[U-Boot] Adding support to Technexion TAM3517 SOM
This patches adds support for the Technexion's SOM TAM3517 based on a TI AM3517. In agreement with Tapani Utrianen, this patchset superseeds the recent patches sent to the ML by him with the same purpose.
This patchset requires the patchset for the AM3517 and EMAC posted by Ilya Yanok, and not yet merged into mainline. Ilya's patches must be applied first before this patchset.
[PATCH 1/2] ARM: omap3: added common configuration for Technexion [PATCH 2/2] ARM: omap3: add support to Technexion twister board
The TAM3517 is a SOM module that can be used on custom boards. The patch add a common configuration file that is included by the boards using this module.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Tapani Utrianen tapani@technexion.com CC: Tom Rini tom.rini@gmail.com CC: Sandeep Paulraj s-paulraj@ti.com --- include/configs/tam3517-common.h | 334 ++++++++++++++++++++++++++++++++++++++ 1 files changed, 334 insertions(+), 0 deletions(-) create mode 100644 include/configs/tam3517-common.h
diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h new file mode 100644 index 0000000..c76138a --- /dev/null +++ b/include/configs/tam3517-common.h @@ -0,0 +1,334 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2009 TechNexion Ltd. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __TAM3517_H +#define __TAM3517_H + +/* + * High Level Configuration Options + */ +#define CONFIG_OMAP /* in a TI OMAP core */ +#define CONFIG_OMAP34XX /* which is a 34XX */ + +/* TODO : Check these ones ! */ +#define CONFIG_TAM3517 /* working with TAM3517 */ + +#define CONFIG_SYS_TEXT_BASE 0x80008000 + +#define CONFIG_SYS_CACHELINE_SIZE 64 + +#define CONFIG_EMIF4 /* The chip has EMIF4 controller */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* + * Display CPU and Board information + */ +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* + * Size of malloc() pool + */ +#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB sector */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10) + \ + 2 * 1024 * 1024) +/* + * DDR related + */ +#define CONFIG_OMAP3_MICRON_DDR /* Micron DDR */ +#define CONFIG_SYS_CS0_SIZE (256 * 1024 * 1024) + +/* + * Hardware drivers + */ + +/* + * NS16550 Configuration + */ +#define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK + +/* + * select serial console configuration + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_COM1 OMAP34XX_UART1 +#define CONFIG_SERIAL1 /* UART1 */ + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ + 115200} +#define CONFIG_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_GENERIC_MMC +#define CONFIG_DOS_PARTITION + +#define CONFIG_USB_STORAGE +#define CONGIG_CMD_STORAGE +#define CONFIG_CMD_FAT + +/* EHCI */ +#define CONFIG_OMAP3_GPIO_5 +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_OMAP +#define CONFIG_OMAP_EHCI_PHY1_RESET 25 +#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 +/* #define CONFIG_EHCI_DCACHE */ + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_JFFS2 /* JFFS2 Support */ + +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_USB +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_GPIO + +#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ +#undef CONFIG_CMD_IMI /* iminfo */ +#undef CONFIG_CMD_IMLS /* List all found images */ + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C +#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C + +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_NFS + +/* + * Board NAND Info. + */ +#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ + /* to access nand */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ + /* to access */ + /* nand at CS0 */ + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ + /* NAND devices */ +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ + +#define CONFIG_JFFS2_NAND +/* nand device jffs2 lives on */ +#define CONFIG_JFFS2_DEV "nand0" +/* start of jffs2 partition */ +#define CONFIG_JFFS2_PART_OFFSET 0x680000 +#define CONFIG_JFFS2_PART_SIZE 0xf980000 /* sz of jffs2 part */ + +#define CONFIG_AUTO_COMPLETE +/* + * Miscellaneous configurable options + */ + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 32 /* max number of command */ + /* args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ + 0x01F00000) /* 31MB */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load */ + /* address */ + +/* + * AM3517 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 << 10) /* regular stack 128 KiB */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4 << 10) /* IRQ stack 4 KiB */ +#define CONFIG_STACKSIZE_FIQ (4 << 10) /* FIQ stack 4 KiB */ +#endif + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE (32 << 20) /* at least 32 MiB */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* SDRAM Bank Allocation method */ +/* TODO : Check */ +/* #define SDRC_R_B_C 1 */ + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ + +/* **** PISMO SUPPORT *** */ + +/* Configure the PISMO */ +#define PISMO1_NAND_SIZE GPMC_SIZE_128M + +#define CONFIG_NAND_OMAP_GPMC +#define GPMC_NAND_ECC_LP_x16_LAYOUT +#define CONFIG_ENV_IS_IN_NAND +#define SMNAND_ENV_OFFSET 0x180000 /* environment starts here */ + +#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET +#define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET + +/*----------------------------------------------------------------------- + * CFI FLASH driver setup + */ +/* timeout values are in ticks */ +#define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ) + +/* Flash banks JFFS2 should use */ +#define CONFIG_SYS_MAX_MTD_BANKS (CONFIG_SYS_MAX_FLASH_BANKS + \ + CONFIG_SYS_MAX_NAND_DEVICE) +#define CONFIG_SYS_JFFS2_MEM_NAND +/* use flash_info[2] */ +#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 +#define CONFIG_SYS_INIT_RAM_SIZE 0x800 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) + +/* + * ethernet support + * + */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_DRIVER_TI_EMAC +#define CONFIG_DRIVER_TI_EMAC_USE_RMII +#define CONFIG_MII +#define CONFIG_EMAC_MDIO_PHY_NUM 0 +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI + +#endif + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_CONSOLE +#define CONFIG_SPL_NAND_SIMPLE +#define CONFIG_SPL_NAND_SOFTECC +#define CONFIG_SPL_NAND_WORKSPACE 0x8f07f000 /* below BSS */ + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_POWER_SUPPORT +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" + +#define CONFIG_SPL_TEXT_BASE 0x40200000 /*CONFIG_SYS_SRAM_START*/ +#define CONFIG_SPL_MAX_SIZE 0xB400 /* 45 K */ +#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SYS_SPL_MALLOC_START 0x8f000000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 +#define CONFIG_SPL_BSS_START_ADDR 0x8f080000 /* end of RAM */ +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 + +/* NAND boot config */ +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 +#define CONFIG_SYS_NAND_ECCPOS {40, 41, 42, 43, 44, 45, 46, 47,\ + 48, 49, 50, 51, 52, 53, 54, 55,\ + 56, 57, 58, 59, 60, 61, 62, 63} +#define CONFIG_SYS_NAND_ECCSIZE 256 +#define CONFIG_SYS_NAND_ECCBYTES 3 + +#define CONFIG_SYS_NAND_ECCSTEPS (CONFIG_SYS_NAND_PAGE_SIZE / \ + CONFIG_SYS_NAND_ECCSIZE) +#define CONFIG_SYS_NAND_ECCTOTAL (CONFIG_SYS_NAND_ECCBYTES * \ + CONFIG_SYS_NAND_ECCSTEPS) + +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 + +#endif /* __TAM3517_H */
Hi Stefano,
- Copyright (C) 2011
- Stefano Babic, DENX Software Engineering, sbabic@denx.de.
- Copyright (C) 2009 TechNexion Ltd.
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
- High Level Configuration Options
- Display CPU and Board information
- Size of malloc() pool
2 * 1024 * 1024)
- DDR related
- Hardware drivers
- NS16550 Configuration
Can this be inlined? instead of defining the define...
- select serial console configuration
115200}
The latest patch from Ilya makes it: CONFIG_OMAP_EHCI_PHY1_RESET_GPIO
- Board NAND Info.
/* to access */
/* nand at CS0 */
/* NAND devices */
Can SZ_* defines from arch/arm/include/asm/sizes.h be used here?
- Miscellaneous configurable options
/* args */
/* address */
- AM3517 has 12 GP timers, they can be driven by the system clock
- (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK).
- This rate is divided by a local divisor.
- Stack sizes
- The stack sizes are set up in start.S using the settings below
These can be removed, as already done in a recent patch from Thomas: http://patchwork.ozlabs.org/patch/127087/
- Physical Memory Map
This is also, removed by a patch from Thomas: http://patchwork.ozlabs.org/patch/127145/
- FLASH and environment organization
- CFI FLASH driver setup
- ethernet support
Can this be aligned with all the others?
Can this have a spaces around the '*' operator?
Here (and in some more places) you have spaces for alignment.
On 23/11/2011 13:44, Igor Grinberg wrote:
Hi Stefano,
Hi Igor,
Yes, I will do it.
Ok, thanks, I will fix it.
I will drop the JFFS2 at all. If a JFFS2 is required, this should be not put in this common file, but in the board specific file.
Thanks, I will do it.
Ok !
Yes, of course.
I will recheck, thanks.
best regards, Stefano babic
Dear Igor Grinberg,
No, they cannot ;-)
I always discourage use of this stuff, just never found enough time to expunge all such occurrances.
Hi Wolfgang,
On 11/23/11 18:11, Wolfgang Denk wrote:
Dear Igor Grinberg,
No, they cannot ;-)
Ok. Just curious, what is the reason for discouraging the use of those?
Dear Stefano Babic,
Maybe you want to sort this list. And eventually remove entries that are defined by default?
Is there any good reason to disable the "iminfo" command?
Do we really need this double definitions? Please get rid of NAND_BASE.
Has this been tested?
/* address */
Don't we have any exception vectors or similar in low memory?
- Stack sizes
Incorrect multiline comment style. Please fix globally.
Don't we auto-detect the size?
Please extend to support redundant environment, plus one or two reserve sectors in case a sector goes bad.
This seems bogus, as there is no NOR flash on these devices.
All this probably does not work.
- ethernet support
Please delete unneeded empty lines like this one.
Urghhh... How do you guarantee this really works, no matter how the image gets linked?
(45 << 10) would be way easier to read...
Don't we auto-detect the RAM size?
On Wednesday, November 23, 2011, Wolfgang Denk wd@denx.de wrote:
Dear Stefano Babic,
address */
/* to access nand
address */
load */
/* address
All of the above is a copy/paste poor example. I've put some low grade thought into it, and it's on my 2012.03 wish list to have be good, or at least better.
In this case (config space stuff iirc), no. But it's also a semi-constant, but I don't have my TRM handy.
Kinda? We have a few cases: - all board revs have the same size, just code. It - a few board revs, and we can tell rev a from b, so hard code that way
We don't have a "ROM says..." like some other platforms.
I will do it
Yes - the command relies on NOR flash. In fact, in cmd_bootm.c do_imls() needs CONFIG_SYS_MAX_FLASH_BANKS, that has no sense on this SOM, because I have not CFI flash.
Also defining CONFIG_SYS_MAX_FLASH_BANKS does not work, because cfi.h is still included. I prefer disabling IMLS as adding fake CFI values.
NAND_BASE is the address of the controller defined in cpu.h. That iis correct.
CONFIG_SYS_NAND_ADDR seems to me obsolete and not used anymore - a lot of boards define it, I think it should be globally removed - I start dropping from here.
Yes - the only issue here is that only 31 MB (the SOM has 256 MB RAM) are tested as default. Personally I do not like to set as default value the whole RAM (subtracting the size of the bootloader code, of course !), because the test takes too much time for a fast run. The user can always provide parameters for the mtest command if he wants to test the whole RAM.
- Stack sizes
Thanks, I will fix it.
Good point, I will do it.
This is completely wrong, bad cut&paste ;-(. I will fix it.
Confirmed, it does not work and I will clean up.
ok
Best regards, Stefano Babic
Dear Stefano Babic,
I was referring to "iminfo", not to "imls".
Arrgh.. I see.
Thanks. I think after doing this, we should then rename NAND_BASE into CONFIG_SYS_NAND_ADDR.
