[U-Boot] [PATCH 2/3] Add EP93XX ethernet driver
Added ethernet driver for EP93XX SoCs
Signed-off-by: Matthias Kaehlcke matthias@kaehlcke.net --- drivers/net/Makefile | 1 + drivers/net/ep93xx.c | 677 ++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/ep93xx.h | 153 ++++++++++++ include/common.h | 10 +- 4 files changed, 840 insertions(+), 1 deletions(-) create mode 100644 drivers/net/ep93xx.c create mode 100644 drivers/net/ep93xx.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 904727e..0694133 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -37,6 +37,7 @@ COBJS-$(CONFIG_DNET) += dnet.o COBJS-$(CONFIG_E1000) += e1000.o COBJS-$(CONFIG_EEPRO100) += eepro100.o COBJS-$(CONFIG_ENC28J60) += enc28j60.o +COBJS-$(CONFIG_EP93XX) += ep93xx.o COBJS-$(CONFIG_FEC_MXC) += fec_mxc.o COBJS-$(CONFIG_FSLDMAFEC) += fsl_mcdmafec.o mcfmii.o COBJS-$(CONFIG_FTMAC100) += ftmac100.o diff --git a/drivers/net/ep93xx.c b/drivers/net/ep93xx.c new file mode 100644 index 0000000..1eb48ca --- /dev/null +++ b/drivers/net/ep93xx.c @@ -0,0 +1,677 @@ +/* + * Cirrus Logic EP93xx ethernet MAC / MII driver. + * + * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net + * + * Copyright (C) 2004, 2005 + * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com + * + * Based on the original eth.[ch] Cirrus Logic EP93xx Rev D. Ethernet Driver, + * which is + * + * (C) Copyright 2002 2003 + * Adam Bezanson, Network Audio Technologies, Inc. + * bezanson@netaudiotech.com + * + * See file CREDITS for list of people who contributed to this project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY + * or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License + * for more details. + * + * You should have received a copy of the GNU General Public License along + * with this program; if not, write to the Free Software Foundation, Inc., + * 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#include <command.h> +#include <common.h> +#include <asm/arch/ep93xx.h> +#include <asm/io.h> +#include <malloc.h> +#include <miiphy.h> +#include <linux/types.h> +#include "ep93xx.h" + +static int ep93xx_eth_send_packet(struct eth_device *dev, + volatile void * const packet, int const length); +static int ep93xx_eth_rcv_packet(struct eth_device *dev); + +/* ---------------------------------------------------------------------------- + * EP93xx ethernet MAC functionality + */ +#if defined(CONFIG_DRIVER_EP93XX_MAC) + +/* ep93xx_miiphy ops forward declarations */ +static int ep93xx_miiphy_read(char * const dev, unsigned char const addr, + unsigned char const reg, unsigned short * const value); +static int ep93xx_miiphy_write(char * const dev, unsigned char const addr, + unsigned char const reg, unsigned short const value); + +/* Reserve memory for the MAC's private data */ +static struct ep93xx_mac ep93xx_mac = { 0 }; + +#if defined(EP93XX_MAC_DEBUG) +/** + * Dump ep93xx_mac values to the terminal. + */ +inline void dump_dev(void) +{ + int i; + + printf("\ndump_dev()\n"); + printf(" is_initialized %02X\n", ep93xx_mac.is_initialized); + printf(" rx_dq.base %08X\n", ep93xx_mac.rx_dq.base); + printf(" rx_dq.current %08X\n", ep93xx_mac.rx_dq.current); + printf(" rx_dq.end %08X\n", ep93xx_mac.rx_dq.end); + printf(" rx_sq.base %08X\n", ep93xx_mac.rx_sq.base); + printf(" rx_sq.current %08X\n", ep93xx_mac.rx_sq.current); + printf(" rx_sq.end %08X\n", ep93xx_mac.rx_sq.end); + + for (i = 0; i < NUMRXDESC; i++) + printf(" rx_buffer[%2.d] %08X\n", i, NetRxPackets[i]); + + printf(" tx_dq.base %08X\n", ep93xx_mac.tx_dq.base); + printf(" tx_dq.current %08X\n", ep93xx_mac.tx_dq.current); + printf(" tx_dq.end %08X\n", ep93xx_mac.tx_dq.end); + printf(" tx_sq.base %08X\n", ep93xx_mac.tx_sq.base); + printf(" tx_sq.current %08X\n", ep93xx_mac.tx_sq.current); + printf(" tx_sq.end %08X\n", ep93xx_mac.tx_sq.end); +} +#else +#define dump_dev(x) +#endif /* defined(EP93XX_MAC_DEBUG) */ + +#if defined(EP93XX_MAC_DEBUG) +/** + * Dump all RX descriptor queue entries to the terminal. + */ +inline void dump_rx_descriptor_queue(void) +{ + int i; + + printf("\ndump_rx_descriptor_queue()\n"); + printf(" descriptor address word1 word2\n"); + for (i = 0; i < NUMRXDESC; i++) { + printf(" [ %08X ] %08X %08X\n", + (ep93xx_mac.rx_dq.base + i), + (ep93xx_mac.rx_dq.base + i)->word1, + (ep93xx_mac.rx_dq.base + i)->word2); + } +} +#else +#define dump_rx_descriptor_queue() +#endif /* defined(EP93XX_MAC_DEBUG) */ + +#if defined(EP93XX_MAC_DEBUG) +/** + * Dump all RX status queue entries to the terminal. + */ +inline void dump_rx_status_queue(void) +{ + int i; + + printf("\ndump_rx_status_queue()\n"); + printf(" descriptor address word1 word2\n"); + for (i = 0; i < NUMRXDESC; i++) { + printf(" [ %08X ] %08X %08X\n", + (ep93xx_mac.rx_sq.base + i), + (ep93xx_mac.rx_sq.base + i)->word1, + (ep93xx_mac.rx_sq.base + i)->word2); + } +} +#else +#define dump_rx_status_queue() +#endif /* defined(EP93XX_MAC_DEBUG) */ + +#if defined(EP93XX_MAC_DEBUG) +/** + * Dump all TX descriptor queue entries to the terminal. + */ +inline void dump_tx_descriptor_queue(void) +{ + int i; + + printf("\ndump_tx_descriptor_queue()\n"); + printf(" descriptor address word1 word2\n"); + for (i = 0; i < NUMTXDESC; i++) { + printf(" [ %08X ] %08X %08X\n", + (ep93xx_mac.tx_dq.base + i), + (ep93xx_mac.tx_dq.base + i)->word1, + (ep93xx_mac.tx_dq.base + i)->word2); + } +} +#else +#define dump_tx_descriptor_queue() +#endif /* defined(EP93XX_MAC_DEBUG) */ + +#if defined(EP93XX_MAC_DEBUG) +/** + * Dump all TX status queue entries to the terminal. + */ +inline void dump_tx_status_queue(void) +{ + int i; + + printf("\ndump_tx_status_queue()\n"); + printf(" descriptor address word1\n"); + for (i = 0; i < NUMTXDESC; i++) { + printf(" [ %08X ] %08X\n", + (ep93xx_mac.rx_sq.base + i), + (ep93xx_mac.rx_sq.base + i)->word1); + } +} +#else +#define dump_tx_status_queue() +#endif /* defined(EP93XX_MAC_DEBUG) */ + +/** + * Reset the EP93xx MAC by twiddling the soft reset bit and spinning until + * it's cleared. + */ +static void ep93xx_mac_reset(void) +{ + struct mac_regs *mac = (struct mac_regs *)MAC_BASE; + + debug("+ep93xx_mac_reset"); + + uint32_t value = readl(&mac->selfctl); + value |= SELFCTL_RESET; + writel(value, &mac->selfctl); + + while (readl(&mac->selfctl) & SELFCTL_RESET) + ; /* noop */ + + debug("-ep93xx_mac_reset"); +} + +/* Eth device open */ +static int ep93xx_eth_open(struct eth_device *dev, bd_t *bd) +{ + struct mac_regs *mac = (struct mac_regs *)MAC_BASE; + uchar enetaddr[6]; + int i; + + /* Reset the descriptor queues' current and end address values */ + ep93xx_mac.tx_dq.current = ep93xx_mac.tx_dq.base; + ep93xx_mac.tx_dq.end = (ep93xx_mac.tx_dq.base + NUMTXDESC); + + ep93xx_mac.tx_sq.current = ep93xx_mac.tx_sq.base; + ep93xx_mac.tx_sq.end = (ep93xx_mac.tx_sq.base + NUMTXDESC); + + ep93xx_mac.rx_dq.current = ep93xx_mac.rx_dq.base; + ep93xx_mac.rx_dq.end = (ep93xx_mac.rx_dq.base + NUMRXDESC); + + ep93xx_mac.rx_sq.current = ep93xx_mac.rx_sq.base; + ep93xx_mac.rx_sq.end = (ep93xx_mac.rx_sq.base + NUMRXDESC); + + /* + * Set the transmit descriptor and status queues' base address, + * current address, and length registers. Set the maximum frame + * length and threshold. Enable the transmit descriptor processor. + */ + writel((uint32_t)ep93xx_mac.tx_dq.base, &mac->txdq.badd); + writel((uint32_t)ep93xx_mac.tx_dq.base, &mac->txdq.curadd); + writel(sizeof(struct tx_descriptor) * NUMTXDESC, &mac->txdq.blen); + + writel((uint32_t)ep93xx_mac.tx_sq.base, &mac->txstsq.badd); + writel((uint32_t)ep93xx_mac.tx_sq.base, &mac->txstsq.curadd); + writel(sizeof(struct tx_status) * NUMTXDESC, &mac->txstsq.blen); + + writel(0x00040000, &mac->txdthrshld); + writel(0x00040000, &mac->txststhrshld); + + writel((TXSTARTMAX << 0) | (PKTSIZE_ALIGN << 16), &mac->maxfrmlen); + writel(BMCTL_TXEN, &mac->bmctl); + + /* + * Set the receive descriptor and status queues' base address, + * current address, and length registers. Enable the receive + * descriptor processor. + */ + writel((uint32_t)ep93xx_mac.rx_dq.base, &mac->rxdq.badd); + writel((uint32_t)ep93xx_mac.rx_dq.base, &mac->rxdq.curadd); + writel(sizeof(struct rx_descriptor) * NUMRXDESC, &mac->rxdq.blen); + + writel((uint32_t)ep93xx_mac.rx_sq.base, &mac->rxstsq.badd); + writel((uint32_t)ep93xx_mac.rx_sq.base, &mac->rxstsq.curadd); + writel(sizeof(struct rx_status) * NUMRXDESC, &mac->rxstsq.blen); + + writel(0x00040000, &mac->rxdthrshld); + + writel(BMCTL_RXEN, &mac->bmctl); + + writel(0x00040000, &mac->rxststhrshld); + + /* Wait until the receive descriptor processor is active */ + while (!(readl(&mac->bmsts) & BMSTS_RXACT)) + ; /* noop */ + + /* + * Initialize the RX descriptor queue. Clear the TX descriptor queue. + * Clear the RX and TX status queues. Enqueue the RX descriptor and + * status entries to the MAC. + */ + for (i = 0; i < NUMRXDESC; i++) { + /* set buffer address */ + (ep93xx_mac.rx_dq.base + i)->word1 = (uint32_t)NetRxPackets[i]; + + /* set buffer length, clear buffer index and NSOF */ + (ep93xx_mac.rx_dq.base + i)->word2 = PKTSIZE_ALIGN; + } + + memset(ep93xx_mac.tx_dq.base, 0, + (sizeof(struct tx_descriptor) * NUMTXDESC)); + memset(ep93xx_mac.rx_sq.base, 0, + (sizeof(struct rx_status) * NUMRXDESC)); + memset(ep93xx_mac.tx_sq.base, 0, + (sizeof(struct tx_status) * NUMTXDESC)); + + writel(NUMRXDESC, &mac->rxdqenq); + writel(NUMRXDESC, &mac->rxstsqenq); + + /* Set the primary MAC address */ + writel(AFP_IAPRIMARY, &mac->afp); + eth_getenv_enetaddr("ethaddr", enetaddr); + writel(enetaddr[0] | (enetaddr[1] << 8) | + (enetaddr[2] << 16) | (enetaddr[3] << 24), + &mac->indad); + writel(enetaddr[4] | (enetaddr[5] << 8), &mac->indad_upper); + + /* Turn on RX and TX */ + writel(RXCTL_IA0 | RXCTL_BA | RXCTL_SRXON | + RXCTL_RCRCA | RXCTL_MA, &mac->rxctl); + writel(TXCTL_STXON, &mac->txctl); + + /* Dump data structures if we're debugging */ + dump_dev(); + dump_rx_descriptor_queue(); + dump_rx_status_queue(); + dump_tx_descriptor_queue(); + dump_tx_status_queue(); + + return 