[U-Boot] [PATCH] Blackfin: bf518f-ezbrd: don't require SPI logic all the time
Only the first run of boards had a ksz switch on it, so if building for a newer silicon rev or SPI is disabled, don't bother checking for the ksz.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf518f-ezbrd/bf518f-ezbrd.c | 30 ++++++++++++++++++++++-------- 1 files changed, 22 insertions(+), 8 deletions(-)
diff --git a/board/bf518f-ezbrd/bf518f-ezbrd.c b/board/bf518f-ezbrd/bf518f-ezbrd.c index ff1ac4c..4bd02ee 100644 --- a/board/bf518f-ezbrd/bf518f-ezbrd.c +++ b/board/bf518f-ezbrd/bf518f-ezbrd.c @@ -57,6 +57,13 @@ static void board_init_enetaddr(uchar *mac_addr) eth_setenv_enetaddr("ethaddr", mac_addr); }
+/* Only the first run of boards had a KSZ switch */ +#if defined(CONFIG_BFIN_SPI) && __SILICON_REVISION__ == 0 +# define KSZ_POSSIBLE 1 +#else +# define KSZ_POSSIBLE 0 +#endif + #define KSZ_MAX_HZ 5000000
#define KSZ_WRITE 0x02 @@ -109,17 +116,16 @@ static int ksz8893m_reset(struct spi_slave *slave) return ret; }
-int board_eth_init(bd_t *bis) +static int board_ksz_init(void) { - static bool switch_is_alive = false, phy_is_ksz = true; - int ret; + static bool switch_is_alive = false;
if (!switch_is_alive) { struct spi_slave *slave = spi_setup_slave(0, 1, KSZ_MAX_HZ, SPI_MODE_3); if (slave) { if (!spi_claim_bus(slave)) { - phy_is_ksz = (ksz8893m_reg_read(slave, KSZ_REG_CHID) == 0x88); - ret = phy_is_ksz ? ksz8893m_reset(slave) : 0; + bool phy_is_ksz = (ksz8893m_reg_read(slave, KSZ_REG_CHID) == 0x88); + int ret = phy_is_ksz ? ksz8893m_reset(slave) : 0; switch_is_alive = (ret == 0); spi_release_bus(slave); } @@ -127,10 +133,18 @@ int board_eth_init(bd_t *bis) } }
- if (switch_is_alive) - return bfin_EMAC_initialize(bis); - else + if (!switch_is_alive) return -1; + else + return 0; +} + +int board_eth_init(bd_t *bis) +{ + if (KSZ_POSSIBLE) + if (board_ksz_init() == -1) + return 0; + return bfin_EMAC_initialize(bis); } #endif
Dear Mike Frysinger,
- if (!switch_is_alive) return -1;
- else
Drop the else, and unindent the return 0;
- if (KSZ_POSSIBLE)
Braces needed for multiline statements.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- v2 - tweak style
board/bf518f-ezbrd/bf518f-ezbrd.c | 30 +++++++++++++++++++++--------- 1 files changed, 21 insertions(+), 9 deletions(-)
diff --git a/board/bf518f-ezbrd/bf518f-ezbrd.c b/board/bf518f-ezbrd/bf518f-ezbrd.c index ff1ac4c..6b455de 100644 --- a/board/bf518f-ezbrd/bf518f-ezbrd.c +++ b/board/bf518f-ezbrd/bf518f-ezbrd.c @@ -57,6 +57,13 @@ static void board_init_enetaddr(uchar *mac_addr) eth_setenv_enetaddr("ethaddr", mac_addr); }
-int board_eth_init(bd_t *bis) +static bool board_ksz_init(void) { - static bool switch_is_alive = false, phy_is_ksz = true; - int ret; + static bool switch_is_alive = false;
if (!switch_is_alive) { struct spi_slave *slave = spi_setup_slave(0, 1, KSZ_MAX_HZ, SPI_MODE_3); if (slave) { if (!spi_claim_bus(slave)) { - phy_is_ksz = (ksz8893m_reg_read(slave, KSZ_REG_CHID) == 0x88); - ret = phy_is_ksz ? ksz8893m_reset(slave) : 0; + bool phy_is_ksz = (ksz8893m_reg_read(slave, KSZ_REG_CHID) == 0x88); + int ret = phy_is_ksz ? ksz8893m_reset(slave) : 0; switch_is_alive = (ret == 0); spi_release_bus(slave); } @@ -127,10 +133,16 @@ int board_eth_init(bd_t *bis) } }
- if (switch_is_alive) - return bfin_EMAC_initialize(bis); - else - return -1; + return switch_is_alive; +} + +int board_eth_init(bd_t *bis) +{ + if (KSZ_POSSIBLE) { + if (!board_ksz_init()) + return 0; + } + return bfin_EMAC_initialize(bis); } #endif
Mike Frysinger