Changes since V2:
- Move xstr define into common configuration file (Wolfgang Denk)
Changes since V1: - CONFIG_OMAP_EHCI_PHY1_RESET_GPIO (Igor Grinberg) - Used inline instead of adding unuseful defines - rebased on latest posted patches for AM3517 - drop mixing of space an tabs (Igor Grinberg) - move default environment into the common file - sort lists (W. Denk) - do not remove CONFIG_CMD_IMI (W. Denk) - drop CONFIG_SYS_NAND_ADDR (W. Denk) - coding styles (several comments) - add redundant environment (W. Denk) - drop completely CFI setup (W. Denk)
include/configs/tam3517-common.h | 361 ++++++++++++++++++++++++++++++++++++++ 1 files changed, 361 insertions(+), 0 deletions(-) create mode 100644 include/configs/tam3517-common.h
diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h new file mode 100644 index 0000000..817d468 --- /dev/null +++ b/include/configs/tam3517-common.h @@ -0,0 +1,361 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2009 TechNexion Ltd. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#ifndef __TAM3517_H +#define __TAM3517_H + +/* + * High Level Configuration Options + */ +#define CONFIG_OMAP /* in a TI OMAP core */ +#define CONFIG_OMAP34XX /* which is a 34XX */ + +#define CONFIG_SYS_TEXT_BASE 0x80008000 + +#define CONFIG_SYS_CACHELINE_SIZE 64 + +#define CONFIG_EMIF4 /* The chip has EMIF4 controller */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* + * Display CPU and Board information + */ +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* + * Size of malloc() pool + */ +#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB sector */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10) + \ + 2 * 1024 * 1024) +/* + * DDR related + */ +#define CONFIG_OMAP3_MICRON_DDR /* Micron DDR */ +#define CONFIG_SYS_CS0_SIZE (256 * 1024 * 1024) + +/* + * Hardware drivers + */ + +/* + * NS16550 Configuration + */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +/* + * select serial console configuration + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_COM1 OMAP34XX_UART1 +#define CONFIG_SERIAL1 /* UART1 */ + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ + 115200} +#define CONFIG_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_GENERIC_MMC +#define CONFIG_DOS_PARTITION + +/* EHCI */ +#define CONFIG_OMAP3_GPIO_5 +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_OMAP +#define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 25 +#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 +#define CONFIG_USB_STORAGE + +/* #define CONFIG_EHCI_DCACHE */ + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MII +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_PING +#define CONFIG_CMD_USB + +#undef CONFIG_CMD_FLASH /* only NAND on the SOM */ +#undef CONFIG_CMD_IMLS + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C +#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C + + +/* + * Board NAND Info. + */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ + /* to access */ + /* nand at CS0 */ + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ + /* NAND devices */ +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ + +#define CONFIG_AUTO_COMPLETE + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 32 /* max number of command */ + /* args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ + 0x01F00000) /* 31MB */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load */ + /* address */ + +/* + * AM3517 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* + * Stack sizes + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 << 10) /* regular stack 128 KiB */ + +/* + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE (32 << 20) /* at least 32 MiB */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* + * FLASH and environment organization + */ + +/* **** PISMO SUPPORT *** */ + +/* Configure the PISMO */ +#define PISMO1_NAND_SIZE GPMC_SIZE_128M + +#define CONFIG_NAND_OMAP_GPMC +#define GPMC_NAND_ECC_LP_x16_LAYOUT +#define CONFIG_ENV_IS_IN_NAND +#define SMNAND_ENV_OFFSET 0x180000 /* environment starts here */ + +/* Redundant Environment */ +#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET +#define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ + 2 * CONFIG_SYS_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 +#define CONFIG_SYS_INIT_RAM_SIZE 0x800 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) + +/* + * ethernet support, EMAC + * + */ +#define CONFIG_DRIVER_TI_EMAC +#define CONFIG_DRIVER_TI_EMAC_USE_RMII +#define CONFIG_MII +#define CONFIG_EMAC_MDIO_PHY_NUM 0 +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_CONSOLE +#define CONFIG_SPL_NAND_SIMPLE +#define CONFIG_SPL_NAND_SOFTECC +#define CONFIG_SPL_NAND_WORKSPACE 0x8f07f000 /* below BSS */ + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_POWER_SUPPORT +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" + +#define CONFIG_SPL_TEXT_BASE 0x40200000 /*CONFIG_SYS_SRAM_START*/ +#define CONFIG_SPL_MAX_SIZE (45 << 10) /* 45 K */ +#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SYS_SPL_MALLOC_START 0x8f000000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 +#define CONFIG_SPL_BSS_START_ADDR 0x8f080000 /* end of RAM */ +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 + +/* NAND boot config */ +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 +#define CONFIG_SYS_NAND_ECCPOS {40, 41, 42, 43, 44, 45, 46, 47,\ + 48, 49, 50, 51, 52, 53, 54, 55,\ + 56, 57, 58, 59, 60, 61, 62, 63} +#define CONFIG_SYS_NAND_ECCSIZE 256 +#define CONFIG_SYS_NAND_ECCBYTES 3 + +#define CONFIG_SYS_NAND_ECCSTEPS (CONFIG_SYS_NAND_PAGE_SIZE / \ + CONFIG_SYS_NAND_ECCSIZE) +#define CONFIG_SYS_NAND_ECCTOTAL (CONFIG_SYS_NAND_ECCBYTES * \ + CONFIG_SYS_NAND_ECCSTEPS) + +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 + +#define CONFIG_OF_LIBFDT +#define CONFIG_FIT +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_RBTREE +#define CONFIG_LZO +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_CMD_MTDPARTS + +/* Setup MTD for NAND on the SOM */ +#define MTDIDS_DEFAULT "nand0=omap2-nand.0" +#define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:512k(MLO)," \ + "512k(u-boot),128k(env1)," \ + "128k(env2),6m(kernel),-(rootfs)" + +#define xstr(s) str(s) +#define str(s) #s + +#define CONFIG_TAM3517_SETTINGS \ + "netdev=eth0\0" \ + "nandargs=setenv bootargs root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addip_sta=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "addip_dyn=setenv bootargs ${bootargs} ip=dhcp\0" \ + "addip=if test -n ${ipdyn};then run addip_dyn;" \ + "else run addip_sta;fi\0" \ + "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ + "addtty=setenv bootargs ${bootargs}" \ + " console=ttyO0,${baudrate}\0" \ + "addmisc=setenv bootargs ${bootargs} ${misc}\0" \ + "loadaddr=82000000\0" \ + "kernel_addr_r=82000000\0" \ + "hostname=" xstr(CONFIG_HOSTNAME) "\0" \ + "bootfile=" xstr(CONFIG_HOSTNAME) "/uImage\0" \ + "flash_self=run ramargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr} ${ramdisk_addr}\0" \ + "flash_nfs=run nfsargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr}\0" \ + "nandboot=run nandargs addip addtty addmtd addmisc;" \ + "nand read ${kernel_addr_r} kernel\0" \ + "bootm ${kernel_addr_r}\0" \ + "net_nfs=tftp ${kernel_addr_r} ${bootfile}; " \ + "run nfsargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr_r}\0" \ + "net_self=if run net_self_load;then " \ + "run ramargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr_r} ${ramdisk_addr_r};" \ + "else echo Images not loades;fi\0" \ + "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.img\0" \ + "load=tftp ${loadaddr} ${u-boot}\0" \ + "loadmlo=tftp ${loadaddr} ${mlo}\0" \ + "mlo=" xstr(CONFIG_HOSTNAME) "/MLO\0" \ + "uboot_addr=0x80000\0" \ + "update=nandecc sw;nand erase ${uboot_addr} 100000;" \ + "nand write ${loadaddr} ${uboot_addr} 80000\0" \ + "updatemlo=nandecc hw;nand erase 0 20000;" \ + "nand write ${loadaddr} 0 20000\0" \ + "upd=if run load;then echo Updating u-boot;if run update;" \ + "then echo U-Boot updated;" \ + "else echo Error updating u-boot !;" \ + "echo Board without bootloader !!;" \ + "fi;" \ + "else echo U-Boot not downloaded..exiting;fi\0" \ + +#endif /* __TAM3517_H */
The twister board is a development board using the TAM3517 SOM.
Support for NAND, 2 Ethernet (EMAC and SMC911), USB (EHCI_OMAP).
Changes since V2:
- drop GENERIC_MMC because already included by OMAP_HSMMC (Tom Rini)
Changes since V1: - drop unuseful comments (W. Denk) - drop postal address (globally) from headers - enable_gpmc_cs_config() to set chip select (Igor Grinberg) - drop unneeded #ifdef (W. Denk)
MAINTAINERS | 1 + board/technexion/twister/Makefile | 38 ++++ board/technexion/twister/twister.c | 116 ++++++++++ board/technexion/twister/twister.h | 411 ++++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/twister.h | 54 +++++ 6 files changed, 621 insertions(+), 0 deletions(-) create mode 100644 board/technexion/twister/Makefile create mode 100644 board/technexion/twister/twister.c create mode 100644 board/technexion/twister/twister.h create mode 100644 include/configs/twister.h
diff --git a/MAINTAINERS b/MAINTAINERS index fdc1a53..4e3246d 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -562,6 +562,7 @@ Stefano Babic sbabic@denx.de mx51evk i.MX51 polaris xscale/pxa trizepsiv xscale/pxa + twister omap3 vision2 i.MX51
Jason Liu r64343@freescale.com diff --git a/board/technexion/twister/Makefile b/board/technexion/twister/Makefile new file mode 100644 index 0000000..38b7b14 --- /dev/null +++ b/board/technexion/twister/Makefile @@ -0,0 +1,38 @@ +# +# Copyright (C) 2011 Ilya Yanok, Emcraft Systems +# +# Based on ti/evm/Makefile +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := $(BOARD).o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend diff --git a/board/technexion/twister/twister.c b/board/technexion/twister/twister.c new file mode 100644 index 0000000..06fac7b --- /dev/null +++ b/board/technexion/twister/twister.c @@ -0,0 +1,116 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2009 TechNexion Ltd. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/mem.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/omap_gpio.h> +#include <asm/arch/mmc_host_def.h> +#include <i2c.h> +#include <asm/gpio.h> +#include "twister.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* Timing definitions for Ethernet Controller */ +static const u32 gpmc_smc911[] = { + NET_GPMC_CONFIG1, + NET_GPMC_CONFIG2, + NET_GPMC_CONFIG3, + NET_GPMC_CONFIG4, + NET_GPMC_CONFIG5, + NET_GPMC_CONFIG6, +}; + +static const u32 gpmc_XR16L2751[] = { + XR16L2751_GPMC_CONFIG1, + XR16L2751_GPMC_CONFIG2, + XR16L2751_GPMC_CONFIG3, + XR16L2751_GPMC_CONFIG4, + XR16L2751_GPMC_CONFIG5, + XR16L2751_GPMC_CONFIG6, +}; + +int board_init(void) +{ + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + /* Chip select 1 and 3 are used for XR16L2751 UART controller */ + enable_gpmc_cs_config(gpmc_XR16L2751, &gpmc_cfg->cs[1], + XR16L2751_UART1_BASE, GPMC_SIZE_16M); + + enable_gpmc_cs_config(gpmc_XR16L2751, &gpmc_cfg->cs[3], + XR16L2751_UART2_BASE, GPMC_SIZE_16M); + + gpio_request(CONFIG_OMAP_EHCI_PHY1_RESET_GPIO, "USB_PHY1_RESET"); + gpio_direction_output(CONFIG_OMAP_EHCI_PHY1_RESET_GPIO, 1); + + return 0; +} + +int misc_init_r(void) +{ + dieid_num_r(); + + return 0; +} + +/* + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers specific to the + * hardware. Many pins need to be moved from protect to primary + * mode. + */ +void set_muxconf_regs(void) +{ + MUX_TWISTER(); +} + +int board_eth_init(bd_t *bis) +{ + davinci_emac_initialize(); + + /* init cs for extern lan */ + enable_gpmc_cs_config(gpmc_smc911, &gpmc_cfg->cs[5], + CONFIG_SMC911X_BASE, GPMC_SIZE_16M); + if (smc911x_initialize(0, CONFIG_SMC911X_BASE) <= 0) + printf("\nError initializing SMC911x controlleri\n"); + + return 0; +} + +#if defined(CONFIG_OMAP_HSMMC) && \ + !defined(CONFIG_SPL_BUILD) +int board_mmc_init(bd_t *bis) +{ + return omap_mmc_init(0); +} +#endif diff --git a/board/technexion/twister/twister.h b/board/technexion/twister/twister.h new file mode 100644 index 0000000..a2051c0 --- /dev/null +++ b/board/technexion/twister/twister.h @@ -0,0 +1,411 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2010 TechNexion Ltd. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#ifndef _TAM3517_H_ +#define _TAM3517_H_ + +const omap3_sysinfo sysinfo = { + DDR_DISCRETE, + "TAM3517 TWISTER Board", + "NAND", +}; + +#define XR16L2751_GPMC_CONFIG1 0x00000000 +#define XR16L2751_GPMC_CONFIG2 0x001e1e01 +#define XR16L2751_GPMC_CONFIG3 0x00080300 +#define XR16L2751_GPMC_CONFIG4 0x1c091c09 +#define XR16L2751_GPMC_CONFIG5 0x04181f1f +#define XR16L2751_GPMC_CONFIG6 0x00000FCF + +#define XR16L2751_UART1_BASE 0x21000000 +#define XR16L2751_UART2_BASE 0x23000000 + + +/* + * IEN - Input Enable + * IDIS - Input Disable + * PTD - Pull type Down + * PTU - Pull type Up + * DIS - Pull type selection is inactive + * EN - Pull type selection is active + * M0 - Mode 0 + * The commented string gives the final mux configuration for that pin + */ +#define MUX_TWISTER() \ + /* SDRC */\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS0N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_DQS1N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_DQS2N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_DQS3N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_CKE0), (M0)) \ + MUX_VAL(CP(SDRC_CKE1), (M0)) \ + MUX_VAL(CP(STRBEN_DLY0), (IEN | PTD | EN | M0)) \ + /*sdrc_strben_dly0*/\ + MUX_VAL(CP(STRBEN_DLY1), (IEN | PTD | EN | M0)) \ + /*sdrc_strben_dly1*/\ + /* GPMC */\ + MUX_VAL(CP(GPMC_A1), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A2), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A3), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A4), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A5), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A6), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A7), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A8), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A9), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A10), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D0), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D2), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D3), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D4), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D5), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D6), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D7), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D8), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D9), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D10), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D11), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D12), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D13), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D14), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D15), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS2), (IDIS | PTD | EN | M2)) /*PWM9*/\ + MUX_VAL(CP(GPMC_NCS3), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS4), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(GPMC_NCS5), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS6), (IDIS | PTD | EN | M3)) /*PWM11*/ \ + MUX_VAL(CP(GPMC_NCS7), (IDIS | PTD | EN | M4)) /*GPIO_58*/ \ + MUX_VAL(CP(GPMC_CLK), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NBE1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_WAIT1), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M4)) /*GPIO_64*/\ + MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M4)) \ + /* DSS */\ + MUX_VAL(CP(DSS_PCLK), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_HSYNC), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_VSYNC), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_ACBIAS), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA0), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA1), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA2), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA3), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA4), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA5), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA6), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA7), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA8), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA9), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA10), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA11), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA12), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA13), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA14), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA15), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA16), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA17), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA18), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA19), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA20), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA21), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0)) \ + /* CAMERA */\ + MUX_VAL(CP(CAM_HS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_VS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_XCLKA), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_PCLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_FLD), (IDIS | PTD | DIS | M4)) /*GPIO_98*/\ + MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_XCLKB), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_WEN), (IEN | PTD | DIS | M4)) /*GPIO_167*/\ + MUX_VAL(CP(CAM_STROBE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DX0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DY0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DX1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DY1), (IEN | PTD | DIS | M0)) \ + /* MMC */\ + MUX_VAL(CP(MMC1_CLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_CMD), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M4)) \ + /* CardDetect */\ + MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M4)) \ + \ + MUX_VAL(CP(MMC2_CLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC2_CMD), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT0), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT1), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT2), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT3), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT4), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT5), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT6), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT7), (IDIS | PTU | EN | M4)) \ + /* McBSP */\ + MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_CLKR), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_FSR), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(MCBSP1_DX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_DR), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTD | DIS | M0)) \ + \ + MUX_VAL(CP(MCBSP2_FSX), (IEN | PTD | EN | M4)) /*GPIO_116*/ \ + MUX_VAL(CP(MCBSP2_CLKX), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(MCBSP2_DR), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(MCBSP2_DX), (IEN | PTD | EN | M4)) \ + \ + MUX_VAL(CP(MCBSP3_DX), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MCBSP3_DR), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MCBSP3_CLKX), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MCBSP3_FSX), (IEN | PTU | EN | M4)) \ + \ + MUX_VAL(CP(MCBSP4_CLKX), (IEN | PTD | DIS | M4)) /*GPIO_152*/\ + MUX_VAL(CP(MCBSP4_DR), (IDIS | PTD | DIS | M4)) /*GPIO_153*/\ + MUX_VAL(CP(MCBSP4_DX), (IDIS | PTD | DIS | M4)) /*GPIO_154*/\ + MUX_VAL(CP(MCBSP4_FSX), (IEN | PTD | DIS | M4)) /*GPIO_155*/\ + /* UART */\ + MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART1_RTS), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(UART1_CTS), (IEN | PTU | EN | M4)) \ + \ + MUX_VAL(CP(UART1_RX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(UART2_CTS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART2_RX), (IEN | PTD | DIS | M0)) \ + \ + MUX_VAL(CP(UART3_CTS_RCTX), (IDIS | PTD | DIS | M4)) /*GPIO_163*/ \ + MUX_VAL(CP(UART3_RTS_SD), (IEN | PTD | DIS | M4)) /*GPIO_164*/\ + MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) \ + /* I2C */\ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0)) \ + /* McSPI */\ + MUX_VAL(CP(MCSPI1_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI1_CS0), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(MCSPI1_CS1), (IEN | PTD | EN | M4)) /*GPIO_175*/\ + MUX_VAL(CP(MCSPI1_CS2), (IEN | PTD | EN | M4)) /*GPIO_176*/\ + MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | EN | M4)) \ + \ + MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | EN | M4)) \ + /* CCDC */\ + MUX_VAL(CP(CCDC_PCLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CCDC_FIELD), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(CCDC_HD), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CCDC_VD), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CCDC_WEN), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(CCDC_DATA0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA7), (IEN | PTD | DIS | M0)) \ + /* RMII */\ + MUX_VAL(CP(RMII_MDIO_DATA), (IEN | M0)) \ + MUX_VAL(CP(RMII_MDIO_CLK), (M0)) \ + MUX_VAL(CP(RMII_RXD0) , (IEN | PTD | M0)) \ + MUX_VAL(CP(RMII_RXD1), (IEN | PTD | M0)) \ + MUX_VAL(CP(RMII_CRS_DV), (IEN | PTD | M0)) \ + MUX_VAL(CP(RMII_RXER), (PTD | M0)) \ + MUX_VAL(CP(RMII_TXD0), (PTD | M0)) \ + MUX_VAL(CP(RMII_TXD1), (PTD | M0)) \ + MUX_VAL(CP(RMII_TXEN), (PTD | M0)) \ + MUX_VAL(CP(RMII_50MHZ_CLK), (IEN | PTD | EN | M0)) \ + /* HECC */\ + MUX_VAL(CP(HECC1_TXD), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(HECC1_RXD), (IEN | PTU | EN | M0)) \ + /* HSUSB */\ + MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(HSUSB0_DIR), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_NXT), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(USB0_DRVBUS), (IEN | PTD | EN | M0)) \ + /* HDQ */\ + MUX_VAL(CP(HDQ_SIO), (IEN | PTD | EN | M4)) \ + /* Control and debug */\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(SYS_NRESWARM), (IDIS | PTU | DIS | M4)) \ + /* - GPIO30 */\ + MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /*GPIO_2*/\ + MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /*GPIO_3 */\ + MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /*GPIO_4*/\ + MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4)) /*GPIO_5*/\ + MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4)) /*GPIO_6*/\ + MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /*GPIO_7*/\ + MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4)) /*GPIO_8*/\ + /* - VIO_1V8*/\ + MUX_VAL(CP(SYS_BOOT7), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SYS_BOOT8), (IEN | PTD | EN | M0)) \ + \ + MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) \ + /* JTAG */\ + MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_EMU0), (IDIS | PTD | EN | M4)) /*GPIO_11*/ \ + MUX_VAL(CP(JTAG_EMU1), (IDIS | PTD | EN | M4)) /*GPIO_31*/ \ + /* ETK (ES2 onwards) */\ + MUX_VAL(CP(ETK_CLK_ES2), (IDIS | PTD | DIS | M3)) \ + /* hsusb1_stp */ \ + MUX_VAL(CP(ETK_CTL_ES2), (IDIS | PTD | DIS | M3)) \ + /* hsusb1_clk */\ + MUX_VAL(CP(ETK_D0_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D1_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D2_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D3_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D4_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D5_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D6_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D7_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D8_ES2), (IEN | PTD | EN | M3)) \ + /* hsusb1_dir */\ + MUX_VAL(CP(ETK_D9_ES2), (IEN | PTD | EN | M3)) \ + /* hsusb1_nxt */\ + MUX_VAL(CP(ETK_D10_ES2), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTD | DIS | M4)) \ + MUX_VAL(CP(ETK_D12_ES2), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(ETK_D13_ES2), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(ETK_D14_ES2), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(ETK_D15_ES2), (IEN | PTD | DIS | M4)) \ + /* Die to Die */\ + MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0)) \ + +#endif diff --git a/boards.cfg b/boards.cfg index 11ef60b..7826e29 100644 --- a/boards.cfg +++ b/boards.cfg @@ -195,6 +195,7 @@ omap3_evm_quick_nand arm armv7 evm ti omap3_sdp3430 arm armv7 sdp3430 ti omap3 devkit8000 arm armv7 devkit8000 timll omap3 mcx arm armv7 mcx htkw omap3 +twister arm armv7 twister technexion omap3 omap4_panda arm armv7 panda ti omap4 omap4_sdp4430 arm armv7 sdp4430 ti omap4 omap5_evm arm armv7 omap5_evm ti omap5 diff --git a/include/configs/twister.h b/include/configs/twister.h new file mode 100644 index 0000000..64a886d --- /dev/null +++ b/include/configs/twister.h @@ -0,0 +1,54 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2009 TechNexion Ltd. + * + * Configuration for the Technexion twister board. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include "tam3517-common.h" + +#define MACH_TYPE_TAM3517 2818 +#define CONFIG_MACH_TYPE MACH_TYPE_TAM3517 + +#define CONFIG_TAM3517_SW3_SETTINGS +#define CONFIG_XR16L2751 + +#define CONFIG_BOOTDELAY 10 + +#define CONFIG_BOOTFILE "uImage" + +#define CONFIG_HOSTNAME twister + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_PROMPT "twister => " + +#define CONFIG_SMC911X +#define CONFIG_SMC911X_16_BIT +#define CONFIG_SMC911X_BASE 0x2C000000 +#define CONFIG_SMC911X_NO_EEPROM + +#define CONFIG_EXTRA_ENV_SETTINGS CONFIG_TAM3517_SETTINGS \ + "bootcmd=run nandboot\0" + +#endif /* __CONFIG_H */
(re-sent due to the U-Boot MX rejecting my provider's servers -- again)
Hi Stefano,
I see this match made it in IMX then ARM, but it seems not to build here either with ELDK 4.2 or linaro (Ubuntu) cross tool chains:
Configuring for twister board... omap_gpmc.c:33:30: attention : ‘hw_nand_oob’ defined but not used [-Wunused-variable] omap_gpmc.c:78:13: attention : ‘omap_hwecc_init’ defined but not used [-Wunused-function] omap_gpmc.c:116:12: attention : ‘omap_correct_data’ defined but not used [-Wunused-function] omap_gpmc.c:182:12: attention : ‘omap_calculate_ecc’ defined but not used [-Wunused-function] omap_gpmc.c:208:13: attention : ‘omap_enable_hwecc’ defined but not used [-Wunused-function] drivers/usb/host/libusb_host.o: In function `usb_lowlevel_stop': /home/uboot/src/u-boot-arm/drivers/usb/host/ehci-hcd.c:806: undefined reference to `ehci_hcd_stop' drivers/usb/host/libusb_host.o: In function `usb_lowlevel_init': /home/uboot/src/u-boot-arm/drivers/usb/host/ehci-hcd.c:814: undefined reference to `ehci_hcd_init' arm-linux-gnueabi-ld: BFD (GNU Binutils for Ubuntu) 2.21.53.20110810 assertion fail ../../bfd/elf32-arm.c:7498 arm-linux-gnueabi-ld: BFD (GNU Binutils for Ubuntu) 2.21.53.20110810 assertion fail ../../bfd/elf32-arm.c:7498 arm-linux-gnueabi-ld: BFD (GNU Binutils for Ubuntu) 2.21.53.20110810 assertion fail ../../bfd/elf32-arm.c:13828 /bin/sh : ligne 1 : 23855 Erreur de segmentation arm-linux-gnueabi-ld -pie -T u-boot.lds -Bstatic -Ttext 0x80008000 $UNDEF_SYM arch/arm/cpu/armv7/start.o --start-group api/libapi.o arch/arm/cpu/armv7/libarmv7.o arch/arm/cpu/armv7/omap-common/libomap-common.o arch/arm/cpu/armv7/omap3/libomap3.o arch/arm/lib/libarm.o common/libcommon.o disk/libdisk.o drivers/bios_emulator/libatibiosemu.o drivers/block/libblock.o drivers/dma/libdma.o drivers/fpga/libfpga.o drivers/gpio/libgpio.o drivers/hwmon/libhwmon.o drivers/i2c/libi2c.o drivers/input/libinput.o drivers/misc/libmisc.o drivers/mmc/libmmc.o drivers/mtd/libmtd.o drivers/mtd/nand/libnand.o drivers/mtd/onenand/libonenand.o drivers/mtd/spi/libspi_flash.o drivers/mtd/ubi/libubi.o drivers/net/libnet.o drivers/net/phy/libphy.o drivers/pci/libpci.o drivers/pcmcia/libpcmcia.o drivers/power/libpower.o drivers/rtc/librtc.o drivers/serial/libserial.o drivers/spi/libspi.o drivers/twserial/libtws.o drivers/usb/eth/libusb_eth.o drivers/usb
/gadget/libusb_gadget.o drivers/usb/host/libusb_host.o drivers/usb/musb/libusb_musb.o drivers/usb/phy/libusb_phy.o drivers/usb/ulpi/libusb_ulpi.o drivers/video/libvideo.o drivers/watchdog/libwatchdog.o fs/cramfs/libcramfs.o fs/ext2/libext2fs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o fs/reiserfs/libreiserfs.o fs/ubifs/libubifs.o fs/yaffs2/libyaffs2.o lib/libfdt/libfdt.o lib/libgeneric.o lib/lzma/liblzma.o lib/lzo/liblzo.o lib/zlib/libz.o net/libnet.o post/libpost.o board/technexion/twister/libtwister.o --end-group /home/uboot/src/u-boot-arm/arch/arm/lib/eabi_compat.o -L /usr/lib/gcc/arm-linux-gnueabi/4.6.1 -lgcc -Map u-boot.map -o u-boot
make: *** [u-boot] Erreur 139 make: *** Attente des tâches non terminées.... arm-linux-gnueabi-size: ./u-boot: File format not recognized
--------------------- SUMMARY ---------------------------- Boards compiled: 1 Boards with warnings or errors: 1 ( twister )
The above was tried on 10a4fa9e22b9677819b3901a87eec05875b346ad (the current u-boot-arm/master, but trying various commits in between it and 92e30c07e02b84a3b63205fcb29ac57defd043f6 (creation of twister), I find no commit where it builds.
