), 373 deletions(-)
diff --git a/arch/arm/dts/uniphier-ld11-global.dts b/arch/arm/dts/uniphier-ld11-global.dts index 644ffb9707..da44a15a8a 100644 --- a/arch/arm/dts/uniphier-ld11-global.dts +++ b/arch/arm/dts/uniphier-ld11-global.dts @@ -164,4 +164,8 @@
&nand { status = "okay"; + + nand@0 { + reg = <0>; + }; }; diff --git a/arch/arm/dts/uniphier-ld11-ref.dts b/arch/arm/dts/uniphier-ld11-ref.dts index 617d2b1e9b..414aeb99e6 100644 --- a/arch/arm/dts/uniphier-ld11-ref.dts +++ b/arch/arm/dts/uniphier-ld11-ref.dts @@ -39,11 +39,11 @@ };
ðsc { - interrupts = <0 8>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; };
&serialsc { - interrupts = <0 8>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; };
&serial0 { @@ -51,7 +51,7 @@ };
&gpio { - xirq0 { + xirq0-hog { gpio-hog; gpios = <UNIPHIER_GPIO_IRQ(0) 0>; input; diff --git a/arch/arm/dts/uniphier-ld11.dtsi b/arch/arm/dts/uniphier-ld11.dtsi index 104d56d625..7bb36b0714 100644 --- a/arch/arm/dts/uniphier-ld11.dtsi +++ b/arch/arm/dts/uniphier-ld11.dtsi @@ -7,6 +7,7 @@
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/gpio/uniphier-gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h>
/ { compatible = "socionext,uniphier-ld11"; @@ -35,6 +36,7 @@ reg = <0 0x000>; clocks = <&sys_clk 33>; enable-method = "psci"; + next-level-cache = <&l2>; operating-points-v2 = <&cluster0_opp>; };
@@ -44,8 +46,13 @@ reg = <0 0x001>; clocks = <&sys_clk 33>; enable-method = "psci"; + next-level-cache = <&l2>; operating-points-v2 = <&cluster0_opp>; }; + + l2: l2-cache { + compatible = "cache"; + }; };
cluster0_opp: opp-table { @@ -102,10 +109,10 @@
timer { compatible = "arm,armv8-timer"; - interrupts = <1 13 4>, - <1 14 4>, - <1 11 4>, - <1 10 4>; + interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 14 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 11 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 10 IRQ_TYPE_LEVEL_HIGH>; };
reserved-memory { @@ -131,7 +138,7 @@ reg = <0x54006000 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 39 4>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi0>; clocks = <&peri_clk 11>; @@ -144,7 +151,7 @@ reg = <0x54006100 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 216 4>; + interrupts = <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi1>; clocks = <&peri_clk 12>; @@ -155,7 +162,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006800 0x40>; - interrupts = <0 33 4>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; clocks = <&peri_clk 0>; @@ -166,7 +173,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006900 0x40>; - interrupts = <0 35 4>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; clocks = <&peri_clk 1>; @@ -177,7 +184,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006a00 0x40>; - interrupts = <0 37 4>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; clocks = <&peri_clk 2>; @@ -188,7 +195,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006b00 0x40>; - interrupts = <0 177 4>; + interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart3>; clocks = <&peri_clk 3>; @@ -223,7 +230,7 @@ audio@56000000 { compatible = "socionext,uniphier-ld11-aio"; reg = <0x56000000 0x80000>; - interrupts = <0 144 4>; + interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_aout1>, <&pinctrl_aoutiec1>; @@ -306,12 +313,12 @@ }; };
- adamv@57920000 { + syscon@57920000 { compatible = "socionext,uniphier-ld11-adamv", "simple-mfd", "syscon"; reg = <0x57920000 0x1000>;
- adamv_rst: reset { + adamv_rst: reset-controller { compatible = "socionext,uniphier-ld11-adamv-reset"; #reset-cells = <1>; }; @@ -323,7 +330,7 @@ reg = <0x58780000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 41 4>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c0>; clocks = <&peri_clk 4>; @@ -337,7 +344,7 @@ reg = <0x58781000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 42 4>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c1>; clocks = <&peri_clk 5>; @@ -350,7 +357,7 @@ reg = <0x58782000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 43 4>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 6>; resets = <&peri_rst 6>; clock-frequency = <400000>; @@ -362,7 +369,7 @@ reg = <0x58783000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 44 4>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c3>; clocks = <&peri_clk 7>; @@ -376,7 +383,7 @@ reg = <0x58784000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 45 4>; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c4>; clocks = <&peri_clk 8>; @@ -389,7 +396,7 @@ reg = <0x58785000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 25 4>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 9>; resets = <&peri_rst 9>; clock-frequency = <400000>; @@ -410,28 +417,28 @@ reg = <0x59801000 0x400>; };
- sdctrl@59810000 { + syscon@59810000 { compatible = "socionext,uniphier-ld11-sdctrl", "simple-mfd", "syscon"; reg = <0x59810000 0x400>;
- sd_rst: reset { + sd_rst: reset-controller { compatible = "socionext,uniphier-ld11-sd-reset"; #reset-cells = <1>; }; };
- perictrl@59820000 { + syscon@59820000 { compatible = "socionext,uniphier-ld11-perictrl", "simple-mfd", "syscon"; reg = <0x59820000 0x200>;
- peri_clk: clock { + peri_clk: clock-controller { compatible = "socionext,uniphier-ld11-peri-clock"; #clock-cells = <1>; };
- peri_rst: reset { + peri_rst: reset-controller { compatible = "socionext,uniphier-ld11-peri-reset"; #reset-cells = <1>; }; @@ -440,7 +447,7 @@ emmc: mmc@5a000000 { compatible = "socionext,uniphier-sd4hc", "cdns,sd4hc"; reg = <0x5a000000 0x400>; - interrupts = <0 78 4>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_emmc>; clocks = <&sys_clk 4>; @@ -460,7 +467,7 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a800100 0x100>; - interrupts = <0 243 4>; + interrupts = <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>; clocks = <&sys_clk 8>, <&mio_clk 7>, <&mio_clk 8>, @@ -476,7 +483,7 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; - interrupts = <0 244 4>; + interrupts = <GIC_SPI 244 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb1>; clocks = <&sys_clk 8>, <&mio_clk 7>, <&mio_clk 9>, @@ -492,7 +499,7 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a820100 0x100>; - interrupts = <0 245 4>; + interrupts = <GIC_SPI 245 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb2>; clocks = <&sys_clk 8>, <&mio_clk 7>, <&mio_clk 10>, @@ -504,24 +511,24 @@ has-transaction-translator; };
- mioctrl@5b3e0000 { + syscon@5b3e0000 { compatible = "socionext,uniphier-ld11-mioctrl", "simple-mfd", "syscon"; reg = <0x5b3e0000 0x800>;
- mio_clk: clock { + mio_clk: clock-controller { compatible = "socionext,uniphier-ld11-mio-clock"; #clock-cells = <1>; };
- mio_rst: reset { + mio_rst: reset-controller { compatible = "socionext,uniphier-ld11-mio-reset"; #reset-cells = <1>; resets = <&sys_rst 7>; }; };
- soc_glue: soc-glue@5f800000 { + soc_glue: syscon@5f800000 { compatible = "socionext,uniphier-ld11-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -530,7 +537,7 @@ compatible = "socionext,uniphier-ld11-pinctrl"; };
- usb-phy { + usb-hub { compatible = "socionext,uniphier-ld11-usb2-phy"; #address-cells = <1>; #size-cells = <0>; @@ -552,9 +559,10 @@ }; };
- soc-glue@5f900000 { + syscon@5f900000 { compatible = "socionext,uniphier-ld11-soc-glue-debug", - "simple-mfd"; + "simple-mfd", "syscon"; + reg = <0x5f900000 0x2000>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x5f900000 0x2000>; @@ -573,7 +581,7 @@ xdmac: dma-controller@5fc10000 { compatible = "socionext,uniphier-xdmac"; reg = <0x5fc10000 0x5300>; - interrupts = <0 188 4>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; dma-channels = <16>; #dma-cells = <2>; }; @@ -591,20 +599,20 @@ <0x5fe40000 0x80000>; /* GICR */ interrupt-controller; #interrupt-cells = <3>; - interrupts = <1 9 4>; + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; };
- sysctrl@61840000 { + syscon@61840000 { compatible = "socionext,uniphier-ld11-sysctrl", "simple-mfd", "syscon"; reg = <0x61840000 0x10000>;
- sys_clk: clock { + sys_clk: clock-controller { compatible = "socionext,uniphier-ld11-clock"; #clock-cells = <1>; };
- sys_rst: reset { + sys_rst: reset-controller { compatible = "socionext,uniphier-ld11-reset"; #reset-cells = <1>; }; @@ -618,7 +626,7 @@ compatible = "socionext,uniphier-ld11-ave4"; status = "disabled"; reg = <0x65000000 0x8500>; - interrupts = <0 66 4>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; clock-names = "ether"; clocks = <&sys_clk 6>; reset-names = "ether"; @@ -638,7 +646,9 @@ status = "disabled"; reg-names = "nand_data", "denali_reg"; reg = <0x68000000 0x20>, <0x68100000 0x1000>; - interrupts = <0 65 4>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_nand>; clock-names = "nand", "nand_x", "ecc"; diff --git a/arch/arm/dts/uniphier-ld20.dtsi b/arch/arm/dts/uniphier-ld20.dtsi index 1aad4cff5b..4e21716302 100644 --- a/arch/arm/dts/uniphier-ld20.dtsi +++ b/arch/arm/dts/uniphier-ld20.dtsi @@ -7,6 +7,7 @@
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/gpio/uniphier-gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/thermal/thermal.h>
/ { @@ -45,6 +46,7 @@ reg = <0 0x000>; clocks = <&sys_clk 32>; enable-method = "psci"; + next-level-cache = <&a72_l2>; operating-points-v2 = <&cluster0_opp>; #cooling-cells = <2>; }; @@ -55,6 +57,7 @@ reg = <0 0x001>; clocks = <&sys_clk 32>; enable-method = "psci"; + next-level-cache = <&a72_l2>; operating-points-v2 = <&cluster0_opp>; #cooling-cells = <2>; }; @@ -65,6 +68,7 @@ reg = <0 0x100>; clocks = <&sys_clk 33>; enable-method = "psci"; + next-level-cache = <&a53_l2>; operating-points-v2 = <&cluster1_opp>; #cooling-cells = <2>; }; @@ -75,12 +79,21 @@ reg = <0 0x101>; clocks = <&sys_clk 33>; enable-method = "psci"; + next-level-cache = <&a53_l2>; operating-points-v2 = <&cluster1_opp>; #cooling-cells = <2>; }; + + a72_l2: l2-cache0 { + compatible = "cache"; + }; + + a53_l2: l2-cache1 { + compatible = "cache"; + }; };
