[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit fa8883a1e39a20e72aaa5093af0c80062cb95757:
Merge branch 'master' of git://git.denx.de/u-boot-i2c (2015-11-27 08:41:03 -0500)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to 3785f57015dbd7582f85fd1c34dcaa26638bf976:
armv8: fsl-layerscape: Fix early MMU table for nand boot (2015-11-30 09:11:13 -0800)
---------------------------------------------------------------- Alison Wang (5): arm: ls1021a: Ensure LS1021 ARM Generic Timer CompareValue Set 64-bit arm: ls1021a: Ensure Generic Timer disabled before jumping into the OS armv8/layerscape: Update MMU table with execute-never bits arm: ls102xa: Update fdt_high and initrd_high for LS1021AQDS board armv8: ls2080a: Define CONFIG_ENV_OVERWRITE to overwrite serial and ethaddr
Gong Qianyu (5): armv8/fsl-layerscape: Remove reference to gdata armv8/ls1043ardb: dts: add dtb support armv8/ls1043aqds: dts: add dtb support armv8/ls1043ardb: add DSPI support armv8/ls1043ardb: add USB support
Mingkai Hu (1): pci/layerscape: add support for LS1043A PCIe LUT register access
Prabhakar Kushwaha (15): armv8: lsch3: Fix lane protocol parsing logic driver: net: fsl-mc: Add create, destroy APIs in flibs driver: net: fsl-mc: Add APIs for DPMAC objects in FLIB armv8: ls2085aqds: Print function name during SerDes error driver: ldpaa: Add api to return linked PHY ID of DPMAC driver: net: fsl-mc: Increase MC command timeout driver: net: fsl-mc: Add DPAA2 commands to manage MC driver: net: fsl-mc: Create DPAA2 object at run-time driver: net: ldpaa: Use DPMAC as net device driver: net: ldpaa: Add debug information driver: net: ldpaa: Fix Rx buffer alignment armv8: LS2080A: Rename LS2085A to reflect LS2080A armv8: ls2085a: Add support of LS2085A SoC board/ls2080qds: Fix typo in README for QSGMII riser card armv8: ls2085a: Add workaround of errata A009635
Shaohui Xie (2): armv8/ls1043aqds: add LS1043AQDS board support net: phy: added aquantia PHY AQR405 support
York Sun (4): drivers/ddr/fsl: Enable detection of one DDR controller operation for LSCH3 drivers/ddr/fsl: Fix typo in BIST test for DDR4 armv8: fsl-layerscape: Fix "cpu release" command armv8: fsl-layerscape: Fix early MMU table for nand boot
README | 3 + arch/arm/Kconfig | 53 +- arch/arm/cpu/armv7/ls102xa/cpu.c | 10 + arch/arm/cpu/armv7/ls102xa/timer.c | 3 +- arch/arm/cpu/armv8/cache_v8.c | 4 +- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 10 +- arch/arm/cpu/armv8/fsl-layerscape/README.lsch3 | 85 ++- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 10 +- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 2 +- .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 25 +- .../arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c | 11 + .../{ls2085a_serdes.c => ls2080a_serdes.c} | 5 + arch/arm/cpu/armv8/fsl-layerscape/mp.c | 6 + arch/arm/cpu/armv8/fsl-layerscape/soc.c | 45 +- arch/arm/cpu/armv8/fsl-layerscape/spl.c | 6 +- arch/arm/dts/Makefile | 6 +- arch/arm/dts/fsl-ls1043a-qds.dts | 124 +++ arch/arm/dts/fsl-ls1043a-rdb.dts | 103 +++ arch/arm/dts/fsl-ls1043a.dtsi | 186 +++++ .../{fsl-ls2085a-qds.dts => fsl-ls2080a-qds.dts} | 8 +- .../{fsl-ls2085a-rdb.dts => fsl-ls2080a-rdb.dts} | 8 +- .../arm/dts/{fsl-ls2085a.dtsi => fsl-ls2080a.dtsi} | 4 +- arch/arm/include/asm/arch-fsl-layerscape/config.h | 26 +- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 87 ++- arch/arm/include/asm/arch-fsl-layerscape/fdt.h | 1 + .../include/asm/arch-fsl-layerscape/fsl_serdes.h | 2 +- .