Stefano, can you have a look at this?
Amicalement,
Hi Stefano,
Hi Albert, hi Tom,
The twister board depends on several patches for the AM3517 processor previously senty by Ilya Yanok. One of them (maybe because it is USB related and should go into u-boot-usb) is missing.
http://patchwork.ozlabs.org/patch/130952/
The patch is set to new and assigned to Remy, but he gived up as maintainer - nobody checks at it ;-(.
I can at least sent my tested-by - it was nice if you can pick it up.
Hi Stefano,
Hi Stefano,
Hi Albert, hi Tom,
Board then compiles but with warnings for 4 declared but unused symbols.
Considering that all it does is adding a new EHCI driver, the worst impact it can have is to not function properly for boards using it, which at the moment means omap3_beagle and tam3517; but it won't affect USB on existing boards.
But then I wonder why twister needs it at all, as it does not have a single USB config option in its header config file...
*If* someone can explain to me why a patch that adds a new USB EHCI driver is needed by a board which does not have any "USB" in its config header file, and *unless Wolfgang says otherwise*, I agree to accept patch 130952 with your Tested-By.
Amicalement,
I see also the warnings, they are related to a couple of drivers (NAND). They need a clean-up patch to fix them.
Well, that is not true...
I can explain this. The twister board is based on the Technexion TAM3517 SOM. There is a common configuration files for all boards (I have also added a second one) using this module with the TI AM3517 SOC:
Because pins for USB are fixed on the SOM, the USB configuration is made common to all boards. In tam3517-common.h you can find:
/* EHCI */ #define CONFIG_OMAP3_GPIO_5 #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_OMAP #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 25 #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 #define CONFIG_USB_STORAGE
..added Wolfgang in CC
Ok, got it. I had only read the twister entry in boards.cfg and thus I thought twister was 'simple' omap3.
So that leaves this:
Oops. Thanks. :)
Amicalement,
On Sat, Jan 14, 2012 at 1:47 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Stefano,
So what happened is I accidentally put this board into u-boot-ti/next a while back, before the USB changes went in, without realizing it. The reason the USB changes haven't gone in, still, is that they've been made more generic (as the IP block is shared between these boards and omap4/5). For that part of the problem perhaps we should turn off the USB portion of the board for now?
Ok - I will sent a patch to turn USB off, until EHCI omap flows into mainline.
Stefano
On Thu, Dec 1, 2011 at 2:56 AM, Stefano Babic sbabic@denx.de wrote:
The TAM3517 is a SOM module that can be used on custom boards. The patch add a common configuration file that is included by the boards using this module.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Tapani Utrianen tapani@technexion.com CC: Tom Rini tom.rini@gmail.com CC: Sandeep Paulraj s-paulraj@ti.com
This and patch 2/2 are now queued up in u-boot-ti/next, thanks.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Tapani Utrianen tapani@technexion.com CC: Tom Rini tom.rini@gmail.com CC: Sandeep Paulraj s-paulraj@ti.com --- MAINTAINERS | 1 + board/technexion/twister/Makefile | 44 ++++ board/technexion/twister/twister.c | 126 +++++++++++ board/technexion/twister/twister.h | 400 ++++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/twister.h | 103 +++++++++ 6 files changed, 675 insertions(+), 0 deletions(-) create mode 100644 board/technexion/twister/Makefile create mode 100644 board/technexion/twister/twister.c create mode 100644 board/technexion/twister/twister.h create mode 100644 include/configs/twister.h
diff --git a/MAINTAINERS b/MAINTAINERS index 7f73900..4d5d947 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -565,6 +565,7 @@ Stefano Babic sbabic@denx.de mx51evk i.MX51 polaris xscale/pxa trizepsiv xscale/pxa + twister omap3 vision2 i.MX51
Jason Liu r64343@freescale.com diff --git a/board/technexion/twister/Makefile b/board/technexion/twister/Makefile new file mode 100644 index 0000000..5d29458 --- /dev/null +++ b/board/technexion/twister/Makefile @@ -0,0 +1,44 @@ +# +# Copyright (C) 2011 Ilya Yanok, Emcraft Systems +# +# Based on ti/evm/Makefile +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := $(BOARD).o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend diff --git a/board/technexion/twister/twister.c b/board/technexion/twister/twister.c new file mode 100644 index 0000000..89a4d81 --- /dev/null +++ b/board/technexion/twister/twister.c @@ -0,0 +1,126 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2009 TechNexion Ltd. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/mem.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/omap_gpio.h> +#include <asm/arch/mmc_host_def.h> +#include <i2c.h> +#include <asm/gpio.h> +#include "twister.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Routine: board_init + * Description: Early hardware init. + */ +int board_init(void) +{ + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + writel(0x00000000, &gpmc_cfg->cs[1].config1); + writel(0x001e1e01, &gpmc_cfg->cs[1].config2); + writel(0x00080300, &gpmc_cfg->cs[1].config3); + writel(0x1c091c09, &gpmc_cfg->cs[1].config4); + writel(0x04181f1f, &gpmc_cfg->cs[1].config5); + writel(0x00000FCF, &gpmc_cfg->cs[1].config6); + writel(0x00000f61, &gpmc_cfg->cs[1].config7); + + writel(0x00000000, &gpmc_cfg->cs[3].config1); + writel(0x001e1e01, &gpmc_cfg->cs[3].config2); + writel(0x00080300, &gpmc_cfg->cs[3].config3); + writel(0x1c091c09, &gpmc_cfg->cs[3].config4); + writel(0x04181f1f, &gpmc_cfg->cs[3].config5); + writel(0x00000FCF, &gpmc_cfg->cs[3].config6); + writel(0x00000f63, &gpmc_cfg->cs[3].config7); + + gpio_request(CONFIG_OMAP_EHCI_PHY1_RESET, "USB_PHY1_RESET"); + gpio_direction_output(CONFIG_OMAP_EHCI_PHY1_RESET, 1); + + return 0; +} + +/* + * Routine: misc_init_r + * Description: Init i2c, ethernet, etc... (done here so udelay works) + */ +int misc_init_r(void) +{ + dieid_num_r(); + + return 0; +} + +/* + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers specific to the + * hardware. Many pins need to be moved from protect to primary + * mode. + */ +void set_muxconf_regs(void) +{ + MUX_TWISTER(); +} + +/* + * Initializes on-chip ethernet controllers. + * to override, implement board_eth_init() + */ +int board_eth_init(bd_t *bis) +{ +#if defined(CONFIG_DRIVER_TI_EMAC) + davinci_emac_initialize(); +#endif +#if defined(CONFIG_SMC911X) + /* init cs for extern lan */ + writel(NET_GPMC_CONFIG1, &gpmc_cfg->cs[5].config1); + writel(NET_GPMC_CONFIG2, &gpmc_cfg->cs[5].config2); + writel(NET_GPMC_CONFIG3, &gpmc_cfg->cs[5].config3); + writel(NET_GPMC_CONFIG4, &gpmc_cfg->cs[5].config4); + writel(NET_GPMC_CONFIG5, &gpmc_cfg->cs[5].config5); + writel(NET_GPMC_CONFIG6, &gpmc_cfg->cs[5].config6); + writel(NET_GPMC_CONFIG7, &gpmc_cfg->cs[5].config7); + if (smc911x_initialize(0, CONFIG_SMC911X_BASE) <= 0) + printf("\nError initializing SMC911x controlleri\n"); + +#endif + return 0; +} + +#if defined(CONFIG_GENERIC_MMC) && defined(CONFIG_OMAP_HSMMC) && \ + !defined(CONFIG_SPL_BUILD) +int board_mmc_init(bd_t *bis) +{ + return omap_mmc_init(0); +} +#endif diff --git a/board/technexion/twister/twister.h b/board/technexion/twister/twister.h new file mode 100644 index 0000000..d19a149 --- /dev/null +++ b/board/technexion/twister/twister.h @@ -0,0 +1,400 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2010 TechNexion Ltd. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef _TAM3517_H_ +#define _TAM3517_H_ + +const omap3_sysinfo sysinfo = { + DDR_DISCRETE, + "TAM3517 TWISTER Board", + "NAND", +}; + +/* + * IEN - Input Enable + * IDIS - Input Disable + * PTD - Pull type Down + * PTU - Pull type Up + * DIS - Pull type selection is inactive + * EN - Pull type selection is active + * M0 - Mode 0 + * The commented string gives the final mux configuration for that pin + */ +#define MUX_TWISTER() \ + /* SDRC */\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS0N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_DQS1N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_DQS2N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_DQS3N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_CKE0), (M0)) \ + MUX_VAL(CP(SDRC_CKE1), (M0)) \ + MUX_VAL(CP(STRBEN_DLY0), (IEN | PTD | EN | M0)) \ + /*sdrc_strben_dly0*/\ + MUX_VAL(CP(STRBEN_DLY1), (IEN | PTD | EN | M0)) \ + /*sdrc_strben_dly1*/\ + /* GPMC */\ + MUX_VAL(CP(GPMC_A1), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A2), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A3), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A4), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A5), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A6), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A7), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A8), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A9), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A10), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D0), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D2), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D3), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D4), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D5), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D6), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D7), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D8), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D9), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D10), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D11), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D12), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D13), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D14), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D15), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS2), (IDIS | PTD | EN | M2)) /*PWM9*/\ + MUX_VAL(CP(GPMC_NCS3), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS4), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(GPMC_NCS5), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS6), (IDIS | PTD | EN | M3)) /*PWM11*/ \ + MUX_VAL(CP(GPMC_NCS7), (IDIS | PTD | EN | M4)) /*GPIO_58*/ \ + MUX_VAL(CP(GPMC_CLK), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NBE1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_WAIT1), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M4)) /*GPIO_64*/\ + MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M4)) \ + /* DSS */\ + MUX_VAL(CP(DSS_PCLK), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_HSYNC), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_VSYNC), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_ACBIAS), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA0), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA1), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA2), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA3), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA4), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA5), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA6), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA7), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA8), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA9), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA10), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA11), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA12), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA13), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA14), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA15), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA16), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA17), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA18), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA19), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA20), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA21), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0)) \ + /* CAMERA */\ + MUX_VAL(CP(CAM_HS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_VS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_XCLKA), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_PCLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_FLD), (IDIS | PTD | DIS | M4)) /*GPIO_98*/\ + MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_XCLKB), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_WEN), (IEN | PTD | DIS | M4)) /*GPIO_167*/\ + MUX_VAL(CP(CAM_STROBE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DX0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DY0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DX1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DY1), (IEN | PTD | DIS | M0)) \ + /* MMC */\ + MUX_VAL(CP(MMC1_CLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_CMD), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M4)) \ + /* CardDetect */\ + MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M4)) \ + \ + MUX_VAL(CP(MMC2_CLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC2_CMD), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT0), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT1), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT2), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT3), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT4), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT5), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT6), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT7), (IDIS | PTU | EN | M4)) \ + /* McBSP */\ + MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_CLKR), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_FSR), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(MCBSP1_DX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_DR), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTD | DIS | M0)) \ + \ + MUX_VAL(CP(MCBSP2_FSX), (IEN | PTD | EN | M4)) /*GPIO_116*/ \ + MUX_VAL(CP(MCBSP2_CLKX), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(MCBSP2_DR), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(MCBSP2_DX), (IEN | PTD | EN | M4)) \ + \ + MUX_VAL(CP(MCBSP3_DX), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MCBSP3_DR), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MCBSP3_CLKX), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MCBSP3_FSX), (IEN | PTU | EN | M4)) \ + \ + MUX_VAL(CP(MCBSP4_CLKX), (IEN | PTD | DIS | M4)) /*GPIO_152*/\ + MUX_VAL(CP(MCBSP4_DR), (IDIS | PTD | DIS | M4)) /*GPIO_153*/\ + MUX_VAL(CP(MCBSP4_DX), (IDIS | PTD | DIS | M4)) /*GPIO_154*/\ + MUX_VAL(CP(MCBSP4_FSX), (IEN | PTD | DIS | M4)) /*GPIO_155*/\ + /* UART */\ + MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART1_RTS), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(UART1_CTS), (IEN | PTU | EN | M4)) \ + \ + MUX_VAL(CP(UART1_RX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(UART2_CTS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART2_RX), (IEN | PTD | DIS | M0)) \ + \ + MUX_VAL(CP(UART3_CTS_RCTX), (IDIS | PTD | DIS | M4)) /*GPIO_163*/ \ + MUX_VAL(CP(UART3_RTS_SD), (IEN | PTD | DIS | M4)) /*GPIO_164*/\ + MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) \ + /* I2C */\ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0)) \ + /* McSPI */\ + MUX_VAL(CP(MCSPI1_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI1_CS0), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(MCSPI1_CS1), (IEN | PTD | EN | M4)) /*GPIO_175*/\ + MUX_VAL(CP(MCSPI1_CS2), (IEN | PTD | EN | M4)) /*GPIO_176*/\ + MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | EN | M4)) \ + \ + MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | EN | M4)) \ + /* CCDC */\ + MUX_VAL(CP(CCDC_PCLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CCDC_FIELD), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(CCDC_HD), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CCDC_VD), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CCDC_WEN), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(CCDC_DATA0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA7), (IEN | PTD | DIS | M0)) \ + /* RMII */\ + MUX_VAL(CP(RMII_MDIO_DATA), (IEN | M0)) \ + MUX_VAL(CP(RMII_MDIO_CLK), (M0)) \ + MUX_VAL(CP(RMII_RXD0) , (IEN | PTD | M0)) \ + MUX_VAL(CP(RMII_RXD1), (IEN | PTD | M0)) \ + MUX_VAL(CP(RMII_CRS_DV), (IEN | PTD | M0)) \ + MUX_VAL(CP(RMII_RXER), (PTD | M0)) \ + MUX_VAL(CP(RMII_TXD0), (PTD | M0)) \ + MUX_VAL(CP(RMII_TXD1), (PTD | M0)) \ + MUX_VAL(CP(RMII_TXEN), (PTD | M0)) \ + MUX_VAL(CP(RMII_50MHZ_CLK), (IEN | PTD | EN | M0)) \ + /* HECC */\ + MUX_VAL(CP(HECC1_TXD), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(HECC1_RXD), (IEN | PTU | EN | M0)) \ + /* HSUSB */\ + MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(HSUSB0_DIR), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_NXT), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(USB0_DRVBUS), (IEN | PTD | EN | M0)) \ + /* HDQ */\ + MUX_VAL(CP(HDQ_SIO), (IEN | PTD | EN | M4)) \ + /* Control and debug */\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(SYS_NRESWARM), (IDIS | PTU | DIS | M4)) \ + /* - GPIO30 */\ + MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /*GPIO_2*/\ + MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /*GPIO_3 */\ + MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /*GPIO_4*/\ + MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4)) /*GPIO_5*/\ + MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4)) /*GPIO_6*/\ + MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /*GPIO_7*/\ + MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4)) /*GPIO_8*/\ + /* - VIO_1V8*/\ + MUX_VAL(CP(SYS_BOOT7), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SYS_BOOT8), (IEN | PTD | EN | M0)) \ + \ + MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) \ + /* JTAG */\ + MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_EMU0), (IDIS | PTD | EN | M4)) /*GPIO_11*/ \ + MUX_VAL(CP(JTAG_EMU1), (IDIS | PTD | EN | M4)) /*GPIO_31*/ \ + /* ETK (ES2 onwards) */\ + MUX_VAL(CP(ETK_CLK_ES2), (IDIS | PTD | DIS | M3)) \ + /* hsusb1_stp */ \ + MUX_VAL(CP(ETK_CTL_ES2), (IDIS | PTD | DIS | M3)) \ + /* hsusb1_clk */\ + MUX_VAL(CP(ETK_D0_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D1_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D2_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D3_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D4_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D5_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D6_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D7_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D8_ES2), (IEN | PTD | EN | M3)) \ + /* hsusb1_dir */\ + MUX_VAL(CP(ETK_D9_ES2), (IEN | PTD | EN | M3)) \ + /* hsusb1_nxt */\ + MUX_VAL(CP(ETK_D10_ES2), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTD | DIS | M4)) \ + MUX_VAL(CP(ETK_D12_ES2), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(ETK_D13_ES2), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(ETK_D14_ES2), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(ETK_D15_ES2), (IEN | PTD | DIS | M4)) \ + /* Die to Die */\ + MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0)) \ + +#endif diff --git a/boards.cfg b/boards.cfg index e6c9c53..a5d3446 100644 --- a/boards.cfg +++ b/boards.cfg @@ -188,6 +188,7 @@ omap3_evm arm armv7 evm ti omap3_sdp3430 arm armv7 sdp3430 ti omap3 devkit8000 arm armv7 devkit8000 timll omap3 mcx arm armv7 mcx htkw omap3 +twister arm armv7 twister technexion omap3 omap4_panda arm armv7 panda ti omap4 omap4_sdp4430 arm armv7 sdp4430 ti omap4 s5p_goni arm armv7 goni samsung s5pc1xx diff --git a/include/configs/twister.h b/include/configs/twister.h new file mode 100644 index 0000000..0eb3f64 --- /dev/null +++ b/include/configs/twister.h @@ -0,0 +1,103 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2009 TechNexion Ltd. + * + * Configuration for the Technexion twister board. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include "tam3517-common.h" + +#define MACH_TYPE_TAM3517 2818 +#define CONFIG_MACH_TYPE MACH_TYPE_TAM3517 + +#define CONFIG_TAM3517_SW3_SETTINGS +#define CONFIG_XR16L2751 + +#define CONFIG_BOOTDELAY 10 + +#define CONFIG_BOOTFILE "uImage" + +#define xstr(s) str(s) +#define str(s) #s +#define CONFIG_HOSTNAME twister + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addip_sta=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "addip_dyn=setenv bootargs ${bootargs} ip=dhcp\0" \ + "addip=if test -n ${ipdyn};then run addip_dyn;" \ + "else run addip_sta;fi\0" \ + "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ + "addtty=setenv bootargs ${bootargs}" \ + " console=ttyO0,${baudrate}\0" \ + "addmisc=setenv bootargs ${bootargs} ${misc}\0" \ + "loadaddr=82000000\0" \ + "kernel_addr_r=82000000\0" \ + "hostname=" xstr(CONFIG_HOSTNAME) "\0" \ + "bootfile=" xstr(CONFIG_HOSTNAME) "/uImage\0" \ + "ramdisk_file=" xstr(CONFIG_HOSTNAME) "/uRamdisk\0" \ + "flash_self=run ramargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr} ${ramdisk_addr}\0" \ + "flash_nfs=run nfsargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr}\0" \ + "net_nfs=tftp ${kernel_addr_r} ${bootfile}; " \ + "run nfsargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr_r}\0" \ + "net_self_load=tftp ${kernel_addr_r} ${bootfile};" \ + "tftp ${ramdisk_addr_r} ${ramdisk_file};\0" \ + "net_self=if run net_self_load;then " \ + "run ramargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr_r} ${ramdisk_addr_r};" \ + "else echo Images not loades;fi\0" \ + "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.bin\0" \ + "load=tftp ${loadaddr} ${u-boot}\0" \ + "uboot_addr=" xstr(CONFIG_SYS_MONITOR_BASE) "\0" \ + "update=nandecc sw;nand erase ${uboot_addr} 100000;" \ + "erase ${uboot_addr} +40000;" \ + "nand write ${loadaddr} ${uboot_addr} 80000\0" \ + "upd=if run load;then echo Updating u-boot;if run update;" \ + "then echo U-Boot updated;" \ + "else echo Error updating u-boot !;" \ + "echo Board without bootloader !!;" \ + "fi;" \ + "else echo U-Boot not downloaded..exiting;fi\0" \ + "bootcmd=run net_nfs\0" + +#define CONFIG_AUTO_COMPLETE + +/* + * Miscellaneous configurable options + */ +#define V_PROMPT "twister => " +#define CONFIG_SYS_PROMPT V_PROMPT + +#define CONFIG_SMC911X +#define CONFIG_SMC911X_16_BIT +#define CONFIG_SMC911X_BASE 0x2C000000 +#define CONFIG_SMC911X_NO_EEPROM + +#endif /* __CONFIG_H */
On 11/23/11 11:26, Stefano Babic wrote:
The twister board is a development board using the TAM3517 SOM.
Support for NAND, 2 Ethernet (EMAC and SMC911), USB (EHCI_OMAP).
- twister omap3 vision2 i.MX51
Postal address is subject to change, I'd prefer to not have it inside the source code files.
- $(call cmd_link_o_target, $(OBJS))
+clean:
- rm -f $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj).depend
clean and distclean should be removed.
- Copyright (C) 2011
- Stefano Babic, DENX Software Engineering, sbabic@denx.de.
- Copyright (C) 2009 TechNexion Ltd.
- project.
- MA 02111-1307 USA
- Routine: board_init
- Description: Early hardware init.
- gpmc_init(); /* in SRAM or SDRAM, finish GPMC */
- /* boot param addr */
- gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100);
- writel(0x00000000, &gpmc_cfg->cs[1].config1);
- writel(0x001e1e01, &gpmc_cfg->cs[1].config2);
- writel(0x00080300, &gpmc_cfg->cs[1].config3);
- writel(0x1c091c09, &gpmc_cfg->cs[1].config4);
- writel(0x04181f1f, &gpmc_cfg->cs[1].config5);
- writel(0x00000FCF, &gpmc_cfg->cs[1].config6);
- writel(0x00000f61, &gpmc_cfg->cs[1].config7);
- writel(0x00000000, &gpmc_cfg->cs[3].config1);
- writel(0x001e1e01, &gpmc_cfg->cs[3].config2);
- writel(0x00080300, &gpmc_cfg->cs[3].config3);
- writel(0x1c091c09, &gpmc_cfg->cs[3].config4);
- writel(0x04181f1f, &gpmc_cfg->cs[3].config5);
- writel(0x00000FCF, &gpmc_cfg->cs[3].config6);
- writel(0x00000f63, &gpmc_cfg->cs[3].config7);
- gpio_request(CONFIG_OMAP_EHCI_PHY1_RESET, "USB_PHY1_RESET");
- gpio_direction_output(CONFIG_OMAP_EHCI_PHY1_RESET, 1);
- Routine: misc_init_r
- Description: Init i2c, ethernet, etc... (done here so udelay works)
Comment is wrong.
- dieid_num_r();
- Routine: set_muxconf_regs
- Description: Setting up the configuration Mux registers specific to the
mode.
- MUX_TWISTER();
- Initializes on-chip ethernet controllers.
- to override, implement board_eth_init()
- davinci_emac_initialize();
- /* init cs for extern lan */
- writel(NET_GPMC_CONFIG1, &gpmc_cfg->cs[5].config1);
- writel(NET_GPMC_CONFIG2, &gpmc_cfg->cs[5].config2);
- writel(NET_GPMC_CONFIG3, &gpmc_cfg->cs[5].config3);
- writel(NET_GPMC_CONFIG4, &gpmc_cfg->cs[5].config4);
- writel(NET_GPMC_CONFIG5, &gpmc_cfg->cs[5].config5);
- writel(NET_GPMC_CONFIG6, &gpmc_cfg->cs[5].config6);
- writel(NET_GPMC_CONFIG7, &gpmc_cfg->cs[5].config7);
There is an enable_gpmc_cs_config() function in /arch/arm/cpu/armv7/omap3/mem.c can't it be used?
- if (smc911x_initialize(0, CONFIG_SMC911X_BASE) <= 0)
- !defined(CONFIG_SPL_BUILD)
- return omap_mmc_init(0);
- Copyright (C) 2010 TechNexion Ltd.
