[U-Boot] [PATCH v3 0/5] ARM: refactor start.S files
This series aims at refactoring start.S files. Some of these files contain cache-related or cpu-reset-related core, which is moved where it belongs. Useless symbols are removed, and finally, exception vector code, common across all ARM CPUs, is moved in its own file.
At this point, the start.S files only contain CPU-specific reset sequences.
Changes in v3: - factorized SPL/non-SPL code - fixed socfpga_cyclone5 IRQ setting in save_boot_params
Changes in v2: - fixed checkpatch issues in arch/arm/cpu/arm946es/cpu.c - fixed checkpatch issues in arch/arm/cpu/sa1100/cpu.c - rebased onto u-boot-arm/master (de4fdfc1) - adjusted comment in Zynq linker script
Albert ARIBAUD (5): arm1136: move cache code from start.S to cache.c arm: move reset_cpu from start.S into cpu.c arm: pxa: move SP check from start.S to cpuinfo.c arm: remove unused _end_vect and _vectors_end symbols arm: move exception handling out of start.S files
arch/arm/cpu/arm1136/start.S | 254 +----------------------- arch/arm/cpu/arm1176/start.S | 198 +------------------ arch/arm/cpu/arm720t/start.S | 229 +--------------------- arch/arm/cpu/arm920t/ep93xx/u-boot.lds | 3 +- arch/arm/cpu/arm920t/start.S | 216 +-------------------- arch/arm/cpu/arm926ejs/mxs/start.S | 92 +-------- arch/arm/cpu/arm926ejs/spear/start.S | 27 +-- arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds | 1 + arch/arm/cpu/arm926ejs/start.S | 262 +------------------------ arch/arm/cpu/arm946es/cpu.c | 13 ++ arch/arm/cpu/arm946es/start.S | 246 +---------------------- arch/arm/cpu/arm_intcm/start.S | 228 +--------------------- arch/arm/cpu/armv7/socfpga/lowlevel_init.S | 15 +- arch/arm/cpu/armv7/start.S | 253 +----------------------- arch/arm/cpu/armv7/zynq/u-boot.lds | 2 +- arch/arm/cpu/pxa/cpuinfo.c | 6 + arch/arm/cpu/pxa/start.S | 253 +----------------------- arch/arm/cpu/sa1100/cpu.c | 14 ++ arch/arm/cpu/sa1100/start.S | 225 +-------------------- arch/arm/cpu/u-boot-spl.lds | 1 + arch/arm/cpu/u-boot.lds | 1 + arch/arm/lib/Makefile | 2 +- arch/arm/lib/cache.c | 13 +- arch/arm/lib/vectors.S | 291 ++++++++++++++++++++++++++++ board/compulab/cm_t335/u-boot.lds | 1 + board/freescale/mx31ads/u-boot.lds | 1 + board/ti/am335x/u-boot.lds | 1 + 27 files changed, 359 insertions(+), 2489 deletions(-) create mode 100644 arch/arm/lib/vectors.S
arch/arm/cpu/arm1136/start.S contain a cache flushing function. Remove the function and move its code into arch/arm/lib/cache.c.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net ---
arch/arm/cpu/arm1136/start.S | 10 ---------- arch/arm/lib/cache.c | 13 ++++++++++--- 2 files changed, 10 insertions(+), 13 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 3e2358e..0085754 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -333,14 +333,4 @@ fiq: bl do_fiq
#endif - .align 5 -.global arm1136_cache_flush -arm1136_cache_flush: -#if !defined(CONFIG_SYS_ICACHE_OFF) - mcr p15, 0, r1, c7, c5, 0 @ invalidate I cache -#endif -#if !defined(CONFIG_SYS_DCACHE_OFF) - mcr p15, 0, r1, c7, c14, 0 @ invalidate D cache -#endif - mov pc, lr @ back to caller #endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index 6cc136a..4f6b9f0 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -12,16 +12,23 @@ void __flush_cache(unsigned long start, unsigned long size) { #if defined(CONFIG_ARM1136) - void arm1136_cache_flush(void);
- arm1136_cache_flush(); +#if !defined(CONFIG_SYS_ICACHE_OFF) + asm("mcr p15, 0, r1, c7, c5, 0"); /* invalidate I cache */ #endif + +#if !defined(CONFIG_SYS_DCACHE_OFF) + asm("mcr p15, 0, r1, c7, c14, 0"); /* Clean+invalidate D cache */ +#endif + +#endif /* CONFIG_ARM1136 */ + #ifdef CONFIG_ARM926EJS /* test and clean, page 2-23 of arm926ejs manual */ asm("0: mrc p15, 0, r15, c7, c10, 3\n\t" "bne 0b\n" : : : "memory"); /* disable write buffer as well (page 2-22) */ asm("mcr p15, 0, %0, c7, c10, 4" : : "r" (0)); -#endif +#endif /* CONFIG_ARM926EJS */ return; } void flush_cache(unsigned long start, unsigned long size)
CPUs arm946es and sa1100 both define the reset_cpu() function in their start.S file. Move this cpu-specific code into cpu.c so that start.S only contains ARM generic code.
Changes in v3: None Changes in v2: - fixed checkpatch issues in arch/arm/cpu/arm946es/cpu.c - fixed checkpatch issues in arch/arm/cpu/sa1100/cpu.c
arch/arm/cpu/arm946es/cpu.c | 13 +++++++++++++ arch/arm/cpu/arm946es/start.S | 23 ----------------------- arch/arm/cpu/sa1100/cpu.c | 14 ++++++++++++++ arch/arm/cpu/sa1100/start.S | 10 ---------- 4 files changed, 27 insertions(+), 33 deletions(-)
diff --git a/arch/arm/cpu/arm946es/cpu.c b/arch/arm/cpu/arm946es/cpu.c index 0c8d92d..e20e5a8 100644 --- a/arch/arm/cpu/arm946es/cpu.c +++ b/arch/arm/cpu/arm946es/cpu.c @@ -16,6 +16,7 @@ #include <common.h> #include <command.h> #include <asm/system.h> +#include <asm/io.h>
static void cache_flush(void);
@@ -51,3 +52,15 @@ static void cache_flush (void) asm ("mcr p15, 0, %0, c7, c5, 0": :"r" (i)); asm ("mcr p15, 0, %0, c7, c6, 0": :"r" (i)); } + +#ifndef CONFIG_INTEGRATOR + +__attribute__((noreturn)) void reset_cpu(ulong addr __attribute__((unused))) +{ + writew(0x0, 0xfffece10); + writew(0x8, 0xfffece10); + for (;;) + ; +} + +#endif /* #ifdef CONFIG_INTEGRATOR */ diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 7d50145..534592f 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -320,26 +320,3 @@ fiq: bl do_fiq
#endif - -# ifdef CONFIG_INTEGRATOR - - /* Satisfied by general board level routine */ - -#else - - .align 5 -.globl reset_cpu -reset_cpu: - - ldr r1, rstctl1 /* get clkm1 reset ctl */ - mov r3, #0x0 - strh r3, [r1] /* clear it */ - mov r3, #0x8 - strh r3, [r1] /* force dsp+arm reset */ -_loop_forever: - b _loop_forever - -rstctl1: - .word 0xfffece10 - -#endif /* #ifdef CONFIG_INTEGRATOR */ diff --git a/arch/arm/cpu/sa1100/cpu.c b/arch/arm/cpu/sa1100/cpu.c index 6651898..4c9752a 100644 --- a/arch/arm/cpu/sa1100/cpu.c +++ b/arch/arm/cpu/sa1100/cpu.c @@ -17,6 +17,7 @@ #include <common.h> #include <command.h> #include <asm/system.h> +#include <asm/io.h>
#ifdef CONFIG_USE_IRQ DECLARE_GLOBAL_DATA_PTR; @@ -52,3 +53,16 @@ static void cache_flush (void)
asm ("mcr p15, 0, %0, c7, c5, 0": :"r" (i)); } + +#define RST_BASE 0x90030000 +#define RSRR 0x00 +#define RCSR 0x04 + +__attribute__((noreturn)) void reset_cpu(ulong addr __attribute__((unused))) +{ + /* repeat endlessly */ + while (1) { + writel(0, RST_BASE + RCSR); + writel(1, RST_BASE + RSRR); + } +} diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index bf80937..472a595 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -337,13 +337,3 @@ fiq: bl do_fiq
#endif - - .align 5 -.globl reset_cpu -reset_cpu: - ldr r0, RST_BASE - mov r1, #0x0 @ set bit 3-0 ... - str r1, [r0, #RCSR] @ ... to clear in RCSR - mov r1, #0x1 - str r1, [r0, #RSRR] @ and perform reset - b reset_cpu @ silly, but repeat endlessly
PXA start.S has a PXA (variant) specific check in start.S. Move it to cpuinfo.c.
arch/arm/cpu/pxa/cpuinfo.c | 6 ++++++ arch/arm/cpu/pxa/start.S | 6 ------ 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/pxa/cpuinfo.c b/arch/arm/cpu/pxa/cpuinfo.c index 9d16079..17d8be5 100644 --- a/arch/arm/cpu/pxa/cpuinfo.c +++ b/arch/arm/cpu/pxa/cpuinfo.c @@ -11,6 +11,12 @@ #include <errno.h> #include <linux/compiler.h>
+#ifdef CONFIG_CPU_PXA25X +#if ((CONFIG_SYS_INIT_SP_ADDR) != 0xfffff800) +#error "Init SP address must be set to 0xfffff800 for PXA250" +#endif +#endif + #define CPU_MASK_PXA_PRODID 0x000003f0 #define CPU_MASK_PXA_REVID 0x0000000f
diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index ae0d13c..eb3243a 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -23,12 +23,6 @@ #include <config.h> #include <version.h>
-#ifdef CONFIG_CPU_PXA25X -#if ((CONFIG_SYS_INIT_SP_ADDR) != 0xfffff800) -#error "Init SP address must be set to 0xfffff800 for PXA250" -#endif -#endif - .globl _start _start: b reset #ifdef CONFIG_SPL_BUILD
arch/arm/cpu/arm1136/start.S | 2 -- arch/arm/cpu/arm1176/start.S | 2 -- arch/arm/cpu/arm946es/start.S | 2 -- arch/arm/cpu/armv7/start.S | 3 --- arch/arm/cpu/pxa/start.S | 2 -- 5 files changed, 11 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 0085754..13567b9 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -53,8 +53,6 @@ _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ #endif /* CONFIG_SPL_BUILD */ -.global _end_vect -_end_vect:
.balignl 16,0xdeadbeef /* diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index ce62011..b353d69 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -61,8 +61,6 @@ _pad: . = _start + 64 #endif
-.global _end_vect -_end_vect: .balignl 16,0xdeadbeef /* ************************************************************************* diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 534592f..9806819 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -56,8 +56,6 @@ _fiq:
-_vectors_end: - /* ************************************************************************* * diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 27be451..eefe1ed 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -55,9 +55,6 @@ _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ #endif /* CONFIG_SPL_BUILD */
-.global _end_vect -_end_vect: - .balignl 16,0xdeadbeef /************************************************************************* * diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index eb3243a..e3bf1c2 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -61,8 +61,6 @@ _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ #endif /* CONFIG_SPL_BUILD */ -.global _end_vect -_end_vect:
Exception handling is basically identical for all ARM targets. Factorize it out of the various start.S files and into a single vectors.S file, and adjust linker scripts accordingly.