1; +} + +/** + * Halt EP93xx MAC transmit and receive by clearing the TxCTL and RxCTL + * registers. + */ +static void ep93xx_eth_close(struct eth_device *dev) +{ + struct mac_regs *mac = (struct mac_regs *)MAC_BASE; + + debug("+ep93xx_eth_close"); + + writel(0x00000000, &mac->rxctl); + writel(0x00000000, &mac->txctl); + + debug("-ep93xx_eth_close"); +} + +#if defined(CONFIG_MII) +int ep93xx_miiphy_initialize(bd_t * const bd) +{ + miiphy_register("ep93xx_eth0", ep93xx_miiphy_read, ep93xx_miiphy_write); + return 0; +} +#endif + +/** + * Initialize the EP93xx MAC. The MAC hardware is reset. Buffers are + * allocated, if necessary, for the TX and RX descriptor and status queues, + * as well as for received packets. The EP93XX MAC hardware is initialized. + * Transmit and receive operations are enabled. + */ +int ep93xx_eth_init(bd_t * const bd) +{ + int ret = ETH_STATUS_FAILURE; + struct eth_device *dev; + + debug("+ep93xx_eth_init"); + + /* Parameter check */ + BUG_ON(bd == NULL); + + /* Reset the MAC */ + ep93xx_mac_reset(); + + /* + * Allocate space for the queues and RX packet buffers if we're not + * already initialized + */ + if (!ep93xx_mac.is_initialized) { + ep93xx_mac.tx_dq.base = calloc(NUMTXDESC, + sizeof(struct tx_descriptor)); + if (ep93xx_mac.tx_dq.base == NULL) { + ERROR("calloc() failed"); + goto eth_init_failed_0; + } + + ep93xx_mac.tx_sq.base = calloc(NUMTXDESC, + sizeof(struct tx_status)); + if (ep93xx_mac.tx_sq.base == NULL) { + ERROR("calloc() failed"); + goto eth_init_failed_1; + } + + ep93xx_mac.rx_dq.base = calloc(NUMRXDESC, + sizeof(struct rx_descriptor)); + if (ep93xx_mac.rx_dq.base == NULL) { + ERROR("calloc() failed"); + goto eth_init_failed_2; + } + + ep93xx_mac.rx_sq.base = calloc(NUMRXDESC, + sizeof(struct rx_status)); + if (ep93xx_mac.rx_sq.base == NULL) { + ERROR("calloc() failed"); + goto eth_init_failed_3; + } + + dev = malloc(sizeof *dev); + if (dev == NULL) { + ERROR("malloc() failed"); + goto eth_init_failed_4; + } + + memset(dev, 0, sizeof *dev); + sprintf(dev->name, "ep93xx MAC"); + dev->iobase = 0; + dev->init = ep93xx_eth_open; + dev->halt = ep93xx_eth_close; + dev->send = ep93xx_eth_send_packet; + dev->recv = ep93xx_eth_rcv_packet; + + eth_register(dev); + + /* + * Set is_initialized flag so we don't go through allocation + * portion of init again. + */ + ep93xx_mac.is_initialized = 1; + } + + /* Done! */ + ret = ETH_STATUS_SUCCESS; + goto eth_init_done; + +eth_init_failed_4: + free(ep93xx_mac.rx_sq.base); + /* Fall through */ + +eth_init_failed_3: + free(ep93xx_mac.rx_dq.base); + /* Fall through */ + +eth_init_failed_2: + free(ep93xx_mac.tx_sq.base); + /* Fall through */ + +eth_init_failed_1: + free(ep93xx_mac.tx_dq.base); + /* Fall through */ + +eth_init_failed_0: + /* Fall through */ + +eth_init_done: + debug("-ep93xx_eth_init %d", ret); + return ret; +} + +/** + * Copy a frame of data from the MAC into the protocol layer for further + * processing. + * + * TODO: Enhance this to deal with as many packets as are available at + * the MAC at one time? */ +static int ep93xx_eth_rcv_packet(struct eth_device *dev) +{ + struct mac_regs *mac = (struct mac_regs *)MAC_BASE; + int ret = ETH_STATUS_FAILURE; + + debug("+ep93xx_eth_rcv_packet"); + + if (RX_STATUS_RFP(ep93xx_mac.rx_sq.current)) { + if (RX_STATUS_RWE(ep93xx_mac.rx_sq.current)) { + /* + * We have a good frame. Extract the frame's length + * from the current rx_status_queue entry, and copy + * the frame's data into NetRxPackets[] of the + * protocol stack. We track the total number of + * bytes in the frame (nbytes_frame) which will be + * used when we pass the data off to the protocol + * layer via NetReceive(). + */ + NetReceive((uchar *)ep93xx_mac.rx_dq.current->word1, + RX_STATUS_FRAME_LEN(ep93xx_mac.rx_sq.current)); + debug("reporting %d bytes...\n", + ep93xx_mac.rx_sq.current->frame_length); + + ret = ETH_STATUS_SUCCESS; + + } else { + /* Do we have an erroneous packet? */ + ERROR("packet rx error, status %08X %08X", + ep93xx_mac.rx_sq.current->word1, + ep93xx_mac.rx_sq.current->word2); + dump_rx_descriptor_queue(); + dump_rx_status_queue(); + } + + /* + * Clear the associated status queue entry, and + * increment our current pointers to the next RX + * descriptor and status queue entries (making sure + * we wrap properly). + */ + memset((void *)ep93xx_mac.rx_sq.current, 0, + sizeof(struct rx_status)); + + ep93xx_mac.rx_sq.current++; + if (ep93xx_mac.rx_sq.current >= ep93xx_mac.rx_sq.end) + ep93xx_mac.rx_sq.current = ep93xx_mac.rx_sq.base; + + ep93xx_mac.rx_dq.current++; + if (ep93xx_mac.rx_dq.current >= ep93xx_mac.rx_dq.end) + ep93xx_mac.rx_dq.current = ep93xx_mac.rx_dq.base; + + /* + * Finally, return the RX descriptor and status entries + * back to the MAC engine, and loop again, checking for + * more descriptors to process. + */ + writel(1, &mac->rxdqenq); + writel(1, &mac->rxstsqenq); + } else { + ret = ETH_STATUS_SUCCESS; + } + + debug("-ep93xx_eth_rcv_packet %d", ret); + return ret; +} + +/** + * Send a block of data via ethernet. + * + * TODO: Enhance this to deal with as much data as are available at one time? */ +static int ep93xx_eth_send_packet(struct eth_device *dev, + volatile void * const packet, int const length) +{ + struct mac_regs *mac = (struct mac_regs *)MAC_BASE; + int ret = ETH_STATUS_FAILURE; + + debug("+ep93xx_eth_send_packet"); + + /* Parameter check */ + BUG_ON(packet == NULL); + + /* + * Initialize the TX descriptor queue with the new packet's info. + * Clear the associated status queue entry. Enqueue the packet + * to the MAC for transmission. + */ + + /* set buffer address */ + ep93xx_mac.tx_dq.current->word1 = (uint32_t)packet; + + /* set buffer length and EOF bit */ + ep93xx_mac.tx_dq.current->word2 = length | TX_DESC_EOF; + + /* clear tx status */ + ep93xx_mac.tx_sq.current->word1 = 0; + + /* enqueue the TX descriptor */ + writel(1, &mac->txdqenq); + + /* wait for the frame to become processed */ + while (!TX_STATUS_TXFP(ep93xx_mac.tx_sq.current)) + ; /* noop */ + + if (!TX_STATUS_TXWE(ep93xx_mac.tx_sq.current)) { + ERROR("packet tx error, status %08X", + ep93xx_mac.tx_sq.current->word1); + dump_tx_descriptor_queue(); + dump_tx_status_queue(); + + /* TODO: Add better error handling? */ + goto eth_send_failed_0; + } + + ret = ETH_STATUS_SUCCESS; + /* Fall through */ + +eth_send_failed_0: + debug("-ep93xx_eth_send_packet %d", ret); + return ret; +} +#endif /* defined(CONFIG_DRIVER_EP93XX_MAC) */ + +/* ----------------------------------------------------------------------------- + * EP93xx ethernet MII functionality. + */ +#if defined(CONFIG_MII) + +/** + * Maximum MII