[U-Boot] [RFC PATCH] spl: Flush spl image after loading
Flush spl image after loading into memory in case d-cache is enabled.
Signed-off-by: York Sun york.sun@nxp.com --- Not sure if anyone noticed that SPL loads image but it doesn't flush the cache. As far as MMU/cache stays the same, we don't notice it. Shall we flush it?
This patch is only tested on limited platforms.
common/spl/spl.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index f7df834..a3b9d9f 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -320,8 +320,11 @@ static int boot_from_devices(struct spl_image_info *spl_image, else puts("SPL: Unsupported Boot Device!\n"); #endif - if (loader && !spl_load_image(spl_image, loader)) + if (loader && !spl_load_image(spl_image, loader)) { + flush_dcache_range(spl_image->load_addr, + spl_image->load_addr + spl_image->size); return 0; + } }
return -ENODEV;
York Sun
