[U-Boot] [PATCH] nios2: remove obsolete PCI5441 and PK1C20 boards
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/Kconfig | 8 -- board/psyent/common/AMDLV065D.c | 170 ---------------------------- board/psyent/pci5441/Kconfig | 15 --- board/psyent/pci5441/MAINTAINERS | 6 - board/psyent/pci5441/Makefile | 8 -- board/psyent/pci5441/config.mk | 14 --- board/psyent/pci5441/pci5441.c | 24 ---- board/psyent/pk1c20/Kconfig | 15 --- board/psyent/pk1c20/MAINTAINERS | 6 - board/psyent/pk1c20/Makefile | 8 -- board/psyent/pk1c20/config.mk | 14 --- board/psyent/pk1c20/led.c | 46 -------- board/psyent/pk1c20/pk1c20.c | 36 ------ configs/PCI5441_defconfig | 2 - configs/PK1C20_defconfig | 2 - include/configs/PCI5441.h | 150 ------------------------- include/configs/PK1C20.h | 225 -------------------------------------- 17 files changed, 0 insertions(+), 749 deletions(-) delete mode 100644 board/psyent/common/AMDLV065D.c delete mode 100644 board/psyent/pci5441/Kconfig delete mode 100644 board/psyent/pci5441/MAINTAINERS delete mode 100644 board/psyent/pci5441/Makefile delete mode 100644 board/psyent/pci5441/config.mk delete mode 100644 board/psyent/pci5441/pci5441.c delete mode 100644 board/psyent/pk1c20/Kconfig delete mode 100644 board/psyent/pk1c20/MAINTAINERS delete mode 100644 board/psyent/pk1c20/Makefile delete mode 100644 board/psyent/pk1c20/config.mk delete mode 100644 board/psyent/pk1c20/led.c delete mode 100644 board/psyent/pk1c20/pk1c20.c delete mode 100644 configs/PCI5441_defconfig delete mode 100644 configs/PK1C20_defconfig delete mode 100644 include/configs/PCI5441.h delete mode 100644 include/configs/PK1C20.h
diff --git a/arch/nios2/Kconfig b/arch/nios2/Kconfig index b703646..0cba45b 100644 --- a/arch/nios2/Kconfig +++ b/arch/nios2/Kconfig @@ -11,16 +11,8 @@ choice config TARGET_NIOS2_GENERIC bool "Support nios2-generic"
-config TARGET_PCI5441 - bool "Support PCI5441" - -config TARGET_PK1C20 - bool "Support PK1C20" - endchoice
source "board/altera/nios2-generic/Kconfig" -source "board/psyent/pci5441/Kconfig" -source "board/psyent/pk1c20/Kconfig"
endmenu diff --git a/board/psyent/common/AMDLV065D.c b/board/psyent/common/AMDLV065D.c deleted file mode 100644 index 64cb970..0000000 --- a/board/psyent/common/AMDLV065D.c +++ /dev/null @@ -1,170 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - - -#include <common.h> -#include <asm/io.h> - -#define SECTSZ (64 * 1024) -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -/*----------------------------------------------------------------------*/ -unsigned long flash_init (void) -{ - int i; - unsigned long addr; - flash_info_t *fli = &flash_info[0]; - - fli->size = CONFIG_SYS_FLASH_SIZE; - fli->sector_count = CONFIG_SYS_MAX_FLASH_SECT; - fli->flash_id = FLASH_MAN_AMD + FLASH_AMDLV065D; - - addr = CONFIG_SYS_FLASH_BASE; - for (i = 0; i < fli->sector_count; ++i) { - fli->start[i] = addr; - addr += SECTSZ; - fli->protect[i] = 1; - } - - return (CONFIG_SYS_FLASH_SIZE); -} -/*--------------------------------------------------------------------*/ -void flash_print_info (flash_info_t * info) -{ - int i, k; - int erased; - unsigned long *addr; - - printf (" Size: %ld KB in %d Sectors\n", - info->size >> 10, info->sector_count); - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - - /* Check if whole sector is erased */ - erased = 1; - addr = (unsigned long *) info->start[i]; - for (k = 0; k < SECTSZ/sizeof(unsigned long); k++) { - if ( readl(addr++) != (unsigned long)-1) { - erased = 0; - break; - } - } - - /* Print the info */ - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s%s", - info->start[i], - erased ? " E" : " ", - info->protect[i] ? "RO " : " "); - } - printf ("\n"); -} - -/*-------------------------------------------------------------------*/ - - -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - unsigned