Changes in v2: - rebased onto u-boot-arm/master (de4fdfc1) - adjusted comment in Zynq linker script
arch/arm/cpu/arm1136/start.S | 242 +---------------------- arch/arm/cpu/arm1176/start.S | 196 +------------------ arch/arm/cpu/arm720t/start.S | 229 +--------------------- arch/arm/cpu/arm920t/ep93xx/u-boot.lds | 3 +- arch/arm/cpu/arm920t/start.S | 216 +-------------------- arch/arm/cpu/arm926ejs/mxs/start.S | 92 +-------- arch/arm/cpu/arm926ejs/spear/start.S | 27 +-- arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds | 1 + arch/arm/cpu/arm926ejs/start.S | 262 +------------------------ arch/arm/cpu/arm946es/start.S | 221 +-------------------- arch/arm/cpu/arm_intcm/start.S | 228 +--------------------- arch/arm/cpu/armv7/socfpga/lowlevel_init.S | 15 +- arch/arm/cpu/armv7/start.S | 250 +----------------------- arch/arm/cpu/armv7/zynq/u-boot.lds | 2 +- arch/arm/cpu/pxa/start.S | 245 +---------------------- arch/arm/cpu/sa1100/start.S | 215 +------------------- arch/arm/cpu/u-boot-spl.lds | 1 + arch/arm/cpu/u-boot.lds | 1 + arch/arm/lib/Makefile | 2 +- arch/arm/lib/vectors.S | 291 ++++++++++++++++++++++++++++ board/compulab/cm_t335/u-boot.lds | 1 + board/freescale/mx31ads/u-boot.lds | 1 + board/ti/am335x/u-boot.lds | 1 + 23 files changed, 316 insertions(+), 2426 deletions(-) create mode 100644 arch/arm/lib/vectors.S
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 13567b9..1cfcca9 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -15,46 +15,7 @@ #include <asm-offsets.h> #include <config.h> #include <version.h> -.globl _start -_start: b reset -#ifdef CONFIG_SPL_BUILD - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang
-_hang: - .word do_hang - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 /* now 16*4=64 */ -#else - ldr pc, _undefined_instruction - ldr pc, _software_interrupt - ldr pc, _prefetch_abort - ldr pc, _data_abort - ldr pc, _not_used - ldr pc, _irq - ldr pc, _fiq - -_undefined_instruction: .word undefined_instruction -_software_interrupt: .word software_interrupt -_prefetch_abort: .word prefetch_abort -_data_abort: .word data_abort -_not_used: .word not_used -_irq: .word irq -_fiq: .word fiq -_pad: .word 0x12345678 /* now 16*4=64 */ -#endif /* CONFIG_SPL_BUILD */ - - .balignl 16,0xdeadbeef /* ************************************************************************* * @@ -68,26 +29,7 @@ _pad: .word 0x12345678 /* now 16*4=64 */ ************************************************************************* */
-#ifdef CONFIG_USE_IRQ -/* IRQ stack memory (calculated at run-time) */ -.globl IRQ_STACK_START -IRQ_STACK_START: - .word 0x0badc0de - -/* IRQ stack memory (calculated at run-time) */ -.globl FIQ_STACK_START -FIQ_STACK_START: - .word 0x0badc0de -#endif - -/* IRQ stack memory (calculated at run-time) + 8 bytes */ -.globl IRQ_STACK_START_IN -IRQ_STACK_START_IN: - .word 0x0badc0de - -/* - * the actual reset code - */ + .globl reset
reset: /* @@ -150,185 +92,3 @@ cpu_init_crit: mov lr, ip /* restore link */ mov pc, lr /* back to my caller */ #endif /* CONFIG_SKIP_LOWLEVEL_INIT */ - -#ifndef CONFIG_SPL_BUILD -/* - ************************************************************************* - * - * Interrupt handling - * - ************************************************************************* - */ -@ -@ IRQ stack frame. -@ -#define S_FRAME_SIZE 72 - -#define S_OLD_R0 68 -#define S_PSR 64 -#define S_PC 60 -#define S_LR 56 -#define S_SP 52 - -#define S_IP 48 -#define S_FP 44 -#define S_R10 40 -#define S_R9 36 -#define S_R8 32 -#define S_R7 28 -#define S_R6 24 -#define S_R5 20 -#define S_R4 16 -#define S_R3 12 -#define S_R2 8 -#define S_R1 4 -#define S_R0 0 - -#define MODE_SVC 0x13 -#define I_BIT 0x80 - -/* - * use bad_save_user_regs for abort/prefetch/undef/swi ... - * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling - */ - - .macro bad_save_user_regs - sub sp, sp, #S_FRAME_SIZE @ carve out a frame on current user stack - stmia sp, {r0 - r12} @ Save user registers (now in svc mode) r0-r12 - - ldr r2, IRQ_STACK_START_IN @ set base 2 words into abort stack - ldmia r2, {r2 - r3} @ get values for "aborted" pc and cpsr (into parm regs) - add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack - - add r5, sp, #S_SP - mov r1, lr - stmia r5, {r0 - r3} @ save sp_SVC, lr_SVC, pc, cpsr - mov r0, sp @ save current stack into r0 (param register) - .endm - - .macro irq_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - add r8, sp, #S_PC @ !!!! R8 NEEDS to be saved !!!! a reserved stack spot would be good. - stmdb r8, {sp, lr}^ @ Calling SP, LR - str lr, [r8, #0] @ Save calling PC - mrs r6, spsr - str r6, [r8, #4] @ Save CPSR - str r0, [r8, #8] @ Save OLD_R0 - mov r0, sp - .endm - - .macro irq_restore_user_regs - ldmia sp, {r0 - lr}^ @ Calling r0 - lr - mov r0, r0 - ldr lr, [sp, #S_PC] @ Get PC - add sp, sp, #S_FRAME_SIZE - subs pc, lr, #4 @ return & move spsr_svc into cpsr - .endm - - .macro get_bad_stack - ldr r13, IRQ_STACK_START_IN @ setup our mode stack (enter in banked mode) - - str lr, [r13] @ save caller lr in position 0 of saved stack - mrs lr, spsr @ get the spsr - str lr, [r13, #4] @ save spsr in position 1 of saved stack - - mov r13, #MODE_SVC @ prepare SVC-Mode - @ msr spsr_c, r13 - msr spsr, r13 @ switch modes, make sure moves will execute - mov lr, pc @ capture return pc - movs pc, lr @ jump to next instruction & switch modes. - .endm - - .macro get_bad_stack_swi - sub r13, r13, #4 @ space on current stack for scratch reg. - str r0, [r13] @ save R0's value. - ldr r0, IRQ_STACK_START_IN @ get data regions start - str lr, [r0] @ save caller lr in position 0 of saved stack - mrs lr, spsr @ get the spsr - str lr, [r0, #4] @ save spsr in position 1 of saved stack - ldr lr, [r0] @ restore lr - ldr r0, [r13] @ restore r0 - add r13, r13, #4 @ pop stack entry - .endm - - .macro get_irq_stack @ setup IRQ stack - ldr sp, IRQ_STACK_START - .endm - - .macro get_fiq_stack @ setup FIQ stack - ldr sp, FIQ_STACK_START - .endm -#endif /* CONFIG_SPL_BUILD */ - -/* - * exception handlers - */ -#ifdef CONFIG_SPL_BUILD - .align 5 -do_hang: - bl hang /* hang and never return */ -#else /* !CONFIG_SPL_BUILD */ - .align 5 -undefined_instruction: - get_bad_stack - bad_save_user_regs - bl do_undefined_instruction - - .align 5 -software_interrupt: - get_bad_stack_swi - bad_save_user_regs - bl do_software_interrupt - - .align 5 -prefetch_abort: - get_bad_stack - bad_save_user_regs - bl do_prefetch_abort - - .align 5 -data_abort: - get_bad_stack - bad_save_user_regs - bl do_data_abort - - .align 5 -not_used: - get_bad_stack - bad_save_user_regs - bl do_not_used - -#ifdef CONFIG_USE_IRQ - - .align 5 -irq: - get_irq_stack - irq_save_user_regs - bl do_irq - irq_restore_user_regs - - .align 5 -fiq: - get_fiq_stack - /* someone ought to write a more effiction fiq_save_user_regs */ - irq_save_user_regs - bl do_fiq - irq_restore_user_regs - -#else - - .align 5 -irq: - get_bad_stack - bad_save_user_regs - bl do_irq - - .align 5 -fiq: - get_bad_stack - bad_save_user_regs - bl do_fiq - -#endif -#endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index b353d69..0704bdd 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -25,46 +25,6 @@ /* ************************************************************************* * - * Jump vector table as in table 3.1 in [1] - * - ************************************************************************* - */ - -.globl _start -_start: b reset -#ifndef CONFIG_SPL_BUILD - ldr pc, _undefined_instruction - ldr pc, _software_interrupt - ldr pc, _prefetch_abort - ldr pc, _data_abort - ldr pc, _not_used - ldr pc, _irq - ldr pc, _fiq - -_undefined_instruction: - .word undefined_instruction -_software_interrupt: - .word software_interrupt -_prefetch_abort: - .word prefetch_abort -_data_abort: - .word data_abort -_not_used: - .word not_used -_irq: - .word irq -_fiq: - .word fiq -_pad: - .word 0x12345678 /* now 16*4=64 */ -#else - . = _start + 64 -#endif - - .balignl 16,0xdeadbeef -/* - ************************************************************************* - * * Startup Code (reset vector) * * do important init only if we don't start from memory! @@ -75,14 +35,7 @@ _pad: ************************************************************************* */
reset: /* @@ -180,150 +133,3 @@ skip_tcmdisable: c_runtime_cpu_setup:
