[U-Boot] [PATCH] include/version.h: workaround sysroot inc order
On some systems the host system or even the cross sysroot can contain a version.h. This leads to the wrong file being picked up and a PLAIN_VERSION undefined error.
This workaround symlinks the version.h into the tool folder to allow reordering of search folders.
Fixes http://autobuild.buildroot.net/results/770/7702d5df36a6532aafdbe6e9e62709bbf... http://autobuild.buildroot.net/results/e34/e3401027d2fb3ce565ca9e2456a427afd... ... additional can be found with these queries ... http://autobuild.buildroot.net/?reason=uboot-tools-2018.03 http://autobuild.buildroot.net/?reason=uboot-tools-2018.05
Upstream: pending
Signed-off-by: Matthew Weber matthew.weber@rockwellcollins.com --- tools/env/Makefile | 3 ++- tools/version.h | 1 + 2 files changed, 3 insertions(+), 1 deletion(-) create mode 120000 tools/version.h
diff --git a/tools/env/Makefile b/tools/env/Makefile index 95a03c9..865fbc3 100644 --- a/tools/env/Makefile +++ b/tools/env/Makefile @@ -11,7 +11,8 @@ override HOSTCC = $(CC)
# Compile for a hosted environment on the target -HOST_EXTRACFLAGS = $(patsubst -I%,-idirafter%, $(filter -I%, $(UBOOTINCLUDE))) \ +HOST_EXTRACFLAGS = -I$(srctree)/tools \ + $(patsubst -I%,-idirafter%, $(filter -I%, $(UBOOTINCLUDE))) \ -idirafter $(srctree)/tools/env \ -DUSE_HOSTCC \ -DTEXT_BASE=$(TEXT_BASE) diff --git a/tools/version.h b/tools/version.h new file mode 120000 index 0000000..bb57607 --- /dev/null +++ b/tools/version.h @@ -0,0 +1 @@ +../include/version.h \ No newline at end of file
Ed,
On Thu, Jul 26, 2018 at 10:37 PM, Matt Weber matthew.weber@rockwellcollins.com wrote:
Should also resolve. https://lists.denx.de/pipermail/u-boot/2018-May/330090.html
Matt
Ed (really CCd this time),
On Thu, Jul 26, 2018 at 10:52 PM, Matthew Weber matthew.weber@rockwellcollins.com wrote:
Ed,
Matt
Upstream: pending
Matt Weber
Matthew Weber
