[PATCH v3 0/3] Support SDMA mode on RPI4 target - 32bit
RPI4's SDHCI controller is supported SDMA mode. (Checked on kernel side) But It doesn't use on u-boot side. Then it's too slow about read/write performance. This patchset is supported SDMA mode on RPI4 target(32bit). - I didn't test on RPI4 64bit.
Read/write time about 8MB file Before - Read : 1.472 seconds - Write : 4.690 seconds After - Read : 0.359 seconds - Write : 0.574 seconds
This patch is based on my RFC's patches.RPI4's SDHCI controller is supported SDMA mode. (Checked on kernel side) But It doesn't use on u-boot side. Then it's too slow about read/write performance. This patchset is supported SDMA mode on RPI4 target(32bit). - I didn't test on RPI4 64bit.
Changelog on V3 - Rebased on latest u-boot-mmc
Changelog on V2 - Keep printf message instead of debug - Add Peng's Reviewed-by tag
Jaehoon Chung (3): mmc: sdhci: use phys2bus macro when dma address is accessed mmc: sdhci: not return error when SDMA is not supported configs: rpi_4_32b_defconfig: enable SDHCI_SDMA config
configs/rpi_4_32b_defconfig | 1 + drivers/mmc/sdhci.c | 13 +++++++------ 2 files changed, 8 insertions(+), 6 deletions(-)
Use phys2bus macro when dma address is accessed. Some targets need to use pyhs2bus macro. (e.g, RPI4) After applied it, SDMA mode can be used.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Minkyu Kang mk7.kang@samsung.com --- drivers/mmc/sdhci.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 520c9f9feb..2b7493fbac 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -16,6 +16,7 @@ #include <sdhci.h> #include <dm.h> #include <linux/dma-mapping.h> +#include <phys2bus.h>
static void sdhci_reset(struct sdhci_host *host, u8 mask) { @@ -150,7 +151,8 @@ static void sdhci_prepare_dma(struct sdhci_host *host, struct mmc_data *data, mmc_get_dma_dir(data));
if (host->flags & USE_SDMA) { - sdhci_writel(host, host->start_addr, SDHCI_DMA_ADDRESS); + sdhci_writel(host, phys_to_bus((ulong)host->start_addr), + SDHCI_DMA_ADDRESS); } else if (host->flags & (USE_ADMA | USE_ADMA64)) { sdhci_prepare_adma_table(host, data);
@@ -204,7 +206,7 @@ static int sdhci_transfer_data(struct sdhci_host *host, struct mmc_data *data) start_addr &= ~(SDHCI_DEFAULT_BOUNDARY_SIZE - 1); start_addr += SDHCI_DEFAULT_BOUNDARY_SIZE; - sdhci_writel(host, start_addr, + sdhci_writel(host, phys_to_bus((ulong)start_addr), SDHCI_DMA_ADDRESS); } }
If Host controller doesn't support SDMA, it doesn't need to return error. Because it can be worked with PIO mode.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Minkyu Kang mk7.kang@samsung.com --- drivers/mmc/sdhci.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 2b7493fbac..49e67fc7bd 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -741,13 +741,12 @@ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, debug("%s, caps: 0x%x\n", __func__, caps);
#ifdef CONFIG_MMC_SDHCI_SDMA - if (!(caps & SDHCI_CAN_DO_SDMA)) { + if ((caps & SDHCI_CAN_DO_SDMA)) { + host->flags |= USE_SDMA; + } else { printf("%s: Your controller doesn't support SDMA!!\n", __func__); - return -EINVAL; } - - host->flags |= USE_SDMA; #endif #if CONFIG_IS_ENABLED(MMC_SDHCI_ADMA) if (!(caps & SDHCI_CAN_DO_ADMA2)) {
Enable SDHCI_SDMA configuration.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Minkyu Kang mk7.kang@samsung.com --- configs/rpi_4_32b_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index 72cda5d949..7189914606 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -25,6 +25,7 @@ CONFIG_DFU_MMC=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_BCM2835=y CONFIG_DM_ETH=y CONFIG_BCMGENET=y
RPi4 can only do DMA transfers to the first GiB of memory. I wasn't sucessfull in understanding the mmc/sdhci code to see where we take the dma-ranges property into account so that we don't use an address > 1 GiB.
Are we safe in this regard? If we are, then we can also enable this for rpi_4_defconfig and rpi_arm64_defconfig I think.
Regards, Matthias
Sorry i don't understand clearly what you said.
I checked rpi_arm64_defconfig history. it's unified config for RPi3/RPI4. As i know, RPi3 doesn't support SDMA mode. So i don't have a plan to apply rpi_arm64_defconfig. (If i understood wrong, let me know,plz.)
I have tested SDMA mode With rpi_4_defconfig / rpi_4_32b_defconfig. Test Environment - Target : RPI4 (1G/2G/4G) target - config : rpi_4_defconfig / rpi_4_32b_defconfig
Read/write some files from Sd-card. Read/write performance is increased than before.
I will resend with rpi_4_defconfig, except rpi_arm64_defconfig.
Best Regards, Jaehoon Chung
Regards, Matthias
I'll try to rephrase: How do we make sure that DMA uses only addresses the in the first GiB of RAM for it's transactions. That a limitation the RPi4 has.
Yes, well we have two different device tree compatibles for them. We have to change the driver to make sure only sdhci of RPi4 does enable SDMA.
Regards, Matthias
Regards, Matthias
Jaehoon Chung
Matthias Brugger
