[U-Boot] [PATCH] ARM: UniPhier: drop special CONFIG_AUTOBOOT_ settings
There is no good reason to use a particular key to stop autobooting. The default allows us to stop the autoboot with any key input.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
configs/ph1_ld4_defconfig | 4 ---- configs/ph1_pro4_defconfig | 4 ---- configs/ph1_sld8_defconfig | 4 ---- 3 files changed, 12 deletions(-)
diff --git a/configs/ph1_ld4_defconfig b/configs/ph1_ld4_defconfig index 723989c..82ce8c7 100644 --- a/configs/ph1_ld4_defconfig +++ b/configs/ph1_ld4_defconfig @@ -9,10 +9,6 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-ld4-ref" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" -CONFIG_AUTOBOOT_DELAY_STR="d" -CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_CMD_BDI=y CONFIG_CMD_CONSOLE=y CONFIG_CMD_BOOTD=y diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index a2e2d4f..671d9cc 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -8,10 +8,6 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-pro4-ref" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" -CONFIG_AUTOBOOT_DELAY_STR="d" -CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_CMD_BDI=y CONFIG_CMD_CONSOLE=y CONFIG_CMD_BOOTD=y diff --git a/configs/ph1_sld8_defconfig b/configs/ph1_sld8_defconfig index dc59dcb..3e763dc 100644 --- a/configs/ph1_sld8_defconfig +++ b/configs/ph1_sld8_defconfig @@ -9,10 +9,6 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-sld8-ref" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" -CONFIG_AUTOBOOT_DELAY_STR="d" -CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_CMD_BDI=y CONFIG_CMD_CONSOLE=y CONFIG_CMD_BOOTD=y
Masahiro Yamada
