[U-Boot] [PATCH v2] ARC: Move ENV_SIZE and ENV_OFFSET to Kconfig
Join the party of some ARM boards and drop more items from include/configs/xxx.h.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com Cc: Michal Simek michal.simek@xilinx.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com ---
Changes in v2:
* Default ENV_OFFSET defined specially for ARC but not all
configs/emsdp_defconfig | 1 + configs/iot_devkit_defconfig | 1 + configs/tb100_defconfig | 1 + env/Kconfig | 4 +++- include/configs/axs10x.h | 1 - include/configs/emsdp.h | 1 - include/configs/hsdk.h | 2 -- include/configs/iot_devkit.h | 1 - include/configs/nsim.h | 6 ------ include/configs/tb100.h | 6 ------ 10 files changed, 6 insertions(+), 18 deletions(-)
diff --git a/configs/emsdp_defconfig b/configs/emsdp_defconfig index 273334b05d..64281d0529 100644 --- a/configs/emsdp_defconfig +++ b/configs/emsdp_defconfig @@ -3,6 +3,7 @@ CONFIG_ISA_ARCV2=y CONFIG_CPU_ARCEM6=y CONFIG_TARGET_EMSDP=y CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_ENV_SIZE=0x1000 CONFIG_SYS_CLK_FREQ=40000000 # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_VERSION_VARIABLE=y diff --git a/configs/iot_devkit_defconfig b/configs/iot_devkit_defconfig index 1b6dd9e55a..24bbe3fc5d 100644 --- a/configs/iot_devkit_defconfig +++ b/configs/iot_devkit_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_ICACHE_OFF=y CONFIG_SYS_DCACHE_OFF=y CONFIG_TARGET_IOT_DEVKIT=y CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_ENV_SIZE=0x1000 CONFIG_SYS_CLK_FREQ=16000000 CONFIG_LOCALVERSION="-iotdk-1.0" # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set diff --git a/configs/tb100_defconfig b/configs/tb100_defconfig index f30053d4de..e3837d92e7 100644 --- a/configs/tb100_defconfig +++ b/configs/tb100_defconfig @@ -1,6 +1,7 @@ CONFIG_ARC=y CONFIG_TARGET_TB100=y CONFIG_SYS_TEXT_BASE=0x84000000 +CONFIG_ENV_SIZE=0x800 CONFIG_SYS_CLK_FREQ=500000000 CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/env/Kconfig b/env/Kconfig index 9011109b47..c22cbbdadc 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -431,7 +431,7 @@ config ENV_EXT4_FILE It's a string of the EXT4 file name. This file use to store the environment (explicit path to the file)
-if ARCH_ROCKCHIP || ARCH_SUNXI || ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_VERSAL +if ARCH_ROCKCHIP || ARCH_SUNXI || ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_VERSAL || ARC
config ENV_OFFSET hex "Environment Offset" @@ -441,6 +441,7 @@ config ENV_OFFSET default 0x88000 if ARCH_SUNXI default 0xE0000 if ARCH_ZYNQ default 0x1E00000 if ARCH_ZYNQMP + default 0 if ARC help Offset from the start of the device (or partition)
@@ -449,6 +450,7 @@ config ENV_SIZE default 0x40000 if ENV_IS_IN_SPI_FLASH && ARCH_ZYNQMP default 0x20000 if ARCH_SUNXI || ARCH_ZYNQ default 0x8000 if ARCH_ROCKCHIP || ARCH_ZYNQMP || ARCH_VERSAL + default 0x4000 if ARC help Size of the environment storage area
diff --git a/include/configs/axs10x.h b/include/configs/axs10x.h index 9452b06771..24afbc8fe5 100644 --- a/include/configs/axs10x.h +++ b/include/configs/axs10x.h @@ -62,7 +62,6 @@ /* * Environment settings */ -#define CONFIG_ENV_SIZE SZ_16K #define CONFIG_EXTRA_ENV_SETTINGS \ "upgrade=if mmc rescan && " \ "fatload mmc 0:1 ${loadaddr} u-boot-update.img && " \ diff --git a/include/configs/emsdp.h b/include/configs/emsdp.h index 9a205edc7c..44614138f8 100644 --- a/include/configs/emsdp.h +++ b/include/configs/emsdp.h @@ -24,7 +24,6 @@ /* * Environment */ -#define CONFIG_ENV_SIZE SZ_4K #define CONFIG_BOOTFILE "app.bin" #define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR
diff --git a/include/configs/hsdk.h b/include/configs/hsdk.h index 94c88b29f1..4755567a2d 100644 --- a/include/configs/hsdk.h +++ b/include/configs/hsdk.h @@ -57,8 +57,6 @@ /* * Environment settings */ -#define CONFIG_ENV_SIZE SZ_16K - #define CONFIG_EXTRA_ENV_SETTINGS \ "upgrade=if mmc rescan && " \ "fatload mmc 0:1 ${loadaddr} u-boot-update.scr && " \ diff --git a/include/configs/iot_devkit.h b/include/configs/iot_devkit.h index 4ffe1141d9..4b110bb9d8 100644 --- a/include/configs/iot_devkit.h +++ b/include/configs/iot_devkit.h @@ -77,7 +77,6 @@ /* * Environment */ -#define CONFIG_ENV_SIZE SZ_4K #define CONFIG_BOOTFILE "app.bin" #define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR
diff --git a/include/configs/nsim.h b/include/configs/nsim.h index c3f34a91e4..61217bbe79 100644 --- a/include/configs/nsim.h +++ b/include/configs/nsim.h @@ -24,12 +24,6 @@ #define CONFIG_SYS_BOOTM_LEN SZ_32M #define CONFIG_SYS_LOAD_ADDR 0x82000000
-/* - * Environment settings - */ -#define CONFIG_ENV_SIZE SZ_512 -#define CONFIG_ENV_OFFSET 0 - /* * Environment configuration */ diff --git a/include/configs/tb100.h b/include/configs/tb100.h index 96e5b6315c..a761c37335 100644 --- a/include/configs/tb100.h +++ b/include/configs/tb100.h @@ -52,12 +52,6 @@ * Command line configuration */
-/* - * Environment settings - */ -#define CONFIG_ENV_SIZE SZ_2K -#define CONFIG_ENV_OFFSET 0 - /* * Environment configuration */
Alexey Brodkin