char *addr = (unsigned char *) info->start[0]; - unsigned char *addr2; - int prot, sect; - ulong start; - - /* Some sanity checking */ - if ((s_first < 0) || (s_first > s_last)) { - printf ("- no sectors to erase\n"); - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - /* It's ok to erase multiple sectors provided we don't delay more - * than 50 usec between cmds ... at which point the erase time-out - * occurs. So don't go and put printf() calls in the loop ... it - * won't be very helpful ;-) - */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr2 = (unsigned char *) info->start[sect]; - writeb (0xaa, addr); - writeb (0x55, addr); - writeb (0x80, addr); - writeb (0xaa, addr); - writeb (0x55, addr); - writeb (0x30, addr2); - /* Now just wait for 0xff & provide some user - * feedback while we wait. - */ - start = get_timer (0); - while ( readb (addr2) != 0xff) { - udelay (1000 * 1000); - putc ('.'); - if (get_timer (start) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("timeout\n"); - return 1; - } - } - } - } - printf ("\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - - vu_char *cmd = (vu_char *) info->start[0]; - vu_char *dst = (vu_char *) addr; - unsigned char b; - ulong start; - - while (cnt) { - /* Check for sufficient erase */ - b = *src; - if ((readb (dst) & b) != b) { - printf ("%02x : %02x\n", readb (dst), b); - return (2); - } - - writeb (0xaa, cmd); - writeb (0x55, cmd); - writeb (0xa0, cmd); - writeb (dst, b); - - /* Verify write */ - start = get_timer (0); - while (readb (dst) != b) { - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return 1; - } - } - dst++; - src++; - cnt--; - } - - return (0); -} diff --git a/board/psyent/pci5441/Kconfig b/board/psyent/pci5441/Kconfig deleted file mode 100644 index d722f31..0000000 --- a/board/psyent/pci5441/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_PCI5441 - -config SYS_BOARD - string - default "pci5441" - -config SYS_VENDOR - string - default "psyent" - -config SYS_CONFIG_NAME - string - default "PCI5441" - -endif diff --git a/board/psyent/pci5441/MAINTAINERS b/board/psyent/pci5441/MAINTAINERS deleted file mode 100644 index f1f10e9..0000000 --- a/board/psyent/pci5441/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -PCI5441 BOARD -M: Scott McNutt smcnutt@psyent.com -S: Maintained -F: board/psyent/pci5441/ -F: include/configs/PCI5441.h -F: configs/PCI5441_defconfig diff --git a/board/psyent/pci5441/Makefile b/board/psyent/pci5441/Makefile deleted file mode 100644 index 364f163..0000000 --- a/board/psyent/pci5441/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := pci5441.o ../common/AMDLV065D.o diff --git a/board/psyent/pci5441/config.mk b/board/psyent/pci5441/config.mk deleted file mode 100644 index 776fa8a..0000000 --- a/board/psyent/pci5441/config.mk +++ /dev/null @@ -1,14 +0,0 @@ -# -# (C) Copyright 2004, Psyent Corporation <www.psyent.com> -# Scott McNutt smcnutt@psyent.com -# -# SPDX-License-Identifier: GPL-2.0+ -# - -CONFIG_SYS_TEXT_BASE = 0x018e0000 - -PLATFORM_CPPFLAGS += -mno-hw-div -mno-hw-mul - -ifeq ($(debug),1) -PLATFORM_CPPFLAGS += -DDEBUG -endif diff --git a/board/psyent/pci5441/pci5441.c b/board/psyent/pci5441/pci5441.c deleted file mode 100644 index 6d619e5..0000000 --- a/board/psyent/pci5441/pci5441.c +++ /dev/null @@ -1,24 +0,0 @@ -/* - * (C) Copyright 2004, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> - -int board_early_init_f (void) -{ - return 0; -} - -int checkboard (void) -{ - puts ("BOARD : Psyent PCI-5441\n"); - return 0; -} - -phys_size_t initdram (int board_type) -{ - return (0); -} diff --git a/board/psyent/pk1c20/Kconfig b/board/psyent/pk1c20/Kconfig deleted file mode 100644 index 75f6cd1..0000000 --- a/board/psyent/pk1c20/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_PK1C20 - -config SYS_BOARD - string - default "pk1c20" - -config SYS_VENDOR - string - default "psyent" - -config SYS_CONFIG_NAME - string - default "PK1C20" - -endif diff --git a/board/psyent/pk1c20/MAINTAINERS b/board/psyent/pk1c20/MAINTAINERS deleted file mode 100644 index 32b901a..0000000 --- a/board/psyent/pk1c20/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -PK1C20 BOARD -M: Scott McNutt smcnutt@psyent.com -S: Maintained -F: board/psyent/pk1c20/ -F: include/configs/PK1C20.h -F: configs/PK1C20_defconfig diff --git a/board/psyent/pk1c20/Makefile b/board/psyent/pk1c20/Makefile deleted file mode 100644 index 5450f93..0000000 --- a/board/psyent/pk1c20/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := pk1c20.o led.o ../common/AMDLV065D.o diff --git a/board/psyent/pk1c20/config.mk b/board/psyent/pk1c20/config.mk deleted file mode 100644 index 83cfadc..0000000 --- a/board/psyent/pk1c20/config.mk +++ /dev/null @@ -1,14 +0,0 @@ -# -# (C) Copyright 2004, Psyent Corporation <www.psyent.com> -# Scott McNutt smcnutt@psyent.com -# -# SPDX-License-Identifier: GPL-2.0+ -# - -CONFIG_SYS_TEXT_BASE = 0x01fc0000 - -PLATFORM_CPPFLAGS += -mno-hw-div -mno-hw-mul - -ifeq ($(debug),1) -PLATFORM_CPPFLAGS += -DDEBUG -endif diff --git a/board/psyent/pk1c20/led.c b/board/psyent/pk1c20/led.c deleted file mode 100644 index 580d590..0000000 --- a/board/psyent/pk1c20/led.c +++ /dev/null @@ -1,46 +0,0 @@ -/* - * (C) Copyright 2004, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/io.h> -#include <nios2-io.h> -#include <status_led.h> - -/* The LED port is configured as output only, so we - * must track the state manually. - */ -static led_id_t val = 0; - -void __led_init (led_id_t mask, int state) -{ - nios_pio_t *pio = (nios_pio_t *)CONFIG_SYS_LEDPIO_ADDR; - - if (state == STATUS_LED_ON) - val &= ~mask; - else - val |= mask; - writel (val, &pio->data); -} - -void __led_set (led_id_t mask, int state) -{ - nios_pio_t *pio = (nios_pio_t *)CONFIG_SYS_LEDPIO_ADDR; - - if (state == STATUS_LED_ON) - val &= ~mask; - else - val |= mask; - writel (val, &pio->data); -} - -void __led_toggle (led_id_t mask) -{ - nios_pio_t *pio = (nios_pio_t *)CONFIG_SYS_LEDPIO_ADDR; - - val ^= mask; - writel (val, &pio->data); -} diff --git a/board/psyent/pk1c20/pk1c20.c b/board/psyent/pk1c20/pk1c20.c deleted file mode 100644 index 0b4c9f8..0000000 --- a/board/psyent/pk1c20/pk1c20.c +++ /dev/null @@ -1,36 +0,0 @@ -/* - * (C) Copyright 2004, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <netdev.h> - -int board_early_init_f (void) -{ - return 0; -} - -int checkboard (void) -{ - puts ("BOARD : Psyent PK-1C20\n"); - return 0; -} - -phys_size_t initdram (int board_type) -{ - return (0); -} - -#ifdef CONFIG_CMD_NET -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_SMC91111 - rc = smc91111_initialize(0, CONFIG_SMC91111_BASE); -#endif - return rc; -} -#endif diff --git a/configs/PCI5441_defconfig b/configs/PCI5441_defconfig deleted file mode 100644 index a4bfdb4..0000000 --- a/configs/PCI5441_defconfig +++ /dev/null @@ -1,2 +0,0 @@ -CONFIG_NIOS2=y -CONFIG_TARGET_PCI5441=y diff --git a/configs/PK1C20_defconfig b/configs/PK1C20_defconfig deleted file mode 100644 index bb2513a..0000000 --- a/configs/PK1C20_defconfig +++ /dev/null @@ -1,2 +0,0 @@ -CONFIG_NIOS2=y -CONFIG_TARGET_PK1C20=y diff --git a/include/configs/PCI5441.h b/include/configs/PCI5441.h deleted file mode 100644 index 7ae25d7..0000000 --- a/include/configs/PCI5441.h +++ /dev/null @@ -1,150 +0,0 @@ -/* - * (C) Copyright 2004, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/*------------------------------------------------------------------------ - * BOARD/CPU - *----------------------------------------------------------------------*/ -#define CONFIG_PCI5441 1 /* PCI-5441 board */ -#define CONFIG_SYS_CLK_FREQ 50000000 /* 50 MHz core clk */ - -#define