[PATCH 1/4] imx: imx8mp: detect i.MX8MP UltraLite when get cpu rev
Detect i.MX8MP UltraLite in get_cpu_variant_type
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/soc.c | 18 ++++++++++++++++-- 1 file changed, 16 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index da106769b1..e2d21bf6b8 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -407,13 +407,27 @@ static u32 get_cpu_variant_type(u32 type)
/* npu disabled*/ if ((value & 0x8) == 0x8) - flag |= (1 << 1); + flag |= BIT(1);
/* isp disabled */ if ((value & 0x3) == 0x3) - flag |= (1 << 2); + flag |= BIT(2); + + /* gpu disabled */ + if ((value & 0xc0) == 0xc0) + flag |= BIT(3); + + /* lvds disabled */ + if ((value & 0x180000) == 0x180000) + flag |= BIT(4); + + /* mipi dsi disabled */ + if ((value & 0x60000) == 0x60000) + flag |= BIT(5);
switch (flag) { + case 0x3f: + return MXC_CPU_IMX8MPUL; case 7: return MXC_CPU_IMX8MPL; case 2:
Beside the fused modules on iMX8MP Lite, this part has also fused GPU3D/2D, LVDS and MIPI DSI. So we have to disable them for kernel and also disable MIPI DSI in u-boot DTS for splash screen at runtime.
Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/soc.c | 147 ++++++++++++++++++++++++++++++++-- 1 file changed, 142 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index e2d21bf6b8..91ff7eca59 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -905,6 +905,90 @@ static int low_drive_gpu_freq(void *blob) } #endif
+static bool check_remote_endpoint(void *blob, const char *ep1, const char *ep2) +{ + int lookup_node; + int nodeoff; + + nodeoff = fdt_path_offset(blob, ep1); + if (nodeoff) { + lookup_node = fdtdec_lookup_phandle(blob, nodeoff, "remote-endpoint"); + nodeoff = fdt_path_offset(blob, ep2); + + if (nodeoff > 0 && nodeoff == lookup_node) + return true; + } + + return false; +} + +int disable_dsi_lcdif_nodes(void *blob) +{ + int ret; + + static const char * const dsi_path_8mp[] = { + "/soc@0/bus@32c00000/mipi_dsi@32e60000" + }; + + static const char * const lcdif_path_8mp[] = { + "/soc@0/bus@32c00000/lcd-controller@32e80000" + }; + + static const char * const lcdif_ep_path_8mp[] = { + "/soc@0/bus@32c00000/lcd-controller@32e80000/port@0/endpoint" + }; + static const char * const dsi_ep_path_8mp[] = { + "/soc@0/bus@32c00000/mipi_dsi@32e60000/port@0/endpoint" + }; + + ret = disable_fdt_nodes(blob, dsi_path_8mp, ARRAY_SIZE(dsi_path_8mp)); + if (ret) + return ret; + + if (check_remote_endpoint(blob, dsi_ep_path_8mp[0], lcdif_ep_path_8mp[0])) { + /* Disable lcdif node */ + return disable_fdt_nodes(blob, lcdif_path_8mp, ARRAY_SIZE(lcdif_path_8mp)); + } + + return 0; +} + +int disable_lvds_lcdif_nodes(void *blob) +{ + int ret, i; + + static const char * const ldb_path_8mp[] = { + "/soc@0/bus@32c00000/ldb@32ec005c", + "/soc@0/bus@32c00000/phy@32ec0128" + }; + + static const char * const lcdif_path_8mp[] = { + "/soc@0/bus@32c00000/lcd-controller@32e90000" + }; + + static const char * const lcdif_ep_path_8mp[] = { + "/soc@0/bus@32c00000/lcd-controller@32e90000/port@0/endpoint@0", + "/soc@0/bus@32c00000/lcd-controller@32e90000/port@0/endpoint@1" + }; + static const char * const ldb_ep_path_8mp[] = { + "/soc@0/bus@32c00000/ldb@32ec005c/lvds-channel@0/port@0/endpoint", + "/soc@0/bus@32c00000/ldb@32ec005c/lvds-channel@1/port@0/endpoint" + }; + + ret = disable_fdt_nodes(blob, ldb_path_8mp, ARRAY_SIZE(ldb_path_8mp)); + if (ret) + return ret; + + for (i = 0; i < ARRAY_SIZE(ldb_ep_path_8mp); i++) { + if (check_remote_endpoint(blob, ldb_ep_path_8mp[i], lcdif_ep_path_8mp[i])) { + /* Disable lcdif node */ + return disable_fdt_nodes(blob, lcdif_path_8mp, ARRAY_SIZE(lcdif_path_8mp)); + } + } + + return 0; +} + int disable_gpu_nodes(void *blob) { static const char * const nodes_path_8mn[] = { @@ -912,7 +996,15 @@ int disable_gpu_nodes(void *blob) "/soc@/gpu@38000000" };