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 10 +- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 10 +- .../{ls2085a_stream_id.h => ls2080a_stream_id.h} | 4 +- arch/arm/include/asm/arch-fsl-layerscape/soc.h | 11 + arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 2 +- arch/arm/include/asm/armv8/mmu.h | 2 +- arch/arm/include/asm/global_data.h | 2 +- board/freescale/common/vid.c | 22 + board/freescale/ls1043aqds/Kconfig | 15 + board/freescale/ls1043aqds/MAINTAINERS | 9 + board/freescale/ls1043aqds/Makefile | 9 + board/freescale/ls1043aqds/README | 96 +++ board/freescale/ls1043aqds/ddr.c | 131 ++++ board/freescale/ls1043aqds/ddr.h | 60 ++ board/freescale/ls1043aqds/eth.c | 492 ++++++++++++ board/freescale/ls1043aqds/ls1043aqds.c | 333 ++++++++ board/freescale/ls1043aqds/ls1043aqds_pbi.cfg | 14 + board/freescale/ls1043aqds/ls1043aqds_qixis.h | 39 + board/freescale/ls1043aqds/ls1043aqds_rcw_nand.cfg | 7 + .../freescale/ls1043aqds/ls1043aqds_rcw_sd_ifc.cfg | 8 + board/freescale/ls1043ardb/ls1043ardb.c | 16 + board/freescale/{ls2085a => ls2080a}/Kconfig | 12 +- board/freescale/ls2080a/MAINTAINERS | 10 + board/freescale/ls2080a/Makefile | 8 + board/freescale/{ls2085a => ls2080a}/README | 2 +- board/freescale/{ls2085a => ls2080a}/ddr.c | 3 +- board/freescale/{ls2085a => ls2080a}/ddr.h | 0 .../{ls2085a/ls2085a.c => ls2080a/ls2080a.c} | 2 + board/freescale/{ls2085ardb => ls2080aqds}/Kconfig | 6 +- board/freescale/ls2080aqds/MAINTAINERS | 10 + .../freescale/{ls2085aqds => ls2080aqds}/Makefile | 2 +- board/freescale/{ls2085aqds => ls2080aqds}/README | 18 +- board/freescale/{ls2085ardb => ls2080aqds}/ddr.c | 5 +- board/freescale/{ls2085aqds => ls2080aqds}/ddr.h | 0 board/freescale/{ls2085aqds => ls2080aqds}/eth.c | 108 +-- .../ls2085aqds.c => ls2080aqds/ls2080aqds.c} | 9 +- .../ls2080aqds_qixis.h} | 0 board/freescale/{ls2085aqds => ls2080ardb}/Kconfig | 6 +- board/freescale/ls2080ardb/MAINTAINERS | 10 + .../freescale/{ls2085ardb => ls2080ardb}/Makefile | 2 +- board/freescale/{ls2085ardb => ls2080ardb}/README | 12 +- board/freescale/{ls2085aqds => ls2080ardb}/ddr.c | 5 +- board/freescale/{ls2085ardb => ls2080ardb}/ddr.h | 0 .../eth_ls2085rdb.c => ls2080ardb/eth_ls2080rdb.c} | 2 +- .../ls2085ardb.c => ls2080ardb/ls2080ardb.c} | 9 +- .../ls2080ardb_qixis.h} | 0 board/freescale/ls2085a/MAINTAINERS | 8 - board/freescale/ls2085a/Makefile | 8 - board/freescale/ls2085aqds/MAINTAINERS | 8 - board/freescale/ls2085ardb/MAINTAINERS | 8 - configs/ls1043aqds_defconfig | 6 + configs/ls1043aqds_nand_defconfig | 5 + configs/ls1043aqds_nor_ddr3_defconfig | 3 + configs/ls1043aqds_sdcard_ifc_defconfig | 5 + configs/ls1043ardb_defconfig | 5 + configs/ls1043ardb_nand_defconfig | 5 + configs/ls1043ardb_sdcard_defconfig | 5 + configs/ls2080a_emu_defconfig | 15 + configs/ls2080a_simu_defconfig | 16 + configs/ls2080aqds_defconfig | 15 + configs/ls2080aqds_nand_defconfig | 9 + configs/ls2080ardb_defconfig | 15 + configs/ls2080ardb_nand_defconfig | 9 + configs/ls2085a_emu_defconfig | 4 +- configs/ls2085a_simu_defconfig | 4 +- configs/ls2085aqds_defconfig | 6 +- configs/ls2085aqds_nand_defconfig | 4 +- configs/ls2085ardb_defconfig | 6 +- configs/ls2085ardb_nand_defconfig | 4 +- doc/README.fsl-trustzone-components | 4 +- drivers/ddr/fsl/fsl_ddr_gen4.c | 28 +- drivers/ddr/fsl/main.c | 1 + drivers/ddr/fsl/util.c | 40 + drivers/net/fsl-mc/Makefile | 3 +- drivers/net/fsl-mc/dpbp.c | 41 + drivers/net/fsl-mc/dpio/dpio.c | 40 + drivers/net/fsl-mc/dpmac.c | 222 ++++++ drivers/net/fsl-mc/dpni.c | 40 + drivers/net/fsl-mc/dprc.c | 46 ++ drivers/net/fsl-mc/mc.c | 800 +++++++++++++++----- drivers/net/fsl-mc/mc_sys.c | 2 +- drivers/net/ldpaa_eth/Makefile | 3 +- drivers/net/ldpaa_eth/ldpaa_eth.c | 295 +++++++- drivers/net/ldpaa_eth/ldpaa_eth.h | 23 +- drivers/net/ldpaa_eth/ldpaa_wriop.c | 27 +- drivers/net/ldpaa_eth/{ls2085a.c => ls2080a.c} | 0 drivers/net/phy/aquantia.c | 15 + drivers/pci/pcie_layerscape.c | 16 +- include/configs/ls1021aqds.h | 8 +- include/configs/ls1043aqds.h | 387 ++++++++++ include/configs/ls1043ardb.h | 23 + .../configs/{ls2085a_common.h => ls2080a_common.h} | 16 +- include/configs/{ls2085a_emu.h => ls2080a_emu.h} | 11 +- include/configs/{ls2085a_simu.h => ls2080a_simu.h} | 11 +- include/configs/{ls2085aqds.h => ls2080aqds.h} | 16 +- include/configs/{ls2085ardb.h => ls2080ardb.h} | 16 +- include/fsl-mc/fsl_dpbp.h | 48 ++ include/fsl-mc/fsl_dpio.h | 60 ++ include/fsl-mc/fsl_dpmac.h | 468 ++++++++++++ include/fsl-mc/fsl_dpni.h | 189 +++++ include/fsl-mc/fsl_dprc.h | 84 ++ include/fsl-mc/fsl_mc.h | 10 +- include/fsl-mc/fsl_mc_private.h | 26 +- include/fsl-mc/ldpaa_wriop.h | 3 +- include/fsl_ddr.h | 1 + include/linux/usb/xhci-fsl.h | 15 +- 132 files changed, 5021 insertions(+), 556 deletions(-) rename arch/arm/cpu/armv8/fsl-layerscape/{ls2085a_serdes.c => ls2080a_serdes.c} (96%) create mode 100644 arch/arm/dts/fsl-ls1043a-qds.dts create mode 100644 arch/arm/dts/fsl-ls1043a-rdb.dts create mode 100644 arch/arm/dts/fsl-ls1043a.dtsi rename arch/arm/dts/{fsl-ls2085a-qds.dts => fsl-ls2080a-qds.dts} (80%) rename arch/arm/dts/{fsl-ls2085a-rdb.dts => fsl-ls2080a-rdb.dts} (67%) rename arch/arm/dts/{fsl-ls2085a.dtsi => fsl-ls2080a.dtsi} (97%) rename arch/arm/include/asm/arch-fsl-layerscape/{ls2085a_stream_id.h => ls2080a_stream_id.h} (93%) create mode 100644 board/freescale/ls1043aqds/Kconfig create mode 100644 board/freescale/ls1043aqds/MAINTAINERS create mode 100644 board/freescale/ls1043aqds/Makefile create mode 100644 board/freescale/ls1043aqds/README create mode 100644 board/freescale/ls1043aqds/ddr.c create mode 100644 board/freescale/ls1043aqds/ddr.h create mode 100644 board/freescale/ls1043aqds/eth.c create mode 100644 board/freescale/ls1043aqds/ls1043aqds.c create mode 100644 board/freescale/ls1043aqds/ls1043aqds_pbi.cfg create mode 100644 board/freescale/ls1043aqds/ls1043aqds_qixis.h create mode 100644 