address we support + */ +#define MII_ADDRESS_MAX (31) + +/** + * Maximum MII register address we support + */ +#define MII_REGISTER_MAX (31) + +/** + * Ethernet MII interface return values for public functions. + */ +enum mii_status { + MII_STATUS_SUCCESS = 0, + MII_STATUS_FAILURE = 1, +}; + +/** + * Read a 16-bit value from an MII register. + */ +static int ep93xx_miiphy_read(char * const dev, unsigned char const addr, + unsigned char const reg, unsigned short * const value) +{ + struct mac_regs *mac = (struct mac_regs *)MAC_BASE; + int ret = MII_STATUS_FAILURE; + uint32_t self_ctl; + + debug("+ep93xx_miiphy_read"); + + /* Parameter checks */ + BUG_ON(dev == NULL); + BUG_ON(addr > MII_ADDRESS_MAX); + BUG_ON(reg > MII_REGISTER_MAX); + BUG_ON(value == NULL); + + /* + * Save the current SelfCTL register value. Set MAC to suppress + * preamble bits. Wait for any previous MII command to complete + * before issuing the new command. + */ + self_ctl = readl(&mac->selfctl); +#if defined(CONFIG_MII_SUPPRESS_PREAMBLE) + writel(self_ctl & ~(1 << 8), &mac->selfctl); +#endif /* defined(CONFIG_MII_SUPPRESS_PREAMBLE) */ + + while (readl(&mac->miists) & MIISTS_BUSY) + ; /* noop */ + + /* + * Issue the MII 'read' command. Wait for the command to complete. + * Read the MII data value. + */ + writel(MIICMD_OPCODE_READ | ((uint32_t)addr << 5) | (uint32_t)reg, + &mac->miicmd); + while (readl(&mac->miists) & MIISTS_BUSY) + ; /* noop */ + + *value = (unsigned short)readl(&mac->miidata); + + /* Restore the saved SelfCTL value and return. */ + writel(self_ctl, &mac->selfctl); + + ret = MII_STATUS_SUCCESS; + /* Fall through */ + + debug("-ep93xx_miiphy_read"); + return ret; +} + +/** + * Write a 16-bit value to an MII register. + */ +static int ep93xx_miiphy_write(char * const dev, unsigned char const addr, + unsigned char const reg, unsigned short const value) +{ + struct mac_regs *mac = (struct mac_regs *)MAC_BASE; + int ret = MII_STATUS_FAILURE; + uint32_t self_ctl; + + debug("+ep93xx_miiphy_write"); + + /* Parameter checks */ + BUG_ON(dev == NULL); + BUG_ON(addr > MII_ADDRESS_MAX); + BUG_ON(reg > MII_REGISTER_MAX); + + /* + * Save the current SelfCTL register value. Set MAC to suppress + * preamble bits. Wait for any previous MII command to complete + * before issuing the new command. + */ + self_ctl = readl(&mac->selfctl); +#if defined(CONFIG_MII_SUPPRESS_PREAMBLE) + writel(self_ctl & ~(1 << 8), &mac->selfctl); +#endif /* defined(CONFIG_MII_SUPPRESS_PREAMBLE) */ + + while (readl(&mac->miists) & MIISTS_BUSY) + ; /* noop */ + + /* Issue the MII 'write' command. Wait for the command to complete. */ + writel((uint32_t)value, &mac->miidata); + writel(MIICMD_OPCODE_WRITE | ((uint32_t)addr << 5) | (uint32_t)reg, + &mac->miicmd); + while (readl(&mac->miists) & MIISTS_BUSY) + ; /* noop */ + + /* Restore the saved SelfCTL value and return. */ + writel(self_ctl, &mac->selfctl); + + ret = MII_STATUS_SUCCESS; + /* Fall through */ + + debug("-ep93xx_miiphy_write"); + return ret; +} +#endif /* defined(CONFIG_MII) */ diff --git a/drivers/net/ep93xx.h b/drivers/net/ep93xx.h new file mode 100644 index 0000000..79337f1 --- /dev/null +++ b/drivers/net/ep93xx.h @@ -0,0 +1,153 @@ +/* + * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net + * + * Copyright (C) 2004, 2005 + * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#ifndef _ETH_H +#define _ETH_H + +#include <net.h> + +/** + * #define this to dump device status and queue info during initialization and + * following errors. + */ +#undef EP93XX_MAC_DEBUG + +/** + * Number of descriptor and status entries in our RX queues. + * It must be power of 2 ! + */ +#define NUMRXDESC PKTBUFSRX + +/** + * Number of descriptor and status entries in our TX queues. + */ +#define NUMTXDESC 1 + +/** + * 944 = (1024 - 64) - 16, Fifo size - Minframesize - 16 (Chip FACT) + */ +#define TXSTARTMAX 944 + +/** + * Ethernet MAC interface return values for public functions. + */ +enum eth_status { + ETH_STATUS_SUCCESS = 0, + ETH_STATUS_FAILURE = 1, +}; + +/** + * Receive descriptor queue entry + */ +struct rx_descriptor { + uint32_t word1; + uint32_t word2; +} __attribute__((packed)); + +/** + * Receive status queue entry + */ +struct rx_status { + uint32_t word1; + uint32_t word2; +} __attribute__((packed)); + +#define RX_STATUS_RWE(rx_status) ((rx_status->word1 >> 30) & 0x01) +#define RX_STATUS_RFP(rx_status) ((rx_status->word1 >> 31) & 0x01) +#define RX_STATUS_FRAME_LEN(rx_status) (rx_status->word2 & 0xFFFF) + + +/** + * Transmit descriptor queue entry + */ +struct tx_descriptor { + uint32_t word1; + uint32_t word2; +} __attribute__((packed)); + +#define TX_DESC_EOF (1 << 31) + +/** + * Transmit status queue entry + */ +struct tx_status { + uint32_t word1; +} __attribute__((packed)); + +#define TX_STATUS_TXWE(tx_status) (((tx_status)->word1 >> 30) & 0x01) +#define TX_STATUS_TXFP(tx_status) (((tx_status)->word1 >> 31) & 0x01) + +/** + * Transmit descriptor queue + */ +struct tx_descriptor_queue { + struct tx_descriptor *base; + struct tx_descriptor *current; + struct tx_descriptor *end; +}; + +/** + * Transmit status queue + */ +struct tx_status_queue { + struct tx_status *base; + volatile struct tx_status *current; + struct tx_status *end; +}; + +/** + * Receive descriptor queue + */ +struct rx_descriptor_queue { + struct rx_descriptor *base; + struct rx_descriptor *current; + struct rx_descriptor *end; +}; + +/** + * Receive status queue + */ +struct rx_status_queue { + struct rx_status *base; + volatile struct rx_status *current; + struct rx_status *end; +}; + +/** + * EP93xx MAC private data structure + */ +struct ep93xx_mac { + int is_initialized; + + struct rx_descriptor_queue rx_dq; + struct rx_status_queue rx_sq; + void *rx_buffer[NUMRXDESC]; + + struct tx_descriptor_queue tx_dq; + struct tx_status_queue tx_sq; +}; + +#endif diff --git a/include/common.h b/include/common.h index 07897f6..6fecf39 100644 --- a/include/common.h +++ b/include/common.h @@ -123,6 +123,13 @@ typedef volatile unsigned char vu_char; #define debugX(level,fmt,args...) #endif /* DEBUG */
+#ifndef ERROR +#define ERROR(fmt, args...) do { \ + printf("ERROR: " fmt "\nat %s:%d/%s()\n", \ + ##args, __FILE__, __LINE__, __func__); \ +} while (0) +#endif + #ifndef BUG #define BUG() do { \ printf("BUG: failure at %s:%d/%s()!\n", __FILE__, __LINE__, __FUNCTION__); \ @@ -500,7 +507,8 @@ ulong get_PCI_freq (void); #endif #if defined(CONFIG_S3C24X0) || \ defined(CONFIG_LH7A40X) || \ - defined(CONFIG_S3C6400) + defined(CONFIG_S3C6400) || \ + defined(CONFIG_EP93XX) ulong get_FCLK (void); ulong get_HCLK (void); ulong get_PCLK (void);
Matthias Kaehlcke