- cluster0_opp: opp-table0 { + cluster0_opp: opp-table-0 { compatible = "operating-points-v2"; opp-shared;
@@ -118,7 +131,7 @@ }; };
- cluster1_opp: opp-table1 { + cluster1_opp: opp-table-1 { compatible = "operating-points-v2"; opp-shared;
@@ -176,10 +189,10 @@
thermal-zones { @@ -236,7 +249,7 @@ reg = <0x54006000 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 39 4>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi0>; clocks = <&peri_clk 11>; @@ -249,7 +262,7 @@ reg = <0x54006100 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 216 4>; + interrupts = <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi1>; clocks = <&peri_clk 12>; @@ -262,7 +275,7 @@ reg = <0x54006200 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 229 4>; + interrupts = <GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi2>; clocks = <&peri_clk 13>; @@ -275,7 +288,7 @@ reg = <0x54006300 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 230 4>; + interrupts = <GIC_SPI 230 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi3>; clocks = <&peri_clk 14>; @@ -286,7 +299,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006800 0x40>; - interrupts = <0 33 4>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; clocks = <&peri_clk 0>; @@ -297,7 +310,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006900 0x40>; - interrupts = <0 35 4>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; clocks = <&peri_clk 1>; @@ -308,7 +321,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006a00 0x40>; - interrupts = <0 37 4>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; clocks = <&peri_clk 2>; @@ -319,7 +332,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006b00 0x40>; - interrupts = <0 177 4>; + interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart3>; clocks = <&peri_clk 3>; @@ -348,7 +361,7 @@ audio@56000000 { compatible = "socionext,uniphier-ld20-aio"; reg = <0x56000000 0x80000>; - interrupts = <0 144 4>; + interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_aout1>, <&pinctrl_aoutiec1>; @@ -431,12 +444,12 @@ }; };
- adamv@57920000 { + syscon@57920000 { compatible = "socionext,uniphier-ld20-adamv", "simple-mfd", "syscon"; reg = <0x57920000 0x1000>;
- adamv_rst: reset { + adamv_rst: reset-controller { compatible = "socionext,uniphier-ld20-adamv-reset"; #reset-cells = <1>; }; @@ -448,7 +461,7 @@ reg = <0x58780000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 41 4>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c0>; clocks = <&peri_clk 4>; @@ -462,7 +475,7 @@ reg = <0x58781000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 42 4>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c1>; clocks = <&peri_clk 5>; @@ -475,7 +488,7 @@ reg = <0x58782000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 43 4>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 6>; resets = <&peri_rst 6>; clock-frequency = <400000>; @@ -487,7 +500,7 @@ reg = <0x58783000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 44 4>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c3>; clocks = <&peri_clk 7>; @@ -501,7 +514,7 @@ reg = <0x58784000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 45 4>; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c4>; clocks = <&peri_clk 8>; @@ -514,7 +527,7 @@ reg = <0x58785000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 25 4>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 9>; resets = <&peri_rst 9>; clock-frequency = <400000>; @@ -535,33 +548,33 @@ reg = <0x59801000 0x400>; };
- sdctrl@59810000 { + sdctrl: syscon@59810000 { compatible = "socionext,uniphier-ld20-sdctrl", "simple-mfd", "syscon"; reg = <0x59810000 0x400>;
- sd_clk: clock { + sd_clk: clock-controller { compatible = "socionext,uniphier-ld20-sd-clock"; #clock-cells = <1>; };
- sd_rst: reset { + sd_rst: reset-controller { compatible = "socionext,uniphier-ld20-sd-reset"; #reset-cells = <1>; }; };
- perictrl@59820000 { + syscon@59820000 { compatible = "socionext,uniphier-ld20-perictrl", "simple-mfd", "syscon"; reg = <0x59820000 0x200>;
- peri_clk: clock { + peri_clk: clock-controller { compatible = "socionext,uniphier-ld20-peri-clock"; #clock-cells = <1>; };
- peri_rst: reset { + peri_rst: reset-controller { compatible = "socionext,uniphier-ld20-peri-reset"; #reset-cells = <1>; }; @@ -570,7 +583,7 @@ emmc: mmc@5a000000 { compatible = "socionext,uniphier-sd4hc", "cdns,sd4hc"; reg = <0x5a000000 0x400>; - interrupts = <0 78 4>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_emmc>; clocks = <&sys_clk 4>; @@ -590,7 +603,7 @@ compatible = "socionext,uniphier-sd-v3.1.1"; status = "disabled"; reg = <0x5a400000 0x800>; - interrupts = <0 76 4>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_sd>; clocks = <&sd_clk 0>; @@ -598,9 +611,10 @@ resets = <&sd_rst 0>; bus-width = <4>; cap-sd-highspeed; + socionext,syscon-uhs-mode = <&sdctrl 0>; };
- soc_glue: soc-glue@5f800000 { + soc_glue: syscon@5f800000 { compatible = "socionext,uniphier-ld20-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -610,9 +624,10 @@ }; };
- soc-glue@5f900000 { + syscon@5f900000 { compatible = "socionext,uniphier-ld20-soc-glue-debug", - "simple-mfd"; + "simple-mfd", "syscon"; + reg = <0x5f900000 0x2000>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x5f900000 0x2000>; @@ -675,7 +690,7 @@ xdmac: dma-controller@5fc10000 { compatible = "socionext,uniphier-xdmac"; reg = <0x5fc10000 0x5300>; - interrupts = <0 188 4>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; dma-channels = <16>; #dma-cells = <2>; }; @@ -693,20 +708,20 @@ <0x5fe80000 0x80000>; /* GICR */ interrupt-controller; #interrupt-cells = <3>; - interrupts = <1 9 4>; + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; };
- sysctrl@61840000 { + syscon@61840000 { compatible = "socionext,uniphier-ld20-sysctrl", "simple-mfd", "syscon"; reg = <0x61840000 0x10000>;
- sys_clk: clock { + sys_clk: clock-controller { compatible = "socionext,uniphier-ld20-clock"; #clock-cells = <1>; };
- sys_rst: reset { + sys_rst: reset-controller { compatible = "socionext,uniphier-ld20-reset"; #reset-cells = <1>; }; @@ -715,9 +730,9 @@ compatible = "socionext,uniphier-wdt"; };
- pvtctl: pvtctl { + pvtctl: thermal-sensor { compatible = "socionext,uniphier-ld20-thermal"; - interrupts = <0 3 4>; + interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; #thermal-sensor-cells = <0>; socionext,tmod-calibration = <0x0f22 0x68ee>; }; @@ -727,7 +742,7 @@ compatible = "socionext,uniphier-ld20-ave4"; status = "disabled"; reg = <0x65000000 0x8500>; - interrupts = <0 66 4>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ether_rgmii>; clock-names = "ether"; @@ -749,7 +764,7 @@ status = "disabled"; reg = <0x65a00000 0xcd00>; interrupt-names = "host"; - interrupts = <0 134 4>; + interrupts = <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>, <&pinctrl_usb1>, <&pinctrl_usb2>, <&pinctrl_usb3>; @@ -762,14 +777,15 @@ dr_mode = "host"; };
- usb-glue@65b00000 { + usb-controller@65b00000 { compatible = "socionext,uniphier-ld20-dwc3-glue", "simple-mfd"; + reg = <0x65b00000 0x400>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x65b00000 0x400>;
- usb_rst: reset@0 { + usb_rst: reset-controller@0 { compatible = "socionext,uniphier-ld20-usb3-reset"; reg = <0x0 0x4>; #reset-cells = <1>; @@ -815,7 +831,7 @@ resets = <&sys_rst 14>; };
- usb_hsphy0: hs-phy@200 { + usb_hsphy0: phy@200 { compatible = "socionext,uniphier-ld20-usb3-hsphy"; reg = <0x200 0x10>; #phy-cells = <0>; @@ -829,7 +845,7 @@ <&usb_hs_i0>; };
- usb_hsphy1: hs-phy@210 { + usb_hsphy1: phy@210 { compatible = "socionext,uniphier-ld20-usb3-hsphy"; reg = <0x210 0x10>; #phy-cells = <0>; @@ -843,7 +859,7 @@ <&usb_hs_i0>; };
- usb_hsphy2: hs-phy@220 { + usb_hsphy2: phy@220 { compatible = "socionext,uniphier-ld20-usb3-hsphy"; reg = <0x220 0x10>; #phy-cells = <0>; @@ -857,7 +873,7 @@ <&usb_hs_i2>; };
- usb_hsphy3: hs-phy@230 { + usb_hsphy3: phy@230 { compatible = "socionext,uniphier-ld20-usb3-hsphy"; reg = <0x230 0x10>; #phy-cells = <0>; @@ -871,7 +887,7 @@ <&usb_hs_i2>; };
- usb_ssphy0: ss-phy@300 { + usb_ssphy0: phy@300 { compatible = "socionext,uniphier-ld20-usb3-ssphy"; reg = <0x300 0x10>; #phy-cells = <0>; @@ -882,7 +898,7 @@ vbus-supply = <&usb_vbus0>; };
- usb_ssphy1: ss-phy@310 { + usb_ssphy1: phy@310 { compatible = "socionext,uniphier-ld20-usb3-ssphy"; reg = <0x310 0x10>; #phy-cells = <0>; @@ -895,7 +911,7 @@ };
pcie: pcie@66000000 { - compatible = "socionext,uniphier-pcie", "snps,dw-pcie"; + compatible = "socionext,uniphier-pcie"; status = "disabled"; reg-names = "dbi", "link", "config"; reg = <0x66000000 0x1000>, <0x66010000 0x10000>, @@ -915,7 +931,8 @@ <0x82000000 0 0x20000000 0x20000000 0 0x0ffe0000>; #interrupt-cells = <1>; interrupt-names = "dma", "msi"; - interrupts = <0 224 4>, <0 225 4>; + interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; interrupt-map-mask = <0 0 0 7>; interrupt-map = <0 0 0 1 &pcie_intc 0>, /* INTA */ <0 0 0 2 &pcie_intc 1>, /* INTB */ @@ -928,7 +945,7 @@ interrupt-controller; #interrupt-cells = <1>; interrupt-parent = <&gic>; - interrupts = <0 226 4>; + interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; }; };
@@ -948,7 +965,9 @@ status = "disabled"; reg-names = "nand_data", "denali_reg"; reg = <0x68000000 0x20>, <0x68100000 0x1000>; - interrupts = <0 65 4>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_nand>; clock-names = "nand", "nand_x", "ecc"; diff --git a/arch/arm/dts/uniphier-ld4-ref.dts b/arch/arm/dts/uniphier-ld4-ref.dts index 03fe696668..e007db0847 100644 --- a/arch/arm/dts/uniphier-ld4-ref.dts +++ b/arch/arm/dts/uniphier-ld4-ref.dts @@ -36,11 +36,11 @@ };
ðsc { - interrupts = <1 8>; + interrupts = <1 IRQ_TYPE_LEVEL_LOW>; };
&serialsc { - interrupts = <1 8>; + interrupts = <1 IRQ_TYPE_LEVEL_LOW>; };
&serial0 { @@ -56,7 +56,7 @@ };
&gpio { - xirq1 { + xirq1-hog { gpio-hog; gpios = <UNIPHIER_GPIO_IRQ(1) 0>; input; @@ -81,4 +81,8 @@