mov pc, lr - -#ifndef CONFIG_SPL_BUILD -/* - ************************************************************************* - * - * Interrupt handling - * - ************************************************************************* - */ -@ -@ IRQ stack frame. -@ -#define S_FRAME_SIZE 72 - -#define S_OLD_R0 68 -#define S_PSR 64 -#define S_PC 60 -#define S_LR 56 -#define S_SP 52 - -#define S_IP 48 -#define S_FP 44 -#define S_R10 40 -#define S_R9 36 -#define S_R8 32 -#define S_R7 28 -#define S_R6 24 -#define S_R5 20 -#define S_R4 16 -#define S_R3 12 -#define S_R2 8 -#define S_R1 4 -#define S_R0 0 - -#define MODE_SVC 0x13 -#define I_BIT 0x80 - -/* - * use bad_save_user_regs for abort/prefetch/undef/swi ... - */ - - .macro bad_save_user_regs - /* carve out a frame on current user stack */ - sub sp, sp, #S_FRAME_SIZE - /* Save user registers (now in svc mode) r0-r12 */ - stmia sp, {r0 - r12} - - ldr r2, IRQ_STACK_START_IN - /* get values for "aborted" pc and cpsr (into parm regs) */ - ldmia r2, {r2 - r3} - /* grab pointer to old stack */ - add r0, sp, #S_FRAME_SIZE - - add r5, sp, #S_SP - mov r1, lr - /* save sp_SVC, lr_SVC, pc, cpsr */ - stmia r5, {r0 - r3} - /* save current stack into r0 (param register) */ - mov r0, sp - .endm - - .macro get_bad_stack - ldr r13, IRQ_STACK_START_IN @ setup our mode stack - - /* save caller lr in position 0 of saved stack */ - str lr, [r13] - /* get the spsr */ - mrs lr, spsr - /* save spsr in position 1 of saved stack */ - str lr, [r13, #4] - - /* prepare SVC-Mode */ - mov r13, #MODE_SVC - @ msr spsr_c, r13 - /* switch modes, make sure moves will execute */ - msr spsr, r13 - /* capture return pc */ - mov lr, pc - /* jump to next instruction & switch modes. */ - movs pc, lr - .endm - - .macro get_bad_stack_swi - /* space on current stack for scratch reg. */ - sub r13, r13, #4 - /* save R0's value. */ - str r0, [r13] - ldr r13, IRQ_STACK_START_IN @ setup our mode stack - /* save caller lr in position 0 of saved stack */ - str lr, [r0] - /* get the spsr */ - mrs lr, spsr - /* save spsr in position 1 of saved stack */ - str lr, [r0, #4] - /* restore lr */ - ldr lr, [r0] - /* restore r0 */ - ldr r0, [r13] - /* pop stack entry */ - add r13, r13, #4 - .endm - -/* - * exception handlers - */ - .align 5 -undefined_instruction: - get_bad_stack - bad_save_user_regs - bl do_undefined_instruction - - .align 5 -software_interrupt: - get_bad_stack_swi - bad_save_user_regs - bl do_software_interrupt - - .align 5 -prefetch_abort: - get_bad_stack - bad_save_user_regs - bl do_prefetch_abort - - .align 5 -data_abort: - get_bad_stack - bad_save_user_regs - bl do_data_abort - - .align 5 -not_used: - get_bad_stack - bad_save_user_regs - bl do_not_used - - .align 5 -irq: - get_bad_stack - bad_save_user_regs - bl do_irq - - .align 5 -fiq: - get_bad_stack - bad_save_user_regs - bl do_fiq -#endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index 1a34842..01c85be 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -15,48 +15,6 @@ /* ************************************************************************* * - * Jump vector table as in table 3.1 in [1] - * - ************************************************************************* - */ - - -.globl _start -_start: b reset - ldr pc, _undefined_instruction - ldr pc, _software_interrupt - ldr pc, _prefetch_abort - ldr pc, _data_abort - ldr pc, _not_used - ldr pc, _irq - ldr pc, _fiq - -#ifdef CONFIG_SPL_BUILD -_undefined_instruction: .word _undefined_instruction -_software_interrupt: .word _software_interrupt -_prefetch_abort: .word _prefetch_abort -_data_abort: .word _data_abort -_not_used: .word _not_used -_irq: .word _irq -_fiq: .word _fiq -_pad: .word 0x12345678 /* now 16*4=64 */ -#else -_undefined_instruction: .word undefined_instruction -_software_interrupt: .word software_interrupt -_prefetch_abort: .word prefetch_abort -_data_abort: .word data_abort -_not_used: .word not_used -_irq: .word irq -_fiq: .word fiq -_pad: .word 0x12345678 /* now 16*4=64 */ -#endif /* CONFIG_SPL_BUILD */ - - .balignl 16,0xdeadbeef - - -/* - ************************************************************************* - * * Startup Code (reset vector) * * do important init only if we don't start from RAM! @@ -67,26 +25,7 @@ _pad: .word 0x12345678 /* now 16*4=64 */ ************************************************************************* */
reset: /* @@ -139,169 +78,3 @@ cpu_init_crit:
mov pc, lr #endif /* CONFIG_SKIP_LOWLEVEL_INIT */ - - -#ifndef CONFIG_SPL_BUILD -/* - ************************************************************************* - * - * Interrupt handling - * - ************************************************************************* - */ - -@ -@ IRQ stack frame. -@ -#define S_FRAME_SIZE 72 - -#define S_OLD_R0 68 -#define S_PSR 64 -#define S_PC 60 -#define S_LR 56 -#define S_SP 52 - -#define S_IP 48 -#define S_FP 44 -#define S_R10 40 -#define S_R9 36 -#define S_R8 32 -#define S_R7 28 -#define S_R6 24 -#define S_R5 20 -#define S_R4 16 -#define S_R3 12 -#define S_R2 8 -#define S_R1 4 -#define S_R0 0 - -#define MODE_SVC 0x13 -#define I_BIT 0x80 - -/* - * use bad_save_user_regs for abort/prefetch/undef/swi ... - * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling - */ - - .macro bad_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - add r8, sp, #S_PC - - ldr r2, IRQ_STACK_START_IN - ldmia r2, {r2 - r4} @ get pc, cpsr, old_r0 - add r0, sp, #S_FRAME_SIZE @ restore sp_SVC - - add r5, sp, #S_SP - mov r1, lr - stmia r5, {r0 - r4} @ save sp_SVC, lr_SVC, pc, cpsr, old_r - mov r0, sp - .endm - - .macro irq_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - add r8, sp, #S_PC - stmdb r8, {sp, lr}^ @ Calling SP, LR - str lr, [r8, #0] @ Save calling PC - mrs r6, spsr - str r6, [r8, #4] @ Save CPSR - str r0, [r8, #8] @ Save OLD_R0 - mov r0, sp - .endm - - .macro irq_restore_user_regs - ldmia sp, {r0 - lr}^ @ Calling r0 - lr - mov r0, r0 - ldr lr, [sp, #S_PC] @ Get PC - add sp, sp, #S_FRAME_SIZE - subs pc, lr, #4 @ return & move spsr_svc into cpsr - .endm - - .macro get_bad_stack - ldr r13, IRQ_STACK_START_IN @ setup our mode stack - - str lr, [r13] @ save caller lr / spsr - mrs lr, spsr - str lr, [r13, #4] - - mov r13, #MODE_SVC @ prepare SVC-Mode - msr spsr_c, r13 - mov lr, pc - movs pc, lr - .endm - - .macro get_irq_stack @ setup IRQ stack - ldr sp, IRQ_STACK_START - .endm - - .macro get_fiq_stack @ setup FIQ stack - ldr sp, FIQ_STACK_START - .endm - -/* - * exception handlers - */ - .align 5 -undefined_instruction: - get_bad_stack - bad_save_user_regs - bl do_undefined_instruction - - .align 5 -software_interrupt: - get_bad_stack - bad_save_user_regs - bl do_software_interrupt - - .align 5 -prefetch_abort: - get_bad_stack - bad_save_user_regs - bl do_prefetch_abort - - .align 5 -data_abort: - get_bad_stack - bad_save_user_regs - bl do_data_abort - - .align 5 -not_used: - get_bad_stack - bad_save_user_regs - bl do_not_used - -#ifdef CONFIG_USE_IRQ - - .align 5 -irq: - get_irq_stack - irq_save_user_regs - bl do_irq - irq_restore_user_regs - - .align 5 -fiq: - get_fiq_stack - /* someone ought to write a more effiction fiq_save_user_regs */ - irq_save_user_regs - bl do_fiq - irq_restore_user_regs - -#else - - .align 5 -irq: - get_bad_stack - bad_save_user_regs - bl do_irq - - .align 5 -fiq: - get_bad_stack - bad_save_user_regs - bl do_fiq - -#endif -#endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/cpu/arm920t/ep93xx/u-boot.lds b/arch/arm/cpu/arm920t/ep93xx/u-boot.lds index 9699404..623a635 100644 --- a/arch/arm/cpu/arm920t/ep93xx/u-boot.lds +++ b/arch/arm/cpu/arm920t/ep93xx/u-boot.lds @@ -16,7 +16,8 @@ SECTIONS .text : { *(.__image_copy_start) - arch/arm/cpu/arm920t/start.o (.text*) + *(.vectors) + arch/arm/cpu/arm920t/start.o (.text*) /* the EP93xx expects to find the pattern 'CRUS' at 0x1000 */ . = 0x1000; LONG(0x53555243) diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index 7bf094a..0740450 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -15,36 +15,6 @@ /* ************************************************************************* * - * Jump vector table as in table 3.1 in [1] - * - ************************************************************************* - */ - - -.globl _start -_start: b start_code - ldr pc, _undefined_instruction - ldr pc, _software_interrupt - ldr pc, _prefetch_abort - ldr pc, _data_abort - ldr pc, _not_used - ldr pc, _irq - ldr pc, _fiq - -_undefined_instruction: .word undefined_instruction -_software_interrupt: .word software_interrupt -_prefetch_abort: .word prefetch_abort -_data_abort: .word data_abort -_not_used: .word not_used -_irq: .word irq -_fiq: .word fiq - - .balignl 16,0xdeadbeef - - -/* - ************************************************************************* - * * Startup Code (called from the ARM reset exception vector) * * do important init only if we don't start from memory! @@ -55,28 +25,9 @@ _fiq: .word fiq ************************************************************************* */
-#ifdef CONFIG_USE_IRQ -/* IRQ stack memory (calculated at run-time) */ -.globl IRQ_STACK_START -IRQ_STACK_START: - .word 0x0badc0de - -/* IRQ stack memory (calculated at run-time) */ -.globl FIQ_STACK_START -FIQ_STACK_START: - .word 0x0badc0de -#endif - -/* IRQ stack memory (calculated at run-time) + 8 bytes */ -.globl IRQ_STACK_START_IN -IRQ_STACK_START_IN: - .word 0x0badc0de + .globl reset
-/* - * the actual start code - */ - -start_code: +reset: /* * set the cpu to SVC32 mode */ @@ -196,166 +147,3 @@ cpu_init_crit: mov lr, ip mov pc, lr #endif /* CONFIG_SKIP_LOWLEVEL_INIT */ - -/* - ************************************************************************* - * - * Interrupt handling - * - ************************************************************************* - */ - -@ -@ IRQ stack frame. -@ -#define S_FRAME_SIZE 72 - -#define S_OLD_R0 68 -#define S_PSR 64 -#define S_PC 60 -#define S_LR 56 -#define S_SP 52 - -#define S_IP 48 -#define S_FP 44 -#define S_R10 40 -#define S_R9 36 -#define S_R8 32 -#define S_R7 28 -#define S_R6 24 -#define S_R5 20 -#define S_R4 16 -#define S_R3 12 -#define S_R2 8 -#define S_R1 4 -#define S_R0 0 - -#define MODE_SVC 0x13 -#define I_BIT 0x80 - -/* - * use bad_save_user_regs for abort/prefetch/undef/swi ... - * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling - */ - - .macro bad_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - ldr r2, IRQ_STACK_START_IN - ldmia r2, {r2 - r3} @ get pc, cpsr - add r0, sp, #S_FRAME_SIZE @ restore sp_SVC - - add r5, sp, #S_SP - mov r1, lr - stmia r5, {r0 - r3} @ save sp_SVC, lr_SVC, pc, cpsr - mov r0, sp - .endm - - .macro irq_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - add r7, sp, #S_PC - stmdb r7, {sp, lr}^ @ Calling SP, LR - str lr, [r7, #0] @ Save calling PC - mrs r6, spsr - str r6, [r7, #4] @ Save CPSR - str r0, [r7, #8] @ Save