[U-Boot] [PATCH v6 1/4] dm: spi: Convert Freescale ESPI driver to driver model
Modify the Freescale ESPI driver to support the driver model. Also resolved the following problems:
===================== WARNING ====================== This board does not use CONFIG_DM_SPI. Please update the board before v2019.04 for no dm conversion and v2019.07 for partially dm converted drivers. Failure to update can lead to driver/board removal See doc/driver-model/MIGRATION.txt for more info. ==================================================== ===================== WARNING ====================== This board does not use CONFIG_DM_SPI_FLASH. Please update the board to use CONFIG_SPI_FLASH before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. ====================================================
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com Signed-off-by: Xiaowei Bao xiaowei.bao@nxp.com --- depends on: https://patchwork.ozlabs.org/cover/1146494/ Changes in v6: - Change #ifndef CONFIG_DM_SPI to #if !CONFIG_IS_ENABLED(DM_SPI). Changes in v5: - Modify the function spi_cs_activate to fsl_spi_cs_activate. - Move cs to the parameter of the fsl_spi_cs_activate function. Changes in v4: - Update copyright information. - Move the fsl_espi_platdata data structure to the include/dm/platform_data/. - Merge the contents of the fsl_espi_priv structure into the fsl_spi_slave structure. - Implement the fsl_espi_set_speed function. - Implement the fsl_espi_set_mode function. - Implement the espi_release_bus function. - Remove unwanted fsl_espi_bind functions. - Implement the fsl_espi_child_pre_probe function as needed. - Use #if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA). Changes in v3: - Add a cover-letter for this patch set. Changes in v2: - The fsl_espi driver support both OF_CONTROL and PLATDATA.
drivers/spi/fsl_espi.c | 445 ++++++++++++++++++++++++++---------- drivers/spi/fsl_espi.c | 445 ++++++++++++++++++++++++++---------- include/dm/platform_data/fsl_espi.h | 16 ++ 2 files changed, 337 insertions(+), 124 deletions(-) create mode 100644 include/dm/platform_data/fsl_espi.h
diff --git a/drivers/spi/fsl_espi.c b/drivers/spi/fsl_espi.c index 7444ae1..fd5ac97 100644 --- a/drivers/spi/fsl_espi.c +++ b/drivers/spi/fsl_espi.c @@ -3,18 +3,25 @@ * eSPI controller driver. * * Copyright 2010-2011 Freescale Semiconductor, Inc. + * Copyright 2019 NXP * Author: Mingkai Hu (Mingkai.hu@freescale.com) + * Chuanhua Han (chuanhua.han@nxp.com) */
#include <common.h> - #include <malloc.h> #include <spi.h> #include <asm/immap_85xx.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <dm/platform_data/fsl_espi.h>
struct fsl_spi_slave { struct spi_slave slave; ccsr_espi_t *espi; + u32 speed_hz; + unsigned int cs; unsigned int div16; unsigned int pm; int tx_timeout; @@ -28,6 +35,9 @@ struct fsl_spi_slave { #define to_fsl_spi_slave(s) container_of(s, struct fsl_spi_slave, slave) #define US_PER_SECOND 1000000UL
+/* default SCK frequency, unit: HZ */ +#define FSL_ESPI_DEFAULT_SCK_FREQ 10000000 + #define ESPI_MAX_CS_NUM 4 #define ESPI_FIFO_WIDTH_BIT 32
@@ -62,116 +72,27 @@ struct fsl_spi_slave {
#define ESPI_MAX_DATA_TRANSFER_LEN 0xFFF0
-struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct fsl_spi_slave *fsl; - sys_info_t sysinfo; - unsigned long spibrg = 0; - unsigned long spi_freq = 0; - unsigned char pm = 0; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - fsl = spi_alloc_slave(struct fsl_spi_slave, bus, cs); - if (!fsl) - return NULL; - - fsl->espi = (void *)(CONFIG_SYS_MPC85xx_ESPI_ADDR); - fsl->mode = mode; - fsl->max_transfer_length = ESPI_MAX_DATA_TRANSFER_LEN; - - /* Set eSPI BRG clock source */ - get_sys_info(&sysinfo); - spibrg = sysinfo.freq_systembus / 2; - fsl->div16 = 0; - if ((spibrg / max_hz) > 32) { - fsl->div16 = ESPI_CSMODE_DIV16; - pm = spibrg / (max_hz * 16 * 2); - if (pm > 16) { - pm = 16; - debug("Requested speed is too low: %d Hz, %ld Hz " - "is used.\n", max_hz, spibrg / (32 * 16)); - } - } else - pm = spibrg / (max_hz * 2); - if (pm) - pm--; - fsl->pm = pm; - - if (fsl->div16) - spi_freq = spibrg / ((pm + 1) * 2 * 16); - else - spi_freq = spibrg / ((pm + 1) * 2); - - /* set tx_timeout to 10 times of one espi FIFO entry go out */ - fsl->tx_timeout = DIV_ROUND_UP((US_PER_SECOND * ESPI_FIFO_WIDTH_BIT - * 10), spi_freq); - - return &fsl->slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); - free(fsl); -} - -int spi_claim_bus(struct spi_slave *slave) +void fsl_spi_cs_activate(struct spi_slave *slave, uint cs) { struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); ccsr_espi_t *espi = fsl->espi; - unsigned char pm = fsl->pm; - unsigned int cs = slave->cs; - unsigned int mode = fsl->mode; - unsigned int div16 = fsl->div16; - int i; - - debug("%s: bus:%i cs:%i\n", __func__, slave->bus, cs); - - /* Enable eSPI interface */ - out_be32(&espi->mode, ESPI_MODE_RXTHR(3) - | ESPI_MODE_TXTHR(4) | ESPI_MODE_EN); - - out_be32(&espi->event, 0xffffffff); /* Clear all eSPI events */ - out_be32(&espi->mask, 0x00000000); /* Mask all eSPI interrupts */ - - /* Init CS mode interface */ - for (i = 0; i < ESPI_MAX_CS_NUM; i++) - out_be32(&espi->csmode[i], ESPI_CSMODE_INIT_VAL); - - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) & - ~(ESPI_CSMODE_PM(0xF) | ESPI_CSMODE_DIV16 - | ESPI_CSMODE_CI_INACTIVEHIGH | ESPI_CSMODE_CP_BEGIN_EDGCLK - | ESPI_CSMODE_REV_MSB_FIRST | ESPI_CSMODE_LEN(0xF))); - - /* Set eSPI BRG clock source */ - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) - | ESPI_CSMODE_PM(pm) | div16); - - /* Set eSPI mode */ - if (mode & SPI_CPHA) - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) - | ESPI_CSMODE_CP_BEGIN_EDGCLK); - if (mode & SPI_CPOL) - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) - | ESPI_CSMODE_CI_INACTIVEHIGH); - - /* Character bit order: msb first */ - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) - | ESPI_CSMODE_REV_MSB_FIRST); - - /* Character length in bits, between 0x3~0xf, i.e. 4bits~16bits */ - out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) - | ESPI_CSMODE_LEN(7)); + unsigned int com = 0; + size_t data_len = fsl->data_len;
- return 0; + com &= ~(ESPI_COM_CS(0x3) | ESPI_COM_TRANLEN(0xFFFF)); + com |= ESPI_COM_CS(cs); + com |= ESPI_COM_TRANLEN(data_len - 1); + out_be32(&espi->com, com); }
-void spi_release_bus(struct spi_slave *slave) +void fsl_spi_cs_deactivate(struct spi_slave *slave) { + struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); + ccsr_espi_t *espi = fsl->espi;
+ /* clear the RXCNT and TXCNT */ + out_be32(&espi->mode, in_be32(&espi->mode) & (~ESPI_MODE_EN)); + out_be32(&espi->mode, in_be32(&espi->mode) | ESPI_MODE_EN); }
static void fsl_espi_tx(struct fsl_spi_slave *fsl, const void *dout) @@ -204,7 +125,8 @@ static void fsl_espi_tx(struct fsl_spi_slave *fsl, const void *dout) debug("***spi_xfer:...Tx timeout! event = %08x\n", event); }
-static int fsl_espi_rx(struct fsl_spi_slave *fsl, void *din, unsigned int bytes) +static int fsl_espi_rx(struct fsl_spi_slave *fsl, void *din, + unsigned int bytes) { ccsr_espi_t *espi = fsl->espi; unsigned int tmpdin, rx_times; @@ -236,10 +158,17 @@ static int fsl_espi_rx(struct fsl_spi_slave *fsl, void *din, unsigned int bytes) return bytes; }
