[U-Boot] [PATCH] image: constify lookup tables
These are pure lookup tables -- no need to be writable.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/image.c | 14 +++++++------- include/image.h | 4 ++-- 2 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/common/image.c b/common/image.c index 385464d..0005fc5 100644 --- a/common/image.c +++ b/common/image.c @@ -74,7 +74,7 @@ static const image_header_t* image_get_ramdisk (ulong rd_addr, uint8_t arch, #include <image.h> #endif /* !USE_HOSTCC*/
-static table_entry_t uimage_arch[] = { +static const table_entry_t uimage_arch[] = { { IH_ARCH_INVALID, NULL, "Invalid ARCH", }, { IH_ARCH_ALPHA, "alpha", "Alpha", }, { IH_ARCH_ARM, "arm", "ARM", }, @@ -96,7 +96,7 @@ static table_entry_t uimage_arch[] = { { -1, "", "", }, };
-static table_entry_t uimage_os[] = { +static const table_entry_t uimage_os[] = { { IH_OS_INVALID, NULL, "Invalid OS", }, { IH_OS_LINUX, "linux", "Linux", }, #if defined(CONFIG_LYNXKDI) || defined(USE_HOSTCC) @@ -129,7 +129,7 @@ static table_entry_t uimage_os[] = { { -1, "", "", }, };
-static table_entry_t uimage_type[] = { +static const table_entry_t uimage_type[] = { { IH_TYPE_INVALID, NULL, "Invalid Image", }, { IH_TYPE_FILESYSTEM, "filesystem", "Filesystem Image", }, { IH_TYPE_FIRMWARE, "firmware", "Firmware", }, @@ -144,7 +144,7 @@ static table_entry_t uimage_type[] = { { -1, "", "", }, };
-static table_entry_t uimage_comp[] = { +static const table_entry_t uimage_comp[] = { { IH_COMP_NONE, "none", "uncompressed", }, { IH_COMP_BZIP2, "bzip2", "bzip2 compressed", }, { IH_COMP_GZIP, "gzip", "gzip compressed", }, @@ -516,7 +516,7 @@ static void genimg_print_time (time_t timestamp) * long entry name if translation succeeds * msg otherwise */ -char *get_table_entry_name (table_entry_t *table, char *msg, int id) +char *get_table_entry_name(const table_entry_t *table, char *msg, int id) { for (; table->id >= 0; ++table) { if (table->id == id) @@ -563,10 +563,10 @@ const char *genimg_get_comp_name (uint8_t comp) * entry id if translation succeeds * -1 otherwise */ -int get_table_entry_id (table_entry_t *table, +int get_table_entry_id(const table_entry_t *table, const char *table_name, const char *name) { - table_entry_t *t; + const table_entry_t *t; #ifdef USE_HOSTCC int first = 1;
diff --git a/include/image.h b/include/image.h index 49d6280..005e0d2 100644 --- a/include/image.h +++ b/include/image.h @@ -300,14 +300,14 @@ typedef struct table_entry { * entry that matches the given short name. If a matching entry is * found, it's id is returned to the caller. */ -int get_table_entry_id (table_entry_t *table, +int get_table_entry_id(const table_entry_t *table, const char *table_name, const char *name); /* * get_table_entry_name() scans the translation table trying to find * an entry that matches the given id. If a matching entry is found, * its long name is returned to the caller. */ -char *get_table_entry_name (table_entry_t *table, char *msg, int id); +char *get_table_entry_name(const table_entry_t *table, char *msg, int id);
const char *genimg_get_os_name (uint8_t os); const char *genimg_get_arch_name (uint8_t arch);
Dear Mike Frysinger,
Applied to "next" branch, thanks.
Mike Frysinger
