[U-Boot] Please pull u-boot-dm
Hi Tom,
Build result at https://travis-ci.org/sglass68/u-boot/builds/519059521
The following changes since commit 02f173ca156cee8526dff87603d5e446b443cde3:
Merge branch 'master' of git://git.denx.de/u-boot-usb (2019-04-11 14:29:37 -0400)
git://git.denx.de/u-boot-dm.git tags/pull-12apr19
for you to fetch changes up to 73c02e5e4fc1ef53d06289232edd6cc52e3d73f6:
fdt: Fix mkimage list to try every header type (2019-04-11 20:10:50 -0600)
---------------------------------------------------------------- fdtdec tests and improvements for carve-outs pinctrl race-condition fix various other fixes in sandbox, sound, mkimage, etc.
---------------------------------------------------------------- Christian Gmeiner (1): dm: sound: make all functions static inline
Christoph Muellner (1): dm: pinctrl: Remove obsolete function pinctrl_decode_pin_config_dm().
Eugeniu Rosca (1): core: ofnode: Fix ASAN-reported stack-buffer-overflow in of_get_address
Jordan Hand (1): fdt: Fix mkimage list to try every header type
Michal Simek (1): dm: Also remove interrupts property from SPL DT
Patrice Chotard (1): dm: pinctrl: Avoid race condition on probe for UCLASS_PINCTRL
Patrick Delaunay (7): dm: remove pre reloc properties in SPL and TPL device tree dm: pinctrl: Skip gpio-controller node in pinconfig_post_bind() syscon: update syscon_regmap_lookup_by_phandle sysreset: use syscon_regmap_lookup_by_phandle clk: at91: replace dm_fdt_pre_reloc by dm_ofnode_pre_reloc clk: socfpga: replace dm_fdt_pre_reloc by dm_ofnode_pre_reloc dm: remove unused function dm_fdt_pre_reloc
Simon Glass (1): cros: Expand the Chromium OS documentation
Thierry Reding (15): fdt: Remove duplicate code vsprintf: Support phys_addr_t specifier unconditionally sandbox: Use correct phys_{addr, size}_t for PHYS_64BIT=y sandbox: Properly print physical addresses libfdt: Add phandle generation helper fdtdec: Add cpu_to_fdt_{addr, size}() macros fdtdec: Add fdt_{addr, size}_unpack() helpers fdtdec: Implement fdtdec_set_phandle() fdtdec: Implement fdtdec_add_reserved_memory() fdtdec: Implement carveout support functions fdtdec: Add Kconfig symbol for tests fdtdec: test: Fix build warning fdtdec: test: Use compound statement macros fdtdec: test: Add carveout tests sandbox: Enable fdtdec tests
.../devicetree/bindings/reserved-memory/reserved-memory.txt | 136 ++++++++++++++ arch/sandbox/dts/test.dts | 3 +- arch/sandbox/include/asm/sdl.h | 4 +- arch/sandbox/include/asm/types.h | 12 +- arch/sandbox/lib/pci_io.c | 2 +- common/fdt_support.c | 6 - configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + doc/README.chromium | 296 ++++++++++++------------------ doc/README.chromium-chainload | 239 ++++++++++++++++++++++++ drivers/clk/altera/clk-arria10.c | 3 +- drivers/clk/at91/pmc.c | 2 +- drivers/core/ofnode.c | 21 +-- drivers/core/syscon-uclass.c | 83 ++++++--- drivers/core/util.c | 40 +--- drivers/pinctrl/pinctrl-uclass.c | 36 +--- drivers/sysreset/sysreset_syscon.c | 15 +- dts/Kconfig | 8 +- include/dm/pinctrl.h | 12 -- include/dm/util.h | 26 --- include/fdtdec.h | 169 +++++++++++++++++ lib/Kconfig | 4 + lib/fdtdec.c | 225 +++++++++++++++++++++++ lib/fdtdec_test.c | 216 +++++++++++++++++----- lib/libfdt/fdt_ro.c | 31 ++++ lib/vsprintf.c | 2 +- scripts/Makefile.lib | 1 + scripts/dtc/libfdt/fdt_ro.c | 31 ++++ scripts/dtc/libfdt/libfdt.h | 19 ++ scripts/dtc/libfdt/libfdt_env.h | 1 + test/dm/syscon.c | 7 + tools/mkimage.c | 23 ++- 32 files changed, 1280 insertions(+), 395 deletions(-) create mode 100644 Documentation/devicetree/bindings/reserved-memory/reserved-memory.txt create mode 100644 doc/README.chromium-chainload
On Fri, Apr 12, 2019 at 03:51:52PM -0600, Simon Glass wrote:
Hi Tom,