-int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, - void *data_in, unsigned long flags) +void espi_release_bus(struct fsl_spi_slave *fsl) { - struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); + /* Disable the SPI hardware */ + out_be32(&fsl->espi->mode, + in_be32(&fsl->espi->mode) & (~ESPI_MODE_EN)); +} + +int espi_xfer(struct fsl_spi_slave *fsl, uint cs, unsigned int bitlen, + const void *data_out, void *data_in, unsigned long flags) +{ + struct spi_slave *slave = &fsl->slave; ccsr_espi_t *espi = fsl->espi; unsigned int event, rx_bytes; const void *dout = NULL; @@ -258,13 +187,14 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, max_tran_len = fsl->max_transfer_length; switch (flags) { case SPI_XFER_BEGIN: - cmd_len = fsl->cmd_len = data_len; + cmd_len = data_len; + fsl->cmd_len = cmd_len; memcpy(cmd_buf, data_out, cmd_len); return 0; case 0: case SPI_XFER_END: if (bitlen == 0) { - spi_cs_deactivate(slave); + fsl_spi_cs_deactivate(slave); return 0; } buf_len = 2 * cmd_len + min(data_len, (size_t)max_tran_len); @@ -304,7 +234,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, num_blks = DIV_ROUND_UP(tran_len + cmd_len, 4); num_bytes = (tran_len + cmd_len) % 4; fsl->data_len = tran_len + cmd_len; - spi_cs_activate(slave); + fsl_spi_cs_activate(slave, cs);
/* Clear all eSPI events */ out_be32(&espi->event , 0xffffffff); @@ -347,37 +277,304 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, *(int *)buffer += tran_len; } } - spi_cs_deactivate(slave); + fsl_spi_cs_deactivate(slave); }
free(buffer); return 0; }
+void espi_claim_bus(struct fsl_spi_slave *fsl, unsigned int cs) +{ + ccsr_espi_t *espi = fsl->espi; + unsigned char pm = fsl->pm; + unsigned int mode = fsl->mode; + unsigned int div16 = fsl->div16; + int i; + + /* Enable eSPI interface */ + out_be32(&espi->mode, ESPI_MODE_RXTHR(3) + | ESPI_MODE_TXTHR(4) | ESPI_MODE_EN); + + out_be32(&espi->event, 0xffffffff); /* Clear all eSPI events */ + out_be32(&espi->mask, 0x00000000); /* Mask all eSPI interrupts */ + + /* Init CS mode interface */ + for (i = 0; i < ESPI_MAX_CS_NUM; i++) + out_be32(&espi->csmode[i], ESPI_CSMODE_INIT_VAL); + + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) & + ~(ESPI_CSMODE_PM(0xF) | ESPI_CSMODE_DIV16 + | ESPI_CSMODE_CI_INACTIVEHIGH | ESPI_CSMODE_CP_BEGIN_EDGCLK + | ESPI_CSMODE_REV_MSB_FIRST | ESPI_CSMODE_LEN(0xF))); + + /* Set eSPI BRG clock source */ + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_PM(pm) | div16); + + /* Set eSPI mode */ + if (mode & SPI_CPHA) + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_CP_BEGIN_EDGCLK); + if (mode & SPI_CPOL) + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_CI_INACTIVEHIGH); + + /* Character bit order: msb first */ + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_REV_MSB_FIRST); + + /* Character length in bits, between 0x3~0xf, i.e. 4bits~16bits */ + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_LEN(7)); +} + +void espi_setup_slave(struct fsl_spi_slave *fsl) +{ + unsigned int max_hz; + sys_info_t sysinfo; + unsigned long spibrg = 0; + unsigned long spi_freq = 0; + unsigned char pm = 0; + + max_hz = fsl->speed_hz; + + get_sys_info(&sysinfo); + spibrg = sysinfo.freq_systembus / 2; + fsl->div16 = 0; + if ((spibrg / max_hz) > 32) { + fsl->div16 = ESPI_CSMODE_DIV16; + pm = spibrg / (max_hz * 16 * 2); + if (pm > 16) { + pm = 16; + debug("max_hz is too low: %d Hz, %ld Hz is used.