&nand { status = "okay"; + + nand@0 { + reg = <0>; + }; }; diff --git a/arch/arm/dts/uniphier-ld4.dtsi b/arch/arm/dts/uniphier-ld4.dtsi index 897162d5f5..1baf590a71 100644 --- a/arch/arm/dts/uniphier-ld4.dtsi +++ b/arch/arm/dts/uniphier-ld4.dtsi @@ -6,6 +6,7 @@ // Author: Masahiro Yamada yamada.masahiro@socionext.com
/ { compatible = "socionext,uniphier-ld4"; @@ -55,7 +56,8 @@ compatible = "socionext,uniphier-system-cache"; reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, <0x506c0000 0x400>; - interrupts = <0 174 4>, <0 175 4>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; cache-unified; cache-size = <(512 * 1024)>; cache-sets = <256>; @@ -69,7 +71,7 @@ reg = <0x54006000 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 39 4>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi0>; clocks = <&peri_clk 11>; @@ -80,7 +82,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006800 0x40>; - interrupts = <0 33 4>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; clocks = <&peri_clk 0>; @@ -91,7 +93,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006900 0x40>; - interrupts = <0 35 4>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; clocks = <&peri_clk 1>; @@ -102,7 +104,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006a00 0x40>; - interrupts = <0 37 4>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; clocks = <&peri_clk 2>; @@ -113,7 +115,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006b00 0x40>; - interrupts = <0 29 4>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart3>; clocks = <&peri_clk 3>; @@ -140,7 +142,7 @@ reg = <0x58400000 0x40>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 41 1>; + interrupts = <GIC_SPI 41 IRQ_TYPE_EDGE_RISING>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c0>; clocks = <&peri_clk 4>; @@ -154,7 +156,7 @@ reg = <0x58480000 0x40>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 42 1>; + interrupts = <GIC_SPI 42 IRQ_TYPE_EDGE_RISING>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c1>; clocks = <&peri_clk 5>; @@ -168,7 +170,7 @@ reg = <0x58500000 0x40>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 43 1>; + interrupts = <GIC_SPI 43 IRQ_TYPE_EDGE_RISING>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c2>; clocks = <&peri_clk 6>; @@ -182,7 +184,7 @@ reg = <0x58580000 0x40>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 44 1>; + interrupts = <GIC_SPI 44 IRQ_TYPE_EDGE_RISING>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c3>; clocks = <&peri_clk 7>; @@ -205,33 +207,33 @@ reg = <0x59801000 0x400>; };
- mioctrl@59810000 { + syscon@59810000 { compatible = "socionext,uniphier-ld4-mioctrl", "simple-mfd", "syscon"; reg = <0x59810000 0x800>;
- mio_clk: clock { + mio_clk: clock-controller { compatible = "socionext,uniphier-ld4-mio-clock"; #clock-cells = <1>; };
- mio_rst: reset { + mio_rst: reset-controller { compatible = "socionext,uniphier-ld4-mio-reset"; #reset-cells = <1>; }; };
- perictrl@59820000 { + syscon@59820000 { compatible = "socionext,uniphier-ld4-perictrl", "simple-mfd", "syscon"; reg = <0x59820000 0x200>;
- peri_clk: clock { + peri_clk: clock-controller { compatible = "socionext,uniphier-ld4-peri-clock"; #clock-cells = <1>; };
- peri_rst: reset { + peri_rst: reset-controller { compatible = "socionext,uniphier-ld4-peri-reset"; #reset-cells = <1>; }; @@ -240,8 +242,13 @@ dmac: dma-controller@5a000000 { compatible = "socionext,uniphier-mio-dmac"; reg = <0x5a000000 0x1000>; - interrupts = <0 68 4>, <0 68 4>, <0 69 4>, <0 70 4>, - <0 71 4>, <0 72 4>, <0 73 4>; + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; clocks = <&mio_clk 7>; resets = <&mio_rst 7>; #dma-cells = <1>; @@ -251,7 +258,7 @@ compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a400000 0x200>; - interrupts = <0 76 4>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default", "uhs"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_uhs>; @@ -271,7 +278,7 @@ compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a500000 0x200>; - interrupts = <0 78 4>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_emmc>; clocks = <&mio_clk 1>; @@ -289,7 +296,7 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a800100 0x100>; - interrupts = <0 80 4>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>; clocks = <&sys_clk 8>, <&mio_clk 7>, <&mio_clk 8>, @@ -303,7 +310,7 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; - interrupts = <0 81 4>; + interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb1>; clocks = <&sys_clk 8>, <&mio_clk 7>, <&mio_clk 9>, @@ -317,7 +324,7 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a820100 0x100>; - interrupts = <0 82 4>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb2>; clocks = <&sys_clk 8>, <&mio_clk 7>, <&mio_clk 10>, @@ -327,7 +334,7 @@ has-transaction-translator; };
- soc-glue@5f800000 { + syscon@5f800000 { compatible = "socionext,uniphier-ld4-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -337,9 +344,10 @@ }; };
- soc-glue@5f900000 { + syscon@5f900000 { compatible = "socionext,uniphier-ld4-soc-glue-debug", - "simple-mfd"; + "simple-mfd", "syscon"; + reg = <0x5f900000 0x2000>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x5f900000 0x2000>; @@ -358,14 +366,16 @@ timer@60000200 { compatible = "arm,cortex-a9-global-timer"; reg = <0x60000200 0x20>; - interrupts = <1 11 0x104>; + interrupts = <GIC_PPI 11 + (GIC_CPU_MASK_RAW(1) | IRQ_TYPE_LEVEL_HIGH)>; clocks = <&arm_timer_clk>; };
timer@60000600 { compatible = "arm,cortex-a9-twd-timer"; reg = <0x60000600 0x20>; - interrupts = <1 13 0x104>; + interrupts = <GIC_PPI 13 + (GIC_CPU_MASK_RAW(1) | IRQ_TYPE_LEVEL_HIGH)>; clocks = <&arm_timer_clk>; };
@@ -384,17 +394,17 @@ #interrupt-cells = <2>; };
- sysctrl@61840000 { + syscon@61840000 { compatible = "socionext,uniphier-ld4-sysctrl", "simple-mfd", "syscon"; reg = <0x61840000 0x10000>;
- sys_clk: clock { + sys_clk: clock-controller { compatible = "socionext,uniphier-ld4-clock"; #clock-cells = <1>; };
- sys_rst: reset { + sys_rst: reset-controller { compatible = "socionext,uniphier-ld4-reset"; #reset-cells = <1>; }; @@ -405,7 +415,9 @@ status = "disabled"; reg-names = "nand_data", "denali_reg"; reg = <0x68000000 0x20>, <0x68100000 0x1000>; - interrupts = <0 65 4>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_nand2cs>; clock-names = "nand", "nand_x", "ecc"; diff --git a/arch/arm/dts/uniphier-pro4-ace.dts b/arch/arm/dts/uniphier-pro4-ace.dts index 27ff2b7b9d..6baee4410d 100644 --- a/arch/arm/dts/uniphier-pro4-ace.dts +++ b/arch/arm/dts/uniphier-pro4-ace.dts @@ -99,3 +99,11 @@ &usb1 { status = "okay"; }; + +&ahci0 { + status = "okay"; +}; + +&ahci1 { + status = "okay"; +}; diff --git a/arch/arm/dts/uniphier-pro4-ref.dts b/arch/arm/dts/uniphier-pro4-ref.dts index 3e1bc1275a..202ca84faa 100644 --- a/arch/arm/dts/uniphier-pro4-ref.dts +++ b/arch/arm/dts/uniphier-pro4-ref.dts @@ -40,11 +40,11 @@ };
ðsc { - interrupts = <2 8>; + interrupts = <2 IRQ_TYPE_LEVEL_LOW>; };
&serialsc { - interrupts = <2 8>; + interrupts = <2 IRQ_TYPE_LEVEL_LOW>; };
&serial0 { @@ -60,7 +60,7 @@ };
&gpio { - xirq2 { + xirq2-hog { gpio-hog; gpios = <UNIPHIER_GPIO_IRQ(2) 0>; input; @@ -104,4 +104,16 @@
&nand { status = "okay"; + + nand@0 { + reg = <0>; + }; +}; + +&ahci0 { + status = "okay"; +}; + +&ahci1 { + status = "okay"; }; diff --git a/arch/arm/dts/uniphier-pro4-sanji.dts b/arch/arm/dts/uniphier-pro4-sanji.dts index e7c122de29..7b6faf2e79 100644 --- a/arch/arm/dts/uniphier-pro4-sanji.dts +++ b/arch/arm/dts/uniphier-pro4-sanji.dts @@ -64,15 +64,15 @@ status = "okay"; };
-&emmc { +&usb2 { status = "okay"; };
-&usb2 { +&usb3 { status = "okay"; };
-&usb3 { +&emmc { status = "okay"; };
diff --git a/arch/arm/dts/uniphier-pro4.dtsi b/arch/arm/dts/uniphier-pro4.dtsi index cd706f485e..ba55af30e9 100644 --- a/arch/arm/dts/uniphier-pro4.dtsi +++ b/arch/arm/dts/uniphier-pro4.dtsi @@ -6,6 +6,7 @@ // Author: Masahiro Yamada yamada.masahiro@socionext.com
/ { compatible = "socionext,uniphier-pro4"; @@ -63,7 +64,8 @@ compatible = "socionext,uniphier-system-cache"; reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, <0x506c0000 0x400>; - interrupts = <0 174 4>, <0 175 4>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; cache-unified; cache-size = <(768 * 1024)>; cache-sets = <256>; @@ -77,7 +79,7 @@ reg = <0x54006000 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 39 4>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi0>; clocks = <&peri_clk 11>; @@ -88,7 +90,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006800 0x40>; - interrupts = <0 33 4>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; clocks = <&peri_clk 0>; @@ -99,7 +101,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006900 0x40>; - interrupts = <0 35 4>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; clocks = <&peri_clk 1>; @@ -110,7 +112,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006a00 0x40>; - interrupts = <0 37 4>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; clocks = <&peri_clk 2>; @@ -121,7 +123,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006b00 0x40>; - interrupts = <0 177 4>; + interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart3>; clocks = <&peri_clk 3>; @@ -148,7 +150,7 @@ reg = <0x58780000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 41 4>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c0>; clocks = <&peri_clk 4>; @@ -162,7 +164,7 @@ reg = <0x58781000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 42 4>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c1>; clocks = <&peri_clk 5>; @@ -176,7 +178,7 @@ reg = <0x58782000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 43 4>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c2>; clocks = <&peri_clk 6>; @@ -190,7 +192,7 @@ reg = <0x58783000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 44 4>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c3>; clocks = <&peri_clk 7>; @@ -206,7 +208,7 @@ reg = <0x58785000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 25 4>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 9>; resets = <&peri_rst 9>; clock-frequency = <400000>; @@ -218,7 +220,7 @@ reg = <0x58786000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 26 4>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 10>; resets = <&peri_rst 10>; clock-frequency = <400000>; @@ -239,33 +241,33 @@ reg = <0x59801000 0x400>; };
