[U-Boot] [PATCH V2] disk: fix unaligned access in efi partitions
start_sect is not aligned to a 4 byte boundary thus causing exceptions on ARM platforms. Access this field via the get_unaligned_le32 macro.
Signed-off-by: Marc Dietrich marvin24@gmx.de --- V2: replace le32_to_cpu(get_unaligned()) with get_unaligned_le32
disk/part_efi.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/disk/part_efi.c b/disk/part_efi.c index b3fd0e9..e9987f0 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -30,6 +30,7 @@ * * This limits the maximum size of addressable storage to < 2 Terra Bytes */ +#include <asm/unaligned.h> #include <common.h> #include <command.h> #include <ide.h> @@ -505,7 +506,7 @@ err: static int pmbr_part_valid(struct partition *part) { if (part->sys_ind == EFI_PMBR_OSTYPE_EFI_GPT && - le32_to_cpu(part->start_sect) == 1UL) { + get_unaligned_le32(&part->start_sect) == 1UL) { return 1; }
Marc Dietrich