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
- DDR_DISCRETE,
- "TAM3517 TWISTER Board",
- "NAND",
- IEN - Input Enable
- IDIS - Input Disable
- PTD - Pull type Down
- PTU - Pull type Up
- DIS - Pull type selection is inactive
- EN - Pull type selection is active
- M0 - Mode 0
- The commented string gives the final mux configuration for that pin
- /* SDRC */\
- MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SDRC_DQS0N), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(SDRC_DQS1N), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(SDRC_DQS2N), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(SDRC_DQS3N), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(SDRC_CKE0), (M0)) \
- MUX_VAL(CP(SDRC_CKE1), (M0)) \
- MUX_VAL(CP(STRBEN_DLY0), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(STRBEN_DLY1), (IEN | PTD | EN | M0)) \
- /* GPMC */\
- MUX_VAL(CP(GPMC_A1), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_A2), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_A3), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_A4), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_A5), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_A6), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_A7), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_A8), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_A9), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_A10), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D0), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D1), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D2), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D3), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D4), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D5), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D6), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D7), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D8), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D9), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D10), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D11), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D12), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D13), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D14), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_D15), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_NCS1), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_NCS2), (IDIS | PTD | EN | M2)) /*PWM9*/\
- MUX_VAL(CP(GPMC_NCS3), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_NCS4), (IEN | PTD | EN | M4)) \
- MUX_VAL(CP(GPMC_NCS5), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_NCS6), (IDIS | PTD | EN | M3)) /*PWM11*/ \
- MUX_VAL(CP(GPMC_NCS7), (IDIS | PTD | EN | M4)) /*GPIO_58*/ \
- MUX_VAL(CP(GPMC_CLK), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_NBE1), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(GPMC_WAIT1), (IEN | PTU | EN | M4)) \
- MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M4)) /*GPIO_64*/\
- MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M4)) \
- /* DSS */\
- MUX_VAL(CP(DSS_PCLK), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_HSYNC), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_VSYNC), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_ACBIAS), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA0), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA1), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA2), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA3), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA4), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA5), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA6), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA7), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA8), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA9), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA10), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA11), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA12), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA13), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA14), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA15), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA16), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA17), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA18), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA19), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA20), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA21), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0)) \
- /* CAMERA */\
- MUX_VAL(CP(CAM_HS), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(CAM_VS), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(CAM_XCLKA), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_PCLK), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(CAM_FLD), (IDIS | PTD | DIS | M4)) /*GPIO_98*/\
- MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_XCLKB), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(CAM_WEN), (IEN | PTD | DIS | M4)) /*GPIO_167*/\
- MUX_VAL(CP(CAM_STROBE), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(CSI2_DX0), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CSI2_DY0), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CSI2_DX1), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CSI2_DY1), (IEN | PTD | DIS | M0)) \
- /* MMC */\
- MUX_VAL(CP(MMC1_CLK), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(MMC1_CMD), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M4)) \
/* CardDetect */\
- MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M4)) \
- MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M4)) \
- MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M4)) \
- MUX_VAL(CP(MMC2_CLK), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(MMC2_CMD), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(MMC2_DAT0), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(MMC2_DAT1), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(MMC2_DAT2), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(MMC2_DAT3), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(MMC2_DAT4), (IDIS | PTU | EN | M4)) \
- MUX_VAL(CP(MMC2_DAT5), (IDIS | PTU | EN | M4)) \
- MUX_VAL(CP(MMC2_DAT6), (IDIS | PTU | EN | M4)) \
- MUX_VAL(CP(MMC2_DAT7), (IDIS | PTU | EN | M4)) \
- /* McBSP */\
- MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(MCBSP1_CLKR), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(MCBSP1_FSR), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(MCBSP1_DX), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(MCBSP1_DR), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(MCBSP2_FSX), (IEN | PTD | EN | M4)) /*GPIO_116*/ \
- MUX_VAL(CP(MCBSP2_CLKX), (IEN | PTD | EN | M4)) \
- MUX_VAL(CP(MCBSP2_DR), (IEN | PTD | EN | M4)) \
- MUX_VAL(CP(MCBSP2_DX), (IEN | PTD | EN | M4)) \
- MUX_VAL(CP(MCBSP3_DX), (IEN | PTU | EN | M4)) \
- MUX_VAL(CP(MCBSP3_DR), (IEN | PTU | EN | M4)) \
- MUX_VAL(CP(MCBSP3_CLKX), (IEN | PTU | EN | M4)) \
- MUX_VAL(CP(MCBSP3_FSX), (IEN | PTU | EN | M4)) \
- MUX_VAL(CP(MCBSP4_CLKX), (IEN | PTD | DIS | M4)) /*GPIO_152*/\
- MUX_VAL(CP(MCBSP4_DR), (IDIS | PTD | DIS | M4)) /*GPIO_153*/\
- MUX_VAL(CP(MCBSP4_DX), (IDIS | PTD | DIS | M4)) /*GPIO_154*/\
- MUX_VAL(CP(MCBSP4_FSX), (IEN | PTD | DIS | M4)) /*GPIO_155*/\
- /* UART */\
- MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(UART1_RTS), (IEN | PTU | EN | M4)) \
- MUX_VAL(CP(UART1_CTS), (IEN | PTU | EN | M4)) \
- MUX_VAL(CP(UART1_RX), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(UART2_CTS), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M0)) \
- MUX_VAL(CP(UART2_RX), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(UART3_CTS_RCTX), (IDIS | PTD | DIS | M4)) /*GPIO_163*/ \
- MUX_VAL(CP(UART3_RTS_SD), (IEN | PTD | DIS | M4)) /*GPIO_164*/\
- MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) \
- /* I2C */\
- MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0)) \
- /* McSPI */\
- MUX_VAL(CP(MCSPI1_CLK), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(MCSPI1_CS0), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(MCSPI1_CS1), (IEN | PTD | EN | M4)) /*GPIO_175*/\
- MUX_VAL(CP(MCSPI1_CS2), (IEN | PTD | EN | M4)) /*GPIO_176*/\
- MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | EN | M4)) \
- MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | EN | M4)) \
- MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | EN | M4)) \
- /* CCDC */\
- MUX_VAL(CP(CCDC_PCLK), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(CCDC_FIELD), (IEN | PTD | DIS | M1)) \
- MUX_VAL(CP(CCDC_HD), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(CCDC_VD), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(CCDC_WEN), (IEN | PTD | DIS | M1)) \
- MUX_VAL(CP(CCDC_DATA0), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CCDC_DATA1), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CCDC_DATA2), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CCDC_DATA3), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CCDC_DATA4), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CCDC_DATA5), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CCDC_DATA6), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(CCDC_DATA7), (IEN | PTD | DIS | M0)) \
- /* RMII */\
- MUX_VAL(CP(RMII_MDIO_DATA), (IEN | M0)) \
- MUX_VAL(CP(RMII_MDIO_CLK), (M0)) \
- MUX_VAL(CP(RMII_RXD0) , (IEN | PTD | M0)) \
- MUX_VAL(CP(RMII_RXD1), (IEN | PTD | M0)) \
- MUX_VAL(CP(RMII_CRS_DV), (IEN | PTD | M0)) \
- MUX_VAL(CP(RMII_RXER), (PTD | M0)) \
- MUX_VAL(CP(RMII_TXD0), (PTD | M0)) \
- MUX_VAL(CP(RMII_TXD1), (PTD | M0)) \
- MUX_VAL(CP(RMII_TXEN), (PTD | M0)) \
- MUX_VAL(CP(RMII_50MHZ_CLK), (IEN | PTD | EN | M0)) \
- /* HECC */\
- MUX_VAL(CP(HECC1_TXD), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(HECC1_RXD), (IEN | PTU | EN | M0)) \
- /* HSUSB */\
- MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) \
- MUX_VAL(CP(HSUSB0_DIR), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(HSUSB0_NXT), (IEN | PTU | DIS | M0)) \
- MUX_VAL(CP(HSUSB0_DATA0), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(HSUSB0_DATA1), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(HSUSB0_DATA2), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(HSUSB0_DATA3), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(HSUSB0_DATA4), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(HSUSB0_DATA6), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(USB0_DRVBUS), (IEN | PTD | EN | M0)) \
- /* HDQ */\
- MUX_VAL(CP(HDQ_SIO), (IEN | PTD | EN | M4)) \
- /* Control and debug */\
- MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(SYS_NRESWARM), (IDIS | PTU | DIS | M4)) \
/* - GPIO30 */\
- MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /*GPIO_2*/\
- MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /*GPIO_3 */\
- MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /*GPIO_4*/\
- MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4)) /*GPIO_5*/\
- MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4)) /*GPIO_6*/\
- MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /*GPIO_7*/\
- MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4)) /*GPIO_8*/\
/* - VIO_1V8*/\
- MUX_VAL(CP(SYS_BOOT7), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(SYS_BOOT8), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) \
- /* JTAG */\
- MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(JTAG_EMU0), (IDIS | PTD | EN | M4)) /*GPIO_11*/ \
- MUX_VAL(CP(JTAG_EMU1), (IDIS | PTD | EN | M4)) /*GPIO_31*/ \
- /* ETK (ES2 onwards) */\
- MUX_VAL(CP(ETK_CLK_ES2), (IDIS | PTD | DIS | M3)) \
/* hsusb1_stp */ \
- MUX_VAL(CP(ETK_CTL_ES2), (IDIS | PTD | DIS | M3)) \
/* hsusb1_clk */\
- MUX_VAL(CP(ETK_D0_ES2), (IEN | PTU | EN | M3)) \
- MUX_VAL(CP(ETK_D1_ES2), (IEN | PTU | EN | M3)) \
- MUX_VAL(CP(ETK_D2_ES2), (IEN | PTU | EN | M3)) \
- MUX_VAL(CP(ETK_D3_ES2), (IEN | PTU | EN | M3)) \
- MUX_VAL(CP(ETK_D4_ES2), (IEN | PTU | EN | M3)) \
- MUX_VAL(CP(ETK_D5_ES2), (IEN | PTU | EN | M3)) \
- MUX_VAL(CP(ETK_D6_ES2), (IEN | PTU | EN | M3)) \
- MUX_VAL(CP(ETK_D7_ES2), (IEN | PTU | EN | M3)) \
- MUX_VAL(CP(ETK_D8_ES2), (IEN | PTD | EN | M3)) \
/* hsusb1_dir */\
- MUX_VAL(CP(ETK_D9_ES2), (IEN | PTD | EN | M3)) \
/* hsusb1_nxt */\
- MUX_VAL(CP(ETK_D10_ES2), (IEN | PTU | EN | M4)) \
- MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTD | DIS | M4)) \
- MUX_VAL(CP(ETK_D12_ES2), (IEN | PTD | EN | M4)) \
- MUX_VAL(CP(ETK_D13_ES2), (IEN | PTD | DIS | M4)) \
- MUX_VAL(CP(ETK_D14_ES2), (IEN | PTD | DIS | M4)) \
- MUX_VAL(CP(ETK_D15_ES2), (IEN | PTD | DIS | M4)) \
- /* Die to Die */\
- MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0)) \
- MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0)) \
- MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0)) \
- MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0)) \
You have spaces for indentation in multiple places above. Please, check.
- Configuration for the Technexion twister board.
- "netdev=eth0\0" \
- "nfsargs=setenv bootargs root=/dev/nfs rw " \
- "ramargs=setenv bootargs root=/dev/ram rw\0" \
- "addip_sta=setenv bootargs ${bootargs} " \
- "addip_dyn=setenv bootargs ${bootargs} ip=dhcp\0" \
- "addip=if test -n ${ipdyn};then run addip_dyn;" \
- "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \
- "addtty=setenv bootargs ${bootargs}" \
- "addmisc=setenv bootargs ${bootargs} ${misc}\0" \
- "loadaddr=82000000\0" \
- "kernel_addr_r=82000000\0" \
- "hostname=" xstr(CONFIG_HOSTNAME) "\0" \
- "bootfile=" xstr(CONFIG_HOSTNAME) "/uImage\0" \
- "ramdisk_file=" xstr(CONFIG_HOSTNAME) "/uRamdisk\0" \
- "flash_self=run ramargs addip addtty addmtd addmisc;" \
- "flash_nfs=run nfsargs addip addtty addmtd addmisc;" \
- "net_nfs=tftp ${kernel_addr_r} ${bootfile}; " \
- "net_self_load=tftp ${kernel_addr_r} ${bootfile};" \
- "net_self=if run net_self_load;then " \
- "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.bin\0" \
- "load=tftp ${loadaddr} ${u-boot}\0" \
- "uboot_addr=" xstr(CONFIG_SYS_MONITOR_BASE) "\0" \
- "update=nandecc sw;nand erase ${uboot_addr} 100000;" \
- "upd=if run load;then echo Updating u-boot;if run update;" \
"fi;" \
- "bootcmd=run net_nfs\0"
This one is present in your common file.
- Miscellaneous configurable options
Can this also be inlined?
Agree, I will remove it. I think the issue was already raised, I admit I have not yet completely the thread.
+clean:
- rm -f $(OBJS)
+distclean: clean
Right, I have copied from a worng file.
Ok
Comment is wrong.
Completely, it makes no sense - I will drop it
Yes, now that I know there is such as function - thanks !
Ok, I will check it.
I drop from here, I will let it in the common file.
Yes, of course.
Best regards, Stefano Babic
Sorry, missed the below in the first reply
Can there be an explanation of what's that and why is it needed? Also, it looks like you are writing the same values to both chip selects. Can enable_gpmc_cs_config() function be used here as well and the values documented (e.g. NET_GPMC_CONFIGx)?
It does not matter...
They are for a UART Controller (XR16L2751) and for the seconfd ethernet controller (SMC911X). I will explain this.
Why not ? The setup sets some relaxing time for both of them
Sure...the name NET_GPMC_CONFIG is quite misleading, the setup for a chip select has nothing to do with the NET. I see that on other boards this defines are always used to set the chipselect for an ethernet controller, but it is not a rule..
I don't mean you should not do this - it is perfectly fine. I mean, you should define those values and reuse the defines or consolidate it in some other way... Anyway, if you use the enable_gpmc_cs_config() function, it gets an array of those values as one of the parameters.
I've just used NET_... as an example. I did not mean you should use it. Now when I know, that's XR16L2751 and an Ethernet controller, I can propose a better name - XR16L2751_GPMC_CONFIG for the UART. For the second Ethernet controller, are these the same values as those in NET_GPMC_CONFIG? If yes, then why not use it?
