[PATCH v2] env: sf: Free the old env_flash
env_flash is a global flash pointer, and the probe would happen only if env_flash is NULL, but there is no checking and free the pointer if is not NULL.
So, this patch frees the old env_flash, and get the probed flash in to env_flash pointer and finally check if is not NULL.
Suggested-by: Pratyush Yadav p.yadav@ti.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - change suggested by Pratyush.
env/sf.c | 13 ++++++------- 1 file changed, 6 insertions(+), 7 deletions(-)
diff --git a/env/sf.c b/env/sf.c index 23de5a3495..02ed846fc7 100644 --- a/env/sf.c +++ b/env/sf.c @@ -53,15 +53,14 @@ static int setup_flash_device(void)
env_flash = dev_get_uclass_priv(new); #else + if (env_flash) + spi_flash_free(env_flash);
+ env_flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS, + CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); if (!env_flash) { - env_flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, - CONFIG_ENV_SPI_CS, - CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); - if (!env_flash) { - env_set_default("spi_flash_probe() failed", 0); - return -EIO; - } + env_set_default("spi_flash_probe() failed", 0); + return -EIO; } #endif return 0;
Reviewed-by: Pratyush Yadav p.yadav@ti.com
Jagan Teki
Pratyush Yadav
