[U-Boot] [PATCH 0/3] efi_loader: ARM: add support for ARMV7_NONSEC=y
This series makes it possible to run EFI applications in non-secure mode. It allows me to run OpenBSD on the imx7d-pico-pi board while using the PSCI implementation provided by U-Boot.
Mark Kettenis (3): ARM: HYP/non-sec: save and restore stack efi_loader: ARM: run EFI payloads non-secure Revert "efi_loader: no support for ARMV7_NONSEC=y"
arch/arm/cpu/armv7/nonsec_virt.S | 6 ++++-- cmd/bootefi.c | 32 ++++++++++++++++++++++++++++++++ doc/README.uefi | 2 -- lib/efi_loader/Kconfig | 2 -- 4 files changed, 36 insertions(+), 6 deletions(-)
The current code that switches into HYP mode doesn't bother to set up a stack for HYP mode. This doesn't work for EFI applications as they expect a usable stack. Fix this by saving the stack pointer before switching and use it to set SP_hyp from monitor. This restores the stack pointer when we drop into HYP mode.
Signed-off-by: Mark Kettenis kettenis@openbsd.org --- arch/arm/cpu/armv7/nonsec_virt.S | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/nonsec_virt.S b/arch/arm/cpu/armv7/nonsec_virt.S index 56bdba1d38..246d817340 100644 --- a/arch/arm/cpu/armv7/nonsec_virt.S +++ b/arch/arm/cpu/armv7/nonsec_virt.S @@ -52,9 +52,9 @@ _secure_monitor: bl psci_stack_setup
@ Configure the PSCI backend - push {r0, r1, r2, ip} + push {r0, r1, r2, r3, ip} bl psci_arch_init - pop {r0, r1, r2, ip} + pop {r0, r1, r2, r3, ip} #endif
#ifdef CONFIG_ARM_ERRATA_773022 @@ -80,6 +80,7 @@ _secure_monitor: #ifdef CONFIG_ARMV7_VIRT orreq r5, r5, #0x100 @ allow HVC instruction moveq r6, #HYP_MODE @ Enter the kernel as HYP + msreq sp_hyp, r3 @ restore saved stack #endif
mcr p15, 0, r5, c1, c1, 0 @ write SCR (with NS bit set) @@ -106,6 +107,7 @@ ENTRY(_do_nonsec_entry) mov r0, r1 mov r1, r2 mov r2, r3 + mov r3, sp smc #0 ENDPROC(_do_nonsec_entry)
Can we be sure that the stack in MON is usable from HYP?
Alex
- push {r0, r1, r2, r3, ip} bl psci_arch_init
- pop {r0, r1, r2, r3, ip}
#endif
- msreq sp_hyp, r3 @ restore saved stack
#endif
- mov r3, sp smc #0
From: Alexander Graf agraf@suse.de Date: Tue, 12 Jun 2018 20:46:02 +0200
I think so. It is the stack that U-Boot sets up for itself in normal memory. As far as I can tell arm64 re-uses this stack when dropping down into EL2 as well.
#endif
#endif
- mov r3, sp smc #0
Well, the question is whether it's secure or non-secure memory. Usually the DRAM controller can be configured to have a window of RAM only available to secure and I'd certainly hope that at least the U-Boot parts that are preserved in EL3 live in such a secured area :)
Alex
From: Alexander Graf agraf@suse.de Date: Tue, 12 Jun 2018 22:32:38 +0200
The U-Boot PSCI implementation ends up in a special memory region and uses a separate stack in that same region. Whether that memory region is marked as secure in hardware depends on board-specific code. On the i.MX7D board I'm playing with it ends up in on on-chip RAM but I'm not sure the current U-Boot code actually marks that region as secure. In principle the PSCI code is all that is preserved for MON/EL3. My diffs really don't change how that works. The code is already there and it already works (I assume) when booting Linux kernels in non-secure mode the traditional (non-EFI) way.
If desired (and possible) switch into HYP mode or non-secure SVC mode before calling the entry point of an EFI application. This allows U-Boot to provide a usable PSCI implementation and makes it possible to boot kernels into hypervisor mode using an EFI bootloader.
Based on diffs from Heinrich Schuchardt and Alexander Graf.
