[PATCH V2] usb: ehci-mx6: Enable OTG detection on imx8mm and imx8mn
The imx8mm and imx8mn appear compatible with imx7d-usb flags in the OTG driver. If the dr_mode is defined as host or peripheral, the device appears to operate correctly, however the auto host/peripheral detection results in an error.
The solution isn't just adding checks for imx8mm and imx8mn to the check for imx7, because the USB clock needs to be running to read from the USBNC_PHY_STATUS_OFFSET register or it will hang.
The init_type in both priv and plat data are the same, so it doesn't make sense to configure the data in the plat data and copy the data to priv when priv can be configured directly. Instead, rename ehci_usb_of_to_plat to ehci_usb_dr_mode and call it from the probe functions after the clocks are enabled, but before the data is required.
With that added, the additional checks for imx8mm and imx8mn will allow reading the register to automatically determine the state (host or device) of the OTG controller.
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Rename ehci_usb_of_to_plat to ehci_usb_dr_mode and call it from the probe after the clocks are enabled, but before the data is needed.
diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 1bd6147c76..f2a34b7f06 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -513,7 +513,7 @@ static const struct ehci_ops mx6_ehci_ops = {
static int ehci_usb_phy_mode(struct udevice *dev) { - struct usb_plat *plat = dev_get_plat(dev); + struct ehci_mx6_priv_data *priv = dev_get_priv(dev); void *__iomem addr = dev_read_addr_ptr(dev); void *__iomem phy_ctrl, *__iomem phy_status; const void *blob = gd->fdt_blob; @@ -540,18 +540,18 @@ static int ehci_usb_phy_mode(struct udevice *dev) val = readl(phy_ctrl);
if (val & USBPHY_CTRL_OTG_ID) - plat->init_type = USB_INIT_DEVICE; + priv->init_type = USB_INIT_DEVICE; else - plat->init_type = USB_INIT_HOST; - } else if (is_mx7()) { + priv->init_type = USB_INIT_HOST; + } else if (is_mx7() || is_imx8mm() || is_imx8mn()) { phy_status = (void __iomem *)(addr + USBNC_PHY_STATUS_OFFSET); val = readl(phy_status);
if (val & USBNC_PHYSTATUS_ID_DIG) - plat->init_type = USB_INIT_DEVICE; + priv->init_type = USB_INIT_DEVICE; else - plat->init_type = USB_INIT_HOST; + priv->init_type = USB_INIT_HOST; } else { return -EINVAL; } @@ -559,19 +559,19 @@ static int ehci_usb_phy_mode(struct udevice *dev) return 0; }
-static int ehci_usb_of_to_plat(struct udevice *dev) +static int ehci_usb_dr_mode(struct udevice *dev) { - struct usb_plat *plat = dev_get_plat(dev); + struct ehci_mx6_priv_data *priv = dev_get_priv(dev); enum usb_dr_mode dr_mode;
dr_mode = usb_get_dr_mode(dev_ofnode(dev));
switch (dr_mode) { case USB_DR_MODE_HOST: - plat->init_type = USB_INIT_HOST; + priv->init_type = USB_INIT_HOST; break; case USB_DR_MODE_PERIPHERAL: - plat->init_type = USB_INIT_DEVICE; + priv->init_type = USB_INIT_DEVICE; break; case USB_DR_MODE_OTG: case USB_DR_MODE_UNKNOWN: @@ -639,10 +639,8 @@ static int mx6_parse_dt_addrs(struct udevice *dev)
static int ehci_usb_probe(struct udevice *dev) { - struct usb_plat *plat = dev_get_plat(dev); struct usb_ehci *ehci = dev_read_addr_ptr(dev); struct ehci_mx6_priv_data *priv = dev_get_priv(dev); - enum usb_init_type type = plat->init_type; struct ehci_hccr *hccr; struct ehci_hcor *hcor; int ret; @@ -660,8 +658,6 @@ static int ehci_usb_probe(struct udevice *dev) return ret;
priv->ehci = ehci; - priv->init_type = type; - priv->phy_type = usb_get_phy_mode(dev_ofnode(dev));
#if CONFIG_IS_ENABLED(CLK) ret = clk_get_by_index(dev, 0, &priv->clk); @@ -677,6 +673,11 @@ static int ehci_usb_probe(struct udevice *dev) mdelay(1); #endif
+ ret = ehci_usb_dr_mode(dev); + if (ret) + goto err_clk; + priv->phy_type = usb_get_phy_mode(dev_ofnode(dev)); + #if CONFIG_IS_ENABLED(DM_REGULATOR) ret = device_get_supply_regulator(dev, "vbus-supply", &priv->vbus_supply); @@ -700,7 +701,7 @@ static int ehci_usb_probe(struct udevice *dev) #if CONFIG_IS_ENABLED(DM_REGULATOR) if (priv->vbus_supply) { ret = regulator_set_enable(priv->vbus_supply, - (type == USB_INIT_DEVICE) ? + (priv->init_type == USB_INIT_DEVICE) ? false : true); if (ret && ret != -ENOSYS) { printf("Error enabling VBUS supply (ret=%i)\n", ret); @@ -785,11 +786,9 @@ U_BOOT_DRIVER(usb_mx6) = { .name = "ehci_mx6", .id = UCLASS_USB, .of_match = mx6_usb_ids, - .of_to_plat = ehci_usb_of_to_plat, .probe = ehci_usb_probe, .remove = ehci_usb_remove, .ops = &ehci_usb_ops, - .plat_auto = sizeof(struct usb_plat), .priv_auto = sizeof(struct ehci_mx6_priv_data), .flags = DM_FLAG_ALLOC_PRIV_DMA, };
