[U-Boot] u-boot.lds question
On Thursday 01 March 2012 01:06:58 Will Khan wrote:
When I look at u-boot.lds (in the main directory), it shows the
incorrect path to start.o. u-boot.lds is generated through the make
all process.
When I manually fix the start.o pathname in u-boot.lds, everything
builds fine. My question is where and how is u-boot.lds generated?
I
see where there is also a u-boot.lds in arch/powerpc/cpu/mpc83xx/,
with an explicit path to start.o, but this file seems to not do
anything (I can modify the file or delete this specific u-boot.lds,
and nothing happens -a new one is not created).
the top level u-boot.lds lacks a depend on the files that create it
(known bug). so you manually have to `rm` it in order for a new one
to be generated.
most likely the cpu subdir u-boot.lds is what is broken & needs fixing.
-mike
One of my issues is that when I remove it and a new one is created, it is always created with the wrong path for start.o. As well, when I make changes to the cpu subdir one, it doesn't affect anything. In fact, I can delete it and a new one is not created, nor is there any complaint. If anything else comes to your mind in terms of where to look, please let me know...
Will
run `make u-boot.lds` to see what exactly is being used to create it -mike
Mike Frysinger
Will Khan