CONFIG_SYS_RESET_ADDR 0x00000000 /* Hard-reset address */ -#define CONFIG_SYS_EXCEPTION_ADDR 0x01000020 /* Exception entry point*/ -#define CONFIG_SYS_NIOS_SYSID_BASE 0x00920828 /* System id address */ -#define CONFIG_BOARD_EARLY_INIT_F 1 /* enable early board-spec. init*/ - -/*------------------------------------------------------------------------ - * CACHE -- the following will support II/s and II/f. The II/s does not - * have dcache, so the cache instructions will behave as NOPs. - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_ICACHE_SIZE 4096 /* 4 KByte total */ -#define CONFIG_SYS_ICACHELINE_SIZE 32 /* 32 bytes/line */ -#define CONFIG_SYS_DCACHE_SIZE 2048 /* 2 KByte (II/f) */ -#define CONFIG_SYS_DCACHELINE_SIZE 4 /* 4 bytes/line (II/f) */ - -/*------------------------------------------------------------------------ - * MEMORY BASE ADDRESSES - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_FLASH_BASE 0x00000000 /* FLASH base addr */ -#define CONFIG_SYS_FLASH_SIZE 0x00800000 /* 8 MByte */ -#define CONFIG_SYS_SDRAM_BASE 0x01000000 /* SDRAM base addr */ -#define CONFIG_SYS_SDRAM_SIZE 0x01000000 /* 16 MByte */ - -/*------------------------------------------------------------------------ - * MEMORY ORGANIZATION - * -Monitor at top. - * -The heap is placed below the monitor. - * -Global data is placed below the heap. - * -The stack is placed below global data (&grows down). - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_MONITOR_LEN (128 * 1024) /* Reserve 128k */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MALLOC_BASE (CONFIG_SYS_MONITOR_BASE - CONFIG_SYS_MALLOC_LEN) -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_MALLOC_BASE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP CONFIG_SYS_GBL_DATA_OFFSET - -/*------------------------------------------------------------------------ - * FLASH (AM29LV065D) - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* Max # sects per bank */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* Max # of flash banks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 8000 /* Erase timeout (msec) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 100 /* Write timeout (msec) */ -#define CONFIG_SYS_FLASH_WORD_SIZE unsigned char /* flash word size */ - -/*------------------------------------------------------------------------ - * ENVIRONMENT -- Put environment in sector CONFIG_SYS_MONITOR_LEN above - * CONFIG_SYS_RESET_ADDR, since we assume the monitor is stored at the - * reset address, no? This will keep the environment in user region - * of flash. NOTE: the monitor length must be multiple of sector size - * (which is common practice). - *----------------------------------------------------------------------*/ -#define CONFIG_ENV_IS_IN_FLASH 1 /* Environment in flash */ -#define CONFIG_ENV_SIZE (64 * 1024) /* 64 KByte (1 sector) */ -#define CONFIG_ENV_OVERWRITE /* Serial change Ok */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_RESET_ADDR + CONFIG_SYS_MONITOR_LEN) - -/*------------------------------------------------------------------------ - * CONSOLE - *----------------------------------------------------------------------*/ -#define CONFIG_ALTERA_UART 1 /* Use altera uart */ -#if defined(CONFIG_ALTERA_JTAG_UART) -#define CONFIG_SYS_NIOS_CONSOLE 0x00920820 /* JTAG UART base addr */ -#else -#define CONFIG_SYS_NIOS_CONSOLE 0x009208a0 /* UART base addr */ -#endif - -#define CONFIG_SYS_NIOS_FIXEDBAUD 1 /* Baudrate is fixed */ -#define CONFIG_BAUDRATE 115200 /* Initial baudrate */ -#define CONFIG_SYS_BAUDRATE_TABLE {115200} /* It's fixed ;-) */ - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* Suppress console info*/ - -/*------------------------------------------------------------------------ - * DEBUG - *----------------------------------------------------------------------*/ -#undef CONFIG_ROM_STUBS /* Stubs not in ROM */ - -/*------------------------------------------------------------------------ - * TIMEBASE -- - * - * The high res timer defaults to 1 msec. Since it includes the period - * registers, the interrupt frequency can be reduced using TMRCNT. - * If the default period is acceptable, TMRCNT can be left undefined. - * TMRMS represents the desired mecs per tick (msecs per interrupt). - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_LOW_RES_TIMER -#define CONFIG_SYS_NIOS_TMRBASE 0x00920860 /* Tick timer base addr */ -#define CONFIG_SYS_NIOS_TMRIRQ 3 /* Timer IRQ num */ -#define CONFIG_SYS_NIOS_TMRMS 10 /* Desired period (msec)*/ -#define CONFIG_SYS_NIOS_TMRCNT \ - (CONFIG_SYS_NIOS_TMRMS * (CONFIG_SYS_CLK_FREQ/1000)) - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#define CONFIG_CMD_BDI -#define CONFIG_CMD_ECHO -#define CONFIG_CMD_SAVEENV -#define CONFIG_CMD_FLASH -#define CONFIG_CMD_IMI -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_LOADS -#define CONFIG_CMD_LOADB -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_MISC -#define CONFIG_CMD_RUN -#define CONFIG_CMD_SAVES - - -/*------------------------------------------------------------------------ - * MISC - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_LONGHELP /* Provide extended help*/ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O buf size */ -#define CONFIG_SYS_MAXARGS 16 /* Max command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot arg buf size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print buf size */ -#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE /* Default load address */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE /* Start addr for test */ -#define CONFIG_SYS_MEMTEST_END CONFIG_SYS_INIT_SP - 0x00020000 - -#endif /* __CONFIG_H */ diff --git a/include/configs/PK1C20.h b/include/configs/PK1C20.h deleted file mode 100644 index e7d0864..0000000 --- a/include/configs/PK1C20.h +++ /dev/null @@ -1,225 +0,0 @@ -/* - * (C) Copyright 2004, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/*------------------------------------------------------------------------ - * BOARD/CPU - *----------------------------------------------------------------------*/ -#define CONFIG_PK1C20 1 /* PK1C20 board */ -#define CONFIG_SYS_CLK_FREQ 50000000 /* 50 MHz core clk */ - -#define CONFIG_SYS_RESET_ADDR 0x00000000 /* Hard-reset address */ -#define CONFIG_SYS_EXCEPTION_ADDR 0x01000020 /* Exception entry point*/ -#define CONFIG_SYS_NIOS_SYSID_BASE 0x021208b8 /* System id address */ -#define CONFIG_BOARD_EARLY_INIT_F 1 /* enable early board-spec. init*/ - -/*------------------------------------------------------------------------ - * CACHE -- the following will support II/s and II/f. The II/s does not - * have dcache, so the cache instructions will behave as NOPs. - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_ICACHE_SIZE 4096 /* 4 KByte total */ -#define CONFIG_SYS_ICACHELINE_SIZE 32 /* 32 bytes/line */ -#define CONFIG_SYS_DCACHE_SIZE 2048 /* 2 KByte (II/f) */ -#define CONFIG_SYS_DCACHELINE_SIZE 4 /* 4 bytes/line (II/f) */ - -/*------------------------------------------------------------------------ - * MEMORY BASE ADDRESSES - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_FLASH_BASE 0x00000000 /* FLASH base addr */ -#define CONFIG_SYS_FLASH_SIZE 0x00800000 /* 8 MByte */ -#define CONFIG_SYS_SDRAM_BASE 0x01000000 /* SDRAM base addr */ -#define CONFIG_SYS_SDRAM_SIZE 0x01000000 /* 16 MByte */ -#define CONFIG_SYS_SRAM_BASE 0x02000000 /* SRAM base addr */ -#define CONFIG_SYS_SRAM_SIZE 0x00100000 /* 1 MB (only 1M mapped)*/ - -/*------------------------------------------------------------------------ - * MEMORY ORGANIZATION - * -Monitor at top. - * -The heap is placed below the monitor. - * -Global