OLD_R0 - mov r0, sp - .endm - - .macro irq_restore_user_regs - ldmia sp, {r0 - lr}^ @ Calling r0 - lr - mov r0, r0 - ldr lr, [sp, #S_PC] @ Get PC - add sp, sp, #S_FRAME_SIZE - /* return & move spsr_svc into cpsr */ - subs pc, lr, #4 - .endm - - .macro get_bad_stack - ldr r13, IRQ_STACK_START_IN @ setup our mode stack - - str lr, [r13] @ save caller lr / spsr - mrs lr, spsr - str lr, [r13, #4] - - mov r13, #MODE_SVC @ prepare SVC-Mode - @ msr spsr_c, r13 - msr spsr, r13 - mov lr, pc - movs pc, lr - .endm - - .macro get_irq_stack @ setup IRQ stack - ldr sp, IRQ_STACK_START - .endm - - .macro get_fiq_stack @ setup FIQ stack - ldr sp, FIQ_STACK_START - .endm - -/* - * exception handlers - */ - .align 5 -undefined_instruction: - get_bad_stack - bad_save_user_regs - bl do_undefined_instruction - - .align 5 -software_interrupt: - get_bad_stack - bad_save_user_regs - bl do_software_interrupt - - .align 5 -prefetch_abort: - get_bad_stack - bad_save_user_regs - bl do_prefetch_abort - - .align 5 -data_abort: - get_bad_stack - bad_save_user_regs - bl do_data_abort - - .align 5 -not_used: - get_bad_stack - bad_save_user_regs - bl do_not_used - -#ifdef CONFIG_USE_IRQ - - .align 5 -irq: - get_irq_stack - irq_save_user_regs - bl do_irq - irq_restore_user_regs - - .align 5 -fiq: - get_fiq_stack - /* someone ought to write a more effiction fiq_save_user_regs */ - irq_save_user_regs - bl do_fiq - irq_restore_user_regs - -#else - - .align 5 -irq: - get_bad_stack - bad_save_user_regs - bl do_irq - - .align 5 -fiq: - get_bad_stack - bad_save_user_regs - bl do_fiq - -#endif diff --git a/arch/arm/cpu/arm926ejs/mxs/start.S b/arch/arm/cpu/arm926ejs/mxs/start.S index 34a0fcb..9b60436 100644 --- a/arch/arm/cpu/arm926ejs/mxs/start.S +++ b/arch/arm/cpu/arm926ejs/mxs/start.S @@ -27,70 +27,6 @@ /* ************************************************************************* * - * Jump vector table as in table 3.1 in [1] - * - ************************************************************************* - */ - - -.globl _start -_start: - b reset - b undefined_instruction - b software_interrupt - b prefetch_abort - b data_abort - b not_used - b irq - b fiq - -/* - * Vector table, located at address 0x20. - * This table allows the code running AFTER SPL, the U-Boot, to install it's - * interrupt handlers here. The problem is that the U-Boot is loaded into RAM, - * including it's interrupt vectoring table and the table at 0x0 is still the - * SPLs. So if interrupt happens in U-Boot, the SPLs interrupt vectoring table - * is still used. - */ -_vt_reset: - .word _reset -_vt_undefined_instruction: - .word _hang -_vt_software_interrupt: - .word _hang -_vt_prefetch_abort: - .word _hang -_vt_data_abort: - .word _hang -_vt_not_used: - .word _reset -_vt_irq: - .word _hang -_vt_fiq: - .word _hang - -reset: - ldr pc, _vt_reset -undefined_instruction: - ldr pc, _vt_undefined_instruction -software_interrupt: - ldr pc, _vt_software_interrupt -prefetch_abort: - ldr pc, _vt_prefetch_abort -data_abort: - ldr pc, _vt_data_abort -not_used: - ldr pc, _vt_not_used -irq: - ldr pc, _vt_irq -fiq: - ldr pc, _vt_fiq - - .balignl 16,0xdeadbeef - -/* - ************************************************************************* - * * Startup Code (reset vector) * * do important init only if we don't start from memory! @@ -101,28 +37,8 @@ fiq: ************************************************************************* */
-#ifdef CONFIG_USE_IRQ -/* IRQ stack memory (calculated at run-time) */ -.globl IRQ_STACK_START -IRQ_STACK_START: - .word 0x0badc0de - -/* IRQ stack memory (calculated at run-time) */ -.globl FIQ_STACK_START -FIQ_STACK_START: - .word 0x0badc0de -#endif - -/* IRQ stack memory (calculated at run-time) + 8 bytes */ -.globl IRQ_STACK_START_IN -IRQ_STACK_START_IN: - .word 0x0badc0de - -/* - * the actual reset code - */ - -_reset: + .globl reset +reset: /* * If the CPU is configured in "Wait JTAG connection mode", the stack * pointer is not configured and is zero. This will cause crash when @@ -179,7 +95,3 @@ _reset: mov r0, #0
bx lr - -_hang: -1: - bl 1b /* hang and never return */ diff --git a/arch/arm/cpu/arm926ejs/spear/start.S b/arch/arm/cpu/arm926ejs/spear/start.S index 7dbd5db..290ac2e 100644 --- a/arch/arm/cpu/arm926ejs/spear/start.S +++ b/arch/arm/cpu/arm926ejs/spear/start.S @@ -17,29 +17,6 @@
#include <config.h>
-.globl _start -_start: - b reset - ldr pc, _undefined_instruction - ldr pc, _software_interrupt - ldr pc, _prefetch_abort - ldr pc, _data_abort - ldr pc, _not_used - ldr pc, _irq - ldr pc, _fiq - -_undefined_instruction: -_software_interrupt: -_prefetch_abort: -_data_abort: -_not_used: -_irq: -_fiq: - .word infinite_loop - -infinite_loop: - b infinite_loop - /* ************************************************************************* * @@ -53,9 +30,7 @@ infinite_loop: ************************************************************************* */
reset: /* diff --git a/arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds b/arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds index b6d0f65..c7ee199 100644 --- a/arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds +++ b/arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds @@ -21,6 +21,7 @@ SECTIONS . = ALIGN(4); .text : { + *(.vectors) arch/arm/cpu/arm926ejs/spear/start.o (.text*) *(.text*) } diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 0717327..8eb2494 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -23,75 +23,6 @@ /* ************************************************************************* * - * Jump vector table as in table 3.1 in [1] - * - ************************************************************************* - */ - - -#ifdef CONFIG_SYS_DV_NOR_BOOT_CFG -.globl _start -_start: -.globl _NOR_BOOT_CFG -_NOR_BOOT_CFG: - .word CONFIG_SYS_DV_NOR_BOOT_CFG - b reset -#else -.globl _start -_start: - b reset -#endif -#ifdef CONFIG_SPL_BUILD -/* No exception handlers in preloader */ - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - -_hang: - .word do_hang -/* pad to 64 byte boundary */ - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 -#else - ldr pc, _undefined_instruction - ldr pc, _software_interrupt - ldr pc, _prefetch_abort - ldr pc, _data_abort - ldr pc, _not_used - ldr pc, _irq - ldr pc, _fiq - -_undefined_instruction: - .word undefined_instruction -_software_interrupt: - .word software_interrupt -_prefetch_abort: - .word prefetch_abort -_data_abort: - .word data_abort -_not_used: - .word not_used -_irq: - .word irq -_fiq: - .word fiq - -#endif /* CONFIG_SPL_BUILD */ - .balignl 16,0xdeadbeef - - -/* - ************************************************************************* - * * Startup Code (reset vector) * * do important init only if we don't start from memory! @@ -102,26 +33,7 @@ _fiq: ************************************************************************* */
reset: /* @@ -198,175 +110,3 @@ flush_dcache: mov lr, ip /* restore link */ mov pc, lr /* back to my caller */ #endif /* CONFIG_SKIP_LOWLEVEL_INIT */ - -#ifndef CONFIG_SPL_BUILD -/* - ************************************************************************* - * - * Interrupt handling - * - ************************************************************************* - */ - -@ -@ IRQ stack frame. -@ -#define S_FRAME_SIZE 72 - -#define S_OLD_R0 68 -#define S_PSR 64 -#define S_PC 60 -#define S_LR 56 -#define S_SP 52 - -#define S_IP 48 -#define S_FP 44 -#define S_R10 40 -#define S_R9 36 -#define S_R8 32 -#define S_R7 28 -#define S_R6 24 -#define S_R5 20 -#define S_R4 16 -#define S_R3 12 -#define S_R2 8 -#define S_R1 4 -#define S_R0 0 - -#define MODE_SVC 0x13 -#define I_BIT 0x80 - -/* - * use bad_save_user_regs for abort/prefetch/undef/swi ... - * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling - */ - - .macro bad_save_user_regs - @ carve out a frame on current user stack - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Save user registers (now in svc mode) r0-r12 - ldr r2, IRQ_STACK_START_IN - @ get values for "aborted" pc and cpsr (into parm regs) - ldmia r2, {r2 - r3} - add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack - add r5, sp, #S_SP - mov r1, lr - stmia r5, {r0 - r3} @ save sp_SVC, lr_SVC, pc, cpsr - mov r0, sp @ save current stack into r0 (param register) - .endm - - .macro irq_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - @ !!!! R8 NEEDS to be saved !!!! a reserved stack spot would be good. - add r8, sp, #S_PC - stmdb r8, {sp, lr}^ @ Calling SP, LR - str lr, [r8, #0] @ Save calling PC - mrs r6, spsr - str r6, [r8, #4] @ Save CPSR - str r0, [r8, #8] @ Save OLD_R0 - mov r0, sp - .endm - - .macro irq_restore_user_regs - ldmia sp, {r0 - lr}^ @ Calling r0 - lr - mov r0, r0 - ldr lr, [sp, #S_PC] @ Get PC - add sp, sp, #S_FRAME_SIZE - subs pc, lr, #4 @ return & move spsr_svc into cpsr - .endm - - .macro get_bad_stack - ldr r13, IRQ_STACK_START_IN @ setup our mode stack - - str lr, [r13] @ save caller lr in position 0 of saved stack - mrs lr, spsr @ get the spsr - str lr, [r13, #4] @ save spsr in position 1 of saved stack - mov r13, #MODE_SVC @ prepare SVC-Mode - @ msr spsr_c, r13 - msr spsr, r13 @ switch modes, make sure moves will execute - mov lr, pc @ capture return pc - movs pc, lr @ jump to next instruction & switch modes. - .endm - - .macro get_irq_stack @ setup IRQ stack - ldr sp, IRQ_STACK_START - .endm - - .macro get_fiq_stack @ setup FIQ stack - ldr sp, FIQ_STACK_START - .endm -#endif /* CONFIG_SPL_BUILD */ - -/* - * exception handlers - */ -#ifdef CONFIG_SPL_BUILD - .align 5 -do_hang: -1: - bl 1b /* hang and never