board/freescale/ls1043aqds/ls1043aqds_rcw_nand.cfg create mode 100644 board/freescale/ls1043aqds/ls1043aqds_rcw_sd_ifc.cfg rename board/freescale/{ls2085a => ls2080a}/Kconfig (66%) create mode 100644 board/freescale/ls2080a/MAINTAINERS create mode 100644 board/freescale/ls2080a/Makefile rename board/freescale/{ls2085a => ls2080a}/README (97%) rename board/freescale/{ls2085a => ls2080a}/ddr.c (99%) rename board/freescale/{ls2085a => ls2080a}/ddr.h (100%) rename board/freescale/{ls2085a/ls2085a.c => ls2080a/ls2080a.c} (98%) rename board/freescale/{ls2085ardb => ls2080aqds}/Kconfig (67%) create mode 100644 board/freescale/ls2080aqds/MAINTAINERS rename board/freescale/{ls2085aqds => ls2080aqds}/Makefile (83%) rename board/freescale/{ls2085aqds => ls2080aqds}/README (95%) rename board/freescale/{ls2085ardb => ls2080aqds}/ddr.c (98%) rename board/freescale/{ls2085aqds => ls2080aqds}/ddr.h (100%) rename board/freescale/{ls2085aqds => ls2080aqds}/eth.c (86%) rename board/freescale/{ls2085aqds/ls2085aqds.c => ls2080aqds/ls2080aqds.c} (98%) rename board/freescale/{ls2085aqds/ls2085aqds_qixis.h => ls2080aqds/ls2080aqds_qixis.h} (100%) rename board/freescale/{ls2085aqds => ls2080ardb}/Kconfig (67%) create mode 100644 board/freescale/ls2080ardb/MAINTAINERS rename board/freescale/{ls2085ardb => ls2080ardb}/Makefile (72%) rename board/freescale/{ls2085ardb => ls2080ardb}/README (94%) rename board/freescale/{ls2085aqds => ls2080ardb}/ddr.c (98%) rename board/freescale/{ls2085ardb => ls2080ardb}/ddr.h (100%) rename board/freescale/{ls2085ardb/eth_ls2085rdb.c => ls2080ardb/eth_ls2080rdb.c} (98%) rename board/freescale/{ls2085ardb/ls2085ardb.c => ls2080ardb/ls2080ardb.c} (97%) rename board/freescale/{ls2085ardb/ls2085ardb_qixis.h => ls2080ardb/ls2080ardb_qixis.h} (100%) delete mode 100644 board/freescale/ls2085a/MAINTAINERS delete mode 100644 board/freescale/ls2085a/Makefile delete mode 100644 board/freescale/ls2085aqds/MAINTAINERS delete mode 100644 board/freescale/ls2085ardb/MAINTAINERS create mode 100644 configs/ls1043aqds_defconfig create mode 100644 configs/ls1043aqds_nand_defconfig create mode 100644 configs/ls1043aqds_nor_ddr3_defconfig create mode 100644 configs/ls1043aqds_sdcard_ifc_defconfig create mode 100644 configs/ls2080a_emu_defconfig create mode 100644 configs/ls2080a_simu_defconfig create mode 100644 configs/ls2080aqds_defconfig create mode 100644 configs/ls2080aqds_nand_defconfig create mode 100644 configs/ls2080ardb_defconfig create mode 100644 configs/ls2080ardb_nand_defconfig create mode 100644 drivers/net/fsl-mc/dpmac.c rename drivers/net/ldpaa_eth/{ls2085a.c => ls2080a.c} (100%) create mode 100644 include/configs/ls1043aqds.h rename include/configs/{ls2085a_common.h => ls2080a_common.h} (97%) rename include/configs/{ls2085a_emu.h => ls2080a_emu.h} (92%) rename include/configs/{ls2085a_simu.h => ls2080a_simu.h} (95%) rename include/configs/{ls2085aqds.h => ls2080aqds.h} (96%) rename include/configs/{ls2085ardb.h => ls2080ardb.h} (96%) create mode 100644 include/fsl-mc/fsl_dpmac.h
Thanks.
York
On Mon, Nov 30, 2015 at 11:32:33AM -0800, York Sun wrote:
Tom,
York Sun