- return disable_fdt_nodes(blob, nodes_path_8mn, ARRAY_SIZE(nodes_path_8mn)); + static const char * const nodes_path_8mp[] = { + "/gpu3d@38000000", + "/gpu2d@38008000" + }; + + if (is_imx8mp()) + return disable_fdt_nodes(blob, nodes_path_8mp, ARRAY_SIZE(nodes_path_8mp)); + else + return disable_fdt_nodes(blob, nodes_path_8mn, ARRAY_SIZE(nodes_path_8mn)); }
int disable_npu_nodes(void *blob) @@ -1168,16 +1260,27 @@ usb_modify_speed: disable_cpu_nodes(blob, 3);
#elif defined(CONFIG_IMX8MP) - if (is_imx8mpl()) + if (is_imx8mpul()) { + /* Disable GPU */ + disable_gpu_nodes(blob); + + /* Disable DSI */ + disable_dsi_lcdif_nodes(blob); + + /* Disable LVDS */ + disable_lvds_lcdif_nodes(blob); + } + + if (is_imx8mpul() || is_imx8mpl()) disable_vpu_nodes(blob);
- if (is_imx8mpl() || is_imx8mp6()) + if (is_imx8mpul() || is_imx8mpl() || is_imx8mp6()) disable_npu_nodes(blob);
- if (is_imx8mpl()) + if (is_imx8mpul() || is_imx8mpl()) disable_isp_nodes(blob);
- if (is_imx8mpl() || is_imx8mp6()) + if (is_imx8mpul() || is_imx8mpl() || is_imx8mp6()) disable_dsp_nodes(blob);
if (is_imx8mpd()) @@ -1188,6 +1291,40 @@ usb_modify_speed: } #endif
+#ifdef CONFIG_OF_BOARD_FIXUP +#ifndef CONFIG_SPL_BUILD +int board_fix_fdt(void *fdt) +{ + if (is_imx8mpul()) { + int i = 0; + int nodeoff, ret; + const char *status = "disabled"; + static const char * const dsi_nodes[] = { + "/soc@0/bus@32c00000/mipi_dsi@32e60000", + "/soc@0/bus@32c00000/lcd-controller@32e80000", + "/dsi-host" + }; + + for (i = 0; i < ARRAY_SIZE(dsi_nodes); i++) { + nodeoff = fdt_path_offset(fdt, dsi_nodes[i]); + if (nodeoff > 0) { +set_status: + ret = fdt_setprop(fdt, nodeoff, "status", status, + strlen(status) + 1); + if (ret == -FDT_ERR_NOSPACE) { + ret = fdt_increase_size(fdt, 512); + if (!ret) + goto set_status; + } + } + } + } + + return 0; +} +#endif +#endif + #if !CONFIG_IS_ENABLED(SYSRESET) void reset_cpu(void) {
Hello Peng,
Am Montag, dem 14.02.2022 um 20:55 +0800 schrieb Peng Fan (OSS):
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach- imx/imx8m/soc.c index e2d21bf6b8..91ff7eca59 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -905,6 +905,90 @@ static int low_drive_gpu_freq(void *blob) } #endif
I stumbled over this already in the NXP U-Boot. We implemented there on top our own board_fix_fdt() callback on board level. So this caused a conflict. This will be a issue for upstream also when a imx8m* board tries to use it. Is there not any other way to solve this than implementing board callbacks on soc level?
Regards, Teresa
- if (is_imx8mpul()) {
int i = 0;
int nodeoff, ret;
"/dsi-host"
if (nodeoff > 0) {
+set_status:
"status", status,
512);
if (!ret)
goto set_status;
+} +#endif +#endif
The extcon is an decrepted property and not used by upstream Linux and NXP 5.10 kernel, so we remove it before kicking linux in case it is in dts. Otherwise distro kernel will not able to have usb function.