return */ -#else /* !CONFIG_SPL_BUILD */ - .align 5 -undefined_instruction: - get_bad_stack - bad_save_user_regs - bl do_undefined_instruction - - .align 5 -software_interrupt: - get_bad_stack - bad_save_user_regs - bl do_software_interrupt - - .align 5 -prefetch_abort: - get_bad_stack - bad_save_user_regs - bl do_prefetch_abort - - .align 5 -data_abort: - get_bad_stack - bad_save_user_regs - bl do_data_abort - - .align 5 -not_used: - get_bad_stack - bad_save_user_regs - bl do_not_used - -#ifdef CONFIG_USE_IRQ - - .align 5 -irq: - get_irq_stack - irq_save_user_regs - bl do_irq - irq_restore_user_regs - - .align 5 -fiq: - get_fiq_stack - /* someone ought to write a more effiction fiq_save_user_regs */ - irq_save_user_regs - bl do_fiq - irq_restore_user_regs - -#else - - .align 5 -irq: - get_bad_stack - bad_save_user_regs - bl do_irq - - .align 5 -fiq: - get_bad_stack - bad_save_user_regs - bl do_fiq - -#endif -#endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 9806819..4112371 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -22,43 +22,6 @@ /* ************************************************************************* * - * Jump vector table as in table 3.1 in [1] - * - ************************************************************************* - */ - - -.globl _start -_start: - b reset - ldr pc, _undefined_instruction - ldr pc, _software_interrupt - ldr pc, _prefetch_abort - ldr pc, _data_abort - ldr pc, _not_used - ldr pc, _irq - ldr pc, _fiq - -_undefined_instruction: - .word undefined_instruction -_software_interrupt: - .word software_interrupt -_prefetch_abort: - .word prefetch_abort -_data_abort: - .word data_abort -_not_used: - .word not_used -_irq: - .word irq -_fiq: - .word fiq - - .balignl 16,0xdeadbeef - -/* - ************************************************************************* - * * Startup Code (reset vector) * * do important init only if we don't start from memory! @@ -69,26 +32,7 @@ _fiq: ************************************************************************* */
reset: /* @@ -155,166 +99,3 @@ cpu_init_crit: mov lr, ip /* restore link */ mov pc, lr /* back to my caller */ #endif -/* - ************************************************************************* - * - * Interrupt handling - * - ************************************************************************* - */ - -@ -@ IRQ stack frame. -@ -#define S_FRAME_SIZE 72 - -#define S_OLD_R0 68 -#define S_PSR 64 -#define S_PC 60 -#define S_LR 56 -#define S_SP 52 - -#define S_IP 48 -#define S_FP 44 -#define S_R10 40 -#define S_R9 36 -#define S_R8 32 -#define S_R7 28 -#define S_R6 24 -#define S_R5 20 -#define S_R4 16 -#define S_R3 12 -#define S_R2 8 -#define S_R1 4 -#define S_R0 0 - -#define MODE_SVC 0x13 -#define I_BIT 0x80 - -/* - * use bad_save_user_regs for abort/prefetch/undef/swi ... - * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling - */ - - .macro bad_save_user_regs - @ carve out a frame on current user stack - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Save user registers (now in svc mode) r0-r12 - - ldr r2, IRQ_STACK_START_IN - @ get values for "aborted" pc and cpsr (into parm regs) - ldmia r2, {r2 - r3} - add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack - add r5, sp, #S_SP - mov r1, lr - stmia r5, {r0 - r3} @ save sp_SVC, lr_SVC, pc, cpsr - mov r0, sp @ save current stack into r0 (param register) - .endm - - .macro irq_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - @ !!!! R8 NEEDS to be saved !!!! a reserved stack spot would be good. - add r8, sp, #S_PC - stmdb r8, {sp, lr}^ @ Calling SP, LR - str lr, [r8, #0] @ Save calling PC - mrs r6, spsr - str r6, [r8, #4] @ Save CPSR - str r0, [r8, #8] @ Save OLD_R0 - mov r0, sp - .endm - - .macro irq_restore_user_regs - ldmia sp, {r0 - lr}^ @ Calling r0 - lr - mov r0, r0 - ldr lr, [sp, #S_PC] @ Get PC - add sp, sp, #S_FRAME_SIZE - subs pc, lr, #4 @ return & move spsr_svc into cpsr - .endm - - .macro get_bad_stack - ldr r13, IRQ_STACK_START_IN @ setup our mode stack - - str lr, [r13] @ save caller lr in position 0 of saved stack - mrs lr, spsr @ get the spsr - str lr, [r13, #4] @ save spsr in position 1 of saved stack - mov r13, #MODE_SVC @ prepare SVC-Mode - @ msr spsr_c, r13 - msr spsr, r13 @ switch modes, make sure moves will execute - mov lr, pc @ capture return pc - movs pc, lr @ jump to next instruction & switch modes. - .endm - - .macro get_irq_stack @ setup IRQ stack - ldr sp, IRQ_STACK_START - .endm - - .macro get_fiq_stack @ setup FIQ stack - ldr sp, FIQ_STACK_START - .endm - -/* - * exception handlers - */ - .align 5 -undefined_instruction: - get_bad_stack - bad_save_user_regs - bl do_undefined_instruction - - .align 5 -software_interrupt: - get_bad_stack - bad_save_user_regs - bl do_software_interrupt - - .align 5 -prefetch_abort: - get_bad_stack - bad_save_user_regs - bl do_prefetch_abort - - .align 5 -data_abort: - get_bad_stack - bad_save_user_regs - bl do_data_abort - - .align 5 -not_used: - get_bad_stack - bad_save_user_regs - bl do_not_used - -#ifdef CONFIG_USE_IRQ - - .align 5 -irq: - get_irq_stack - irq_save_user_regs - bl do_irq - irq_restore_user_regs - - .align 5 -fiq: - get_fiq_stack - /* someone ought to write a more effiction fiq_save_user_regs */ - irq_save_user_regs - bl do_fiq - irq_restore_user_regs - -#else - - .align 5 -irq: - get_bad_stack - bad_save_user_regs - bl do_irq - - .align 5 -fiq: - get_bad_stack - bad_save_user_regs - bl do_fiq - -#endif diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index 7404ea7..c0c07b6 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -21,42 +21,6 @@ /* ************************************************************************* * - * Jump vector table - * - ************************************************************************* - */ - -.globl _start -_start: - b reset - ldr pc, _undefined_instruction - ldr pc, _software_interrupt - ldr pc, _prefetch_abort - ldr pc, _data_abort - ldr pc, _not_used - ldr pc, _irq - ldr pc, _fiq - -_undefined_instruction: - .word undefined_instruction -_software_interrupt: - .word software_interrupt -_prefetch_abort: - .word prefetch_abort -_data_abort: - .word data_abort -_not_used: - .word not_used -_irq: - .word irq -_fiq: - .word fiq - - .balignl 16,0xdeadbeef - -/* - ************************************************************************* - * * Startup Code (reset vector) * * do important init only if we don't start from memory! @@ -67,26 +31,7 @@ _fiq: ************************************************************************* */
reset: /* @@ -132,174 +77,3 @@ cpu_init_crit: */ mov pc, lr /* back to my caller */ #endif -/* - ************************************************************************* - * - * Interrupt handling - * - ************************************************************************* - */ - -@ -@ IRQ stack frame. -@ -#define S_FRAME_SIZE 72 - -#define S_OLD_R0 68 -#define S_PSR 64 -#define S_PC 60 -#define S_LR 56 -#define S_SP 52 - -#define S_IP 48 -#define S_FP 44 -#define S_R10 40 -#define S_R9 36 -#define S_R8 32 -#define S_R7 28 -#define S_R6 24 -#define S_R5 20 -#define S_R4 16 -#define S_R3 12 -#define S_R2 8 -#define S_R1 4 -#define S_R0 0 - -#define MODE_SVC 0x13 -#define I_BIT 0x80 - -/* - * use bad_save_user_regs for abort/prefetch/undef/swi ... - * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling - */ - - .macro bad_save_user_regs - @ carve out a frame on current user stack - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Save user registers (now in svc mode) r0-r12 - - ldr r2, IRQ_STACK_START_IN - @ get values for "aborted" pc and cpsr (into parm regs) - ldmia r2, {r2 - r3} - add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack - add r5, sp, #S_SP - mov r1, lr - stmia r5, {r0 - r3} @ save sp_SVC, lr_SVC, pc, cpsr - mov r0, sp @ save current stack into r0 (param register) - .endm - - .macro irq_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - @ !!!! R8 NEEDS to be saved !!!! a reserved stack spot would be good. - add r8, sp, #S_PC - stmdb r8, {sp, lr}^ @ Calling SP, LR - str lr, [r8, #0] @ Save calling PC - mrs r6, spsr - str r6, [r8, #4] @ Save CPSR - str r0, [r8, #8] @ Save OLD_R0 - mov r0, sp - .endm - - .macro irq_restore_user_regs - ldmia sp, {r0 - lr}^ @ Calling r0 - lr - mov r0, r0 - ldr lr, [sp, #S_PC] @ Get PC - add sp, sp, #S_FRAME_SIZE - subs pc, lr, #4 @ return & move spsr_svc into cpsr - .endm - - .macro get_bad_stack - ldr r13, IRQ_STACK_START_IN @ setup our mode stack - - str lr, [r13] @ save caller lr in position 0 of saved stack - mrs lr, spsr @ get the spsr - str lr, [r13, #4] @ save spsr in position 1 of saved stack - mov r13, #MODE_SVC @ prepare SVC-Mode - @ msr spsr_c, r13 - msr spsr, r13 @ switch modes, make sure moves will execute - mov lr, pc @ capture return pc - movs pc, lr @ jump to next instruction & switch modes. - .endm - - .macro get_irq_stack @ setup IRQ stack - ldr sp, IRQ_STACK_START - .endm - - .macro get_fiq_stack @ setup FIQ stack - ldr sp, FIQ_STACK_START - .endm - -/* - * exception handlers - */ - .align 5 -.globl undefined_instruction -undefined_instruction: - get_bad_stack - bad_save_user_regs - bl do_undefined_instruction - - .align 5 -.globl software_interrupt -software_interrupt: - get_bad_stack - bad_save_user_regs - bl do_software_interrupt - - .align 5 -.globl prefetch_abort -prefetch_abort: - get_bad_stack - bad_save_user_regs - bl do_prefetch_abort - - .align 5 -.globl data_abort -data_abort: - get_bad_stack - bad_save_user_regs - bl do_data_abort - - .align 5 -.globl not_used -not_used: - get_bad_stack - bad_save_user_regs - bl do_not_used - -#ifdef CONFIG_USE_IRQ - .align 5 -.globl irq -irq: - get_irq_stack - irq_save_user_regs - bl do_irq - irq_restore_user_regs - - .align 5 -.globl fiq -fiq: - get_fiq_stack - /* someone ought to write a more effiction fiq_save_user_regs */ - irq_save_user_regs - bl do_fiq - irq_restore_user_regs - -#else - - .align 5 -.globl irq -irq: - get_bad_stack - bad_save_user_regs - bl do_irq - - .align 5 -.globl fiq -fiq: - get_bad_stack - bad_save_user_regs - bl do_fiq - -#endif diff --git a/arch/arm/cpu/armv7/socfpga/lowlevel_init.S b/arch/arm/cpu/armv7/socfpga/lowlevel_init.S index 1caaa27..2f2e9fc 100644 --- a/arch/arm/cpu/armv7/socfpga/lowlevel_init.S +++ b/arch/arm/cpu/armv7/socfpga/lowlevel_init.S @@ -10,20 +10,7 @@ /* Save the parameter pass in by previous boot loader */ .global save_boot_params save_boot_params: - /* save the parameter here */ - - /* - * Setup stack for exception, which is located - * at the end of on-chip RAM. We don't expect exception prior to - * relocation and if that happens, we won't worry -- it will overide - * global data region as the code will goto reset. After relocation, - * this region won't be used by other part of program. - * Hence it is safe. - */ - ldr r0, =(CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE) - ldr r1, =IRQ_STACK_START_IN - str r0, [r1] - + /* no parameter to save */ bx lr
