[U-Boot] [PATCH] cmd_net: drop spurious comma in U_BOOT_CMD
Building for boards that have CONFIG_CMD_CDP enabled fail with: cmd_net.c:301: error: expected expression before ',' token
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/cmd_net.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/cmd_net.c b/common/cmd_net.c index 44d17db..b131006 100644 --- a/common/cmd_net.c +++ b/common/cmd_net.c @@ -297,7 +297,7 @@ int do_cdp (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
U_BOOT_CMD( cdp, 1, 1, do_cdp, - "Perform CDP network configuration", + "Perform CDP network configuration" ); #endif
Dear Mike Frysinger,
Applied, thanks.
Applied, thanks.
I wish I had tested this before applying - and even more I wish you had run MAKEALL as requested when sumbitting patches.
Reverted, as it breaks building of some boards:
Configuring for LANTEC board... cmd_net.c:301:1: error: macro "U_BOOT_CMD" requires 6 arguments, but only 5 given cmd_net.c:298: warning: data definition has no type or storage class cmd_net.c:298: warning: type defaults to 'int' in declaration of 'U_BOOT_CMD' make[1]: *** [/work/wd/tmp-ppc/common/cmd_net.o] Error 1
Applied, thanks.
actually, as i had stated in one of my other patches, i *was* running MAKEALL but the vast majority of boards were failing (probably because of your patches you noted some time later). for the few boards that didnt fail in that way, they were failing *because of this code*.
i wrote the patch *because* MAKEALL was reporting failures due to this code. but perhaps the failure i was seeing was just fallout of the bad patches you had pushed already. i guess i dont really care because none of my boards were or are failing due to this, and i'll stop trying to fix other people's board failures. -mike
Mike Frysinger
