[U-Boot] [PATCH] ARM: at91: sama5: change the environment address to 0x6000
As sama5 board has 32k sram size, so the at91bootstrap and spl for sama5 boards is bigger than 16k (0x4000). That will overlap the U-Boot environment. So I move environment to 0x6000. And reduce its size as well.
Signed-off-by: Josh Wu josh.wu@atmel.com ---
include/configs/at91-sama5_common.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index a5990ce..0b60f0b 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -98,8 +98,8 @@ #elif CONFIG_SYS_USE_SERIALFLASH /* u-boot env in serial flash, by default is bus 0 and cs 0 */ #define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_OFFSET 0x4000 -#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_OFFSET 0x6000 +#define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x1000 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x21000000 0x60000 0xc000; " \
Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com
Hi Josh,
Just curious about from which commit the spl binary size bigger than 16k?
Best Regards, Bo Shen
Hi, Bo
On 10/26/2015 2:43 PM, Bo Shen wrote:
Hi Josh,
From a rough test, I found v2015.07 have spls which is bigger than 16k. but in v2015.04 all are smaller than 16k (very close).
➜ temp cd v2015.04 ➜ v2015.04 ls *spi*spl.bin -l -rwxrwxr-x 1 josh josh 15540 Oct 26 15:38 at91sam9n12ek_spiflash_defconfig_u-boot-spl.bin -rwxrwxr-x 1 josh josh 15704 Oct 26 15:38 at91sam9x5ek_spiflash_defconfig_u-boot-spl.bin -rwxrwxr-x 1 josh josh 16064 Oct 26 15:34 sama5d3xek_spiflash_defconfig_u-boot-spl.bin -rwxrwxr-x 1 josh josh 16304 Oct 26 15:35 sama5d4ek_spiflash_defconfig_u-boot-spl.bin -rwxrwxr-x 1 josh josh 16304 Oct 26 15:37 sama5d4_xplained_spiflash_defconfig_u-boot-spl.bin ➜ v2015.04 cd ../v2015.07 ➜ v2015.07 ls *spi*spl.bin -l -rwxrwxr-x 1 josh josh 16136 Oct 26 15:30 at91sam9n12ek_spiflash_defconfig_u-boot-spl.bin -rwxrwxr-x 1 josh josh 16300 Oct 26 15:30 at91sam9x5ek_spiflash_defconfig_u-boot-spl.bin -rwxrwxr-x 1 josh josh 16664 Oct 26 15:25 sama5d3xek_spiflash_defconfig_u-boot-spl.bin -rwxrwxr-x 1 josh josh 16904 Oct 26 15:26 sama5d4ek_spiflash_defconfig_u-boot-spl.bin -rwxrwxr-x 1 josh josh 16904 Oct 26 15:28 sama5d4_xplained_spiflash_defconfig_u-boot-spl.bin
But I am not sure which exact commit cause the size changes. Or maybe many commits increase size little be little.
Best Regards, Josh Wu
Hi Josh,
On 10/26/2015 16:41 PM, Josh Wu wrote:
Hi, Bo
Hi Josh,
Thanks for these information. So, I regard this patch as a fix. If this information can be added into commit message I think that will be better.
Acked-by: Bo Shen voice.shen@gmail.com
On 10/27/2015 9:55 AM, Bo Shen wrote:
Hi Josh,
Hi, Bo
Hi Josh,
Thanks, Bo. Indeed, I will generate a v2 and add such information.
Andreas Bießmann
Bo Shen
Josh Wu