Hi Adam,
Tested "ums 0 mmc 0" on a imx7s-warp. It still works fine:
Tested-by: Fabio Estevam festevam@gmail.com
} else if (is_mx7() || is_imx8mm() || is_imx8mn()) { phy_status = (void __iomem *)(addr + USBNC_PHY_STATUS_OFFSET); val = readl(phy_status); if (val & USBNC_PHYSTATUS_ID_DIG)
struct ehci_mx6_priv_data *priv = dev_get_priv(dev); enum usb_dr_mode dr_mode; dr_mode = usb_get_dr_mode(dev_ofnode(dev)); switch (dr_mode) { case USB_DR_MODE_HOST:
priv->ehci = ehci;
if (ret)
goto err_clk;
2.32.0
Adam,
How are you testing this for IMX8MM or IMX8MN?
Best Regards,
Tim
priv->ehci = ehci;
if (ret)
goto err_clk;
(priv->init_type ==
USB_INIT_DEVICE) ?
ret);
2.32.0
Adam,
I ran "ums 0 mmc 2" to test peripheral mode and verified that I could see the corresponding MMC device appear on my host machine. I actually burned an image to the eMMC and I was able to get Linux to run the eMMC I burned.
I connected a USB host adapter that grounds the ID pin and ran "usb start" to test for mass storage devices, and did simple tests like "fatls usb 0" to verify I could read the thumb drive.
I had to enable power-domain support, USB, mass storage, and a few other items in my config file to get it all to work. I'm traveling, so I won't be able to give you my exact config options that I enabled.
adam
Best Regards,
Tim
priv->ehci = ehci;
if (ret)
goto err_clk;
2.32.0
Adam,
Adam,
Thanks - It was the various configs that I was having trouble with... there are a bunch of dependencies that are not obvious making me think something else was still missing.
Tested-By: Tim Harvey tharvey@gateworks.com on imx8mm-venice-gw73xx-0x
I tested gadget mode via ums as well as host via asix_eth and this was my defconfig diff for testing: diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index 822324766843..36a16866f1a0 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -48,6 +48,8 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_UUID=y @@ -97,6 +99,8 @@ CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y CONFIG_DM_PMIC=y CONFIG_DM_PMIC_BD71837=y CONFIG_SPL_DM_PMIC_BD71837=y @@ -112,5 +116,21 @@ CONFIG_SYSRESET_PSCI=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_IMX_TMU=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_LAN75XX=y +CONFIG_USB_ETHER_LAN78XX=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Gateworks" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_IMX_WATCHDOG=y CONFIG_HEXDUMP=y
Best Regards,
Tim
priv->ehci = ehci;
I'm not sure this is correct. There is also this: https://elixir.bootlin.com/u-boot/v2022.01-rc4/source/drivers/usb/host/usb-u...
Which won't work anymore. usb_setup_ehci_gadget() is called from usb_gadget_register_driver() in ci_udc.c. The latter is the one used on the imx, right? But I might be wrong. I'm still trying to figure out how this all works together, because I also try to get OTG running on the dwc3 driver. It looks like the ci_udc.c is special here, and I wonder how a transition to UCLASS_USB_GADGET_GENERIC might look like for this driver.
-michael
priv->ehci = ehci;
Michael,
Further down in the code, you should see: priv->phy_type = usb_get_phy_mode(dev_ofnode(dev));
This driver really isn't changing anything, it's just an order of operations. Previously there was a separate that was being called to determine the init_type as being either a peripheral or host. If it wasn't explicitly set in the device tree, the helper function would query a register, however, on the imx8mm and imx8mn platforms, the clocks were not running which resulted in a hang. What I've done is simply move the helper function into the probe and have it run after the clocks start. In theory the register values will be the same as they would be with the help function still in place.