- mioctrl@59810000 { + mioctrl: syscon@59810000 { compatible = "socionext,uniphier-pro4-mioctrl", "simple-mfd", "syscon"; reg = <0x59810000 0x800>;
- mio_clk: clock { + mio_clk: clock-controller { compatible = "socionext,uniphier-pro4-mio-clock"; #clock-cells = <1>; };
- mio_rst: reset { + mio_rst: reset-controller { compatible = "socionext,uniphier-pro4-mio-reset"; #reset-cells = <1>; }; };
- perictrl@59820000 { + syscon@59820000 { compatible = "socionext,uniphier-pro4-perictrl", "simple-mfd", "syscon"; reg = <0x59820000 0x200>;
- peri_clk: clock { + peri_clk: clock-controller { compatible = "socionext,uniphier-pro4-peri-clock"; #clock-cells = <1>; };
- peri_rst: reset { + peri_rst: reset-controller { compatible = "socionext,uniphier-pro4-peri-reset"; #reset-cells = <1>; }; @@ -274,8 +276,14 @@ dmac: dma-controller@5a000000 { compatible = "socionext,uniphier-mio-dmac"; reg = <0x5a000000 0x1000>; - interrupts = <0 68 4>, <0 68 4>, <0 69 4>, <0 70 4>, - <0 71 4>, <0 72 4>, <0 73 4>, <0 74 4>; + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; clocks = <&mio_clk 7>; resets = <&mio_rst 7>; #dma-cells = <1>; @@ -285,7 +293,7 @@ compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a400000 0x200>; - interrupts = <0 76 4>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default", "uhs"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_uhs>; @@ -299,13 +307,14 @@ sd-uhs-sdr12; sd-uhs-sdr25; sd-uhs-sdr50; + socionext,syscon-uhs-mode = <&mioctrl 0>; };
emmc: mmc@5a500000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a500000 0x200>; - interrupts = <0 78 4>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_emmc>; clocks = <&mio_clk 1>; @@ -323,7 +332,7 @@ compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a600000 0x200>; - interrupts = <0 85 4>; + interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_sd1>; clocks = <&mio_clk 2>; @@ -339,7 +348,7 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a800100 0x100>; - interrupts = <0 80 4>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb2>; clocks = <&sys_clk 8>, <&mio_clk 7>, <&mio_clk 8>, @@ -355,7 +364,7 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; - interrupts = <0 81 4>; + interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb3>; clocks = <&sys_clk 8>, <&mio_clk 7>, <&mio_clk 9>, @@ -367,7 +376,7 @@ has-transaction-translator; };
- soc_glue: soc-glue@5f800000 { + soc_glue: syscon@5f800000 { compatible = "socionext,uniphier-pro4-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -376,7 +385,7 @@ compatible = "socionext,uniphier-pro4-pinctrl"; };
- usb-phy { + usb-hub { compatible = "socionext,uniphier-pro4-usb2-phy"; #address-cells = <1>; #size-cells = <0>; @@ -403,11 +412,17 @@ vbus-supply = <&usb1_vbus>; }; }; + + sg_clk: clock-controller { + compatible = "socionext,uniphier-pro4-sg-clock"; + #clock-cells = <1>; + }; };
- soc-glue@5f900000 { + syscon@5f900000 { compatible = "socionext,uniphier-pro4-soc-glue-debug", - "simple-mfd"; + "simple-mfd", "syscon"; + reg = <0x5f900000 0x2000>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x5f900000 0x2000>; @@ -431,7 +446,7 @@ xdmac: dma-controller@5fc10000 { compatible = "socionext,uniphier-xdmac"; reg = <0x5fc10000 0x5300>; - interrupts = <0 188 4>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; dma-channels = <16>; #dma-cells = <2>; }; @@ -446,14 +461,16 @@ timer@60000200 { compatible = "arm,cortex-a9-global-timer"; reg = <0x60000200 0x20>; - interrupts = <1 11 0x304>; + interrupts = <GIC_PPI 11 + (GIC_CPU_MASK_RAW(3) | IRQ_TYPE_LEVEL_HIGH)>; clocks = <&arm_timer_clk>; };
timer@60000600 { compatible = "arm,cortex-a9-twd-timer"; reg = <0x60000600 0x20>; - interrupts = <1 13 0x304>; + interrupts = <GIC_PPI 13 + (GIC_CPU_MASK_RAW(3) | IRQ_TYPE_LEVEL_HIGH)>; clocks = <&arm_timer_clk>; };
@@ -465,17 +482,17 @@ interrupt-controller; };
- sysctrl@61840000 { + syscon@61840000 { compatible = "socionext,uniphier-pro4-sysctrl", "simple-mfd", "syscon"; reg = <0x61840000 0x10000>;
- sys_clk: clock { + sys_clk: clock-controller { compatible = "socionext,uniphier-pro4-clock"; #clock-cells = <1>; };
- sys_rst: reset { + sys_rst: reset-controller { compatible = "socionext,uniphier-pro4-reset"; #reset-cells = <1>; }; @@ -485,7 +502,7 @@ compatible = "socionext,uniphier-pro4-ave4"; status = "disabled"; reg = <0x65000000 0x8500>; - interrupts = <0 66 4>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ether_rgmii>; clock-names = "gio", "ether", "ether-gb", "ether-phy"; @@ -503,12 +520,107 @@ }; };
+ ahci0: sata@65600000 { + compatible = "socionext,uniphier-pro4-ahci", + "generic-ahci"; + status = "disabled"; + reg = <0x65600000 0x10000>; + interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&sys_clk 12>, <&sys_clk 28>; + resets = <&sys_rst 12>, <&sys_rst 28>, <&ahci0_rst 3>; + ports-implemented = <1>; + phys = <&ahci0_phy>; + assigned-clocks = <&sg_clk 0>; + assigned-clock-rates = <25000000>; + }; + + sata-controller@65700000 { + compatible = "socionext,uniphier-pxs2-ahci-glue", + "simple-mfd"; + reg = <0x65700000 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x65700000 0x100>; + + ahci0_rst: reset-controller@0 { + compatible = "socionext,uniphier-pro4-ahci-reset"; + reg = <0x0 0x4>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 28>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 28>; + #reset-cells = <1>; + }; + + ahci0_phy: phy@10 { + compatible = "socionext,uniphier-pro4-ahci-phy"; + reg = <0x10 0x40>; + clock-names = "link", "gio"; + clocks = <&sys_clk 28>, <&sys_clk 12>; + reset-names = "link", "gio", "phy", + "pm", "tx", "rx"; + resets = <&sys_rst 28>, <&sys_rst 12>, + <&sys_rst 30>, + <&ahci0_rst 0>, <&ahci0_rst 1>, + <&ahci0_rst 2>; + #phy-cells = <0>; + }; + }; + + ahci1: sata@65800000 { + compatible = "socionext,uniphier-pro4-ahci", + "generic-ahci"; + status = "disabled"; + reg = <0x65800000 0x10000>; + interrupts = <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&sys_clk 12>, <&sys_clk 29>; + resets = <&sys_rst 12>, <&sys_rst 29>, <&ahci1_rst 3>; + ports-implemented = <1>; + phys = <&ahci1_phy>; + assigned-clocks = <&sg_clk 0>; + assigned-clock-rates = <25000000>; + }; + + sata-controller@65900000 { + compatible = "socionext,uniphier-pro4-ahci-glue", + "simple-mfd"; + reg = <0x65900000 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x65900000 0x100>; + + ahci1_rst: reset-controller@0 { + compatible = "socionext,uniphier-pro4-ahci-reset"; + reg = <0x0 0x4>; + clock-names = "gio", "link"; + clocks = <&sys_clk 12>, <&sys_clk 29>; + reset-names = "gio", "link"; + resets = <&sys_rst 12>, <&sys_rst 29>; + #reset-cells = <1>; + }; + + ahci1_phy: phy@10 { + compatible = "socionext,uniphier-pro4-ahci-phy"; + reg = <0x10 0x40>; + clock-names = "link", "gio"; + clocks = <&sys_clk 29>, <&sys_clk 12>; + reset-names = "link", "gio", "phy", + "pm", "tx", "rx"; + resets = <&sys_rst 29>, <&sys_rst 12>, + <&sys_rst 30>, + <&ahci1_rst 0>, <&ahci1_rst 1>, + <&ahci1_rst 2>; + #phy-cells = <0>; + }; + }; + usb0: usb@65a00000 { compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65a00000 0xcd00>; interrupt-names = "host", "peripheral"; - interrupts = <0 134 4>, <0 135 4>; + interrupts = <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>; clock-names = "ref", "bus_early", "suspend"; @@ -518,9 +630,10 @@ dr_mode = "host"; };
- usb-glue@65b00000 { + usb-controller@65b00000 { compatible = "socionext,uniphier-pro4-dwc3-glue", "simple-mfd"; + reg = <0x65b00000 0x100>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x65b00000 0x100>; @@ -534,7 +647,7 @@ resets = <&sys_rst 12>, <&sys_rst 14>; };
- usb0_ssphy: ss-phy@10 { + usb0_ssphy: phy@10 { compatible = "socionext,uniphier-pro4-usb3-ssphy"; reg = <0x10 0x10>; #phy-cells = <0>; @@ -545,7 +658,7 @@ vbus-supply = <&usb0_vbus>; };
- usb0_rst: reset@40 { + usb0_rst: reset-controller@40 { compatible = "socionext,uniphier-pro4-usb3-reset"; reg = <0x40 0x4>; #reset-cells = <1>; @@ -561,7 +674,8 @@ status = "disabled"; reg = <0x65c00000 0xcd00>; interrupt-names = "host", "peripheral"; - interrupts = <0 137 4>, <0 138 4>; + interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb1>; clock-names = "ref", "bus_early", "suspend"; @@ -571,9 +685,10 @@ dr_mode = "host"; };
- usb-glue@65d00000 { + usb-controller@65d00000 { compatible = "socionext,uniphier-pro4-dwc3-glue", "simple-mfd"; + reg = <0x65d00000 0x100>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x65d00000 0x100>; @@ -587,7 +702,7 @@ resets = <&sys_rst 12>, <&sys_rst 15>; };
- usb1_rst: reset@40 { + usb1_rst: reset-controller@40 { compatible = "socionext,uniphier-pro4-usb3-reset"; reg = <0x40 0x4>; #reset-cells = <1>; @@ -603,7 +718,9 @@ status = "disabled"; reg-names = "nand_data", "denali_reg"; reg = <0x68000000 0x20>, <0x68100000 0x1000>; - interrupts = <0 65 4>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_nand>; clock-names = "nand", "nand_x", "ecc"; diff --git a/arch/arm/dts/uniphier-pro5.dtsi b/arch/arm/dts/uniphier-pro5.dtsi index 19848e36fa..c039378942 100644 --- a/arch/arm/dts/uniphier-pro5.dtsi +++ b/arch/arm/dts/uniphier-pro5.dtsi @@ -5,6 +5,8 @@ // Copyright (C) 2015-2016 Socionext Inc. // Author: Masahiro Yamada yamada.masahiro@socionext.com
