[U-Boot] [PATCH] usb: musb-new: omap2430: Reset the MUSB controller early
When booting from USB peripheral boot, the bootrom will not properly deinit the MUSB controller, which doesn't clearly indicate an USB disconnection to the host and leaves U-Boot to deal with the state of the previous USB session.
On some host controller drivers (e.g. xhci_hcd), this ends up in a failure during set address, caused by the lack of proper disconnection notification.
Resetting the controller early in U-Boot notifies the host of the disconnection and doesn't hurt other use cases.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- drivers/usb/musb-new/omap2430.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/drivers/usb/musb-new/omap2430.c b/drivers/usb/musb-new/omap2430.c index 98f4830..6b256bb 100644 --- a/drivers/usb/musb-new/omap2430.c +++ b/drivers/usb/musb-new/omap2430.c @@ -321,6 +321,7 @@ static int omap2430_musb_init(struct musb *musb) { u32 l; int status = 0; + int timeout = 10; #ifndef __UBOOT__ struct device *dev = musb->controller; struct omap2430_glue *glue = dev_get_drvdata(dev->parent); @@ -331,6 +332,22 @@ static int omap2430_musb_init(struct musb *musb) (struct omap_musb_board_data *)musb->controller; #endif
+ /* Reset the controller */ + musb_writel(musb->mregs, OTG_SYSCONFIG, SOFTRST); + + while (timeout--) { + l = musb_readl(musb->mregs, OTG_SYSCONFIG); + + if (l & SOFTRST) + udelay(1); + else + break; + } + + if (timeout == 0) { + dev_err(musb->controller, "MUSB reset is taking too long\n"); + return -ENODEV; + }
#ifndef __UBOOT__ /* We require some kind of external transceiver, hooked
- int timeout = 10;
- /* Reset the controller */
- musb_writel(musb->mregs, OTG_SYSCONFIG, SOFTRST);
- while (timeout--) {
Hi!
Just a minor nitpick, you might want to replace the timeout with get_timer(0) and friends, see for example drivers/spi/altera_spi.c:161 (the inner loop in spi_xfer() ).
+CC Hans, can you test on sunxi please ?
Thank you !
Best regards, Marek Vasut
- int timeout = 10;
Hi!
Well to be honest here, I added that timeout code "just because" and every time I tried, the bit was cleared on the first read right after instructing the reset, so I doubt there is a real need for "doing it right". Let me know if you really think this would be better with timers.
I could test on sunxi as well if that helps, but isn't that part of the code specific to the OMAP?
Thanks for the review!
- int timeout = 10;
#ifndef __UBOOT__
#endif
Hi!
By using this get_timer() approach, you implement a much more consistent and deterministic timeout, which expires around the number of mSec it was supposed to take, while in this current approach, the real duration of the loop might vary greatly.
The get_timer() approach is also the favored way of implementing timeouts in U-Boot, so I would prefer to use this approach if/where possible.
Oh, oops, sorry. You're right, thanks for pointing it out.
In that case, please fix the loop and unless anyone has any objections, I'd pick V2 for the current merge window. Tom, do you agree please ?
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- drivers/usb/musb-new/omap2430.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/drivers/usb/musb-new/omap2430.c b/drivers/usb/musb-new/omap2430.c index 98f4830..31a280e 100644 --- a/drivers/usb/musb-new/omap2430.c +++ b/drivers/usb/musb-new/omap2430.c @@ -321,6 +321,7 @@ static int omap2430_musb_init(struct musb *musb) { u32 l; int status = 0; + unsigned long int start; #ifndef __UBOOT__ struct device *dev = musb->controller; struct omap2430_glue *glue = dev_get_drvdata(dev->parent); @@ -331,6 +332,21 @@ static int omap2430_musb_init(struct musb *musb) (struct omap_musb_board_data *)musb->controller; #endif
+ /* Reset the controller */ + musb_writel(musb->mregs, OTG_SYSCONFIG, SOFTRST); + + start = get_timer(0); + + while (1) { + l = musb_readl(musb->mregs, OTG_SYSCONFIG); + if ((l & SOFTRST) == 0) + break; + + if (get_timer(start) > (CONFIG_SYS_HZ / 1000)) { + dev_err(musb->controller, "MUSB reset is taking too long\n"); + return -ENODEV; + } + }
Reviewed-by: Tom Rini trini@ti.com
Applied, thanks!
Paul Kocialkowski