Both Tim Harvey and I have tested on an imx8mm and Fabio tested it on an imx7. For me, the peripheral mode worked when the ID pin of the USB-OTG was not grounded. When it was grounded, the system corrected identified it as a host and I was able to mount a USB drive.
-michael
Am 2022-01-11 15:20, schrieb Adam Ford:
priv->ehci = ehci;
Michael,
But that is just fetching the mode from the device tree, the usb_setup_ehci_gadget() referenced above, change the mode during runtime by writing the plat->init_type and reprobing the device.
It doesn't use the plat->init_type at all anymore, no?
Again, I'm missing something here, but the only user of usb_setup_ehci_gadget() is usb/gadget/ci_udc.c.
-michael
priv->ehci = ehci;
Michael,
From what I could tell, the only thing that plat->init_type did was to
set priv->init_type. The priv structure appears to do most of the work.
I can't speak to what those functions do. What are you suggesting that I do differently?
adam
-michael
Am 2022-01-11 17:52, schrieb Adam Ford:
priv->ehci = ehci;
Michael,
From what I could tell, the only thing that plat->init_type did was to set priv->init_type. The priv structure appears to do most of the work.
but plat->init_type seems to change during runtime (by usb_setup_ehci_gadget()) and with this patch applied, it doesn't do that anymore.
I'd start by seeing if/when usb_setup_ehci_gadget() is called and see if plat->init_type changes. If its not called, is it dead code then? Sorry I just noticed this, while reviewing how this particular driver works, because I still like to find a working OTG driver in u-boot. I don't have any imx boards.
-michael
priv->ehci = ehci;
Michael,
I commented out the call to usb_setup_ehci_gadget(), and the gadget driver still enumerated. I'll push a V2 to remove it along with some subsequent patches to update the defconfig, so others who want to use/test it don't have to guess what config options are necessary.
Thanks for catching that.
adam
-michael
> The imx8mm and imx8mn appear compatible with imx7d-usb > flags in the OTG driver. If the dr_mode is defined as > host or peripheral, the device appears to operate correctly, > however the auto host/peripheral detection results in an error. > > The solution isn't just adding checks for imx8mm and imx8mn to > the check for imx7, because the USB clock needs to be running > to read from the USBNC_PHY_STATUS_OFFSET register or it will hang. > > The init_type in both priv and plat data are the same, so it doesn't > make sense to configure the data in the plat data and copy the > data to priv when priv can be configured directly. Instead, rename > ehci_usb_of_to_plat to ehci_usb_dr_mode and call it from the > probe functions after the clocks are enabled, but before the data > is required. > > With that added, the additional checks for imx8mm and imx8mn will > allow reading the register to automatically determine the state > (host or device) of the OTG controller. > > Signed-off-by: Adam Ford aford173@gmail.com > --- > V2: Rename ehci_usb_of_to_plat to ehci_usb_dr_mode and call it > from the probe after the clocks are enabled, but before > the data is needed. > > diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c > index 1bd6147c76..f2a34b7f06 100644 > --- a/drivers/usb/host/ehci-mx6.c > +++ b/drivers/usb/host/ehci-mx6.c
> @@ -639,10 +639,8 @@ static int mx6_parse_dt_addrs(struct udevice *dev) > > static int ehci_usb_probe(struct udevice *dev) > { > - struct usb_plat *plat = dev_get_plat(dev); > struct usb_ehci *ehci = dev_read_addr_ptr(dev); > struct ehci_mx6_priv_data *priv = dev_get_priv(dev); > - enum usb_init_type type = plat->init_type; > struct ehci_hccr *hccr; > struct ehci_hcor *hcor; > int ret; > @@ -660,8 +658,6 @@ static int ehci_usb_probe(struct udevice *dev) > return ret; > > priv->ehci = ehci; > - priv->init_type = type;
Michael,
Simon,
i went go to remove usb_setup_ehci_gadget(), but the header file has a TODO with your name on it, but the ci_udc river appears to be the only function to call it, and from what I can tell, the CI-UDC driver doesn't need this.
/** * usb_setup_ehci_gadget() - Set up a USB device as a gadget * * TODO(sjg@chromium.org): Tidy this up when USB gadgets can use driver model * * This provides a way to tell a controller to start up as a USB device * instead of as a host. It is untested. */
If I remove the function call from the ci_udc.c driver, do you want this left in the header? As it's written, the usb_setup_ehci_gadget() appears to attempt to override the plat->init_type, but this change is eliminating the need for the plat structure since it is pointless.