Reviewed-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/soc.c | 33 +++++++++++++++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 91ff7eca59..6802b6e478 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -1146,6 +1146,37 @@ static int disable_cpu_nodes(void *blob, u32 disabled_cores) return 0; }
+#if defined(CONFIG_IMX8MM) +static int cleanup_nodes_for_efi(void *blob) +{ + static const char * const usbotg_path[] = { + "/soc@0/bus@32c00000/usb@32e40000", + "/soc@0/bus@32c00000/usb@32e50000" + }; + int nodeoff, i, rc; + + for (i = 0; i < ARRAY_SIZE(usbotg_path); i++) { + nodeoff = fdt_path_offset(blob, usbotg_path[i]); + if (nodeoff < 0) + continue; /* Not found, skip it */ + debug("Found %s node\n", usbotg_path[i]); + + rc = fdt_delprop(blob, nodeoff, "extcon"); + if (rc == -FDT_ERR_NOTFOUND) + continue; + if (rc) { + printf("Unable to update property %s:%s, err=%s\n", + usbotg_path[i], "extcon", fdt_strerror(rc)); + return rc; + } + + printf("Remove %s:%s\n", usbotg_path[i], "extcon"); + } + + return 0; +} +#endif + int ft_system_setup(void *blob, struct bd_info *bd) { #ifdef CONFIG_IMX8MQ @@ -1240,6 +1271,8 @@ usb_modify_speed: else if (is_imx8mms() || is_imx8mmsl()) disable_cpu_nodes(blob, 3);
+ cleanup_nodes_for_efi(blob); + #elif defined(CONFIG_IMX8MN) if (is_imx8mnl() || is_imx8mndl() || is_imx8mnsl()) disable_gpu_nodes(blob);
Need to drop phy-reset-gpios before booting linux, this property is legacy property and replaced with reset-gpios.
If provide both, kernel would failed to request the same gpio twice and cause fec not work.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/soc.c | 25 +++++++++++++------------ 1 file changed, 13 insertions(+), 12 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 6802b6e478..f1b998c5c5 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -1149,28 +1149,30 @@ static int disable_cpu_nodes(void *blob, u32 disabled_cores) #if defined(CONFIG_IMX8MM) static int cleanup_nodes_for_efi(void *blob) { - static const char * const usbotg_path[] = { - "/soc@0/bus@32c00000/usb@32e40000", - "/soc@0/bus@32c00000/usb@32e50000" - }; + static const char * const path[][2] = { + { "/soc@0/bus@32c00000/usb@32e40000", "extcon" }, + { "/soc@0/bus@32c00000/usb@32e50000", "extcon" }, + { "/soc@0/bus@30800000/ethernet@30be0000", "phy-reset-gpios" }, + { "/soc@0/bus@30800000/ethernet@30bf0000", "phy-reset-gpios" } + }; int nodeoff, i, rc;
- for (i = 0; i < ARRAY_SIZE(usbotg_path); i++) { - nodeoff = fdt_path_offset(blob, usbotg_path[i]); + for (i = 0; i < ARRAY_SIZE(path); i++) { + nodeoff = fdt_path_offset(blob, path[i][0]); if (nodeoff < 0) continue; /* Not found, skip it */ - debug("Found %s node\n", usbotg_path[i]); + debug("Found %s node\n", path[i][0]);
- rc = fdt_delprop(blob, nodeoff, "extcon"); + rc = fdt_delprop(blob, nodeoff, path[i][1]); if (rc == -FDT_ERR_NOTFOUND) continue; if (rc) { printf("Unable to update property %s:%s, err=%s\n", - usbotg_path[i], "extcon", fdt_strerror(rc)); + path[i][0], path[i][1], fdt_strerror(rc)); return rc; }
- printf("Remove %s:%s\n", usbotg_path[i], "extcon"); + printf("Remove %s:%s\n", path[i][0], path[i][1]); }
return 0; @@ -1271,8 +1273,6 @@ usb_modify_speed: else if (is_imx8mms() || is_imx8mmsl()) disable_cpu_nodes(blob, 3);
- cleanup_nodes_for_efi(blob); - #elif defined(CONFIG_IMX8MN) if (is_imx8mnl() || is_imx8mndl() || is_imx8mnsl()) disable_gpu_nodes(blob); @@ -1320,6 +1320,7 @@ usb_modify_speed: disable_cpu_nodes(blob, 2); #endif
+ cleanup_nodes_for_efi(blob); return 0; } #endif
Peng Fan (OSS)
Teresa Remmet