\n", + max_hz, spibrg / (32 * 16)); + } + } else { + pm = spibrg / (max_hz * 2); + } + if (pm) + pm--; + fsl->pm = pm; + + if (fsl->div16) + spi_freq = spibrg / ((pm + 1) * 2 * 16); + else + spi_freq = spibrg / ((pm + 1) * 2); + + /* set tx_timeout to 10 times of one espi FIFO entry go out */ + fsl->tx_timeout = DIV_ROUND_UP((US_PER_SECOND * ESPI_FIFO_WIDTH_BIT + * 10), spi_freq);/* Set eSPI BRG clock source */ +} + +#if !CONFIG_IS_ENABLED(DM_SPI) int spi_cs_is_valid(unsigned int bus, unsigned int cs) { return bus == 0 && cs < ESPI_MAX_CS_NUM; }
-void spi_cs_activate(struct spi_slave *slave) +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct fsl_spi_slave *fsl; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + fsl = spi_alloc_slave(struct fsl_spi_slave, bus, cs); + if (!fsl) + return NULL; + + fsl->espi = (void *)(CONFIG_SYS_MPC85xx_ESPI_ADDR); + fsl->mode = mode; + fsl->max_transfer_length = ESPI_MAX_DATA_TRANSFER_LEN; + fsl->speed_hz = max_hz; + + espi_setup_slave(fsl); + + return &fsl->slave; +} + +void spi_free_slave(struct spi_slave *slave) { struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); - ccsr_espi_t *espi = fsl->espi; - unsigned int com = 0; - size_t data_len = fsl->data_len;
- com &= ~(ESPI_COM_CS(0x3) | ESPI_COM_TRANLEN(0xFFFF)); - com |= ESPI_COM_CS(slave->cs); - com |= ESPI_COM_TRANLEN(data_len - 1); - out_be32(&espi->com, com); + free(fsl); }
-void spi_cs_deactivate(struct spi_slave *slave) +int spi_claim_bus(struct spi_slave *slave) { struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); - ccsr_espi_t *espi = fsl->espi;
- /* clear the RXCNT and TXCNT */ - out_be32(&espi->mode, in_be32(&espi->mode) & (~ESPI_MODE_EN)); - out_be32(&espi->mode, in_be32(&espi->mode) | ESPI_MODE_EN); + espi_claim_bus(fsl, slave->cs); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); + + espi_release_bus(fsl); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct fsl_spi_slave *fsl = (struct fsl_spi_slave *)slave; + + return espi_xfer(fsl, slave->cs, bitlen, dout, din, flags); +} +#else +static void __espi_set_speed(struct fsl_spi_slave *fsl) +{ + espi_setup_slave(fsl); + + /* Set eSPI BRG clock source */ + out_be32(&fsl->espi->csmode[fsl->cs], + in_be32(&fsl->espi->csmode[fsl->cs]) + | ESPI_CSMODE_PM(fsl->pm) | fsl->div16); +} + +static void __espi_set_mode(struct fsl_spi_slave *fsl) +{ + /* Set eSPI mode */ + if (fsl->mode & SPI_CPHA) + out_be32(&fsl->espi->csmode[fsl->cs], + in_be32(&fsl->espi->csmode[fsl->cs]) + | ESPI_CSMODE_CP_BEGIN_EDGCLK); + if (fsl->mode & SPI_CPOL) + out_be32(&fsl->espi->csmode[fsl->cs], + in_be32(&fsl->espi->csmode[fsl->cs]) + | ESPI_CSMODE_CI_INACTIVEHIGH); +} + +static int fsl_espi_claim_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct fsl_spi_slave *fsl = dev_get_priv(bus); + + espi_claim_bus(fsl, fsl->cs); + + return 0; +} + +static int fsl_espi_release_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct fsl_spi_slave *fsl = dev_get_priv(bus); + + espi_release_bus(fsl); + + return 0; +} + +static int fsl_espi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev->parent; + struct fsl_spi_slave *fsl = dev_get_priv(bus); + + return espi_xfer(fsl, fsl->cs, bitlen, dout, din, flags); +} + +static int fsl_espi_set_speed(struct udevice *bus, uint speed) +{ + struct fsl_spi_slave *fsl = dev_get_priv(bus); + + debug("%s speed %u\n", __func__, speed); + fsl->speed_hz = speed; + + __espi_set_speed(fsl); + + return 0; +} + +static int fsl_espi_set_mode(struct udevice *bus, uint mode) +{ + struct fsl_spi_slave *fsl = dev_get_priv(bus); + + debug("%s mode %u\n", __func__, mode); + fsl->mode = mode; + + __espi_set_mode(fsl); + + return 0; } + +static int fsl_espi_child_pre_probe(struct udevice *dev) +{ + struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); + struct udevice *bus = dev->parent; + struct fsl_spi_slave *fsl = dev_get_priv(bus); + + debug("%s cs %u\n", __func__, slave_plat->cs); + fsl->cs = slave_plat->cs; + + return 0; +} + +static int fsl_espi_probe(struct udevice *bus) +{ + struct fsl_espi_platdata *plat = dev_get_platdata(bus); + struct fsl_spi_slave *fsl = dev_get_priv(bus); + + fsl->espi = (ccsr_espi_t *)((u32)plat->regs_addr); + fsl->max_transfer_length = ESPI_MAX_DATA_TRANSFER_LEN; + fsl->speed_hz = plat->speed_hz; + + debug("%s probe done, bus-num %d.\n", bus->name, bus->seq); + + return 0; +} + +static const struct dm_spi_ops fsl_espi_ops = { + .claim_bus = fsl_espi_claim_bus, + .release_bus = fsl_espi_release_bus, + .xfer = fsl_espi_xfer, + .set_speed = fsl_espi_set_speed, + .set_mode = fsl_espi_set_mode, +}; + +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +static int fsl_espi_ofdata_to_platdata(struct udevice *bus) +{ + fdt_addr_t addr; + struct fsl_espi_platdata *plat = bus->platdata; + const void *blob = gd->fdt_blob; + int node = dev_of_offset(bus); + + addr = dev_read_addr(bus); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->regs_addr = lower_32_bits(addr); + plat->speed_hz = fdtdec_get_int(blob, node, "spi-max-frequency", + FSL_ESPI_DEFAULT_SCK_FREQ); + + debug("ESPI: regs=%p, max-frequency=%d\n", + &plat->regs_addr, plat->speed_hz); + + return 0; +} + +static const struct udevice_id fsl_espi_ids[] = { + { .compatible = "fsl,mpc8536-espi" }, + { } +}; +#endif + +U_BOOT_DRIVER(fsl_espi) = { + .name = "fsl_espi", + .id = UCLASS_SPI, +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) + .of_match = fsl_espi_ids, + .ofdata_to_platdata = fsl_espi_ofdata_to_platdata, +#endif + .ops = &fsl_espi_ops, + .platdata_auto_alloc_size = sizeof(struct fsl_espi_platdata), + .priv_auto_alloc_size = sizeof(struct fsl_spi_slave), + .probe = fsl_espi_probe, + .child_pre_probe = fsl_espi_child_pre_probe, +}; +#endif diff --git a/include/dm/platform_data/fsl_espi.h b/include/dm/platform_data/fsl_espi.h new file mode 100644 index 0000000..812933f --- /dev/null +++ b/include/dm/platform_data/fsl_espi.h @@ -0,0 +1,16 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#ifndef __fsl_espi_h +#define __fsl_espi_h + +struct fsl_espi_platdata { + uint flags; + uint speed_hz; + uint num_chipselect; + fdt_addr_t regs_addr; +}; + +#endif /* __fsl_espi_h */
Add espi controller node to support t2080.
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com Signed-off-by: Xiaowei Bao xiaowei.bao@nxp.com --- Changes in v6: - No change. Changes in v5: - No change. Changes in v4: - No change. Changes in v3: - Add a cover-letter for this patch set. Changes in v2: - No change.
arch/powerpc/dts/t2080.dtsi | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/powerpc/dts/t2080.dtsi b/arch/powerpc/dts/t2080.dtsi index 999fa8c..ad82c97 100644 --- a/arch/powerpc/dts/t2080.dtsi +++ b/arch/powerpc/dts/t2080.dtsi @@ -69,6 +69,16 @@ voltage-ranges = <1800 1800 3300 3300>; };
+ espi0: spi@110000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,mpc8536-espi"; + reg = <0x110000 0x1000>; + interrupts = <53 0x2 0 0>; + fsl,espi-num-chipselects = <4>; + status = "disabled"; + }; + usb0: usb@210000 { compatible = "fsl-usb2-mph"; reg = <0x210000 0x1000>;
Add espi slave nodes to support t2080qds.