+#include <dt-bindings/interrupt-controller/arm-gic.h> + / { compatible = "socionext,uniphier-pro5"; #address-cells = <1>; @@ -135,7 +137,8 @@ compatible = "socionext,uniphier-system-cache"; reg = <0x500c0000 0x2000>, <0x503c0100 0x8>, <0x506c0000 0x400>; - interrupts = <0 190 4>, <0 191 4>; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; cache-unified; cache-size = <(2 * 1024 * 1024)>; cache-sets = <512>; @@ -148,7 +151,8 @@ compatible = "socionext,uniphier-system-cache"; reg = <0x500c8000 0x2000>, <0x503c8100 0x8>, <0x506c8000 0x400>; - interrupts = <0 174 4>, <0 175 4>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; cache-unified; cache-size = <(2 * 1024 * 1024)>; cache-sets = <512>; @@ -162,7 +166,7 @@ reg = <0x54006000 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 39 4>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi0>; clocks = <&peri_clk 11>; @@ -175,7 +179,7 @@ reg = <0x54006100 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 216 4>; + interrupts = <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi1>; clocks = <&peri_clk 11>; /* common with spi0 */ @@ -186,7 +190,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006800 0x40>; - interrupts = <0 33 4>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; clocks = <&peri_clk 0>; @@ -197,7 +201,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006900 0x40>; - interrupts = <0 35 4>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; clocks = <&peri_clk 1>; @@ -208,7 +212,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006a00 0x40>; - interrupts = <0 37 4>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; clocks = <&peri_clk 2>; @@ -219,7 +223,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006b00 0x40>; - interrupts = <0 177 4>; + interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart3>; clocks = <&peri_clk 3>; @@ -246,7 +250,7 @@ reg = <0x58780000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 41 4>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c0>; clocks = <&peri_clk 4>; @@ -260,7 +264,7 @@ reg = <0x58781000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 42 4>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c1>; clocks = <&peri_clk 5>; @@ -274,7 +278,7 @@ reg = <0x58782000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 43 4>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c2>; clocks = <&peri_clk 6>; @@ -288,7 +292,7 @@ reg = <0x58783000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 44 4>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c3>; clocks = <&peri_clk 7>; @@ -304,7 +308,7 @@ reg = <0x58785000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 25 4>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 9>; resets = <&peri_rst 9>; clock-frequency = <400000>; @@ -316,7 +320,7 @@ reg = <0x58786000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 26 4>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 10>; resets = <&peri_rst 10>; clock-frequency = <400000>; @@ -337,39 +341,39 @@ reg = <0x59801000 0x400>; };
- sdctrl@59810000 { + sdctrl: syscon@59810000 { compatible = "socionext,uniphier-pro5-sdctrl", "simple-mfd", "syscon"; reg = <0x59810000 0x400>;
- sd_clk: clock { + sd_clk: clock-controller { compatible = "socionext,uniphier-pro5-sd-clock"; #clock-cells = <1>; };
- sd_rst: reset { + sd_rst: reset-controller { compatible = "socionext,uniphier-pro5-sd-reset"; #reset-cells = <1>; }; };
- perictrl@59820000 { + syscon@59820000 { compatible = "socionext,uniphier-pro5-perictrl", "simple-mfd", "syscon"; reg = <0x59820000 0x200>;
- peri_clk: clock { + peri_clk: clock-controller { compatible = "socionext,uniphier-pro5-peri-clock"; #clock-cells = <1>; };
- peri_rst: reset { + peri_rst: reset-controller { compatible = "socionext,uniphier-pro5-peri-reset"; #reset-cells = <1>; }; };
- soc-glue@5f800000 { + syscon@5f800000 { compatible = "socionext,uniphier-pro5-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -379,9 +383,10 @@ }; };
- soc-glue@5f900000 { + syscon@5f900000 { compatible = "socionext,uniphier-pro5-soc-glue-debug", - "simple-mfd"; + "simple-mfd", "syscon"; + reg = <0x5f900000 0x2000>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x5f900000 0x2000>; @@ -415,7 +420,7 @@ xdmac: dma-controller@5fc10000 { compatible = "socionext,uniphier-xdmac"; reg = <0x5fc10000 0x5300>; - interrupts = <0 188 4>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; dma-channels = <16>; #dma-cells = <2>; }; @@ -430,14 +435,16 @@ timer@60000200 { compatible = "arm,cortex-a9-global-timer"; reg = <0x60000200 0x20>; - interrupts = <1 11 0x304>; + interrupts = <GIC_PPI 11 + (GIC_CPU_MASK_RAW(3) | IRQ_TYPE_LEVEL_HIGH)>; clocks = <&arm_timer_clk>; };
@@ -449,17 +456,17 @@ interrupt-controller; };
- sysctrl@61840000 { + syscon@61840000 { compatible = "socionext,uniphier-pro5-sysctrl", "simple-mfd", "syscon"; reg = <0x61840000 0x10000>;
- sys_clk: clock { + sys_clk: clock-controller { compatible = "socionext,uniphier-pro5-clock"; #clock-cells = <1>; };
- sys_rst: reset { + sys_rst: reset-controller { compatible = "socionext,uniphier-pro5-reset"; #reset-cells = <1>; }; @@ -470,7 +477,7 @@ status = "disabled"; reg = <0x65a00000 0xcd00>; interrupt-names = "host"; - interrupts = <0 134 4>; + interrupts = <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>; clock-names = "ref", "bus_early", "suspend"; @@ -480,14 +487,15 @@ dr_mode = "host"; };
- usb-glue@65b00000 { + usb-controller@65b00000 { compatible = "socionext,uniphier-pro5-dwc3-glue", "simple-mfd"; + reg = <0x65b00000 0x400>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x65b00000 0x400>;
- usb0_rst: reset@0 { + usb0_rst: reset-controller@0 { compatible = "socionext,uniphier-pro5-usb3-reset"; reg = <0x0 0x4>; #reset-cells = <1>; @@ -506,7 +514,7 @@ resets = <&sys_rst 12>, <&sys_rst 14>; };
- usb0_hsphy0: hs-phy@280 { + usb0_hsphy0: phy@280 { compatible = "socionext,uniphier-pro5-usb3-hsphy"; reg = <0x280 0x10>; #phy-cells = <0>; @@ -517,7 +525,7 @@ vbus-supply = <&usb0_vbus0>; };
- usb0_ssphy0: ss-phy@380 { + usb0_ssphy0: phy@380 { compatible = "socionext,uniphier-pro5-usb3-ssphy"; reg = <0x380 0x10>; #phy-cells = <0>; @@ -534,7 +542,7 @@ status = "disabled"; reg = <0x65c00000 0xcd00>; interrupt-names = "host"; - interrupts = <0 137 4>; + interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb1>, <&pinctrl_usb2>; clock-names = "ref", "bus_early", "suspend"; @@ -544,14 +552,15 @@ dr_mode = "host"; };
- usb-glue@65d00000 { + usb-controller@65d00000 { compatible = "socionext,uniphier-pro5-dwc3-glue", "simple-mfd"; + reg = <0x65d00000 0x400>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x65d00000 0x400>;
- usb1_rst: reset@0 { + usb1_rst: reset-controller@0 { compatible = "socionext,uniphier-pro5-usb3-reset"; reg = <0x0 0x4>; #reset-cells = <1>; @@ -579,7 +588,7 @@ resets = <&sys_rst 12>, <&sys_rst 15>; };
- usb1_hsphy0: hs-phy@280 { + usb1_hsphy0: phy@280 { compatible = "socionext,uniphier-pro5-usb3-hsphy"; reg = <0x280 0x10>; #phy-cells = <0>; @@ -590,7 +599,7 @@ vbus-supply = <&usb1_vbus0>; };
- usb1_hsphy1: hs-phy@290 { + usb1_hsphy1: phy@290 { compatible = "socionext,uniphier-pro5-usb3-hsphy"; reg = <0x290 0x10>; #phy-cells = <0>; @@ -601,7 +610,7 @@ vbus-supply = <&usb1_vbus1>; };
- usb1_ssphy0: ss-phy@380 { + usb1_ssphy0: phy@380 { compatible = "socionext,uniphier-pro5-usb3-ssphy"; reg = <0x380 0x10>; #phy-cells = <0>; @@ -614,8 +623,7 @@ };
pcie_ep: pcie-ep@66000000 { - compatible = "socionext,uniphier-pro5-pcie-ep", - "snps,dw-pcie-ep"; + compatible = "socionext,uniphier-pro5-pcie-ep"; status = "disabled"; reg-names = "dbi", "dbi2", "link", "addr_space"; reg = <0x66000000 0x1000>, <0x66001000 0x1000>, @@ -648,7 +656,9 @@ status = "disabled"; reg-names = "nand_data", "denali_reg"; reg = <0x68000000 0x20>, <0x68100000 0x1000>; - interrupts = <0 65 4>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_nand2cs>; clock-names = "nand", "nand_x", "ecc"; @@ -661,7 +671,7 @@ compatible = "socionext,uniphier-sd-v3.1"; status = "disabled"; reg = <0x68400000 0x800>; - interrupts = <0 78 4>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_emmc>; clocks = <&sd_clk 1>; @@ -677,7 +687,7 @@ compatible = "socionext,uniphier-sd-v3.1"; status = "disabled"; reg = <0x68800000 0x800>; - interrupts = <0 76 4>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default", "uhs"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_uhs>; @@ -689,6 +699,7 @@ sd-uhs-sdr12; sd-uhs-sdr25; sd-uhs-sdr50; + socionext,syscon-uhs-mode = <&sdctrl 0>; }; }; }; diff --git a/arch/arm/dts/uniphier-pxs2-gentil.dts b/arch/arm/dts/uniphier-pxs2-gentil.dts index 759384b606..5f18b926c5 100644 --- a/arch/arm/dts/uniphier-pxs2-gentil.dts +++ b/arch/arm/dts/uniphier-pxs2-gentil.dts @@ -99,3 +99,7 @@ &usb1 { status = "okay"; }; + +&ahci { + status = "okay"; +}; diff --git a/arch/arm/dts/uniphier-pxs2.dtsi b/arch/arm/dts/uniphier-pxs2.dtsi index 0364bdce7e..e3a4b6ad1f 100644 --- a/arch/arm/dts/uniphier-pxs2.dtsi +++ b/arch/arm/dts/uniphier-pxs2.dtsi @@ -6,6 +6,7 @@ // Author: Masahiro Yamada yamada.masahiro@socionext.com