From what I can tell the function is trying to force a re-probe with
the plat->init_type redefined as a peripheral, but the code I want to use auto-detects the host/peripheral mode, rendering this pointless.
adam
adam
-michael
On Tue, Jan 4, 2022 at 2:32 AM Michael Walle michael@walle.cc wrote: > > The imx8mm and imx8mn appear compatible with imx7d-usb > > flags in the OTG driver. If the dr_mode is defined as > > host or peripheral, the device appears to operate correctly, > > however the auto host/peripheral detection results in an error. > > > > The solution isn't just adding checks for imx8mm and imx8mn to > > the check for imx7, because the USB clock needs to be running > > to read from the USBNC_PHY_STATUS_OFFSET register or it will hang. > > > > The init_type in both priv and plat data are the same, so it doesn't > > make sense to configure the data in the plat data and copy the > > data to priv when priv can be configured directly. Instead, rename > > ehci_usb_of_to_plat to ehci_usb_dr_mode and call it from the > > probe functions after the clocks are enabled, but before the data > > is required. > > > > With that added, the additional checks for imx8mm and imx8mn will > > allow reading the register to automatically determine the state > > (host or device) of the OTG controller. > > > > Signed-off-by: Adam Ford aford173@gmail.com > > --- > > V2: Rename ehci_usb_of_to_plat to ehci_usb_dr_mode and call it > > from the probe after the clocks are enabled, but before > > the data is needed. > > > > diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c > > index 1bd6147c76..f2a34b7f06 100644 > > --- a/drivers/usb/host/ehci-mx6.c > > +++ b/drivers/usb/host/ehci-mx6.c > > .. > > > @@ -639,10 +639,8 @@ static int mx6_parse_dt_addrs(struct udevice *dev) > > > > static int ehci_usb_probe(struct udevice *dev) > > { > > - struct usb_plat *plat = dev_get_plat(dev); > > struct usb_ehci *ehci = dev_read_addr_ptr(dev); > > struct ehci_mx6_priv_data *priv = dev_get_priv(dev); > > - enum usb_init_type type = plat->init_type; > > struct ehci_hccr *hccr; > > struct ehci_hcor *hcor; > > int ret; > > @@ -660,8 +658,6 @@ static int ehci_usb_probe(struct udevice *dev) > > return ret; > > > > priv->ehci = ehci; > > - priv->init_type = type; >
Michael,
> I'm not sure this is correct. There is also this: > https://elixir.bootlin.com/u-boot/v2022.01-rc4/source/drivers/usb/host/usb-u... >
> Which won't work anymore. usb_setup_ehci_gadget() is called from > usb_gadget_register_driver() in ci_udc.c. The latter is the one used > on the imx, right? But I might be wrong. I'm still trying to figure > out how this all works together, because I also try to get OTG > running on the dwc3 driver. It looks like the ci_udc.c is special > here, and I wonder how a transition to UCLASS_USB_GADGET_GENERIC > might look like for this driver.
Simon,
- usb_setup_ehci_gadget() - Set up a USB device as a gadget
- TODO(sjg@chromium.org): Tidy this up when USB gadgets can use driver model
- This provides a way to tell a controller to start up as a USB device
- instead of as a host. It is untested.
If I remove the function call from the ci_udc.c driver, do you want this left in the header? As it's written, the usb_setup_ehci_gadget() appears to attempt to override the plat->init_type, but this change is eliminating the need for the plat structure since it is pointless. From what I can tell the function is trying to force a re-probe with the plat->init_type redefined as a peripheral, but the code I want to use auto-detects the host/peripheral mode, rendering this pointless.
Michael,
It appears that the usb_setup_ehci_gadget() forces the USB driver into peripheral mode regardless of the device tree and/or the state of the register that detects the pin, so I'm going to submit a V3 that keeps the helper function. The helper function will not read the register to determine the host/peripheral mode. Instead, it will return UNKNOWN if the device tree does not explicitly state the dr_mode.
If the device type is UNKNOWN, then the probe will call ehci_usb_phy_mode after the clocks are started which will query the register for the IP block to determine the state. This way, we don't break some of the functionality for forcing peripheral mode if we intentionally activate a peripheral.
Tim & Fabio,
Would you mind re-testing? I'm going to drop the added tags on the V3 because there is enough changes here and a small change in behavior that I think it warrants re-test and/or re-review.
adam
adam
adam
-michael
Adam Ford
Fabio Estevam
Michael Walle
Tim Harvey