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com Signed-off-by: Xiaowei Bao xiaowei.bao@nxp.com --- Changes in v6: - No change. Changes in v5: - No change. Changes in v4: - Modify the spi-max-frequency attribute value of the flash@x node of the device tree. Changes in v3: - Add a cover-letter for this patch set. Changes in v2: - No change.
arch/powerpc/dts/t2080qds.dts | 33 +++++++++++++++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/arch/powerpc/dts/t2080qds.dts b/arch/powerpc/dts/t2080qds.dts index 1819a08..f9e786b 100644 --- a/arch/powerpc/dts/t2080qds.dts +++ b/arch/powerpc/dts/t2080qds.dts @@ -14,4 +14,37 @@ #address-cells = <2>; #size-cells = <2>; interrupt-parent = <&mpic>; + + aliases { + spi0 = &espi0; + }; +}; + +&espi0 { + + status = "okay"; + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "micron,n25q128a11", "jedec,spi-nor"; /* 16MB */ + reg = <0>; + spi-max-frequency = <10000000>; + }; + + flash@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "sst,sst25wf040", "jedec,spi-nor"; + reg = <1>; + spi-max-frequency = <10000000>; + }; + + flash@2 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "eon,en25s64", "jedec,spi-nor"; + reg = <2>; + spi-max-frequency = <10000000>; + }; + };
This patch is to enable espi DM for T2080QDS in uboot
configs/T2080QDS_NAND_defconfig | 2 ++ configs/T2080QDS_SDCARD_defconfig | 2 ++ configs/T2080QDS_SECURE_BOOT_defconfig | 2 ++ configs/T2080QDS_SPIFLASH_defconfig | 2 ++ configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 2 ++ configs/T2080QDS_defconfig | 2 ++ 6 files changed, 12 insertions(+)
diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 0db930f..7e33ed2 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -78,3 +78,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index f5cca80..8bedcbf 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -75,3 +75,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index dea8479..5ee298a 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -65,3 +65,5 @@ CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 60539f4..1357382 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -76,3 +76,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index f4bebee..92978f4 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -55,3 +55,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index e22542f..cb5f21f 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -62,3 +62,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y
Dear Jagan,
-----Original Message----- From: Xiaowei Bao xiaowei.bao@nxp.com Sent: Monday, August 26, 2019 2:55 PM To: wd@denx.de; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; jagan@amarulasolutions.com; sjg@chromium.org; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Chuanhua Han chuanhua.han@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; bmeng.cn@gmail.com; u-boot@lists.denx.de Cc: York Sun york.sun@nxp.com; Xiaowei Bao xiaowei.bao@nxp.com Subject: [PATCH v6 1/4] dm: spi: Convert Freescale ESPI driver to driver model
===================== WARNING ====================== This board does not use CONFIG_DM_SPI. Please update the board before v2019.04 for no dm conversion and v2019.07 for partially dm converted drivers. Failure to update can lead to driver/board removal See doc/driver- model/MIGRATION.txt for more info. ==================================================== ===================== WARNING ====================== This board does not use CONFIG_DM_SPI_FLASH. Please update the board to use CONFIG_SPI_FLASH before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. ====================================================
depends on: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatchwo rk.ozlabs.org%2Fcover%2F1146494%2F&data=02%7C01%7Cprabhakar.kus hwaha%40nxp.com%7Ccc2424972d4e4d6835f908d72a08b877%7C686ea1d3bc2 b4c6fa92cd99c5c301635%7C0%7C0%7C637024089250212151&sdata=3Ki9 mrnn9YXWMR0vjoDmeE2eKBIn1RKlgnRC81SZQbU%3D&reserved=0 Changes in v6:
Changes in v4:
structure.
Changes in v2:
Please review this patch-set and provide your comments.
Once reviewed, I will send pull request via mpc85xx tree
--pk
-----Original Message----- From: Prabhakar Kushwaha Sent: 2019年8月26日 23:12 To: Xiaowei Bao xiaowei.bao@nxp.com; wd@denx.de; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; jagan@amarulasolutions.com; sjg@chromium.org; Chuanhua Han chuanhua.han@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; bmeng.cn@gmail.com; u-boot@lists.denx.de Cc: York Sun york.sun@nxp.com; Xiaowei Bao xiaowei.bao@nxp.com Subject: RE: [PATCH v6 1/4] dm: spi: Convert Freescale ESPI driver to driver model
Dear Jagan,
sjg@chromium.org;
board does
board does
depends on: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatc hwo
rk.ozlabs.org%2Fcover%2F1146494%2F&data=02%7C01%7Cprabhakar.k us
hwaha%40nxp.com%7Ccc2424972d4e4d6835f908d72a08b877%7C686ea1d3 bc2
b4c6fa92cd99c5c301635%7C0%7C0%7C637024089250212151&sdata= 3Ki9
Changes in v5:
Changes in v4:
Changes in v2:
Hi Prabhakar and Jagan,
What is the progress, if there are any comments, please let me know, if no comments, please help to merge it, thanks a lot.