data is placed below the heap. - * -The stack is placed below global data (&grows down). - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 128k */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MALLOC_BASE (CONFIG_SYS_MONITOR_BASE - CONFIG_SYS_MALLOC_LEN) -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_MALLOC_BASE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP CONFIG_SYS_GBL_DATA_OFFSET - -/*------------------------------------------------------------------------ - * FLASH (AM29LV065D) - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* Max # sects per bank */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* Max # of flash banks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 8000 /* Erase timeout (msec) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 100 /* Write timeout (msec) */ -#define CONFIG_SYS_FLASH_WORD_SIZE unsigned char /* flash word size */ - -/*------------------------------------------------------------------------ - * ENVIRONMENT -- Put environment in sector CONFIG_SYS_MONITOR_LEN above - * CONFIG_SYS_RESET_ADDR, since we assume the monitor is stored at the - * reset address, no? This will keep the environment in user region - * of flash. NOTE: the monitor length must be multiple of sector size - * (which is common practice). - *----------------------------------------------------------------------*/ -#define CONFIG_ENV_IS_IN_FLASH 1 /* Environment in flash */ -#define CONFIG_ENV_SIZE (64 * 1024) /* 64 KByte (1 sector) */ -#define CONFIG_ENV_OVERWRITE /* Serial change Ok */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_RESET_ADDR + CONFIG_SYS_MONITOR_LEN) - -/*------------------------------------------------------------------------ - * CONSOLE - *----------------------------------------------------------------------*/ -#define CONFIG_ALTERA_UART 1 /* Use altera uart */ -#if defined(CONFIG_ALTERA_JTAG_UART) -#define CONFIG_SYS_NIOS_CONSOLE 0x021208b0 /* JTAG UART base addr */ -#else -#define CONFIG_SYS_NIOS_CONSOLE 0x02120840 /* UART base addr */ -#endif - -#define CONFIG_SYS_NIOS_FIXEDBAUD 1 /* Baudrate is fixed */ -#define CONFIG_BAUDRATE 115200 /* Initial baudrate */ -#define CONFIG_SYS_BAUDRATE_TABLE {115200} /* It's fixed ;-) */ - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* Suppress console info*/ - -/*------------------------------------------------------------------------ - * EPCS Device -- wne CONFIG_SYS_NIOS_EPCSBASE is defined code/commands for - * epcs device access is enabled. The base address is the epcs - * _register_ base address, NOT THE ADDRESS OF THE MEMORY BLOCK. - * The register base is currently at offset 0x600 from the memory base. - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_NIOS_EPCSBASE 0x02100200 /* EPCS register base */ - -/*------------------------------------------------------------------------ - * DEBUG - *----------------------------------------------------------------------*/ -#undef CONFIG_ROM_STUBS /* Stubs not in ROM */ - -/*------------------------------------------------------------------------ - * TIMEBASE -- - * - * The high res timer defaults to 1 msec. Since it includes the period - * registers, the interrupt frequency can be reduced using TMRCNT. - * If the default period is acceptable, TMRCNT can be left undefined. - * TMRMS represents the desired mecs per tick (msecs per interrupt). - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_LOW_RES_TIMER -#define CONFIG_SYS_NIOS_TMRBASE 0x02120820 /* Tick timer base addr */ -#define CONFIG_SYS_NIOS_TMRIRQ 3 /* Timer IRQ num */ -#define CONFIG_SYS_NIOS_TMRMS 10 /* Desired period */ -#define CONFIG_SYS_NIOS_TMRCNT \ - (CONFIG_SYS_NIOS_TMRMS * (CONFIG_SYS_CLK_FREQ/1000)) - -/*------------------------------------------------------------------------ - * STATUS LED -- Provides a simple