/ { @@ -161,7 +162,10 @@ compatible = "socionext,uniphier-system-cache"; reg = <0x500c0000 0x2000>, <0x503c0100 0x8>, <0x506c0000 0x400>; - interrupts = <0 174 4>, <0 175 4>, <0 190 4>, <0 191 4>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; cache-unified; cache-size = <(1280 * 1024)>; cache-sets = <512>; @@ -175,7 +179,7 @@ reg = <0x54006000 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 39 4>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi0>; clocks = <&peri_clk 11>; @@ -188,7 +192,7 @@ reg = <0x54006100 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 216 4>; + interrupts = <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi1>; clocks = <&peri_clk 12>; @@ -199,7 +203,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006800 0x40>; - interrupts = <0 33 4>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; clocks = <&peri_clk 0>; @@ -210,7 +214,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006900 0x40>; - interrupts = <0 35 4>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; clocks = <&peri_clk 1>; @@ -221,7 +225,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006a00 0x40>; - interrupts = <0 37 4>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; clocks = <&peri_clk 2>; @@ -232,7 +236,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006b00 0x40>; - interrupts = <0 177 4>; + interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart3>; clocks = <&peri_clk 3>; @@ -259,7 +263,7 @@ audio@56000000 { compatible = "socionext,uniphier-pxs2-aio"; reg = <0x56000000 0x80000>; - interrupts = <0 144 4>; + interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ain1>, <&pinctrl_ain2>, @@ -317,7 +321,7 @@ reg = <0x58780000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 41 4>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c0>; clocks = <&peri_clk 4>; @@ -331,7 +335,7 @@ reg = <0x58781000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 42 4>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c1>; clocks = <&peri_clk 5>; @@ -345,7 +349,7 @@ reg = <0x58782000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 43 4>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c2>; clocks = <&peri_clk 6>; @@ -359,7 +363,7 @@ reg = <0x58783000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 44 4>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c3>; clocks = <&peri_clk 7>; @@ -373,7 +377,7 @@ reg = <0x58784000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 45 4>; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 8>; resets = <&peri_rst 8>; clock-frequency = <400000>; @@ -385,7 +389,7 @@ reg = <0x58785000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 25 4>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 9>; resets = <&peri_rst 9>; clock-frequency = <400000>; @@ -397,7 +401,7 @@ reg = <0x58786000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 26 4>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 10>; resets = <&peri_rst 10>; clock-frequency = <400000>; @@ -418,33 +422,33 @@ reg = <0x59801000 0x400>; };
- sdctrl@59810000 { + sdctrl: syscon@59810000 { compatible = "socionext,uniphier-pxs2-sdctrl", "simple-mfd", "syscon"; reg = <0x59810000 0x400>;
- sd_clk: clock { + sd_clk: clock-controller { compatible = "socionext,uniphier-pxs2-sd-clock"; #clock-cells = <1>; };
- sd_rst: reset { + sd_rst: reset-controller { compatible = "socionext,uniphier-pxs2-sd-reset"; #reset-cells = <1>; }; };
- perictrl@59820000 { + syscon@59820000 { compatible = "socionext,uniphier-pxs2-perictrl", "simple-mfd", "syscon"; reg = <0x59820000 0x200>;
- peri_clk: clock { + peri_clk: clock-controller { compatible = "socionext,uniphier-pxs2-peri-clock"; #clock-cells = <1>; };
- peri_rst: reset { + peri_rst: reset-controller { compatible = "socionext,uniphier-pxs2-peri-reset"; #reset-cells = <1>; }; @@ -454,7 +458,7 @@ compatible = "socionext,uniphier-sd-v3.1.1"; status = "disabled"; reg = <0x5a000000 0x800>; - interrupts = <0 78 4>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_emmc>; clocks = <&sd_clk 1>; @@ -470,7 +474,7 @@ compatible = "socionext,uniphier-sd-v3.1.1"; status = "disabled"; reg = <0x5a400000 0x800>; - interrupts = <0 76 4>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default", "uhs"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_uhs>; @@ -482,9 +486,10 @@ sd-uhs-sdr12; sd-uhs-sdr25; sd-uhs-sdr50; + socionext,syscon-uhs-mode = <&sdctrl 0>; };
- soc_glue: soc-glue@5f800000 { + soc_glue: syscon@5f800000 { compatible = "socionext,uniphier-pxs2-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -494,9 +499,10 @@ }; };
- soc-glue@5f900000 { + syscon@5f900000 { compatible = "socionext,uniphier-pxs2-soc-glue-debug", - "simple-mfd"; + "simple-mfd", "syscon"; + reg = <0x5f900000 0x2000>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x5f900000 0x2000>; @@ -515,7 +521,7 @@ xdmac: dma-controller@5fc10000 { compatible = "socionext,uniphier-xdmac"; reg = <0x5fc10000 0x5300>; - interrupts = <0 188 4>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; dma-channels = <16>; #dma-cells = <2>; }; @@ -530,14 +536,16 @@ timer@60000200 { compatible = "arm,cortex-a9-global-timer"; reg = <0x60000200 0x20>; - interrupts = <1 11 0xf04>; + interrupts = <GIC_PPI 11 + (GIC_CPU_MASK_RAW(0xf) | IRQ_TYPE_LEVEL_HIGH)>; clocks = <&arm_timer_clk>; };
timer@60000600 { compatible = "arm,cortex-a9-twd-timer"; reg = <0x60000600 0x20>; - interrupts = <1 13 0xf04>; + interrupts = <GIC_PPI 13 + (GIC_CPU_MASK_RAW(0xf) | IRQ_TYPE_LEVEL_HIGH)>; clocks = <&arm_timer_clk>; };
@@ -549,24 +557,24 @@ interrupt-controller; };
- sysctrl@61840000 { + syscon@61840000 { compatible = "socionext,uniphier-pxs2-sysctrl", "simple-mfd", "syscon"; reg = <0x61840000 0x10000>;
- sys_clk: clock { + sys_clk: clock-controller { compatible = "socionext,uniphier-pxs2-clock"; #clock-cells = <1>; };
- sys_rst: reset { + sys_rst: reset-controller { compatible = "socionext,uniphier-pxs2-reset"; #reset-cells = <1>; };
- pvtctl: pvtctl { + pvtctl: thermal-sensor { compatible = "socionext,uniphier-pxs2-thermal"; - interrupts = <0 3 4>; + interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; #thermal-sensor-cells = <0>; socionext,tmod-calibration = <0x0f86 0x6844>; }; @@ -576,7 +584,7 @@ compatible = "socionext,uniphier-pxs2-ave4"; status = "disabled"; reg = <0x65000000 0x8500>; - interrupts = <0 66 4>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ether_rgmii>; clock-names = "ether"; @@ -593,12 +601,53 @@ }; };
+ ahci: sata@65600000 { + compatible = "socionext,uniphier-pxs2-ahci", + "generic-ahci"; + status = "disabled"; + reg = <0x65600000 0x10000>; + interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&sys_clk 28>; + resets = <&sys_rst 28>, <&ahci_rst 0>; + ports-implemented = <1>; + phys = <&ahci_phy>; + }; + + sata-controller@65700000 { + compatible = "socionext,uniphier-pxs2-ahci-glue", + "simple-mfd"; + reg = <0x65700000 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x65700000 0x100>; + + ahci_rst: reset-controller@0 { + compatible = "socionext,uniphier-pxs2-ahci-reset"; + reg = <0x0 0x4>; + clock-names = "link"; + clocks = <&sys_clk 28>; + reset-names = "link"; + resets = <&sys_rst 28>; + #reset-cells = <1>; + }; + + ahci_phy: phy@10 { + compatible = "socionext,uniphier-pxs2-ahci-phy"; + reg = <0x10 0x10>; + clock-names = "link"; + clocks = <&sys_clk 28>; + reset-names = "link", "phy"; + resets = <&sys_rst 28>, <&sys_rst 30>; + #phy-cells = <0>; + }; + }; + usb0: usb@65a00000 { compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65a00000 0xcd00>; - interrupt-names = "host", "peripheral"; - interrupts = <0 134 4>, <0 135 4>; + interrupt-names = "dwc_usb3"; + interrupts = <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>, <&pinctrl_usb2>; clock-names = "ref", "bus_early", "suspend"; @@ -609,14 +658,15 @@ dr_mode = "host"; };
- usb-glue@65b00000 { + usb-controller@65b00000 { compatible = "socionext,uniphier-pxs2-dwc3-glue", "simple-mfd"; + reg = <0x65b00000 0x400>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x65b00000 0x400>;
- usb0_rst: reset@0 { + usb0_rst: reset-controller@0 { compatible = "socionext,uniphier-pxs2-usb3-reset"; reg = <0x0 0x4>; #reset-cells = <1>; @@ -644,7 +694,7 @@ resets = <&sys_rst 14>; };
- usb0_hsphy0: hs-phy@200 { + usb0_hsphy0: phy@200 { compatible = "socionext,uniphier-pxs2-usb3-hsphy"; reg = <0x200 0x10>; #phy-cells = <0>; @@ -655,7 +705,7 @@ vbus-supply = <&usb0_vbus0>; };
- usb0_hsphy1: hs-phy@210 { + usb0_hsphy1: phy@210 { compatible = "socionext,uniphier-pxs2-usb3-hsphy"; reg = <0x210 0x10>; #phy-cells = <0>; @@ -666,7 +716,7 @@ vbus-supply = <&usb0_vbus1>; };
- usb0_ssphy0: ss-phy@300 { + usb0_ssphy0: phy@300 { compatible = "socionext,uniphier-pxs2-usb3-ssphy"; reg = <0x300 0x10>; #phy-cells = <0>; @@ -677,7 +727,7 @@ vbus-supply = <&usb0_vbus0>; };
- usb0_ssphy1: ss-phy@310 { + usb0_ssphy1: phy@310 { compatible = "socionext,uniphier-pxs2-usb3-ssphy"; reg = <0x310 0x10>; #phy-cells = <0>; @@ -693,8 +743,8 @@ compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65c00000 0xcd00>; - interrupt-names = "host", "peripheral"; - interrupts = <0 137 4>, <0 138 4>; + interrupt-names = "dwc_usb3"; + interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb1>, <&pinctrl_usb3>; clock-names = "ref", "bus_early", "suspend"; @@ -704,14 +754,15 @@ dr_mode = "host"; };
- usb-glue@65d00000 { + usb-controller@65d00000 { compatible = "socionext,uniphier-pxs2-dwc3-glue", "simple-mfd"; + reg = <0x65d00000 0x400>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x65d00000 0x400>;
- usb1_rst: reset@0 { + usb1_rst: reset-controller@0 { compatible = "socionext,uniphier-pxs2-usb3-reset"; reg = <0x0 0x4>; #reset-cells = <1>; @@ -739,7 +790,7 @@ resets = <&sys_rst 15>; };
- usb1_hsphy0: hs-phy@200 { + usb1_hsphy0: phy@200 { compatible = "socionext,uniphier-pxs2-usb3-hsphy"; reg = <0x200 0x10>; #phy-cells = <0>; @@ -750,7 +801,7 @@ vbus-supply = <&usb1_vbus0>; };
- usb1_hsphy1: hs-phy@210 { + usb1_hsphy1: phy@210 { compatible = "socionext,uniphier-pxs2-usb3-hsphy"; reg = <0x210 0x10>; #phy-cells = <0>; @@ -761,7 +812,7 @@ vbus-supply = <&usb1_vbus1>; };
- usb1_ssphy0: ss-phy@300 { + usb1_ssphy0: phy@300 { compatible = "socionext,uniphier-pxs2-usb3-ssphy"; reg = <0x300 0x10>; #phy-cells = <0>; @@ -778,7 +829,9 @@ status = "disabled"; reg-names = "nand_data", "denali_reg"; reg = <0x68000000 0x20>, <0x68100000 0x1000>; - interrupts = <0 65 4>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_nand2cs>; clock-names = "nand", "nand_x", "ecc"; diff --git a/arch/arm/dts/uniphier-pxs3-ref.dts b/arch/arm/dts/uniphier-pxs3-ref.dts index 1a80cd91d2..1ced6190ab 100644 --- a/arch/arm/dts/uniphier-pxs3-ref.dts +++ b/arch/arm/dts/uniphier-pxs3-ref.dts @@ -40,11 +40,11 @@ };
ðsc { - interrupts = <4 8>; + interrupts = <4 IRQ_TYPE_LEVEL_LOW>; };
&serialsc { - interrupts = <4 8>; + interrupts = <4 IRQ_TYPE_LEVEL_LOW>; };
&spi0 { @@ -68,7 +68,7 @@ };
&gpio { - xirq4 { + xirq4-hog { gpio-hog; gpios = <UNIPHIER_GPIO_IRQ(4) 0>; input; @@ -131,6 +131,18 @@
&pinctrl_ether_rgmii { diff --git a/arch/arm/dts/uniphier-pxs3.dtsi b/arch/arm/dts/uniphier-pxs3.dtsi index 410bf51e52..91d6dde030 100644 --- a/arch/arm/dts/uniphier-pxs3.dtsi +++ b/arch/arm/dts/uniphier-pxs3.dtsi @@ -7,6 +7,7 @@