Thanks Xiaowei
--pk
Dear Jagan,
sjg@chromium.org;
board does
board does
mrnn9YXWMR0vjoDmeE2eKBIn1RKlgnRC81SZQbU%3D&reserved=0 Changes in v6: - Change #ifndef CONFIG_DM_SPI to #if !CONFIG_IS_ENABLED(DM_SPI). Changes in v5: - Modify the function spi_cs_activate to fsl_spi_cs_activate. - Move cs to the parameter of the fsl_spi_cs_activate function. Changes in v4: - Update copyright information. - Move the fsl_espi_platdata data structure to the include/dm/platform_data/. - Merge the contents of the fsl_espi_priv structure into the fsl_spi_slave structure. - Implement the fsl_espi_set_speed function. - Implement the fsl_espi_set_mode function. - Implement the espi_release_bus function. - Remove unwanted fsl_espi_bind functions. - Implement the fsl_espi_child_pre_probe function as needed. - Use #if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA). Changes in v3: - Add a cover-letter for this patch set. Changes in v2: - The fsl_espi driver support both OF_CONTROL and PLATDATA.
I marked my r-b tag, and Prabhakar would take this via his tree (as he mentioned)
-----Original Message----- From: Jagan Teki jagan@amarulasolutions.com Sent: 2019年9月9日 14:07 To: Xiaowei Bao xiaowei.bao@nxp.com Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; wd@denx.de; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; sjg@chromium.org; Chuanhua Han chuanhua.han@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; bmeng.cn@gmail.com; u-boot@lists.denx.de; York Sun york.sun@nxp.com; Jiafei Pan jiafei.pan@nxp.com Subject: Re: [PATCH v6 1/4] dm: spi: Convert Freescale ESPI driver to driver model
Dear Jagan,
sjg@chromium.org;
board does
board does
depends on: https://patc hwo
us
bc2
3Ki9
Hi Jagan, thanks a lot.
-----Original Message----- From: Jagan Teki jagan@amarulasolutions.com Sent: Monday, September 9, 2019 11:37 AM To: Xiaowei Bao xiaowei.bao@nxp.com Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; wd@denx.de; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; sjg@chromium.org; Chuanhua Han chuanhua.han@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; bmeng.cn@gmail.com; u-boot@lists.denx.de; York Sun york.sun@nxp.com; Jiafei Pan jiafei.pan@nxp.com Subject: Re: [PATCH v6 1/4] dm: spi: Convert Freescale ESPI driver to driver model
Dear Jagan,
sjg@chromium.org;
board does
board does
us
Thanks Jagan..
We will pull it via our tree
--pk
On Mon, Sep 9, 2019 at 1:13 PM Prabhakar Kushwaha prabhakar.kushwaha@nxp.com wrote:
Dear Jagan,
sjg@chromium.org;
board does
board does
us
Thanks Jagan..
Hope it for next release, true?
-----Original Message----- From: Jagan Teki jagan@amarulasolutions.com Sent: Friday, September 13, 2019 7:58 AM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: Xiaowei Bao xiaowei.bao@nxp.com; Priyanka Jain priyanka.jain@nxp.com; wd@denx.de; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; sjg@chromium.org; Chuanhua Han chuanhua.han@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; bmeng.cn@gmail.com; u- boot@lists.denx.de; York Sun york.sun@nxp.com; Jiafei Pan jiafei.pan@nxp.com Subject: Re: [PATCH v6 1/4] dm: spi: Convert Freescale ESPI driver to driver model
wd@denx.de;
Liu
Dear Jagan,
Ruchika
sjg@chromium.org;
Chuanhua Han
board does
v2019.04
drivers.
board does
rk.ozlabs.org%2Fcover%2F1146494%2F&data=02%7C01%7Cprabhaka r.k
us
hwaha%40nxp.com%7Ccc2424972d4e4d6835f908d72a08b877%7C686ea1 d3
bc2
b4c6fa92cd99c5c301635%7C0%7C0%7C637024089250212151&sdat a=
3Ki9
Thanks Jagan..
It may not be possible as this patch has dependency on https://patchwork.ozlabs.org/cover/1146494/
Patch mentioned is under review/rework phase.