Signed-off-by: Mark Kettenis kettenis@openbsd.org --- cmd/bootefi.c | 32 ++++++++++++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 707d159bac..a5d144d9a4 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -20,6 +20,11 @@ #include <asm-generic/unaligned.h> #include <linux/linkage.h>
+#ifdef CONFIG_ARM +#include <asm/armv7.h> +#include <asm/secure.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
#define OBJ_LIST_NOT_INITIALIZED 1 @@ -189,6 +194,18 @@ static efi_status_t efi_run_in_el2(EFIAPI efi_status_t (*entry)( } #endif
+#ifdef CONFIG_ARMV7_NONSEC +static efi_status_t efi_run_in_hyp(EFIAPI efi_status_t (*entry)( + efi_handle_t image_handle, struct efi_system_table *st), + efi_handle_t image_handle, struct efi_system_table *st) +{ + /* Enable caches again */ + dcache_enable(); + + return efi_do_enter(image_handle, st, entry); +} +#endif + /* Carve out DT reserved memory ranges */ static efi_status_t efi_carve_out_dt_rsv(void *fdt) { @@ -338,6 +355,21 @@ static efi_status_t do_bootefi_exec(void *efi, } #endif
+#ifdef CONFIG_ARMV7_NONSEC + if (armv7_boot_nonsec()) { + dcache_disable(); /* flush cache before switch to HYP */ + + armv7_init_nonsec(); + secure_ram_addr(_do_nonsec_entry)(efi_run_in_hyp, + (uintptr_t)entry, + (uintptr_t)loaded_image_info_obj.handle, + (uintptr_t)&systab); + + /* Should never reach here, efi exits with longjmp */ + while (1) { } + } +#endif + ret = efi_do_enter(loaded_image_info_obj.handle, &systab, entry);
exit:
+#ifdef CONFIG_ARM
Is this the correct guard? CONFIG_ARM is also set for AArch64 for example. Maybe use CONFIG_ARMV7_NONSEC instead?
- /* Enable caches again */
- dcache_enable();
Are you sure the dcache_enable/disable bits do what you want? IIRC the situation on armv7 wasn't quite as obvious.
Alex
- return efi_do_enter(image_handle, st, entry);
+} +#endif
- if (armv7_boot_nonsec()) {
(uintptr_t)entry,
while (1) { }
- ret = efi_do_enter(loaded_image_info_obj.handle, &systab, entry);
exit:
This reverts commit c524997acb3d322e1bbd36c06ad02ef589705e7c.
Booting ARMv7 in non-secure mode using bootefi works now.
Signed-off-by: Mark Kettenis kettenis@openbsd.org --- doc/README.uefi | 2 -- lib/efi_loader/Kconfig | 2 -- 2 files changed, 4 deletions(-)
diff --git a/doc/README.uefi b/doc/README.uefi index d4031ef8e8..6b9759cfed 100644 --- a/doc/README.uefi +++ b/doc/README.uefi @@ -329,8 +329,6 @@ This driver is only available if U-Boot is configured with * persistence * runtime support
-* support bootefi booting ARMv7 in non-secure mode (CONFIG_ARMV7_NONSEC=y) - ## Links
* [1](http://uefi.org/specifications) diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index df58e633d1..ce6a09f0b4 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -1,8 +1,6 @@ config EFI_LOADER bool "Support running EFI Applications in U-Boot" depends on (ARM || X86 || RISCV) && OF_LIBFDT - # We do not support bootefi booting ARMv7 in non-secure mode - depends on !ARMV7_NONSEC # We need EFI_STUB_64BIT to be set on x86_64 with EFI_STUB depends on !EFI_STUB || !X86_64 || EFI_STUB_64BIT # We need EFI_STUB_32BIT to be set on x86_32 with EFI_STUB
This is the output I got with your patches when trying to boot my BananaPi:
=> bootefi hello Scanning disk mmc@01c0f000.blk... Found 3 disks WARNING: booting without device tree ## Starting EFI application at 42000000 ... WARNING: using memory device/image path, this may confuse some payloads!
U-Boot SPL 2018.07-rc1-D001-00104-g5b859da7ca8 (Jun 12 2018 - 19:52:34 +0200) DRAM:
Where able to run bootefi hello on your board? Which board are you on?
Best regards
Heinrich
From: Heinrich Schuchardt xypron.glpk@gmx.de Date: Tue, 12 Jun 2018 20:00:28 +0200
I can run helloworld.efi on my board with this diff.
Technexion PICO-PI-IMX7; it's a board with an i.MX7D SoC.
I have a Banana Pi as well, so I'll give that one a go tomorrow.
I could reproduce that. For some reason r3 gets clobbered and we still end up with a broken stack. Posted v2 that simply migrates SP_svc to SP_hyp. That seems to work on both imx7 and sun7i.
Alexander Graf
Mark Kettenis
Mark Kettenis
