[U-Boot] [PATCH 1/2] wandboard: Remove cpu type check prior to setup_sata()
Inside setup_sata() there is a cpu type check, so there is no need to do this check in the board file.
This also brings the benefit to allowing setup_sata() to be called for the mx6qp wandboard variant.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- board/wandboard/wandboard.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index adfcf48..3f12b50 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -380,9 +380,7 @@ int board_early_init_f(void) setup_display(); #endif #ifdef CONFIG_SATA - /* Only mx6q wandboard has SATA */ - if (is_cpu_type(MXC_CPU_MX6Q)) - setup_sata(); + setup_sata(); #endif
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- board/udoo/udoo.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/board/udoo/udoo.c b/board/udoo/udoo.c index a359626..562f0d8 100644 --- a/board/udoo/udoo.c +++ b/board/udoo/udoo.c @@ -245,8 +245,7 @@ int board_init(void) gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
#ifdef CONFIG_SATA - if (is_cpu_type(MXC_CPU_MX6Q)) - setup_sata(); + setup_sata(); #endif return 0; }
#ifdef CONFIG_SATA
setup_sata();
- setup_sata();
#endif return 0; }
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
setup_sata();
- setup_sata();
#endif
Fabio Estevam