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index eefe1ed..fedd7c8 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -19,43 +19,6 @@ #include <asm/system.h> #include <linux/linkage.h>
-.globl _start -_start: b reset - ldr pc, _undefined_instruction - ldr pc, _software_interrupt - ldr pc, _prefetch_abort - ldr pc, _data_abort - ldr pc, _not_used - ldr pc, _irq - ldr pc, _fiq -#ifdef CONFIG_SPL_BUILD -_undefined_instruction: .word _undefined_instruction -_software_interrupt: .word _software_interrupt -_prefetch_abort: .word _prefetch_abort -_data_abort: .word _data_abort -_not_used: .word _not_used -_irq: .word _irq -_fiq: .word _fiq -_pad: .word 0x12345678 /* now 16*4=64 */ -#else -.globl _undefined_instruction -_undefined_instruction: .word undefined_instruction -.globl _software_interrupt -_software_interrupt: .word software_interrupt -.globl _prefetch_abort -_prefetch_abort: .word prefetch_abort -.globl _data_abort -_data_abort: .word data_abort -.globl _not_used -_not_used: .word not_used -.globl _irq -_irq: .word irq -.globl _fiq -_fiq: .word fiq -_pad: .word 0x12345678 /* now 16*4=64 */ -#endif /* CONFIG_SPL_BUILD */ - - .balignl 16,0xdeadbeef /************************************************************************* * * Startup Code (reset vector) @@ -67,26 +30,7 @@ _pad: .word 0x12345678 /* now 16*4=64 */ * *************************************************************************/
reset: bl save_boot_params @@ -247,195 +191,3 @@ ENTRY(cpu_init_crit) b lowlevel_init @ go setup pll,mux,memory ENDPROC(cpu_init_crit) #endif - -#ifndef CONFIG_SPL_BUILD -/* - ************************************************************************* - * - * Interrupt handling - * - ************************************************************************* - */ -@ -@ IRQ stack frame. -@ -#define S_FRAME_SIZE 72 - -#define S_OLD_R0 68 -#define S_PSR 64 -#define S_PC 60 -#define S_LR 56 -#define S_SP 52 - -#define S_IP 48 -#define S_FP 44 -#define S_R10 40 -#define S_R9 36 -#define S_R8 32 -#define S_R7 28 -#define S_R6 24 -#define S_R5 20 -#define S_R4 16 -#define S_R3 12 -#define S_R2 8 -#define S_R1 4 -#define S_R0 0 - -#define MODE_SVC 0x13 -#define I_BIT 0x80 - -/* - * use bad_save_user_regs for abort/prefetch/undef/swi ... - * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling - */ - - .macro bad_save_user_regs - sub sp, sp, #S_FRAME_SIZE @ carve out a frame on current - @ user stack - stmia sp, {r0 - r12} @ Save user registers (now in - @ svc mode) r0-r12 - ldr r2, IRQ_STACK_START_IN @ set base 2 words into abort - @ stack - ldmia r2, {r2 - r3} @ get values for "aborted" pc - @ and cpsr (into parm regs) - add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack - - add r5, sp, #S_SP - mov r1, lr - stmia r5, {r0 - r3} @ save sp_SVC, lr_SVC, pc, cpsr - mov r0, sp @ save current stack into r0 - @ (param register) - .endm - - .macro irq_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - add r8, sp, #S_PC @ !! R8 NEEDS to be saved !! - @ a reserved stack spot would - @ be good. - stmdb r8, {sp, lr}^ @ Calling SP, LR - str lr, [r8, #0] @ Save calling PC - mrs r6, spsr - str r6, [r8, #4] @ Save CPSR - str r0, [r8, #8] @ Save OLD_R0 - mov r0, sp - .endm - - .macro irq_restore_user_regs - ldmia sp, {r0 - lr}^ @ Calling r0 - lr - mov r0, r0 - ldr lr, [sp, #S_PC] @ Get PC - add sp, sp, #S_FRAME_SIZE - subs pc, lr, #4 @ return & move spsr_svc into - @ cpsr - .endm - - .macro get_bad_stack - ldr r13, IRQ_STACK_START_IN @ setup our mode stack (enter - @ in banked mode) - - str lr, [r13] @ save caller lr in position 0 - @ of saved stack - mrs lr, spsr @ get the spsr - str lr, [r13, #4] @ save spsr in position 1 of - @ saved stack - - mov r13, #MODE_SVC @ prepare SVC-Mode - @ msr spsr_c, r13 - msr spsr, r13 @ switch modes, make sure - @ moves will execute - mov lr, pc @ capture return pc - movs pc, lr @ jump to next instruction & - @ switch modes. - .endm - - .macro get_bad_stack_swi - sub r13, r13, #4 @ space on current stack for - @ scratch reg. - str r0, [r13] @ save R0's value. - ldr r0, IRQ_STACK_START_IN @ get data regions start - @ spots for abort stack - str lr, [r0] @ save caller lr in position 0 - @ of saved stack - mrs lr, spsr @ get the spsr - str lr, [r0, #4] @ save spsr in position 1 of - @ saved stack - ldr lr, [r0] @ restore lr - ldr r0, [r13] @ restore r0 - add r13, r13, #4 @ pop stack entry - .endm - - .macro get_irq_stack @ setup IRQ stack - ldr sp, IRQ_STACK_START - .endm - - .macro get_fiq_stack @ setup FIQ stack - ldr sp, FIQ_STACK_START - .endm - -/* - * exception handlers - */ - .align 5 -undefined_instruction: - get_bad_stack - bad_save_user_regs - bl do_undefined_instruction - - .align 5 -software_interrupt: - get_bad_stack_swi - bad_save_user_regs - bl do_software_interrupt - - .align 5 -prefetch_abort: - get_bad_stack - bad_save_user_regs - bl do_prefetch_abort - - .align 5 -data_abort: - get_bad_stack - bad_save_user_regs - bl do_data_abort - - .align 5 -not_used: - get_bad_stack - bad_save_user_regs - bl do_not_used - -#ifdef CONFIG_USE_IRQ - - .align 5 -irq: - get_irq_stack - irq_save_user_regs - bl do_irq - irq_restore_user_regs - - .align 5 -fiq: - get_fiq_stack - /* someone ought to write a more effective fiq_save_user_regs */ - irq_save_user_regs - bl do_fiq - irq_restore_user_regs - -#else - - .align 5 -irq: - get_bad_stack - bad_save_user_regs - bl do_irq - - .align 5 -fiq: - get_bad_stack - bad_save_user_regs - bl do_fiq - -#endif /* CONFIG_USE_IRQ */ -#endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/cpu/armv7/zynq/u-boot.lds b/arch/arm/cpu/armv7/zynq/u-boot.lds index f2a5965..69500a6 100644 --- a/arch/arm/cpu/armv7/zynq/u-boot.lds +++ b/arch/arm/cpu/armv7/zynq/u-boot.lds @@ -88,7 +88,7 @@ SECTIONS }
/* - * Zynq needs to discard more sections because the user + * Zynq needs to discard these sections because the user * is expected to pass this image on to tools for boot.bin * generation that require them to be dropped. */ diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index e3bf1c2..c77d51e 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -23,46 +23,6 @@ #include <config.h> #include <version.h>
-.globl _start -_start: b reset -#ifdef CONFIG_SPL_BUILD - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - ldr pc, _hang - -_hang: - .word do_hang - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 - .word 0x12345678 /* now 16*4=64 */ -#else - ldr pc, _undefined_instruction - ldr pc, _software_interrupt - ldr pc, _prefetch_abort - ldr pc, _data_abort - ldr pc, _not_used - ldr pc, _irq - ldr pc, _fiq - -_undefined_instruction: .word undefined_instruction -_software_interrupt: .word software_interrupt -_prefetch_abort: .word prefetch_abort -_data_abort: .word data_abort -_not_used: .word not_used -_irq: .word irq -_fiq: .word fiq -_pad: .word 0x12345678 /* now 16*4=64 */ -#endif /* CONFIG_SPL_BUILD */ - - .balignl 16,0xdeadbeef /* ************************************************************************* * @@ -76,26 +36,7 @@ _pad: .word 0x12345678 /* now 16*4=64 */ ************************************************************************* */
reset: /* @@ -166,190 +107,6 @@ cpu_init_crit: mov pc, lr /* back to my caller */ #endif /* !CONFIG_SKIP_LOWLEVEL_INIT || CONFIG_CPU_PXA25X */