--pk
-----Original Message----- From: Prabhakar Kushwaha Sent: 2019年9月13日 14:56 To: Jagan Teki jagan@amarulasolutions.com Cc: Xiaowei Bao xiaowei.bao@nxp.com; Priyanka Jain priyanka.jain@nxp.com; wd@denx.de; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; sjg@chromium.org; Chuanhua Han chuanhua.han@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; bmeng.cn@gmail.com; u-boot@lists.denx.de; York Sun york.sun@nxp.com; Jiafei Pan jiafei.pan@nxp.com Subject: RE: [PATCH v6 1/4] dm: spi: Convert Freescale ESPI driver to driver model
Gediya
wd@denx.de;
Liu
Dear Jagan,
> -----Original Message----- > From: Xiaowei Bao xiaowei.bao@nxp.com > Sent: Monday, August 26, 2019 2:55 PM > To: wd@denx.de; Shengzhou Liu shengzhou.liu@nxp.com;
Ruchika
> Gupta ruchika.gupta@nxp.com; jagan@amarulasolutions.com; sjg@chromium.org; > Prabhakar Kushwaha prabhakar.kushwaha@nxp.com;
Chuanhua Han
> chuanhua.han@nxp.com; Jagdish Gediya > jagdish.gediya@nxp.com; bmeng.cn@gmail.com; > u-boot@lists.denx.de > Cc: York Sun york.sun@nxp.com; Xiaowei Bao > xiaowei.bao@nxp.com > Subject: [PATCH v6 1/4] dm: spi: Convert Freescale ESPI > driver to driver model > > From: Chuanhua Han chuanhua.han@nxp.com > > Modify the Freescale ESPI driver to support the driver model. > Also resolved the following problems: > > ===================== WARNING
board does > not use CONFIG_DM_SPI. Please update the board before
v2019.04
drivers.
> Failure to update can lead to driver/board removal See > doc/driver- model/MIGRATION.txt for more info. >
board does > not use CONFIG_DM_SPI_FLASH. Please update the board to use > CONFIG_SPI_FLASH before the v2019.07 release. > Failure to update by the deadline may result in board removal. > See doc/driver-model/MIGRATION.txt for more info. >
> > Signed-off-by: Chuanhua Han chuanhua.han@nxp.com > Signed-off-by: Xiaowei Bao xiaowei.bao@nxp.com > --- > depends on: > https://patc > hwo >
us >
bc2 >
3Ki9 >
> Changes in v6: > - Change #ifndef CONFIG_DM_SPI to #if
> Changes in v5: > - Modify the function spi_cs_activate to fsl_spi_cs_activate. > - Move cs to the parameter of the fsl_spi_cs_activate
function.
> Changes in v4: > - Update copyright information. > - Move the fsl_espi_platdata data structure to the > include/dm/platform_data/. > - Merge the contents of the fsl_espi_priv structure into > the fsl_spi_slave structure. > - Implement the fsl_espi_set_speed function. > - Implement the fsl_espi_set_mode function. > - Implement the espi_release_bus function. > - Remove unwanted fsl_espi_bind functions. > - Implement the fsl_espi_child_pre_probe function as
needed.
> - Use #if CONFIG_IS_ENABLED(OF_CONTROL) && > !CONFIG_IS_ENABLED(OF_PLATDATA). > Changes in v3: > - Add a cover-letter for this patch set. > Changes in v2: > - The fsl_espi driver support both OF_CONTROL and
PLATDATA.
> > drivers/spi/fsl_espi.c | 445 ++++++++++++++++++++++++++---------- > drivers/spi/fsl_espi.c | 445 ++++++++++++++++++++++++++---------- > include/dm/platform_data/fsl_espi.h | 16 ++ > 2 files changed, 337 insertions(+), 124 deletions(-) > create mode > 100644
Thanks Jagan..
I don't know how to do, if there are any issue need me to fix, please let me know.
Thanks Xiaowei
--pk
-----Original Message----- From: Xiaowei Bao xiaowei.bao@nxp.com Sent: Saturday, September 14, 2019 12:15 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Jagan Teki jagan@amarulasolutions.com Cc: Priyanka Jain priyanka.jain@nxp.com; wd@denx.de; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; sjg@chromium.org; Chuanhua Han chuanhua.han@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; bmeng.cn@gmail.com; u- boot@lists.denx.de; York Sun york.sun@nxp.com; Jiafei Pan jiafei.pan@nxp.com Subject: RE: [PATCH v6 1/4] dm: spi: Convert Freescale ESPI driver to driver model
<snip> There has been many changes in SPI driver now. Please help to rebase and resend the series.
Regards Priyanka
Jagan Teki
Prabhakar Kushwaha
Priyanka Jain
Xiaowei Bao