/ { @@ -42,6 +43,7 @@ reg = <0 0x000>; clocks = <&sys_clk 33>; enable-method = "psci"; + next-level-cache = <&l2>; operating-points-v2 = <&cluster0_opp>; #cooling-cells = <2>; }; @@ -52,6 +54,7 @@ reg = <0 0x001>; clocks = <&sys_clk 33>; enable-method = "psci"; + next-level-cache = <&l2>; operating-points-v2 = <&cluster0_opp>; #cooling-cells = <2>; }; @@ -62,6 +65,7 @@ reg = <0 0x002>; clocks = <&sys_clk 33>; enable-method = "psci"; + next-level-cache = <&l2>; operating-points-v2 = <&cluster0_opp>; #cooling-cells = <2>; }; @@ -72,9 +76,14 @@ reg = <0 0x003>; clocks = <&sys_clk 33>; enable-method = "psci"; + next-level-cache = <&l2>; operating-points-v2 = <&cluster0_opp>; #cooling-cells = <2>; }; + + l2: l2-cache { + compatible = "cache"; + }; };
cluster0_opp: opp-table { @@ -135,10 +144,10 @@
timer { compatible = "arm,armv8-timer"; - interrupts = <1 13 4>, - <1 14 4>, - <1 11 4>, - <1 10 4>; + interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 14 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 11 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 10 IRQ_TYPE_LEVEL_HIGH>; };
thermal-zones { @@ -195,7 +204,7 @@ reg = <0x54006000 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 39 4>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi0>; clocks = <&peri_clk 11>; @@ -208,7 +217,7 @@ reg = <0x54006100 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 216 4>; + interrupts = <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi1>; clocks = <&peri_clk 12>; @@ -219,7 +228,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006800 0x40>; - interrupts = <0 33 4>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; clocks = <&peri_clk 0>; @@ -230,7 +239,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006900 0x40>; - interrupts = <0 35 4>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; clocks = <&peri_clk 1>; @@ -241,7 +250,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006a00 0x40>; - interrupts = <0 37 4>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; clocks = <&peri_clk 2>; @@ -252,7 +261,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006b00 0x40>; - interrupts = <0 177 4>; + interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart3>; clocks = <&peri_clk 3>; @@ -284,7 +293,7 @@ reg = <0x58780000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 41 4>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c0>; clocks = <&peri_clk 4>; @@ -298,7 +307,7 @@ reg = <0x58781000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 42 4>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c1>; clocks = <&peri_clk 5>; @@ -312,7 +321,7 @@ reg = <0x58782000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 43 4>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c2>; clocks = <&peri_clk 6>; @@ -326,7 +335,7 @@ reg = <0x58783000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 44 4>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c3>; clocks = <&peri_clk 7>; @@ -340,7 +349,7 @@ reg = <0x58786000 0x80>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 26 4>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; clocks = <&peri_clk 10>; resets = <&peri_rst 10>; clock-frequency = <400000>; @@ -361,33 +370,33 @@ reg = <0x59801000 0x400>; };
- sdctrl@59810000 { + sdctrl: syscon@59810000 { compatible = "socionext,uniphier-pxs3-sdctrl", "simple-mfd", "syscon"; reg = <0x59810000 0x400>;
- sd_clk: clock { + sd_clk: clock-controller { compatible = "socionext,uniphier-pxs3-sd-clock"; #clock-cells = <1>; };
- sd_rst: reset { + sd_rst: reset-controller { compatible = "socionext,uniphier-pxs3-sd-reset"; #reset-cells = <1>; }; };
- perictrl@59820000 { + syscon@59820000 { compatible = "socionext,uniphier-pxs3-perictrl", "simple-mfd", "syscon"; reg = <0x59820000 0x200>;
- peri_clk: clock { + peri_clk: clock-controller { compatible = "socionext,uniphier-pxs3-peri-clock"; #clock-cells = <1>; };
- peri_rst: reset { + peri_rst: reset-controller { compatible = "socionext,uniphier-pxs3-peri-reset"; #reset-cells = <1>; }; @@ -396,7 +405,7 @@ emmc: mmc@5a000000 { compatible = "socionext,uniphier-sd4hc", "cdns,sd4hc"; reg = <0x5a000000 0x400>; - interrupts = <0 78 4>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_emmc>; clocks = <&sys_clk 4>; @@ -416,7 +425,7 @@ compatible = "socionext,uniphier-sd-v3.1.1"; status = "disabled"; reg = <0x5a400000 0x800>; - interrupts = <0 76 4>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default", "uhs"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_uhs>; @@ -428,9 +437,10 @@ sd-uhs-sdr12; sd-uhs-sdr25; sd-uhs-sdr50; + socionext,syscon-uhs-mode = <&sdctrl 0>; };
- soc_glue: soc-glue@5f800000 { + soc_glue: syscon@5f800000 { compatible = "socionext,uniphier-pxs3-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -440,9 +450,10 @@ }; };
- soc-glue@5f900000 { + syscon@5f900000 { compatible = "socionext,uniphier-pxs3-soc-glue-debug", - "simple-mfd"; + "simple-mfd", "syscon"; + reg = <0x5f900000 0x2000>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x5f900000 0x2000>; @@ -505,7 +516,7 @@ xdmac: dma-controller@5fc10000 { compatible = "socionext,uniphier-xdmac"; reg = <0x5fc10000 0x5300>; - interrupts = <0 188 4>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; dma-channels = <16>; #dma-cells = <2>; }; @@ -523,20 +534,20 @@ <0x5fe80000 0x80000>; /* GICR */ interrupt-controller; #interrupt-cells = <3>; - interrupts = <1 9 4>; + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; };
- sysctrl@61840000 { + syscon@61840000 { compatible = "socionext,uniphier-pxs3-sysctrl", "simple-mfd", "syscon"; reg = <0x61840000 0x10000>;
- sys_clk: clock { + sys_clk: clock-controller { compatible = "socionext,uniphier-pxs3-clock"; #clock-cells = <1>; };
- sys_rst: reset { + sys_rst: reset-controller { compatible = "socionext,uniphier-pxs3-reset"; #reset-cells = <1>; }; @@ -545,9 +556,9 @@ compatible = "socionext,uniphier-wdt"; };
- pvtctl: pvtctl { + pvtctl: thermal-sensor { compatible = "socionext,uniphier-pxs3-thermal"; - interrupts = <0 3 4>; + interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; #thermal-sensor-cells = <0>; socionext,tmod-calibration = <0x0f22 0x68ee>; }; @@ -557,7 +568,7 @@ compatible = "socionext,uniphier-pxs3-ave4"; status = "disabled"; reg = <0x65000000 0x8500>; - interrupts = <0 66 4>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ether_rgmii>; clock-names = "ether"; @@ -578,7 +589,7 @@ compatible = "socionext,uniphier-pxs3-ave4"; status = "disabled"; reg = <0x65200000 0x8500>; - interrupts = <0 67 4>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ether1_rgmii>; clock-names = "ether"; @@ -595,12 +606,94 @@ }; };
+ ahci0: sata@65600000 { + compatible = "socionext,uniphier-pxs3-ahci", + "generic-ahci"; + status = "disabled"; + reg = <0x65600000 0x10000>; + interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&sys_clk 28>; + resets = <&sys_rst 28>, <&ahci0_rst 0>; + ports-implemented = <1>; + phys = <&ahci0_phy>; + }; + + sata-controller@65700000 { + compatible = "socionext,uniphier-pxs3-ahci-glue", + "simple-mfd"; + reg = <0x65700000 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x65700000 0x100>; + + ahci0_rst: reset-controller@0 { + compatible = "socionext,uniphier-pxs3-ahci-reset"; + reg = <0x0 0x4>; + clock-names = "link"; + clocks = <&sys_clk 28>; + reset-names = "link"; + resets = <&sys_rst 28>; + #reset-cells = <1>; + }; + + ahci0_phy: phy@10 { + compatible = "socionext,uniphier-pxs3-ahci-phy"; + reg = <0x10 0x10>; + clock-names = "link", "phy"; + clocks = <&sys_clk 28>, <&sys_clk 30>; + reset-names = "link", "phy"; + resets = <&sys_rst 28>, <&sys_rst 30>; + #phy-cells = <0>; + }; + }; + + ahci1: sata@65800000 { + compatible = "socionext,uniphier-pxs3-ahci", + "generic-ahci"; + status = "disabled"; + reg = <0x65800000 0x10000>; + interrupts = <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&sys_clk 29>; + resets = <&sys_rst 29>, <&ahci1_rst 0>; + ports-implemented = <1>; + phys = <&ahci1_phy>; + }; + + sata-controller@65900000 { + compatible = "socionext,uniphier-pxs3-ahci-glue", + "simple-mfd"; + reg = <0x65900000 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x65900000 0x100>; + + ahci1_rst: reset-controller@0 { + compatible = "socionext,uniphier-pxs3-ahci-reset"; + reg = <0x0 0x4>; + clock-names = "link"; + clocks = <&sys_clk 29>; + reset-names = "link"; + resets = <&sys_rst 29>; + #reset-cells = <1>; + }; + + ahci1_phy: phy@10 { + compatible = "socionext,uniphier-pxs3-ahci-phy"; + reg = <0x10 0x10>; + clock-names = "link", "phy"; + clocks = <&sys_clk 29>, <&sys_clk 30>; + reset-names = "link", "phy"; + resets = <&sys_rst 29>, <&sys_rst 30>; + #phy-cells = <0>; + }; + }; + usb0: usb@65a00000 { compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65a00000 0xcd00>; - interrupt-names = "host", "peripheral"; - interrupts = <0 134 4>, <0 135 4>; + interrupt-names = "dwc_usb3"; + interrupts = <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>, <&pinctrl_usb2>; clock-names = "ref", "bus_early", "suspend"; @@ -611,14 +704,15 @@ dr_mode = "host"; };
- usb-glue@65b00000 { + usb-controller@65b00000 { compatible = "socionext,uniphier-pxs3-dwc3-glue", "simple-mfd"; + reg = <0x65b00000 0x400>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x65b00000 0x400>;
- usb0_rst: reset@0 { + usb0_rst: reset-controller@0 { compatible = "socionext,uniphier-pxs3-usb3-reset"; reg = <0x0 0x4>; #reset-cells = <1>; @@ -646,7 +740,7 @@ resets = <&sys_rst 12>; };
- usb0_hsphy0: hs-phy@200 { + usb0_hsphy0: phy@200 { compatible = "socionext,uniphier-pxs3-usb3-hsphy"; reg = <0x200 0x10>; #phy-cells = <0>; @@ -660,7 +754,7 @@ <&usb_hs_i0>; };
- usb0_hsphy1: hs-phy@210 { + usb0_hsphy1: phy@210 { compatible = "socionext,uniphier-pxs3-usb3-hsphy"; reg = <0x210 0x10>; #phy-cells = <0>; @@ -674,7 +768,7 @@ <&usb_hs_i0>; };
- usb0_ssphy0: ss-phy@300 { + usb0_ssphy0: phy@300 { compatible = "socionext,uniphier-pxs3-usb3-ssphy"; reg = <0x300 0x10>; #phy-cells = <0>; @@ -685,7 +779,7 @@ vbus-supply = <&usb0_vbus0>; };