-#ifndef CONFIG_SPL_BUILD -/* - ************************************************************************* - * - * Interrupt handling - * - ************************************************************************* - */ -@ -@ IRQ stack frame. -@ -#define S_FRAME_SIZE 72 - -#define S_OLD_R0 68 -#define S_PSR 64 -#define S_PC 60 -#define S_LR 56 -#define S_SP 52 - -#define S_IP 48 -#define S_FP 44 -#define S_R10 40 -#define S_R9 36 -#define S_R8 32 -#define S_R7 28 -#define S_R6 24 -#define S_R5 20 -#define S_R4 16 -#define S_R3 12 -#define S_R2 8 -#define S_R1 4 -#define S_R0 0 - -#define MODE_SVC 0x13 -#define I_BIT 0x80 - -/* - * use bad_save_user_regs for abort/prefetch/undef/swi ... - * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling - */ - - .macro bad_save_user_regs - sub sp, sp, #S_FRAME_SIZE @ carve out a frame on current user stack - stmia sp, {r0 - r12} @ Save user registers (now in svc mode) r0-r12 - - ldr r2, IRQ_STACK_START_IN @ set base 2 words into abort stack - ldmia r2, {r2 - r3} @ get values for "aborted" pc and cpsr (into parm regs) - add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack - - add r5, sp, #S_SP - mov r1, lr - stmia r5, {r0 - r3} @ save sp_SVC, lr_SVC, pc, cpsr - mov r0, sp @ save current stack into r0 (param register) - .endm - - .macro irq_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - add r8, sp, #S_PC @ !!!! R8 NEEDS to be saved !!!! a reserved stack spot would be good. - stmdb r8, {sp, lr}^ @ Calling SP, LR - str lr, [r8, #0] @ Save calling PC - mrs r6, spsr - str r6, [r8, #4] @ Save CPSR - str r0, [r8, #8] @ Save OLD_R0 - mov r0, sp - .endm - - .macro irq_restore_user_regs - ldmia sp, {r0 - lr}^ @ Calling r0 - lr - mov r0, r0 - ldr lr, [sp, #S_PC] @ Get PC - add sp, sp, #S_FRAME_SIZE - subs pc, lr, #4 @ return & move spsr_svc into cpsr - .endm - - .macro get_bad_stack - ldr r13, IRQ_STACK_START_IN @ setup our mode stack (enter in banked mode) - - str lr, [r13] @ save caller lr in position 0 of saved stack - mrs lr, spsr @ get the spsr - str lr, [r13, #4] @ save spsr in position 1 of saved stack - - mov r13, #MODE_SVC @ prepare SVC-Mode - @ msr spsr_c, r13 - msr spsr, r13 @ switch modes, make sure moves will execute - mov lr, pc @ capture return pc - movs pc, lr @ jump to next instruction & switch modes. - .endm - - .macro get_bad_stack_swi - sub r13, r13, #4 @ space on current stack for scratch reg. - str r0, [r13] @ save R0's value. - ldr r0, IRQ_STACK_START_IN @ get data regions start - str lr, [r0] @ save caller lr in position 0 of saved stack - mrs lr, spsr @ get the spsr - str lr, [r0, #4] @ save spsr in position 1 of saved stack - ldr lr, [r0] @ restore lr - ldr r0, [r13] @ restore r0 - add r13, r13, #4 @ pop stack entry - .endm - - .macro get_irq_stack @ setup IRQ stack - ldr sp, IRQ_STACK_START - .endm - - .macro get_fiq_stack @ setup FIQ stack - ldr sp, FIQ_STACK_START - .endm -#endif /* CONFIG_SPL_BUILD */ - -/* - * exception handlers - */ -#ifdef CONFIG_SPL_BUILD - .align 5 -do_hang: - bl hang /* hang and never return */ -#else /* !CONFIG_SPL_BUILD */ - .align 5 -undefined_instruction: - get_bad_stack - bad_save_user_regs - bl do_undefined_instruction - - .align 5 -software_interrupt: - get_bad_stack_swi - bad_save_user_regs - bl do_software_interrupt - - .align 5 -prefetch_abort: - get_bad_stack - bad_save_user_regs - bl do_prefetch_abort - - .align 5 -data_abort: - get_bad_stack - bad_save_user_regs - bl do_data_abort - - .align 5 -not_used: - get_bad_stack - bad_save_user_regs - bl do_not_used - -#ifdef CONFIG_USE_IRQ - - .align 5 -irq: - get_irq_stack - irq_save_user_regs - bl do_irq - irq_restore_user_regs - - .align 5 -fiq: - get_fiq_stack - /* someone ought to write a more effiction fiq_save_user_regs */ - irq_save_user_regs - bl do_fiq - irq_restore_user_regs - -#else - - .align 5 -irq: - get_bad_stack - bad_save_user_regs - bl do_irq - - .align 5 -fiq: - get_bad_stack - bad_save_user_regs - bl do_fiq - -#endif - .align 5 -#endif /* CONFIG_SPL_BUILD */ - - /* * Enable MMU to use DCache as DRAM. * diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 472a595..78e0cb8 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -16,36 +16,6 @@ /* ************************************************************************* * - * Jump vector table as in table 3.1 in [1] - * - ************************************************************************* - */ - - -.globl _start -_start: b reset - ldr pc, _undefined_instruction - ldr pc, _software_interrupt - ldr pc, _prefetch_abort - ldr pc, _data_abort - ldr pc, _not_used - ldr pc, _irq - ldr pc, _fiq - -_undefined_instruction: .word undefined_instruction -_software_interrupt: .word software_interrupt -_prefetch_abort: .word prefetch_abort -_data_abort: .word data_abort -_not_used: .word not_used -_irq: .word irq -_fiq: .word fiq - - .balignl 16,0xdeadbeef - - -/* - ************************************************************************* - * * Startup Code (reset vector) * * do important init only if we don't start from memory! @@ -56,26 +26,7 @@ _fiq: .word fiq ************************************************************************* */
reset: /* @@ -173,167 +124,3 @@ cpu_init_crit: mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */
mov pc, lr - - -/* - ************************************************************************* - * - * Interrupt handling - * - ************************************************************************* - */ - -@ -@ IRQ stack frame. -@ -#define S_FRAME_SIZE 72 - -#define S_OLD_R0 68 -#define S_PSR 64 -#define S_PC 60 -#define S_LR 56 -#define S_SP 52 - -#define S_IP 48 -#define S_FP 44 -#define S_R10 40 -#define S_R9 36 -#define S_R8 32 -#define S_R7 28 -#define S_R6 24 -#define S_R5 20 -#define S_R4 16 -#define S_R3 12 -#define S_R2 8 -#define S_R1 4 -#define S_R0 0 - -#define MODE_SVC 0x13 -#define I_BIT 0x80 - -/* - * use bad_save_user_regs for abort/prefetch/undef/swi ... - * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling - */ - - .macro bad_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - add r8, sp, #S_PC - - ldr r2, IRQ_STACK_START_IN - ldmia r2, {r2 - r4} @ get pc, cpsr, old_r0 - add r0, sp, #S_FRAME_SIZE @ restore sp_SVC - - add r5, sp, #S_SP - mov r1, lr - stmia r5, {r0 - r4} @ save sp_SVC, lr_SVC, pc, cpsr, old_r - mov r0, sp - .endm - - .macro irq_save_user_regs - sub sp, sp, #S_FRAME_SIZE - stmia sp, {r0 - r12} @ Calling r0-r12 - add r8, sp, #S_PC - stmdb r8, {sp, lr}^ @ Calling SP, LR - str lr, [r8, #0] @ Save calling PC - mrs r6, spsr - str r6, [r8, #4] @ Save CPSR - str r0, [r8, #8] @ Save OLD_R0 - mov r0, sp - .endm - - .macro irq_restore_user_regs - ldmia sp, {r0 - lr}^ @ Calling r0 - lr - mov r0, r0 - ldr lr, [sp, #S_PC] @ Get PC - add sp, sp, #S_FRAME_SIZE - subs pc, lr, #4 @ return & move spsr_svc into cpsr - .endm - - .macro get_bad_stack - ldr r13, IRQ_STACK_START_IN @ setup our mode stack - - str lr, [r13] @ save caller lr / spsr - mrs lr, spsr - str lr, [r13, #4] - - mov r13, #MODE_SVC @ prepare SVC-Mode - msr spsr_c, r13 - mov lr, pc - movs pc, lr - .endm - - .macro get_irq_stack @ setup IRQ stack - ldr sp, IRQ_STACK_START - .endm - - .macro get_fiq_stack @ setup FIQ stack - ldr sp, FIQ_STACK_START - .endm - -/* - * exception handlers - */ - .align 5 -undefined_instruction: - get_bad_stack - bad_save_user_regs - bl do_undefined_instruction - - .align 5 -software_interrupt: - get_bad_stack - bad_save_user_regs - bl do_software_interrupt - - .align 5 -prefetch_abort: - get_bad_stack - bad_save_user_regs - bl do_prefetch_abort - - .align 5 -data_abort: - get_bad_stack - bad_save_user_regs - bl do_data_abort - - .align 5 -not_used: - get_bad_stack - bad_save_user_regs - bl do_not_used - -#ifdef CONFIG_USE_IRQ - - .align 5 -irq: - get_irq_stack - irq_save_user_regs - bl do_irq - irq_restore_user_regs - - .align 5 -fiq: - get_fiq_stack - /* someone ought to write a more effiction fiq_save_user_regs */ - irq_save_user_regs - bl do_fiq - irq_restore_user_regs - -#else - - .align 5 -irq: - get_bad_stack - bad_save_user_regs - bl do_irq - - .align 5 -fiq: - get_bad_stack - bad_save_user_regs - bl do_fiq - -#endif diff --git a/arch/arm/cpu/u-boot-spl.lds b/arch/arm/cpu/u-boot-spl.lds index 3e88668..4beddf0 100644 --- a/arch/arm/cpu/u-boot-spl.lds +++ b/arch/arm/cpu/u-boot-spl.lds @@ -18,6 +18,7 @@ SECTIONS .text : { __image_copy_start = .; + *(.vectors) CPUDIR/start.o (.text*) *(.text*) } diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds index 33c1f99..a7728e0 100644 --- a/arch/arm/cpu/u-boot.lds +++ b/arch/arm/cpu/u-boot.lds @@ -18,6 +18,7 @@ SECTIONS .text : { *(.__image_copy_start) + *(.vectors) CPUDIR/start.o (.text*) *(.text*) } diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index e035d6a..585f1f7 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -11,7 +11,7 @@ lib-$(CONFIG_USE_PRIVATE_LIBGCC) += _ashldi3.o _ashrdi3.o _divsi3.o \ ifdef CONFIG_ARM64 obj-y += crt0_64.o else -obj-y += crt0.o +obj-y += vectors.o crt0.o endif
ifndef CONFIG_SPL_BUILD diff --git a/arch/arm/lib/vectors.S b/arch/arm/lib/vectors.S new file mode 100644 index 0000000..d68cc47 --- /dev/null +++ b/arch/arm/lib/vectors.S @@ -0,0 +1,291 @@ +/* + * vectors - Generic ARM exception table code + * + * Copyright (c) 1998 Dan Malek dmalek@jlc.net + * Copyright (c) 1999 Magnus Damm <kieraypc01.p.y.kie.era.ericsson.se> + * Copyright (c) 2000 Wolfgang Denk wd@denx.de + * Copyright (c) 2001 Alex Züpke azu@sysgo.de + * Copyright (c) 2001 Marius Gröger mag@sysgo.de + * Copyright (c) 2002 Alex Züpke azu@sysgo.de + * Copyright (c) 2002 Gary Jennejohn garyj@denx.de + * Copyright (c) 2002 Kyle Harris kharris@nexus-tech.