[PATCH] rockchip: puma-rk3399: remove dead code
From: Quentin Schulz quentin.schulz@theobroma-systems.com
CONFIG_SERIAL_TAG is not selectable for ARM64 machines. While get_board_serial is weakly defined if ENV_VARS_UBOOT_RUNTIME_CONFIG is defined, it is only called when CONFIG_SUPPORT_PASSING_ATAGS is defined, which also is not selectable for ARM64 machines. Therefore this is dead code so let's remove it.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- .../theobroma-systems/puma_rk3399/puma-rk3399.c | 16 ---------------- 1 file changed, 16 deletions(-)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index deeba3084a..3237a6aa2e 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -136,19 +136,3 @@ int misc_init_r(void)
return 0; } - -#ifdef CONFIG_SERIAL_TAG -void get_board_serial(struct tag_serialnr *serialnr) -{ - char *serial_string; - u64 serial = 0; - - serial_string = env_get("serial#"); - - if (serial_string) - serial = simple_strtoull(serial_string, NULL, 16); - - serialnr->high = (u32)(serial >> 32); - serialnr->low = (u32)(serial & 0xffffffff); -} -#endif
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
return 0; }
- u64 serial = 0;
-} -#endif
Kever Yang
Quentin Schulz