blinking led. For Nios2 each board - * must implement its own led routines -- leds are, after all, - * board-specific, no? - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_LEDPIO_ADDR 0x02120870 /* LED PIO base addr */ -#define CONFIG_STATUS_LED /* Enable status driver */ -#define CONFIG_BOARD_SPECIFIC_LED - -#define STATUS_LED_BIT 1 /* Bit-0 on PIO */ -#define STATUS_LED_STATE 1 /* Blinking */ -#define STATUS_LED_PERIOD (500/CONFIG_SYS_NIOS_TMRMS) /* Every 500 msec */ - -/*------------------------------------------------------------------------ - * ETHERNET -- The header file for the SMC91111 driver hurts my eyes ... - * and really doesn't need any additional clutter. So I choose the lazy - * way out to avoid changes there -- define the base address to ensure - * cache bypass so there's no need to monkey with inx/outx macros. - *----------------------------------------------------------------------*/ -#define CONFIG_SMC91111_BASE 0x82110300 /* Base addr (bypass) */ -#define CONFIG_SMC91111 /* Using SMC91c111 */ -#undef CONFIG_SMC91111_EXT_PHY /* Internal PHY */ -#define CONFIG_SMC_USE_32_BIT /* 32-bit interface */ - -#define CONFIG_ETHADDR 08:00:3e:26:0a:5b -#define CONFIG_NETMASK 255.255.255.0 -#define CONFIG_IPADDR 192.168.2.21 -#define CONFIG_SERVERIP 192.168.2.16 - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ - -#define CONFIG_CMD_BDI -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_ECHO -#define CONFIG_CMD_SAVEENV -#define CONFIG_CMD_FLASH -#define CONFIG_CMD_IMI -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_LOADS -#define CONFIG_CMD_LOADB -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_MISC -#define CONFIG_CMD_NET -#define CONFIG_CMD_PING -#define CONFIG_CMD_RUN -#define CONFIG_CMD_SAVES - - -/*------------------------------------------------------------------------ - * COMPACT FLASH - *----------------------------------------------------------------------*/ -#if defined(CONFIG_CMD_IDE) -#define CONFIG_IDE_PREINIT /* Implement id_preinit */ -#define CONFIG_SYS_IDE_MAXBUS 1 /* 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* 1 drive per IDE bus */ - -#define CONFIG_SYS_ATA_BASE_ADDR 0x00900800 /* ATA base addr */ -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 /* IDE0 offset */ -#define CONFIG_SYS_ATA_DATA_OFFSET 0x0040 /* Data IO offset */ -#define CONFIG_SYS_ATA_REG_OFFSET 0x0040 /* Register offset */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 /* Alternate reg offset */ -#define CONFIG_SYS_ATA_STRIDE 4 /* Width betwix addrs */ -#define CONFIG_DOS_PARTITION - -/* Board-specific cf regs */ -#define CONFIG_SYS_CF_PRESENT 0x00900880 /* CF Present PIO base */ -#define CONFIG_SYS_CF_POWER 0x00900890 /* CF Power FET PIO base*/ -#define CONFIG_SYS_CF_ATASEL 0x009008a0 /* CF ATASEL PIO base */ - -#endif - -/*------------------------------------------------------------------------ - * JFFS2 - *----------------------------------------------------------------------*/ -#if defined(CONFIG_CMD_JFFS2) -#define CONFIG_SYS_JFFS_CUSTOM_PART /* board defined part */ -#endif - -/*------------------------------------------------------------------------ - * MISC - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_LONGHELP /* Provide extended help*/ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O buf size */ -#define CONFIG_SYS_MAXARGS 16 /* Max command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot arg buf size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print buf size */ -#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE /* Default load address */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE /* Start addr for test */ -#define CONFIG_SYS_MEMTEST_END CONFIG_SYS_INIT_SP - 0x00020000 - -#define CONFIG_SYS_HUSH_PARSER - -#endif /* __CONFIG_H */
Applied.
Thomas Chou
Thomas Chou