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + ************************************************************************* + * + * Symbol _start is referenced elsewhere, so make it global + * + ************************************************************************* + */ + +.globl _start + +/* + ************************************************************************* + * + * Vectors have their own section so linker script can map them easily + * + ************************************************************************* + */ + + .section ".vectors", "x" + +/* + ************************************************************************* + * + * Exception vectors as described in ARM reference manuals + * + * Uses indirect branch to allow reaching handlers anywhere in memory. + * + ************************************************************************* + */ + +_start: + +#ifdef CONFIG_SYS_DV_NOR_BOOT_CFG + .word CONFIG_SYS_DV_NOR_BOOT_CFG +#endif + +_start: + ldr pc, _reset + ldr pc, _undefined_instruction + ldr pc, _software_interrupt + ldr pc, _prefetch_abort + ldr pc, _data_abort + ldr pc, _not_used + ldr pc, _irq + ldr pc, _fiq + +/* + ************************************************************************* + * + * Indirect vectors table + * + * Symbols referenced here must be defined somewhere else + * + ************************************************************************* + */ + + .globl _undefined_instruction + .globl _software_interrupt + .globl _prefetch_abort + .globl _data_abort + .globl _not_used + .globl _irq + .globl _fiq + +_reset: .word reset +_undefined_instruction: .word undefined_instruction +_software_interrupt: .word software_interrupt +_prefetch_abort: .word prefetch_abort +_data_abort: .word data_abort +_not_used: .word not_used +_irq: .word irq +_fiq: .word fiq + + .balignl 16,0xdeadbeef + +/* + ************************************************************************* + * + * Interrupt handling + * + ************************************************************************* + */ + +/* SPL interrupt handling: just hang */ + +#ifdef CONFIG_SPL_BUILD + + .align 5 +undefined_instruction: +software_interrupt: +prefetch_abort: +data_abort: +not_used: +irq: +fiq: + +1: + bl 1b /* hang and never return */ + +#else /* !CONFIG_SPL_BUILD */ + +/* IRQ stack memory (calculated at run-time) + 8 bytes */ +.globl IRQ_STACK_START_IN +IRQ_STACK_START_IN: + .word 0x0badc0de + +#ifdef CONFIG_USE_IRQ +/* IRQ stack memory (calculated at run-time) */ +.globl IRQ_STACK_START +IRQ_STACK_START: + .word 0x0badc0de + +/* IRQ stack memory (calculated at run-time) */ +.globl FIQ_STACK_START +FIQ_STACK_START: + .word 0x0badc0de + +#endif /* CONFIG_USE_IRQ */ + +@ +@ IRQ stack frame. +@ +#define S_FRAME_SIZE 72 + +#define S_OLD_R0 68 +#define S_PSR 64 +#define S_PC 60 +#define S_LR 56 +#define S_SP 52 + +#define S_IP 48 +#define S_FP 44 +#define S_R10 40 +#define S_R9 36 +#define S_R8 32 +#define S_R7 28 +#define S_R6 24 +#define S_R5 20 +#define S_R4 16 +#define S_R3 12 +#define S_R2 8 +#define S_R1 4 +#define S_R0 0 + +#define MODE_SVC 0x13 +#define I_BIT 0x80 + +/* + * use bad_save_user_regs for abort/prefetch/undef/swi ... + * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling + */ + + .macro bad_save_user_regs + @ carve out a frame on current user stack + sub sp, sp, #S_FRAME_SIZE + stmia sp, {r0 - r12} @ Save user registers (now in svc mode) r0-r12 + ldr r2, IRQ_STACK_START_IN + @ get values for "aborted" pc and cpsr (into parm regs) + ldmia r2, {r2 - r3} + add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack + add r5, sp, #S_SP + mov r1, lr + stmia r5, {r0 - r3} @ save sp_SVC, lr_SVC, pc, cpsr + mov r0, sp @ save current stack into r0 (param register) + .endm + + .macro irq_save_user_regs + sub sp, sp, #S_FRAME_SIZE + stmia sp, {r0 - r12} @ Calling r0-r12 + @ !!!! R8 NEEDS to be saved !!!! a reserved stack spot would be good. + add r8, sp, #S_PC + stmdb r8, {sp, lr}^ @ Calling SP, LR + str lr, [r8, #0] @ Save calling PC + mrs r6, spsr + str r6, [r8, #4] @ Save CPSR + str r0, [r8, #8] @ Save OLD_R0 + mov r0, sp + .endm + + .macro irq_restore_user_regs + ldmia sp, {r0 - lr}^ @ Calling r0 - lr + mov r0, r0 + ldr lr, [sp, #S_PC] @ Get PC + add sp, sp, #S_FRAME_SIZE + subs pc, lr, #4 @ return & move spsr_svc into cpsr + .endm + + .macro get_bad_stack + ldr r13, IRQ_STACK_START_IN @ setup our mode stack + + str lr, [r13] @ save caller lr in position 0 of saved stack + mrs lr, spsr @ get the spsr + str lr, [r13, #4] @ save spsr in position 1 of saved stack + mov r13, #MODE_SVC @ prepare SVC-Mode + @ msr spsr_c, r13 + msr spsr, r13 @ switch modes, make sure moves will execute + mov lr, pc @ capture return pc + movs pc, lr @ jump to next instruction & switch modes. + .endm + + .macro get_irq_stack @ setup IRQ stack + ldr sp, IRQ_STACK_START + .endm + + .macro get_fiq_stack @ setup FIQ stack + ldr sp, FIQ_STACK_START + .endm + +/* + * exception handlers + */ + + .align 5 +undefined_instruction: + get_bad_stack + bad_save_user_regs + bl do_undefined_instruction + + .align 5 +software_interrupt: + get_bad_stack + bad_save_user_regs + bl do_software_interrupt + + .align 5 +prefetch_abort: + get_bad_stack + bad_save_user_regs + bl do_prefetch_abort + + .align 5 +data_abort: + get_bad_stack + bad_save_user_regs + bl do_data_abort + + .align 5 +not_used: + get_bad_stack + bad_save_user_regs + bl do_not_used + +#ifdef CONFIG_USE_IRQ + + .align 5 +irq: + get_irq_stack + irq_save_user_regs + bl do_irq + irq_restore_user_regs + + .align 5 +fiq: + get_fiq_stack + /* someone ought to write a more effiction fiq_save_user_regs */ + irq_save_user_regs + bl do_fiq + irq_restore_user_regs + +#else + + .align 5 +irq: + get_bad_stack + bad_save_user_regs + bl do_irq + + .align 5 +fiq: + get_bad_stack + bad_save_user_regs + bl do_fiq + +#endif /* CONFIG_USE_IRQ */ + +#endif /* CONFIG_SPL_BUILD */ diff --git a/board/compulab/cm_t335/u-boot.lds b/board/compulab/cm_t335/u-boot.lds index 0984dfe..c8ab716 100644 --- a/board/compulab/cm_t335/u-boot.lds +++ b/board/compulab/cm_t335/u-boot.lds @@ -18,6 +18,7 @@ SECTIONS .text : { *(.__image_copy_start) + *(.vectors) CPUDIR/start.o (.text*) board/compulab/cm_t335/built-in.o (.text*) *(.text*) diff --git a/board/freescale/mx31ads/u-boot.lds b/board/freescale/mx31ads/u-boot.lds index 6da1d4b..61b83bf 100644 --- a/board/freescale/mx31ads/u-boot.lds +++ b/board/freescale/mx31ads/u-boot.lds @@ -22,6 +22,7 @@ SECTIONS /* WARNING - the following is hand-optimized to fit within */ /* the sector layout of our flash chips! XXX FIXME XXX */
+ * (.vectors) arch/arm/cpu/arm1136/start.o (.text*) board/freescale/mx31ads/built-in.o (.text*) arch/arm/lib/built-in.o (.text*) diff --git a/board/ti/am335x/u-boot.lds b/board/ti/am335x/u-boot.lds index a9e3d34..2c5a0f8 100644 --- a/board/ti/am335x/u-boot.lds +++ b/board/ti/am335x/u-boot.lds @@ -34,6 +34,7 @@ SECTIONS .text : { *(.__image_copy_start) + *(.vectors) CPUDIR/start.o (.text*) board/ti/am335x/built-in.o (.text*) *(.text*)
On Tuesday, April 15, 2014 at 04:13:49 PM, Albert ARIBAUD wrote:
PXA start.S has a PXA (variant) specific check in start.S. Move it to cpuinfo.c.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
On Tue, 2014-04-15 at 16:13 +0200, Albert ARIBAUD wrote:
[ ... deeply nested 'git send-email' thread ... ]
May I suggest the following git config option?
[sendemail] chainreplyto = false
This creates "shallow threads", and improves consumption on the receivers' side, allowing to more quickly tell patches from review feedback, and better follow the series' structure.
Just a thought, not picking at this specific submission, only following up when I saw one of those occurances (thus the list reply, too, for the archives) ...
virtually yours Gerhard Sittig
Hi Gerhard,
Thanks for th tip! Setting added on my ~/.gitconfig.
Amicalement,
On Tue, 15 Apr 2014 16:13:46 +0200, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
This series aims at refactoring start.S files. Some of these files contain cache-related or cpu-reset-related core, which is moved where it belongs. Useless symbols are removed, and finally, exception vector code, common across all ARM CPUs, is moved in its own file.
At this point, the start.S files only contain CPU-specific reset sequences.
Changes in v3:
- factorized SPL/non-SPL code
- fixed socfpga_cyclone5 IRQ setting in save_boot_params
Changes in v2:
- fixed checkpatch issues in arch/arm/cpu/arm946es/cpu.c
- fixed checkpatch issues in arch/arm/cpu/sa1100/cpu.c
- rebased onto u-boot-arm/master (de4fdfc1)
- adjusted comment in Zynq linker script
Albert ARIBAUD (5): arm1136: move cache code from start.S to cache.c arm: move reset_cpu from start.S into cpu.c arm: pxa: move SP check from start.S to cpuinfo.c arm: remove unused _end_vect and _vectors_end symbols arm: move exception handling out of start.S files
arch/arm/cpu/arm1136/start.S | 254 +----------------------- arch/arm/cpu/arm1176/start.S | 198 +------------------ arch/arm/cpu/arm720t/start.S | 229 +--------------------- arch/arm/cpu/arm920t/ep93xx/u-boot.lds | 3 +- arch/arm/cpu/arm920t/start.S | 216 +-------------------- arch/arm/cpu/arm926ejs/mxs/start.S | 92 +-------- arch/arm/cpu/arm926ejs/spear/start.S | 27 +-- arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds | 1 + arch/arm/cpu/arm926ejs/start.S | 262 +------------------------ arch/arm/cpu/arm946es/cpu.c | 13 ++ arch/arm/cpu/arm946es/start.S | 246 +---------------------- arch/arm/cpu/arm_intcm/start.S | 228 +--------------------- arch/arm/cpu/armv7/socfpga/lowlevel_init.S | 15 +- arch/arm/cpu/armv7/start.S | 253 +----------------------- arch/arm/cpu/armv7/zynq/u-boot.lds | 2 +- arch/arm/cpu/pxa/cpuinfo.c | 6 + arch/arm/cpu/pxa/start.S | 253 +----------------------- arch/arm/cpu/sa1100/cpu.c | 14 ++ arch/arm/cpu/sa1100/start.S | 225 +-------------------- arch/arm/cpu/u-boot-spl.lds | 1 + arch/arm/cpu/u-boot.lds | 1 + arch/arm/lib/Makefile | 2 +- arch/arm/lib/cache.c | 13 +- arch/arm/lib/vectors.S | 291 ++++++++++++++++++++++++++++ board/compulab/cm_t335/u-boot.lds | 1 + board/freescale/mx31ads/u-boot.lds | 1 + board/ti/am335x/u-boot.lds | 1 + 27 files changed, 359 insertions(+), 2489 deletions(-) create mode 100644 arch/arm/lib/vectors.S
Applied to u-boot-arm/master.
Amicalement,
Albert ARIBAUD
Gerhard Sittig