Dear Stefano Babic,
What exactly is the meaning of the above comment?
We always want this, don't we?
What is this V_PROMPT thing needed for? Please scrap it.
Changes since V1: - CONFIG_OMAP_EHCI_PHY1_RESET_GPIO (Igor Grinberg) - Used inline instead of adding unuseful defines - rebased on latest posted patches for AM3517 - drop mixing of space an tabs (Igor Grinberg) - move default environment into the common file - sort lists (W. Denk) - do not remove CONFIG_CMD_IMI (W. Denk) - drop CONFIG_SYS_NAND_ADDR (W. Denk) - coding styles (several comments) - add redundant environment (W. Denk) - drop completely CFI setup (W. Denk)
include/configs/tam3517-common.h | 358 ++++++++++++++++++++++++++++++++++++++ 1 files changed, 358 insertions(+), 0 deletions(-) create mode 100644 include/configs/tam3517-common.h
diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h new file mode 100644 index 0000000..f972592 --- /dev/null +++ b/include/configs/tam3517-common.h @@ -0,0 +1,358 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2009 TechNexion Ltd. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#ifndef __TAM3517_H +#define __TAM3517_H + +/* + * High Level Configuration Options + */ +#define CONFIG_OMAP /* in a TI OMAP core */ +#define CONFIG_OMAP34XX /* which is a 34XX */ + +#define CONFIG_SYS_TEXT_BASE 0x80008000 + +#define CONFIG_SYS_CACHELINE_SIZE 64 + +#define CONFIG_EMIF4 /* The chip has EMIF4 controller */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* + * Display CPU and Board information + */ +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* + * Size of malloc() pool + */ +#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB sector */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10) + \ + 2 * 1024 * 1024) +/* + * DDR related + */ +#define CONFIG_OMAP3_MICRON_DDR /* Micron DDR */ +#define CONFIG_SYS_CS0_SIZE (256 * 1024 * 1024) + +/* + * Hardware drivers + */ + +/* + * NS16550 Configuration + */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +/* + * select serial console configuration + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_COM1 OMAP34XX_UART1 +#define CONFIG_SERIAL1 /* UART1 */ + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ + 115200} +#define CONFIG_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_GENERIC_MMC +#define CONFIG_DOS_PARTITION + +/* EHCI */ +#define CONFIG_OMAP3_GPIO_5 +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_OMAP +#define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 25 +#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 +#define CONFIG_USB_STORAGE + +/* #define CONFIG_EHCI_DCACHE */ + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MII +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_PING +#define CONFIG_CMD_USB + +#undef CONFIG_CMD_FLASH /* only NAND on the SOM */ +#undef CONFIG_CMD_IMLS + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C +#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C + + +/* + * Board NAND Info. + */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ + /* to access */ + /* nand at CS0 */ + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ + /* NAND devices */ +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ + +#define CONFIG_AUTO_COMPLETE + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 32 /* max number of command */ + /* args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ + 0x01F00000) /* 31MB */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load */ + /* address */ + +/* + * AM3517 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* + * Stack sizes + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 << 10) /* regular stack 128 KiB */ + +/* + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE (32 << 20) /* at least 32 MiB */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* + * FLASH and environment organization + */ + +/* **** PISMO SUPPORT *** */ + +/* Configure the PISMO */ +#define PISMO1_NAND_SIZE GPMC_SIZE_128M + +#define CONFIG_NAND_OMAP_GPMC +#define GPMC_NAND_ECC_LP_x16_LAYOUT +#define CONFIG_ENV_IS_IN_NAND +#define SMNAND_ENV_OFFSET 0x180000 /* environment starts here */ + +/* Redundant Environment */ +#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET +#define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ + 2 * CONFIG_SYS_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 +#define CONFIG_SYS_INIT_RAM_SIZE 0x800 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) + +/* + * ethernet support, EMAC + * + */ +#define CONFIG_DRIVER_TI_EMAC +#define CONFIG_DRIVER_TI_EMAC_USE_RMII +#define CONFIG_MII +#define CONFIG_EMAC_MDIO_PHY_NUM 0 +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_CONSOLE +#define CONFIG_SPL_NAND_SIMPLE +#define CONFIG_SPL_NAND_SOFTECC +#define CONFIG_SPL_NAND_WORKSPACE 0x8f07f000 /* below BSS */ + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_POWER_SUPPORT +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" + +#define CONFIG_SPL_TEXT_BASE 0x40200000 /*CONFIG_SYS_SRAM_START*/ +#define CONFIG_SPL_MAX_SIZE (45 << 10) /* 45 K */ +#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SYS_SPL_MALLOC_START 0x8f000000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 +#define CONFIG_SPL_BSS_START_ADDR 0x8f080000 /* end of RAM */ +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 + +/* NAND boot config */ +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 +#define CONFIG_SYS_NAND_ECCPOS {40, 41, 42, 43, 44, 45, 46, 47,\ + 48, 49, 50, 51, 52, 53, 54, 55,\ + 56, 57, 58, 59, 60, 61, 62, 63} +#define CONFIG_SYS_NAND_ECCSIZE 256 +#define CONFIG_SYS_NAND_ECCBYTES 3 + +#define CONFIG_SYS_NAND_ECCSTEPS (CONFIG_SYS_NAND_PAGE_SIZE / \ + CONFIG_SYS_NAND_ECCSIZE) +#define CONFIG_SYS_NAND_ECCTOTAL (CONFIG_SYS_NAND_ECCBYTES * \ + CONFIG_SYS_NAND_ECCSTEPS) + +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 + +#define CONFIG_OF_LIBFDT +#define CONFIG_FIT +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_RBTREE +#define CONFIG_LZO +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_CMD_MTDPARTS + +/* Setup MTD for NAND on the SOM */ +#define MTDIDS_DEFAULT "nand0=omap2-nand.0" +#define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:512k(MLO)," \ + "512k(u-boot),128k(env1)," \ + "128k(env2),6m(kernel),-(rootfs)" + +#define CONFIG_TAM3517_SETTINGS \ + "netdev=eth0\0" \ + "nandargs=setenv bootargs root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addip_sta=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "addip_dyn=setenv bootargs ${bootargs} ip=dhcp\0" \ + "addip=if test -n ${ipdyn};then run addip_dyn;" \ + "else run addip_sta;fi\0" \ + "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ + "addtty=setenv bootargs ${bootargs}" \ + " console=ttyO0,${baudrate}\0" \ + "addmisc=setenv bootargs ${bootargs} ${misc}\0" \ + "loadaddr=82000000\0" \ + "kernel_addr_r=82000000\0" \ + "hostname=" xstr(CONFIG_HOSTNAME) "\0" \ + "bootfile=" xstr(CONFIG_HOSTNAME) "/uImage\0" \ + "flash_self=run ramargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr} ${ramdisk_addr}\0" \ + "flash_nfs=run nfsargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr}\0" \ + "nandboot=run nandargs addip addtty addmtd addmisc;" \ + "nand read ${kernel_addr_r} kernel\0" \ + "bootm ${kernel_addr_r}\0" \ + "net_nfs=tftp ${kernel_addr_r} ${bootfile}; " \ + "run nfsargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr_r}\0" \ + "net_self=if run net_self_load;then " \ + "run ramargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr_r} ${ramdisk_addr_r};" \ + "else echo Images not loades;fi\0" \ + "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.img\0" \ + "load=tftp ${loadaddr} ${u-boot}\0" \ + "loadmlo=tftp ${loadaddr} ${mlo}\0" \ + "mlo=" xstr(CONFIG_HOSTNAME) "/MLO\0" \ + "uboot_addr=0x80000\0" \ + "update=nandecc sw;nand erase ${uboot_addr} 100000;" \ + "nand write ${loadaddr} ${uboot_addr} 80000\0" \ + "updatemlo=nandecc hw;nand erase 0 20000;" \ + "nand write ${loadaddr} 0 20000\0" \ + "upd=if run load;then echo Updating u-boot;if run update;" \ + "then echo U-Boot updated;" \ + "else echo Error updating u-boot !;" \ + "echo Board without bootloader !!;" \ + "fi;" \ + "else echo U-Boot not downloaded..exiting;fi\0" \ + +#endif /* __TAM3517_H */
Signed-off-by: Stefano Babic sbabic@denx.de CC: Tapani Utrianen tapani@technexion.com CC: Tom Rini tom.rini@gmail.com CC: Sandeep Paulraj s-paulraj@ti.com ---
Changes since V1: - drop unuseful comments (W. Denk) - drop postal address (globally) from headers - enable_gpmc_cs_config() to set chip select (Igor Grinberg) - drop unneeded #ifdef (W. Denk)
MAINTAINERS | 1 + board/technexion/twister/Makefile | 38 ++++ board/technexion/twister/twister.c | 116 ++++++++++ board/technexion/twister/twister.h | 411 ++++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/twister.h | 56 +++++ 6 files changed, 623 insertions(+), 0 deletions(-) create mode 100644 board/technexion/twister/Makefile create mode 100644 board/technexion/twister/twister.c create mode 100644 board/technexion/twister/twister.h create mode 100644 include/configs/twister.h
diff --git a/MAINTAINERS b/MAINTAINERS index fdc1a53..4e3246d 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -562,6 +562,7 @@ Stefano Babic sbabic@denx.de mx51evk i.MX51 polaris xscale/pxa trizepsiv xscale/pxa + twister omap3 vision2 i.MX51
Jason Liu r64343@freescale.com diff --git a/board/technexion/twister/Makefile b/board/technexion/twister/Makefile new file mode 100644 index 0000000..38b7b14 --- /dev/null +++ b/board/technexion/twister/Makefile @@ -0,0 +1,38 @@ +# +# Copyright (C) 2011 Ilya Yanok, Emcraft Systems +# +# Based on ti/evm/Makefile +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := $(BOARD).o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend diff --git a/board/technexion/twister/twister.c b/board/technexion/twister/twister.c new file mode 100644 index 0000000..950e76c --- /dev/null +++ b/board/technexion/twister/twister.c @@ -0,0 +1,116 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2009 TechNexion Ltd. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/mem.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/omap_gpio.h> +#include <asm/arch/mmc_host_def.h> +#include <i2c.h> +#include <asm/gpio.h> +#include "twister.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* Timing definitions for Ethernet Controller */ +static const u32 gpmc_smc911[] = { + NET_GPMC_CONFIG1, + NET_GPMC_CONFIG2, + NET_GPMC_CONFIG3, + NET_GPMC_CONFIG4, + NET_GPMC_CONFIG5, + NET_GPMC_CONFIG6, +}; + +static const u32 gpmc_XR16L2751[] = { + XR16L2751_GPMC_CONFIG1, + XR16L2751_GPMC_CONFIG2, + XR16L2751_GPMC_CONFIG3, + XR16L2751_GPMC_CONFIG4, + XR16L2751_GPMC_CONFIG5, + XR16L2751_GPMC_CONFIG6, +}; + +int board_init(void) +{ + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + /* Chip select 1 and 3 are used for XR16L2751 UART controller */ + enable_gpmc_cs_config(gpmc_XR16L2751, &gpmc_cfg->cs[1], + XR16L2751_UART1_BASE, GPMC_SIZE_16M); + + enable_gpmc_cs_config(gpmc_XR16L2751, &gpmc_cfg->cs[3], + XR16L2751_UART2_BASE, GPMC_SIZE_16M); + + gpio_request(CONFIG_OMAP_EHCI_PHY1_RESET_GPIO, "USB_PHY1_RESET"); + gpio_direction_output(CONFIG_OMAP_EHCI_PHY1_RESET_GPIO, 1); + + return 0; +} + +int misc_init_r(void) +{ + dieid_num_r(); + + return 0; +} + +/* + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers specific to the + * hardware. Many pins need to be moved from protect to primary + * mode. + */ +void set_muxconf_regs(void) +{ + MUX_TWISTER(); +} + +int board_eth_init(bd_t *bis) +{ + davinci_emac_initialize(); + + /* init cs for extern lan */ + enable_gpmc_cs_config(gpmc_smc911, &gpmc_cfg->cs[5], + CONFIG_SMC911X_BASE, GPMC_SIZE_16M); + if (smc911x_initialize(0, CONFIG_SMC911X_BASE) <= 0) + printf("\nError initializing SMC911x controlleri\n"); + + return 0; +} + +#if defined(CONFIG_GENERIC_MMC) && defined(CONFIG_OMAP_HSMMC) && \ + !defined(CONFIG_SPL_BUILD) +int board_mmc_init(bd_t *bis) +{ + return omap_mmc_init(0); +} +#endif diff --git a/board/technexion/twister/twister.h b/board/technexion/twister/twister.h new file mode 100644 index 0000000..a2051c0 --- /dev/null +++ b/board/technexion/twister/twister.h @@ -0,0 +1,411 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2010 TechNexion Ltd. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#ifndef _TAM3517_H_ +#define _TAM3517_H_ + +const omap3_sysinfo sysinfo = { + DDR_DISCRETE, + "TAM3517 TWISTER Board", + "NAND", +}; + +#define XR16L2751_GPMC_CONFIG1 0x00000000 +#define XR16L2751_GPMC_CONFIG2 0x001e1e01 +#define XR16L2751_GPMC_CONFIG3 0x00080300 +#define XR16L2751_GPMC_CONFIG4 0x1c091c09 +#define XR16L2751_GPMC_CONFIG5 0x04181f1f +#define XR16L2751_GPMC_CONFIG6 0x00000FCF + +#define XR16L2751_UART1_BASE 0x21000000 +#define XR16L2751_UART2_BASE 0x23000000 + + +/* + * IEN - Input Enable + * IDIS - Input Disable + * PTD - Pull type Down + * PTU - Pull type Up + * DIS - Pull type selection is inactive + * EN - Pull type selection is active + * M0 - Mode 0 + * The commented string gives the final mux configuration for that pin + */ +#define MUX_TWISTER() \ + /* SDRC */\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS0N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_DQS1N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_DQS2N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_DQS3N), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SDRC_CKE0), (M0)) \ + MUX_VAL(CP(SDRC_CKE1), (M0)) \ + MUX_VAL(CP(STRBEN_DLY0), (IEN | PTD | EN | M0)) \ + /*sdrc_strben_dly0*/\ + MUX_VAL(CP(STRBEN_DLY1), (IEN | PTD | EN | M0)) \ + /*sdrc_strben_dly1*/\ + /* GPMC */\ + MUX_VAL(CP(GPMC_A1), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A2), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A3), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A4), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A5), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A6), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A7), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A8), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A9), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A10), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D0), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D2), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D3), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D4), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D5), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D6), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D7), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D8), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D9), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D10), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D11), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D12), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D13), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D14), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D15), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS2), (IDIS | PTD | EN | M2)) /*PWM9*/\ + MUX_VAL(CP(GPMC_NCS3), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS4), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(GPMC_NCS5), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS6), (IDIS | PTD | EN | M3)) /*PWM11*/ \ + MUX_VAL(CP(GPMC_NCS7), (IDIS | PTD | EN | M4)) /*GPIO_58*/ \ + MUX_VAL(CP(GPMC_CLK), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NBE1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_WAIT1), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M4)) /*GPIO_64*/\ + MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M4)) \ + /* DSS */\ + MUX_VAL(CP(DSS_PCLK), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_HSYNC), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_VSYNC), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_ACBIAS), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA0), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA1), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA2), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA3), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA4), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA5), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA6), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA7), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA8), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA9), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA10), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA11), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA12), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA13), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA14), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA15), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA16), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA17), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA18), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA19), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA20), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA21), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0)) \ + /* CAMERA */\ + MUX_VAL(CP(CAM_HS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_VS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_XCLKA), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_PCLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_FLD), (IDIS | PTD | DIS | M4)) /*GPIO_98*/\ + MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_XCLKB), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_WEN), (IEN | PTD | DIS | M4)) /*GPIO_167*/\ + MUX_VAL(CP(CAM_STROBE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DX0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DY0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DX1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DY1), (IEN | PTD | DIS | M0)) \ + /* MMC */\ + MUX_VAL(CP(MMC1_CLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_CMD), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M4)) \ + /* CardDetect */\ + MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M4)) \ + \ + MUX_VAL(CP(MMC2_CLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC2_CMD), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT0), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT1), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT2), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT3), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MMC2_DAT4), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT5), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT6), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT7), (IDIS | PTU | EN | M4)) \ + /* McBSP */\ + MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_CLKR), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_FSR), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(MCBSP1_DX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_DR), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTD | DIS | M0)) \ + \ + MUX_VAL(CP(MCBSP2_FSX), (IEN | PTD | EN | M4)) /*GPIO_116*/ \ + MUX_VAL(CP(MCBSP2_CLKX), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(MCBSP2_DR), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(MCBSP2_DX), (IEN | PTD | EN | M4)) \ + \ + MUX_VAL(CP(MCBSP3_DX), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MCBSP3_DR), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MCBSP3_CLKX), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MCBSP3_FSX), (IEN | PTU | EN | M4)) \ + \ + MUX_VAL(CP(MCBSP4_CLKX), (IEN | PTD | DIS | M4)) /*GPIO_152*/\ + MUX_VAL(CP(MCBSP4_DR), (IDIS | PTD | DIS | M4)) /*GPIO_153*/\ + MUX_VAL(CP(MCBSP4_DX), (IDIS | PTD | DIS | M4)) /*GPIO_154*/\ + MUX_VAL(CP(MCBSP4_FSX), (IEN | PTD | DIS | M4)) /*GPIO_155*/\ + /* UART */\ + MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART1_RTS), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(UART1_CTS), (IEN | PTU | EN | M4)) \ + \ + MUX_VAL(CP(UART1_RX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(UART2_CTS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART2_RX), (IEN | PTD | DIS | M0)) \ + \ + MUX_VAL(CP(UART3_CTS_RCTX), (IDIS | PTD | DIS | M4)) /*GPIO_163*/ \ + MUX_VAL(CP(UART3_RTS_SD), (IEN | PTD | DIS | M4)) /*GPIO_164*/\ + MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) \ + /* I2C */\ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0)) \ + /* McSPI */\ + MUX_VAL(CP(MCSPI1_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI1_CS0), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(MCSPI1_CS1), (IEN | PTD | EN | M4)) /*GPIO_175*/\ + MUX_VAL(CP(MCSPI1_CS2), (IEN | PTD | EN | M4)) /*GPIO_176*/\ + MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | EN | M4)) \ + \ + MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | EN | M4)) \ + /* CCDC */\ + MUX_VAL(CP(CCDC_PCLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CCDC_FIELD), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(CCDC_HD), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CCDC_VD), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CCDC_WEN), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(CCDC_DATA0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CCDC_DATA7), (IEN | PTD | DIS | M0)) \ + /* RMII */\ + MUX_VAL(CP(RMII_MDIO_DATA), (IEN | M0)) \ + MUX_VAL(CP(RMII_MDIO_CLK), (M0)) \ + MUX_VAL(CP(RMII_RXD0) , (IEN | PTD | M0)) \ + MUX_VAL(CP(RMII_RXD1), (IEN | PTD | M0)) \ + MUX_VAL(CP(RMII_CRS_DV), (IEN | PTD | M0)) \ + MUX_VAL(CP(RMII_RXER), (PTD | M0)) \ + MUX_VAL(CP(RMII_TXD0), (PTD | M0)) \ + MUX_VAL(CP(RMII_TXD1), (PTD | M0)) \ + MUX_VAL(CP(RMII_TXEN), (PTD | M0)) \ + MUX_VAL(CP(RMII_50MHZ_CLK), (IEN | PTD | EN | M0)) \ + /* HECC */\ + MUX_VAL(CP(HECC1_TXD), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(HECC1_RXD), (IEN | PTU | EN | M0)) \ + /* HSUSB */\ + MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(HSUSB0_DIR), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_NXT), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(USB0_DRVBUS), (IEN | PTD | EN | M0)) \ + /* HDQ */\ + MUX_VAL(CP(HDQ_SIO), (IEN | PTD | EN | M4)) \ + /* Control and debug */\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(SYS_NRESWARM), (IDIS | PTU | DIS | M4)) \ + /* - GPIO30 */\ + MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /*GPIO_2*/\ + MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /*GPIO_3 */\ + MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /*GPIO_4*/\ + MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4)) /*GPIO_5*/\ + MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4)) /*GPIO_6*/\ + MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /*GPIO_7*/\ + MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4)) /*GPIO_8*/\ + /* - VIO_1V8*/\ + MUX_VAL(CP(SYS_BOOT7), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(SYS_BOOT8), (IEN | PTD | EN | M0)) \ + \ + MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) \ + /* JTAG */\ + MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_EMU0), (IDIS | PTD | EN | M4)) /*GPIO_11*/ \ + MUX_VAL(CP(JTAG_EMU1), (IDIS | PTD | EN | M4)) /*GPIO_31*/ \ + /* ETK (ES2 onwards) */\ + MUX_VAL(CP(ETK_CLK_ES2), (IDIS | PTD | DIS | M3)) \ + /* hsusb1_stp */ \ + MUX_VAL(CP(ETK_CTL_ES2), (IDIS | PTD | DIS | M3)) \ + /* hsusb1_clk */\ + MUX_VAL(CP(ETK_D0_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D1_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D2_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D3_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D4_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D5_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D6_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D7_ES2), (IEN | PTU | EN | M3)) \ + MUX_VAL(CP(ETK_D8_ES2), (IEN | PTD | EN | M3)) \ + /* hsusb1_dir */\ + MUX_VAL(CP(ETK_D9_ES2), (IEN | PTD | EN | M3)) \ + /* hsusb1_nxt */\ + MUX_VAL(CP(ETK_D10_ES2), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTD | DIS | M4)) \ + MUX_VAL(CP(ETK_D12_ES2), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(ETK_D13_ES2), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(ETK_D14_ES2), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(ETK_D15_ES2), (IEN | PTD | DIS | M4)) \ + /* Die to Die */\ + MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0)) \ + +#endif diff --git a/boards.cfg b/boards.cfg index 11ef60b..7826e29 100644 --- a/boards.cfg +++ b/boards.cfg @@ -195,6 +195,7 @@ omap3_evm_quick_nand arm armv7 evm ti omap3_sdp3430 arm armv7 sdp3430 ti omap3 devkit8000 arm armv7 devkit8000 timll omap3 mcx arm armv7 mcx htkw omap3 +twister arm armv7 twister technexion omap3 omap4_panda arm armv7 panda ti omap4 omap4_sdp4430 arm armv7 sdp4430 ti omap4 omap5_evm arm armv7 omap5_evm ti omap5 diff --git a/include/configs/twister.h b/include/configs/twister.h new file mode 100644 index 0000000..f4af2a3 --- /dev/null +++ b/include/configs/twister.h @@ -0,0 +1,56 @@ +/* + * Copyright (C) 2011 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * Copyright (C) 2009 TechNexion Ltd. + * + * Configuration for the Technexion twister board. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include "tam3517-common.h" + +#define MACH_TYPE_TAM3517 2818 +#define CONFIG_MACH_TYPE MACH_TYPE_TAM3517 + +#define CONFIG_TAM3517_SW3_SETTINGS +#define CONFIG_XR16L2751 + +#define CONFIG_BOOTDELAY 10 + +#define CONFIG_BOOTFILE "uImage" + +#define xstr(s) str(s) +#define str(s) #s +#define CONFIG_HOSTNAME twister + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_PROMPT "twister => " + +#define CONFIG_SMC911X +#define CONFIG_SMC911X_16_BIT +#define CONFIG_SMC911X_BASE 0x2C000000 +#define CONFIG_SMC911X_NO_EEPROM + +#define CONFIG_EXTRA_ENV_SETTINGS CONFIG_TAM3517_SETTINGS \ + "bootcmd=run nandboot\0" + +#endif /* __CONFIG_H */
Dear Stefano Babic,
In message 1322149442-16555-2-git-send-email-sbabic@denx.de you wrote:
The twister board is a development board using the TAM3517 SOM.
Support for NAND, 2 Ethernet (EMAC and SMC911), USB (EHCI_OMAP).
Nitpick:
It appears neither of these is actuallyused any more in this header file?
[snip]
- !defined(CONFIG_SPL_BUILD)
Another little change, OMAP_HSMMC requires GENERIC_MMC so no need to test both.
With this, and Wolfgang's change made in a v3, are you and Tapani otherwise in agreement for how this looks going in?
[snip]
Thanks, I drop it.
Yes, I think so. Tapani, I also changed in V2 the default way to boot from network to NAND for the twister, and further boards can always overwrite this behavior if desired. Do you have any open points ?
In my view the architecture and implementation is ok.
The only dark cloud is this u-boot cannot act as a direct replacement for the one we have, because of failures to mount USBv3 devices on the Twister board using our (ancient, but still the latest released) 2.6.32 kernel. As discussed, there can be any number of reasons to that, not necessarily related to u-boot. However, for this I cannot give an "ack" or succesfully "tested by". :-(
With some luck, I get some time to play with Twister tomorrow -- I can see if I can get this u-boot to work there.
//Tapani
Dear Tapani Utriainen,
I'm not sure how you define "released".
The latest stable released Linux kernel is v3.1.4; compared to that, 2.6.32 is more than 9 kernel releases ago, or more than 2.5 years in time. In terms of Linux kernel development, this is stone age.
Dear Stefano Babic,
In message 1322149442-16555-1-git-send-email-sbabic@denx.de you wrote:
The TAM3517 is a SOM module that can be used on custom boards. The patch add a common configuration file that is included by the boards using this module.
Here you rely on xstr() being defined in some higher level header file. That's not a good idea. Please mode the definitions into this common header, and drop it in the other file(s).
Am 24/11/2011 21:43, schrieb Wolfgang Denk:
This was not thought, I miss to move it, thanks for pointing out
..it's a very bad idea....
I do it
participants (7)
Albert ARIBAUD
Igor Grinberg
Stefano Babic
stefano babic
Tapani Utriainen