- usb0_ssphy1: ss-phy@310 { + usb0_ssphy1: phy@310 { compatible = "socionext,uniphier-pxs3-usb3-ssphy"; reg = <0x310 0x10>; #phy-cells = <0>; @@ -701,8 +795,8 @@ compatible = "socionext,uniphier-dwc3", "snps,dwc3"; status = "disabled"; reg = <0x65c00000 0xcd00>; - interrupt-names = "host", "peripheral"; - interrupts = <0 137 4>, <0 138 4>; + interrupt-names = "dwc_usb3"; + interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb1>, <&pinctrl_usb3>; clock-names = "ref", "bus_early", "suspend"; @@ -713,14 +807,15 @@ dr_mode = "host"; };
- usb-glue@65d00000 { + usb-controller@65d00000 { compatible = "socionext,uniphier-pxs3-dwc3-glue", "simple-mfd"; + reg = <0x65d00000 0x400>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x65d00000 0x400>;
- usb1_rst: reset@0 { + usb1_rst: reset-controller@0 { compatible = "socionext,uniphier-pxs3-usb3-reset"; reg = <0x0 0x4>; #reset-cells = <1>; @@ -748,7 +843,7 @@ resets = <&sys_rst 13>; };
- usb1_hsphy0: hs-phy@200 { + usb1_hsphy0: phy@200 { compatible = "socionext,uniphier-pxs3-usb3-hsphy"; reg = <0x200 0x10>; #phy-cells = <0>; @@ -763,7 +858,7 @@ <&usb_hs_i2>; };
- usb1_hsphy1: hs-phy@210 { + usb1_hsphy1: phy@210 { compatible = "socionext,uniphier-pxs3-usb3-hsphy"; reg = <0x210 0x10>; #phy-cells = <0>; @@ -778,7 +873,7 @@ <&usb_hs_i2>; };
- usb1_ssphy0: ss-phy@300 { + usb1_ssphy0: phy@300 { compatible = "socionext,uniphier-pxs3-usb3-ssphy"; reg = <0x300 0x10>; #phy-cells = <0>; @@ -792,7 +887,7 @@ };
pcie: pcie@66000000 { - compatible = "socionext,uniphier-pcie", "snps,dw-pcie"; + compatible = "socionext,uniphier-pcie"; status = "disabled"; reg-names = "dbi", "link", "config"; reg = <0x66000000 0x1000>, <0x66010000 0x10000>, @@ -812,7 +907,8 @@ <0x82000000 0 0x20000000 0x20000000 0 0x0ffe0000>; #interrupt-cells = <1>; interrupt-names = "dma", "msi"; - interrupts = <0 224 4>, <0 225 4>; + interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; interrupt-map-mask = <0 0 0 7>; interrupt-map = <0 0 0 1 &pcie_intc 0>, /* INTA */ <0 0 0 2 &pcie_intc 1>, /* INTB */ @@ -825,7 +921,7 @@ interrupt-controller; #interrupt-cells = <1>; interrupt-parent = <&gic>; - interrupts = <0 226 4>; + interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; }; };
@@ -845,7 +941,9 @@ status = "disabled"; reg-names = "nand_data", "denali_reg"; reg = <0x68000000 0x20>, <0x68100000 0x1000>; - interrupts = <0 65 4>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_nand>; clock-names = "nand", "nand_x", "ecc"; diff --git a/arch/arm/dts/uniphier-sld8-ref.dts b/arch/arm/dts/uniphier-sld8-ref.dts index 22898df39c..2446f9e153 100644 --- a/arch/arm/dts/uniphier-sld8-ref.dts +++ b/arch/arm/dts/uniphier-sld8-ref.dts @@ -36,11 +36,11 @@ };
ðsc { - interrupts = <0 8>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; };
&serialsc { - interrupts = <0 8>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; };
&gpio { - xirq0 { + xirq0-hog { gpio-hog; gpios = <UNIPHIER_GPIO_IRQ(0) 0>; input; @@ -85,4 +85,8 @@
&nand { status = "okay"; + + nand@0 { + reg = <0>; + }; }; diff --git a/arch/arm/dts/uniphier-sld8.dtsi b/arch/arm/dts/uniphier-sld8.dtsi index 93ddebbae4..4708b2d7a1 100644 --- a/arch/arm/dts/uniphier-sld8.dtsi +++ b/arch/arm/dts/uniphier-sld8.dtsi @@ -6,6 +6,7 @@ // Author: Masahiro Yamada yamada.masahiro@socionext.com
#include <dt-bindings/gpio/uniphier-gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h>
/ { compatible = "socionext,uniphier-sld8"; @@ -55,7 +56,8 @@ compatible = "socionext,uniphier-system-cache"; reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, <0x506c0000 0x400>; - interrupts = <0 174 4>, <0 175 4>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; cache-unified; cache-size = <(256 * 1024)>; cache-sets = <256>; @@ -69,7 +71,7 @@ reg = <0x54006000 0x100>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 39 4>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi0>; clocks = <&peri_clk 11>; @@ -80,7 +82,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006800 0x40>; - interrupts = <0 33 4>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; clocks = <&peri_clk 0>; @@ -91,7 +93,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006900 0x40>; - interrupts = <0 35 4>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; clocks = <&peri_clk 1>; @@ -102,7 +104,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006a00 0x40>; - interrupts = <0 37 4>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; clocks = <&peri_clk 2>; @@ -113,7 +115,7 @@ compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006b00 0x40>; - interrupts = <0 29 4>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart3>; clocks = <&peri_clk 3>; @@ -144,7 +146,7 @@ reg = <0x58400000 0x40>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 41 1>; + interrupts = <GIC_SPI 41 IRQ_TYPE_EDGE_RISING>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c0>; clocks = <&peri_clk 4>; @@ -158,7 +160,7 @@ reg = <0x58480000 0x40>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 42 1>; + interrupts = <GIC_SPI 42 IRQ_TYPE_EDGE_RISING>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c1>; clocks = <&peri_clk 5>; @@ -172,7 +174,7 @@ reg = <0x58500000 0x40>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 43 1>; + interrupts = <GIC_SPI 43 IRQ_TYPE_EDGE_RISING>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c2>; clocks = <&peri_clk 6>; @@ -186,7 +188,7 @@ reg = <0x58580000 0x40>; #address-cells = <1>; #size-cells = <0>; - interrupts = <0 44 1>; + interrupts = <GIC_SPI 44 IRQ_TYPE_EDGE_RISING>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c3>; clocks = <&peri_clk 7>; @@ -209,33 +211,33 @@ reg = <0x59801000 0x400>; };
- mioctrl@59810000 { + mioctrl: syscon@59810000 { compatible = "socionext,uniphier-sld8-mioctrl", "simple-mfd", "syscon"; reg = <0x59810000 0x800>;
- mio_clk: clock { + mio_clk: clock-controller { compatible = "socionext,uniphier-sld8-mio-clock"; #clock-cells = <1>; };
- mio_rst: reset { + mio_rst: reset-controller { compatible = "socionext,uniphier-sld8-mio-reset"; #reset-cells = <1>; }; };
- perictrl@59820000 { + syscon@59820000 { compatible = "socionext,uniphier-sld8-perictrl", "simple-mfd", "syscon"; reg = <0x59820000 0x200>;
- peri_clk: clock { + peri_clk: clock-controller { compatible = "socionext,uniphier-sld8-peri-clock"; #clock-cells = <1>; };
- peri_rst: reset { + peri_rst: reset-controller { compatible = "socionext,uniphier-sld8-peri-reset"; #reset-cells = <1>; }; @@ -244,8 +246,13 @@ dmac: dma-controller@5a000000 { compatible = "socionext,uniphier-mio-dmac"; reg = <0x5a000000 0x1000>; - interrupts = <0 68 4>, <0 68 4>, <0 69 4>, <0 70 4>, - <0 71 4>, <0 72 4>, <0 73 4>; + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; clocks = <&mio_clk 7>; resets = <&mio_rst 7>; #dma-cells = <1>; @@ -255,7 +262,7 @@ compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a400000 0x200>; - interrupts = <0 76 4>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default", "uhs"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_uhs>; @@ -269,13 +276,14 @@ sd-uhs-sdr12; sd-uhs-sdr25; sd-uhs-sdr50; + socionext,syscon-uhs-mode = <&mioctrl 0>; };
emmc: mmc@5a500000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a500000 0x200>; - interrupts = <0 78 4>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_emmc>; clocks = <&mio_clk 1>; @@ -293,7 +301,7 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a800100 0x100>; - interrupts = <0 80 4>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>; clocks = <&sys_clk 8>, <&mio_clk 7>, <&mio_clk 8>, @@ -307,7 +315,7 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; - interrupts = <0 81 4>; + interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb1>; clocks = <&sys_clk 8>, <&mio_clk 7>, <&mio_clk 9>, @@ -321,7 +329,7 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a820100 0x100>; - interrupts = <0 82 4>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb2>; clocks = <&sys_clk 8>, <&mio_clk 7>, <&mio_clk 10>, @@ -331,7 +339,7 @@ has-transaction-translator; };
- soc-glue@5f800000 { + syscon@5f800000 { compatible = "socionext,uniphier-sld8-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -341,9 +349,10 @@ }; };
- soc-glue@5f900000 { + syscon@5f900000 { compatible = "socionext,uniphier-sld8-soc-glue-debug", - "simple-mfd"; + "simple-mfd", "syscon"; + reg = <0x5f900000 0x2000>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x5f900000 0x2000>; @@ -362,14 +371,16 @@ timer@60000200 { compatible = "arm,cortex-a9-global-timer"; reg = <0x60000200 0x20>; - interrupts = <1 11 0x104>; + interrupts = <GIC_PPI 11 + (GIC_CPU_MASK_RAW(1) | IRQ_TYPE_LEVEL_HIGH)>; clocks = <&arm_timer_clk>; };
@@ -388,17 +399,17 @@ #interrupt-cells = <2>; };
- sysctrl@61840000 { + syscon@61840000 { compatible = "socionext,uniphier-sld8-sysctrl", "simple-mfd", "syscon"; reg = <0x61840000 0x10000>;
- sys_clk: clock { + sys_clk: clock-controller { compatible = "socionext,uniphier-sld8-clock"; #clock-cells = <1>; };
- sys_rst: reset { + sys_rst: reset-controller { compatible = "socionext,uniphier-sld8-reset"; #reset-cells = <1>; }; @@ -409,7 +420,9 @@ status = "disabled"; reg-names = "nand_data", "denali_reg"; reg = <0x68000000 0x20>, <0x68100000 0x1000>; - interrupts = <0 65 4>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_nand2cs>; clock-names = "nand", "nand_x", "ecc";
On 2/28/23 03:37, Kunihiko Hayashi wrote:
Synchronize devicetree sources with Linux v6.2.
- Use GIC interrupt definitions
- Add reg properties in USB-glue and SoC-glue node
- Fix node names to follow the generic names list in DT specification
- Add L2 cache and AHCI nodes
- Update nand and pcie nodes
- And some trivial fixes
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com
Acked-by: Marek Vasut marex@denx.de
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com Acked-by: Marek Vasut marex@denx.de
Kunihiko Hayashi
