[PATCH] armv7m: kconfig adds the NVIC option and masks the GIC option when NVIC is selected
ARMv7-M architecture uses NVIC instead of GIC. NVIC is an interrupt controller specially designed for ARM Cortex-M series processors.
Signed-off-by: Liya Huang 1425075683@qq.com ---
arch/arm/Kconfig | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 314916527c9..c88b3b2aa43 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -108,6 +108,9 @@ config LNX_KRNL_IMG_TEXT_OFFSET_BASE The value subtracted from CONFIG_TEXT_BASE to calculate the TEXT_OFFSET value written to the Linux kernel image header.
+config NVIC + bool + config GICV2 bool
@@ -117,6 +120,7 @@ config GICV3 config DRIVER_GICV2 bool "ARM GICV2 driver" select IRQ + depends on !NVIC help ARM GICV2 driver. Basic support for parsing the GICV2 node and generate ACPI tables. @@ -124,6 +128,7 @@ config DRIVER_GICV2 config GIC_V3_ITS bool "ARM GICV3 ITS" select IRQ + depends on !NVIC help ARM GICV3 Interrupt translation service (ITS). Basic support for programming locality specific peripheral @@ -134,6 +139,7 @@ config GIC_V3_ITS
config GICV3_SUPPORT_GIC600 bool "ARM GICV3 GIC600 SUPPORT" + depends on !NVIC help ARM GIC-600 IP complies with ARM GICv3 architecture, but among others, implements a power control register in the Redistributor frame.This @@ -193,6 +199,7 @@ config SPL_SYS_DCACHE_OFF
config SYS_ARM_CACHE_CP15 bool "CP15 based cache enabling support" + depends on !CPU_V7M help Select this if your processor suports enabling caches by using CP15 registers. @@ -200,6 +207,7 @@ config SYS_ARM_CACHE_CP15 config SYS_ARM_MMU bool "MMU-based Paged Memory Management Support" select SYS_ARM_CACHE_CP15 + depends on !CPU_V7M help Select if you want MMU-based virtualised addressing space support via paged memory management. @@ -350,6 +358,7 @@ config CPU_V7M select SYS_CACHE_SHIFT_5 select SYS_THUMB_BUILD select THUMB2_KERNEL + select NVIC
config CPU_V7R bool
1425075683@qq.com
